10-1319.1199
10-1319.1199
    EAO
    Module
    可配置开关灯 白炽 透明 48V
10-1319.1199 数据手册
Series Series 22 Proven. Durable and powerful. https://eao.com/ 22 22 Information about the Series Markings Key advantages § Reliable switching of high § Compact construction § Long travel tactile action loads § Engraving § Hot stamping § Film insert/marking Typical application areas Approvals § Building services and automation § Control cabinets § Rail, electrical and waterbound vehicles § CB (IEC 61058) § CSA § ENEC (EN 61058) § UL plate Functions § Illuminated pushbutton § Mushroom-head pushbutton § Selector switch § Indicator Conformities § CE § 2014/35/EU § 2011/65/EU (LVD) (RoHS) Design § Flush IP front protection § IP65 Raitings § 400 VAC (10 A) Mounting cut-outs § 22 mm x 30 mm Terminal § Plug-in terminal § Screw terminal Lens Material § Plastic 428 ​ eao.com § 10/2022 Index 22 Flush design Illuminated pushbutton 430 Mushroom-head pushbutton 432 Keylock switch 2 positions 434 Indicator 435 Components 436 Accessories 439 Technical data 442 Marking 443 Application guidelines 445 01 02 03 04 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 10/2022 § eao.com ​ 429 22 Flush design Illuminated pushbutton, IP65 Equipment consisting of (schematic overview) 1.5 ... 6 02 03 A 04 7.5 B 29.3 x 21.3 01 59.5 Lens Page 436 Front bezel Page 436 LED Page 437 71.5 09 Product can differ from the current configuration. 14 Dimensions [mm] A = Screw terminal B = Plug-in terminal 6.3 mm x 0.8 mm Actuator NJO 17 Each Part Number listed below includes all the black components shown in the 3D-drawing.   r  18 NJO 3NBY 19 To obtain a complete unit, please select the red components from the pages shown.   r 22 Mounting cut-outs [mm] 31 Actuator, Front dimension 36 mm x 24 mm 41 45 Switching action Momentary 51 56 57 Maintained 61 70 71 Contacts Terminal Part No. Wiring diagram 1 NO Screw terminal 22-211.011 152 1 NO Plug-in terminal 22-211.014 152 1 NC Screw terminal 22-212.011 148 2 NO Screw terminal 22-213.011 155 2 NO Plug-in terminal 22-213.014 155 2 NC Screw terminal 22-214.011 154 1 NC / 1 NO Screw terminal 22-215.011 150 1 NC / 1 NO Plug-in terminal 22-215.014 150 1 NO Screw terminal 22-221.011 153 1 NO Plug-in terminal 22-221.014 153 1 NC Screw terminal 22-222.011 149 2 NO Screw terminal 22-223.011 156 2 NO Plug-in terminal 22-223.014 156 1 NC / 1 NO Screw terminal 22-225.011 151 1 NC / 1 NO Plug-in terminal 22-225.014 151 Contacts: NC = Normally closed, NO = Normally open 82 84 92 96 430 eao.com § 10/2022 Flush design 22 Wiring diagrams 01 21 x2+ 21 x2+ 13 21 x2+ 13 21 x2+ 13 x2+ 13 x2+ 22 x1- 22 x1- 14 22 x1- 14 22 x1- 14 x1- 14 x1- 02 03 04 Wiring diagram 148 Wiring diagram 149 Wiring diagram 150 Wiring diagram 151 Wiring diagram 152 Wiring diagram 153 09 Wiring diagrams 14 11 21 x2+ 13 23 x2+ 13 23 x2+ 12 22 x1- 14 24 x1- 14 24 x1- 17 18 19 Wiring diagram 154 Wiring diagram 155 Wiring diagram 156 22 31 41 45 51 56 57 61 70 71 82 84 92 96 10/2022 § eao.com ​ 431 22 Flush design Mushroom-head pushbutton, IP65 Equipment consisting of (schematic overview) 1.5 ... 6 02 03 A 04 17.5 B 29.3 x 21.3 01 Product can differ from the current configuration. 14 Page 436 Front bezel Page 436 59.5 71.5 09 Lens Actuator Dimensions [mm] A = Screw terminal B = Plug-in terminal 6.3 mm x 0.8 mm Each Part Number listed below includes all the black components shown in the 3D-drawing. NJO 17 To obtain a complete unit, please select the red components from the pages shown.   