MTSMC-LVW3-U.R4
MTSMC-LVW3-U.R4
    MULTI-TECHSYSTEMS
    DIP-45
    手机,导航 4G LTE CAT-1(Verizon),GNSS RF 收发器模块 700MHz,1.7GHz,1.9GHz 不含天线,U.FL 通孔
MTSMC-LVW3-U.R4 数据手册
SocketModem® Cell Embedded Cellular Modems 4G-LTE Models SocketModem® Cell embedded cellular modem is a complete, ready-to-integrate communications device ideal for customers looking to add 4G-LTE cellular communications to their IoT/M2M BENEFITS • Approved by carriers and regulatory agencies saving customers time, money, and protection from the risks associated with pursuing their own certifications • Quick to market leveraging MultiTech’s approvals • Interchangeable communications devices for easy migration to future networks • Long solution lifecycle reduces redesign time and cost • Support from leading experts in IoT/M2M technology solutions. These communications devices enable easy technology transitions and allow developers to add wireless communication to products with a minimum of development time and expense. The SocketModem Cell embedded cellular modems are carrier approved and end-device certified, decreasing time to market while saving customers money. Your Devices & Data FEATURES • 4G Models (Cat 4, Cat 1 and Cat M1) • Global capable Cat 4 and Cat M1/NB-IoT models • 4G Cat 4, Cat 1 Sprint and Cat M1 include GNSS • Universal Socket connectivity • Short Message Services (SMS) • Serial or USB interfaces • Serial interface supports speeds up to 921.6K bps • AT command compatible • USB 2.0 HS compatible • Two-year warranty Connecting Your Devices Insight + Action + Control Energy Alerts Financial / Retail Real-Time Management Healthcare Remote Monitoring Wireless Service Provider Asset Management Platform Reports HIGHLIGHTS Power Saving Modes (Cat M1 Models) Extended Discontinuous Reception (eDRX) mode increases the length of time the end device can sleep before it has to check in with the network which saves power. Power Saving Mode (PSM) allows the device to notify the network it is going to sleep or dormant indefinitely only waking up based on user defined timer. Once the device wakes up and transmits it will stay awake for a few frames of time in case the network needs to reach that device. A device using PSM transmitting a small amount of data once per day could last many years using 2 AA batteries. (Note: Some power saving modes will be available in a future firmware release.) SPECIFICATIONS Models Performance Frequency Bands (MHz) MTSMC-L4G1 MTSMC-L4G1-U MTSMC-L4N1 MTSMC-L4N1-U MTSMC-L4E1 MTSMC-L4E1-U MTSMC-LAT3 MTSMC-LAT3-U LTE 3GPP Release 11 (Category 4; 150 Mbps peak downlink/50 Mbps peak uplink) with HSPA and 2G Fallback LTE FDD Cat.4, 3GPP release 10 compliant (Category 4; 150 Mbps peak downlink/ 50 Mbps peak uplink) with 3G Fallback LTE FDD Cat.4, 3GPP release 10 compliant (Category 4; 150 Mbps peak downlink/ 50 Mbps peak uplink) with 3G/2G Fallback LTE 3GPP Release 9 (Category 1; 10 Mbps peak downlink/ 5 Mbps peak uplink) with HSPA Fallback 4G FDD: B1(2100), B2(1900), B3(1800), B4(AWS1700), B5(850), B7(2600), B8(900), B12/ B13(700), B18(850), B19(850), B20(800), B25(1900), B26(850), B28(700) TDD: B38(2600), B39(1900), B40(2300), B41(2500) 4G: B2(1900), B4(AWS1700), B5(850), B12(700a), B13(700c), B14(700 FirstNet),† B66(AWS-3 1700), B71(600) 4G: B1(2100), B3(1800), B7(2600), B8(900), B20(800), B28A(700) AT&T: B2, B4, B5, B12, B14 3G: B1(2100), B3(1800), B8(900) 2G: B3(1800), B8(900) Verizon: B4, B13 3G: B1(2100), B2(1900), B4(AWS1700), B5(850), B6(800), B8(900), B19(850) 4G: B12/B13(700), B5(850), B4(AWS1700), B2(1900) 3G: B5(850), B2(1900) 3G: B2(1900), B4(AWS1700), B5(850) 2G: B2(1900), B3(1800), B5(850), B8(900) SMS Mobile Originate, Mobile Terminated and Cell Broadcast / PDU or Text Mode USB USB 2.0 high speed compatible (-U Models) TCP/IP Functions* Connectors FTP, SMTP, SSL, TCP, UDP Antenna : 3 UFL (Cellular, Rx Diversity/MIMO, GPS) / Mini SIM (2FF); 1.8V & 3V Dimensions Power Draw* Antenna: 2 UFL (Cellular, Rx Diversity/MIMO) / Mini SIM (2FF); 1.8V & 3V 3.15" x 1.375" (80.010 mm x 34.925 mm) Serial Model @ 5VDC; 22.6mA sleep, 46mA idle, 562mA average at max power Serial Model @ 5VDC; 4mA sleep, 20mA idle, 615mA average at max power USB Model @ 5VDC; 46mA idle, USB Model @ 5VDC; 21mA idle, 577mA average at max power 672mA average at max power Input Power Serial Model @ 5VDC; 8mA sleep, 13mA idle, 747mA average at max power USB Model @ 5VDC; 816mA average at max power Serial Model @ 5VDC; 13mA sleep, 20mA idle, 400mA average at max power USB Model @ 5VDC; sleep N/A, 32mA idle, 432mA average at max power 3.3V – 5VDC Environmental Operating Temperature -40° C to +85° C (-40° F to +185° F) Storage Temperature -40° C to +85° C (-40° F to +185° F) Relative Humidity 20% to 90% RH noncondensing Certifications EMC/Radio Compliance Safety Network Carrier FCC Part 15 Class B FCC Part 22, 24, 27 CE Mark, RED (EU) RCM (AU) FCC Part 15 Class B FCC Part 22, 24, 27 CE Mark, RED FCC Part 15 Class B FCC Part 22, 24, 27 UL/cUL 60950-1 2nd ED, IEC 60950-1 2nd ED +Am.2 UL 60950-1 2nd ED, cUL 60950-1 2nd ED IEC 60950-1 2nd ED UL 60950-1 2nd ED, cUL 60950-1 2nd ED, IEC 60950-1 2nd ED PTCRB PTCRB N/A PTCRB AT&T, Verizon AT&T, Verizon N/A AT&T * See device guides or AT command guides for additional information. † All future end-user (OEM) devices will and must go through FirstNet certification prior to being included in the FirstNet device ecosystem. Developer Kits Developer Kits allow you to plug in the communications device and use it for testing, programming and evaluation. MTUDK2-ST-CELL developer kit is designed to work with all of our cellular SocketModem® Cell and Dragonfly™ cellular modems. Developer kits include a development board and all the necessary accessories to get you up and running right out of the box. SPECIFICATIONS Models Performance Frequency Bands (MHz) MTSMC-LVW3 MTSMC-LVW3-U MTSMC-LSP3 MTSMC-LSP3-U MTSMC-MNG2 MTSMC-MNG2-U MTSMC-MNA1 MTSMC-MNA1-U LTE 3GPP Release 9 (Category 1; 10 Mbps peak downlink/ 5 Mbps peak uplink) (No Fallback) LTE 3GPP Release 10 (Category 1; 10 Mbps peak downlink/ 5 Mbps peak uplink) LTE 3GPP Release 13 (Category M1; Up to 300 Kb/s Downlink Up to 375 Kb/s Uplink NB1; Up to 250 Kb/s Downlink (multi-tone) Up to 20 Kb/s Uplink (single-tone)) LTE 3GPP Release 13 (Category M1; Up to 300 Kbps downlink & up to 375 Kbps uplink) 4G: B1(2100)/B2(1900/ B3(1800)/B4(AWS1700)/ B5(850)/B8(900)/ B12(700)/ B13(700)/ B18(800)/ B19(800)/ B20(800)/ B26(850)/ B28(700)/ B39(1900) AT&T: B12(700), B4(AWS1700), B2(1900) B13(700), B4(AWS1700), B2(1900) 4G: B12(700), B5/25(850), B4(AWS1700), B2/25(1900), B25(1900+) Verizon: B13(700), B4(AWS1700) 2G: B2(1900)/B3(1800)/ B5(850)/B8(900) SMS Mobile Originate, Mobile Terminated and Cell Broadcast / PDU or Text Mode USB USB 2.0 high speed compatible (-U Models) TCP/IP Functions Connectors FTP, SMTP, SSL, TCP & UDP Antenna: 2 UFL (Cellular, Rx Diversity/MIMO) Mini SIM (2FF); 1.8V & 3V Antenna: 3 UFL (Cellular, Rx Diversity/MIMO, GPS) Mini SIM (2FF); 1.8V & 3V Dimensions Antenna: 2 UFL (Cellular, GPS) Mini SIM (2FF); 1.8V & 3V Antenna: 2 UFL (Cellular, GPS) Mini SIM (2FF); 1.8V & 3V 3.15" x 1.375" (80.010 mm x 34.925 mm) Serial Model @ 5VDC; 16mA sleep, 19mA idle, 373mA average at max power Serial Model @ 5VDC; 7mA sleep, 55mA idle, 551mA average at max power Serial Model @ 5VDC; 6mA sleep, 14mA idle, 191mA average at max power Serial Model @ 5VDC; 9mA sleep, 14mA idle, 122mA average at max power USB Model @ 5VDC; sleep N/A, 104mA idle, 388mA average at max power USB Model @ 5VDC; sleep N/A, 69mA idle, 603mA average at max power USB Model @ 5VDC; sleep N/A, 27mA idle, 205mA average at max power USB Model @ 5VDC; sleep N/A, 28mA idle, 151mA average at max power Power Draw* Input Power 3.3V – 5VDC Environmental Operating Temperature -40° C to +85° C (-40° F to +185° F) Storage Temperature -40° C to +85° C (-40° F to +185° F) Relative Humidity 20% to 90% RH noncondensing Certifications EMC/Radio Compliance Safety Network Carrier FCC Part 15 Class B FCC Part 22, 24, 27 CE Mark, RED (EU), RCM (AU) FCC Part 15 Class B FCC Part 27 FCC Part 15 Class B FCC Part 