92191
92191
    WIHA(威汉)
    Molded
    六角形,十字,开槽型,Torx® 螺母,螺丝刀组
92191 数据手册
2022 COMPLETE PRODUCT GUIDE Updated With New Products 1/1/2022 Page # SAFETY QUALITY INNOVATION INSULATED TOOLS CATALOG 2-13 PLIERS & CUTTERS CATALOG 14-18 MASTER PRO TOOL SETS 19 SCREWDRIVERS CATALOG 20-31 ESD SAFE CATALOG 32-34 BITS CATALOG 35-53 HEX INCH & METRIC CATALOG 54-57 TORX CATALOG 58-60 SHOP TOOLS CATALOG 61-66 TORQUE CONTROL CATALOG 67-69 2 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA INSULATED TOOLS 1000V RATED | 10,000V TESTED for your safety 1000 V IEC 60900 With Socket Release Button Insulated Strippers - 1000Volt Insulated 1/4” Drive Ratchet - 1000Volt Item No. Description Case Pack 10250 Insulated Strippers 3 6.3”/160mm OAL - AWG 20-10 Item No. Description Case Pack 12851 Insulated 1/4” Drive Ratchet 1 5.5”/140mm OAL With Socket Release Button Insulated Auto Pliers Wrench Item No. Description 11610 10”/250mm OAL Case Pack 3 For cutting solid aluminum and copper conductors Insulated Cable Cutter - 1000Volt Item No. Description Case Pack 11950 Insulated Cable Cutter 1 9.6” OAL, Cutting Capacity 1/2” Insulated Hex Metric L-keys Item No. 13650 13651 13652 13653 13654 13655 13656 13657 13658 13659 Description 1.5mm x 100mm 2.0mm x 105mm 2.5mm x 115mm 3.0mm x 130mm 4.0mm x 120mm 5.0mm x 140mm 6.0mm x 150mm 12.0mm x 260mm 8.0mm x 150mm 10.0mm x 220mm Item No. 13662 13663 13664 13665 13666 13667 13668 13669 13670 13671 13672 13673 Description 3/8” x 9.2” 1/8” x 4.1” 1/2” x 9.2” 5/32” x 4.1” 3/16” x 5.3” 7/32 x 5.3” 1/4” x 5.3” 5/16” x 5.7” 1/16” x 3.1” 5/64” x 3.3” 3/32” x 3.5” 7/64” x 3.7” Case Pack 3 3 3 3 3 3 3 3 3 3 10 Pc. Insulated Hex Metric L-key Set Item No. Description 13693 Ins. Metric Hex L-keys Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0, 12.0mm Case Pack 1 Insulated 3/8” Drive Ratchet - 1000Volt Item No. Description Case Pack 12852 Insulated 3/8” Drive Ratchet 1 7.5”/190mm OAL Insulated 1/2” Drive Ratchet - 1000Volt Item No. Description Case Pack 12853 Insulated 1/2” Drive Ratchet 1 10.2”/260mm OAL Insulated Hex Inch L-keys Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 12 Pc. Insulated Hex Inch L-key Set Item No. Description Case Pack 13694 Ins. Inch Hex L-keys 1 Inch: 3/8, 1/8, 1/2, 5/32, 3/16, 7/32, 1/4, 5/16, 1/16, 5/64, 3/32, 7/64” Insulated Electrician’s Cable Stripping Knife Item No. Description 15000 50mm x 216mm Case Pack 3 Insulated 1/4” Drive Extension Bars Item No. Description 12854 2.0”/50mm OAL 12855 3.9”/100mm OAL Case Pack 3 3 Insulated Electrician’s Cable Stripping Knife 8 Pc. Insulated Hex Inch L-key Set Case Pack 1 1 1 Insulated 3/8” Drive Extension Bars Item No. Description 12856 4.9”/125mm OAL 12857 9.8”/250mm OAL Insulated 3/8” & 1/2” Breaker Bar Item No. Description Case Pack 12326 1/2” - 10.5”/267mm OAL 3 12327 3/8” - 8.5”/216mm OAL 3 Case Pack 3 Item No. Description Case Pack 13690 Ins. Inch Hex L-keys 1 Inch: 1/8, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8, 1/2” Insulated Double Ratcheting Cable Cutters Item No. Description 11960 10”/250mm 11975 11”/280mm 11980 13.9”/353mm Item No. Description 15003 50mm x 230mm Insulated 1/2” Drive Extension Bars Item No. Description 12858 4.9”/125mm OAL 12859 9.8”/250mm OAL Insulated Stripping Knife Case Pack 3 3 Case Pack 3 3 Item No. Description 15050 35mm x 222mm Case Pack 3 7 Pc. Insulated Hex Metric L-key Set Item No. Description 13691 Ins. Metric Hex L-keys Metric: 3, 4, 5, 6, 8, 10, 12mm Case Pack 1 Insulated Hacksaw Item No. Description 19767 18”/457mm OAL Case Pack 1 3 www.wihatools.com • USA | www.wihatools.ca • CANADA Insulated Metric Open End Wrenches Item No. 20006 20007 20008 20009 20010 20011 20012 20013 20014 20015 20016 20017 20018 20019 20020 20022 20024 20027 20030 20032 Description 6mm x 97mm 7mm x 98mm 8mm x 104mm 9mm x 108mm 10mm x 107mm 11mm x 118mm 12mm x 129mm 13mm x 137mm 14mm x 150mm 15mm x 151mm 16mm x 164mm 17mm x 162mm 18mm x 173mm 19mm x 178mm 20mm x 190mm 22mm x 196mm 24mm x 211mm 27mm x 218mm 30mm x 235mm 32mm x 237mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 14 Pc. Insulated Inch Open End Wrench Set Item No. Description Case Pack 20190 Insulated Open End Wrenches 1 Inch: 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1, 1-1/16, 1-1/8” Insulated Inch Deep Offset Ring Wrenches Item No. 21040 21042 21044 21046 21048 21050 21052 21054 21056 21057 21058 21060 21062 21064 21066 21068 Description 1/4” x 159mm 5/16” x 159mm 3/8” x 171mm 7/16” x 178mm 1/2” x 191mm 9/16” x 194mm 5/8” x 203mm 11/16” x 203mm 3/4” x 219mm 25/32” x 241mm 13/16” x 250mm 7/8” x 257mm 15/16” x 279mm 1.0” x 286mm 1-1/16” x 311mm 1-1/4” x 318mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Insulated Metric Ratchet Wrenches Item No. 21208 21209 21210 21211 21212 21213 21214 21215 21216 21217 21218 21219 Description 8mm x 125mm 9mm x 10mm x 140mm 11mm x 12mm x 150mm 13mm x 152mm 14mm x 163mm 15mm x 16mm x 17mm x 193mm 18mm x 19mm x 210mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 8 Pc. Insulated Inch Open End Wrench Set Item No. Description Case Pack 20192 Insulated Open End Wrenches 1 Inch: 5/16 - 3/4” 15 Pc. Insulated Metric Open End Wrench Set Item No. Description Case Pack 20091 Insulated Open End Wrenches 1 Metric: 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 19, 22, 24mm In Tool Box Tray 13 Pc. Insulated Inch Open End Wrench Set Item No. Description Case Pack 20194 Insulated Open End Wrenches 1 Inch: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1” 8 Pc. Insulated Metric Open End Wrench Set 13 Pc. Insulated Metric Open End Wrench Set Item No. Description Case Pack 20093 Insulated Open End Wrenches 1 Metric: 6, 7, 8, 10, 13, 14, 17, 19mm Item No. Description Case Pack 20196 Insulated Open End Wrenches 1 Metric: 8, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 22, 24mm Insulated Inch Open End Wrenches Item No. 20131 20133 20135 20136 20137 20138 20140 20141 20142 20144 20145 20146 20147 20148 20149 20151 20154 Description 1/4” x 3.4” 5/16” x 3.9” 3/8” x 4.1” 7/16” x 4.6” 1/2” x 5.5” 9/16” x 5.7” 5/8” x 6.2” 11/16” x 6.5” 3/4” x 7.0” 13/16” x 7.5” 7/8” x 7.6” 15/16” x 7.9” 1” x 8.4” 1-1/16” x 9.2” 1-1/8” x 9.2” 1-1/4” x 7.5” 1-1/2” x 7.5” Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 16Pc. Insulated Metric Offset Ring Wrench Set 7 Pc. Insulated Metric Ratchet Wrench Set Item No. Description Case Pack 21093 Insulated Offset Ring Wrenches 1 Metric: 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 17.0, 19.0, 20.0, 22.0, 24.0, 27.0, 30.0, 32.0mm Item No. Description Case Pack 21290 Insulated Ratchet Wrenches 1 Metric: 8, 10, 12, 13, 14, 17, 19mm 16 Pc. Insulated Inch Offset Ring Wrench Set Item No. Description Case Pack 21094 Insulated Offset Ring Wrenches 1 Inch: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 25/32, 13/16, 7/8, 15/16, 1, 1-1/16, 1-1/4” Insulated Inch Ratchet Wrenches Item No. 21319 21321 21323 21325 21327 21329 21331 21333 21334 21335 21336 21337 Description 1/4” x 5/16” x 11/32” x 3/8” x 5.5” 7/16” x 5.6” 1/2” x 6.1” 9/16” x 6.4” 5/8” x 7.0” 11/16” x 3/4” x 8.2” 13/16” x 7/8” x Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 Insulated Metric Deep Offset Ring Wrenches Item No. 21008 21009 21010 21011 21012 21013 21014 21015 21017 21019 21020 21022 21024 21027 21030 21032 Description 8mm x 159mm 9mm x 159mm 10mm x 171mm 11mm x 178mm 12mm x 191mm 13mm x 194mm 14mm x 203mm 15mm x 203mm 17mm x 219mm 19mm x 241mm 20mm x 250mm 22mm x 257mm 24mm x 379mm 27mm x 286mm 30mm x 311mm 32mm x 318mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 8 Pc. Insulated Metric Offset Ring Wrench Set Item No. Description Case Pack 21095 Insulated Offset Ring Wrenches 1 Metric: 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 17.0, 19.0mm 8 Pc. Insulated Inch Offset Ring Wrench Set Item No. Description Case Pack 21096 Insulated Offset Ring Wrenches 1 Inch: 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4” 6 Pc. Insulated Inch Ratchet Wrench Set Item No. Description Case Pack 21391 Insulated Ratchet Wrenches 1 Inch: 3/8, 7/16,1/2, 9/16, 5/8, 3/4” 4 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA Cat. IV Voltage Detector - Battery Operated Item No. Description 25505 5.75” OAL (146mm) LED Auto off Case Pack 3 SlimLine Insulated Slotted/Pozidriv® Blade Item No. Description 28320 #1 x 3.8Nm 28321 #2 x 5.5Nm On/Off Case Pack 3 3 12pc. Insulated SlimLine Blade Belt Set Item No. Description Case Pack 28348 Slim Blade Set 3 Slotted: 4.0, 5.5mm, Phillips: #1, 2, Square: #1, 2 ® Hex: 2.5, 3.0, 4.0mm, TORX : T15, T20, T25 Cat. IV Voltage Detector - Battery Operated Item No. Description 25506 6.0” OAL (152mm) Case Pack 3 Insulated Single-Pole Voltage Tester Item No. Description 25511 3.0mm x 65mm SlimLine Insulated Terminal Block Xeno Blade Item No. Description 28327 #1 x 3.8Nm 28329 #2 x 5.5Nm Case Pack 3 3 Case Pack 3 SlimLine Insulated Pozidriv® Blade Item No. Description 28330 #1 x 3.8Nm 28331 #2 x 5.5Nm Case Pack 3 3 Meets VDE, EN/IEC, ASTM, CSA, NFPA specs +/- 10% Insulated Easy-TorqueControl Adapters Item No. 28366 28367 28368 28369 28371 Description 7.0 in/lbs. - 0.8Nm 17.7 in/lbs. - 2.0Nm 23.1 in/lbs. - 2.5Nm 24.7 in/lbs. - 2.8Nm 35.4 in/lbs. - 4.0Nm Case Pack 3 3 3 3 3 SlimLine Blade Holder Insulated Handle Item No. Description 28301 1/4” x 160mm 12 Pc. SlimLine Insulated Blade Set Item No. Description Case Pack 28392 Insulated Blade Set 3 Slotted: 3.0, 5.5mm & Phillips: #2 & Square: #1, 2 TORX: T8, T10, T15, T20 & Xeno Slt/Ph: #1, 2 Insulated Cushion Grip Blade Holder 7 Pc. Insulated Pop-Up SlimLine Blade Set Item No. Description Case Pack 28393 Pop-Up Blade Set 3 Slotted: 3.0, 4.0, 5.5, 6.5mm, Phillips: #1, 2 Case Pack 3 SlimLine Insulated Hex Metric Blade SlimLine Blade Holder Insulated Stubby Handle Item No. Description 28302 1/4” x 60mm Case Pack 3 Item No. 28332 28333 28334 28335 28336 28337 28338 Description 1.5 x 0.9Nm 2.0 x 1.8Nm 2.5 x 3.8Nm 3.0 x 5.5Nm 4.0 x 5.5Nm 5.0 x 5.5Nm 6.0 x 5.5Nm Case Pack 3 3 3 3 3 3 3 Holds 6mm SlimLine Blades SlimLine PicoFinish® Blade Holder Handle Item No. Description 28303 1/4” x 103mm (4.02”) Case Pack 3 SlimLine Blade Holder Insulated Handle Item No. Description 28304 1/4” x 114mm Case Pack 3 SlimLine Insulated 1/4” Socket Adapter Item No. Description 28311 For SlimLine Blade Holders Case Pack 3 SlimLine Insulated TORX® Blade Item No. 28325 28326 28339 28344 28340 28341 28342 28343 Description T6 x .6Nm T7 x .9Nm T8 x 1.3Nm T9 x 1.3Nm T10 x 3.8Nm T15 x 5.5Nm T20 x 5.5Nm T25 x 5.5Nm Case Pack 3 3 3 3 3 3 3 3 Description 2.5mm x 0.4Nm 3.0mm x 0.6Nm 4.0mm x 2.5Nm 3.5mm x 2.5Nm 5.5mm x 3.8Nm 6.5mm x 5.5Nm Case Pack 3 3 3 3 3 3 7 Pc. Insulated Pop-Up SlimLine Blade Set Item No. Description Case Pack 28394 Pop-Up Blade Set 3 Slotted: 3.0, 4.0mm, Phillips: #1, 2, Square: #1, 2 7 Pc. Insulated SlimLine Blade Set Item No. Description Case Pack 28373 SlimLine Blade Set 3 Slotted: 2.5, 3.5, 5.5mm, Phillips: #1, 2, Xeno Slt/Ph: #1, 2 7 Pc. Insulated Pop-Up SlimLine Blade Set Item No. Description Case Pack 28395 Pop-Up Blade Set 3 Slotted: 3.0, 4.0mm, Phillips: #1, 2, Terminal: #1, 2 Stubby Blade Holder SlimLine Insulated Square Blade Item No. Description 28346 #1 x 3.8Nm 28347 #2 x 5.5Nm Case Pack 3 3 SlimLine Insulated Slotted Blade Item No. 28307 28308 28309 28310 28312 28315 7 Pc. Insulated SlimLine Blade Set Item No. Description Case Pack 28372 SlimLine Blade Set 3 Slotted: 2.5, 3.5, 5.5mm, Phillips: #1, 2 Square: #1, 2 15 Pc. SlimLine Insulated Blade Set Item No. Description Case Pack 28390 Insulated Blade Set 3 Slotted: 3.0, 4.0, 5.5, 6.5mm & Phillips: #1, 2 TORX: T8, T10, T15, T20 & Xeno Slt/Ph: #1, 2 Square: #1, 2 Insulated Cushion Grip Blade Holder 20 Pc. SlimLine Insulated Blade Set Item No. Description Case Pack 28396 Insulated Blade Set 1 Slotted: 3.0, 3.5, 4.0, 5.5mm & Phillips: #1, 2 TORX: T8, T10, T15, T20 & Xeno: #1, 2 Xeno SL/PZ #1, 2, Sq: #1, 2 & Hex: 3.0, 4.0, 5.0mm Insulated Cushion Grip Blade Holder Insulated SlimLine Torque Blade Holder Item No. Description 28350 6.0mm x 170mm Case Pack 3 SlimLine Insulated 1/4” Blade Holder Item No. Description 28316 For SlimLine Blades Case Pack 3 8 Pc. SlimLine Insulated Blade Set SlimLine Insulated Phillips Blade Item No. Description 28317 #1 x 3.8Nm 28319 #2 x 5.5Nm Case Pack 3 3 4pc. Insulated SoftFinish® SlimLine Blade Set Item No. Description Case Pack 28328 Slim Blade Set 3 Slotted: 3.5mm, Phillips: #2, Square: #2 Item No. Description 28391 Insulated Blade Set Slotted: 4.0, 6.5mm & Phillips: #1, 2 TORX: T15, T20 & Xeno Slt/Ph: #2 Insulated Cushion Grip Blade Holder Case Pack 3 4pc. Insulated PicoFinish® SlimLine Blade Set Item No. Description Case Pack 28397 Slim Blade Set 3 Slotted: 3.5mm, Phillips: #2, Square: #2 5 www.wihatools.com • USA | www.wihatools.ca • CANADA SlimLine (Slotted/Phillips) 20 Pc. SlimLine Insulated Blade Set 19 Pc. SlimLine Insulated Blade Set Item No. Description Case Pack 28398 Insulated Blade Set 1 Slotted: 3.0, 4.0, 5.5mm & Phillips: #1, 2 TORX: T8, T10, T15, T20 & Xeno: #1, 2 Xeno SL/PZ #1, 2, Sq: #1, 2 & Hex: 3.0, 4.0, 5.0mm Insulated Cushion Grip Blade Holder Item No. Description Case Pack 28781 Insulated Blade Set 1 Slotted: 2.5, 3.5, 4.0, 6.5mm Phillips: #1, 2 (2 of #2) & Square: #1, 2 TORX: T10, T15, T20, T25 & Xeno Slt/Ph: #1, 2 TorqueVario-S Handle 10-50 in/lbs. 6.75” SlimLine Blade Holder & Torque Adj. Tool Insulated SoftFinish® Cushion Grip Blade Holder Insulated PicoFinish® SlimLine Blade Holder Insulated Terminal Block Xeno Screwdrivers Insulated 1/4” Drive T-Handle Item No. Description 29006 1/4” x 160mm OAL Case Pack 1 Item No. Description 30746 1 x 80mm 30747 2 x 100mm Insulated 3/8” Drive T-Handle Item No. Description 29009 3/8” x 200mm OAL Case Pack 1 Insulated 1/2” Drive T-Handle Item No. Description 29012 1/2” x 200mm OAL Case Pack 1 SlimLine (Slotted/Phillips) 2 Pc. Insulated Terminal Block Xeno Set Item No. Description 30770 Terminal Block Xeno Set Slt/Ph Xeno: #1, 2 30 Pc. SlimLine Insulated Blade Set 11 Pc. Ins. TorqueControl SlimLine Blade Set Item No. Description Case Pack 28399 Insulated Blade Set 1 Slotted: 2.5, 3.0, 3.5, 4.0, 5.5, 6.5mm & Phillips: #1, 2 TORX: T8, T9, T10, T15, T20, T25 & Xeno: #1, 2 Xeno SL/PZ #1, 2, Sq: #1, 2, Pozidriv: #1, 2 & Hex: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0mm Insulated Cushion Grip Blade Holder Item No. Description Case Pack 28789 SlimLine Blade Set 1 Slotted: 4.0, 6.5mm & Phillips: #1, 2 Terminal Xeno: #1, 2 & Square: #1, 2 TorqueVario-S Handle 10-50 in/lbs. SlimLine Blade Holder & Torque Adj. Tool TorqueControl Insulated Socket Adapter Item No. Description 28700 6.0 x 180mm Direct Reading Window Scale Item No. 30114 30138 30152 +/-6% accuracy tolerance Certificate of calibration Case Pack 1 Description 1/4” Drive, 5-25Nm 3/8” Drive, 5-50Nm 1/2” Drive, 40-220Nm Case Pack 1 1 1 Item No. Description 28724 5-18 in/lbs. 28726 10-50 in/lbs. 28727 18-62 in/lbs. *Requires #28350 Blade Holder Case Pack 1 1 1 Item No. Description Case Pack 28791 Slotted/Phillips Blade Set 1 Slotted: 3.0, 4.0, 5.5mm & Phillips: #1, 2 TorqueVario-S Handle 10-50 in/lbs. SlimLine Blade Holder & Torque Adj. Tool Insulated Adj. Nm TorqueVario-S Handle* Direct Reading Window Scale 3/8” Drive 16 Pc. Insulated 3/8” Drive Inch Socket Set In Newton Meter Scale Item No. Description 28734 0.5-2.0 Nm 28736 0.8-5.0 Nm 28738 2.0-7.0 Nm *Requires #28350 Blade Holder Insulated 1/4” Drive Metric Sockets Item No. Description 31326 5mm 31327 6mm 31328 7mm 31329 8mm 31330 9mm 31331 10mm 31332 11mm 31333 12mm 31334 13mm 31335 14mm Case Pack 3 3 3 3 3 3 3 3 3 3 Insulated 1/4” Drive Inch Sockets 8 Pc. Ins. TorqueControl SlimLine Blade Set Insulated Adjustable TorqueVario-S Handle* Case Pack 6 Insulated End Cutters Item No. Description 29250 10”/250mm OAL Insulated Ratcheting Torque Wrenches Case Pack 3 Case Pack 3 3 Item No. Description 31336 3/16” 31337 7/32” 31338 1/4” 31339 9/32” 31340 5/16” 31341 11/32” 31342 3/8” 31343 7/16” 31344 1/2” 31345 9/16” Case Pack 3 3 3 3 3 3 3 3 3 3 Item No. Description Case Pack 30190 Ins. 3/8” Dr. Socket Set 1 13 Inch Sockets: 1/4” - 7/8” 125mm & 250mm Extension Bar - 3/8” Drive 3/8” Drive Ratcheting Torque Wrench 5-50Nm Case Pack 1 1 1 16 Pc. Ins. TorqueControl SlimLine Blade Set +/-6% accuracy tolerance Certificate of calibration Item No. Description Case Pack 28792 SlimLine Blade Set 1 Slotted: 4.0, 5.5, 6.5mm & Phillips: #1, 2 Terminal Xeno: #1, 2 & Square: #1, 2 TORX: T8, T10, T15, T20 TorqueVario-S Handle 18-62 in/lbs. SlimLine Blade Holder & Torque Adj. Tool 16 Pc. Insulated 3/8” Drive Metric Socket Set Item No. Description Case Pack 30192 Ins. 3/8” Dr. Socket Set 1 Metric: 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20mm 125mm & 250mm Extension Bar - 3/8” Drive 3/8” Drive Ratcheting Torque Wrench 5-50Nm Insulated 1/4 - 3/8” Socket Adapter/Reducer Item No. Description 31350 1/4 to 3/8” Adapter Case Pack 3 1/4” Drive Insulated TorqueVario-S Handle & Blade Holder Item No. 28750 28751 28752 Description 5-18 in/lbs. 10-50 in/lbs. 18-62 in/lbs. Case Pack 1 1 1 (Slotted/Phillips) Insulated Terminal Block Xeno Screwdrivers Item No. Description 30700 1 x 80mm 30701 2 x 100mm In Newton Meter Scale Insulated TorqueVario-S Handle & Blade Holder Item No. 28740 28741 28742 Description 0.5-2.0 Nm 0.8-5.0 Nm 2.0-7.0 Nm Case Pack 1 1 1 Case Pack 10 10 12 Pc. Ins. TorqueControl SlimLine Blade Set Item No. Description Case Pack 28795 SlimLine Blade Set 1 Slotted: 4.0, 5.5, 6.5mm & Phillips: #1, 2 Pozidriv®: #1, 2 & Terminal Xeno Slt/Ph: #2 TorqueVario-S Handle 0.8 - 5.0 Nm SlimLine Blade Holder & Torque Adj. Tool SlimLine Blade Holder Handle SlimLine Blade Holder 13 Pc. Insulated 1/4” Drive Inch Socket Set Item No. Description Case Pack 31390 Insulated 1/4” Socket Set 1 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16” 50mm & 100mm Extension Bar - 1/4” 140mm Ratchet - 1/4” 13 Pc. Insulated 1/4” Drive Metric Socket Set (Slotted/Pozidriv®) Insulated Terminal Block Xeno Screwdrivers Item No. Description 30711 1 x 80mm 30712 2 x 100mm Case Pack 10 10 Item No. Description Case Pack 31391 Insulated 1/4” Socket Set 1 Metric: 5, 6, 7, 8, 9, 10, 11, 12, 13, 14mm 50mm & 100mm Extension Bar - 1/4” 140mm Ratchet - 1/4” 6 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA 3/8” Drive 3/8” Drive Insulated 1/2” Drive Metric Sockets 10 Pc. Insulated 1/4” Drive Socket Set 16 Pc. Insulated 3/8” Drive In/mm Socket Set 10 Pc. Insulated 3/8” Drive Metric Socket Set Item No. Description Case Pack 31393 Ins. 1/4” Dr. Socket Set 1 Metric: 5, 6, 7, 8, 9, 10, 11, 12, 13, 14mm Item No. Description Case Pack 31491 Ins. 3/8” Drive Socket Set 1 Inch: 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4” Metric: 8, 10, 11, 12, 13, 14, 17, 19mm Item No. Description Case Pack 31590 Ins. 3/8” Drive Socket Set 1 Metric: 8, 10, 11, 12, 13, 14, 17, 19mm 125mm Extension Bar - 3/8” Drive 280mm Ratchet - 3/8” Drive 3/8” Drive 1/4” Drive 3/8” Drive 11 Pc. Insulated Inch T-handle & Socket Set Item No. Description Case Pack 31394 Ins. 1/4” T-handle Socket Set 1 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16” 1/4” Insulated T-handle 10 Pc. Insulated 3/8” Drive Inch Socket Set Item No. Description Case Pack 31493 Ins. 3/8” Drive Socket Set 1 Inch: 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4” 125mm Extension Bar - 3/8” Drive 280mm Ratchet - 3/8” Drive 1/4” Drive 3/8” Drive 11 Pc. Insulated Metric T-handle & Socket Set Item No. Description Case Pack 31395 Ins. 1/4” T-handle Socket Set 1 Metric: 5, 6, 7, 8, 9, 10, 11, 12, 13, 14mm 1/4” Insulated T-handle 10 Pc. Insulated 1/4” Drive Socket Set Item No. Description Case Pack 31396 Ins. 1/4” Dr. Socket Set 1 Inch: 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16” 24 Pc. Insulated 3/8” Drive Metric Socket Set Item No. Description Case Pack 31592 Ins. 3/8” Drive Socket Set 1 Metric: 6, 7, 8, 9, 10, 11, 12, 13, 14, 17, 19mm 125mm & 250mm Extension Bars - 3/8” Drive 190mm Ratchet - 3/8” Drive 50mm Insulated Electrician’s Knife Slotted: 3.5, 4.5, 6.5mm & Phillips: #1, 2, 3 6.3” Long Nose Pliers, 8.0” Combo Pliers & 6.3” Diagonal Cutters Item No. Description 31608 8mm 31609 9mm 31610 10mm 31611 11mm 31612 12mm 31613 13mm 31614 14mm 31615 15mm 31616 16mm 31617 17mm 31618 18mm 31619 19mm 31620 20mm 31621 21mm 31622 22mm 31623 23mm 31624 24mm 31626 26mm 31627 27mm 31628 28mm 31630 30mm 31632 32mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Insulated 1/2 - 3/8” Socket Adapter/Reducer Item No. Description 31650 1/2 to 3/8” Adapter 24 Pc. Insulated 3/8” Drive Inch Socket Set Item No. Description Case Pack 31495 Ins. 3/8” Drive Socket Set 1 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4” 125mm & 250mm Extension Bars - 3/8” Drive 190mm Ratchet - 3/8” Drive 50mm Insulated Electrician’s Knife Slotted: 3.5, 4.5, 6.5mm & Phillips: #1, 2, 3 6.3” Long Nose Pliers, 8.0” Combo Pliers & 6.3” Diagonal Cutters 3/8” Drive Case Pack 3 18 Pc. Insulated 3/8” Drive Socket Set Item No. Description Case Pack 31593 Ins. 3/8” Dr. Socket Set 1 Metric: 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 24mm 1/2” Drive 3/8” Drive 24 Pc. Insulated 1/2” Drive Metric Socket Set Insulated 3/8” Drive Inch Sockets Item No. Description 31425 1/4” 31428 9/32” 31429 5/16” 31430 11/32” 31431 3/8” 31432 7/16” 31433 1/2” 31434 9/16” 31435 5/8” 31436 11/16” 31437 3/4” 31438 13/16” 31439 7/8” Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 Insulated 3/8 - 1/2” Socket Adapter/Reducer Item No. Description 31450 3/8 to 1/2” Adapter Case Pack 3 Insulated 3/8 - 1/4” Socket Adapter/Reducer Item No. Description 31460 3/8 to 1/4” Adapter Case Pack 3 10 Pc. Insulated Inch T-handle & Socket Set Item No. Description Case Pack 31496 Ins. 3/8” T-handle Socket Set 1 Inch: 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4” 3/8” Ins. T-handle & 125mm Extension Bar 10 Pc. Insulated Metric T-handle & Socket Set Item No. Description Case Pack 31595 Ins. 3/8” T-handle Socket Set 1 Metric: 8, 10, 11, 12, 13, 14, 17, 19mm 3/8” Ins. T-handle & 125mm Extension Bar 1/2” Drive Insulated 3/8” Drive Metric Sockets Item No. Description 31506 6mm 31507 7mm 31508 8mm 31509 9mm 31510 10mm 31511 11mm 31512 12mm 31513 13mm 31514 14mm 31515 15mm 31516 16mm 31517 17mm 31518 18mm 31519 19mm 31520 20mm 31521 21mm 31522 22mm 31524 24mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Item No. Description Case Pack 31691 Ins. 1/2” Drive Socket Set 1 Metric: 8, 9, 10, 12, 13, 14, 15, 17, 19, 22, 24mm 125mm & 250mm Extension Bars - 1/2” Drive 260mm Ratchet - 1/2” Drive 50mm Insulated Electrician’s Knife Slotted: 3.5, 4.5, 6.5mm & Phillips: #1, 2, 3 6.3” Long Nose Pliers, 8.0” Combo Pliers & 6.3” Diagonal Cutters 13 Pc. Insulated 3/8” Drive Socket Set 14 Pc. Insulated 1/2” Drive Metric Socket Set Item No. Description Case Pack 31596 Ins. 3/8” Dr. Socket Set 1 Inch: 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8” Item No. Description Case Pack 31694 Ins. 1/2” Dr. Socket Set 1 Metric: 8, 9, 10, 11, 12, 13, 14, 17, 19, 22, 24mm 1/2” Drive Insulated Ratchet - 72 Tooth 125mm & 250mm Extension Bar 7 www.wihatools.com • USA | www.wihatools.ca • CANADA SlimLine Insulated 1/2” Drive Inch Sockets Item No. Description 31703 5/16” 31704 11/32” 31705 3/8” 31707 7/16” 31708 1/2” 31709 9/16” 31710 5/8” 31712 11/16” 31713 3/4” 31714 13/16” 31715 7/8” 31716 15/16 31718 1” 31720 1-1/2” 31722 1-1/4” Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 1/2” Drive Insulated 3/8” Drive Inch Hex Bit Sockets Item No. 31805 31807 31809 31811 31813 31815 31817 Description 3/16 x 3.1” 7/32 x 3.1” 1/4 x 3.1” 5/16 x 3.1” 3/8 x 3.1” 7/16 x 3.1” 1/2 x 3.1” Case Pack 3 3 3 3 3 3 3 30 Pc. Insulated SlimLine Counter Display 7 Pc. Insulated Slotted/Phillips Pliers Set Item No. Description Case Pack 32079 Insulated Slim Counter Rack 1 6 of each Slotted: 3.5, 4.5, 5.5mm 6 of each Phillips: #1, 2 Item No. Description Case Pack 32086 Insulated Tool Set 3 Slotted: 3.0, 4.0mm Phillips: #0, 1, 2 & Square: #2 8.0”/200mm Insulated Long Nose Pliers With Cutters Insulated 1/2” Drive Inch Hex Bit Sockets Item No. 31830 31832 31834 31836 31838 31840 31842 31844 Description 1/4” x 2.75” 5/16” x 2.75” 3/8” x 2.75 7/16” x 2.75 1/2” x 2.75” 9/16” x 2.75” 5/8” x 2.75” 3/4” x 2.75” Case Pack 3 3 3 3 3 3 3 3 Medium - 15.5” x 11” x 1.25” 10 Pc. Insulated Screwdriver Tray Set 7 Pc. Insulated Tool Set Item No. Description Case Pack 32080 Insulated SoftFinish® Drivers 1 Slotted: 3.5, 4.5, 4.5, 5.5, 6.5mm Phillips: #1, 2, 3 & Square: #1, 2 Item No. Description Case Pack 32087 Insulated Screwdriver Set 3 Slotted: 4.0, 5.5, 6.5mm & Phillips: #1, 2 Square: #2 & Single Pole Voltage Detector 24 Pc. Insulated 1/2” Drive Inch Socket Set Item No. Description Case Pack 31790 Ins. 1/2” Drive Socket Set 1 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1” 125mm & 250mm Extension Bars - 1/2” Drive 260mm Ratchet - 1/2” Drive 50mm Insulated Electrician’s Knife Slotted: 3.5, 4.5, 6.5mm & Phillips: #1, 2, 3 6.3” Long Nose Pliers, 8.0” Combo Pliers & 6.3” Diagonal Cutters 1/2” Drive 14 Pc. Insulated 1/2” Drive Inch Socket Set Item No. Description Case Pack 31792 Ins. 1/2” Dr. Socket Set 1 Inch: 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1” 1/2” Drive Insulated Ratchet - 72 Tooth 125mm & 250mm Extension Bar 22 Pc. Insulated 1/2” Drive Socket Set Item No. Description Case Pack 31793 Ins. 1/2” Dr. Socket Set 1 Metric: 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 26, 27, 28, 30, 32mm 7 Pc. Insulated Inch Hex Bit 3/8” Socket Set Item No. Description Case Pack 31890 3/8” Drive Hex Bit Socket Set 1 3/16, 7/32, 1/4, 5/16, 3/8, 7/16, 1/2” Small - 11” x 7.75” x 1.25” 5 Pc. Insulated Screwdriver Tray Set Item No. Description Case Pack 1 32081 Insulated SoftFinish® Drivers Slotted: 4.5, 5.5, 6.5mm & Phillips: #1, 2 8 Pc. Insulated PicoFinish Precision Driver Set Item No. Description 32088 Insulated Prec. Driver Set Slotted: 1.5, 2.0, 2.5, 3.0, 3.5mm Phillips: #00, 0, 1 Case Pack 3 Insulated PicoFinish Slotted Precision Drivers Item No. 32000 32001 32002 32003 32004 Description 1.5 x 40mm 2.0 x 40mm 2.5 x 60mm 3.0 x 60mm 3.5 x 60mm Case Pack 3 3 3 3 3 5 Pc. Insulated Slotted/Phillips/Square Set Item No. Description Case Pack 32083 Insulated Screwdriver Set 3 Slotted: 3.5mm, Phillips: #1, 2 & Square: #1, 2 Insulated Slotted Cushion Grip Screwdrivers Item No. 32005 32010 32012 32015 32017 32023 32024 32025 32026 32027 32028 32031 32034 32039 32042 32045 Description 2.0 x 60mm 2.5 x 75mm 3.0 x 100mm 3.5 x 100mm 4.0 x 100mm 4.5 x 100mm 4.5 x 125mm 4.5 x 175mm 5.5 x 175mm 4.5 x 150mm 4.5 x 200mm 5.5 x 125mm 6.0 x 150mm 6.5 x 150mm 8.0 x 175mm 10.0 x 200mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 In Carry Case 9 Pc. Insulated Slot/Ph/Terminal Xeno Set Item No. Description Case Pack 32089 Ins. Screwdriver Set 1 Slotted: 3.5, 4.0, 4.5, 4.5, 5.5mm & Phillips: #1, 2 Xeno: #2 & Single-Pole Voltage Detector 5 Pc. Insulated Slotted & Phillips Set Item No. Description Case Pack 32084 Insulated Screwdriver Set 6 Slotted: 3.5, 4.5, 6.5mm & Phillips: #1, 2 4 Pc. Insulated Slotted & Phillips Set Item No. Description 32090 Insulated Screwdriver Set Slotted: 3.5, 4.5mm & Phillips: #1, 2 Case Pack 3 SlimLine Insulated SlimLine Slotted Cushion Grip Driver 15 Pc. Insulated 1/2” Drive Socket Set Item No. Description Case Pack 31796 Ins. 1/2 Dr. Socket Set 1 Inch: 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1, 1-1/8, 1-1/4” Item No. 32046 32049 32052 32055 32058 Description 3.5 x 100mm 4.0 x 100mm 4.5 x 125mm 5.5 x 125mm 6.5 x 150mm Case Pack 3 3 3 3 3 5 Pc. Insulated PicoFinish Precision Driver Set Item No. Description 32085 Insulated Prec. Driver Set Slotted: 1.5, 2.5, 3.5mm Phillips: #0, 1 Case Pack 3 5 Pc. Insulated Slotted & Phillips Set Item No. Description Case Pack 32091 Insulated Screwdriver Set 3 Slotted: 3.0, 4.5, 6.5mm & Phillips: #1, 2 8 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA SlimLine 2 Pc. Insulated Slotted & Phillips Set 7 Pc. Insulated Slotted/Phillips/Square Set 6 Pc. Insulated Slotted & Phillips Set Item No. Description Case Pack 32092 Insulated Screwdriver Set 3 Slotted: 3.5, 4.5, 6.5mm & Phillips: #1, 2, 3 Item No. Description 32097 Insulated Screwdriver Set Slotted: 3.5, 5.5, 6.5mm Phillips: #1, 2 & Square: #1, 2 Item No. Description 32189 Insulated Screwdriver Set Slotted: 4.5mm & Phillips: #2 Case Pack 6 8 Pc. Insulated Slotted/Phillips/Square Set Item No. Description Case Pack 32197 Insulated Screwdriver Set 1 Slotted: 3.5, 4.0, 4.5, 5.5mm & Phillips: #1, 2 Square: #1, 2 Case Pack 6 SlimLine 15Pc. Insulated Slotted/Phillips/Nut Driver Set Item No. Description Case Pack 32190 Insulated Screwdriver Set 1 Slotted: 2.0, 2.5, 3.0, 3.5, 4.5, 6.5, 8.0mm Phillips: #1, 2, 3 In Nut Drivers: 1/4, 5/16, 3/8, 7/16, 1/2” 7 Pc. Insulated Slotted & Phillips Set 10 Pc. Insulated Slotted & Phillips Set Item No. Description 32093 Insulated Screwdriver Set Slotted: 2.0, 2.5, 3.0, 3.5, 4.5, 6.5mm Phillips: #0, 1, 2, 3 Case Pack 1 Item No. Description 32099 Insulated Screwdriver Set Slotted: 3.5, 4.0, 5.5, 6.5mm Phillips: #1, 2, 3 Case Pack 6 11 Pc. Insulated Slot/Ph/Sq/Terminal Xeno Set Item No. Description Case Pack 32198 Insulated Screwdriver Set 1 Slotted: 3.5, 4.0, 4.5, 5.5, 6.5mm & Phillips: #1, 2 Square: #1, 2 & Xeno: #1, 2 14 Pc. Insulated Pliers/Slot/Ph/Nut Driver Set Insulated Phillips Cushion Grip Driver 13 Pc. Insulated Slotted & Phillips Set Item No. 32100 32101 32102 32103 32104 Description 0 x 60mm 1 x 80mm 2 x 100mm 3 x 150mm 4 x 200mm Case Pack 10 10 10 10 10 Item No. Description Case Pack 32192 Insulated Screwdriver Set 1 Slotted: 3.0, 4.5, 6.5mm & Phillips: #1, 2 Nut Drivers Inch: 1/4, 5/16, 11/32, 3/8, 1/2” 8” Combo Pliers, 6.3” Diagonal Cutters, 6.3 & 8.0” Long Nose Pliers w/Cutters 30 Pc. Insulated Workstation Screwdriver Set Item No. Description Case Pack 32199 Insulated Driver Set 1 PicoFinish: Slotted 1.5, 2.0, 2.5mm & Phillips #00, 0 Slotted: 3.5, 4.0, 4.5, 5.5, 6.5mm Phillips: #1, 2, 3 & Square: #1, 2 & Pozidriv: #1, 2 Xeno Slt/Ph: #1, 2 & Hex: 2.5, 3.0, 4.0, 5.0, 6.0mm TORX: T8, T10, T15, T20, T25, T30 Item No. Description Case Pack 32094 Insulated Screwdriver Set 1 Slotted: 2.0, 2.5, 3.0, 3.5, 4.5, 5.5, 6.5, 8.0, 10.0mm Phillips: #0, 1, 2, 3 2 Pc. Insulated Slotted & Phillips Set Item No. Description 32105 Insulated Screwdriver Set Slotted: 5.5mm & Phillips: #2 19 Pc. Insulated Screwdriver Tool Box Set Item No. Description Case Pack 32095 Insulated Screwdriver Set 1 Slot: 2.5, 3.0, 3.5, 4.0, 4.5, 5.5, 6.0, 6.5, 8.0, 10.0mm Phillips: #0, 1, 2, 3 & Square: #1, 2 & Xeno: #1, 2 Cat. III Voltage Detector Case Pack 6 5 Pc. Insulated SlimLine Slotted/Phillips Set Item No. Description 32194 Insulated Screwdriver Set Slotted: 3.5, 4.5, 6.5mm Phillips: #1, 2 Case Pack 6 Insulated Cushion Grip Metric Nut Driver Insulated PicoFinish Phillips Precision Drivers Item No. 32106 32107 32108 Description 00 x 45mm 0 x 60mm 1 x 60mm Case Pack 3 3 3 7 Pc. Insulated SlimLine Slotted/Phillips Set Item No. Description 32195 Insulated Screwdriver Set Slotted: 3.5, 4.0, 4.5, 5.5, 6.5mm Phillips: #1, 2 SlimLine Case Pack 6 Insulated SlimLine Phillips Cushion Grip Driver Item No. Description 32145 1 x 80mm 32146 2 x 100mm Case Pack 3 3 7 Pc. Insulated Slotted/Phillips/Square Set Case Pack 3 7 Pc. Insulated Slotted & Phillips Set Item No. Description Case Pack 32188 Ins. Screwdriver Set 1 Slotted: 2.0, 2.5, 3.0, 3.5, 4.0mm & Phillips: #0, 1 Description 4.0 x 125mm 5.0 x 125mm 5.5 x 125mm 6.0 x 125mm 7.0 x 125mm 8.0 x 125mm 9.0 x 125mm 10.0 x 125mm 11.0 x 125mm 12.0 x 125mm 13.0 x 125mm 14.0 x 125mm 15.0 x 125mm 16.0 x 125mm 17.0 x 125mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Insulated Cushion Grip Inch Nut Driver SlimLine Item No. Description 32096 Insulated Screwdriver Set Slotted: 3.5, 4.0, 5.5, 6.5mm Phillips: #1, 2 & Square: #2 Item No. 32206 32209 32212 32215 32218 32221 32224 32227 32230 32233 32236 32238 32239 32240 32241 6 Pc. Insulated Slotted/Phillips/Square Set Item No. Description 32196 Insulated Screwdriver Set Slotted: 4.5, 6.5mm & Phillips: #1, 2 Square: #1, 2 Case Pack 3 Item No. 32255 32258 32261 32264 32267 32268 32270 32273 32276 32278 32280 Description 5/32 x 5.0” 3/16 x 5.0” 7/32 x 5.0” 1/4 x 5.0” 5/16 x 5.0” 11/32 x 5.0” 3/8 x 5.0” 7/16 x 5.0” 1/2 x 5.0” 9/16 x 5.0” 5/8 x 5.0” Case Pack 10 10 10 10 10 10 10 10 10 10 10 9 www.wihatools.com • USA | www.wihatools.ca • CANADA In Roll-up Pouch 9 Pc. Insulated Inch Nut Driver Set Item No. Description Case Pack 32288 Insulated Inch Nut Driver Set 1 Inch: 3/16, 1/4, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8” 6 Pc. Insulated Hex Metric Screwdriver Set Item No. Description 32366 Insulated Hex Drivers Metric: 2.5, 2.0, 4.0, 5.0, 6.0, 8.0mm Case Pack 3 Insulated Cushion Grip Pozidriv® Screwdrivers Item No. 32400 32401 32402 32403 Description 0 x 60mm 1 x 80mm 2 x 100mm 3 x 150mm Case Pack 10 10 10 10 10 Pc. Insulated TORX® Screwdriver Set Item No. Description Case Pack 32592 Insulated Driver Set 3 TORX: T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 6 Pc. Insulated Security TORX® Screwdrivers Item No. Description Case Pack 32596 Ins Security TORX Set 1 TORX: T10s, T15s, T20s, T25s, T27s, T30s Insulated Long Nose & Bent Nose Pliers Item No. Description 32807 6.3”/160mm Bent Case Pack 3 Insulated Long Flat Nose Pliers Item No. Description 32810 6.3”/160mm Case Pack 3 5 Pc. Insulated Metric Nut Driver Set Item No. Description Case Pack 32291 Insulated Metric Nut Driver Set 3 Metric: 6.0, 7.0, 8.0, 9.0, 10.0mm Insulated Combination Pliers 5 Pc. Insulated Inch Nut Driver Set 13 Pc. speedE-II Electric SlimLine Blade Set Item No. Description Case Pack 32292 Insulated Inch Nut Driver Set 3 Inch: 7/32, 1/4, 5/16, 3/8, 1/2” Item No. Description Case Pack 32490 speedE/SlimLine Set 1 Slotted: 3.5, 3.5mm & Phillips: #1, #2 Square: #1, #2 & Terminal Xeno Sl/Ph: #1, #2 speedE Screwdriver Handle Range 0.4 Nm 2 rechargeable batteries & wall plug adapter/charger 7 Pc. Insulated Metric Nut Driver Set * Must use insulated SlimLine blades to be insulated Item No. Description Case Pack 32293 Insulated Metric Nut Driver Set 1 Metric: 5.0, 5.5, 6.0, 7.0, 8.0, 10.0, 13.0mm 7 Pc. Insulated Inch Nut Driver Set Item No. Description Case Pack 32294 Insulated Inch Nut Driver Set 1 In: 3/16, 7/32, 1/4, 5/16, 3/8, 7/16, 1/2” Insulated TORX® Cushion Grip Driver Item No. 32505 32511 32516 32521 32526 32531 32536 32541 32546 32551 32556 Description T5 x 60mm T6 x 60mm T7 x 60mm T8 x 60mm T9 x 60mm T10 x 60mm T15 x 80mm T20 x 80mm T25 x 80mm T27 x 100mm T30 x 100mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 Rolling Water Tight Traveling Tool Box Item No. Description 32814 6.3”/160mm Case Pack 3 80 Pc. Insulated Master Electrician’s Set Item No. Description Case Pack 32800 Insulated Tool Set 1 6.3” & 8.0” Long Nose Pliers, 6.3” Bent Nose Pliers, 6.3” Long Flat Nose Pliers, 6.3” Diagonal Cutters 9.0” Combo Pliers/Crimpers, 8.0” Cable Cutters, 8.0” High Leverage Cutters & 6.3” Stripping Pliers 8.0” Adjustable Wrench Slotted: 2.5 - 10.0mm, Phillips: #0 - 3, Square: #1, 2 TORX: T6 - T30 & Slt/Ph Terminal: #1, 2 Nut Driver In/mm: 7/32 - 7/16” & 5.0 - 13.0mm T-handle Hex In/mm: 5/32 - 3/8” & 4.0 - 8.0mm Hex L-key: 10.0mm & 1/2” Sockets In/mm: 1/2” - 7/8” & 13.0 - 22.0mm 4.9” Extension, 3/8” Drive Ratchet, 50mm Cable Stripping Knife & 2 Meter Ruler In/mm Cat. III Voltage Detector - Battery Operated Insulated High Leverage Combination Pliers Item No. Description 32820 9.0”/225mm Case Pack 3 Insulated Lineman’s “5-in-1” Pliers Item No. Description 32821 9.0”/225mm Case Pack 3 Insulated Serrated Edge Cable Cutters 11 Pc. Insulated Inch Nut Driver Set Item No. Description Case Pack 32296 Insulated Inch Nut Driver Set 1 Inch: 5/32, 3/16, 7/32, 1/4, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8” Insulated Security TORX® Cushion Grip Driver Item No. 32512 32513 32514 32515 32517 32518 32519 Description T10s x 100mm T15s x 100mm T20s x 100mm T25s x 125mm T27s x 125mm T30s x 125mm T40s x 150mm Case Pack 3 3 3 3 3 3 3 Insulated Cushion Grip Metric Hex Driver Item No. 32302 32303 32304 32305 32306 32308 Description 2.5 x 75mm 3.0 x 75mm 4.0 x 75mm 5.0 x 75mm 6.0 x 100mm 8.0 x 100mm Case Pack 10 10 10 10 10 10 6 Pc. Insulated TORX® Screwdriver Set Item No. Description 32590 Insulated TORX Driver Set TORX: T8, T9, T10, T15, T20, T25 Case Pack 3 112 Pc. Insulated Master Electrician’s Set Item No. Description Case Pack 32801 Insulated Tool Set 1 6.3” & 8.0” Long Nose Pliers, 6.3” Bent Nose Pliers, 6.3” Long Flat Nose Pliers, 6.3” Diagonal Cutters 9.0” Combo Pliers/Crimpers, 8.0” Cable Cutters, 8.0” High Leverage Cutters & 6.3” Stripping Pliers 8.0” Adjustable Wrench Slotted: 2.5 - 10.0mm, Phillips: #0 - 3, Square: #1, 2 TORX: T6 - T30 & Slt/Ph Terminal: #1, 2 Nut Driver In/mm: 7/32 - 7/16” & 5.0 - 13.0mm T-handle Hex In/mm: 5/32 - 3/8” & 4.0 - 8.0mm Hex L-key: 10.0mm & 1/2” Sockets In/mm: 1/2” - 7/8” & 13.0 - 22.0mm 4.9” Extension, 3/8” Drive Ratchet, 50mm Cable Stripping Knife & 2 Meter Ruler In/mm Cat. III Voltage Detector - Battery Operated Insulated Inch Deep Offset Ring Wrenches: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 25/32, 13/16, 7/8, 15/16, 1, 1-1/16, 1-1/4” Insulated Metric Deep Offset Ring Wrenches: 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 17.0, 19.0, 20.0, 22.0, 24.0, 27.0, 30.0, 32.0mm Item No. Description 32826 6.3”/160mm 32828 8.0”/200mm Case Pack 3 3 Insulated Diagonal Cutters Item No. Description 32832 6.3”/160mm Case Pack 3 Insulated NE Style Lineman’s Pliers Item No. Description 32831 9.5”/245mm Case Pack 3 10 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA In Canvas Pouch Knurled striking zone on vinyl grip pliers 2 Pc. NE Style Lineman’s Pliers Item No. Description Case Pack 32833 NE Style Lineman’s 3 9.5”/245mm Insulated Lineman’s Pliers 9.5”/245mm Soft Vinyl Grip Lineman’s Pliers Insulated Diagonal Cutters W/Stripping Holes Item No. Description 32861 6.3”/160mm Case Pack 3 10 Pc. Insulated Pliers/Cutters & Drivers Set Item No. Description Case Pack 32868 Insulated Tool Set 1 7.0” Diagonal Cutters, 9” Combo Pliers, 8.0” Long Nose Pliers, 6.3” Wire Stripper, 7” Crimping Pliers Slotted: 3.0. 4.5, 6.0mm, Phillips: #1, 2 In Zipper Pouch Insulated High Leverage Diagonal Cutters Item No. Description 32835 6.3”/160mm 32836 7.0”/180mm Case Pack 3 3 2 Pc. Insulated Pliers/Cutters Set Item No. Description 32862 Insulated Pliers/Cutters Set 8.0” BiCut SuperCut Pliers 8.0” Combination Lineman’s Pliers Case Pack 3 Insulated BiCut SuperCut Chrome Finish Item No. Description 32837 8.0”/200mm 14 Pc. Insulated Pliers/Cutters & Drivers Set Item No. Description Case Pack 32869 Insulated Tool Set 1 9.0” Lineman’s Pliers, 8.0” High Leverage Cutters, 8.0” Cable Cutters, 8.0” Long Nose Pliers, 6.0” Stripping Pliers 10-20 AWG SlimeLine: Slotted: 3.0. 