2108-P
2108-P
    TECHSPRAY
    Conformal
    TURBO-COAT ACRYLIC CONFORMAL COA
2108-P 数据手册
Rev. D (3/21) Page 1 of 4 Turbo-Coat Acrylic Conformal Coating Product# 2108 Product Description TurboCoat Acrylic Conformal Coating is designed to speed up board production throughput without additional investment of expensive UV systems or other capital equipment. Conformal coating cure time is often considered a production bottleneck for PCB assembly operations. TurboCoat dries tack free in 3 minutes, allowing manufactures to handle boards in 1/3 the time of the leading acrylic coating! Full cure can be achieved as quickly as 10 minutes with elevated temperatures. Features / Benefits • Fastest Cure – Dry to Touch in 3 Minutes! • Faster Throughput without Capital Investment • Thick Coating – One-Pass Application • Fast & Easy Rework & Repair • IPC-CC-830 Tested • UL94 V-0 Rated • Crystal Clear & Glossy Finish • UV Indicator for Black Light QC Inspection • MEK, Toluene & Xylene Free • Adjustable spray head (Aerosol) Applications Electronic Assemblies for... • Automotive • Aviation • Consumer Electronics • Appliances • Industrial Meters & Control Usage Instructions For industrial use only. Read SDS carefully prior to use. Before applying Turbo-Coat™ conformal coating, clean circuit boards to remove contamination and allow to dry. Cleaning is recommended for optimal adhesion, and may be performed with Techspray G3, E-LINE™ and Precision-V defluxers. Spray Application: Apply top to bottom, allowing coating to flow evenly around components. Repeat application 3 additional times from varying directions to prevent component shadowing. Then allow board to cure. If additional thickness is desired, apply additional coatings. When using liquid spray with automatic dispensing equipment, adjustments may be required in application rate and viscosity. Typical Product Data and Physical Properties Physical State: Odor: Color: Percent Volatile: Vapor pressure: Liquid Characteristic odor Clear, colorless 93.4 at 25ºC (77ºF) 14.52 mmHg @ 20ºC Vapor density: Boiling Point: Flashpoint and method: Solubility in water: Evaporation rate: >1 (Air=1) 39.4ºC (103ºF) 1.49ºC (35ºF) Negligible >1 (n-Butyl Acetate=1) Density: Viscosity #1: VOC: Shelf life: 0.834 at 25ºC (77ºF) 10 to 20 Centipoise at 25ºC (77ºF) 33.240% by weight 2 years Chemical Components Acrylic Polymer (non-hazardous) n-Propyl acetate CAS#109-60-4 Acetone CAS#67-64-1 n-Heptane CAS#142-82-5 Dip Application: Using automatic equipment or hand immersion technique, slowly immerse PCB into the coating and remove slowly. Use an average rate of approximately 1 foot per minute. After allowing the board to cure, process may be repeated to achieve desired thickness. Brush Application: Evenly apply coating to areas desired at thickness required. Allow time for curing before reapplying to achieve a thick coating. Use WonderMASK to protect components during conformal coating process. After application, cured Fine-L-KoteTM may be removed using Techspray Conformal Coating Removal Pen (2510-N or 2510-P). 800-858-4043 • www.techspray.com Rev. D (3/21) Page 2 of 4 Turbo-Coat Acrylic Conformal Coating Product# 2108 Thinning/Removal Techspray® coatings can be thinned to meet production requirements using Conformal Coating Thinner (2105). Conformal Coating Remover (2510) is also available for rework and repair, although coating is often just burnt through in the soldering process for spot repairs. Techspray® coatings contain Opti/Scan to allow quality control inspection of coverage and evenness of the coating on a PCB. A coated board can be passed under a standard, low-cost UV (black) light, and the coated areas glow. The brighter the glow, the thicker the coating. Coverage (1mil dry film) 1 aerosol can = 14ft2 (1.3M2) 1 gal. lquid = 272ft2 (25.3M2) Application Application Method Cure time Accelerated cure time Dry time to touch Quality inspection method of coverage Removal method Characteristics As Supplied: Visual appearance Density (25 C) Viscosity (25 C) Cure Profile Accelerated Cure: Ambient Cure: Tack-Time (dry to touch): Test Data 20 minutes @ 149°F / 65°C 15 hours @ 74°F / 23°C (ambient temp) 3 minutes @ 74°F / 23°C (ambient temp) Cure time depends on a number of factors, including the method and thickness of application. Dilution will also change the cure profile. 149°F / 65°C is recommended as the best accelerated temperature to optimize leveling, providing the smoothest possible finish. A faster cure may be achieved, but should be thoroughly tested first. Operating Temperature Test Method* TS-053 TS-054 TS-055 2108 Test Results Spray system, dip, or brush 24 hours 25 min @65C 3 min UV (long-wave black) light Alkane, Acetone or Acetate, Solder iron burn through Test Method TS-050 TS-019-1 Instrument (Brookefield RVT) guide Solids % TS-015 Flash point Vapor pressure (20 C) (VOC composite) Maximum Incremental Reactivity (MIR) Initial boiling point Stability (30-day test @ 37 C/100 F) Stability (30-day test @ 6.1 C/21 F) ASTM D-56 (TAG CC) Calculated Resin T g Resin mol wt 2108 Test Results Clear 0.8603 g/ml 20 cp -85º -257ºF / -65º -125ºC Aerosol - 16% Bulk - 16-18% 1.7C(35F) 25.02mm Hg 0.35 TS-051 TS-052 39.4C (103F) Stable TS-052-1 Stable provided by supplier provided by supplier 50-55C 60,000 800-858-4043 • www.techspray.com Rev. D (3/21) Page 3 of 4 Turbo-Coat Acrylic Conformal Coating Product# 2108 Certified Testing NO 200 2B 5B Observations Adhesion (ASTM D3359) - Higher is better 3 Hardness (Gardner Pencil) - Lower is harder Tack-Free Time (minutes) YES Threshold Limit Value (TLV) - Lower is more hazardous UL94 Tested V-0 Rated YES Contains MEK, Toluene, Xylene MIL-I-46058C / IPC-CC-830 Techspray 2108-12S Competitive Comparison High gloss, fast/even level, soft/med spray pattern As Cured - Physical Test Method ASTM D-149, IPC-TM650 2.5.6.1, Rev. A ASTM D-3359 ASTM D-3363 ASTM D-1005 Dielectric strength Adhesion Film hardness Film thickness (1 dip) Techspray 2103-12S 17 NO 200 4B 4B Med gloss, even level, soft/med spray pattern Humiseal 1B31 YES N0 9 MEK, Toluene 50 4B 4B Good gloss, patchy level, good pattern Chemtronics CTAR-12 MG 419B Loctite 3900 Humiseal 1B73 NO IPC-CC-830B 3.5.2 IPC-CC-830B 3.5.3 IPC-CC-830B 3.5.6 IPC-TM-650 2.6.1.1 IPC-TM-650 2.4.5.1 IPC-TM-650 2.5.7.1 IPC-TM-650 2.6.3.4 IPC-TM-650 2.6.7.1 IPC-TM-650 2.6.11.1 pass UL Qualification Test Method Coating flammability UL94/746E YES NO NO YES YES NO NO YES 33 6 10 33 MEK, Toluene Toluene Toluene, Xylene MEK 50 50 50 50 2B 4B 6B 4B 4B Good gloss, good level, very wide pattern 5B Good gloss, good level, med cone pattern 4B Uneven gloss, orange peel texture, very soft spray pattern 4B High gloss, uneven spray pattern, large amount of material Test Method Appearance Fluorescence Flammability Fungus resistance Flexibility Dielectric withstand voltage Moisture & insulation resistance Thermal shock Temperature humidity ageing 1000 volts 5B 2B 1 mil (0.001”) 2108 Test Results V-0 2108 Test Results pass pass pass pass pass pass pass pass IPC-CC-830B Qualification YES 2108 Test Results Chemical Compatibility – Industrial Chemicals INDUSTRIAL CHEMICALS Methanol Ethanol IPA 70% IPA 50% Ethanol DPM Glycol ether EB THF Acetone n-propyl acetate t-butyl acetate Hexane Heptane Cyclopentane Cyclohexane T oluene Trans-dce EFFECT CAS # Soften Dissolution Dissolution Dissolution No effect Dissolution Dissolution Dissolution Dissolution Dissolution Dissolution Dissolution Soften Dissolution Dissolution Dissolution Dissolution 67-56-1 64-17-5 67-63-0 67-63-0 64-17-5 34590-94-8 111-76-2 109-99-9 67-64-1 109-60-4 540-88-5 110-54-3 142-82-5 287-92-3 110-82-7 108-88-3 800-858-4043 • www.techspray.com Rev. D (3/21) Page 4 of 4 Turbo-Coat Acrylic Conformal Coating Product# 2108 Chemical Compatibility – Household Chemicals HOUSEHOLD CHEMICALS 5% Acetic acid 0.1N Hydrochloric acid 50% Nitric acid Parson's solution 0.1N Potassium hydroxide 45% Potassium hydroxide d-limonene Chlorox neat Chlorox 1:1 Chlorox 1:4 Pine-Sol Lemon Pro 409 EFFECT No effect No effect EXAMPLE OF US BRAND NAME Heinz Vinegar Lime-A-Way Toilet Bowl Cleaner Packaging and Availability 2108-12S 2108-P 2108-G 2108-5G 12oz. Liquid 1 Pint Liquid 1 Gallon Liquid 5 Gallon Liquid Environmental Policy Techspray® is committed to developing products to ensure a safer and cleaner environment. We will continue to meet and sustain the regulations of all federal, state and local government agencies. No effect No effect Windex Resources No effect 10% Liquid Plumber No effect Liquid Plumber Techspray® products are supported by global sales, technical and customer services resources. Dissolution No effect No effect No effect No effect No effect Orange Glo Chlorox 50% Chlorox 20% Chlorox Pine-Sol Lemon 409 Professional In most cases, Techspray® corporate test methods (TS designation) correspond to standard ASTM Copies of Techspray® corporate test methods are available upon request. Corporate Office 8125 Cobb Center Drive Kennesaw, GA 30152 800-858-4043 tsales@techspray.com For additional technical information on this product or other Techspray® products in the United States, call the technical sales department at 800-858-4043, email tsales@techspray.com or visit our web site at: www.techspray.com. Important Notice to Purchaser/User: The information in this publication is based on tests that we believe are reliable. The results may vary due to differences in tests type and conditions. We recommend that each user evaluate the product to determine its suitability for the intended application. Conditions of use are outside our control and vary widely. Techspray’s only obligation and your only solution is replacement of product that is shown to be defective when you receive it. In no case will Techspray® be liable for any special, incidental, or consequential damages based on breach of warranty, negligence or any other theory. Europe ITW Contamination Control BV Saffierlaan 5, 2132 VZ Hoofddorp The Netherlands +31 88 1307 400 info@itw-cc.com China ITW Specialty Materials (Suzhou) Co., Ltd Hengqiao Road, Wujiang Economic Development Zone, Suzhou, Jiangsu Province, China 215200 +6019-2184801 chinasales@itwsms.com
2108-P 价格&库存
很抱歉,暂时无法提供与“2108-P”相匹配的价格&库存,您可以联系我们找货
