KTM5030B0T
KTM5030B0T
    KINETIC(芯凯)
    LFBGA289
    DisplayPort,Netbooks 接口 289-LFBGA(12x12)
KTM5030B0T 数据手册
KTM5030 USB Type-C / DisplayPort 1.4 MST Hub (DSC) Features • USB Type-C DisplayPort Alt-mode de-mux  Simultaneous USB3.2 Gen2 and 2 lanes DP1.4a input OR 4 lanes DP1.4a input  Flip option for connector plug orientation  DP lane swap and polarity swap • DisplayPort® (DP) ver.1.4a compliant receiver  Link rate 1.62 / 2.74 / 5.4 / 8.1Gbps  1, 2, or 4 lanes configuration  MST up to 6 streams (compressed /uncompressed)  FEC Decode  DSC Transport & Decode  AUX CH 1 Mbps  HPD_OUT  Adaptive receiver equalization  TPS4 EQ Phase LT support  Scrambling of main link data  De-spreading of link frequency  Video Stream Handling ■ RGB/ YCC 444/422/420 pixel format up to 16 bpc ■ Up to 1080 Mpix/sec dual pixel path  DPCD ■ DPCD data structure revision 1.4 ■ DSC support capability & control ■ FEC capability & control ■ SST Split SDP capability ■ VSC_EXT_SDP for VESA & CTA ■ Protocol converter capability & control ■ Virtual DP Peer Device capability & control ■ CEC tunneling over AUX  Chainable SDP packets (2KB or more metadata per stream)  Adaptive Sync SDP  PPS SDPAudio stream handling ■ Non-HBR Compressed Formats • 2/8 ch layouts • Up to 192kHz sample rates • Dolby Digital, Digital+, Atmos  HBR Audio Formats ■ 8 ch layout ■ Up to 1536kHz sample rates ■ Dolby TrueHD, Atmos, DTS Master ■ LPCM Formats ■ 2/8/16/32 Ch ■ Up to 192kHz sample rates ■ 3D LPCM, speaker allocation & mapping March 2023 - Revision 04d  OneBit DSD Formats ■ 2/8 ch ■ Single & Double Rate ■ 12288 kHz sample rates  DST DSD Formats ■ Single/Double rate ■ Up to 22579.2kHz  Audio InfoFrame/ ACP/ ISRC/ Audio Metadata DI packets • Triple DP1.4a / HDMI2.0b (DP++) transmitters  DP mode ■ Lane count, Link rate conversion ■ Link rate 1.62 / 2.74 / 5.4 / 8.1Gbps ■ 1, 2, or 4 lanes configuration ■ DSC stream transport with FEC Encode ■ MST up to 6 streams (compressed / uncompressed) ■ AUX CH 1 Mbps ■ 3.3V HPD_IN  HDMI mode ■ TX1 & TX3: VML AC coupled HDMI ■ TX2: CML DC-coupled HDMI ■ No External Level shifters needed ■ 600 MHz maximum TMDS character clock ■ TMDS character-clock divide_by_4 mode ■ HPD_IN (5V Tolerant) ■ DDC CH (5V Tolerant) • HDMI 2.1 Features  Through 6GHz TMDS Mode  Supports 4k120Hz,4:2:0, 8bpc with Adaptive Sync to VRR conversion  Dynamic HDR Metadata through Extended Metadata Packet  Supports VRR, FVA, QMS, QFT, ALLM  Scrambler for DP/HDMI output  Programmable signal amplitude and edge rate control  Programmable pre-emphasis control  Pixel format RGB / YCC 444/422/420  Deep color up to 16 bits per color  3D video timings  CEC support – snooping, tunneling  SCDC read request handling  Metadata handling  Conversion to DVI output  Link power management Page 1 of 35 Kinetic Technologies Confidential KTM5030 Features (continued) • USB3.2 compliant re-timer  5Gbps and 10Gbps support  Spread spectrum clocking  LFPS polling and processing  Lane polarity inversion  Bit level re-timer for SS mode  SRIS (Separate Reference Clock Independent SSC) for SSP mode  Adaptive Receiver Equalization  Multi-tap FIR EQ Transmitter Emphasis • Video processing  MST to SST conversions or pass-through  SST lef-right separation  Color space conversion from RGB to YCC  Colorimetry support: BT2020, BT709, BT601, and Adobe RGB  Color bit depth expansion (10 to 12 bits) 16 bits per color pass through  DP to HDMI Stereoscopic 3D Transport  Frame sequential to stacked top-bottom conversion  Pass through of other 3D formats  Programmable coefficient 3x3 matrix ■ Programmable input offset ■ Programmable output offset ■ Programmable output clipping levels  Chroma down sampling ■ 5-tap H & V FIR filters with programmable coefficients ■ 12 bits per color input width ■ 12 bits per color output width ■ YCbCr444 to YCbCr420 conversion ■ YCbCr444 to YCbCr422 conversion  Pass through for YCbCr444/422/420  Dual DSC1.2A stream decoding  1/2/4 Slice DSC1.2Aa RGB/YCC444/422/420 10-b format support  FEC decoding / encoding  Video Horizontal blanking expansion  Pixel stream de-skewing  Adaptive Sync Video • Max video resolution and color depth on DP output uncompressed ■ 5K3K60Hz, RGB/YCbCr444, 8 bpc ■ 8K4K60Hz, YCbCr420 up to 8 bpc ■ 4K2K120Hz, RGB/YCbCr444, 8 bpc • Max video resolution and color depth on DP output compressed (DSC) ■ 8K4K60Hz, RGB/YCC444 up to 8 bpc ■ 5K3K60Hz, RGB/YCbCr444, 12 bpc ■ 4x 4K2K60Hz, RGB/YCbCr444, 8 bpc March 2023 - Revision 04d • Max video resolution and color depth on HDMI TX ■ 4Kp60Hz, RGB/YCbCr444, 8 bpc ■ 4Kp60Hz, YCbCr420, up to 16 bpc ■ 4Kp30Hz, RGB/YCbCr444, up to 16 bpc • Audio processing  Audio stream forwarding from DP RX to HDMI TX  Conversion to I2S or TDM audio output (8 CH)  Conversion to SPDIF audio output (2CH) • HDCP support  HDCP1.3 to HDCP1.4 Repeater function  HDCP2.3 to HDCP1.4 Repeater function  HDCP2.3 to HDCP2.3 Repeater function  Read- protected embedded HDCP keys • Enhanced security  Encrypted on-chip key storage  RSA-2048bit signed application firmware  Secure Boot & In-system Programming  Test, debug ports deactivation • Metadata handling  HDMI TX DVI/HDMI mode setting (DPCD register)  YCbCr444-420 conversion (DPCD register)  IEC60958 BYTE3 channel status overwrite  CTA861G INFO FRAME generation  CTA861.3 HDR and Mastering InfoFrame  Chainable VSC_EXT SDP packing format • ARM processor and peripheral controllers  ARM Cortex M3 core  SPI controller  I2C master, slave controller  On-Chip, RAM, ROM, OTP • Device configuration options  Application FW stored in SPI flash  AUX CH, I2C host interface • Internal video pattern generator  Configurable through vendor specific DPCD registers • EMI reduction support  Spread spectrum for DP input, output  Scrambler for DP and HDMI outputs • Low power operation  860mW nominal operation with retimer  700mW nominal operation without retimer  Under 10mW Standby operation • ESD specification  ESD: ±2kV HBM, 500 V CDM • Package  289 LFBGA (12 x 12mm)  Halogen free Halogen free RoHS and Green Compliant • Power supply voltages  1.8V Analog and I/O, 0.95V Analog and core Page 2 of 35 Kinetic Technologies Confidential KTM5030 Description The KTM5030 is an advanced DisplayPort1.4a MST hub with an integrated USB type-C de-multiplexer, targeted