4.5, 6.5mm & Phillips: #1, 2 Square: #1, 2 & Terminal Driver: #2 Single Pole Tester 66 Pc. Insulated Tool Box Set Item No. Description Case Pack 32876 Insulated Tool Set 1 8.0” Long Nose Pliers, 6.3” Long Flat Nose Pliers, 9.0” Combo Pliers/Crimpers, 8.0” Cable Cutters, 6.3” Side Cutters, 8.0” BiCut SuperCut, 6.3” Stripping Pliers & 8.0” Adjustable Wrench Slotted: 2.0-10.0mm, Phillips: #0 - 3, Square: #1, 2 Inch Nut Drivers: 1/4 - 7/16” & TORX: T8 - T30 T-handle Hex In/mm: 5/32 - 3/8” & 4.0 - 8.0mm Slt/Ph Terminal: #1, 2 & Hex L-key: 10.0mm & 1/2” Sockets In/mm: 1/2” - 7/8” & 8.0 - 22.0mm 4.9” Extension, 3/8” Drive Ratchet & 50mm Cable Knife Case Pack 3 3 Pc. Insulated Pliers/Cutters Set Item No. Description Case Pack 32863 Insulated Pliers/Cutters Set 1 8.0” H.Lev. Diagonal Cutters, 9.0” Lineman’s Pliers, 6.3” Stripping Pliers 5 Pc. Insulated Pliers/Cutters & Drivers Set Item No. Description Case Pack 32872 Insulated Belt Pack Pouch Set 3 6.3” Diagonal Cutters, 8.0” Long Nose Pliers Slotted: 3.0, 4.5mm & Phillips: #2 5 Pc. Insulated Pliers/Cutters & Drivers Set Item No. Description Case Pack 32856 Insulated Combo Set 3 6.3” Diagonal Cutters, 8.0” Long Nose Pliers Slotted: 4.5, 5.5mm & Phillips: #2 3 Pc. Insulated Pliers/Cutters Set Item No. Description Case Pack 32864 Insulated Pliers/Cutters Set 3 6.3” Diagonal Cutters, 8.0” Long Nose Pliers 8.0” Combination Lineman’s Pliers 3 Pc. Insulated Pliers & Cutters Set Item No. Description Case Pack 32873 Insulated Belt Pack Pouch Set 3 6.3” Diagonal Cutters, 8.0” Long Nose Pliers & 8.0” Combination Pliers 80 Pc. Insulated Master Electrician’s Set Item No. Description Case Pack 32877 Insulated Tool Set 1 6.3” & 8.0” Long Nose Pliers, 6.3” Bent Nose Pliers, 6.3” Long Flat Nose Pliers, 6.3” Diagonal Cutters 9.0” Combo Pliers/Crimpers, 8.0” Cable Cutters, 8.0” BiCut SuperCut & 6.3” Stripping Pliers, 8.0” Adjustable Wrench Slotted: 2.0-10.0mm, Phillips: #0 - 3, Square: #1, 2 TORX: T6 - T30 & Slt/Ph Terminal: #1, 2 Nut Driver In/mm: 7/32 - 7/16” & 5.0 - 13.0mm T-handle Hex In/mm: 5/32 - 3/8” & 4.0 - 8.0mm Hex L-key: 10.0mm & 1/2” Sockets In/mm: 1/2” - 7/8” & 13.0 - 22.0mm 4.9” Extension, 3/8” Drive Ratchet, 50mm Cable Stripping Knife & 2 Meter Ruler In/mm 7 Pc. Insulated BiCut SuperCut & Drivers Set Item No. Description Case Pack 32857 Insulated Combo Set 3 8.0” BiCut SuperCut Pliers Slotted: 3.5, 4.5, 5.5mm & Phillips: #0, 1, 2 8 Pc. Insulated Pliers & SlimLine Blade Set Case Pack Item No. Description 1 Insulated Pliers/Cutters Set 32865 8.0” Long Nose Pliers W/Cutters Insulated SlimLine Pop-Up Blade Set Slotted: 3.0, 4.0, 5.5, 6.5 & Phillips: #1, 2 7 Pc. Insulated Lineman’s Pliers & Drivers Set Item No. Description Case Pack 32858 Insulated Combo Set 3 8.0” Combination Lineman’s Pliers Slotted: 3.5, 4.5, 5.5mm & Phillips: #0, 1, 2 In Canvas Pouch 48 Pc. Insulated Canvas Tool Bag Set 13 Pc. Insulated Canvas Tool Bag Set Item No. Description Case Pack 32874 Insulated Tool Set 1 6.3” & 8.0” Long Nose Pliers, 6.3” Combination Pliers, 9.0” Combo Pliers/Crimpers, 6.3” Side Cutters, 8.0” High Leverage Cutters, 6.3” Stripping Pliers 8.0” Adjustable Wrench Slotted: 2.0 - 8.0mm, Phillips: #0 - 3, Square: #1, 2 Inch Nut Drivers: 7/32 - 1/2” & TORX: T8 - T30 T-handle Hex: 5/32 - 3/8” & Slt/Ph Terminal: #1, 2 50mm Cable Knife & 2 Meter Ruler In/mm Item No. Description Case Pack 32878 Insulated Tool Set 1 8.0” Long Nose Pliers, 9.0” Combo Pliers/Crimpers 8.0” High Leverage Cutters Slotted: 3.0, 4.5, 6.0mm & Phillips: #1, 2 Square: #1, 2 & Slt/Ph Terminal: #1, 2 50mm Cable Knife SlimLine Drivers 10 Pc. Insulated Pliers/Cutters & Drivers Set Insulated Stripping Pliers Item No. Description 32860 6.3”/160mm Case Pack 3 Item No. Description Case Pack 32867 Insulated Tool Set 1 6.3” Diagonal Cutters, 9” Combo Pliers, 6.3” Long Nose Pliers, 6.3” Wire Stripper, 7” Crimping Pliers Slotted: 4.5, 6.0mm, Phillips: #1, 2 & Square: #2 5 Pc. Insulated Industrial Pliers & Drivers Set Item No. Description Case Pack 32875 Ins Industrial Belt Pack Pouch Set 1 9.5” Lineman’s Pliers, 8.0” Long Nose Pliers Slotted: 4.5, 6.5mm & Phillips: #2 25 Pc. Insulated Tool Set Item No. Description Case Pack 32879 Insulated Tool Set 1 8.0” Long Nose Pliers, 9.0” Combination Pliers 8.0” High Leverage Cutters, 6.3” Stripping Pliers Slotted: 3.0, 4.5, 6.0mm & Phillips: #1, 2 Square: #1, 2 & Slt/Ph Terminal: #1, 2 Nut Driver In/mm: 1/4 - 1/2” & 7.0 - 13.0mm 50mm Cable Knife & 2 Meter Ruler In/mm 11 www.wihatools.com • USA | www.wihatools.ca • CANADA Natural Brushed Finish 17 Pc. Pliers/Cutters & Pop Up Set Item No. Description Case Pack 32886 Insulated Belt Pack Pouch Set 1 8.0” Long Nose Pliers, 8.0” High Leverage Cutters 9.5” Lineman’s Pliers Slotted: 4.5, 5.5, 6.0mm & Phillips: #0, 1, 2, 3 Sq: #1, 2, 3 & TORX: T15, T20, T25 Insulated Industrial Bent Nose Pliers 13 Pc. Insulated Pliers/Cutters & Drivers Set Item No. Description 32928 6.3”/160mm Case Pack 3 Item No. Description Case Pack 32894 Insulated Tool Bag Set 1 6.3” Long Nose Pliers, 8.0” Combination Pliers 8.0” Bent Nose Pliers, 6.3” Side Cutters, 10” Water Pump Pliers Slotted: 4.5, 6.5mm & Phillips: #1, 2 Inch Nut Drivers: 1/4, 5/16, 3/8, 1/2” Insulated Industrial BiCut SuperCut Item No. Description 32936 8.0”/200mm Case Pack 3 In Zipper Carry Case Insulated Industrial Diagonal Cutters In Canvas Pouch Item No. Description 32929 8.0”/200mm 32933 6.3”/160mm 11 Pc. Insulated Tool Pouch Set 14 Pc. Insulated Pliers/Cutters & Drivers Set Item No. Description Case Pack 32888 Insulated Tool Set 1 6.3” Long Nose Pliers, 8.0” Combination Pliers 6.3” Side Cutters, 6.3” Stripping Pliers Slotted: 2.5, 3.5, 4.5, 6.0mm & Phillips: #0, 1, 2 Item No. Description Case Pack 32895 Insulated Tool Set 1 8.0” Long Nose Pliers, 9.0” Combination Pliers 6.3” Side Cutters, 8.0” High Lev. Cutters, 6.3” Stripping Pliers Slt: 2.0, 2.5, 3.0, 3.5, 4.5, 6.5mm & Ph: #1, 2, 3 Case Pack 3 3 Insulated Industrial H. Leverage Combo Pliers Item No. Description 32930 8.0”/200mm Case Pack 3 8 Pc. Insulated Pliers & Cutters Pouch Set Item No. Description Case Pack 32889 Insulated Tool Set 1 6.3” & 8.0” Long Nose Pliers, 6.3” Diagonal Cutters, 6.3” & 9.0” Lineman’s Pliers, 8.0” BiCut SuperCut, 6.3” Stripping Pliers & 50mm Electrician’s Knife In Electrician’s Belt Pack Insulated Industrial NE Style Lineman’s Pliers Insulated Combination Pliers In Zipper Carry Case Item No. Description 32900 9.0”/225mm 59 Pc. Insulated Master Electrician’s Tool Set Item No. Description Case Pack 32937 Insulated Tool Set 1 8.0” Long Nose Pliers, 9.5” NE Style Lineman’s Pliers, 8.0” Heavy Duty Diagonal Cutters, 8.0” Cable Cutters, 10.0” Water Pump Pliers Non-Insulated 10.0” Auto Water Pump Pliers, 7.25” Stripping Pliers 10-20 AWG, 25 Ft. Tape Measure, 20 oz. Claw Hammer, 9” Torpedo Level, Cat IV Voltage Detector, Nut Setters 1/4, 5/16, 3/8” ErgoStar Ball End Hex Inch & Metric 22 Pc. L-key Sets Extra Heavy Duty SoftFinish® Driver Slotted: 10.0mm Insulated Cushion Grip SlimLine Drivers: Slotted: 4.0, 4.5, 5.5, 6.5mm, Phillips: #1, 2, Square: #1, 2, Terminal Xeno Slt/Ph: #1, 2 Nut Drivers Inch: 7/32, 1/4, 5/16, 3/8, 7/16, 1/2” Insulated PicoFinish® Precision Screwdrivers: Slotted: 2.5, 3.0, 3.5mm, Phillips: #00, 0, 1 Item No. Description 32938 9.5”/245mm Case Pack 3 Case Pack 3 16 Pc. Insulated Apprentice Tool Set 10 Pc. Insulated Pliers/Cutters & Drivers Set Item No. Description Case Pack 32891 Insulated Tool Set 1 8.0” Long Nose Pliers, 8.0” Combination Pliers 8.0” BiCut SuperCut, 6.3” Cable Cutters, 6.3” Stripping Pliers Slotted: 4.5, 6.5mm & Phillips: #1, 2, 3 Insulated Long Nose & Bent Nose Pliers Item No. Description 32901 8.0”/200mm Long Case Pack 3 Item No. Description Case Pack 32934 Insulated Tool Set 1 Insulated Industrial High Lev. Diagonal Cutters 8.0” Long Nose Pliers, 9.5” NE Style Lineman’s Pliers, Item No. Description Case Pack 8.0” Heavy Duty Diagonal Cutters 32939 8.0”/200mm 3 7.25” Stripping Pliers 10-20 AWG, 25 Ft. Tape Measure, 20 oz. Claw Hammer, 9” Torpedo Level Insulated SoftFinish® Cushion Grip Screwdrivers: Slotted: 4.5, 6.5mm, Phillips: #1, 2, Square: #2 PicoFinish® Precision Screwdrivers: Insulated Industrial Long Flat Nose w/Cutters Slotted: 2.5, 3.0, 3.5mm, Phillips: #0 Item No. Description Case Pack 32941 6.3”/160mm 3 Industrial Serrated Edge Cable Cutters Item No. Description 32902 6.3”/160mm 32927 8.0”/200mm Case Pack 3 3 30 Pc. Insulated Journeyman’s Tool Set In Canvas Tool Bag 10 Pc. Insulated Pliers/Cutters & Drivers Set Item No. Description Case Pack 32892 Insulated Tool Bag Set 1 6.3” Long Nose Pliers, 8.0” Combination Pliers 8.0” Bent Nose Pliers, 6.3” Side Cutters, Slotted: 3.0, 4.5, 6.5mm & Phillips: #0, 1, 2 Insulated Industrial Long Nose Pliers Item No. Description 32923 8.0”/200mm 32926 6.3”/160mm Case Pack 3 3 Item No. Description Case Pack 32935 Insulated Tool Set 1 8.0” Long Nose Pliers, 9.5” NE Style Lineman’s Pliers, 8.0” Heavy Duty Diagonal Cutters, 8.0” Cable Cutters, 10.0” Water Pump Pliers Non-Insulated 10.0” Auto Water Pump Pliers, 7.25” Stripping Pliers 10-20 AWG, 25 Ft. Tape Measure, 20 oz. Claw Hammer, 9” Torpedo Level, Cat IV Voltage Detector, Nut Setters 1/4, 5/16, 3/8” Extra Heavy Duty SoftFinish® Driver Slotted: 8.0mm Insulated SoftFinish® Cushion Grip Screwdrivers: Slotted: 4.0, 4.5, 6.5mm, Phillips: #1, 2, Square: #1, 2, Nut Drivers Inch: 1/4, 5/16, 3/8” PicoFinish® Precision Screwdrivers: Slotted: 2.5, 3.0, 3.5mm, Phillips: #0, 1 7 Pc. Industrial Insulated Combination Set Item No. Description Case Pack 32942 Drivers & BiCut SuperCut Set 3 8.0” SoftGrip BiCut SuperCut Slotted: 3.0, 4.5, 5.5mm & Phillips: #0, #1, #2 Faster combined cutting & stripping Insulated Industrial TriCut 3 In 1 Item No. Description 32944 6.7”/170mm Case Pack 3 12 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA Insulated Industrial Crimping Pliers Item No. Description 32945 7.0”/180mm Case Pack 3 3 Pc. Insulated Industrial Pliers & Cutters Set 7 Pc. Industrial Pliers/Cutters & Drivers Set Item No. Description Case Pack 32968 Insulated Industrial Set 6 9.5” NE Style Lineman’s Pliers, 8.0” Long Nose Pliers, 8.0” Diagonal Cutters Item No. Description Case Pack 32985 Insulated Industrial Set 3 8.0” Combo Pliers, 6.3” Long Nose Pliers, 6.3” Diagonal Cutters Slotted: 3.0, 4.5mm & Phillips: #1, 2 17 Pc. Industrial Pliers/Cutters & Pop Up Set Item No. Description Case Pack 32990 Insulated Industrial Pouch Set 1 8.0” Long Nose Pliers, 8.0” High Leverage Cutters 9.5” Lineman’s Pliers Slotted: 4.5, 5.5, 6.0mm & Phillips: #0, 1, 2, 3 Sq: #1, 2, 3 & TORX: T15, T20, T25 Insulated Industrial Strippers Item No. Description 32947 6.3”/160mm Case Pack 3 Ind. NE Style Lineman’s Pliers w/Crimpers Item No. Description 32948 9.5”/245mm Case Pack 3 Insulated Proturn Electrician’s Shears Item No. Description 32951 6.3”/160mm Case Pack 3 22 Pc. Industrial Pliers/Cutters & Drivers Set 11 Pc. Industrial Pliers/Cutters & Drivers Set Item No. Description Case Pack 32973 Insulated Industrial Set 1 9.0” Lineman’s w/Crimpers, 8.0” Long Nose Pliers, 8.0” Diagonal Cutters, 50mm Stripping Knife Slim Slotted: 3.5, 4.5mm & Slim Phillips: #1, 2 Slim Xeno: #1, 2 & Slim Square: #1, 2 T-handle Hex Inch: 3/16, 7/32, 1/4, 5/16, 3/8, 5/32” Nut Drivers Inch: 3/8, 7/16, 1/4, 5/16” Item No. Description Case Pack 32986 Insulated Industrial Set 1 6.3” Long Nose Pliers, 6.3” Diagonal Cutters, 8.0” Combo Pliers, 6.3” Stripping Pliers Slotted: 3.0, 4.5, 5.5mm Phillips: #1, 2 & Square: #1, 2 Item No. Description Case Pack 32999 Insulated Pliers Set 1 8.0” Combo Pliers, 9” Lineman’s Pliers, 6.3” & 8.0” Long Nose Pliers, 6.3” Stripping Pliers, 6.3” & 8.0” Diagonal Cutters, 7.0” Crimping Pliers, 8.0” Cable Cutters 11 Pc. Insulated Pliers/Cutters & Driver Set Item No. Description Case Pack 32977 Insulated Industrial Set 1 Pliers & Cutters: 8.0” Combination Pliers, 8.0” Long Nose Pliers w/Cutters, 8.0” High Leverage Cutters, 6.3” Long Nose Pliers, 6.3” Diagonal Cutters Slotted: 3.0, 4.0, 6.5mm & Phillips: #0, 1, 2 Insulated Industrial Water Pump Pliers Item No. Description 32954 10.0”/250mm In Blow Molded Tool Tray 9 Pc. Insulated Industrial Pliers & Cutters Set Case Pack 3 1000Volt Insulated Metric T-handle 8 Pc. Insulated Industrial Pliers/Cutters Set Item No. Description Case Pack 32987 Insulated Industrial Set 1 6.3” & 8.0” Long Nose Pliers, 6.3” Diagonal Cutters, 8.0” H.D. Diagonal Cutters, 9.0” Lineman’s w/Cutters, 6.3” Stripping Pliers, 8.0” Cable Cutters, 7.0” Crimpers Item No. 33441 33443 33445 33447 33449 Description 4.0 x 150mm 5.0 x 150mm 6.0 x 150mm 8.0 x 150mm 10.0 x 150mm Case Pack 10 10 10 10 10 3 Pc. Insulated Industrial Pliers & Cutters Set Insulated Ind. Push Button Water Pump Pliers Item No. Description 32956 10.0”/250mm Case Pack 3 Item No. Description Case Pack 32981 Insulated Industrial Set 3 8.0” High Leverage Combination Pliers, 8.0” Long Nose Pliers & 8.0” Diagonal Pliers 5 Pc. Insulated Hex Metric T-handle Set Item No. Description 33478 Insulated T-handle Set Metric: 4.0, 5.0, 6.0, 8.0, 10.0mm Case Pack 3 22 Pc. Insulated Industrial Pliers/SlimLine Set 7 Pc. Industrial Insulated Combination Set Item No. Description Case Pack 32958 Drivers & Combo Pliers Set 3 8.0” Combination Pliers Slotted: 3.5, 4.5, 5.5mm & Phillips: #0, #1, #2 5 Pc. Ins. Industrial Cutters & Drivers Set Item No. Description 32983 Insulated Industrial Set 6.3” Diagonal Cutters Slotted: 3.0, 4.5mm & Phillips: #1, 2 Case Pack 3 Item No. Description Case Pack 32988 Ind. & SlimLine Set 1 8.0” Long Nose Pliers, 6.3” Diagonal Cutters, 8.0” H.D. Diagonal Cutters, 9.0” Lineman’s w/Cutters, 6.3” Strip Pliers, 8.0” Cable Cutters, 7.0” Crimpers SlimLine Blade Set Includes: SlimLine Blade Holder Slotted: 3.0, 4.0, 5.5, 6.5mm & Phillips: #1, 2 Xeno: #1, 2 & Sq.: #1, 2 & TORX: T8, T10, T15, T20 In Blow Molded Tool Trays 1000Volt Insulated Inch T-handle Item No. 33481 33482 33483 33485 33486 33487 Description 5/32” x 5.9” 3/16” x 5.9” 7/32” x 5.9” 1/4” x 6.9” 5/16” x 6.9” 3/8” x 6.9” Case Pack 10 10 10 10 10 10 28 Pc. Insulated Pliers/Screwdrivers Tray Sets Small - 11” x 7.75” x 1.25” 3 Pc. Insulated Industrial Pliers & Cutters Set 6 Pc. Insulated Industrial Pliers & Drivers Set Item No. Description Case Pack 32960 Insulated Industrial Set 1 9.5” NE Style Lineman’s Pliers 8.0” Long Nose Pliers & 8.0” Angled Cutters Item No. Description Case Pack 32984 Insulated Industrial Set 1 8.0” Combination Pliers, 8.0” Long Nose Pliers Slotted: 3.0, 4.5mm & Phillips: #2 & Square: #2 Item No. Description Case Pack 32989 Insulated Pliers Set 1 8” Combo Pliers, 9” Lineman’s Pliers, 8” Cable Cutters, 6.3” & 8” Long Nose Pliers, 6.3” Stripping Pliers, 6.3” & 8” Diagonal Cutters, 7” Crimping Pliers Slot: 2.5, 3.0, 3.5, 4.0, 4.5, 5.5, 6.0, 6.5, 8.0, 10.0mm Phillips: #0, 1, 2, 3 & Square: #1, 2 & Xeno: #1, 2 Cat. III Voltage Detector - Battery Operated 6 Pc. Insulated Hex Inch T-handle Set Item No. Description 33490 Insulated T-handle Set Inch: 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Case Pack 3 13 www.wihatools.com • USA | www.wihatools.ca • CANADA In Clamshell 2 Pc. Insulated Slotted & Phillips Set Item No. Description 33532 Insulated Screwdriver Set Slotted: 6.0mm & Phillips: #2 Case Pack 6 14 Pc. Insulated Pop-Up Insert Bit Set Item No. Description Case Pack 38051 Insulated Pop Up Set - 1/4” Bits 3 Slotted: 4.5, 5.5, 6.0mm & Phillips: #0, 1, 2, 3 Sq: #1, 2, 3 & TORX: T15, T20, T25 Insulated Adjustable Wrenches Item No. 76208 76210 76212 76215 Description 8.0 x 200mm 10.0 x 250mm 12.0 x 300mm 15.0 x 380mm Case Pack 3 3 3 3 Insulated TORX® Drivers In Blister Pkg. Item No. 92062 92063 92064 92065 92066 92067 92068 92069 92070 92071 92072 Description T5 x 60mm T6 x 60mm T7 x 60mm T8 x 60mm T9 x 60mm T10 x 60mm T15 x 80mm T20 x 80mm T25 x 80mm T27 x 100mm T30 x 100mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 Insulated T-handle Metric Nut Drivers Item No. 33632 33634 33637 33641 Description 8.0 x 200mm 10.0 x 230mm 13.0 x 230mm 17.0 x 230mm Case Pack 10 10 10 10 In Clamshell Insulated Large Capacity Cable Cutter Item No. Description 40800 800mm OAL Case Pack 1 3 Pc. Insulated Adjustable Wrench Set Item No. Description 76290 Ins. Adj. Wrenches 8.0”, 10.0”, 12.0” Adjustable Case Pack 1 Item No. Description 92075 #1 x 80mm 92076 #2 x 100mm In Clamshell Case Pack 10 10 Insulated Cushion Grip SlimLine Square Tip Item No. Description 35844 1 x 100mm 35845 2 x 125mm Case Pack 3 3 (Slotted/Pozidriv®) Insulated MaxiFlex Combo MM/In Ruler Item No. Description 61630 Increments 1/16” Case Pack 3 Insulated Serrated Straight Fine Tweezers Item No. Description 75205 Fine Point - 130mm Case Pack 3 Insulated Serrated Straight Blunt Tweezers Item No. Description 75210 Blunt Point - 130mm Case Pack 3 6 Pc. Insulated Slotted/Phillips/Square Set Item No. Description 35890 Insulated Screwdriver Set Slotted: 4.5, 6.5mm & Phillips: #1, 2 Square: #1, 2 Insulated Slotted Drivers In Clamshell Item No. 92000 92002 92004 92005 92006 92008 92010 92012 92014 92016 92018 92020 92022 92024 92026 92028 Description 2.0 x 60mm (5/64”) 2.5 x 75mm (3/32”) 3.0 x 100mm (1/8”) 3.5 x 100mm (9/64”) 4.0 X 100mm (5/32”) 4.5 x 100mm (3/16”) 4.5 x 125mm (3/16”) 4.5 x 150mm (3/16”) 4.5 x 175mm (3/16”) 4.5 x 200mm (3/16”) 5.5 x 125mm (7/32”) 5.5 x 175mm (7/32”) 6.0 x 150mm (15/64”) 6.5 x 150mm (1/4”) 8.0 x 175mm (5/16”) 10.0 x 200mm (3/8”) Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Insulated Phillips Drivers In Blister Package Insulated Serrated Straight Blunt Tweezers Case Pack 3 Item No. 92031 92033 92035 92038 92040 Description #0 x 60mm #1 x 80mm #2 x 100mm #3 x 150mm #4 x 200mm Case Pack 3 3 3 3 3 In Clamshell 6 Pc. Insulated Slotted/Phillips/Square Set Case Pack 3 Insulated Serrated Straight Blunt Tweezers Item No. Description 75220 Blunt Point - 200mm Case Pack 3 Insulated Square Drivers In Blister Package Item No. Description 92043 #1 x 100mm 92045 #2 x 150mm Insulated Xeno Drivers In Blister Package Item No. Description 92077 #1 x 80mm 92078 #2 x 100mm Case Pack 3 3 In Clamshell Insulated Pozidriv® Drivers In Blister Package Item No. 92079 92080 92081 92082 Description #0 x60mm #1 x 80mm #2 x 100mm #3 x 150mm Case Pack 3 3 3 3 In Clamshell Insulated Metric Nut Drivers In Blister Package In Clamshell Case Pack 3 Item No. Description 75215 Blunt Point - 140mm Item No. Description 35891 Insulated Screwdriver Set Slotted: 3.0, 5.5mm & Phillips: #1, 2 Square: #1, 2 Case Pack 3 3 In Clamshell Insulated Square Tip Cushion Grip Screwdriver Item No. Description 35811 1 x 100mm 35812 2 x 150mm (Slotted/Phillips) Insulated Xeno Drivers In Blister Package Item No. 92206 92209 92212 92215 92218 92221 92224 92226 92230 92233 92236 92238 92239 92240 92241 Description 4.0 x 125mm 5.0 x 125mm 5.5 x 125mm 6.0 x 125mm 7.0 x 125mm 8.0 x 125mm 9.0 x 125mm 10.0 x 125mm 11.0 x 125mm 12.0 x 125mm 13.0 x 125mm 14.0 x 125mm 15.0 x 125mm 16.0 x 125mm 17.0 x 125mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Case Pack 3 3 Insulated Inch Nut Drivers In Blister Package Insulated Serrated Angled Fine Tweezers Item No. Description 75302 Fine Point - 145mm Case Pack 3 14 Pc. Insulated Pop-Up Insert Bit Set Item No. Description Case Pack 38050 Insulated Pop Up Set - 1/4” Bits 3 Slotted: 4.5, 5.5, 6.0mm & Phillips: #0, 1, 2, 3 Square: #1, 2, 3 & Pozidriv®: #1, 2, 3 Insulated Serrated Angled Blunt Tweezers Item No. Description 75304 Blunt Point - 200mm Case Pack 3 In Clamshell Insulated Hex Metric Drivers In Blister Pkg. Item No. 92050 92052 92054 92056 92058 92060 Description 2.5 x 75mm 3.0 x 75mm 4.0 x 75mm 5.0 x 75mm 6.0 x 100mm 8.0 x 100mm Case Pack 3 3 3 3 3 3 Item No. 92255 92258 92261 92264 92267 92268 92270 92273 92276 92278 92280 Description 5/32 x 5.0” 3/16 x 5.0” 7/32 x 5.0” 1/4 x 5.0” 5/16 x 5.0” 11/32 x 5.0” 3/8 x 5.0” 7/16 x 5.0” 1/2” x 5.0” 9/16 x 5.0” 5/8 x 5.0” Case Pack 3 3 3 3 3 3 3 3 3 3 3 14 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA PLIERS AND CUTTERS Safety | Quality | Innovation Industrial SoftGrip Combination Pliers Item No. Description 30901 6.3”/160mm 30903 7.0”/180mm 30905 8.0”/200mm Case Pack 3 3 3 Industrial SoftGrip H. Duty Combination Pliers Item No. Description 30907 8.0”/200mm 30909 9.0”/225mm Case Pack 3 3 Industrial SoftGrip Long Nose Pliers Item No. Description 30911 6.3”/160mm 30913 8.0”/200mm Case Pack 3 3 Industrial SoftGrip Diagonal Cutters Item No. Description 30923 5.5”/140mm 30925 6.3”/160mm 30927 7.0”/180mm Case Pack 3 3 3 2 Pc. Industrial SoftGrip Pliers Pack 2 Pc. Industrial SoftGrip Pliers Pack Item No. Description 30941 Pliers & Cutters Set 9.0”/225mm Lineman’s Crimpers 8.0”/200mm BiCut SuperCut Case Pack 3 2 Pc. Industrial SoftGrip Pliers Pack Industrial SoftGrip Cable Cutters Item No. Description 30926 6.3”/160mm 30928 8.0”/200mm Item No. Description 30963 Pliers & Cutters Set 9.5”/245mm NE Style Lineman’s Pliers 8.0”/200mm BiCut SuperCut Case Pack 3 3 Industrial SoftGrip H. Lev. Diagonal Cutters Item No. Description 30929 6.3”/160mm 30931 7.0”/180mm 30933 8.0”/200mm Case Pack 3 3 3 Item No. Description Case Pack 30961 Pliers & Cutters Set 3 9.5”/245mm NE Style Lineman’s Pliers 8.0”/200mm Long Nose Pliers W/Cutters Case Pack 3 7 Pc. Industrial SoftGrip Combination Set Item No. Description Case Pack 30942 Drivers & BiCut SuperCut Set 6 8.0” Soft Grip BiCut SuperCut Slotted: 3.0, 4.0, 6.5mm & Phillips: #0, #1, #2 3 Pc. Industrial SoftGrip Pliers Pack Item No. Description Case Pack 30964 Pliers & Cutters Set 3 8.0” Combo Pliers, 8.0” Long Nose Pliers W/Cutters, 6.3” Diagonal Cutters Industrial SoftGrip Lineman’s Crimpers Item No. Description 30912 9.0”/225mm Case Pack 3 Industrial SoftGrip BiCut SuperCut Item No. Description 30936 8.0”/200mm Case Pack 3 Industrial SoftGrip Push Button Pump Pliers Item No. Description 30943 10.0”/250mm 30944 12.0”/300mm Case Pack 3 3 Industrial SoftGrip Long Bent Nose Pliers Item No. Description 30915 6.3”/160mm 40° Bent 30917 8.0”/200mm 40° Bent Case Pack 3 3 3 Pc. Industrial SoftGrip Pliers Pack Industrial SoftGrip Heavy Duty End Nippers Item No. Description 30939 8.0”/200mm Case Pack 3 Industrial SoftGrip Wire Strippers Item No. Description 30947 6.3”/160mm Case Pack 3 Item No. Description Case Pack 30965 Pliers & Cutters Set 3 8.0” Long Nose Pliers W/Cutters, 9.0” Lineman’s Pliers W/Crimpers & 10.0” Adjustable Water Pump Pliers Industrial SoftGrip Flat Nose Pliers Item No. Description 30919 6.3”/160mm Case Pack 3 Industrial SoftGrip Round Nose Pliers Item No. Description 30921 6.3”/160mm Case Pack 3 Industrial SoftGrip NE Style Lineman’s Pliers Item No. Description 30940 9.5”/245mm Case Pack 3 2 Pc. Industrial SoftGrip Pliers Pack 4 Pc. Industrial SoftGrip Pliers & Cutters Set Item No. Description Case Pack 30960 Pliers & Cutters Set 3 9.5”/245mm NE Style Lineman’s Pliers 8.0”/200mm Long Nose Pliers w/Cutters Item No. Description Case Pack 30990 Pliers & Cutters Set 3 9” Lineman’s Pliers, 8” Long Nose Pliers, 8” H.D. Diagonal Cutters, 6.3” Wire Stripper 15 www.wihatools.com • USA | www.wihatools.ca • CANADA 3 Pc. Industrial SoftGrip Pliers & Cutters Set Item No. Description Case Pack 30993 Pliers & Cutters Set 3 8” Combination Pliers, 8” Long Nose Pliers, 8” H.D. Diagonal Cutters Soft Grip Flush Cutters W/Return Spring Item No. Description 32607 5.0”/127mm 32614 6.3”/160mm Case Pack 3 3 8 Pc. Soft Grip Pliers & Cutters Set Soft Grip Cable Cutters Item No. Description 32600 6.3”/160mm 32602 7.9”/200mm Case Pack 3 3 Item No. Description Case Pack 32608 Soft Grip Pliers Set 1 6.3” Combination Pliers, 6.3” & 8.0” Long Nose