r  18 NJO 3NBY 19   r 22 Mounting cut-outs [mm] 31 Actuator, Front dimension 36 mm x 24 mm 41 45 Switching action Momentary 51 56 57 Maintained 61 70 71 Contacts Terminal Part No. Wiring diagram 1 NO Screw terminal 22-211.011 152 1 NO Plug-in terminal 22-211.014 152 1 NC Screw terminal 22-212.011 148 2 NO Screw terminal 22-213.011 155 2 NO Plug-in terminal 22-213.014 155 2 NC Screw terminal 22-214.011 154 1 NC / 1 NO Screw terminal 22-215.011 150 1 NC / 1 NO Plug-in terminal 22-215.014 150 1 NO Screw terminal 22-221.011 153 1 NO Plug-in terminal 22-221.014 153 1 NC Screw terminal 22-222.011 149 2 NO Screw terminal 22-223.011 156 2 NO Plug-in terminal 22-223.014 156 1 NC / 1 NO Screw terminal 22-225.011 151 1 NC / 1 NO Plug-in terminal 22-225.014 151 Contacts: NC = Normally closed, NO = Normally open 82 84 92 96 432 eao.com § 10/2022 Flush design 22 Wiring diagrams 01 21 x2+ 21 x2+ 13 21 x2+ 13 21 x2+ 13 x2+ 13 x2+ 22 x1- 22 x1- 14 22 x1- 14 22 x1- 14 x1- 14 x1- 02 03 04 Wiring diagram 148 Wiring diagram 149 Wiring diagram 150 Wiring diagram 151 Wiring diagram 152 Wiring diagram 153 09 Wiring diagrams 14 11 21 x2+ 13 23 x2+ 13 23 x2+ 12 22 x1- 14 24 x1- 14 24 x1- 17 18 19 Wiring diagram 154 Wiring diagram 155 Wiring diagram 156 22 31 41 45 51 Follow us. We are on YouTube! 56 EAO ermöglicht. Seit 1947. 57 61 70 71 Come take a look at our YouTube profi le today! Be sure to give us a follow so that you can fully interact with us. 82 https://www.youtube.com/user/eaoswitches 84 92 www.eao.com 10/2022 § eao.com 96 ​ 433 22 Flush design 01 Keylock switch 2 positions, IP65 Equipment consisting of (schematic overview) 1.5 ... 6 03 A 04 32 8 B 29.3 x 21.3 02 Actuator 59.5 71.5 09 Product can differ from the current configuration. 14 Each Part Number listed below includes all the black components shown in the 3D-drawing. Dimensions [mm] A = Screw terminal B = Plug-in terminal 6.3 mm x 0.8 mm General information NJO • Standard lock: DOM 311 • Front plastic black 3NBY   r  18 NJO 17 19   r 22 31 Mounting cut-outs [mm] 0 0 I I 41 Actuator, Front dimension 36 mm x 24 mm 45 51 56 57 61 70 Switching action Contacts Terminal Switching angle Part No. Wiring diagram Rest (a) - Maintained (a) 1 NO Screw terminal 90° right 22-331.511D 169 1 NO Plug-in terminal 90° right 22-331.514D 169 2 NO Screw terminal 90° right 22-333.111D 170 2 NO Plug-in terminal 90° right 22-333.114D 170 Rest (a) - Maintained (a) 2 NO Screw terminal 90° right 22-333.511D 170 Rest (a) - Maintained 1 NC / 1 NO Screw terminal 90° right 22-335.111D 168 Rest (a) - Maintained (a) 1 NC / 1 NO Screw terminal 90° right 22-335.511D 168 Rest (a) - Momentary 2 NO Screw terminal 45° right 22-353.111D 167 Rest (a) - Maintained Contacts: NC = Normally closed, NO = Normally open a = Key remove Wiring diagrams 71 13 23 13 21 13 13 23 14 24 14 22 14 14 24 82 84 92 Wiring diagram 167 Wiring diagram 168 Wiring diagram 169 Wiring diagram 170 96 434 eao.com § 10/2022 Flush design 22 Indicator, IP65 01 Equipment consisting of (schematic overview) 02 Page 436 A Front bezel Page 436 LED Page 437 B 29.3 x 21.3 Lens 1.5 ... 6 03 04 59.5 7.5 71.5 Actuator Dimensions [mm] A = Screw terminal B = Plug-in terminal 6.3 mm x 0.8 mm 09 Product can differ from the current configuration. 