primarily for Mobile Notebook accessory and display applications. This device functions as a multistream audio-video splitter and protocol converter with an HDCP1.x/ HDCP2.3 repeater supporting both compressed (DSC) and uncompressed AV streams. KTM5030 has a DP alt-mode capable USB Type-C Upstream Facing Port (UFP). The four high speed lanes of UFP can receive DP1.4a MST audio-video and USB3.2 Gen2 data streams simultaneously. The input lane mapping is flexible and meets standard DP or the USB Type-C connector with flip orientation requirements. The incoming DP and USB signals are de-multiplexed, retimed, and transmitted on the Downstream Facing Ports (DFP). The KTM5030 consists of three AC coupled DP/DP++ or DC coupled HDMI/DVI DFPs, each with four high-speed lanes and one USB port with USB3.2 TX and RX pair. The Stream Routing Logic in KTM5030 allows flexible routing of incoming DP MST stream converted into any combination of MST or SST streams on any of the DFP video ports with link rate and lane count change option. Also, the SST stream can be replicated on two or more DFP ports. In addition, the DP SST stream can be converted into a HDMI or DVI output (TMDS signal format). The combo receiver in KTM5030 supports all DP standard data rates up to HBR3 (8.1 Gbps/lane) and USB3.2 Gen1 (5.0 Gbps) and Gen2 (10.0 Gbps). The dual mode (DP++) transmitters support DP standard data rates up to 8.1 Gbps/lane and TMDS data rates up to 6.0 Gbps/lane. The side-band channel uses 1.0 Mbps Manchester-coded AUX signaling for DP and DDC signaling up to 100kbps for the HDMI interface. KTM5030 is capable of processing up to six DP audiovideo streams compressed or uncompressed. FEC decoding and encoding is employed for the reliable reception and transmission of DSC1.2a compressed streams. These streams can be part of one single large video timing or six independent video timings from a single source with corresponding independent multi-channel audio. The highest video timing per stream and the number of streams transported is limited by the DP1.4a and HDMI2.0 link bandwidth. When the received DP MST stream is in DSC1.2a compressed format, KTM5030 can decode the March 2023 - Revision 04d streams (max two streams) or pass through to the downstream sink or to another cascaded KTM5030 device. If a DP source sends an 8k4k60Hz RGB/YCC444 DSC1.2a encoded video as four 4k2k60Hz MST, then two KTM5030 devices are needed to decode all four streams. KTM5030 supports both RGB 444 and YCC444/422/420 video pixel encoding formats with a color depth up to 16 bpc (bits per component or 48 bits per pixel). It has a pixel processing unit capable of video pixel encoding format conversion from RGB444 to YCC444 with bit depth expansion and down scaling from YCC444 to YCC422/420. Pixel format conversion along with horizontal blanking expansion improves interoperability and smooth rendering of CVT video timings from a mobile PC on a consumer displays such as TVs and projectors which supports only CEA timings. KTM5030 processes High Dynamic Range (HDR) video content specified in BT601, BT709, BT2020, BT2100 , Adobe RGB colorimetry format with the proper metadata conversion from DP to HDMI. It also offers secure reception and transmission of high bandwidth digital audio and video content with HDCP1.x or HDCP2.3 content protection. As a branch device KTM5030 functions as a HDCP1.x and HDCP2.3 repeater between the DP source and DP or HDMI sink. KTM5030 uses an external 25 MHz reference clock for its operation. The reference clock can be generated from a 25MHz crystal or from an external source. It has a 300MHz ARM Cortex M3 CPU with on-chip memories for code and data storage. The peripheral subsystem includes SPI, UART (debug only), and I2C master, slave interfaces. An internal Power-On Reset (POR) circuit senses the voltage on the reset input and provides the chip reset during system power-up. The KTM5030 uses an external 16 Mbit SPI flash memory for storing the RSA-2048 signed application firmware with fail-safe recovery. At boot up, the CPU goes through a secure boot process authenticating the application code image stored in the SPI flash. It supports both standard mode and quad mode SPI operation. Firmware update for the SPI flash is done securely through the DP AUX_CH or I2C host interface (Secure In-System-Programming). Page 3 of 35 Kinetic Technologies Confidential KTM5030 Table 1. Part Numbers Features KTM5030 USB-C (DP alt-mode) (DP 4 lanes OR 2 lanes DP and 2 lanes USB3.2) 3x DP++ (DP or HDMI) 1x USB3.2 Yes Input Outputs USB De-mux & Re-timer HDCP2.2 Yes HDR, Pixel Processor Yes DSC & FEC Yes Package LFBGA 12x12mm / 0.65mm pitch Applications The target applications of the KTM5030 are: • Mobile PC docking stations • Dongles • MST video hubs • AR / VR devices • High end displays such as digital signage • Daisy-chain monitors DisplayPort and USB Type-C are the prominent interfaces in these applications and the KTM5030 offers the highest performance at the optimum bill of material cost. Docking Station Application In a mobile docking station topology, the KTM5030 is part of a larger system which has a system controller such as TCPC, USB hub, etc. The docking station can be a traditional dock with a custom connector or a travel dock with a USB Type-C tethered cable. The audio-video interface between the notebook and the docking station is either DP or DP Alt-Mode over USB Type-C. The KTM5030 is an ideal device for a Type-C docking station where it can function as a Type-C Port Manager (TCPM) along with an external TCPC device (e.g. Kinetic MCDP9000 TCPC). It is designed with integrated features such as a USB-C de-mux, a video hub, a protocol converter, and an HDCP repeater in a single chip. The downstream video ports can be configured as DP1.4a or HDMI2.0 depending on the requirements. Docking Station DP or HDMI cable Monitor TCPC DP or HDMI cable Notebook KTM5030 Monitor DP or USB Type-C Connector /cable USB Hub DP or HDMI cable Monitor USB Type-A or Type-C Ports Figure 1. KTM5030 Docking Station Use Case March 2023 - Revision 04d Page 4 of 35 Kinetic Technologies Confidential KTM5030 Daisy-Chain Monitor / Signage Application A daisy-chain monitor or signage featuring the USB Type-C connector