MCDP6200C1
MCDP6200C1
    KINETIC(芯凯)
    QFN46
    重定时器,USB Type C 接口 46-VQFN(6.5x4.5)
MCDP6200C1 数据手册
Datasheet Brief MCDP6200 USB Type-C Switching Retimer Kinetic Technologies cannot assume responsibility for use of any circuitry other than circuitry entirely embodied in a Kinetic Technologies product. No intellectual property or circuit patent licenses are implied. Kinetic Technologies reserves the right to change the circuitry and specifications without notice at any time. June 2021 – Revision 03h Page 1 of 5 Company Confidential Datasheet Brief MCDP6200 Features • • − Flip-ability of USB Type-C − USB 3.2 x1 Gen1 / Gen2 retiming − • Power Supply Voltages − • o Integrated USB Type-C lane switch to support 1.8 V for I/O, 1.2 V for core USB3.2 Appendix.E x1 Compliant Retimer CTLE for SS to support -20dB insertion loss compensation @2.5GHz Support of custom PHY configuration through TWI (Two Wire Interface) TWI slave to configure the integrated lane mapping and operation mode − Compatible with I2C master − Support up to 4 unique TWI device ID − 5 Gbps and 10 Gbps support − Link training participation • − Spread-spectrum clocking as per USB 3.2 standard Configuration pins for the integrated lane switch and operation mode − • Low Power Operation LFPS polling and processing − LFPS Based PWM support − Pass-Through / Local loopback − Loopback BERT for USB 3.2 SS − Lane polarity inversion − BLR (Bit-Level Retimer) for SS mode o Low latency data path o Link layer snooping ▪ 8b/10b coding ▪ De-scrambler ▪ Link power management support − SRIS (Separate Reference clock Independent SSC) for SSP mode o 128b/132b coding o Scrambler / De-scrambler o Link power management support o SKP OS handling / Elastic buffer for USB for clock offset compensation o DC balance tracking / control o Error correction − Transmitter Emphasis o 3-tap FIR TXEQ for SSP o 2-tap TXEQ for SS − 270mW in USB 3.2 x1 Gen2 mode with 1.2 V and 1.8 V power supply − 180mW in USB 3.2 x1 Gen1 mode with 1.2 V and 1.8 V power supply − 850 uW in low power state ESD Specification − • 2kV HBM, ±500V CDM Package − 46 Ex-VQFN (6.5 mm x 4.5 mm) Applications Adaptive Receiver Equalization o DFE + CTLE for SSP to support -23dB insertion loss compensation @5GHz June 2021 – Revision 03h • − Page 2 of 5 • Desktop PC / Notebook / Tablet / Smartphone motherboard enabling USB Type-C • USB device to drive longer USB Type-C cable Company Confidential Datasheet Brief MCDP6200 Figure 1. MCDP6200 System Block Diagram SSTX SSRX I2C or Conf. pins From battery To each components June 2021 – Revision 03h CC PD control / Plug orientation Power Management Unit Type-C receptacle MCDP6200 USB host / Device D+/- Vconn Vbus Page 3 of 5 Company Confidential Datasheet Brief MCDP6200 1. Description The MCDP6200 is a low power USB 3.2 x1 retimer with an integrated USB Type-C switch targeted for desktop / mobile PC motherboard-down and USB Type-C device application. The USB 3.2 x1 retimer supports both SuperSpeed (SS) bit rate (5 Gbps), and SuperSpeedPlus (SSP) data rate (10 Gbps). The USB 3.2 x1 retimer includes the link layer function and LTSSM and RTSSM to participate in the link training. The MCDP6200 supports SS mode with a BLR (Bit-Level Retimer) and SSP mode with a SRIS (Separate Reference clock Independent SSC). The MCDP6200 supports link power management with Ux entry and exits in both SS and SSP modes. In addition, the MCDP6200 supports the link state and link quality maintenance, compensates the clock offset between the downstream port and the upstream port, detects errors, and corrects single symbol errors in framing order sets, single bit block header errors, and single or double-bit SKP symbol errors in SSP mode. It also supports spread spectrum clocking (SSC) to minimize EMI and the low frequency periodic signaling (LFPS). The transmitter employs 3-tap FIRbased transmitter equalizer for SSP operation and fixed transmitter equalizer ranging from 3 dB to 4 dB for SS operation. The receiver employs an adaptive Continuous Time Linear Equalizer (CTLE) and a Decision Feedback Equalizer (DFE). Both the transmitter equalizer and the receiver equalizer are configurable through the TWI register. Proper settings to comply with USB 3.2 electrical requirements are provided by default. The MCDP6200 operating mode can be configured through the DIS_N and P_POL pins. It can be optionally configured through TWI by enabling the feature through TWI. These interfaces can be controlled from an external Power Delivery (PD) controller or microcontroller to set the plug orientation and the pin mapping of the USB Type-C. The MCDP6200 operates at 1.8 V and 1.2 V. The power consumption is: 280 mW in Gen2 operation and 190 mW in Gen1 operation. 850 µW in stand-by state The MCDP6200 is offered in a 46-pin, 6.5 mm x 4.5 mm Ex-VQFN package. June 2021 – Revision 03h Page 4 of 5 Company Confidential Datasheet Brief MCDP6200 2. Application Overview The target application of MCDP6200 is the Desktop PC / Notebook / Tablet / Smartphone motherboard and USB Type-C device enabling USB Gen2 bit rate over USB Type-C. The MCDP6200 resides next to the USB 3.x host or dual-role device, and the Power Delivery (PD) controller on a same PCB with copper tracks connecting directly to these devices. High speed serial interface tracks are typical microstrip lines with controlled impedance of 100 ohm. The MCDP6200 communicates with these devices through either TWI or 2 configuration pins. By default, the operating mode and the plug orientation are controlled by the PD controller or the Embedded Controller (EC) through the two configuration pins. Figure 2. Motherboard PD controller USB3.1/3.2 x1 controller SoC MCDP6200 Motherboard-Down Use Case USB Type-C Cable USB3.1/3.2 controller MCDP6200 3. Ordering Information Part Number MCDP6200C1 June 2021 – Revision 03h Operating Temperature 0°C to +70°C Page 5 of 5 Package Ex-VQFN46 Company Confidential
MCDP6200C1 价格&库存
很抱歉,暂时无法提供与“MCDP6200C1”相匹配的价格&库存,您可以联系我们找货