14 NJO NJO  To obtain a complete unit, please select the red components from the pages shown. 17 3NBY  r  Each Part Number listed below includes all the black components shown in the 3D-drawing. 18 19   r 22 Mounting cut-outs [mm] 31 41 Actuator, Front dimension 36 mm x 24 mm Terminal Part No. Wiring diagram Screw terminal 22-040.001 4 Plug-in terminal 22-040.004 4 45 51 Wiring diagrams 56 x2+ 57 x1- 61 Wiring diagram 4 70 71 82 84 92 96 10/2022 § eao.com 435 22 Components 01 02 03 Lens plastic Lens material Lens colour Lens optics Lens shape Lens illumination Dimensions Part No. Plastic Smokey black transparent flush illuminative 17 mm x 25,5 mm 22-903.1 04 09 Red transparent flush illuminative 17 mm x 25,5 mm 22-903.2 Orange transparent flush illuminative 17 mm x 25,5 mm 22-903.3 Yellow transparent flush illuminative 17 mm x 25,5 mm 22-903.4 Green transparent flush illuminative 17 mm x 25,5 mm 22-903.5 Blue transparent flush illuminative 17 mm x 25,5 mm 22-903.6 Colourless transparent flush illuminative 17 mm x 25,5 mm 22-903.7 Black opaque flush non illuminative 17 mm x 25,5 mm 22-901.0 14 17 18 Mushroom-head cap Product attributes Lens material Lens colour Lens optics Lens shape Lens illumination Dimensions Use only flush front bezel Plastic Black opaque mushroom-head non illuminative 23 mm x 35 mm 22-930.0 Plastic Red opaque mushroom-head non illuminative 23 mm x 35 mm 22-930.2 19 Part No. Plastic Yellow opaque mushroom-head non illuminative 23 mm x 35 mm 22-930.4 Plastic Green opaque mushroom-head non illuminative 23 mm x 35 mm 22-930.5 22 31 41 Front bezel raised 45 51 Product attributes Front bezel material Front bezel colour Dimensions Part No. Lens only removable with lens remover Part No. 98-969 Plastic Black 24 mm x 36 mm 02-967.0 Product attributes Front bezel material Front bezel colour Dimensions Part No. Lens only removable with lens remover Part No. 02-905 Plastic Black 24 mm x 36 mm 02-965.0 56 57 61 Front bezel flush 70 71 82 84 92 96 436 eao.com § 10/2022 Components 22 01 Single-LED, T1 3/4 MG Illumination colour Operating voltage Operation current Lumi. Intensity Dom. Wavelength Part No. Wiring diagram Red 6 V DC +10% 15 mA ±15 % 350 mcd 630 nm 10-2J06.3142 55 12 V AC/DC +10% 7 - 14 mA ±15 % 330 mcd 630 nm 10-2J09.1062 55 24 V AC/DC +10% 7 - 14 mA ±15 % 330 mcd 630 nm 10-2J12.1062 55 28 V AC/DC +10% 7 - 14 mA ±15 % 330 mcd 630 nm 10-2J13.1062 55 48 V AC/DC +10% 4 - 8 mA ±15 % 200 mcd 630 nm 10-2J19.1042 55 6 V DC +10% 15 mA ±15 % 300 mcd 587 nm 10-2J06.3144 55 12 V AC/DC +10% 7 - 14 mA ±15 % 280 mcd 587 nm 10-2J09.1064 55 24 V AC/DC +10% 7 - 14 mA ±15 % 280 mcd 587 nm 10-2J12.1064 55 28 V AC/DC +10% 7 - 14 mA ±15 % 280 mcd 587 nm 10-2J13.1064 55 48 V AC/DC +10% 4 - 8 mA ±15 % 180 mcd 587 nm 10-2J19.1044 55 6 V DC +10% 7 mA ±15 % 1050 mcd 525 nm 10-2J06.3145 55 12 V AC/DC +10% 4 - 7 mA ±15 % 1050 mcd 525 nm 10-2J09.1065 55 24 V AC/DC +10% 4 - 7 mA ±15 % 1050 mcd 525 nm 10-2J12.1065 55 28 V AC/DC +10% 4 - 7 mA ±15 % 1050 mcd 525 nm 10-2J13.1065 55 48 V AC/DC +10% 2 - 4 mA ±15 % 600 mcd 525 nm 10-2J19.1045 55 6 V DC +10% 15 mA ±15 % 680 mcd 470 nm 10-2J06.3146 55 12 V AC/DC +10% 4 - 14 mA ±15 % 650 mcd 470 nm 10-2J09.1066 55 24 V AC/DC +10% 7 - 14 mA ±15 % 650 mcd 470 nm 10-2J12.1066 55 28 V AC/DC +10% 7 - 14 mA ±15 % 650 mcd 470 nm 10-2J13.1066 55 48 V AC/DC +10% 4 - 8 mA ±15 % 400 mcd 470 nm 10-2J19.1046 55 6 V DC +10% 6 mA ±15 % 900 mcd