Pliers, 6.3” Diagonal Cutters, 6.3” Long Flat Nose Pliers, 6.3” Long Round Nose Pliers, 8.0” High Lev. Cutters, 9.0” High Leverage Combo Pliers Soft Grip Needle Nose W/Cutting Edge Spring Item No. Description 32617 6.3”/160mm Case Pack 3 Soft Grip Long Nose Pliers w/Cutters Item No. Description 32618 6.3”/160mm 32621 8.0”/200mm Case Pack 3 3 Soft Grip Lineman’s W/Crimpers Item No. Description 32624 9.5”/245mm Case Pack 3 5 Pc. Soft Grip Straight Internal Ring Pliers Set Item No. Description Case Pack 32626 Internal Ring Pliers Set 1 5.5”-Tip .035/.9mm, 5.5”-Tip .050/1.3mm, 7.0”-Tip .070/1.5mm, 8.9”-Tip .090/2.3mm 12.2”-Tip .126/3.2mm 5 Pc. Soft Grip 90° Angle Internal Ring Pliers Item No. Description Case Pack 32627 90° Angle Internal Ring Pliers 1 5.5”-Tip .035/.9mm, 5.5”-Tip .050/1.3mm, 7.0”-Tip .070/1.5mm, 8.9”-Tip .090/2.3mm 12.2”-Tip .126/3.2mm Comfort Grip Multi-purpose Electrician’s Shears Item No. Description Case Pack 32611 5.75”/145mm 3 5 Pc. Soft Grip Straight External Ring Pliers Soft Grip Combo Pack Wrench & Auto Pliers Item No. Description 32619 2 Pc. Wrench & Auto Pliers 10.5”/267mm Pliers Wrench 10.0”/250mm Auto Pliers 4 Pc. Soft Grip Pliers & Cutters Set Item No. Description Case Pack 32601 Soft Grip Pliers Set 1 8.0” Combination Pliers, 6.3” Long Nose Pliers, 6.3” Diagonal Cutters, 10.0” Water Pump Pliers Case Pack 3 Soft Grip High Leverage Combination Pliers Item No. Description 32612 8.0”/200mm 32615 9.0”/225mm Case Pack 3 3 3 Case Pack 3 3 Case Pack 3 Soft Grip High Leverage Angle Cutters Case Pack 3 Soft Grip Flush Cutters With Spring Item No. Description 32616 9.0”/225mm Case Pack 3 Soft Grip NE Style Lineman’s Pliers Item No. Description 32631 9.5”/245mm Case Pack 3 Soft Grip Lineman’s “5-in-1” Pliers Soft Grip Crimping Pliers Item No. Description 32630 6.3”/160mm Item No. Description 32620 8.0”/200mm Item No. Description 32613 5.0”/127mm Item No. Description 32604 5.75”/145mm 32605 7.0”/180mm Soft Grip Long Flat Nose Pliers Case Pack 3 3 Soft Grip Combination Pliers Item No. Description 32603 6.3”/160mm 32606 7.0”/180mm 32609 8.0”/200mm Item No. Description Case Pack 32628 External Ring Pliers Set 1 5.5”-Tip .035/.9mm, 5.5”-Tip .050/1.3mm, 7.0”-Tip .070/1.5mm, 8.9”-Tip .090/2.3mm 12.2”-Tip .126/3.2mm Soft Grip Bent Long Nose Pliers w/Cutters Item No. Description 32623 6.3”/160mm 32625 8.0”/200mm Case Pack 3 3 Case Pack 3 Soft Grip Long Round Nose Pliers Item No. Description 32633 6.3”/160mm Case Pack 3 16 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA Soft Grip Internal Retaining Ring Pliers Item No. Description 32654 12.2”-Tip .126/3.2mm 7 Pc. Soft Grip Combination Set 3 Piece Pliers/Cutters Set Item No. Description Case Pack 32634 3 pc. Pliers/Cutters 6 9.5” NE Style Lineman’s Pliers 8.0” Long Pliers & 8.0” High Leverage Angle Cutters Soft Grip Pliers Wrench Case Pack 3 Push Button Adjustable Water Pump Pliers Item No. Description 32664 7.0”/180mm 32665 10.0”/250mm 32667 12.0”/300mm Case Pack 3 3 3 Item No. Description Case Pack 32644 Drivers & BiCut SuperCut Set 6 8.0” SoftGrip BiCut SuperCut Slotted: 3.0, 4.0, 6.5mm, Phillips: #0, #1, #2 Soft Grip High Leverage Cutters Item No. Description 32635 10.25/260mm Case Pack 3 Item No. Description 32646 6.3”/160mm 32649 7.0”/180mm 32652 8.0”/200mm Case Pack 3 3 3 5 Pc. Soft Grip Pliers & Drivers In Belt Pack Item No. Description Case Pack 32655 Soft Grip Pliers & Screwdrivers 3 Slotted: 3.0, 4.5mm & Phillips: #2 6.3” Diagonal Cutters, 8.0” Long Nose Pliers 3 Pc. Push Button Water Pump Pliers Set Item No. Description 32669 Push Button Pliers Set 7.0”, 10.0”, 12.0” Case Pack 1 3 Pc. Adjustable Pliers - Box Type Set Item No. Description 32670 Adjustable Pliers Set 7.0”, 10.0”, 12.0” Soft Grip BiCut SuperCut Item No. Description 32636 8.0”/200mm 90° Angle Internal Retaining Ring Pliers Case Pack 3 4 Pc. Soft Grip Pliers & Cutters Set Item No. Description 32656 12.2”-Tip .126/3.2mm Case Pack 3 Item No. Description Case Pack 32647 Soft Grip Pliers Set 3 8.0” Combination Pliers, 8.0” Long Nose Pliers, 6.3” Diagonal Cutters, 10.0” Water Pump Pliers 2 Pc. Soft Grip Pliers & Cutters Set Item No. Description Case Pack 32675 Pliers & Cutters Set 3 9.5” NE Style Lineman’s Pliers, 8.0” High Lev. Cutters Soft Grip High Leverage End Cutting Nippers Soft Grip Auto Pliers Item No. Description 32637 10.0”/250mm Item No. Description 32657 6.3”/160mm 32658 7.0”/180mm 32659 8.0”/200mm Case Pack 3 Case Pack 3 3 3 2 Pc. Soft Grip Pliers & Cutters Set Soft Grip Internal Retaining Ring Pliers Item No. Description Case Pack 32648 Pliers & Cutters Set 3 8.0” Long Nose Pliers, 6.3” Diagonal Cutters Item No. 32681 32682 32683 32684 Soft Grip Diagonal Cutters Item No. Description 32638 5.5”/140mm 32639 7.0”/180mm 32642 6.3”/160mm Case Pack 3 3 3 Description 5.5”-Tip .035/.9mm 5.5”-Tip .050/1.3mm 7.0”-Tip .070/1.5mm 8.9”-Tip .090/2.3mm Case Pack 3 3 3 3 Soft Grip Adjustable Pliers - Box Type Item No. Description 32660 7.0”/180mm 32661 10.0”/250mm 32663 12.0”/300mm Case Pack 3 3 3 2 Pc. Soft Grip Pliers & Cutters Set 90° Angle Internal Retaining Ring Pliers Item No. 32685 32686 32687 32688 Item No. Description Case Pack 32651 Pliers & Cutters Set 3 9.5” NE Style Lineman’s Pliers, 8.0” BiCut SuperCut Description 5.5”-Tip .035/.9mm 5.5”-Tip .050/1.3mm 7.0”-Tip .070/1.5mm 8.9”-Tip .090/2.3mm Case Pack 3 3 3 3 Soft Grip External Retaining Ring Pliers 2 Pc. Soft Grip Pliers Pack Item No. Description 32640 Pliers & Cutters Set 9.0”/225mm Lineman’s Pllers 8.0”/200mm BiCut SuperCut Case Pack 1 Item No. Description 32662 12.2”-Tip .126/3.2mm Case Pack 3 3 Pc. Soft Grip Pliers & Cutters In Belt Pack Item No. Description Case Pack 32653 Soft Grip Pliers & Cutters 3 8.0” High Leverage Cutters, 8.0” Combo Pliers, 8.0” Long Nose Pliers w/Cutters Case Pack 3 90° Angle External Retaining Ring Pliers Item No. Description 32666 11.7”-Tip .126/3.2mm Case Pack 3 Soft Grip External Retaining Ring Pliers Item No. 32689 32690 32691 32692 Description 5.5”-Tip .035/.9mm 5.5”-Tip .050/1.3mm 7.0”-Tip .070/1.5mm 8.9”-Tip .090/2.3mm Case Pack 3 3 3 3 17 www.wihatools.com • USA | www.wihatools.ca • CANADA D ESD Safe Prec. Cutters Wide Tapered Head Item No. Description 32708 4.5” Flush 32710 4.5” Full Flush Case Pack 3 3 D ESD Safe Prec. Bent Snipe Nose Pliers 45° Item No. Description 32744 4 3/4” Smooth Jaws Case Pack 3 Pipe Wrenches Narrow Style - 45° Item No. Description 32975 16.77” OAL Case Pack 3 8 Pc. Soft Grip Straight Retaining Ring Pliers Item No. Description Case Pack 32693 Retaining Ring Pliers Set 1 Internal: 5.5” - Tip .035”, 5.5” - Tip .050”, 7.0” - Tip .070”, 8.9” - Tip .090” External: 5.5” - Tip .035”, 5.5” - Tip .050”, 7.0” - Tip .070”, 8.9” - Tip. 090” 90° Angle External Retaining Ring Pliers Item No. 32694 32696 32697 Description 5.5”-Tip .035/.9mm 7.0”-Tip .070/1.5mm 8.9”-Tip .090/2.3mm Case Pack 3 3 3 D ESD Safe Precision Cutters Slim Oval Head Item No. Description 32712 4.5” Flush 32714 4.5” Full Flush Case Pack 3 3 D ESD Safe Precision Cutters Wide Oval Head Item No. Description 32716 4.5” Bevel 32720 4.5” Flush Case Pack 3 3 D ESD Safe Precision Long Needle Nose Pliers Item No. Description 32746 5 3/4” Serrated Jaws Case Pack 3 Pipe Wrenches Narrow Style - 90° Item No. 32978 32979 32980 Description 12.20” OAL 16.54” OAL 22.05” OAL Case Pack 1 1 1 D ESD Safe Prec. 90° Bent Needle Nose Pliers Item No. Description 32748 5 3/4” Smooth Jaws Case Pack 3 3 Pc. Narrow Style 90° Pipe Wrench Set Item No. Description Case Pack 32996 Pipe Wrench Set 1 12.20”, 16.54”, 22.05” Narrow Style - 90° D With Wire Trapping Device ESD Safe Precision Cutters Wide Oval Head Item No. Description 32721 4.5” Flush Case Pack 3 D ESD Safe Precision Short Round Nose Pliers Item No. Description 32750 4 3/4” Smooth Jaws Case Pack 3 3 Pc. Soft Grip Pliers & Cutters Set Item No. Description Case Pack 32698 Pliers & Cutters Set 6 7.0” Combination Pliers, 6.3” Diagonal Cutters, 6.3” Long Nose Pliers MagicTip Internal Safety Notched Ring Pliers Item No. Description 34612 12.0”-Tip .126/3.2mm D ESD Safe Prec. Oblique 29° Angled Cutters Item No. Description 32724 4.5” Full Flush Case Pack 3 D ESD Safe Precision Short Flat Nose Pliers Item No. Description 32752 4 3/4” Serrated Jaws Case Pack 3 MagicTip 90° Internal Safety Notched Ring Pliers Item No. Description Case Pack 34616 8.7”-Tip .090/2.3mm 3 34617 12.0”-Tip .126/3.2mm 3 Flush Cutting 2 Pc. Soft Grip Pliers & Cutters Set Item No. Description Case Pack 32699 Pliers & Cutters Set 3 9.5” NE Style Lineman’s Pliers, 8.0” Long Nose Pliers D Short Head ESD Safe Precision Diagonal Cutters ESD Safe Prec. Oblique 29° Angled Cutters Item No. Description 32726 4.5” Semi Flush Case Pack 3 Case Pack 3 Item No. Description 32760 5.25”/133mm OAL Case Pack 3 With Return Spring MagicTip External Safety Notched Ring Pliers D Hollow Ground Back ESD Safe Precision Cutters Sm. Tapered Head Item No. Description 32702 4.5” Semi Flush 32704 4.5” Flush Case Pack 3 3 D ESD Safe Precision Cutters Sm. Tapered Head Item No. Description 32703 4.5” Semi Flush 32705 4.5” Flush Case Pack 3 3 D ESD Safe Precision End Cutters Wide Head Item No. Description 32734 4.5” Flush Case Pack 3 D ESD Safe Precision Short Snipe Nose Pliers Item No. Description 32742 4 3/4” Serrated Jaws Case Pack 3 D ESD Safe Precision Long Nose Pliers Item No. Description 32762 6.5”/165mm OAL Description 12.60” OAL 16.38” OAL 21.06” OAL Case Pack 3 Case Pack 3 Pipe Wrenches Narrow Style / S-Jaw 45° Item No. 32970 32971 32972 Item No. Description 34622 11.8”-Tip .126/3.2mm Case Pack 1 1 1 MagicTip 90° External Safety Notched Ring Pliers Item No. Description 34626 9.5”-Tip .090/2.3mm 34627 12.0”-Tip .126/3.2mm Case Pack 3 3 18 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA Crimps Insulated & Non-Insulated Ratchet End Sleeve Crimper Item No. Description Case Pack 43612 220mm Crimping Tool 1 Crimps Insulated & Non-insulated End Sleeves 6 Crimp Positions. 26 - 8 AWG Small - 11” x 7.75” x 1.25” Electronic Prec. Diagonal Full Flush Cutters Item No. Description 56813 5.0”/128mm OAL Wire Trapping Spring - 18 AWG Case Pack 3 3 Pc. Soft Grip Pliers & Cutters Set Item No. Description Case Pack 34680 Small Foam Tray Set 1 9.0” NE Style Lineman’s Pliers 8.0” Long Nose Pliers & 8.0” Angled Cutters Small - 11” x 7.75” x 1.25” 4 Pc. Soft Grip Pliers & Cutters Set Item No. Description Case Pack 34681 Small Foam Tray Set 1 9.0” NE Style Lineman’s Pliers 6.3” & 8.0” Long Nose Pliers, 8.0” BiCut SuperCut Ratchet Crimper For Standard Connectors Item No. Description Case Pack 43618 220mm Crimping Tool 1 Crimps Insulated & Non-insulated Connectors 3 Crimp Positions. 20 - 10 AWG Crimps Insulated & Non-Insulated Electronic Precision Diagonal Cutters Item No. Description 56815 5.5”/138mm OAL Wide Pointed Head - 12 AWG Case Pack 3 Case Pack 1 Wire 5-in-1 Combo Strippers & Crimpers Item No. Description Case Pack 57814 8.25”/210mm OAL 3 Stripping stations AWG 10-22 Screw Cutter 4-40 / 5-40 / 6-32 / 8-32 / 10-32 / 10-24 Ratchet Crimper Push On Terminals Item No. Description 43624 220mm Crimping Tool Crimps Non-insulated Terminals 4 Crimp Positions. 24 - 10 AWG UpFront Cutters/Crimper/Strippers Item No. Description Case Pack 57812 8.5”/216mm OAL 3 Stripping Stations AWG 10-22 Screw Cutter 4-40 / 6-32 / 8-32 / 10-32 / 10-24 Electronic Precision Diagonal Cutters Item No. Description 56818 5.5”/138mm OAL Wide Pointed Head - 16 AWG Case Pack 3 Wire Strippers & Cutters Item No. Description 57816 6.0”/152mm OAL Stripping Stations 10-20 / 0.8-2.6mm Ratchet Crimper For Eye Terminals Item No. Description Case Pack 43643 220mm Crimping Tool 1 Crimps Insulated & Non-insulated Terminals 4 Crimp Positions. 26 - 6 AWG Medium - 15.5” x 11” x 1.25” Case Pack 3 Electronic Precision Diagonal Cutters Item No. Description Case Pack 56825 5.5”/138mm OAL 3 Wide Shape With Wire Holding Spring - 16 AWG 4 Pc. Soft Grip Pliers & Cutters Set Item No. Description Case Pack 34682 Medium Foam Tray Set 1 6.3” Long Nose Pliers & 8.0” Long Nose Pliers 8.0” BiCut SuperCut & 8.0” Angled Cutters 9.0” High Leverage Combination Pliers 8.0” Cable Cutters 5.5” Diagonal Cutters & 5.0” Diagonal Cutters Wire Strippers & Cutters Compact Ergo Wire Stripper Item No. Description 44219 Compact Wire Stripper Case Pack 3 Automatic Adjustment Cable Stripper Small - 11” x 7.75” x 1.25” 3 Pc. Soft Grip Tongue & Groove Set Item No. Description 44216 165mm OAL Strip Range 4.0-28mm2 Case Pack 3 Electronic Precision Narrow 30° Front Cutter Item No. Description 56830 4.5”/118mm OAL Long Nose Pliers - 22 AWG Case Pack 3 Electronic Precision Oblique 48° Cutter Item No. Description 56833 5.5”/138mm OAL Wide Pointed Head - 16 AWG Case Pack 3 Item No. Description Case Pack 34690 Small Foam Tray Set 1 7.0” Adjustable Pliers & 10.0” Adjustable Pliers 10.0” Auto Grip Wrench Electronic Precision Short Nose Pliers Item No. Description 56801 5.5”/138mm OAL Case Pack 3 Item No. Description Case Pack 57818 7.25”/184mm OAL 3 Stripping Stations 20-30 Solid & 22-32 Standard Screw Cutter 6-32 / 8-32 Wire Strippers Dual NM-B Cable Item No. Description Case Pack 57820 7.75”/197mm OAL 3 Strippers Size 12-2/14-2 NM-B - 12-14 AWG Screw Cutter 6-32 / 8-32 Electronic Precision Stripping Pliers Item No. Description 56871 7.0”/180mm OAL Wide Long Head - 20-10 AWG Case Pack 3 Medium - 15.5” x 11” x 1.25” 5 Pc. Soft Grip Tongue & Groove Set Item No. Description Case Pack 34691 Medium Foam Tray Set 1 7.0” Adjustable Pliers & 10.0” Adjustable Pliers 12.0” Adjustable Pliers & 10.0” Auto Grip Wrench 10.25” Pliers Wrench Electronic Precision Diagonal Cutters Item No. Description 56812 4.5”/118mm OAL Narrow Shape - 20 AWG Case Pack 3 Wire Stripping Pliers Item No. Description Case Pack 57810 7.25”/184mm OAL 3 Stripping Stations 10-18 Solid & 12-20 Standard Screw Cutter 6-32 / 8-32 3 Pc.Wire Strippers Set Item No. Description Case Pack 57830 3 Pc. Wire Strippers 6 8.25” Wire 5-in-1 Combo Strippers & Crimpers 6.0” Wire Strippers & Cutters 7.75” Wire Strippers Dual NM-B Cable 19 www.wihatools.com • USA | www.wihatools.ca • CANADA PROFESSIONAL QUALITY SETS Storage systems covering most applications Rolling Water Tight Traveling Tool Box 80 Pc. Insulated Master Electrician’s Set XXL3 Rolling Tool Case Item No. Description Case Pack Item No. Description 91216 XXL3 Storage System 32800 Insulated Tool Set 1 20.6 x 17 x 27.3 6.3” & 8.0” Long Nose Pliers, 6.3” Bent Nose Pliers, 6.3” Long Flat Nose Pliers, 6.3” Diagonal Cutters 9.0” Combo Pliers/Crimpers, 8.0” Cable Cutters, 8.0” High Leverage Cutters & 6.3” Stripping Pliers 8.0” Adjustable Wrench Slotted: 2.5 - 10.0mm, Phillips: #0 - 3, Square: #1, 2 TORX: T6 - T30 & Slt/Ph Terminal: #1, 2 Nut Driver In/mm: 7/32 - 7/16” & 5.0 - 13.0mm T-handle Hex In/mm: 5/32 - 3/8” & 4.0 - 8.0mm Hex L-key: 10.0mm & 1/2” Sockets In/mm: 1/2” - 7/8” & 13.0 - 22.0mm 4.9” Extension, 3/8” Drive Ratchet, 50mm Cable Stripping Knife & 2 Meter Ruler In/mm Cat. III Voltage Detector - Battery Operated Case Pack 1 30 Piece RedStripe™ Tool Kit Item No. Description Case Pack 91596 Veto RedStripe Pro Pac 1 11inOne Multi-Driver SoftFinish Screwdrivers Slotted: 3.5, 6.5mm, Phillips: #1, #2 and Square: #1, #2 9.0”/225mm NE Style Lineman’s With Crimpers 6Pc. Color Coded Nut Setters 13Pc. Color Coded Inch Hex L-key Set 9Pc. Color Coded Metric Hex L-key Set Veto RedStripe™ Pro Pac® Tech Pac 74 Piece RedStripe™ Electrician’s Tool Kit 112 Pc. Insulated Master Electrician’s Set 93 Piece XXL3 Rolling Tool Set Item No. Description Case Pack 32801 Insulated Tool Set 1 6.3” & 8.0” Long Nose Pliers, 6.3” Bent Nose Pliers, 6.3” Long Flat Nose Pliers, 6.3” Diagonal Cutters 9.0” Combo Pliers/Crimpers, 8.0” Cable Cutters, 8.0” High Leverage Cutters & 6.3” Stripping Pliers 8.0” Adjustable Wrench Slotted: 2.5 - 10.0mm, Phillips: #0 - 3, Square: #1, 2 TORX: T6 - T30 & Slt/Ph Terminal: #1, 2 Nut Driver In/mm: 7/32 - 7/16” & 5.0 - 13.0mm T-handle Hex In/mm: 5/32 - 3/8” & 4.0 - 8.0mm Hex L-key: 10.0mm & 1/2” Sockets In/mm: 1/2” - 7/8” & 13.0 - 22.0mm 4.9” Extension, 3/8” Drive Ratchet, 50mm Cable Stripping Knife & 2 Meter Ruler In/mm Cat. III Voltage Detector - Battery Operated Insulated Inch Deep Offset Ring Wrenches: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 25/32, 13/16, 7/8, 15/16, 1, 1-1/16, 1-1/4” Insulated Metric Deep Offset Ring Wrenches: 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 17.0, 19.0, 20.0, 22.0, 24.0, 27.0, 30.0, 32.0mm Item No. Description Case Pack 91567 PRO Tool Set 1 35Pc. 1/4” Ratchet Bit Set, 7Pc. Bit Buddy Impact Bit Set, 14inOne Stubby Multi-Bit Holder, 11inOne Multi-Driver, 5 PicoFinish Precision Drivers, SoftFinish Drivers Slt 6.5mm & Sq #2, XHD SoftFinish Slt 8.0, 12.0mm & PH #2, 8.0” H. Lev. End Cutting Pliers, 10.0” Auto Grip Pliers, 8.0” BiCut SuperCut, 8.0” Long Nose Pliers, 6Pc. Color Coded Nut Setters, 13Pc. MagicRing Inch Hex L-key Set, 9Pc. MagicRing Metric Hex L-key Set, XXL3 Rolling Tool Case Item No. Description Case Pack 91597 Veto RedStripe Pro Pac 1 Insulated 8.0” Long Nose, 8.0” High Leverage Cutters, 8.0” Cable Cutters, 8.0” BiCut SuperCut, 9.5” Lineman’s With Crimpers SoftFinish Slt 4.5, 6.5mm, Ph #1, #2 and Sq #1, #2 SlimLine Pop-up Slt 3.0, 4.0mm, Ph #1, #2 & Sq #1, #2 25505 Voltage Detector Non-Insulated 10.0” Auto Grip Pliers, 7.25” Wire Strippers XHD SoftFinish Slotted 10.0mm x 175mm 14inOne Stubby Bit Holder Set, 11inOne Multi-Driver 6Pc. Color Coded Nut Setters 9Pc. Color Coded Metric L-key Set 13Pc. Color Coded Inch L-key Set 1” TerminatorBlue Impact Bit Buddy Set 2” TerminatorBlue Impact Bit Buddy Set Veto RedStripe™ Pro Pac® Tech Pac 20 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA SCREWDRIVERS AND NUT DRIVERS Advanced technology in handle design, comfort and performance Precision Slotted Screwdrivers Switch Cabinet Key Item No. Description 21103 Switch Cabinet Key Case Pack 3 Pen Style Control Cabinet Key Item No. Description 21105 Control Cabinet Key Case Pack 3 Item No. 26008 26010 26012 26015 26018 26020 26022 26023 26025 26027 26028 26030 26032 26033 26034 26035 26040 26041 26042 Description .8 x 40mm 1.0 x 40mm 1.2 x 40mm 1.5 x 40mm 1.8 x 40mm 2.0 x 40mm 2.0 x 50mm 2.0 x 100mm 2.5 x 50mm 2.5 x 100mm 2.5 x 150mm 3.0 x 50mm 3.0 x 60mm 3.0 x 100mm 3.0 x 150mm 3.5 x 60mm 4.0 x 60mm 4.0 x 100mm 4.0 x 150mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Precision Phillips Screwdrivers 25-Piece PicoFinish Precison Driver Set Item No. Description Case Pack 26091 PicoFinish 25pc. Set 1 Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: #000, 00, 0, 1 TORX®: T4, T5, T6, T7, T8, T9, T10, T15 Hex Metric: 1.3 (.050”), 2.0, 2.5, 3.0mm Pentelobe: PL1, PL2, PL4, PL5 Tri-Wing: Y000 Case Pack 3 PicoFinish Bit Holder Handle Item No. Description 26003 Fits 4mm Micro Bits Case Pack 3 Precision PicoFinish Slotted Screwdrivers Item No. 26050 26051 26052 26053 26055 26060 26061 26065 26066 26068 26070 26072 26074 26076 26079 Description .8 x 40mm 1.0 x 40mm 1.2 x 40mm 1.5 x 40mm 1.8 x 40mm 2.0 x 40mm 2.0 x 60mm 2.5 x 50mm 2.5 x 75mm 2.5 x 100mm 3.0 x 50mm 3.0 x 100mm 3.5 x 60mm 4.0 x 60mm 4.0 x 100mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Case Pack 10 10 10 10 10 10 10 10 10 10 10 Precision PicoFinish Standoff Driver W/Pin 7 Pc. Precision Slotted/Phillips Driver Set Plastic Precision Tool Rack Description 00 x 40mm 00 x 75mm 000 x 40mm 0 x 50mm 0 x 100mm 0 x 75mm 0 x 150mm 1 x 60mm 1 x 80mm 1 x 100mm 1 x 150mm Item No. Description 26103 00 x 40mm w/Pin Item No. Description Case Pack 26092 Precision Slotted/Phillips Drivers 3 Slotted: 2.5 x 50mm, 2.5, 3.0, 4.0 x 100mm, 3.0, 4.0 x 150mm & Phillips: #0 Item No. Description 26000 Holds 6 Prec. Drivers Item No. 26100 26101 26102 26105 26107 26108 26109 26110 26113 26114 26115 Case Pack 3 Precision PicoFinish Phillips Screwdrivers Item No. 26130 26132 26135 26136 26140 Description 000 x 40mm 00 x 40mm 0 x 50mm 0 x 75mm 1 x 60mm Case Pack 10 10 10 10 10 In canvas roll-up pouch 8 Pc. Precision PicoFinish Slotted Driver Set Item No. Description Case Pack 26093 PicoFinish Slotted Screwdrivers 3 Slotted: .8, 1.2, 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm 8 Pc. PicoFinish Precision Set Item No. Description 26187 Precision Slotted: 1.5, 2.0, 2.5, 3.5mm Phillips: #00, 0, 1 Case Pack 3 In Canvas Pouch PicoFinish Screwdriver Holder Item No. Description 26004 Fits all Pico handles Case Pack 3 6 Pc. Precision Slotted Screwdriver Set 8 Pc. Precision Slotted Screwdriver Set 8 Pc. Precision Slotted/Phillips/Pliers Set Item No. Description Case Pack 26090 Precision Slotted Screwdrivers 6 Slotted: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm Item No. Description Case Pack 26099 Prec. Slotted Drivers 6 Slotted: 1.0, 1.2, 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm Item No. Description Case Pack 26190 