supporting the DP Alt-mode requires a USB Type-C de-mux and a DP MST hub device with two or more video outputs. KTM5030 is an ideal fit for such applications where it can receive the USB and multiple video streams simultaneously. It then routes one of the video stream to the internal SoC and the remaining streams to the downstream units. In this use case, the KTM5030 can support two 4K60Hz displays without DSC or up to four 4K60Hz displays with DSC. For a Large Format Display Application, such as a 5x5 video wall configuration, KTM5030 can support 25 or more daisy chained displays. Signage System SoC KTM5030 Signage System Signage System SoC SoC KTM5030 KTM5030 Signage System SoC KTM5030 Figure 2. KTM5030 Digital Signage Use Case AR/VR Application The current AR/VR head mount displays use a video splitter device for routing the video from the graphics source to the dual OLED panels. Future designs are targeting higher video resolutions, refresh rates, and low latency. The KTM5030 is suitable for such designs; it can deliver up to 2x 2560x2160 @120 Hz without DSC or up to 2x 3860x2160@ 90 Hz with DSC. Additionally, the KTM5030 can generate a global frame synchronization signal for synchronizing the video with the sensor inputs. Also it can deliver up to 8CH compressed or LPCM audio through the I2S or TDM format to audio codec for the best quality audio experience. HMD System TCPC eDP USB-C KTM5030 Panel eDP I2S/ TDM Sensor Hub Panel Audio Codec Figure 3. KTM5030 AR/VR Head Mount Display Use Case March 2023 - Revision 04d Page 5 of 35 Kinetic Technologies Confidential KTM5030 Functional Block Diagram USB Receiver / Transmitter USB3.1 TX USB3.1 RX ML0_RX_P/_N USB Retimer ML1_RXTX_P/_N ML3_RX_P/_N DP/HDMI Combo Transmitter Demux USB-DP Combo Receiver / Transmitter ML2_RXTX_P/_N RX_AUX_P/_N Audio, Video processing (DSC, Color Conversion ) Routing Logic, Lane, Link Conversion RX_HPD_OUT XTAL Clock Generation TCLK GPIO SPI UART I2C Slave DP / HDMITX2_P /_N DP / HDMITX2_P /_N DP / HDMITX2_P /_N DP / HDMITX2_P /_N AUX / DDC CH HPD_IN DP / HDMITX3_P /_N DP / HDMITX3_P /_N DP / HDMITX3_P /_N DP / HDMITX3_P /_N AUX / DDC CH HPD_IN I2S /SPDIF I2S /SPDIF Out CEC HDMITX_CEC ALERTN I2CM_SDA Page 6 of 35 AUX / DDC CH HPD_IN I2C Master I2CM_SCL I2C_SDA I2C_SCL UART_RX UART_TX SPI_DI SPI_DO SPI_CLK SPI_CS SPI_WPN GPIO0 * * GPIO37 March 2023 - Revision 04d DP/HDMI Combo Transmitter OCM ARM- M3 Reset Generation RESETN DP/HDMI Combo Transmitter DP / HDMITX1_P /_N DP / HDMITX1_P /_N DP / HDMITX1_P /_N DP / HDMITX1_P /_N Kinetic Technologies Confidential KTM5030 BGA Footprints and Pin Mapping The ball grid array (BGA) diagrams give the allocation of pins to the package shown, from the top looking down, using the PCB footprint. Some signal names in BGA diagrams have been abbreviated. Refer to the pin list for full signal names sorted by pin number. 2 3 4 5 A HPD_OUT_ GPIO2 1 GND SSRX2P _RX3N GND SSTX2P _RX2N B I2CM_SCL_ PCONF1 GND SSRX2N _RX3P GND C ALERTN_PP OL GND GND GND 6 7 8 9 10 11 12 13 14 15 16 17 GND RX_REXT REFCLK_OU T GND SSTX1P _RX1P GND SSRX1P _RX0P GND TX0_ SSRXP GND TX0_ SSTXP GND A SSTX2N _RX2P GND EXT_RESETN GND GND SSTX1N _RX1N GND SSRX1N _RX0N GND TX0_ SSRXN GND TX0_ SSTXN GND B GND GND XTAL_IN XTAL_OUT GND GND GND GND GND C GND NC TX1_ CONFIG1_G PIO11 SPI_DO D AVDD18_UFP AVDD18_UFP AVDD18_UFP AVDD18_UFP D I2CM_SDA_ PCONF0 GND RX_AUXN_SB RX_AUXP_S AVDDP9_UF AVDDP9_UF AVDDP9_UFP AVDDP9_UFP AVDDP9_UFP AVDDP9_UFP AVDDP9_UFP AVDDP9_UFP AVDDP9_UFP U1 BU2 P P E TX3_ DDC_SCL GPIO0_ I2C_SDA GND DVDDP9 GND GND GND GND GND GND GND GND GND DVDDP9 DVDD18 SPI_CLK SPI_HOLD E F TX3_ HPD_IN GPIO1_ I2C_SCL GND DVDDP9 GND GND GND GND GND GND GND GND GND DVDDP9 DVDD18 SPI_CSN SPI_DI F G TX2_ DDC_SCL TX3_ DDC_SDA DVDD18 DVDDP9 GND GND GND GND GND GND GND GND GND DVDDP9 TEST SPI_WPN URX_GPIO8 G H TX1_ DDC_SDA TX2_ DDC_SDA DVDD18 DVDDP9 GND GND GND GND GND GND GND GND GND DVDDP9 DVDD18 TX2_ UTX_GPIO9 CONFIG1_G PIO12 H J TX1_ DDC_SCL TX2_ HPD_IN GND DVDDP9 GND GND GND GND GND GND GND GND GND DVDDP9 DVDD18 TX3_ DBUG0_GPI CONFIG1_G O6 PIO13 J K TX1_CEC_G PIO10 TX1_ HPD_IN GND DVDDP9 GND GND GND GND GND GND GND GND GND DVDDP9 DVDD18 I2S_WCK_G DBUG1_GPI PIO14 O7 K L TX3_CEC_G GPIO37_TX2 PIO36 _CEC GND DVDDP9 GND GND GND GND GND GND GND GND GND DVDDP9 DVDD18 I2S_D0_GPI I2S_FCK_G O16 PIO15 L I2S_D2_GPIO I2S_D3_GPI I2S_D1_GPI 18 O19 O17 M M GND GND TX2_AUX_N DVDDP9 GND GND GND GND GND GND GND GND GND DVDDP9 N TX1_L3_HD MICLK_N GND TX2_AUX_P GND GND GND GND GND GND GND GND GND GND GND GND GND GND N P TX1_L3_HD MICLK_P GND TX1_AUX_N AVDDP9_TX AVDDP9_TX AVDDP9_TX AVDDP9_TX AVDDP9_TX AVDDP9_TX AVDDP9_TX GND TX3_AUX_N GND TX3_L0_HD MICH2_P P R TX1_L2_HD MICH0_N GND TX1_AUX_P AVDD18_TX TX1_CM AVDD18_TX AVDD18_TX TX2_CM AVDD18_TX AVDD18_TX AVDD18_TX TX3_CM AVDD18_TX GND TX3_AUX_P GND TX3_L0_HD MICH2_N R T TX1_L2_HD MICH0_P GND GND GND GND TX2_L3_HDMI CLK_N GND GND GND GND TX2_L0_HDMI CH2_P GND GND GND GND GND TX3_L1_HD MICH1_P T U TX1_L1_HD TX1_L1_HD TX1_L0_HDMI TX1_L0_HD MICH1_N MICH1_P CH2_N MICH2_P GND TX2_L3_HDMI TX2_L2_HDMI TX2_L2_HDM TX2_L1_HDM TX2_L1_HDM TX2_L0_HDMI CLK_P CH0_N ICH0_P ICH1_N ICH1_P CH2_N GND TX3_L3_HDMI TX3_L3_HDMI TX3_L2_HDMI TX3_L2_HD TX3_L1_HD CLK_N CLK_P CH0_N MICH0_P MICH1_N U 1 2 3 4 5 6 7 AVDDP9_TX AVDDP9_TX AVDDP9_TX 8 9 10 11 12 13 14 15 16 17 TOP VIEW 10GHz SERDES GND ANALOG DIGITAL 1.8V I/O DIGITAL 5V 1.8V ANALOG TOL OPEN- 0.9V DIGITAL 0.9V ANALOG 1.8V DIGITAL VDD DRAIN I/O 289-Pin 12.0mm x 12.0mm x 1.3mm LFBGA Package, 0.65mm pitch Figure 4. KTM5030 BGA Diagram March 2023 - Revision 04d Page 7 of 35 Kinetic Technologies Confidential KTM5030 KTM5030B0 TNNNNN ES YYWWVXXX 289-Pin 12.0mm x 12.0mm x 1.3mm LFBGA Package, 0.65mm pitch Table 2. Field Marking Description Field Description Marking DOT Pin1 indicator DOT Line 1 Company logo Kinetic Logo Line 2 Part Number + IC revision Traceability codes TNNNNN: Fab Lot Number ES: for Engineering Samples YYWW: Assembly Date Code (Work Year & Work Week) V: Assembly Vendor Code XXX: Serial Number KTM5030B0 Line 3 Line 4 March 2023 - Revision 04d Page 8 of 35 “Variant” “Variant” Kinetic Technologies Confidential KTM5030 Table 3. Pin List Pin # Name Pin # Name Pin # Name A1 A2 A3 A4 A5 HPD_OUT_GPIO2 GND SSRX2P _RX3N