x: 0.31 / y: 0.32 nm 10-2J06.3149 55 12 V AC/DC +10% 3 - 6 mA ±15 % 900 mcd x: 0.31 / y: 0.32 nm 10-2J09.1069 55 24 V AC/DC +10% 2,5 - 5 mA ±15 % 750 mcd x: 0.31 / y: 0.32 nm 10-2J12.1069 55 28 V AC/DC +10% 2,5 - 5 mA ±15 % 750 mcd x: 0.31 / y: 0.32 nm 10-2J13.1069 55 48 V AC/DC +10% 2 - 4 mA ±15 % 600 mcd x: 0.31 / y: 0.32 nm 10-2J19.1049 55 24 V AC/DC +10% 15/14 mA ±15 % 600/630 mcd 625 / 525 nm 10-A312.314A 171 Yellow Green Blue White Red / Green 02 03 04 09 14 17 18 19 22 31 41 Additional information 45 • Due to high surface temperatures, the series resistor must not be soldered directly to the terminals of the equipment (use a terminal plate) • When using AC/DC types with AC operation, slight flickering can occur 51 • The luminous intensity stated is for when used with DC • Electrical and optical data are measured at 25 °C 56 • The specified versions are built with a protection diode (halve wave rectifier) in series and the LED • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED 57 • Where supply voltages are over 48 V, a voltage-reduction element (external protective series resistor) must be used. 61 70 Ø6.1 max. 16 max. 71 82 84 Dimensions [mm] 92 96 10/2022 § eao.com 437 22 Components 01 Wiring diagrams x2+ 02 x2+ 03 x1x1- 04 Wiring diagram 55 Wiring diagram 171 09 14 Filament lamp 17 18 19 22 Operating voltage Operation current Part No. Wiring diagram 12 V AC/DC 75 mA ±10 % 10-1309.1309 4 14 V AC/DC 80 mA ±10 % 10-1310.1319 4 24 V AC/DC 35 mA ±10 % 10-1312.1229 4 28 V AC/DC 40 mA ±10 % 10-1313.1249 4 36 V AC/DC 30 mA ±10 % 10-1316.1209 4 48 V AC/DC 25 mA ±10 % 10-1319.1199 4 Wiring diagrams 31 x2+ 41 45 x1- 51 Wiring diagram 4 56 57 61 70 71 82 84 92 96 438 eao.com § 10/2022 Accessories 22 Front side 01 02 Blind plug Dimensions Material Colour Part No. 24 mm x 36 mm plastic Black 22-949.0 03 04 09 Spare key Product attributes Material Part No. Standard lock: DOM 311 metal 31-989.311 14 17 Master key Product attributes Material Part No. For standard lock: DOM 311 … 445 metal 31-989.300 18 19 22 Protective cover Material Optics Mounting cut-out Part No. Plastic transparent 22 mm x 30 mm 22-925 31 41 Additional information • Hinged, with means for sealing 45 • Please note that bigger minimum distances are necessary • Use only flush front bezel 18 51 36.5 36 30 13.7 29.7 56 57 2 10.5 61 Dimensions [mm] 70 71 82 84 92 96 10/2022 § eao.com 439 22 Accessories 01 Rear side 02 03 04 Side terminal plate empty Product attributes Dimensions Part No. 5 spaces 62.5 mm x 15 mm x 60 mm 02-912.1 10 spaces 125 mm x 15 mm x 60 mm 02-912.2 15 spaces 187.6 mm x 15 mm x 60 mm 02-912.3 20 spaces 250 mm x 15 mm x 60 mm 02-912.4 Operating voltage Resistance Part No. 110 V AC 2.7 kOhm 02-904.0 125 V AC 3.3 kOhm 02-904.1 145 V AC 4.7 kOhm 02-904.3 240 V AC 10 kOhm 02-904.7 09 14 17 18 19 22 Series resistor Additional information • Only for filament lamp 48 VAC, 25 mA • Due to high surface temperatures, the series resistor must not be soldered directly to the terminals of the equipment (use a terminal plate) 31 41 45 51 56 57 61 70 71 82 84 92 96 440 eao.com § 10/2022 Accessories 22 Mounting 01 02 Dismantling tool Product attributes Material Part No. For dismantling the lens from the holder metal / plastic 22-938 03 04 Lens remover 09 Product attributes Material Part No. For raised design metal 02-905 For dismantling of the square lens, flush design metal 98-968 14 17 Lamp remover 18 Product attributes Material Part No. A switching action may occur when replacing the lamp plastic 61-9740.0 19 22 31 41 45 51 Follow us. We are on LinkedIn! 