Precision Slot/Ph & Pliers Set 6 Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: #00, 0, 1 6.3” Industrial SoftGrip Long Nose Pliers 21 www.wihatools.com • USA | www.wihatools.ca • CANADA In canvas roll-up pouch 8 Pc. Precision Slotted/Phillips/Pliers Set 5 Pc. Precision PicoFinish/Tweezer Set Item No. Description Case Pack 26191 Precision Slot/Ph & Pliers Set 3 Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: #00, 0, 1 5.0”/127mm Flush Cutting Diagonal Cutters Item No. Description Case Pack 26196 Prec. PicoFinish & Tweezer Set 3 Phillips: #0, 1, Pentalobe: PL1, Tri-Wing: #000 Tweezer 2a SA ESD Flat Round Tip 5 Pc. Precision Slotted & Phillips Driver Set Item No. Description 26192 Precision Slotted/Phillips Slotted: 2.5, 3.0, 4.0mm Phillips: #0, 1 Case Pack 3 Precision Hex Inch & Metric Screwdrivers Item No. 26307 26309 26313 26315 26316 26320 26323 26325 26327 26330 26331 26333 26336 26340 Description 0.7(0.028”) x 40mm 0.9(0.035”) x 40mm 1.3(0.05”) x 40mm 1.5 x 50mm 1/16” x 50mm 2.0(5/64”) x 50mm 3/32” x 60mm 2.5 x 60mm 7/64” x 60mm 3.0 x 60mm 1/8” x 60mm 9/64” x 60mm 5/32” x 60mm 4.0 x 60mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 10 7 Pc. Precision Slotted & Phillips Driver Set Item No. Description 26197 Slotted/Phillips Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: #00, 0, 1 7 Pc. Precision PicoFinish Hex Metric Drivers Item No. Description Case Pack 26393 Hex Metric Drivers 3 Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0mm In Canvas Pouch 8 Pc. Precision Hex Inch Screwdriver Set Item No. Description 26399 Precision Hex Inch Drivers Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8” Case Pack 3 Case Pack 6 Precision PicoFinish Hex Inch/Metric Drivers In canvas roll-up pouch 8 Pc. Precision PicoFinish Screwdriver Set 11 Pc. Smartphone Precision PicoFinish Set Item No. Description Case Pack 26193 Prec. PicoFinish Slotted/Phillips 3 Slotted: 1.0, 1.5, 2.0, 2.5, 3.5mm Phillips: #00, 0, 1 Item No. Description Case Pack 26198 Smartphone Set 3 Slotted: 1.8mm & Phillips: #000, 00, 0 ® TORX : T3, T4, T5, T6 Pentalobe: PL1 & Tri-Wing: #000 Y-Type ESD Safe: PSF SA ESD Long Flat Tweezers Item No. 26341 26343 26345 26347 26349 26351 26353 26363 26367 26369 26371 Description 0.7(0.028”) x 40mm 0.9(0.035”) x 40mm 1.3(0.05”) x 40mm 1.5 x 50mm 2.0(5/64”) x 50mm 2.5 x 60mm 3.0 x 60mm 1/16” x 50mm 3/32” x 60mm 7/64” x 60mm 1/8” x 60mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 Precision Ball End Hex Inch & Metric Drivers Item No. 26413 26415 26416 26419 26420 26423 26425 26427 26430 26431 26436 26439 26440 Description 1.3(0.50”) x 40mm 1.5 x 50mm 1/16” x 50mm 5/64” x 50mm 2.0 x 50mm 3/32” x 50mm 2.5 x 60mm 7/64” x 60mm 3.0 x 60mm 1/8” x 60mm 9/64” x 60mm 5/32” x 60mm 4.0 x 60mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 Precision PicoFinish Ball End Hex Drivers 4 Pc. Precision Phillips Driver Set In Canvas Pouch 7 Pc. Precision Hex Metric Screwdriver Set Item No. Description Case Pack 26390 Hex Metric Drivers 3 Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0mm Item No. Description Case Pack 26194 Precision Phillips Screwdrivers 3 Phillips: #000, 00, 0, 1 8 Pc. Precision Slotted & Phillips Driver Set Item No. Description 26199 Precision Slotted/Phillips Slotted: 1.0, 2.0, 3.0, 4.0mm Phillips: #000, 00, 0, 1 Case Pack 6 8 Pc. Precision Hex Inch Screwdriver Set Item No. Description Case Pack 26391 Hex Inch Drivers 3 Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8” In canvas roll-up pouch 5 Pc. Precision PicoFinish Screwdriver Set Item No. Description Case Pack 26195 Prec. PicoFinish Slotted/Phillips 3 Slotted: 1.5, 2.5, 3.5mm Phillips: #0, 1 Precision Pozidriv® Screwdrivers Item No. Description 26205 #0 x 50mm 26210 #1 x 60mm Case Pack 10 10 8 Pc. Precision PicoFinish Hex Inch Driver Set Item No. Description Case Pack 26392 Hex Inch Drivers 3 Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8” Item No. Description PicoFinish Metric: 26441 1.3 x 40mm 26443 1.5 x 50mm 26445 2.0 x 50mm 26447 2.5 x 60mm 26449 3.0 x 60mm PicoFinish Inch: 26455 1/16” x 50mm 26457 5/64” x 50mm 26459 3/32” x 50mm 26461 7/64” x 60mm 26463 1/8” x 60mm 26465 9/64” x 60mm 26467 5/32” x 60mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 22 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA In Canvas Pouch Precision PicoFinish Inch & Metric Nut Drivers 8 Pc. Precision Ball End Hex Inch Driver Set Item No. Description Case Pack 26490 Prec. Ball End Hex Inch Set 3 Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 5 Pc. Precision Ball End Hex Metric Driver Set Item No. Description Case Pack 26491 Prec. Ball End Hex Metric Set 3 Metric: 1.3, 1.5, 2.0, 2.5, 3.0mm Item No. Description Inch Nut Drivers: 26571 3/32” x 60mm 26572 7/64” x 60mm 26573 1/8” x 60mm 26574 9/64” x 60mm 26575 5/32” x 60mm 26576 3/16” x 60mm 26577 7/32” x 60mm 26578 1/4” x 60mm Metric Nut Drivers: 26579 1.5 x 60mm 26581 2.0 x 60mm 26582 2.5 x 60mm 26583 3.0 x 60mm 26584 3.5 x 60mm 26585 4.0 x 60mm 26586 4.5 x 60mm 26587 5.0 x 60mm 26588 5.5 x 60mm 26589 6.0 x 60mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 8 Pc. Precision Metric Nut Driver Set Item No. Description Case Pack 26598 Precision Metric Nut Drivers 3 Metric: 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5, 6.0mm In Canvas Pouch 8 Pc. Precision Inch Nut Driver Set Item No. Description 26599 Precision Inch Nut Drivers Inch: 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Pentalobe Precision Screwdrivers Item No. 26761 26762 26763 26764 26765 26766 Description PL1 x 40mm PL2 x 40mm PL3 x 40mm PL4 x 40mm PL5 x 40mm PL6 x 40mm Case Pack 3 3 3 3 3 3 Case Pack 3 Precision PicoFiniah Pentalobe Screwdrivers Precision Tri-Wing Screwdriver Item No. Description 26601 000 x 40mm Case Pack 3 Item No. 26771 26772 26773 26774 26775 26776 Description PL1 x 40mm PL2 x 40mm PL3 x 40mm PL4 x 40mm PL5 x 40mm PL6 x 40mm Case Pack 3 3 3 3 3 3 In Canvas Pouch Precision PicoFinish® Tri-Wing Screwdriver Item No. Description 26631 000 x 40mm 7 Pc. Precision PicoFinish Ball End Hex Inch 8 Pc. Precision Metric Nut Driver Set Item No. Description Case Pack 26493 PicoFinish Ball End Hex Inch 3 Inch: 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Item No. Description Case Pack 26590 Precision Metric Nut Drivers 3 Metric: 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5, 6.0mm Case Pack 3 6 Pc. Precision TORX® Screwdriver Set Item No. Description 26790 Precision TORX Driver Set TORX: T6, T7, T8, T9, T10, T15 Precision TORX® Screwdrivers In Canvas Pouch 8 Pc. Precision Inch Nut Driver Set Item No. Description 26591 Precision Inch Nut Drivers Inch: 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” 8 Pc. Precision Ball End Hex Inch Driver Set Item No. Description 26499 Precision Hex Inch Drivers Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Case Pack 3 Case Pack 3 7 Pc. Precision Metric Nut Driver Set Item No. Description Case Pack 26592 Precision Metric Nut Drivers 3 Metric: 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm In Canvas Pouch Precision Inch & Metric Nut Drivers Item No. 26510 26515 26520 26523 26525 26527 26530 26531 26535 26536 26539 26540 26545 26547 26550 26555 26556 26560 26563 26570 Description 1.5 x 60mm 1.8 x 60mm 2.0 x 60mm 3/32” x 60mm 2.5 x 60mm 7/64” x 60mm 3.0 x 60mm 1/8” x 60mm 3.5 x 60mm 9/64” x 60mm 5/32” x 60mm 4.0 x 60mm 4.5 x 60mm 3/16” x 60mm 5.0 x 60mm 5.5 x 60mm 7/32” x 60mm 6.0 x 60mm 1/4” x 60mm 7.0 x 60mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 8 Pc. Precision PicoFinish Inch Nut Driver Set Item No. Description Case Pack 26593 Precision PicoFinsh Nut Drivers 3 Inch: 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Item No. 26701 26702 26703 26704 26705 26706 26707 26708 26709 26710 26715 26720 Description T1 x 40mm T2 x 40mm T3 x 40mm T4 x 40mm T5 x 40mm T6 x 40mm T7 x 40mm T8 x 40mm T9 x 50mm T10 x 50mm T15 x 60mm T20 x 60mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 Case Pack 3 8 Pc. Precision TORX® Screwdriver Set Item No. Description 26791 Precision TORX Driver Set TORX: T1, T2, T3, T4, T5, T6, T7, T8 Case Pack 3 7 Pc. Precision TORX® Screwdriver Set Item No. Description 26792 Precision TORX Driver Set TORX: T5, T6, T7, T8, T9, T10, T15 Case Pack 3 In canvas roll-up pouch Precision PicoFinish TORX® Screwdrivers Item No. 26732 26733 26735 26736 26737 26739 26741 26743 26745 26747 26749 26751 Description T1 x 40mm T2 x 40mm T3 x 40mm T4 x 40mm T5 x 40mm T6 x 40mm T7 x 40mm T8 x 40mm T9 x 50mm T10 x 50mm T15 x 60mm T20 x 60mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 8 Pc. Precision PicoFinish TORX® Driver Set Item No. Description 26793 Precision TORX Driver Set TORX: T1, T2, T3, T4, T5, T6, T7, T8 Case Pack 3 In Canvas Pouch 8 Pc. Precision PicoFinish Metric Nut Drivers Item No. Description Case Pack 26596 Prec. PicoFinish Nut Drivers 3 Metric: 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm 6 Pc. Precision Pentalobe Screwdriver Set Item No. Description Case Pack 26794 Pentalobe Driver Set 3 Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 23 www.wihatools.com • USA | www.wihatools.ca • CANADA In Canvas Pouch In canvas roll-up pouch SYS 4 Drive-Loc Slotted Reversible Blade 6 Pc. PicoFinish Precision Pentalobe Set Item No. Description Case Pack 26795 Pentalobe Driver Set 3 Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 Item No. 26958 26959 26960 Description 1.5 + 3.0 2.0 + 3.5 2.5 + 4.0 Case Pack 3 3 3 9 Pc. Cushion Grip Drive-Loc IV Blade Set Item No. Description 26984 Slot/Ph/TORX® Blade Set Slotted: 1.5x3.0, 2.0x3.5, 2.5x4.0mm Phillips: #000x#00, #0x#1 TORX®: T6xT8, T7xT9, T10xT15 SoftFinish® Drive-Loc IV Handle Case Pack 3 SoftFinish® 1/4” Magnetic Bit Holder Item No. Description 28102 1/4” Bit Holder Case Pack 3 Drive-Loc VI Slotted Reversible Blade 8 Pc. Precision PicoFinish TORX® Driver Set Item No. Description 26796 Precision TORX Driver Set TORX: T5, T6, T7, T8, T9, T10, T15, T20 Item No. Description 28106 3.5 + 4.5 x 150mm 28108 5.5 + 6.5 x 150mm In Canvas Pouch Case Pack 3 Case Pack 3 3 SYS 4 Drive-Loc ESD Safe Handle Item No. Description 26961 ESD Safe 4.0mm Cushion Grip Handle In Canvas Pouch Case Pack 3 12 Pc. ESD Safe Drive-Loc IV Blade Set Item No. Description Case Pack 26985 ESD Drive-Loc IV Blade Set 1 ESD Safe Drive-Loc Cushion Grip Handle Slotted: 1.5+3.0, 2.0+3.5, 2.5+4.0 Phillips: 000+00, 00+1 TORX®: T1+T2, T3+T4, T5+T6, T6+T8, T7+T9, T10+T15 In Canvas Pouch 8 Pc. Precision TORX® Screwdriver Set Item No. Description 26799 Precision TORX Driver Set TORX: T3, T4, T5, T6, T7, T8, T9, T10 Drive-Loc VI Slotted/Phillips Reversible Blade Item No. 28107 28109 28110 Description 3.0 + #0 x 150mm 4.0 + #1 x 150mm 6.0 + #2 x 150mm Case Pack 3 3 3 Case Pack 3 In Canvas Pouch Drive-Loc VI Phillips Reversible Blade Item No. Description 28112 #1 + #2 x 150mm 12 Pc. ESD Drive-Loc IV Blade & Tweezer Set Precision Chip Lifter Item No. Description 26810 1mm x 50mm Case Pack 3 Item No. Description Case Pack 26970 Slot/Ph/TORX® Blade Set 1 Slotted: 2.0x3.5, 2.5x4.0mm Phillips: #000x#00, #0x#1 TORX®: T6xT8, T7xT9, T10xT15 AA SA Fine Point, 5 SA Extra Fine Point, 2a SA Flat & Blunt, 7a SA Curved & Fine Point ESD Safe Drive-Loc IV Handle 9 Pc. ESD Safe Drive-Loc IV Blade Set Item No. Description 26994 Slot/Ph/TORX® Blade Set Slotted: 1.5x3.0, 2.0x3.5, 2.5x4.0mm Phillips: #000x#00, #0x#1 TORX®: T6xT8, T7xT9, T10xT15 ESD Safe Drive-Loc IV Handle Case Pack 3 Case Pack 3 Drive-Loc VI Pozidriv® Reversible Blade Item No. Description 28114 #1 + #2 x 150mm Case Pack 3 Drive-Loc VI Ball End Hex & Hex Metric Blade SYS 4 Drive-Loc Cushion Grip Handle Item No. Description 26906 4.0mm Handle SoftFinish® Cushion Grip Case Pack 3 SYS 4 Drive-Loc Phillips Reversible Blade Item No. Description 26975 000 + 00 26976 0 + 1 Case Pack 3 3 SYS 4 Drive-Loc TORX® Reversible Blade Item No. 26977 26978 26979 26980 26981 26982 26983 Description T1 + T2 T3 + T4 T5 + T6 T6 + T8 T7 + T9 T10 + T15 T15 + T20 Case Pack 3 3 3 3 3 3 3 SYSTEM 4 ESD Safe Precision Handle Item No. Description 28000 4.0mm x 110mm Case Pack 3 SYS 4 Drive-Loc Pozidriv® Reversible Blade Item No. Description 28002 #0 + #1 x 120mm Case Pack 3 SYS 4 Ball End Hex & Hex Metric Blade 7 Pc. ESD Safe Drive-Loc IV Blade Set Item No. Description 26930 TORX® Blade Set TORX®: T3xT4, T5xT6, T6xT8, T7xT9, T10xT15, T15xT20 ESD Safe Drive-Loc IV Handle Case Pack 3 Item No. 28003 28004 28005 28006 28007 28008 Description 1.3 + 1.3 x 120mm 1.5 + 1.5 x 120mm 2.0 + 2.0 x 120mm 2.5 + 2.5 x 120mm 3.0 + 3.0 x 120mm 4.0 + 4.0 x 120mm Case Pack 3 3 3 3 3 3 Item No. 28116 28117 28118 28119 28120 Description 2.5 + 2.5 x 150mm 3.0 + 3.0 x 150mm 4.0 + 4.0 x 150mm 5.0 + 5.0 x 150mm 6.0 + 6.0 x 150mm Case Pack 3 3 3 3 3 Drive-Loc VI Hex Inch Reversible Blade Item No. 28122 28123 28124 Description 3/32 + 7/64 x 150mm 1/8 + 9/64 x 150mm 5/32 + 3/16 x 150mm Case Pack 3 3 3 Drive-Loc VI TORX® Reversible Blade Item No. 28126 28127 28128 28129 28130 Description T6+T8 x 150mm T7+T9 x 150mm T10+T15 x 150mm T20+T25 x 150mm T30+T40 x 150mm Case Pack 3 3 3 3 3 24 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA In Canvas Pouch Drive-Loc VI Security TORX® Reversible Blade Item No. Description 28132 T6s+T8s x 150mm 28133 T7s+T9s x 150mm 28134 T10s+T15sx150mm 28135 T20s+T25sx150mm 28136 T30s+T40sx150mm Case Pack 3 3 3 3 3 Drive-Loc VI Square Reversible Blade Item No. Description 28137 #1 + #2 x 150mm Case Pack 3 5 Pc. Drive-Loc VI Interchangeable Blade Set 32 Pc. Drive-Loc VI Interchangeable Blade Set Item No. Description Case Pack 28187 Drive-Loc Blade Set 1 Slotted: 3.5+4.5, 5.5+6.5 & Square: 1+2, Phillips/Slotted: 0+3.0, 1+4.0, 2+6.0 Security TORX: T6s+T8s, T7s+T9s, T10s+T15s, T20s+T25s, T30s+T40s Hex MM: 2.0+2.5, 3.0+4.0, 5.0+6.0mm Hex In: 3/32+7/64, 1/8+9/64, 5/32+3/16” Nut Driver In: 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2” Nut Driver MM: 5.5, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0mm ESD Safe Cushion Grip Blade Lock Handle 8 Pc. Drive-Loc VI Interchangeable Blade Set Item No. Description Case Pack 28196 Inch Nut Driver Blade Set 3 Inch: 3/16, 1/4, 5/16, 11/32, 3/8, 7/16, 1/2” Cushion Grip Blade Lock Handle 5 Pc. Drive-Loc VI Interchangeable Blade Set Item No. Description Case Pack 28197 Security TORX Blade Set 3 Security TORX: T6s + T8s, T7s + T9s, T10s + T15s, T20s + T25s, T30s + T40s Cushion Grip Blade Lock Handle Drive-Loc VI Tri-wing® Reversible Blade Description 0 + 1 x 150mm 2 + 3 x 150mm 4 + 5 x 150mm Case Pack 3 3 3 Case Pack 3 In Canvas Pouch 6 Pc. Drive-Loc VI Interchangeable Blade Set Item No. 28138 28139 28140 Item No. Description 28477 Sec. TORX Driver Blade Set Security TORX: T6+T8, T7+T9, T10+T15, T20+T25, T30+T40 Item No. Description 28479 Tri-wing & Torq Set Blades Tri-wing: #0+1, 2+3, 4+5 Torq Set: #2+4, 6+8 Case Pack 3 In Canvas Pouch 5 Pc. Drive-Loc VI Interchangeable Blade Set Drive-Loc VI Torq Set Reversible Blade ® Item No. Description 28142 2 + 4 x 150mm 28143 6 + 8 x 150mm Case Pack 3 3 Drive-Loc VI Hex Metric Reversible Blade Item No. 28149 28150 28151 Description 2.0 + 2.5 x 150mm 3.0 + 4.0 x 150mm 5.0 + 6.0 x 150mm Case Pack 3 3 3 32 Pc. Drive-Loc VI Interchangeable Blade Set Item No. Description Case Pack 28188 Drive-Loc Blade Set 1 Slotted: 3.5+4.5, 5.5+6.5 & Square: 1+2, Phillips/Slotted: 0+3.0, 1+4.0, 2+6.0 Security TORX: T6s+T8s, T7s+T9s, T10s+T15s, T20s+T25s, T30s+T40s Hex MM: 2.0+2.5, 3.0+4.0, 5.0+6.0mm Hex In: 3/32+7/64, 1/8+9/64, 5/32+3/16” Nut Driver In: 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2” Nut Driver MM: 5.5, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0mm SoftFinish® Cushion Grip Blade Lock Handle Description 3/16 x 150mm 7/32 x 150mm 1/4 x 150mm 9/32 x 150mm 5/16 x 150mm 11/32 x 150mm 3/8 x 150mm 7/16 x 150mm 1/2 x 150mm Case Pack 3 3 3 3 3 3 3 3 3 Drive-Loc VI Metric Nut Driver Blade Item No. 28168 28169 28170 28171 28172 28173 28174 28175 28176 28177 Description 4.0 x 150mm 4.5 x 150mm 5.0 x 150mm 5.5 x 150mm 6.0 x 150mm 7.0 x 150mm 8.0 x 150mm 10.0 x 150mm 11.0 x 150mm 9.0 x 150mm Case Pack 3 5 Pc. Drive-Loc VI Interchangeable Blade Set 10 Pc. Drive-Loc VI Interchangeable Blade Set ESD Safe Drive-Loc VI Cushion Grip Handle Item No. Description 28486 6.0 x 115mm Case Pack 3 15 Pc. Drive-Loc VI Interchangeable Blade Set Item No. Description Case Pack 28189 Drive-Loc Blade Set 1 Slotted: 3.5+4.5, 5.5+6.5 Phillips: 1+2 Security TORX: T6s+T8s, T7s+T9s, T10s+T15s, T20s+T25s, T30s+T40s Hex Metric: 2.0+2.5, 3.0+4.0, 5.0+6.0mm Hex Inch: 3/32+7/64, 1/8+9/64, 5/32+3/16” SoftFinish® Cushion Grip Blade Lock Handle Case Pack 3 3 3 3 3 In 3 Canvas 3 Pouch 3 3 3 Drive-Loc VI Magnetic Bit Holder In Canvas Pouch Item No. Description Case Pack 28199 Slotted/Phillips/TORX/Hex 3 Slotted/Phillips: 4.0 + 1, 6.0 + 2 TORX: T6 + T8, T7 + T9, T10 + T15, T20 + T25 Hex Inch: 3/32 + 7/64, 1/8 + 9/64, 5/32 + 3/16” Cushion Grip Blade Lock Handle 5 Pc. Drive-Loc VI Interchangeable Blade Set Item No. Description 28184 Holds 1/4” Bits Item No. Description Case Pack 28198 Metric Nut Driver Blade Set 3 Metric: 5.0, 5.5, 6.0, 7.0, 8.0, 9.0, 10.0mm Cushion Grip Blade Lock Handle Item No. Description Case Pack 28485 TORX Driver Blade Set 3 TORX: T6+T8, T7+T9, T10+T15, T20+T25, T30+T40 Drive-Loc VI Inch Nut Driver Blade Item No. 28156 28157 28158 28159 28160 28161 28162 28163 28164 8 Pc. Drive-Loc VI Interchangeable Blade Set Item No. Description Case Pack 28483 Drive-Loc VI Blades 3 Slotted/Phillips: 3.0+#0, 4.0+#1, 6.0+#2 Square: #1+2 & Pozidriv: #1+2 Item No. Description Case Pack 28194 Slotted/Phillips/Square Blades 3 Slotted: 3.5 + 4.5, 5.5 + 6.5 & Phillips: #1 + #2 Square: #1 + #2 Cushion Grip Blade Lock Handle 5 Pc. Drive-Loc VI Interchangeable Blade Set Item No. Description Case Pack 28474 Hex Driver Blade Set 3 Inch: 3/32+7/64, 1/8+9/64, 5/32+3/16” Metric: 3.0+4.0, 5.0+6.0mm 5 Pc. Drive-Loc VI Interchangeable Blade Set Item No. Description 28476 Hex Driver Blade Set Metric: 2.5, 3.0, 4.0, 5.0, 6.0mm Case Pack 3 Drive-Loc VI SoftFinish Cushion Grip Handle Item No. Description 28488 6.0 x 115mm Case Pack 3 Drive-Loc VI Cushion Grip Bit Holder Item No. Description 28489 1/4” - Magnetic Extends 1-3/4” - 4-7/8” Case Pack 3 25 www.wihatools.com • USA | www.wihatools.ca • CANADA Cushion Grip Slotted Screwdrivers Item No. 30202 30203 30204 30205 30206 30208 30210 30211 30212 30215 30216 30217 30218 30219 30220 30221 30222 30223 30225 30226 30227 30230 30232 30235 30236 30238 Description 2.0 x 65mm 2.5 x 75mm 3.0 x 80mm 3.0 x 100mm 3.0 x 150mm 3.0 x 200mm 3.5 x 100mm 4.5 x 125mm 3.5 x 200mm 4.0 x 100mm 4.0 x 200mm 4.0 x 150mm 4.5 x 80mm 4.5 x 150mm 5.5 x 125mm 5.5 x 200mm 6.0 x 100mm 6.5 x 100mm 6.5 x 150mm 6.5 x 200mm 8.0 x 150mm 8.0 x 175mm 8.0 x 300mm 10.0 x 200mm 12.0 x 250mm 5.5 x 300mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Cushion Grip Stubby Slotted Screwdrivers Item No. 30239 30255 30265 Description 4.0 x 25mm 5.5 x 25mm 6.5 x 25mm Case Pack 10 10 10 7 Pc. Cushion Grip Slotted/Phillips Pliers Set Item No. Description Case Pack 30288 Drivers/Pliers Set 3 Slotted: 3.0, 4.0, 5.5mm, Phillips: #0, 1, 2 7.0”/180mm Cushion Grip Diagonal Cutters 6 Pc. Cushion Grip Slotted & Phillips Set Item No. Description Case Pack 30294 Slotted & Phillips Driver Set 3 Slotted: 4.0, 6.5, 8.0mm & 4.0 x 25mm Phillips: #1, 2 In Carry Case 5 Pc. Cushion Grip Slotted & Phillips Set 8 Pc. Cushion Grip Slotted/Phillips/Square Set Item No. Description Case Pack 30277 Slotted & Phillips Driver Set 6 Slotted: 3.5, 4.5, 6.5mm Phillips: #1, 2 Item No. Description Case Pack 30289 Slot/Ph/Sq. Screwdriver Set 6 Slotted: 3.0, 4.5, 5.5, 6.5mm Phillips: #1, 2 & Square: #0, 1 5 Pc. Cushion Grip Slotted & Phillips Set Item No. Description Case Pack 30295 Slotted & Phillips Driver Set 3 Slotted: 3.0, 4.0, 6.5mm Phillips: #1, 2 In Clamshell Cushion Grip Slotted Screwdrivers Item No. 30241 30243 30245 30247 30249 30250 30251 30252 30253 30254 30256 30257 30258 30259 30260 30261 30262 30263 30264 30266 30267 30268 30269 30270 30271 30272 Description 2.0 x 65mm 2.5 x 75mm 3.0 x 80mm 3.0 x 100mm 3.0 x 150mm 3.0 x 200mm 3.5 x 100mm 3.5 x 200mm 4.0 x 100mm 4.0 x 150mm 4.0 x 200mm 4.5 x 80mm 4.5 x 125mm 4.5 x 150mm 5.5 x 125mm 5.5 x 300mm 5.5 x 200mm 6.0 x 100mm 6.5 x 100mm 6.5 x 150mm 6.5 x 200mm 8.0 x 150mm 8.0 x 175mm 8.0 x 300mm 10.0 x 200mm 12.0 x 250mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 7 Pc. Cushion Grip Slotted & Phillips Set 10Pc. Cushion Grip Slotted/Phillips/Square Set Item No. Description Case Pack 30278 Slotted & Phillips Driver Set 6 Slotted: 3.5, 4.0, 5.5, 6.5mm Phillips: #1, 2, 3 Item No. Description Case Pack 30290 Slot/Ph/Sq. Screwdriver Set 1 Slotted: 3.0, 3.5, 4.5, 6.5mm Phillips: #0, 1, 2 & Square: #1, 2, 3 Medium - 15.5” x 11” x 1.25” 10 Pc. SoftFinish® Screwdriver