GND SSTX2P _RX2N C9 C10 C11 C12 C13 GND AVDD18_UFP AVDD18_UFP AVDD18_UFP AVDD18_UFP E17 F1 F2 F3 F4 SPI_HOLD TX3_HPD_IN GPIO1_I2C_SCL GND DVDDP9 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 A16 A17 GND RX_REXT REFCLK_OUT GND SSTX1P _RX1P GND SSRX1P _RX0P GND TX0_ SSRXP GND TX0_ SSTXP GND C14 C15 C16 C17 D1 D2 D3 D4 D5 D6 D7 D8 GND GND GND GND I2CM_SDA_PCONF0 GND RX_AUXN_SBU1 RX_AUXP_SBU2 AVDDP9_UFP AVDDP9_UFP AVDDP9_UFP AVDDP9_UFP F5 F6 F7 F8 F9 F10 F11 F12 F13 F14 F15 F16 GND GND GND GND GND GND GND GND GND DVDDP9 DVDD18 SPI_CSN B1 B2 B3 B4 B5 B6 B7 I2CM_SCL_PCONF1 GND SSRX2N _RX3P GND SSTX2N _RX2P GND EXT_RESETN D9 D10 D11 D12 D13 D14 D15 F17 G1 G2 G3 G4 G5 G6 SPI_DI TX2_DDC_SCL TX3_DDC_SDA DVDD18 DVDDP9 GND GND B8 GND D16 G7 GND B9 B10 B11 B12 B13 B14 B15 B16 B17 GND SSTX1N _RX1N GND SSRX1N _RX0N GND TX0_ SSRXN GND TX0_ SSTXN GND D17 E1 E2 E3 E4 E5 E6 E7 E8 AVDDP9_UFP AVDDP9_UFP AVDDP9_UFP AVDDP9_UFP AVDDP9_UFP GND NC TX1_ CONFIG1_GPIO11 SPI_DO TX3_DDC_SCL GPIO0_I2C_SDA GND DVDDP9 GND GND GND GND G8 G9 G10 G11 G12 G13 G14 G15 G16 GND GND GND GND GND GND DVDDP9 TEST SPI_WPN C1 C2 C3 C4 C5 C6 C7 C8 ALERTN_PPOL GND GND GND GND GND XTAL_IN XTAL_OUT E9 E10 E11 E12 E13 E14 E15 E16 GND GND GND GND GND DVDDP9 DVDD18 SPI_CLK G17 H1 H2 H3 H4 H5 H6 H7 URX_GPIO8 TX1_DDC_SDA TX2_DDC_SDA DVDD18 DVDDP9 GND GND GND Continues on page 12 March 2023 - Revision 04d Page 9 of 35 Kinetic Technologies Confidential KTM5030 Pint List (Continued) Pin # Name Pin # Name Pin # Name H8 H9 H10 H11 H12 GND GND GND GND GND K16 K17 L1 L2 L3 I2S_WCK_GPIO14 DBUG1_GPIO7 TX3_CEC_GPIO36 GPIO37_TX2_CEC GND N7 N8 N9 N10 N11 GND GND GND GND GND H13 H14 H15 H16 GND DVDDP9 DVDD18 UTX_GPIO9 TX2_ CONFIG1_GPIO12 TX1_DDC_SCL TX2_HPD_IN GND DVDDP9 GND GND GND GND GND GND GND GND L4 L5 L6 L7 DVDDP9 GND GND GND N12 N13 N14 N15 GND GND GND GND L8 GND N16 GND L9 L10 L11 L12 L13 L14 L15 L16 L17 M1 M2 M3 GND GND GND GND GND DVDDP9 DVDD18 I2S_D0_GPIO16 I2S_FCK_GPIO15 GND GND TX2_AUX_N N17 P1 P2 P3 P4 P5 P6 P7 P8 P9 P10 P11 GND TX1_L3_HDMICLK_P GND TX1_AUX_N AVDDP9_TX AVDDP9_TX AVDDP9_TX AVDDP9_TX AVDDP9_TX AVDDP9_TX AVDDP9_TX AVDDP9_TX M4 M5 M6 M7 DVDDP9 GND GND GND P12 P13 P14 P15 AVDDP9_TX AVDDP9_TX GND TX3_AUX_N H17 J1 J2 J3 J4 J5 J6 J7 J8 J9 J10 J11 J12 J13 J14 J15 J16 M8 GND P16 GND K1 K2 K3 K4 K5 K6 K7 K8 K9 K10 K11 K12 GND DVDDP9 DVDD18 DBUG0_GPIO6 TX3_ CONFIG1_GPIO13 TX1_CEC_GPIO10 TX1_HPD_IN GND DVDDP9 GND GND GND GND GND GND GND GND M9 M10 M11 M12 M13 M14 M15 M16 M17 N1 N2 N3 GND GND GND GND GND DVDDP9 I2S_D2_GPIO18 I2S_D3_GPIO19 I2S_D1_GPIO17 TX1_L3_HDMICLK_N GND TX2_AUX_P P17 R1 R2 R3 R4 R5 R6 R7 R8 R9 R10 R11 TX3_L0_HDMICH2_P TX1_L2_HDMICH0_N GND TX1_AUX_P AVDD18_TX TX1_CM AVDD18_TX AVDD18_TX TX2_CM AVDD18_TX AVDD18_TX AVDD18_TX K13 K14 K15 GND DVDDP9 DVDD18 N4 N5 N6 GND GND GND R12 R13 R14 TX3_CM AVDD18_TX GND J17 Continues on page 13 March 2023 - Revision 04d Page 10 of 35 Kinetic Technologies Confidential KTM5030 Pint List (Continued) Pin # Name R15 R16 R17 T1 T2 TX3_AUX_P GND TX3_L0_HDMICH2_N TX1_L2_HDMICH0_P GND T3 T4 T5 T6 T7 T8 T9 T10 T11 T12 T13 T14 GND GND GND TX2_L3_HDMICLK_N GND GND GND GND TX2_L0_HDMICH2_P GND GND GND T15 T16 T17 U1 U2 U3 U4 U5 U6 U7 U8 U9 GND GND TX3_L1_HDMICH1_P TX1_L1_HDMICH1_N TX1_L1_HDMICH1_P TX1_L0_HDMICH2_N TX1_L0_HDMICH2_P GND TX2_L3_HDMICLK_P TX2_L2_HDMICH0_N TX2_L2_HDMICH0_P TX2_L1_HDMICH1_N U10 U11 U12 U13 U14 U15 U16 U17 TX2_L1_HDMICH1_P TX2_L0_HDMICH2_N GND TX3_L3_HDMICLK_N TX3_L3_HDMICLK_P TX3_L2_HDMICH0_N TX3_L2_HDMICH0_P TX3_L1_HDMICH1_N March 2023 - Revision 04d Page 11 of 35 Kinetic Technologies Confidential KTM5030 Ordering Information Part Number Functional Description KTM5030B0 USB-C/ DP alt-mode DP 4 lanes OR 2 lanes DP and 2 lanes USB3.2 DSC KTM5030B0T Marking1 Operating Temperature Package External Package TRAYS KTM5030B0 0°C to +70°C 289- LFBGA Tape and Reel Absolute Maximum Ratings2 (TA = 25C unless otherwise noted) Symbol Description Value Units VVDD_1.8 VDD1.8V to GND -0.3 to 2.16 V VVDD_0.95 VIO0.95V to GND -0.3 to 1.14 V VIN5tol Input voltage tolerance for 3.3V, 5V tolerant I/O pins -0.3 to 5.5 V TSTG Storage temperature -40 to 150 C TSOL Peak IR reflow soldering temperature 260 C ESD and Latch-up Ratings3 Symbol Description Value Units VESD_HBM JEDEC JESD22-A114 ESD HBM (all pins) ±2.0 kV VESD_CDM JEDEC JESD22-C101 ESD CDM (all pins) ±500 V JEDEC JESD78 ±100 mA Value Units 27 C/W ILU Thermal Capabilities4 Symbol Description ΘJA Thermal Resistance – Junction to Ambient ΘJC Thermal Resistance – Junction to Case 8.473 C/W TA Ambient Operating Temperature Range 0 to 70 C TJ Junction Operating Temperature Range 0 to 125 C 1. See Table 1 for trace codes marking details;. ES – Engineering Sample. 2. Stresses above those listed in Absolute Maximum Ratings may cause permanent damage to the device. Functional operation at conditions other than the operating conditions specified is not implied. Only one Absolute Maximum rating should be applied at any one time. 3. ESD and Latch-up Ratings conform to JEDEC industry standards. Some pins may actually have higher performance. Ratings apply with chip enabled, disabled, or unpowered, unless otherwise noted. 4. Junction to Ambient thermal resistance is highly dependent on PCB layout. Values are based on thermal properties of the device when soldered to a four-layer JEDEC PCB board, no heat spreader, and no air flow. March 2023 - Revision 04d Page 12 of 35 Kinetic Technologies Confidential KTM5030 Electrical Characteristics5 Unless otherwise noted, the Min and Max specs are applied over the full operation temperature range of 0°C to +70°C and VDD_1.8V = 1.8V, VDD_0.95V = 0.95V. Typical values are specified at TA = +25°C. DC Characteristics Supply Specifications Symbol Description Min Typ Max Units VVDD_1.8 1.8V supply voltages (analog and digital) Conditions 1.71 1.8 1.89 V VVDD_0.9 0.95V supply voltages (analog and digital) 0.90 0.95 1.00 V 550 600 mW 626 711 mW 712 795 mW Power Protocol converter Mode Measurement condition: Nominal corner, 25°C, Nominal power supply Operating condition 1 Input: DP MST HBR3 (4L) Output1: DP SST HBR3 (4L) 4k2k30Hz Output2: DP SST HBR3 (4L) 4k2k30Hz Output3: HDMI 4k2k30Hz Operating condition 2 Input: DP MST HBR3 (4L) Output1: DP SST HBR3 (4L) 1080p60Hz Output2: DP SST HBR3 (4L) 4k2k30Hz Output3: HDMI 4k2k60Hz Operating condition 3 Input: DP SST HBR3 (4L) 4k2k60Hz Output1: DP SST HBR3 (4L) 4k2k60Hz Output2: DP SST HBR3 (4L) 4k2k60Hz Output3: HDMI 4k2k60Hz Standby IDD_0.95V 0.95V Supply Current IDD_1.8V 1.8V Supply Current7 9.2 Nominal corner, 25°C, Nominal power supply Operating condition 3 (See above) VDD (analog and digital) 0.95V VDD (analog and digital) 1.8V TRAMP_MIN Minimum Power Rail Ramp up Time 100 mW 7336 892 mA 146 155 mA µS 5. Device is guaranteed to meet performance specifications over the 0°C to +70°C operating temperature range by design, characterization and correlation with statistical process controls. 