56 EAO creates possibilities. Since 1947. 57 61 70 71 Come take a look at our LinkedIn profi le today! Be sure to give us a follow so that you can fully interact with us. 82 https://www.linkedin.com/company/eao/ 84 92 www.eao.com 10/2022 § eao.com 96 441 22 Technical data 01 02 03 04 09 14 Actuator with snap-action switching element Switching system Electrical characteristics Self-cleaning, double-break, snap-action switching system (with contact gap 2 x 1.5 mm). Max. 2 normally closed or 2 normally open contacts, or one of each. Switching voltage and switching current Material Lens 400 VAC, 10 A (ohmisch) 400 VAC, 4 A (induktiv, cos(phi) = 0,7) 250 VAC, 5 A (induktiv, cos(phi) = 0,7) 250 VAC, 2 A (induktiv, cos(phi) = 0,7) 125 VAC, 8 A (induktiv, cos(phi) = 0,7) 110 VDC, 0,4 A (induktiv, L:R = 30 ms) 60 VDC, 1,5 A (induktiv, L:R = 30 ms) 24 VDC, 6 A (induktiv, L:R = 30 ms) Plastic, as per UL 94 HB Electric strength 17 Front bezel Plastic 2500 VAC, 50 Hz, 1 minute between all terminals and earth, as per IEC 60512-2-11. 18 Material of contact Electrical lifetime Hard silver 50 000 cycles of operation 19 Actuator housing Ambient conditions Plastic 22 31 41 45 51 56 57 Storage temperature Mechanical characteristics – 40 °C ... + 95 °C Terminals Operating temperature Screw terminal (with self-lifting clip): Max. wire cross-section 2 x 2.5 mm² Max. wire cross-section of stranded cable 2 x 1.5 mm² – 25 °C ... + 85 °C for the switch body and up to + 55 °C for the actuating part Protection degree Plug-in terminal 6.3 mm x 0.8 mm Actuating force With 1 switching element 3.6 N ±0.3 N With 2 switching elements 6.8 N ±0.3 N Shock resistance Actuating travel Vibration resistance 5.5 mm ±0.2 mm (sinusoidal) 10 g at 10 Hz … 2000 Hz, amplitude 0.75 mm, as per IEC 60512-4-4 Travel 61 70 50 g for 11 ms, as per IEC 60512-4-3 3 mm Mechanical lifetime Approvals Illuminated pushbutton 1 million operations Keylock switch 40 000 operations Approbations CB (IEC 61058-1) CSA ENEC (EN 61058-1) UL 71 82 Conformities 84 CE 2014 / 35 / EU (LVD) 2011 / 65 / EC (RoHS) 92 96 IP20 terminal / case IP65 front side, as per IEC 60529 EAO reserves the right to alter specifications without further notice. 442 ​ eao.com § 10/2022 Marking 22 General notes 01 1. Engraving 3. Film inserts In addition to the most commonly used world languages, in DIN1451-3 close spacing, other typefaces are available as Scandinavian, Slavic, Greek, Russian and Polish. Red, blue and black lenses are filled with white colour. Other colour lenses are filled in black. Standard height of letters is 3 mm. If the height is not specified, we will supply 3 mm engraved letters. Instead of using engraving the lenses can be fitted with transparent film inserts, as an alternative. For this purpose, though, it is advisible to use transparent lenses. In the case of use of a smoke-black lens the fitted film becomes readable only if the lamp is on. The film thickness is 0.2 mm. 02 03 04 Important: Consider pushbutton mounting orientation befor specifying 09 engraving characters! 