Tray Set Item No. Description Case Pack 30280 SoftFinish® Screwdrivers 1 Slotted: 3.5, 4.0, 4.5, 4.5, 5.5, 6.0, 6.5, 8.0mm Phillips: #1, 2, 3 12 Pc. Cushion Grip Slotted & Phillips Set Item No. Description Case Pack 30297 Slotted & Phillips Driver Set 1 Slotted: 3.0, 4.0, 5.5, 6.5, 8.0, 10.0mm & 6.5 x 25mm Phillips: #0, 1, 2, 3 & #2 x 25mm 6 Pc. Cushion Grip Slotted/Phillips/Square Set Item No. Description Case Pack 30291 Slot/Ph/Sq. Screwdriver Set 3 Slotted: 4.5, 6.5mm & Phillips: #1, 2 Square: #1, 2 8 Pc. Cushion Grip Slotted & Phillips Set Item No. Description Case Pack 30298 Slotted & Phillips Driver Set 1 Slotted: 3.0, 4.0, 5.5, 6.5, 8.0mm Phillips: #1, 2, 3 Cushion Grip “Measure-Up” Slotted Drivers Item No. Description 30237 5.5 x 125mm Case Pack 3 5 Pc. Cushion Grip Slotted/Phillips/Square Set Item No. Description Case Pack 30286 Slot/Ph/Sq. Screwdriver Set 6 Slotted: 3.5mm & Phillips: #1, 2, Square: #1, 2 11 Pc. SoftFinish® & PicoFinish® Slot/Ph Set 20 Pc. Cushion Grip Screwdriver Set Item No. Description Case Pack 30293 Slotted & Phillips Driver Set 1 Precision Pico Slotted: 1.5, 2.0, 2.5mm Precision Pico Phillips: #000, #00, #0 SoftFinish® Slotted: 4.0, 6.5mm SoftFinish® Phillips: #1, #2, #3 Item No. Description Case Pack 30299 SoftFinish Screwdriver Set 1 Slotted: 3.0, 4.0, 5.5, 6.5, 8.0mm & Phillips: #0, 1, 2 Square: #1, 2, 3 & Pozidriv: #1, 2 TORX: T6, T8, T10, T15, T20, T25, T30 26 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA Magnetic Cushion Grip Slotted Hex Bolster Drivers Item No. 30813 30814 30815 30816 30817 30820 30825 30830 30835 Description Case Pack 3.5 x 75mm No Bolster 10 4.5 x 90mm No Bolster 10 5.5 x 100mm 10 6.5 x 100mm 10 6.5 x 125mm 10 7.0 x 125mm 10 8.0 x 150mm 10 10.0 x 175mm 10 12.0 x 200mm 10 2 Pc. Cushion Grip Stubby Screwdriver Set Item No. Description 31190 25mm Stubby Driver Set Slotted: 4.0mm & Phillips: #1 Case Pack 3 2 Pc. Cushion Grip Stubby Screwdriver Set Item No. Description 31191 25mm Stubby Driver Set Slotted: 6.5mm & Phillips: #2 SoftFinish® Cushion Grip Metric Nut Drivers T-handle Inch Nut Drivers Item No. 33653 33659 33665 33671 33674 33677 Description 3/16” x 6.0” 1/4” x 6.0” 5/16” x 6.0” 3/8” x 6.0” 7/16” x 6.0” 1/2” x 6.0” Case Pack 10 10 10 10 10 10 Case Pack 3 Cushion Grip Phillips Screwdrivers Item No. 31105 31110 31112 31114 31115 31117 31118 31120 31125 Description 0 x 60mm 1 x 80mm 1 x 200mm 1 x 300mm 2 x 100mm 2 x 200mm 2 x 300mm 3 x 150mm 4 x 200mm Case Pack 10 10 10 10 10 10 10 10 10 7 Pc. Cushion Grip Inch Nut Driver Set Case Pack 3 2 Pc. Cushion Grip Stubby Screwdriver Set Item No. Description 31193 Slotted Stubby Driver Set Slotted: 4.0 x 25mm, 6.5 x 25mm Case Pack 10 10 Case Pack 3 2 Pc. Cushion Grip Stubby Screwdriver Set Item No. Description 31192 Phillips Stubby Driver Set Phillips: 1 x 25mm, 2 x 25mm Item No. Description 34152 5.5 x 125mm 34154 5.5 x 250mm Item No. Description 34193 SoftFinish Nut Driver Set Inch: 3/16, 1/4, 5/16, 11/32, 3/8, 7/16, 1/2” Case Pack 3 6 Pc. T-handle Inch Nut Driver Set Item No. Description 33690 T-handle Nut Driver Set 3/16, 1/4, 5/16, 3/8, 7/16, 1/2” Case Pack 1 7 Pc. Cushion Grip Metric Nut Driver Set Item No. Description 34194 SoftFinish Nut Driver Set Metric: 5.0, 5.5, 6.0, 7.0, 8.0, 10.0, 13.0mm Case Pack 3 Cushion Grip Phillips Hex Bolster Drivers Item No. Description 31201 1 x 80mm 31203 3 x 150mm Case Pack 10 10 5 Pc. T-handle Metric Nut Driver Set Item No. Description 33691 T-handle Nut Driver Set Metric: 6.0, 8.0, 9.0, 10.0, 13.0mm Case Pack 3 10 Pc. Cushion Grip Inch Nut Driver Set Item No. Description Case Pack 34195 SoftFinish Nut Driver Set 1 Inch: 3/16, 7/32, 1/4, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8” Cushion Grip Pozidriv® Screwdrivers Cushion Grip Stubby Phillips Screwdrivers Item No. Description 31135 1 x 25mm 31140 2 x 25mm Case Pack 10 10 Item No. 31305 31310 31315 31316 31320 Description 0 x 60mm 1 x 80mm 2 x 100mm 2 x 300mm 3 x 150mm Case Pack 10 10 10 10 10 In Clamshell Cushion Grip “Measure-Up” Phillips Drivers Item No. Description 31137 2 x 100mm Case Pack 10 Cushion Grip Pozidriv® Screwdrivers Item No. 31349 31351 31353 31354 Description 0 x 60mm 1 x 80mm 2 x 100mm 3 x 150mm Case Pack 3 3 3 3 In Clamshell Description 0 x 60mm 1 x 80mm 1 x 200mm 1 x 300mm 2 x 100mm 2 x 200mm 2 x 300mm 3 x 150mm 4 x 200mm Description 5.0 x 125mm 5.5 x 125mm 6.0 x 125mm 7.0 x 125mm 8.0 x 125mm 10.0 x 125mm 11.0 x 125mm 12.0 x 125mm 13.0 x 125mm 14.0 x 125mm 15.0 x 125mm 16.0 x 125mm 17.0 x 125mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 SoftFinish® Cushion Grip Inch Nut Drivers T-handle Metric Nut Drivers Cushion Grip Phillips Screwdrivers Item No. 31141 31142 31143 31144 31145 31146 31147 31148 31149 SoftFinish® Cushion Grip Metric Nut Drivers Item No. 34120 34121 34122 34123 34124 34126 34127 34128 34129 34130 34131 34132 34133 Case Pack 3 3 3 3 3 3 3 3 3 Item No. 33603 33606 33607 33609 33612 33620 33622 33623 Description 6.0 x 125mm 8.0 x 125mm 8.0 x 200mm 9.0 x 125mm 10.0 x 125mm 12.0 x 125mm 13.0 x 125mm 13.0 x 230mm Case Pack 10 10 10 10 10 10 10 10 Item No. 34134 34135 34136 34137 34138 34139 34140 34141 34142 34143 34144 34145 Description 9/64 x 5.0” 5/32 x 5.0” 3/16 x 5.0” 7/32 x 5.0” 1/4 x 5.0” 5/16 x 5.0” 11/32 x 5.0” 3/8 x 5.0” 7/16 x 5.0” 1/2” x 5.0” 9/16 x 5.0” 5/8” x 5.0” Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 Cushion Grip Hollow Shaft Metric Nut Drivers Item No. 34302 34304 34306 34308 34310 34312 34314 Description 5.0 x 70mm 5.5 x 70mm 6.0 x 70mm 7.0 x 70mm 8.0 x 70mm 10.0 x 70mm 13.0 x 70mm Case Pack 10 10 10 10 10 10 10 Cushion Grip Hollow Shaft Inch Nut Drivers Item No. 34336 34338 34339 34340 34341 34342 34343 Description 3/16 x 2.75” 1/4 x 2.75” 5/16 x 2.75” 11/32 x 2.75” 3/8 x 2.75” 7/16 x 2.75” 1/2 x 2.75” Case Pack 10 10 10 10 10 10 10 27 www.wihatools.com • USA | www.wihatools.ca • CANADA 4 Pc. SoftFinish Cushion Grip Square Set 7 Pc. Hollow Shaft Inch Nut Driver Set Item No. Description Case Pack 34390 Cushion Grip Nut Driver Set 3 Inch: 3/16, 1/4, 5/16, 11/32, 3/8, 7/16, 1/2” Item No. Description 35894 Square Screwdriver Set Square: #0, 1, 2, 3 Case Pack 3 8 Pc. SoftFinish Screw Holding Screwdrivers Item No. Description Case Pack 34596 Slotted/Phillips Screwdriver Set 3 Slotted: 2.5, 3.0, 4.0, 5.0, 6.0mm Phillips: #0, 1, 2 7 Pc. Hollow Shaft Metric Nut Driver Set Item No. Description Case Pack 34391 Cushion Grip Nut Driver Set 1 Metric: 5.0, 5.5, 6.0, 7.0, 8.0, 10.0, 13.0mm Heavy Duty Cushion Grip Metric Nut Drivers w/Hex Bolster Item No. 34712 34715 34718 34721 34724 34727 34730 Description 7.0 x 125mm 8.0 x 125mm 9.0 x 125mm 10.0 x 125mm 11.0 x 125mm 12.0 x 125mm 13.0 x 125mm Case Pack 10 10 10 10 10 10 10 Cushion Grip Triangle Nut Drivers Item No. 34474 34475 34476 34478 Description M4 - 6.8 x 125mm M5 - 8.3 x 125mm M6 - 10.1 x 125mm M8 - 12.1 x 125mm Case Pack 10 10 10 10 Item No. 34753 34759 34765 34771 34774 Description 3/16 x 5.0” 1/4 x 5.0” 5/16 x 5.0” 3/8 x 5.0” 7/16 x 5.0” Case Pack 10 10 10 10 10 Phillips Screw Holding Screwdrivers Item No. 34501 34502 34503 Description 0 x 100mm 1 x 125mm 2 x 175mm Item No. Description Case Pack 34791 Cushion Grip Nut Driver Set 3 Metric: 5.0, 6.0, 8.0, 10.0, 11.0mm Slotted Screw Holding Screwdrivers Description 2.5 x 75mm 3.0 x 100mm 4.0 x 125mm 5.0 x 150mm 6.0 x 175mm Case Pack 10 10 10 10 10 SoftFinish® Cushion Grip Square Screwdriver Item No. 35800 35801 35802 35803 Description 0 x 80mm 1 x 100mm 2 x 150mm 3 x 150mm Case Pack 10 10 10 10 Case Pack 3 7 Pc. SoftFinish® Ball End TORX® Set Item No. Description Case Pack 34592 Slotted/Phillips Screwdriver Set 3 Slotted: 2.5, 3.0, 4.0mm Phillips: #0, #1 Item No. 36202 36203 36207 36234 36244 36249 36254 36256 36258 Description T6 x 60mm T7 x 60mm T8 x 60mm T9 x 60mm T10 x 80mm T15 x 80mm T20 x 100mm T25 x 100mm T30 x 115mm SoftFinish® Cushion Grip Square Screwdriver Item No. 35820 35821 35822 35823 Description 0 x 80mm 1 x 100mm 2 x 150mm 3 x 150mm Item No. 36211 36223 36228 36229 36233 36238 36239 36243 36248 36253 36255 Description IP6 x 60mm IP7 x 60mm IP8 x 60mm IP9 x 60mm IP10 x 80mm IP15 x 80mm IP20 x 100mm IP25 x 100mm IP27 x 115mm IP30 x 115mm IP40 x 130mm Item No. Description Case Pack 36237 Ball End TORX® Driver Set 3 TORX: T9, T10, T15, T20, T25, T27, T30 Case Pack 10 10 10 10 10 10 10 10 10 Case Pack 3 3 3 3 Case Pack 10 10 10 10 10 10 10 10 10 10 10 TORXPlus® Cushion Grip Screwdriver - Clamshell Item No. 36214 36231 36232 36241 36242 36246 36247 36252 36262 36263 36265 Description IP6 x 60mm IP7 x 60mm IP8 x 60mm IP9 x 60mm IP10 x 80mm IP15 x 80mm IP20 x 100mm IP25 x 100mm IP27 x 115mm IP30 x 115mm IP40 x 130mm * Packaged in Clamshell In Clamshell 5 Pc. SoftFinish Screw Holding Screwdrivers Case Pack 10 10 10 10 10 10 10 TORXPlus® Cushion Grip Screwdriver Case Pack 10 10 10 5 Pc. Cushion Grip Metric Nut Driver Set Item No. 34504 34505 34506 34507 34508 Description T9 x 60mm T10 x 60mm T15 x 80mm T20 x 80mm T25 x 100mm T27 x 115mm T30 x 115mm 6 Pc. SoftFinish Cushion Grip TORX® Set Item No. Description 36201 TORX® Screwdriver Set TORX: T6, T8, T10, T15, T20, T25 Screw Holding MagicSpring TORX® Cushion Grip Screwdriver Heavy Duty Cushion Grip Inch Nut Drivers w/Hex Bolster Ball End TORX® Cushion Grip Screwdriver Item No. 36216 36217 36221 36222 36226 36227 36236 Case Pack 3 3 3 3 3 3 3 3 3 3 3 10 Pc. Cushion Grip Security TORX® Set Item No. Description Case Pack 36259 SoftFinish Screwdriver Set 1 Security TORX: T7s, T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s TORX® SoftFinish Cushion Grip Screwdriver Item No. 36264 36266 36268 36270 36272 36274 36276 36278 36280 36282 36284 36286 36288 Description T5 x 60mm T6 x 60mm T7 x 60mm T8 x 60mm T9 x 60mm T10 x 80mm T15 x 80mm T20 x 100mm T25 x 100mm T27 x 115mm T30 x 115mm T40 x 130mm T45 x 130mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 28 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA Screw Holding SoftFinish Cushion Grip MagicRing Ball End Hex Inch Screwdrivers 12 Pc. SoftFinish Cushion Grip TORX® Set Item No. Description Case Pack 36267 SoftFinish TORX® Driver Set 1 TORX: T5, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30, T40 8 Pc. TORXPlus® SoftFinish Cushion Grip Set Item No. Description 36297 SoftFinish Screwdriver Set TORXPlus: IP6, IP7, IP8, IP9, IP10, IP15, IP20, IP25 Case Pack 3 Item No. 36710 36713 36716 36719 36723 36726 36728 36732 36734 36736 36738 36742 36744 Description .050 x 3.1” 1/16” x 3.1” 5/64” x 3.9” 3/32” x 3.9” 7/64” x 3.9” 1/8” x 3.9” 9/64” x 3.9” 5/32” x 5.0” 3/16” x 6.0” 7/32” x 6.0” 1/4” x 6.0” 5/16” x 8.0” 3/8” x 8.0” Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 Screw Holding 8 Pc. MagicRing Hex Inch Cushion Grip Set Item No. Description Case Pack 36793 SoftFinish Driver Set 1 Inch: 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Screw Holding Security TORX® Cushion Grip Screwdriver Item No. 36269 36271 36273 36275 36277 36279 36281 36283 36285 36287 Description T7s x 60mm T8s x 60mm T9s x 60mm T10s x 80mm T15s x 80mm T20s x 100mm T25s x 100mm T27s x 115mm T30s x 115mm T40s x 130mm Case Pack 10 10 10 10 10 10 10 10 10 10 Screw Holding SoftFinish Cushion Grip 6 Pc. MagicRing Hex Inch Cushion Grip Set 7 Pc. Security TORX® Cushion Grip Set Item No. Description 36298 SoftFinish Screwdriver Set Security TORX: T7s, T8s, T9s, T10s, T15s, T20s, T25s Case Pack 3 Screw Holding MagicRing Ball End Hex Metric Screwdrivers Item No. 36715 36720 36725 36730 36740 36750 36760 36780 36786 Description 1.5 x 75mm 2.0 x 100mm 2.5 x 100mm 3.0 x 100mm 4.0 x 125mm 5.0 x 150mm 6.0 x 150mm 8.0 x 200mm 10.0 x 200mm Case Pack 10 10 10 10 10 10 10 10 10 Screw Holding 6 Pc. MagicSpring TORX® Cushion Grip Set Item No. Description 36290 SoftFinish Screwdriver Set TORX: T8, T10, T15, T20, T25, T30 Case Pack 3 6 Pc. TORX® SoftFinish Cushion Grip Set Case Pack 3 Case Pack 3 Case Pack 3 Flexible Shaft Inch Nut Drivers Cushion Grip Item No. 37220 37222 37226 37228 37230 Description 3/16 x 5.9” 1/4 x 5.9” 3/8 x 6.9” 7/16 x 6.9” 1/2” x 6.9” Case Pack 3 3 3 3 3 Item No. Description Case Pack 36790 SoftFinish Driver Set 1 Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm TORX® SoftFinish Cushion Grip Screwdriver Item No. 36364 36366 36368 36370 36372 36374 36376 36378 36380 36382 36384 36386 36388 Description T5 x 60mm T6 x 60mm T7 x 60mm T8 x 60mm T9 x 60mm T10 x 80mm T15 x 80mm T20 x 100mm T25 x 100mm T27 x 115mm T30 x 115mm T40 x 130mm T45 x 130mm Flexible Shaft Metric Nut Drivers Cushion Grip 9 Pc. MagicRing Hex Metric Cushion Grip Set Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 8 Pc. TORX® SoftFinish Cushion Grip Set Item No. Description 36294 SoftFinish Screwdriver Set TORX: T6, T8, T10, T15, T20, T25, T27, T30 Case Pack 3 7 Pc. TORXPlus® SoftFinish Cushion Grip Set Item No. Description 36299 SoftFinish Screwdriver Set TORXPlus: IP8, IP10, IP15, IP20, IP25, IP30, IP40 In Clamshell Item No. Description 36291 SoftFinish Screwdriver Set TORX: T6, T7, T8, T9, T10, T15 Item No. Description 36794 SoftFinish Driver Set Inch: 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Screw Holding Item No. 37235 37236 37237 37238 37239 37241 37244 Description 5.0 x 150mm 5.5 x 150mm 6.0 x 150mm 7.0 x 150mm 8.0 x 150mm 10.0 x 175mm 13.0 x 175mm Case Pack 3 3 3 3 3 3 3 13 Pc. MagicRing Hex Inch Cushion Grip Set Item No. Description Case Pack 36791 SoftFinish MagicRing Set 1 Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” In Clamshell 7 Pc. Flexible Shaft Metric Nut Driver Set Item No. Description Case Pack 37291 SoftFinish Nut Driver Set 1 Metric: 5.0, 5.5, 6.0, 7.0, 8.0, 10.0, 13.0mm Security TORX® Cushion Grip Screwdriver 6 Pc. TORXPlus® SoftFinish Cushion Grip Set Item No. Description Case Pack 36296 SoftFinish Screwdriver Set 3 TORXPlus: IP6, IP7, IP8, IP9, IP10, IP15 Item No. 36369 36371 36373 36375 36377 36379 36381 36383 36385 36387 Description T7s x 60mm T8s x 60mm T9s x 60mm T10s x 80mm T15s x 80mm T20s x 100mm T25s x 100mm T27s x 115mm T30s x 115mm T40s x 130mm Case Pack 3 3 3 3 3 3 3 3 3 3 Screw Holding 6 Pc. MagicRing Hex Metric Cushion Grip Set Item No. Description 36792 SoftFinish Driver Set Metric: 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm Case Pack 1 Magnetizer/Demagnetizer Item No. Description 40010 2.1” x 2.0” x 1.1” Case Pack 10 29 www.wihatools.com • USA | www.wihatools.ca • CANADA With Hex Bolster In Clamshell MicroFinish Non-Slip Grip Slotted Drivers Item No. Description 52005 4.0 x 100mm 52020 5.5 x 125mm Case Pack 10 10 Solid Metal Cap SoftFinish Cushion Grip Phillips Screwdrivers 5 Pc. Slotted/Phillips Cushion Grip Driver Set Item No. Description Case Pack 53075 SoftFinish Driver Set 3 Slotted: 4.5, 5.5, 6.5mm Phillips: #1, 2 Item No. 53131 53132 53133 Description 1 x 80mm 2 x 100mm 3 x 150mm Case Pack 3 3 3 Security Hex Metric Power Blade 90mm Item No. 76001 76002 76003 76004 Description 2.5 x 90mm 3.0 x 90mm 4.0 x 90mm 5.0 x 90mm Case Pack 3 3 3 3 Hex Inch Power Blade 90mm 7 Pc. Slotted & Phillips MicroFinish Driver Set Item No. Description Case Pack 52097 MicroFinish Screwdriver Set 3 Slotted: 4.0, 5.5, 8.0mm Phillips: #1x80, #1x200, #2x100, #2x200 Medium - 15.5” x 11” x 1.25” 10 Pc. SoftFinish® Heavy Duty Tray Set 5 Pc. Slotted/Phillips Cushion Grip Driver Set Item No. Description Case Pack 53090 SoftFinish Driver Set 3 Slotted: 5.5, 6.5, 8.0mm & Phillips: #1, 2 Item No. 53310 53315 53320 53325 53330 Description 4.5 x 90mm 5.5 x 100mm 6.5 x 125mm 8.0 x 150mm 10.0 x 175mm Case Pack 10 10 10 10 10 6 Pc. Slotted/Phillips Cushion Grip Driver Set MicroFinish 1/4” Bit Holding Screwdriver Item No. Description Case Pack 53096 SoftFinish Driver Set 3 Slotted: 3.5, 4.5, 5.5, 6.5mm & Phillips: #1, 2 Security TORX Power Blade 90mm Item No. 76008 76009 76010 76015 76020 76025 76027 76030 76040 Description T8s x 90mm T9s x 90mm T10s x 90mm T15s x 90mm T20s x 90mm T25s x 90mm T27s x 90mm T30s x 90mm T40s x 90mm Case Pack 3 3 3 3 3 3 3 3 3 Case Pack 10 5 Pc. Slotted/Phillips MicroFinish Driver Set Item No. Description 53390 Non-Slip Grip Driver Set Slotted: 5.5, 6.5, 8.0mm Phillips: #1, 2 MicroFinish Non-Slip Grip TORX Screwdrivers ® Item No. 52713 52716 52719 52722 Case Pack 3 3 3 3 3 3 3 3 3 3 With Hex Bolster MicroFinish Non-Slip Grip Slotted Drivers Case Pack 10 Item No. Description 52650 1/4” x 125mm Description 1/16 x 90mm 5/64 x 90mm 3/32 x 90mm 7/64 x 90mm 1/8 x 90mm 9/64 x 90mm 5/32 x 90mm 3/16 x 90mm 7/32 x 90mm 1/4 x 90mm Solid Metal Cap MicroFinish Non-Slip Grip Phillips Drivers Item No. Description 52125 3 x 150mm Item No. Description Case Pack 53180 Extra Heavy Duty Screwdrivers 1 Slotted: 3.5, 4.5, 5.5, 6.5, 8.0, 10.0, 12.0mm Phillips: #1, 2, 3 Item No. 76045 76005 76006 76007 76014 76016 76017 76018 76019 76021 Description T10 x 80mm T15 x 80mm T20 x 100mm T25 x 100mm Case Pack 10 10 10 10 Case Pack 3 Pozidriv® Power Blade 90mm Item No. 76011 76012 76013 Description 1 x 90mm 2 x 90mm 3 x 90mm Case Pack 3 3 3 7 Pc. Slotted/Phillips Cushion Grip Driver Set Item No. Description Case Pack 53097 SoftFinish Driver Set 1 Slotted: 5.5, 6.5, 8.0, 10.0mm & Phillips: #1, 2, 3 Spanner Power Blade 90mm With Hex Bolster In Clamshell Solid Metal Cap 8 Pc. Slotted/Phillips MicroFinish Driver Set SoftFinish Cushion Grip Slotted Screwdrivers Item No. 53001 53002 53003 53004 53005 53006 53007 Description 3.5x75mm (Clamshell) 4.5x90mm (Clamshell) 5.5x100mm (Clamshell) 6.5x125mm (Clamshell) 8.0x150mm (Clamshell) 10.0x175mm (Clamshell) 12.0x200mm (Clamshell) Case Pack 3 3 3 3 3 3 3 With Hex Bolster Item No. Description 53398 Non-Slip Grip Driver Set Slotted: 4.5, 5.5, 6.5, 8.0, 10.0mm Phillips: #1, 2, 3 Item No. 53010 53015 53020 53025 53027 53035 53040 Description 3.5 x 75mm 4.5 x 90mm 5.5 x 100mm 6.5 x 125mm 8.0 x 150mm 10.0 x 175mm 12.0 x 200mm Case Pack 10 10 10 10 10 10 10 Description 6 x 90mm 8 x 90mm 10 x 90mm Case Pack 3 3 3 Case Pack 1 Tri-Wing Power Blade 90mm With Hex Bolster 10 Pc. Slotted/Phillips Cushion Grip Driver Set Item No. Description Case Pack 53099 SoftFinish Driver Set 1 Slotted: 3.5, 4.5, 5.5, 6.5, 8.0, 10.0, 12.0mm Phillips: #1, 2, 3 Solid Metal Cap SoftFinish Cushion Grip Slotted Screwdrivers Item No. 76022 76023 76024 Solid Metal Cap MicroFinish Non-Slip Grip Phillips Drivers Item No. 53405 53410 53425 Description 1 x 80mm 2 x 100mm 3 x 150mm Item No. 76031 76032 76033 76034 Description 1 x 90mm 2 x 90mm 3 x 90mm 4 x 90mm Item No. 76035 76036 76037 76038 76039 Description 2.5 x 90mm 3.0 x 90mm 4.5 x 90mm 5.5 x 90mm 6.0 x 90mm Case Pack 3 3 3 3 Case Pack 10 10 10 With Hex Bolster Slotted Power Blade 90mm Solid Metal Cap SoftFinish Cushion Grip Phillips Screwdrivers Item No. 53110 53115 53120 Description 1 x 80mm 2 x 100mm 3 x 150mm Case Pack 10 10 10 CentroFix Blade Holding Screwdriver Item No. Description 76000 6.0mm x 149mm Case Pack 3 Case Pack 3 3 3 3 3 30 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA Phillips Power Blade 90mm Item No. 76041 76042 76043 76044 Description 0 x 90mm 1 x 90mm 2 x 90mm 3 x 90mm Case Pack 3 3 3 3 4 Pc. Security Hex Metric Power Blades 90mm 10 Pc. Security Hex Inch Power Blades 90mm Item No. Description Case Pack 76090 Sec. Hex Power Blades 3 Sec. Hex: 2.5, 3.0, 4.0, 5.0mm x 90mm Item No. Description Case Pack 76096 Sec. Hex Power Blades 3 Standard Hex: 1/16” x 90mm Security Hex: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” x 90mm 22 Pc. Power Blade Inch/Metric Nut Driver Set Security Hex Inch Power Blade 90mm Item No. 76045 76046 76047 76048 76049 76050 76051 76052 76053 76054 Description 1/16 x 90mm (hex) 5/64 x 90mm 3/32 x 90mm 7/64 x 90mm 1/8 x 90mm 9/64 x 90mm 5/32 x 90mm 3/16 x 90mm 7/32 x 90mm 1/4 x 90mm Item No. 76056 76057 76058 Description 1 x 90mm 2 x 90mm 3 x 90mm Case Pack 3 3 3 3 3 3 3 3 3 3 Square Power Blade 90mm Case Pack 3 3 3 Item No. Description Case Pack 76084 Power Blade Set 1 Inch Nut Drivers: 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2” Metric Nut Drivers: 4.0, 4.5, 5.0, 5.5, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0mm CentroFix Cushion Grip Blade Holder 9 Pc. Security Hex Inch Power Blades 90mm 3 Pc. Pozidriv® Power Blades 90mm Item No. Description 76091 Pozidriv® Power Blades Pozidriv®: 1, 2, 3 x 90mm Item No. Description 76097 Hex Power Blades Hex: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Case Pack 3 Case Pack 3 9 Pc. Power Blade Inch Nut Driver Set Item No. Description Case Pack 76085 Power Blade Set 3 Inch Nut Drivers: 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2” 36 Pc. Security Power Blade Set 90mm 9 Pc. Security TORX Power Blades 90mm Item No. Description Case Pack 76092 Sec. TORX Power Blades 3 Security TORX: T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s x 90mm Item No. Description Case Pack 76098 Security Power Blade Set 1 Slotted: 2.5, 3.0, 