6. Values are for Power Supply design only and not indicative for Max Power Consumption. 7. Ripple amplitude for power supplies should be 20mV or lower with max ripple frequency up to 30MHz. March 2023 - Revision 04d Page 13 of 35 Kinetic Technologies Confidential KTM5030 Electrical Characteristics5 (continued) Unless otherwise noted, the Min and Max specs are applied over the full operation temperature range of 0°C to +70°C and VDD_1.8V = 1.8V, VDD_0.95V = 0.95V. Typical values are specified at TA = +25°C. 3.3V IO Signals, 5V Tolerant Open Drain Type Symbol VPAD Description Conditions Min Input Voltage at PAD VIH Input High voltage Typ Max Units 5 6 V 2.0 V VIL Input Low voltage 0.8 V VOL Output Low voltage 0.4 V IOL Output Low current (measured at VOL = 0.4V) 8.7 10.7 mA IIL 2.4 3.8 A 2 3.2 A Ivref Input Leakage current Input Leakage in Fail Safe (unpowered VDD/VREF) VREF DC current 0.1 0.8 nA Ivdd VDD DC current 0.8 3.9 A Typ Max Units IIL_off 5.3 1.8V IO Signals, 1.8V Tolerant, TRISTATE Symbol Description Conditions Min VIH Input High voltage VIL Input Low voltage 0.55 V VOL Output Low voltage 0.45 V VOH Output High voltage -10 10 A -10 10 A IIH IIL 1.25 V 1.35 Input Leakage current V Tri-state output Leakage current Pull-up Resistor 80 kΩ RPD Pull-down Resistor 95 kΩ March 2023 - Revision 04d -10 Page 14 of 35 10 A IOZ RPU Kinetic Technologies Confidential KTM5030 Electrical Characteristics5 (continued) Unless otherwise noted, the Min and Max specs are applied over the full operation temperature range of 0°C to +70°C and VDD_1.8V = 1.8V, VDD_0.95V = 0.95V. Typical values are specified at TA = +25°C. AC Characteristics8 Maximum Speed of Operation Symbol Description Conditions Min Typ Max Units TCLK Reference Input Clock 25 MHz OCLK On-Chip Microcontroller Clock 300 MHz SLAVE_SCL I2C host interface clock 400 kHz MSTRx_SCL DDC Master 400 kHz SPI Clock 75 MHz Max Units 800 mV SPI DisplayPort Receiver Characteristics Receiver Operating Range Symbol Description Conditions Min Typ VRX_DIF_PP_RANGE Differential Input Voltage Range 40 RRX_TERM_RANGE RX Termination Control Range 80 100 120 Ω Min Typ Max Units System Parameters Symbol Description Conditions UIHBR3 HBR3 unit interval (8.1Gbps) 123 Ps UIHBR2 HBR2 unit interval (5.4Gbps) 185 Ps UIHBR HBR unit interval (2.7Gbps) 370 Ps UIRBR RBR unit interval (1.62Gbps) 617 ps Link clock down spreading Modulation frequency range of 30kHz to 33kHz 0 0.5 % 8. AC characteristics parameters are guaranteed by the silicon characterization across operating condition unless otherwise specified. Not all parameters are tested in the production test. March 2023 - Revision 04d Page 15 of 35 Kinetic Technologies Confidential KTM5030 Electrical Characteristics5 (continued) Unless otherwise noted, the Min and Max specs are applied over the full operation temperature range of 0°C to +70°C and VDD_1.8V = 1.8V, VDD_0.95V = 0.95V. Typical values are specified at TA = +25°C. Main Link and AUX CH Parameters Symbol Description Main Link Jitter Tolerance, Target Bit Error Rate TRX_TJ_RBR TRX_Non-ISI_RBR TRX_TJ_HBR TRX_Non-ISI_HBR TRX_TJ_HBR2 TRX_Non-ISI_HBR2 TRX_TJ_HBR3 TRX_NON_ISI_HBR3 Conditions Min Typ Max Units 0.747 UI 0.177 UI 0.491 UI 0.330 UI 0.62 UI 0.40 UI 0.62 UI 0.38 UI 0.27 1.36 V 0.29 1.38 V 10-9 RBR Total jitter at TP3 EH = 56 mVdiff_pp RBR non-ISI jitter HBR Total jitter at TP3_EQ EH = 160 mVdiff_pp HBR non-ISI jitter HBR2 Total jitter at TP3_EQ EH = 100 mVdiff_pp HBR2 non-ISI jitter HBR3 Total jitter at TP3_CTLE EH = 50 mVdiff_pp HBR3 non-ISI jitter AUX Parameters VAUX_RX_DIF_RANGE VAUX_TX_DIF_RANGE RAUX_TERM_RANGE Differential Input Voltage Range Differential Output Voltage Range RX DIFF Termination Control Range March 2023 - Revision 04d TP3 100 Page 16 of 35 Ω Kinetic Technologies Confidential KTM5030 Electrical Characteristics5 (continued) Unless otherwise noted, the Min and Max specs are applied over the full operation temperature range of 0°C to +70°C and VDD_1.8V = 1.8V, VDD_0.95V = 0.95V. Typical values are specified at TA = +25°C. DisplayPort Transmitter Characteristics Transmitter Operating Range Symbol Description Conditions VTX_DIF_PP_RANGE Differential Output Voltage Range RTX_TERM_RANGE TX Termination Control Range Min 80 Typ 100 Max Units 1.38 V 120 Ω DisplayPort Transmitter System Parameters UIHBR3 HBR3 unit interval (8.1Gbps) 123 ps UIHBR2 HBR2 unit interval (5.4Gbps) 185 ps UIRBR HBR unit interval (2.7Gbps) 370 ps UIRBR RBR unit interval (1.62Gbps) 617 ps Modulation frequency range of 30kHz to 33kHz All Main lanes and AUX CH need AC coupling on the transmitter side Link clock down spreading CTX Coupling capacitor 0 0.5 100 % nF DisplayPort Transmitter TP2 Parameters TTX_SKEW_INTER_PAIR Lane-to-Lane output Skew TTX_SKEW_INRA_PAIR Lane Intra pair Skew Target bit error rate TTX_TJ_TPS4_HBR3 Applies to all pairwise combinations of supported lanes Applies to all supported lanes 1250 ps 30 ps 0.47 UI 0.23 UI 0.58 UI 0.36 UI 10-9 HBR3 Total Jitter at TP3_CTLE TTX_NonISI_TPS4_HBR3 HBR3 Non-ISI Jitter TTX_TJ_CP2520_HBR2 HBR2 Total Jitter at TP3_EQ VSL/PEL = 1/1, Adc = -3 dB VSL/PEL = 1/1 TTX_NonISI_CP2520_HBR2 HBR2 Non-ISI Jitter TTX_TJ_D10.2_HBR2 HBR2 Total Jitter with D10.2 Measured at TP3_EQ 0.40 UI TTX_DJ_D10.2_HBR2 HBR2 Dual-Dirac Jitter with D10.2 Measured at TP3_EQ 0.27 UI TTX_RJ_D10.2_HBR2 HBR2 Random Jitter with D10.2 Measured at TP3_EQ 19.2 mUIrms 0.27 1.38 V 0.29 1.38 V AUX Parameters VAUX_RX_DIFF_PP Differential Input Voltage Range VAUX_TX_DIFF_PP Differential Output Voltage Range RX DIFF Termination Control Range RAUX_TERM_RANGE March 