2. Hot stamping For larger series it is worth considering markings by means of hot stamping. We will pleased to advise you. 14 Engraving film insert 17 All dimensions in mm Film insert max. dimensions Height of letters h 14.3 x 22.4 3 4 18 Number of lines Number of capital letters per line (guide value) Number of lowercase letters per line (guide value) 3 9 10 B1 2 7 8 B1 Picture 5 2 5 6 B1 6 1 4 5 B1 8 1 3 4 B1 3 5 6 6 B2 4 4 4 5 B2 5 3 3 4 B2 6 2 3 3 B2 8 2 2 2 B2 B2 ABC abc ABC abc h B1 19 22 31 41 45 51 56 57 The gap between two words results in each case a letter less. 61 70 71 82 84 92 96 10/2022 § eao.com ​ 443 22 Marking Engraving lens All dimensions in mm 02 03 Number of lowercase letters per line (guide value) Lens Height of letters h Number of lines Number of capital letters per line (guide value) 17.5 x 25.5 3 4 10 11 B1 4 3 8 9 B1 04 09 14 17 Picture 5 2 6 7 B1 6 2 5 6 B1 8 1 4 4 B1 3 6 7 8 B2 4 4 5 6 B2 5 4 4 5 B2 6 3 3 4 B2 8 2 3 3 B2 18 19 B1 B2 ABC abc ABC abc h 01 22 The gap between two words results in each case a letter less. 31 41 45 51 56 57 61 70 71 82 84 92 96 444 ​ eao.com § 10/2022 Application guidelines 22 Suppressor circuits 01 When switching inductive loads such as relays, DC motors, and DC solenoids, it is always important to absorb surges (e. g. with a diode) to protect the contacts. When these inductive loads are switched off, a counter emf can severely damage switch contacts and greatly shorten lifetime. Fig. 1 shows an inductive load with a free-wheeling diode connected in parallel. This free-wheeling diode provides a path for the inductor current to flow when the current is interrupted by the switch. Without this free-wheeling diode, the voltage across the coil will be limited only by dielectric breakdown voltages of the circuit or parasitic elements of the coil. This voltage can be kilo- 02 volts in amplitude even when nominal circuit voltages are low (e. g. 12 VDC) see Fig. 2. The free-wheeling diode should be chosen so that the reverse breakdown voltage is greater than the voltage driving the inductive load. The DC blocking voltage (VR) of the free-wheeling diode can be found in the datasheet of a diode. The forward current should be equal or greater than the maximum current flowing through the load. To get an efficient protection, the free-wheeling diode must be connected as close as possible to the inductive load! Switch ON 04 09 14 17 Counter EMF over load without free-wheeling diode Fig. 2 Switching with inductive load Fig. 1 03 18 OFF 19 0 VDC + _ Free-wheeling diode Inductive load Several hundred to several thousend volts 22 di __ e = L dt 31 41 LED polarity 45 When fitting the LED element the polarity has to correspond with the respective terminal, (+) goes to +. +X2 51 56 (+X2) (-X1) 57 61 70 71 82 84 92 96 10/2022 § eao.com ​ 445
10-1319.1199 价格&库存
很抱歉,暂时无法提供与“10-1319.1199”相匹配的价格&库存,您可以联系我们找货
  • 1+52.235051+6.75740
  • 10+48.2169710+6.23760
  • 25+46.0332325+5.95510
  • 50+44.3735850+5.74040
  • 100+42.53924100+5.50310
  • 250+40.35550250+5.22060
  • 500+38.60851500+4.99460
  • 1000+36.948871000+4.77990
  • 1+50.85077
  • 5+48.84090
  • 10+46.96641
  • 25+45.85213
  • 50+43.56108
库存:96
10-1319.1199
  • 1+48.45101
  • 10+44.72585
  • 25+42.67761
  • 50+41.09652
  • 100+39.43158
  • 250+37.38334
  • 500+35.80224
  • 1000+34.22115
  • 1+63.799701+8.25347
  • 10+55.0895510+7.12668
  • 25+51.9504825+6.72059
  • 50+49.6909750+6.42829
  • 100+47.52581100+6.14819
  • 250+44.80368250+5.79604
  • 500+43.23903500+5.59363
库存:3664