4.5, 5.5, 6.0mm & Pozidriv®: 1, 2, 3 Phillips: 0, 1, 2, 3 & Square: 1, 2, 3 Tri-Wing: 1, 2, 3, 4 & Spanner: 6, 8, 10 Security Hex Metric: 2.5, 3.0, 4.0, 5.0mm Security TORX: T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s CentroFix Cushion Grip Blade Holder Power Blade Inch Nut Drivers 100mm Item No. 76059 76060 76061 76062 76063 76064 76065 76066 76067 Description 3/16” x 100mm 7/32” x 100mm 1/4” x 100mm 9/32” x 100mm 5/16” x 100mm 11/32” x 100mm 3/8” x 100mm 7/16” x 100mm 1/2” x 100mm Case Pack 3 3 3 3 3 3 3 3 3 12 Pc. Power Blade Inch/Metric Nut Driver Set Item No. Description Case Pack 76086 Power Blade Set 3 Metric Nut Drivers: 4.0, 4.5, 5.0, 5.5, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0mm 5 Pc. Slotted Power Blades 90mm Item No. Description 76093 Slotted Power Blades Slotted: 2.5, 3.0, 4.5, 5.5, 6.0 x 90mm Case Pack 3 37 Pc. Power Blade Set 90mm Power Blade Metric Nut Drivers 100mm Item No. 76068 76069 76070 76071 76072 76073 76074 76075 76076 76077 76078 76080 Description 4.0mm x 100mm 4.5mm x 100mm 5.0mm x 100mm 5.5mm x 100mm 6.0mm x 100mm 7.0mm x 100mm 8.0mm x 100mm 9.0mm x 100mm 10.0mm x 100mm 11.0mm x 100mm 12.0mm x 100mm 13.0mm x 100mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 4 Pc. Tri-Wing Power Blades 90mm Item No. Description 76088 Tri-Wing Power Blades Tri-Wing: 1, 2, 3, 4 x 90mm Case Pack 3 3 Pc. Spanner Power Blades 90mm Item No. Description 76089 Spanner Power Blades Spanner: 6, 8, 10 x 90mm Belt Wallet For Power Blades 90mm Item No. Description Case Pack 76079 Belt Wallet 1 7.125” x 14.75” (open) - Holds 38 Pieces Case Pack 3 4 Pc. Phillips Power Blades 90mm Item No. Description 76094 Phillips Power Blades Phillips: 0, 1, 2, 3 x 90mm Case Pack 3 3 Pc. Square Power Blades 90mm Item No. Description 76095 Square Power Blades Square: 1, 2, 3 x 90mm Case Pack 3 Item No. Description Case Pack 76099 Power Blade Set 1 Slotted: 2.5, 3.0, 4.5, 5.5, 6.0mm & Pozidriv®: 1, 2, 3 Phillips: 0, 1, 2, 3 & Square: 1, 2, 3 Standard Hex Inch: 1/16” & Security Hex Inch: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Security TORX: T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s & Magnetic Nut Setters: 1/4”, 5/16”, 3/8” CentroFix Cushion Grip Blade Holder 31 www.wihatools.com • USA | www.wihatools.ca • CANADA Precision Inch & Metric Hex Screwdrivers 50 Pc. Master Technicians Bench Top Set 6inOne SoftFinish Multi-Driver Set Item No. Description 77890 Multi-Driver Screwdriver Slotted: 3/16, 1/4” Phillips: #1, 2 Nut Driver: 1/4, 5/16” Case Pack 6 Item No. Description Case Pack 92189 Precision Tool Set 1 Pentalobe: PL1, PL2, PL3, PL4 Slotted: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: #000, 00, 0, 1 TORX: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Hex Metric: 1.27, 1.5, 2.0, 2.5, 3.0mm Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Nut Drivers: 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm 26810 Chip Lifter Item No. 96307 96309 96313 96315 96316 96320 96323 96325 96327 96330 96331 Description .71(.028”) x 40mm .89(.035”) x 40mm 1.27(.050”) x 40mm 1.5mm x 50mm 1/16” x 50mm 2.0(5/64”) x 50mm 3/32” x 60mm 2.5mm x 60mm 7/64” x 60mm 3.0mm x 60mm 1/8” x 60mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 50 Pc. Master Technicians Bench Top Set Item No. Description Case Pack 92190 Precision Tool Set 1 Slotted: .8, 1.0, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: #000, 00, 0, 1 TORX: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Hex Metric: 1.27, 1.5, 2.0, 2.5, 3.0mm Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Nut Drivers: 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm 26810 Chip Lifter 11inOne SoftFinish Multi-Driver Set Item No. Description 77891 Multi-Driver Screwdriver Slotted: 3/16, 1/4” & Phillips: #1, 2 Square: #1, 2 & TORX: T20, T25 Nut Driver: 1/4, 5/16” Case Pack 6 Precision Inch & Metric Ball End Hex Drivers Item No. 96413 96415 96416 96419 96420 96423 96425 96427 96430 96431 96436 96439 Description 1.27(.050”) x 40mm 1.5mm x 50mm 1/16” x 50mm 5/64” x 50mm 2.0mm x 50mm 3/32” x 50mm 2.5mm x 60mm 7/64” x 60mm 3.0 x 60mm 1/8” x 60mm 9/64” x 60mm 5/32” x 60mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 51 Pc. Precision Tool Tray Set Item No. Description Case Pack 92191 Precision Tool Set 1 Slotted: .8, 1.0, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: #000, 00, 0, 1 TORX: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Hex Metric: 1.27, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Nut Drivers: 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm 26810 Chip Lifter Conduit Reamer & 6inOne Multi-Driver Set Item No. Description Case Pack 77890 SoftFinish Multi-Driver 3 Slotted: 3/16, 1/4” & Phillips: #1, 2 Nut Driver: 1/4, 5/16” Conduit Reamer Reams: 1/2”, 3/4”, 1” Rugged Polyester Canvas Storage Pouch Item No. Description 91118 Holds 8 Prec. Tools Case Pack 3 Precision Slotted Drivers In Blister Package Item No. 96008 96010 96012 96015 96018 96020 96025 96030 96035 96040 Description .8 x 40mm 1.0 x 40mm 1.2 x 40mm 1.5 x 40mm 1.8 x 40mm 2.0 x 40mm 2.5 x 50mm 3.0 x 50mm 3.5 x 60mm 4.0 x 60mm Case Pack 3 3 3 3 3 3 3 3 3 3 Precision Phillips Drivers In Blister Package Item No. 96100 96102 96105 96110 Description 00 x 40mm 000 x 40mm 0 x 50mm 1 x 60mm Case Pack 3 3 3 3 Precision Inch & Metric Nut Drivers Item No. Description Metric 96510 1.5 x 60mm 96515 1.8 x 60mm 96520 2.0 x 60mm 96525 2.5 x 60mm 96530 3.0 x 60mm 96535 3.5 x 60mm 96540 4.0 x 60mm 96545 4.5 x 60mm 96550 5.0 x 60mm 96555 5.5 x 60mm 96560 6.0 x 60mm 96570 7.0 x 60mm Inch 96523 3/32 x 60mm 96527 7/64 x 60mm 96531 1/8 x 60mm 96536 9/64 x 60mm 96539 5/32 x 60mm 96547 3/16 x 60mm 96556 7/32 x 60mm 96563 1/4 x 60mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Precision TORX® Drivers In Blister Package Item No. 96703 96704 96705 96706 96707 96708 96709 96710 96715 96720 Description T3 x 40mm T4 x 40mm T5 x 40mm T6 x 40mm T7 x 40mm T8 x 40mm T9 x 50mm T10 x 50mm T15 x 60mm T20 x 60mm Case Pack 3 3 3 3 3 3 3 3 3 3 32 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA ESD Safe Tools For working on static sensitive electronic components ESD standard IEC 61340-5-1 Drive-Loc VI In Durable Pouch ESD Safe Precision Slotted Screwdrivers Item No. 27224 27228 27234 27238 27243 Description 2.0 x 150mm 2.5 x 150mm 3.0 x 150mm 3.5 x 150mm 4.0 x 150mm Case Pack 10 10 10 10 10 D D Item No. Description 27392 Slotted & Phillips Drivers Slotted: 1.5, 2.0, 2.5, 3.5mm Phillips: #00, 0, 1 4 Pc. ESD Safe Interchangeable Blade Set Item No. Description Case Pack 10891 ESD Safe Interchangeable Set 3 Slotted: 3.0, 4.0, 6.0mm & Phillips: #0, 1, 2 ESD Safe Handle - 135mm 8 Pc. ESD Safe PicoFinish Precision Set 7 Pc. ESD Safe PicoFinish Precision Set Case Pack 3 Item No. Description 27396 Slotted & Phillips Drivers Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: #000, 00, 0, 1 Case Pack 3 ESD Safe PicoFinish Precision Slotted Driver Drive-Loc VI In Durable Pouch 8 Pc. ESD Safe Interchangeable Blade Set Item No. Description Case Pack 10892 ESD Safe Interchangeable Set 3 Metric Nut Drivers: 5.0 - 10.0mm ESD Safe Handle - 135mm Item No. 27270 27271 27272 27273 27274 27275 27276 27277 27278 27279 27280 27281 Description .8 x 40mm 1.0 x 40mm 1.2 x 40mm 1.5 x 40mm 2.0 x 40mm 2.0 x 100mm 2.5 x 50mm 2.5 x 100mm 3.0 x 50mm 3.0 x 100mm 3.5 x 60mm 4.0 x 60mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 Drive-Loc VI In Durable Pouch Case Pack 10 10 Item No. Description Case Pack 10895 ESD Safe Interchangeable Set 3 Slotted: 3.0, 4.0, 6.0mm & Phillips: #0, 1, 2 Inch Nut Drivers: 3/16 - 1/2” ESD Safe Handle - 135mm Case Pack 10 10 10 10 10 10 10 10 ESD Safe PicoFinish Precision Hex MM Driver 11 Pc. ESD Safe PicoFinish Precision Set ESD Safe PicoFinish Precision Phillips Driver 11 Pc. ESD Safe Interchangeable Blade Set Item No. Description Case Pack 27393 ESD Slotted/Phillips Drivers 3 Slotted: 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: #0, 1 Description 0.028 x 40mm 0.035 x 40mm 0.05 x 40mm 1/16 x 50mm 5/64 x 50mm 3/32 x 50mm 7/64 x 60mm 1/8 x 60mm ESD Safe Precision Phillips Screwdrivers Item No. Description 27316 0 x 150mm 27326 1 x 150mm 5 Pc. ESD Safe Interchangeable Blade Set In Durable Pouch 7 Pc. ESD Safe Precision Screwdriver Set D Item No. Description Case Pack 10893 ESD Safe Interchangeable Set 3 TORX: T6, T7, T8, T9, T10, T15, T20, T25 ESD Safe Handle - 135mm Drive-Loc VI ESD Safe PicoFinish Precision Hex Inch Driver Item No. 27550 27551 27552 27557 27554 27558 27559 27560 Item No. 27330 27331 27332 27333 27334 27335 Description 000 x 40mm 00 x 40mm 0 x 50mm 0 x 100mm 1 x 60mm 1 x 100mm Item No. Description Case Pack 27394 Smartphone Pico Set 3 Slotted: 1.5mm & Phillips: #000, 00, 0 TORX: T3, T4, T5, T6 & Pentalobe: PL1 Y-Type: #0 & Flat Tweezers: PSF SA ESD Long Case Pack 10 10 10 10 10 10 Item No. 27550 27551 27552 27553 27554 27555 27556 Description 0.7 x 40mm 0.9 x 40mm 1.3 x 40mm 1.5 x 50mm 2.0 x 50mm 2.5 x 60mm 3.0 x 60mm Case Pack 10 10 10 10 10 10 10 ESD standard IEC 61340-5-1 D Static Dissipative ESD standard IEC 61340-5-1 7 Pc. ESD Safe PicoFinish Precision Set Item No. Description Case Pack 27589 Hex Metric Drivers 3 Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0mm 33 www.wihatools.com • USA | www.wihatools.ca • CANADA ESD Safe PicoFinish Precision Inch Nut Driver Item No. 27770 27771 27772 27773 27774 27775 27776 27777 Description 3/32 x 60mm 7/64 x 60mm 1/8 x 60mm 9/64 x 60mm 5/32 x 60mm 3/16 x 60mm 7/32 x 60mm 1/4 x 60mm Case Pack 10 10 10 10 10 10 10 10 ESD Safe PicoFinish Precision TORX® Driver Item No. 27860 27861 27862 27863 27864 27865 27866 27867 27868 27869 27870 27871 Description T1 x 40mm T2 x 40mm T3 x 40mm T4 x 40mm T5 x 40mm T6 x 40mm T7 x 40mm T8 x 40mm T9 x 50mm T10 x 50mm T15 x 60mm T20 x 60mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 ESD Safe Cushion Grip Phillips Screwdrivers Item No. 31150 31151 31152 Description 0 x 60mm 1 x 80mm 2 x 100mm Case Pack 10 10 10 ESD Safe Universal Fine Point Tweezers Item No. Description 44501 AA SA ESD - 130mm Case Pack 3 ESD Long Narrow Body Low Force Tweezers Item No. Description 44503 SS SA ESD - 135mm Case Pack 3 D ESD Reduced Body To Medium Point Tweezers ESD Safe PicoFinish Precision MM Nut Driver Item No. 27780 27781 27782 27783 27784 27785 27786 27787 27788 Description 1.5 x 60mm 2.0 x 60mm 2.5 x 60mm 3.0 x 60mm 3.5 x 60mm 4.0 x60mm 4.5 x 60mm 5.0 x 60mm 5.5 x 60mm Case Pack 10 10 10 10 10 10 10 10 10 11 Piece ESD Safe Precision Set D 7Pc. ESD Safe PicoFinish Precision Set Item No. Description 27892 TORX® Drivers TORX®: T4, T5, T6, T7, T8, T9, T10 Case Pack 3 Item No. Description 32794 Pliers & PicoFinish Drivers Slotted: 2.0, 2.5, 3.0, 3.5mm Phillips: #00, 0, 1 5.25” Diagonal Cutters 4.5” Flush Tapered Cutters 4.75” Short Snipe Nose Pliers 5.75” Long Needle Nose Pliers ESD Tweezers Flat Round Tip Smooth Sides Item No. Description 44505 2a SA ESD - 120mm ESD Safe TORX® Cushion Grip Screwdriver 8Pc. ESD Safe PicoFinish Precision Set Item No. Description Case Pack 27789 Metric Nut Drivers 3 Metric: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0, 5.0, 5.5mm ESD Safe PicoFinish Precision Chip Lifter Item No. Description 27922 3.5mm x 50mm Case Pack 3 Case Pack 3 ESD Fine Round Points For Assembly Tweezers Case Pack 3 D Case Pack 3 Case Pack 1 ESD Safe PicoFinish Precision Chip Lifter Item No. Description 27921 3.5mm x 50mm Item No. Description 44504 2 SA ESD - 120mm Item No. 36200 36204 36206 36208 36209 36218 36219 36224 36260 Description T5 x 60mm T4 x 60mm T6 x 60mm T8 x 60mm T9 x 60mm T10 x 80mm T15 x 80mm T20 x 100mm T3 x 60mm Case Pack 10 10 10 10 10 10 10 10 10 Item No. Description 44506 3 SA ESD - 120mm Case Pack 3 ESD Safe Fine Round Points Shorter Tweezers Item No. Description 44507 3c SA ESD - 110mm Case Pack 3 ESD Safe Cushion Grip Slotted Screwdrivers Item No. 30240 30242 30244 30246 30248 D Description 2.5 x 75mm 3.0 x 100mm 4.0 x 100mm 5.5 x 125mm 6.5 x 150mm Case Pack 10 10 10 10 10 ESD Safe Very Fine Points/Tapered Tweezers Item No. Description 44508 4 SA ESD - 110mm 8Pc. ESD Safe PicoFinish Precision Set 6 Pc. ESD Safe Cushion Grip TORX® Set Item No. Description Case Pack 27792 Inch Nut Drivers 3 Inch: 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Item No. Description Case Pack 36289 SoftFinish TORX® Driver Set 3 TORX: T6, T8, T9, T10, T15, T20 Case Pack 3 ESD Safe Extra Fine Points/Tapered Tweezers Item No. Description 44509 5 SA ESD - 110mm Case Pack 3 6 Pc. ESD Safe Cushion Grip Screwdriver Set Item No. Description Case Pack 30292 Slotted & Phillips Driver Set 3 Slotted: 3.0, 4.0, 5.5mm Phillips: #0, 1, 2 ESD Safe Curved Extra Fine Rounded Tweezers Item No. Description 44510 7a SA ESD - 110mm Case Pack 3 34 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA D ESD Safe Wafer Tweezers ESD Narrow Rounded Tip Serrated w/Guide Pins Item No. Description 44518 22 SA ESD - 110mm Case Pack 3 ESD Safe Universal Blunt Tip Serrated Tweezers Item No. Description 44520 40 SA ESD - 145mm Case Pack 3 ESD Long Flat to 1.0mm Wide No Serration Item No. Description 44523 PSF SA ESD - 125mm Case Pack 3 Item No. Description 55538 72a SA - 26 Piece ESD Safe Precision Set Item No. Description Case Pack 45892 Pliers & PicoFinish Drivers 1 Slotted: 2.0, 2.5, 3.0, 3.5mm Phillips: #00, 0, 1 5.25” Diagonal Cutters 4.5” Flush Tapered Cutters 4.75” Short Snipe Nose Pliers 5.75” Long Needle Nose Pliers 4mm Micro Bits: Hex: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0mm Torx®: T4, T5, T6, T7, T9, T10 Precision Bit Holder & Micro Bit Extension ESD Safe Tweezer: 00 SA ESD 120mm Heavy Duty Strong, Tapered To Strong Point ESD Safe Very Fine Points 40° Tapered To Tip Item No. Description 55539 4b SA - 110mm ESD Curved Extra Fine, 3mm long Straight Case Pack 3 Case Pack 3 ESD Safe 9mm Wide With Back Stop Pins Item No. Description 55546 89 SA - 125mm Item No. Description 44525 7abb SA-SMD-120mm Case Pack 3 Case Pack 3 ESD Safe MicroTip 30° Bend & 0.5mm Slot Item No. Description 55531 11SA SMD - 117mm Case Pack 3 ESD Safe Angled 12mm Wide Flat, Back Stop S ESD Extra Fine Points Bent 30°-3mm Long Item No. Description 44528 5bb SA ESD - 107mm Case Pack 3 Item No. Description 55547 91 SA - 125mm Case Pack 3 ESD Safe Blunt Tips - 1.0mm Wide Serrated Item No. Description 55533 PSF SA-ESD S-125mm Case Pack 3 Surface resistance of handles is 106 - 109 Ohms ESD Safe General Purpose Fine Point Item No. Description 44531 1 SA ESD - 120mm Case Pack 3 ESD Safe Flat and Broad Tips 3mm Wide Item No. Description 55534 F SA - 120mm Case Pack 3 ESD Safe PicoFinish Precision Bit Holder Item No. Description 75804 Case Pack 3 ESD standard IEC 61340-5-1 ESD Hvy. Duty Strong Tapered to Strong Point Item No. Description 44532 00 SA ESD - 120mm Case Pack 3 ESD Safe Straight & 0.5mm Slot Milled Item No. Description 55535 8ab SA SMD - 120mm Case Pack 3 ESD Safe 30° Bent & Angled With 0.5 Slot Item No. Description 55536 19 SA SMD - 120mm Case Pack 3 10 Pc. ESD Safe Tweezers Set Item No. Description Case Pack 44593 ESD Safe Tweezers 1 AA SA Fine Point, 2a SA Flat Round Tip, 3 SA Round Point, 3c SA Fine Round Points Shorter, 4 SA Very Fine Points, 7a SA Curved Extra Fine, PSF SA Flat 1.0mm Wide, 7abb SA Curved Extra Fine, 5bb SA Extra Fine Bent, 4b SA Very Fine Point 40 ESD Safe 30° Bent & Angled With 0.5 Slot Item No. Description 55537 R10 SA SMD - 117mm Case Pack 3 50 Pc. ESD PicoFinish Bench Top Set Item No. Description Case Pack 92093 ESD Safe Precision Tool Set 1 Slotted: .8, 1.0, 1.2, 1.5, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: #000, 00, 0, 1 TORX: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T15, T20 Hex Metric: .71, .89, 1.27, 1.5, 2.0, 2.5, 3.0mm Hex Inch: 1/16, 3/32, 7/64, 1/8” Metric Nut Drivers: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm & Inch Nut Drivers: 1/8, 5/32, 3/16, 1/4” 3.5mm Chip Lifter 35 www.wihatools.com • USA | www.wihatools.ca • CANADA Standard & Impact Bits and Nut Setters Exact fit precision machined tip for reduced cam-out 1/4” Bits Magnetic 1/4” Stubby Bit Holder Cushion Grip Item No. Description 28103 1/4” x 57mm Case Pack 3 7 Pc. Slotted/Phillips/Pozidriv® Stubby Set Item No. Description 38043 Cushion Grip Bit Holder Slotted: 4.5, 6.0mm & Phillips: #1, 2 Pozidriv: #1, 2 Case Pack 3 In Clamshell 13 Piece Pop-Up Security Hex Bit Set 1/4” Magnetic Bit Holding Cushion Grip Driver Item No. Description Case Pack 38049 Pop-Up Set - 1/4” Bits 3 Hex Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0mm Hex Inch: 5/64, 3/32, 1/8, 5/32, 3/16, 1/4” Item No. Description Case Pack 38451 1/4” x 125mm - In Clamshell 3 With Ring Retainer ESD Safe 1/4” Stubby Bit Holder Cushion Grip Item No. Description 28180 1/4” x 57mm Case Pack 3 13 Piece Pop-Up TORX® Bit Set Item No. Description Case Pack 38044 Pop-Up Set - 1/4” Bits 3 TORX: T5, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 & T40 7 Pc. Ball End Hex Inch Stubby Bit Holder Set Item No. Description 38056 Cushion Grip Bit Holder Inch: 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Case Pack 3 7 Pc. Hex Metric Stubby Bit Holder Set Item No. Description 38057 Cushion Grip Bit Holder Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0mm Case Pack 3 12 Pc. Computer Tech 1/4” Bit Set Item No. Description Case Pack 38490 Cushion Grip Bit Holders 3 Slotted: 4.5, 5.5, 6.5mm & Phillips: #1, 2 ® TORX : T6, T15, T20 Security TORX®: T8s, T10s Magnetic Bit holder 1/4” x 125mm Stubby Bit Holder 1/4” x 57mm 13 Pc. Slotted/Phillips/TORX® Pop-Up Set Item No. Description Case Pack 38032 Pop-Up Set - 1/4” Bits 3 Slotted: 4.5, 5.5, 6.0mm & Phillips: #1, 2, 34 TORX: T10, T15, T20, T25, T27, T30 7 Pc. TORX® Stubby Bit Holder Set Item No. Description 38045 Cushion Grip Bit Holder TORX: T8, T10, T15, T20, T25, T30 Case Pack 3 7 Pc. Hex Inch Stubby Bit Holder Set Item No. Description 38058 Cushion Grip Bit Holder In: 3/16, 5/32, 9/64, 1/8, 7/64, 3/32” Case Pack 3 Flexible Shaft Retaining Ring 1/4” Bit Holder Item No. Description 38600 1/4” x 150mm Case Pack 3 ESD Safe Quick Release 1/4” Bit Holder 12 Piece Pop-Up Bit Set 13 Piece Pop-Up Security TORX® Bit Set Item No. Description Case Pack 38041 Pop-Up Set - 1/4” Bits 3 Slotted: 4.5, 6.0mm & Phillips: #1, 2 & Square: #1, 2 TORX: T20, T25, T30 & Hex: 4.0, 5.0, 6.0mm Item No. Description 38046 Pop-Up Set - 1/4” Bits TORX: T5, T6 Security TORX: T7s, T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s & T40s Case Pack 3 72 Tooth Ratchet / SlimFix / Phillips Bit Set 7 Pc. Security TORX® Stubby Bit Holder Set 14inOne Slotted/Phillips/Square Multi-Bit Set Item No. Description Case Pack 38035 Pop-Up Set - 1/4” Bits 3 Slotted: 4.5, 5.5, 6.5mm & Phillips: #0, 1, 2 TORX: T6, T15, T20, T25 & Security TORX: T8s, T10s Item No. Description Case Pack 38047 Cushion Grip Bit Holder 3 Security TORX: T8s, T10s, T15s, T20s, T25s, T30s Item No. Description Case Pack 38090 Cushion Grip Bit Holder 3 Slotted: 3.0+4.5, 4.0+6.0, 5.5+6.5mm Phillips: #0+3, #1+2 Square: #0+3, #1+2 7 Pc. Slotted/Phillips/Square Stubby Set 1/4” Magnetic Bit Holding Cushion Grip Driver 13 Pc. Pop-Up Security TORX® Set-75mm Bits Case Pack 10 Item No. Description 38048 Cushion Grip Bit Holder Slotted: 4.5, 6.0mm & Phillips: #1, 2 Square: #1, 2 Case Pack 3 Case Pack 3 Item No. Description Case Pack 38060 Mini Ratchet/SlimFix Set 3 Mini Bit Ratchet, SlimFix, Phillips: #2 13 Piece Pop-Up Bit Set Item No. Description 38042 Pop-Up Set - 1/4” Bits Security TORX: TR10, TR15, TR20, TR25, TR27 & TR30 Item No. Description 38701 1/4” x 148mm Item No. Description 38450 1/4” x 125mm 38460 1/4” x 300mm Case Pack 10 10 20Pc. ESD Safe 1/4” Quick Release Holder Set Item No. Description 38790 ESD Blade & Bit Holder Set Slotted: 2.5, 3.0, 3.5, 4.0, 5.5, 6.5mm Phillips: #0, 1, 2 & Pozidriv: #0, 1, 2 TORX: T6, T7, T8, T9, T10, T15 Case Pack 3 1/4” T-handle Bit Holder Item No. Description 38800 1/4” x 150mm Case Pack 10 36 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA 2” Bits 10 Pack Security TORX® 1/4” Insert Bits - 10 Pack Comfort Grip T-handle Double End Bit Holder Item No. Description 38801 1/4” x 178mm Case Pack 10 With retail tag for hanging Comfort Grip T-handle Double End Bit Holder Item No. Description 38802 1/4” x 178mm Case Pack 3 Item No. 70127 70128 70129 70135 70139 70142 70148 70160 70163 70168 Description T7s x 25mm T8s x 25mm T9s x 25mm T10s x 25mm T15s x 25mm T20s x 25mm T25s x 25mm T27s x 25mm T30s x 25mm T40s x 25mm Case Pack 3 3 3 3 3 3 3 3 3 3 TerminatorBlue 1/4” Impact Bits - 15 Bit Pack Item No. 70242 70260 70265 Description Phillips #2 - 15 Bits TORX T25 - 15 Bits Square #2 - 15 Bits Case Pack 6 6 6 5/16” Hex Inch Standard Nut Setters Item No. 70468 70469 70470 70472 Description 2.5” OAL 4.0” OAL 6.0” OAL 12.0” OAL Case Pack 3 3 3 3 3/8” Hex Inch Standard