2023 - Revision 04d 50mV/step in 4 steps Page 17 of 35 100 Ω Kinetic Technologies Confidential KTM5030 Electrical Characteristics5 (continued) Unless otherwise noted, the Min and Max specs are applied over the full operation temperature range of 0°C to +70°C and VDD_1.8V = 1.8V, VDD_0.95V = 0.95V. Typical values are specified at TA = +25°C. HDMI Transmitter I/O Characteristics HDMI Transmitter DC Specifications Symbol VTX_PP VTX_DIF_ HIGH Description Conditions Differential output: single ended swing amplitude Differential output: Single ended high-level output Min Typ Max Units 0.4 0.5 0.6 V Sink supply dependent (typical VDD = 3.3V) 3.3 V HDMI Transmitter AC Specifications Symbol Description Conditions Min Typ Max Units fTX_CHR_CLK TMDS Character Clock Programmable 25 600 MHz VTX_DIF_PP Differential Output Voltage In 64 steps (usable range 0.8 – 1.2 V) VTX_DIF_PP + APREMPH should be less than 1.2 V 0 1.2 V 0 6 dB APREMPH RTX_TERM_ RANGE TTX_CLK_ JITTER TX Pre-Emphasis Level TX Differential Termination Control Range Programmable Termination (range 85-600) TX Clock jitter Tighter than HDMI specification TX Data Jitter Refer to the tables below. March 2023 - Revision 04d Page 18 of 35 Ω 100 0.25 TBIT Kinetic Technologies Confidential KTM5030 B C A D E F Figure 5. HDMI1.4b EYE Diagram at TP1 at TMDS Character Clock Rate ≤ 340MHz Table 4. TMDS TX EYE Opening Specification for TMDS Character Clock Rate ≤ 340MHz Point H(UI) V (mV_diff_pp) A 0.13 0 B 0.20 200 C 0.80 200 D 0.87 0 E 0.80 -200 F 0.20 -200 Figure 6. HDMI2.0 EYE Diagram at TP2_EQ at TMDS Character Clock Rate > 340MHz Table 5. TMDS TX PHY Jitter Specification at TMDS Character Clock Rate > 340 MHz TMDS Bit Rate (Gbps) H (Tbit) V (mV_diff_pp) 3.4 < Rbit < 3.712 0.72 -0.0332 Rbit2 + 0.2312 Rbit + 0.1998 0.48 335 -19.66 Rbit2 + 106.74 Rbit + 209.58 150 3.712 < Rbit ≤ 5.94 5.94 < Rbit ≤ 6.0 March 2023 - Revision 04d Page 19 of 35 Kinetic Technologies Confidential KTM5030 USB 3.2x1 Transmitter and Receiver Characteristics USB 3.2 x1 transmitter (SSRX pin and Type-C interface in USB mode) Symbol Description UIUSB_GEN1 Unit interval in Gen1 UIUSB_GEN2 Unit interval in Gen2 Conditions Min Typ Max Units 199.94 200.46 ps 99.97 100.03 ps AC coupling capacitor 75 265 nF SSC deviation 0 -5000 ppm Modulation rate 30 33 kHz Differential peak-to-peak voltage swing 0.8 1.2 V De-emphasis in Gen1 3.0 4.0 dB VTX_PS_RATIO Pre-shoot in Gen2 VTX_DE_RATIO De-emphasis in Gen2 1.2 3.2 dB 2.1 4.1 dB RTX_DIFF_DC VTX_RCV_ 72 120 Ω 0.6 V CTX_USB tSSC_FREQ_ DEVIATION tSSC_MOD_ RATE VUSB_TX_ DIFF_PP VTX_DE_RATIO _GEN1 _GEN2 DETECT tCDR_SLEW_ RATE SSCdfdt VEYE_HEIGHT_ GEN1 VEYE_HEIGHT_ GEN2 DC differential impedance The amount of voltage change during Rx detection Maximum slew rate In Gen1 10 ms/s SSC df/dt In Gen2 1250 ppm/ µs Eye height at TP4 in Gen1 100 1000 mV Eye height at TP4 in Gen2 70 1000 mV DjUSB_GEN1 Deterministic jitter at TP4 in Gen1 430 mUI DjUSB_GEN2 Deterministic jitter at TP4 in Gen2 530 mUI RjUSB_GEN1 3.22 ps 1 ps TjUSB_GEN1 RMS Random jitter at TP4 in Gen1 RMS Deterministic jitter at TP4 in Gen2 Total jitter at TP4 in Gen1 660 mUI TjUSB_GEN1 Total jitter at TP4 in Gen2 DjUSB_GEN2 tPERIOD VTX_DIFF_PP_ LFPS TDUTY_LFPS LFPS tPERIOD LFPS peak-to-peak differential amplitude LFPS duty cycle March 2023 - Revision 04d Page 20 of 35 671 mUI 20 80 ns 800 1000 mV 40 60 % Kinetic Technologies Confidential KTM5030 USB 3.2 x1 Receiver (SSRX pin and Type-C interface in USB mode) Symbol Description UIUSB_GEN1 Unit interval in Gen1 UIUSB_GEN2 tSSC_FREQ_ Unit interval in Gen2 DEVIATION tSSC_MOD_ RATE RRX_DC RRX_DIFF_DC ZRX_HIGH_IMP _DC_POS VRX_LFPS_ DET_DIFFp-p Conditions Max Units 199.94 200.46 ps 99.97 100.23 ps SSC deviation 0 -5000 ppm Modulation rate 30 33 kHz 18 30 Ω 72 120 Ω Receiver DC common mode impedance DC differential impedance Min Receiver high impedance 10k LFPS detect threshold 100 Typ Ω 300 mV DDC (I2C) Interface Timing Characteristics DDC (I2C) Interface Timing Symbol Description Conditions fSCL SCL clock rate Fast mode Hold time START After this period, the 1st clock starts tLOW Low period of clock SCL tHIGH High period of clock SCL tHD-STA Min Typ Max Units 0 - 400 kHz 1.2 - - s 1.3 - - s 1.2 - - s 1.2 - - s 0.7 - 0.99 s tsu;STA Set up time for a repeated START tHD;DAT Data hold time tSU;DAT Data setup time Bus free time between STOP and START Capacitance load for each bus line 380 - - ns 1.3 - - s - 100 400 pF tr Rise time 220 - 300 ns tf Fall time 60 0.25 VDD 0.2 VDD - 300 ns - - V - - V TBUF CB Vnh Noise margin at high level Vnl Noise margin at low level For master 9. The maximum tHD;DAT only has to be met if the device does not stretch the low period t LOW of the SCL signal. In the diagram below, S = start, P = stop, Sr = Repeated start, and SP = Repeated stop conditions. March 2023 - Revision 04d Page 21 of 35 Kinetic Technologies Confidential KTM5030 I2C Host Interface Timing (Figure 7. I2C Timing) Symbol FSCL Description Min Typ SCL Clock Frequency Max Units 400 kHz thd: DAT Data hold time 0 - µs tSU :DAT Data set-up time 50 - ns 20x (VDD/5.5) 0.5 120 ns 120 ns tR Rise time of both SDA and SCL signals tF Fall time of both SDA and SCL signals tBUF Bus free time between a STOP and START condition - µs CB Capacitance load for each bus line - 550 pF Data valid time - 0.45 µs Data valid acknowledge time - 0.45 µs Time for I2C SINGLE BYTE READ - 110 µs Time for I2C SINGLE BYTE WRITE - 85 µs Time for I2C Multi BYTE READ - 100+35/byte µs 85+30/byte µs tVD: DAT tVD: ACK tI2C_SBR (400 kHz) tI2C_SBW (400 kHz) tI2C_MBR (400 kHz) tI2C_MBW (400 kHz) Time for I2C Multi BYTE WRITE SDA tf tLOW tSU; DAT tr tf tHD; STA tSP tr tBUF SCL S tHD ; STA tHD;DAT tHIGH tSU ;STA Sr tSU; STO P S Figure 7. I2C Timing March 2023 - Revision 04d Page 22 of 35 Kinetic Technologies Confidential KTM5030 SPI Interface Timing Characteristics SPI Interface Timing for Normal Operating Mode10 Symbol Description Min Typ Max Units 50 75 MHz FCLK SPI_CLK output clock frequency for normal SPI mode TSCKH Serial clock high time 9.2 ns TSCKL Serial clock low time 9.2 ns TR_SPI_CLK SPI_CLK rise time @10mA drive 10pF load TF_SPI_CLK SPI_CLK fall time @10mA drive 10pF load 2.8 ns 3.2 ns TCSN_SU CSN output setup time requirement 7 ns TCSN_HLD CSN