22, 24, 27 UL 60950-1 2nd ED, cUL 60950-1 2nd ED, IEC 60950-1 2nd ED UL 60950-1 2nd ED UL/cUL 60950-1 2nd ED, IEC 60950-1 2nd ED +Am.2 N/A N/A PTCRB Verizon Sprint AT&T, Verizon * See device guides or AT command guides for additional information. FCC Part 15 Class B FCC Part 22, 24, 27 Services & Warranty SocketModem Cell Pin-Out MultiTech’s comprehensive Support Services programs offer a full array The SocketModem Cell cellular of options to suit your specific modem interfaces easily with existing needs. These services are aimed products through a standard serial at protecting your investment, communication channel. The serial extending the life of your solution DTE channel is capable of transfer or product, and reducing total speeds to 921.6K bps (depending on cost of ownership. Our seasoned model) and can be interfaced directly technical experts, with an average to a UART or microcontroller. The tenure of more than 10 years, can walk you through smooth complete on-board RF transceiver installations, troubleshoot issues interfaces with an antenna for direct and help you with configurations. connection to wireless data networks. It also includes an onboard LED to Technical Support Services display network status. At MultiTech, we’re committed to providing you personalized attention and quality service while ORDERING INFORMATION providing you a quick response SocketModem® Cell LTE Models to your product support needs. Model Description Region MTSMC-L4G1 LTE Cat 4 Embedded Modem w/Fallback & GNSS (Serial Interface) Global MTSMC-L4G1-U LTE Cat 4 Embedded Modem w/Fallback & GNSS (USB Interface) Global MTSMC-L4N1 LTE Cat 4 Embedded Modem w/Fallback & GNSS (Serial Interface) (AT&T/Verizon) US/Can MTSMC-L4N1-U LTE Cat 4 Embedded Modem w/Fallback & GNSS (USB Interface) (AT&T/Verizon) US/Can MTSMC-L4E1 LTE Cat 4 Embedded Modem w/Fallback & GNSS* (Serial Interface) Euro/GB MTSMC-L4E1-U LTE Cat 4 Embedded Modem w/Fallback & GNSS* (USB Interface) Euro/GB MTSMC-LAT3 LTE Cat 1 Embedded Modem w/Fallback (Serial Interface) (AT&T) US/Can representative or visit MTSMC-LAT3-U LTE Cat 1 Embedded Modem w/Fallback (USB Interface) (AT&T) US/Can www.multitech.com/support.go MTSMC-LVW3 LTE Cat 1 Embedded Modem w/o Fallback (Serial Interface) (Verizon) US MTSMC-LVW3-U LTE Cat 1 Embedded Modem w/o Fallback (USB Interface) (Verizon) US MTSMC-LSP3 LTE Cat 1 Embedded Modem w/GNSS w/o Fallback (Serial Interface) (Sprint) US MTSMC-LSP3-U LTE Cat 1 Embedded Modem w/GNSS w/o Fallback (USB Interface) (Sprint) US MTSMC-MNG2 LTE Cat M1/NB/2G Embedded Modem w/GNSS (Serial Interface) MTSMC-MNG2-U LTE Cat M1/NB/2G Embedded Modem w/GNSS (USB Interface) MTSMC-MNA1 LTE Cat M1 Embedded Modem w/GNSS (Serial Interface) (AT&T/Verizon) US/Can MTSMC-MNA1-U LTE Cat M1 Embedded Modem w/GNSS (USB Interface) (AT&T/Verizon) US/Can Model Description Region MTUDK2-ST-CELL.R1 SocketModem® & Dragonfly Developer Kit (DB9 RS-232 Connector and USB) Global MTUDK2-ST-CELL SocketModem & Dragonfly Developer Kit - Cellular Global We have several options of support for you to choose from. For additional information on Support Services as well as other service offerings, please contact your MultiTech Global Global Developer Kit Ordering part numbers as listed are 50 packs. To order a single pack add a –SP to the end of the ordering part number. (i.e. MTSMC-L4N1-SP) Go to www.multitech.com for detailed product model numbers. World Headquarters Multi-Tech Systems, Inc. 2205 Woodale Drive Mounds View, MN 55112 U.S.A. Tel: 763-785-3500 Email: sales@multitech.com www.multitech.com Produced in the U.S. of U.S. and non-U.S. components. Features and specifications are subject to change without notice. Trademarks and Registered Trademarks: MultiTech and the MultiTech logo, SocketModem, Dragonfly: Multi-Tech Systems, Inc. All other products and technologies are the trademarks or registered trademarks of their respective holders. 2023-08 • 86002214 • © 2023 Multi-Tech Systems, Inc. All rights reserved.
MTSMC-LVW3-U.R4 价格&库存
很抱歉,暂时无法提供与“MTSMC-LVW3-U.R4”相匹配的价格&库存,您可以联系我们找货
