S O L I D
S TAT E
Your TOTAL solutions source!
INC.
1N3305 – 1N3350
1N4549 – 1N4556
50 WATTS
ZENER
DIODES
DO5
ZENER DIODES
Units are available with anodeto-case and cathode-to-case
connections (standard and
reverse polarity). For reverse
polarity add suffix “R” to type
number.
MAXIMUM RATINGS:
Junction and Storage
Temperature: -65°C to +175°C
DC Power Dissipation: 50 Watts
(Derate 0.5W/°C above 75°C)
• Standard polarity is anode-to-case
TOLERANCE DESIGNATION:
Standard voltage tolerances are
+/-5% with B suffix, +/-10%
with an A suffix and +/-20%
with no suffix.
S O LID
• Reverse polarity with cathode-to-case by designation R suffix in part number, e.g. 1N3305RB, etc.
S T A T E 46 Farrand Street, Bloomfield, NJ 07003 • 800.631.2075
INC.
In NJ: 973.429.8700 • Fax: 973.429.8683 • www.solidstateinc.com
S O L I D
S TAT E
1N3305 – 1N3350
1N4549 – 1N4556
INC.
50 WATTS
ZENER
DIODES
ELECTRICAL CHARACTERISTICS (TC = 30°C unless otherwise specified, VF = 1.5 V max @ 10 A on all types)
Type
Number
*VR1 – Test Voltage for 5%
Tolerance Device
VR2 – Test Voltage for 10%
Tolerance Device
No Leakage Specified as 20%
Tolerance Device
• Standard voltage tolerance are
with an A suffix, and +/-20%
with no suffix
anode-to-case
cathode-to-case by
designating R suffix in part
S O LID
1N4549
1N4550
1N4551
1N4552
1N4553
1N4554
1N3305
1N4555
1N3306
1N4556
1N3307
1N3308
1N3309
1N3310
1N3311
1N3312
1N3313
1N3314
1N3315
1N3316
1N3317
1N3318
1N3319
1N3320
1N3321
1N3322
1N3323
1N3324
1N3325
1N3326
1N3327
1N3328
1N3329
1N3330
1N3331
1N3332
1N3333
1N3334
1N3335
1N3336
1N3337
1N3338
1N3339
1N3340
1N3341
1N3342
1N3343
1N3344
1N3345
1N3346
1N3347
1N3348
1N3349
1N3350
Nominal
Zener
Voltage
VZ @ IZT
Volts
Test
Current
(IZT)
mA
Max Zener Impedance
ZZT @ IZT
Ohms
ZZK @ IZT
= 5mA
Ohms
Max DC
Zener
75°C Case
Temp
(IZM)mA
3.9
4.3
4.7
5.1
5.6
6.2
6.8
6.8
7.5
7.5
8.2
9.1
10
11
12
13
14
15
16
17
18
19
24
25
27
30
33
36
39
43
45
47
50
51
52
56
62
68
75
82
91
100
105
110
120
130
140
150
160
175
180
200
3200
2900
2650
2450
2250
2000
1850
1850
1700
1650
1500
1370
1200
1100
1000
960
890
830
780
740
700
660
630
570
520
500
460
420
380
350
320
290
280
270
250
245
240
220
200
180
170
150
140
120
120
110
100
95
90
85
80
70
68
65
0.16
0.16
0.12
0.12
0.12
0.14
0.2
0.16
0.3
0.24
0.4
0.5
0.6
0.8
1.0
1.1
1.2
1.4
1.6
1.8
2.0
2.2
2.4
2.5
2.6
2.7
2.8
3.0
3.2
3.5
4.0
4.5
4.5
5.0
5.0
5.2
5.5
6
7
8
9
11
15
30
40
50
60
75
80
85
90
100
400
500
600
650
900
1000
70
200
70
100
70
70
80
80
80
80
80
80
80
80
80
80
80
80
80
90
90
90
90
90
90
90
100
100
100
100
100
110
120
140
150
160
180
200
210
220
240
275
325
400
450
500
525
600
11900
10650
9700
8900
8100
7300
6600
6650
5900
6050
5200
4800
4300
3900
3600
3300
3000
2800
2650
2500
2300
2200
2100
1900
1750
1550
1500
1400
1300
1150
1050
975
930
880
830
810
790
740
660
600
540
490
420
400
380
365
335
310
290
270
250
230
220
200
Reverse Leakage Current
IRMax
VR1
VR2
150
150
100
10
75
10
50
25
10
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
0.5
0.5
1.0
1.0
1.0
2.0
4.5
2.0
5.0
3.0
5.4
6.1
6.7
8.4
9.1
9.9
10.6
11.4
12.2
13.0
13.7
14.4
15.2
16.7
18.2
19.0
20.6
22.8
25.1
27.4
29.7
32.7
34.2
35.8
38.0
38.8
39.5
42.6
47.1
51.7
56.0
62.2
69.2
76.0
79.8
83.6
91.2
98.8
106.4
114.0
121.6
133.0
136.8
152.0
0.5
0.5
1.0
1.0
1.0
2.0
4.3
2.0
4.7
3.0
5.2
5.7
6.3
8.0
8.6
9.4
10.1
10.8
11.5
12.2
13.0
13.7
14.4
15.8
17.3
18.0
19.4
21.6
23.8
25.9
28.1
31.0
32.4
33.8
36.0
36.7
37.4
40.3
44.6
49.0
54.0
59.0
65.5
72.0
75.6
79.2
86.4
93.6
100.8
108.0
115.2
126.0
129.6
144.0
Typical
Zener
Voltage
Temperature
Coeff. %/°C
-.025
-.025
.010
.015
.030
.040
.040
.045
.045
.053
.048
.051
.055
.060
.065
.065
.070
.070
.070
.075
.075
.075
.075
.080
.080
.080
.085
.085
.085
.085
.090
.090
.090
.090
.090
.090
.090
.090
.090
.090
.090
.090
.090
.090
.095
.095
.095
.095
.095
.095
.095
.095
.095
.100
INC.
很抱歉,暂时无法提供与“1N4549B”相匹配的价格&库存,您可以联系我们找货