output hold time requirement 7 ns T_DO_PD Data Output propagation delay 6 ns TDI_SU Data Input setup time 3 ns TDI_HLD Data Input hold time 5 ns 10. These specifications specify the typical SPI_CLK output frequency and the minimum requirements of the interface between the SPI NOR Flash device and KTM5030. March 2023 - Revision 04d Page 23 of 35 Kinetic Technologies Confidential KTM5030 Interface Description UFP AV Interface The UFP AV interface consists of 4 highspeed lanes, Auxiliary channel (Side band channel) and HPD out. The highspeed lanes can receive DP audio-video streams or USB data from a source device through DP or USB Type-C link. The high-speed lane mapping is configurable to match the standard DP connector or the USB Type-C connector. The following table shows the KTM5030 high-speed main lanes and side band channel signal mapping for the USB Type-C and DP connector. STRAIGHT MAP FLIPPED MAP USB TYPE-C STD DP Assignment Assignment Assignment Assignment CONNECTOR CONNECTOR C D C D PIN NAME DP DP + USB DP_BR DP_BR+USB PIN NAME KTM5030 PIN SIGNAL NAME B8 SBU2 AUX_CH_P AUX_CH_P AUX_CH_N AUX_CH_N 15 AUX_CH_P D4 RX_AUXP_SBU2 A8 SBU1 AUX_CH_N AUX_CH_N AUX_CH_P AUX_CH_P 17 AUX_CH_N D3 RX_AUXN_SBU1 B11 RX1+ ML2+ SSRX+ ML1+ ML1+ 12 ML0_P A12 RX_L0P_SSRX1P B10 RX1- ML2- SSRX- ML1- ML1- 10 ML0_N B12 RX_L0N_SSRX1N A2 TX1+ ML3+ SSTX+ ML0+ ML0+ 9 ML1_P A10 RX_L1P_SSTX1P A3 TX1- ML3- SSTX- ML0- ML0- 7 ML1_N B10 RX_L1N_SSTX1N B3 TX2- ML0- ML0- ML3- SSTX- 6 ML2_P B5 RX_L2P_SSTX2N B2 TX2+ ML0+ ML0+ ML3+ SSTX+ 4 ML2_N A5 RX_L2N_SSTX2P A10 RX2- ML1- ML1- ML2- SSRX- 3 ML3_P B3 RX_L3P_SSRX2N A11 RX2+ ML1+ ML1+ ML2+ SSRX+ 1 ML3_N A3 RX_L3N_SSRX2P RX PHY AUX CH LANE 0 LANE1 LANE 2 LANE 3 If the UFP connector in the system is DP, then all the UFP interface signals are routed to the connector, if the UFP connector is USB Type-C then only the high-speed lanes are routed connector, HPD may connect to the PD controller or remain unused. The AUX signal shall use the AC-coupling capacitors and 1M termination (Pull-up on AUX_CH_P and Pull-down on AUX_CH_N). The HPD out is a 1.8V TTL signal, it shall use 100K pull-down to GND. The KTM5030 can be powered from the connected DP or USB Type-C source or from an external power supply depending on the application. The AUX CH supports both native AUX transaction syntax and I2C-over-AUX transaction syntax. DP source access the EDID from the downstream sink using I2C-over-AUX transactions. EDID larger than 256 bytes can be accessed using segmented addressing mechanism specified in the E-DDC standard. The KTM5030 supports link training with AUX transactions as specified in DP1.4A. The usage of TPS4 (Training Pattern Sequence 4) is recommended to optimize both DPTX PHY drive setting of DP source and its own DPRX EQ setting. If a DP source does not support TPS4, POST_LT_ADJ_REQ procedure is recommended as defined in DP1.4A. Once the DP source has performed link training, but later stops the main link signal transmission (for example, transitioning to the power saving state with DPCD 00600h set to 02h), another full link training is required to re-establish the link. KTM5030 also supports the link training policy defined for DP alternative mode sources. In this policy, the lane count is reduced to match the number of lanes physically connected based on the DPCD clock recovery status register [LANEx-CR_DONE]. By default, the firmware keeps DP_HPD asserted unless it is in power OFF state, regardless of whether DFP HPD input is asserted or not. The DFP HPD input status is reflected on SINK_COUNT value at DPCD 00200h. The value is 1 when the DFP_HPD input is asserted, and 0 when de-asserted. Whenever KTM5030 detects DFP_HPD input status change, it generates IRQ_HPD on the UFP_HPD line. Other signaling requirements for UFP interface such as cable sense or power sense are supported through GPIOs. March 2023 - Revision 04d Page 24 of 35 Kinetic Technologies Confidential KTM5030 DFP Interfaces The KTM5030 DFP interface consists of three AV ports, one USB3.2 port and a digital audio output port. AV Interface The three DFP interfaces can be configured as below: DFP Drive Architecture AC Coupled DP++ DC Coupled HDMI AC Coupled HDMI TX1 VML Y N Y TX2 CML Y Y Y TX3 VML Y N Y Each interface has 4 high speed main lanes, side band channels (AUX CH or DDC CH) and HPD inputs. The max signaling rate is 8.1Gbps per lane in AC coupling mode and 6.0Gbps in DC coupling mode. TX2 transmitter has a port determination power pin TX_CM which decides the AC or DC coupled mode of operation. For AC coupled DP++ mode TX_CM pin shall connect to 1.8 V, for DC coupled HDMI mode it is left open. The high-speed main lanes shall use 0.1µF capacitor in DP++ mode or terminated to 3.3 V by the downstream sink in HDMI mode. KTM5030 autonomously controls both TMDS character clock divide by 4 and scrambling as defined by HDMI2.0b. Differential voltage swing, pre-emphasis, edge rate, and source termination can be controlled through programming.. When a Port is used in HDMI AC-Couple mode, external level translators are not required. On- board passive circuitry on High-speed and VCM Pins allow direct connection to HDMI connectors. Each DFP AV interface has an AUX CH and DDC CH pins. In DP++ mode these signals are routed to the DP connector using an external analog switch. The switching selection is based on the CONFIG1 signal status. In HDMI mode the DDC pins are directly connected to the HDMI connector with a pull-up to VDD33. The HPD input on each AV interface is directly connected to the HPD from the downstream sink through DP or HDMI connector. A 47K pull-down is recommended for the HPD input. USB3.2 Interface The DFP USB3.2 interface has a TX and a RX differential pair supporting USB 3.2 Gen1 and Gen2 bit rate streams. This is an extension of the UFP USB interface with signal integrity enhancement. KTM5030 supports BLR (Bit-LevelRetimer for the SS mode and SRIS (Separate Reference clock Independent SSC) for SSP mode. The TX and RX pair may connect to an in-system USB hub or to a downstream facing USB connector. Audio Interface The audio output interface in KTM5030 can be configured to transmit audio in I2S, TDM or SPDIF format exclusively. This digital audio interface comprises of 6 multi-purpose input/output pins. Functional description of these pins is covered in the connection section. KTM5030 is capable of extracting audio from the incoming AV streams and transmit on the digital audio interface for external audio CODEC. The audio stream selection and the output format selection are configurable through firmware. In SPDIF configuration, there are 4 audio pins, each can be configured to drive 2-Channel PCM or compressed audio data from a single stream source. Maximum toggle rate in this format is limited to 50MHz. In I2S configuration 6 audio pins (4 data, bit clock, word clock) are used to drive 8-Channel audio data. In TDM format 3 audio pins (1 data, bit clock, word clock) are used to driver 8-Channel audio in time division multiplexing. The security policy engine in KTM5030 prevents transmission of protected audio through digital audio interface port. SPI Interface KTM5030 uses an external SPI flash memory to store the firmware. This is a standard SPI interface comprises of following signals: SPI_CSN, SPI_WPN, SPI_HOLD, SPI_DO, SPI_DI, SPI_CLK. KTM5030 supports single, dual, quad and QPI read mode operation. SPI clock speed is programmable, and the maximum supported clock speed is 75MHz. Commercial SPI flash of 16Mbit size, operating at 1.8V supply is recommended. Contact Kinetic for the list of qualified SPI flash devices. March 2023 - Revision 04d Page 25 of 35 Kinetic Technologies Confidential KTM5030 I2C Interface KTM5030 has an I2C master and a slave interface port for in-system connectivity with peripheral devices. It supports standard I2C protocol with maximum data rate up to 400Kbps. The I2C data and clock pins are 3.3V/5V tolerant and should connect to a 3.3 or 5V supply through an external 2.2K pull-up. The I2C master interface signals are multifunction pins; these pins can also function as operating mode configuration signals for external PD / TCPC controller. The I2C slave interface uses an ALERT signal to interrupt the external master. The I2C slave, host interface, is initialized to accept I2C transactions directed to device identifier 0xE0-0xE7. Bootstrap 6 and 7 shall be used to select the I2C slave device identifier according to the table below: Table 6. Bootstrap Selectable I2C Slave Device Identifiers Bootstrap 7 Low Low High (1.8V) Bootstrap 6 Low High(1.8V) Low I2C Device Identifier E0/E1 E2/E3 E4/E5 High(1.8V) High(1.8V) E6/E7 March 2023 - Revision 04d Page 26 of 35 Kinetic Technologies Confidential KTM5030 Chip Power-up Sequence and Reset KTM5030 requires 0.95V, 1.8V - power supply for its operation. These power supply rails can be generated from external voltage regulators. Refer to the electrical specification section for the supply ratings and maximum power consumption of the device.Power Sequencing is not required by the SOC between the 1.8V & 0.95V Rails though there may be requirements based on specific usage (Type-C Interface). However care must be taken to ensure that ramp-up of Power Rails is greater than 100uS. Power-On Reset The Power-On Reset unit generates an internal chip reset under two conditions: One, when the both 1.8V and 0.95V supply voltages cross the threshold level. Two, when the RESETN signal to the chip is held low for certain duration and released. The figure below shows internal reset signal generation in relation to the power supply threshold, ramp-up sequence and RESETN signal timing. During rail power up, the voltage (pull-up resistor to 1.8V supply) on RESETN pin is sensed by the internal Power-On Reset (POR) circuit to generate an internal reset pulse. The internal reset pulse is low until both the 1.8V and 0.95V rails are stable and continues to stay low for at least 1.5ms after the 0.95V power rail reaches 0.675Vand the 1.8V power rail reaches 1.35V (nominal threshold levels). During the device power up, the 1.8V supply should lead the 0.95V supply (VDD18 >= VDDP9 for t > 0). VDD18 EXT_ RESETn pulled low by for 0.2ms VDD1V8 Rail VT18 Voltage 1.35V At any time: VDD18> = VDD0P9 VDD0P9 Rail VT09 t 0.675V tR 1.5 ms (typ) EXT_ RESETn kept low by INTERNAL_RESETn after a narrow glitch( ~ 25ns) INTERNAL_RESETn (dotted line) Time tP > 0.2ms 1.5 ms (typ) Figure 8. Power-up and Reset Timing Sequence Any time a power supply glitch causes the power rails to fall below the nominal threshold voltage levels, the internal reset signal drops and stays low for at least 1.5ms after both power rail exceed their nominal threshold voltage levels again. The external reset signal pin RESETN should be connected to 1.8V power supply through a 2.2K resistor. The RESETN pin may be driven by an external open-collector drive or push-button switch to assert a chip reset. A 10pF external capacitor is recommended at the RESET pin to keep the external reset signal low at least 0.2ms to generate proper chip reset. RESETn pin is input/output open-drain analog pad, therefore it require external pull-up resistor to 1.8V/3.3V. RESETn is an “Active-LOW” signal. IO Pad behavior as open-drain Output pad: • Chip can drive RESETn pin either “LOW” or “Hi-Z” • During power ramp-up, RESETn pad is used as status pin. • It is weakly pulled High (follows the power rail) by external resistor, once power rails reached set thresholds internal driver pulls it Low and chip enters in Reset mode. • After ~1.5mS reset is de-asserted switching-off the internal driver and RESETn pin is pulled High by external resistor, chip comes out of reset mode and ready for normal operation. • Leakage current when driver is off ~20nA – 100nA depending on process corner and junction temp March 2023 - Revision 04d Page 27 of 35 Kinetic Technologies Confidential KTM5030 IO Pad behavior as Input pad: • Internal driver is off, RESETn is High (pulled up by external resistor) and chip is in normal mode of operation • When External Reset is required, LOW pulse should be applied to RESETn externally • RESETn input pulse is processed through input buffer and generates a reset signal to core. • For input buffer to detect signal as Low, voltage at RESETn pin
KTM5030B0T 价格&库存
很抱歉,暂时无法提供与“KTM5030B0T”相匹配的价格&库存,您可以联系我们找货
KTM5030B0T
  • 1+134.240241+17.45080
  • 10+106.2029510+13.80604
  • 25+99.1948625+12.89501
  • 100+95.08104100+12.36023
库存:611