Nut Setters TerminatorBlue 1/4” Impact Bits - 5 Bit Pack Item No. 70269 70277 70279 70282 2 Bit Pack TerminatorBlue 1/4” Impact Bits - 2 Bit Pack Item No. 70002 70020 70025 Description Phillips #2 - 1” Bits TORX T25 - 1” Bits Square #2 - 1” Bits Case Pack 6 6 6 Description Phillips #2 - 2” Bits TORX T25 - 2” Bits TORX T30 - 2” Bits Square #2 - 2” Bits Case Pack 6 6 6 6 Item No. 70474 70476 70477 70479 Description 2.5” OAL 4.0” OAL 6.0” OAL 12.0” OAL Case Pack 3 3 3 3 XZN 1/4” Insert Bits - Triple Square - 2 Pack Item No. 70144 70145 70146 70147 Description M4 x 25mm M5 x 25mm M6 x 25mm M8 x 35mm/1-1/3” Case Pack 3 3 3 3 TerminatorBlue 7 Pc. 2” BitBuddy Item No. Description 70298 Bit Seletor Set Phillips: #1, 2 & Square: #1, 2 TORX: T20, T25, T30 1” Bits TerminatorBlue 1/4” Impact Bits - 20 Bit Pack Item No. 70042 70060 70065 Description Phillips #2 - 20 Bits TORX T25 - 20 Bits Square #2 - 20 Bits Case Pack 6 6 6 Universal Magnetic Bit Holder Item No. Description 70096 1/4 x 2.4” Case Pack 6 2 Bit Pack Security TORX® 1/4” Insert Bits - 2 Bit Pack Item No. 70150 70151 70152 70153 70154 70155 70156 70157 70158 70159 Description T7s x 25mm T8s x 25mm T9s x 25mm T10s x 25mm T15s x 25mm T20s x 25mm T25s x 25mm T27s x 25mm T30s x 25mm T40s x 25mm Case Pack 3 3 3 3 3 3 3 3 3 3 Case Pack 10 TerminatorBlue 1/4” Impact Bits - 2 Bit Pack Item No. 70302 70319 70320 70322 70325 Color Coded Magnetic Nut Setters Item No. 70480 70482 70483 70484 70485 Description Phillips #2 - 3.5” Bits TORX T20 - 3.5” Bits TORX T25 - 3.5” Bits TORX T30 - 3.5” Bits Square #2 - 3.5” Bits Case Pack 6 6 6 6 6 Description 1/4” x 6“ (red) 3/8” x 6“ (blue) 7/16” x 6“ (brown) 1/2” x 6“ (orange) 9/16” x 6“ (black) Case Pack 10 3 3 3 3 6 Pc. Color Coded Magnetic Nut Setters Set Item No. Description Case Pack 70486 6” Nut Setter Set 6 Hex Inch: 1/4, 5/16, 3/8 7/16, 1/2, 9/16” Non Magnetic 1/4” Hex Inch Standard Nut Setters Item No. 70424 70427 70430 Description 1/4 x 55mm 5/16 x 55mm 3/8 x 55mm Case Pack 3 3 3 Security TORX® 1/4” Bit Selector Set TerminatorBlue 8 Pc. 1” BitBuddy Item No. Description 70098 Bit Seletor Set Phillips: #1, 2 & Square: #1, 2 TORX: T20, T25, T30 1/4” Magnetic Bit Holder Description T7s x 42mm T8s x 42mm T9s x 42mm T10s x 42mm T15s x 42mm T20s x 42mm T25s x 42mm T27s x 42mm T30s x 42mm T40s x 42mm Magnetic 1/4” Case Pack 6 1/4” Hex Inch Standard Nut Setters Item No. 70437 70438 70440 70442 70445 70448 70450 3/8” Drive Security TORX® 1/4” Bit Sockets Item No. 70107 70108 70109 70110 70113 70115 70117 70119 70121 70123 Item No. Description Case Pack 70190 Bit Seletor Set 3 Security TORX: T7s, T8s, T9s, T10s, T15s, T20s, T25s Case Pack 3 3 3 3 3 3 3 3 3 3 Description 5.0 x 55mm 5.5 x 55mm 6.0 x 55mm 7.0 x 55mm 8.0 x 55mm 10.0 x 55mm 13.0 x 55mm Case Pack 3 3 3 3 3 3 3 2.5” 3 Pc. Hex Inch Nut Setter Set Item No. Description 70490 65mm Nut Setter Set Hex Inch: 1/4, 5/16, 3/8 x 2.5” Case Pack 3 4.0” OAL 3 Pc. Hex Inch Nut Setter Set TerminatorBlue 1/4” Impact Bits - 2 Bit Pack Item No. 70201 70202 70203 70218 70219 70220 70222 70223 70225 Description Phillips #1 - 2” Bits Phillips #2 - 2” Bits Phillips #3 - 2” Bits TORX T15 - 2” Bits TORX T20 - 2” Bits TORX T25 - 2” Bits TORX T30 - 2” Bits TORX T40 - 2” Bits Square #2 - 2” Bits Case Pack 6 6 6 6 6 6 6 6 6 Item No. Description 70491 102mm Nut Setter Set Hex Inch: 1/4, 5/16, 3/8 x 4.0” Case Pack 3 1/4” Hex Inch Standard Nut Setters Item No. 70462 70463 70464 70466 Description 2.5” OAL 4.0” OAL 6.0” OAL 12.0” OAL Case Pack 3 3 3 3 6.0” OAL 3 Pc. Hex Inch Nut Setter Set Item No. Description 70492 152mm Nut Setter Set Hex Inch: 1/4, 5/16, 3/8 x 6.0” Case Pack 3 37 www.wihatools.com • USA | www.wihatools.ca • CANADA 2 Bit Pack 12.0” OAL 3 Pc. Hex Inch Nut Setter Set Item No. Description 70493 305mm Nut Setter Set Hex Inch: 1/4, 5/16, 3/8 x 12.0” Case Pack 3 55mm OAL Magnetic Bit Holder Slotted 1/4” Insert Bits - 2 Bit Pack Item No. 71051 71052 71053 71054 Description 4.5 x 25mm 5.5 x 25mm 6.0 x 25mm 8.0 x 25mm Case Pack 3 3 3 3 Item No. Description 71139 1/4 x 4.0”(100mm) 3/8” Drive Hex Metric 1/4” Bit Sockets Case Pack 3 3 Pc. Hex Metric Nut Setter Set Item No. Description 70494 55mm Nut Setter Set Hex Metric: 7, 8, 10 x 55mm Case Pack 3 2 Bit Pack Item No. 71300 71316 71320 71322 71323 71325 71331 71341 Description 2.0 x 42mm 2.5 x 42mm 8.0 x 42mm 10.0 x 42mm 5.0 x 42mm 6.0 x 42mm 4.0 x 42mm 3.0 x 42mm Case Pack 3 3 3 3 3 3 3 3 Phillips 1/4” Insert Bits - 2 Bit Pack Slotted & Phillips 1/4” Insert Bits - 6 Bit Pack Item No. Description Case Pack 71056 6 1/4” Bit Pack 3 Slotted: 4.5, 5.5, 6.5 & Phillips: #1, 2, 3 Item No. 71149 71151 71152 71153 Description 0 x 25mm 1 x 25mm 2 x 25mm 3 x 25mm Case Pack 3 3 3 3 1/4” Drive Hex Metric 1/4” Bit Sockets 10 pack Security TORX® 1/4” Power Bits - 10 Pack Item No. 70507 70508 70509 70510 70515 70520 70525 70527 70530 70540 70545 70550 Description T7s x 50mm T8s x 50mm T9s x 50mm T10s x 50mm T15s x 50mm T20s x 50mm T25s x 50mm T27s x 50mm T30s x 50mm T40s x 50mm T45s x 50mm T50s x 50mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 Slotted/Phillips/Hex 1/4” Bit Selector Set Item No. Description Case Pack 71090 Bit Selector Set 6 Slotted: 4.5, 5.5, 6.5mm & Phillips: #1, 2, 3 Hex: 1/8, 5/32, 3/16” & 1/4” Bit Holder 7 Pc. PokitPak TORX® 1/4” Insert Bits Item No. Description 71195 1/4” Bit PokitPack TORX: T8, T10, T15, T20, T25, T30 1/4” Magnetic Bit Holder Case Pack 3 Item No. 71301 71302 71305 71313 71314 71317 71319 71327 71340 Description 1.5 x 38mm 2.0 x 38mm 2.5 x 38mm 3.0 x 38mm 4.0 x 38mm 5.0 x 38mm 6.0 x 38mm 8.0 x 38mm 10.0 x 38mm Case Pack 3 3 3 3 3 3 3 3 3 10 Pack Hex Metric 1/4” Insert Bits - 10 Pack 5 pc. bit pack Security TORX® 1/4” Power Bits Item No. 70533 70534 70535 70536 70537 70538 70539 Description T10s x 90mm T15s x 90mm T20s x 90mm T25s x 90mm T27s x 90mm T30s x 90mm T40s x 90mm Case Pack 3 3 3 3 3 3 3 51 Piece ClicFix Bits Collector 6 Pc. PokitPak Slotted & Phillips Insert Bits Item No. Description Case Pack 71095 Bits Collector Set 3 10 Each Phillips: #1, 2 & 5 Phillips: #3 10 Each Hex Inch: 1/8, 3/16” & 5 Hex Inch: 5/32” ClicFix Quick Release Bit Holder Item No. Description Case Pack 71198 1/4” Bit PokitPack 3 Slotted: 4.5, 6.0mm & Phillips: #0, 1, 2, 3 Security TORX® 1/4” Power Bits - 2 Bit Pack Item No. 70556 70557 70558 70559 70560 70561 70562 70563 70564 70565 70566 70567 Description T7s x 50mm T8s x 50mm T9s x 50mm T10s x 50mm T15s x 50mm T20s x 50mm T25s x 50mm T27s x 50mm T30s x 50mm T40s x 50mm T45s x 50mm T50s x 50mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 Description 0 x 25mm 1 x 25mm 2 x 25mm 3 x 25mm Case Pack 3 3 3 3 Item No. 71200 71201 71202 71203 Description 0 x 25mm 1 x 25mm 2 x 25mm 3 x 25mm Case Pack 3 3 3 3 2 Bit Pack Pozidriv® 1/4” Insert Bits - 2 Bit Pack Universal Magnetic Bit Holder Item No. Description 71130 1/4 x 2.9”(74mm) 71131 1/4 x 2.3”(59mm) Case Pack 3 3 3 3 3 3 3 3 3 Pozdriv® 1/4” Insert Bits Phillips 1/4” Insert Bits - 10 Pack Item No. 71100 71101 71102 71103 Description 1.5 x 25mm 2.0 x 25mm 2.5 x 25mm 3.0 x 25mm 4.0 x 25mm 5.0 x 25mm 6.0 x 25mm 8.0 x 25mm 10.0 x 25mm 10 Pack 10 pack 2 Bit Pack Item No. 71303 71306 71308 71309 71312 71315 71318 71321 71324 Case Pack 10 10 Item No. 71250 71251 71252 71253 Description 0 x 25mm 1 x 25mm 2 x 25mm 3 x 25mm Case Pack 3 3 3 3 Hex Inch 1/4” Insert Bits - 10 Pack Item No. 71326 71328 71329 71330 71333 71336 71339 71342 71345 71348 71351 71353 71356 Description 1/16 x 25mm 5/64 x 25mm .050 x 25mm 3/32 x 25mm 7/64 x 25mm 1/8 x 25mm 9/64 x 25mm 5/32 x 25mm 3/16 x 25mm 7/32 x 25mm 1/4 x 25mm 5/16 x 25mm 3/8 x 25mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 10 pack Screw Holding MagicRing Hex Metric 1/4” Insert Bits Slotted 1/4” Insert Bits - 10 Pack Item No. 71001 71002 71003 71004 Description 4.5 x 25mm 6.5 x 25mm 8.0 x 25mm 5.5 x 25mm Case Pack 3 3 3 3 10 Bit Pack Phillips Drywall Stop Bit - 10 Pieces Item No. Description 71132 #2 x 25mm Case Pack 3 Pozdriv® 1/4” Insert Bits - 3 Bit Pack Item No. Description 71254 Pozidriv 3 Bit Pack Pozidriv: #1, 2, 3 x 25mm Case Pack 3 Item No. 71304 71307 71310 71311 Description 3.0 x 25mm 4.0 x 25mm 5.0 x 25mm 6.0 x 25mm Case Pack 10 10 10 10 38 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA 3/8” Drive Hex Metric 5/16” Bit Socket Item No. Description 71332 12.0 x 75mm Case Pack 3 1/4” Sq. Dr. Hex Metric 1/4” Bit Socket Set 7 Pc. 1/4” Sq. Dr. Ball End Hex Bit Socket Set Item No. Description Case Pack 71389 7 Pc. Hex Bit Socket Set 3 Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0mm Item No. Description Case Pack 71398 1/4” Bit Socket Set 3 Inch: 3/32, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” CentroFix 1/4” Bit Holder Item No. Description 71480 1/4 x 60mm Case Pack 3 8 Pc. 3/8” Sq. Dr. Hex Inch 1/4” Bit Socket Set Item No. Description Case Pack 71392 Hex Bit Socket Set 3 Inch: 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Screw Holding ClicFix Magnetic 1/4” Bit Holder For Insert Bits MagicRing Hex Inch 1/4” Insert Bits Item No. 71343 71346 71349 71352 71354 Description 1/8 x 25mm 9/64 x 25mm 5/32 x 25mm 3/16 x 25mm 7/32 x 25mm Item No. Description 71491 1/4 x 75mm Case Pack 10 10 10 10 10 5 Pc. 3/8” Sq. Dr. Hex Inch 1/4” Bit Socket Set Item No. Description 71393 Hex Bit Socket Set Inch: 1/8, 3/16, 1/4, 5/16, 3/8” Case Pack 3 Magnetic 1/4” Bit Holders - Retaining Ring Item No. 71431 71433 71435 71437 71439 71441 Hex Inch 1/4” Insert Bits - 2 Bit Pack Item No. 71359 71360 71361 71362 71363 71364 71365 71366 71367 71368 71369 71373 71387 Description .050 x 25mm 1/16 x 25mm 5/64 x 25mm 3/32 x 25mm 7/64 x 25mm 1/8 x 25mm 9/64 x 25mm 5/32 x 25mm 3/16 x 25mm 7/32 x 25mm 1/4 x 25mm 5/16 x 25mm 3/8 x 25mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 1/4” Drive Hex Inch 1/4” Bit Sockets Description 5/64 x 38mm 1/16 x 38mm 3/32 x 38mm 7/64 x 38mm 1/8 x 38mm 9/64 x 38mm 5/32 x 38mm 3/16 x 38mm 7/32 x 38mm 1/4 x 38mm Case Pack 3 3 3 3 3 3 3 3 3 3 Case Pack 10 10 10 10 10 10 Item No. Description 71394 Hex Bit Socket Set Metric: 4.0, 5.0, 6.0, 8.0, 10.0mm Case Pack 3 Stainless Steel 1/4” Bit Holder For Insert Bits Xeno Combination Terminal Block 1/4” Bits Item No. Description 71452 1 x 50mm (10 Pk.) 71453 2 x 50mm (10 Pk.) Case Pack 3 3 3 3 3 3 3 3 Item No. Description 71494 1/4 x 54mm Case Pack 3 Case Pack 3 3 2 Bit Pack Item No. Description Case Pack 71396 Hex Inch 6 Bit Pack 3 Inch: 1/16, 3/32, 1/8, 5/32, 3/16, 1/4” x 25mm SlimFix 1/4” Bit Holder For Insert Bits Item No. Description 71496 1/4 x 10.9mm Case Pack 3 Xeno Terminal Block 1/4” Bits - 2 Bit Packs Item No. Description 71455 1 x 50mm 71456 2 x 50mm Case Pack 3 3 5 Pc. Magnetic 1/4” Bit Holder Set Item No. Description 71499 1/4” Bit Holder Set Includes: 60, 100, 150, 200, 253mm Hex Metric 1/4” Insert Bits - 6 Bit Pack Case Pack 3 Proturn 1/4” Quick Release Bit Holders Item No. 71475 71476 71477 71478 71479 Description 2.4” x 60mm 3.9” x 100mm 5.9” x 150mm 7.9” x 200mm 9.9” x 250mm Case Pack 3 3 3 3 3 Case Pack 3 10 pack Proturn 1/4” Quick Release Bit Holder Set Item No. Description 71474 5 Pc. Proturn Bit Holder Set Includes: 60, 100, 150, 200, 250mm 3/8” Square Drive Hex Inch 1/4” Bit Sockets Description 1/8 x 42mm 9/64 x 42mm 5/32 x 42mm 3/16 x 42mm 7/32 x 42mm 1/4 x 42mm 5/16 x 42mm 3/8 x 42mm Case Pack 10 10 Rated to 600 In/lbs. Item No. Description Case Pack 71397 Hex Metric 6 Bit Pack 3 Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0mm x 25mm Item No. 71375 71377 71379 71381 71383 71385 71388 71390 Screw Cap Bit Holder With O-Ring Item No. Description 71492 1/4 x 62mm 71493 1/4 x 76mm 10 Pack 3/8” Sq. Dr. Hex Metric 1/4” Bit Socket Set Hex Inch 1/4” Insert Bits - 6 Bit Pack Item No. 71370 71371 71372 71374 71376 71378 71380 71382 71384 71386 Description 1/4” x 60mm 1/4” x 67mm 1/4” x 100mm 1/4” x 150mm 1/4” x 200mm 1/4” x 253mm Case Pack 3 TORX 1/4” Insert Bits - 10 Pack ® Item No. 71505 71506 71507 71508 71509 71510 71515 71520 71523 71524 71525 71527 71530 71540 Description T5 x 25mm T6 x 25mm T7 x 25mm T8 x 25mm T9 x 25mm T10 x 25mm T15 x 25mm T20 x 25mm T3 x 25mm T4 x 25mm T25 x 25mm T27 x 25mm T30 x 25mm T40 x 25mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 39 www.wihatools.com • USA | www.wihatools.ca • CANADA 2 Bit Pack 10 pack TORX® Align 1/4” Insert Bits Item No. 71536 71537 71538 71541 71542 71543 71544 71545 71546 71547 Description T6 x 25mm T7 x 25mm T8 x 25mm T10 x 25mm T15 x 25mm T20 x 25mm T25 x 25mm T27 x 25mm T30 x 25mm T40 x 25mm Case Pack 3 3 3 3 3 3 3 3 3 3 2 Bit Pack Screw Holding TORXPlus® 1/4” Insert Bits - 2 Bit Packs Item No. 71631 71632 71633 71634 71635 71636 71637 71638 71639 71641 71642 71643 71644 71645 Description IP3 x 25mm IP4 x 25mm IP5 x 25mm IP6 x 25mm IP7 x 25mm IP8 x 25mm IP9 x 25mm IP10 x 25mm IP15 x 25mm IP20 x 25mm IP25 x 25mm IP27 x 25mm IP30 x 25mm IP40 x 25mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 TORXPlus® 1/4” Insert Bit Selector Set Item No. Description 71692 Bit Selector Set TORXPlus: IP3, IP4, IP5, IP6, IP7, IP8, IP9, IP10, IP15, IP20 Case Pack 3 1/4” & 3/8” Sq. Dr. TORXPlus® Bit Sockets Item No. Description 71698 8 Pc. Bit Socket Set on Rail 1/4”: IP9, IP10, IP15, IP20 3/8”: IP25, IP27, IP30, IP40 Case Pack 3 TORX® 1/4” Insert Bits - 2 Bit Packs Item No. 71548 71549 71550 71551 71552 71553 71554 71555 71556 71557 71558 71559 71560 71561 Description T3 x 25mm T4 x 25mm T5 x 25mm T6 x 25mm T7 x 25mm T8 x 25mm T9 x 25mm T10 x 25mm T15 x 25mm T20 x 25mm T25 x 25mm T27 x 25mm T30 x 25mm T40 x 25mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 10 pack MagicRing Ball End Hex MM 1/4” Power Bits Item No. 71730 71740 71750 71760 Description 3.0 x 50mm 4.0 x 50mm 5.0 x 50mm 6.0 x 50mm Case Pack 10 10 10 10 Ball End Hex Inch 1/4” Insert Bit Sockets Item No. 71761 71762 71763 71764 71765 71766 71767 71768 Description 3/32 x 38mm 7/64 x 38mm 1/8 x 38mm 9/64 x 38mm 5/32 x 38mm 3/16 x 38mm 7/32 x 38mm 1/4 x 38mm Case Pack 3 3 3 3 3 3 3 3 Ball End Hex Inch 1/4” Insert Bits - 10 Pack Security Pentalobe 5 Point 1/4” Insert Bits Item No. 71648 71650 71652 71654 71656 71657 71658 71660 Description PLS8 x 25mm PLS10 x 25mm PLS15 x 25mm PLS20 x 25mm PLS25 x 25mm PLS27 x 25mm PLS30 x 25mm PLS40 x 35mm Case Pack 3 3 3 3 3 3 3 3 Item No. 71701 71702 71703 71704 71705 71706 71707 71708 Description 3/32 x 25mm 7/64 x 25mm 1/8 x 25mm 9/64 x 25mm 5/32 x 25mm 3/16 x 25mm 7/32 x 25mm 1/4 x 25mm Case Pack 3 3 3 3 3 3 3 3 Ball End Hex Metric 1/4” Insert Bit Sockets Item No. 71771 71772 71773 71774 71775 71776 71777 Description 1.5 x 51mm 2.0 x 51mm 2.5 x 51mm 3.0 x 51mm 4.0 x 51mm 5.0 x 51mm 6.0 x 51mm Case Pack 3 3 3 3 3 3 3 2 Bit Pack 7 Pc. 1/4” Sq. Dr. Ball End Hex Bit Socket Set TORX® 1/4” Insert Bits - 6 Bit Pack Item No. Description 71570 TORX 6 Bit Pack TORX: T5, T6, T7, T8, T9, T10 x 25mm Case Pack 3 TORX® 1/4” Insert Bits - 6 Bit Pack Item No. Description Case Pack 71571 TORX 6 Bit Pack 3 TORX: T15, T20, T25, T27, T30, T40 x 25mm 1/4” Sq. Dr. TORXPlus® 1/4” Insert Bit Sockets Ball End Hex Inch 1/4” Insert Bits - 2 Bit Pack Item No. 71661 71662 71663 71664 71665 71666 71667 71668 71669 71670 71671 Item No. 71711 71712 71713 71714 71715 71716 71717 71718 Description IP6 x 38mm IP7 x 38mm IP8 x 38mm IP9 x 38mm IP10 x 38mm IP15 x 38mm IP20 x 38mm IP25 x 38mm IP27 x 38mm IP30 x 38mm IP40 x 38mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 TORXPlus® 1/4” Insert Bits - 10 Pack Item No. 71603 71604 71605 71606 71607 71608 71609 71610 71615 71620 71625 71627 71630 71640 Description IP3 x 25mm IP4 x 25mm IP5 x 25mm IP6 x 25mm IP7 x 25mm IP8 x 25mm IP9 x 25mm IP10 x 25mm IP15 x 25mm IP20 x 25mm IP25 x 25mm IP27 x 25mm IP30 x 25mm IP40 x 25mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Case Pack 3 3 3 3 3 3 3 3 1/4” Sq. Dr. Ball End Hex Bit Socket Set Item No. Description Case Pack 71798 8 Pc. 1/4” Bit Socket Set 3 Inch: 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” 2 Bit Pack 3/8” Sq. Dr. TORXPlus® 1/4” Insert Bit Sockets 10 pack Description 3/32 x 25mm 7/64 x 25mm 1/8 x 25mm 9/64 x 25mm 5/32 x 25mm 3/16 x 25mm 7/32 x 25mm 1/4 x 25mm Item No. Description Case Pack 71797 1/4” Bit Socket Set 3 1/4” Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0mm Item No. 71673 71674 71675 71676 71677 71678 71680 71681 Description IP9 x 38mm IP10 x 38mm IP15 x 38mm IP20 x 38mm IP25 x 38mm IP27 x 38mm IP30 x 38mm IP40 x 38mm Case Pack 3 3 3 3 3 3 3 3 Ball End Hex Metric 1/4” Insert Bits-2 Bit Pk Item No. 71719 71720 71721 71722 71723 71724 71725 Description 1.5 x 38mm 2.0 x 38mm 2.5 x 38mm 3.0 x 38mm 4.0 x 38mm 5.0 x 38mm 6.0 x 38mm Case Pack 3 3 3 3 3 3 3 Square 1/4” Insert Bits Item No. 71801 71802 71803 Description 1 x 25mm 2 x 25mm 3 x 25mm Case Pack 3 3 3 2 Bit Pack Screw Holding MagicRing Ball End Hex Inch 1/4” Power Bits TORXPlus® 1/4” Insert Bit Selector Set Item No. Description 71690 Bit Selector Set TORXPlus: IP7, IP8, IP9, IP10, IP15, IP20, IP25, IP27, IP30, IP40 Case Pack 3 Item No. 71726 71728 71732 71734 71736 71738 Description 1/8 x 50mm 9/64 x 50mm 5/32 x 50mm 3/16 x 50mm 7/32 x 50mm 1/4 x 50mm Case Pack 10 10 10 10 10 10 Square 1/4” Insert Bits - 2 Bit Pack Item No. 71851 71852 71853 Description 1 x 25mm 2 x 25mm 3 x 25mm Case Pack 3 3 3 40 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA 10 Pack Square 1/4” Insert Bits - 3 Bit Pack Item No. Description 71854 Square Bit Pack Square: 1, 2, 3 x 25mm Case Pack 3 10 Pack Tri-Wing 1/4” Insert Bits - 10 Pack Item No. 71900 71901 71902 71903 71904 Description 0 x 25mm 1 x 25mm 2 x 25mm 3 x 25mm 4 x 25mm Case Pack 3 3 3 3 3 10 Pack Security Hex Inch 1/4” Insert Bits - 10 Pack Item No. 71930 71932 71934 71936 71938 71940 71955 71956 71960 Description 5/64 x 25mm 3/32 x 25mm 7/64 x 25mm 1/8 x 25mm 9/64 x 25mm 5/32 x 25mm 3/16 x 25mm 7/32 x 25mm 1/4 x 25mm Case Pack 3 3 3 3 3 3 3 3 3 Description 6 x 25mm 4 x 25mm 8 x 25mm 5 x 25mm 10 x 25mm 0 x 25mm 1 x 25mm 2 x 25mm 3 x 25mm Case Pack 3 3 3 3 3 3 3 3 3 Description 2.0 x 25mm 2.5 x 25mm 3.0 x 25mm 4.0 x 25mm 5.0 x 25mm 6.0 x 25mm 8.0 x 25mm Case Pack 3 3 3 3 3 3 3 Description 4 x 25mm 5 x 25mm 6 x 25mm 8 x 25mm 10 x 25mm Case Pack 3 3 3 3 3 Tri-Wing 1/4” Insert Bits - 2 Bit Pack Description 5 x 25mm 0 x 25mm 1 x 25mm 2 x 25mm 3 x 25mm 4 x 25mm Case Pack 3 3 3 3 3 3 Description 4 x 25mm 6 x 25mm 8 x 25mm 10 x 25mm Case Pack 3 3 3 3 2 Bit Pack Security Hex Inch 1/4” Insert Bits Item No. 71970 71971 71972 71973 71974 71975 71976 71977 71978 Description 5/64 x 25mm 3/32 x 25mm 7/64 x 25mm 1/8 x 25mm 9/64 x 25mm 5/32 x 25mm 3/16 x 25mm 7/32 x 25mm 1/4 x 25mm Case Pack 3 3 3 3 3 3 3 3 3 2 Bit Pack 10 Pack Description 4 x 25mm 6 x 25mm 8 x 25mm 10 x 25mm Case Pack 3 3 3 3 7 Pc. 3/8” Sq. Dr. Security Hex Bit Socket Set 6 Pc. Security Hex In. 1/4” Insert Bits PokitPak Item No. Description Case Pack 71989 3/8” Sq. Dr. Socket Set 3 Hex Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0mm Item No. Description Case Pack 71998 6 Pc. PokitPak 3 Security: 3/32, 7/64, 1/8, 9/64, 5/32, 3/16” x 25mm Security Hex Inch 1/4” Insert Bits Item No. 71979 71980 71981 71982 71983 71984 71985 Description 2.0 x 25mm 2.5 x 25mm 3.0 x 25mm 4.0 x 25mm 5.0 x 25mm 6.0 x 25mm 8.0 x 25mm 39 Pc. Security Bits Collector Set Item No. Description Case Pack 71990 Bits Collector Set 3 Security TORX: T8s-T40s Security Hex: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Tri-Wing: 1, 2, 3, 4 & Torq Set: 6, 8, 10 Spanner: 4, 6, 8, 10 & Pozidriv: 0, 1, 2, 3 Slotted: 6.5, 8.0mm & Phillips: 1, 2 & Square: 1, 2, 3 1/4” Handle, 1/4” Magnetic Bit Holder, 1/4” Bit Holding Socket Adapter 9 Pc. 3/8” Sq. Dr. Security Hex Bit Socket Set Item No. Description 71999 3/8” Sq. Dr. Socket Set Hex Inch: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Case Pack 3 39 Pc. Security Bits Collector Set Item No. Description Case Pack 71991 Bits Collector Set 3 Security TORX: T8s-T40s Security Hex: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Tri-Wing: 1, 2, 3, 4 & Torq Set: 6, 8, 10 Spanner: 4, 6, 8, 10 & Pozidriv: 0, 1, 2, 3 Slotted: 6.5, 8.0mm & Phillips: 1, 2 & Square: 1, 2, 3 1/4” Handle, 1/4” SlimFix Locking Bit Holder, 1/4” Bit Holding Socket Adapter Impact Bit Holding Sockets W/Retaining Ring Item No. 72001 72002 72003 Description 1/4” x 25mm (1/4” Dr.) 1/4” x 30mm (3/8” Dr.) 1/4” x 35mm (1/2” Dr.) Case Pack 3 3 3 38 Piece Bits Collector Set Spanner 1/4” Insert Bits - 10 Pack Item No. 71914 71916 71918 71920 Case Pack 3 Spanner 1/4” Insert Bits - 2 Bit Pack Item No. 71963 71964 71965 71966 2 Bit Pack Item No. 71913 71949 71950 71951 71952 71953 9 Pc. 1/4” & 3/8” Sq. Dr. Hex Bit Socket Set Item No. Description 71996 Hex Metric Socket Set 1/4” Metric: 1.5, 2.0, 2.5, 3.0, 4.0mm 3/8” Metric: 5.0, 6.0, 8.0, 10.0mm Case Pack 3 2 Bit Pack Torq Set 1/4” Insert Bits - 2 Bit Pack 39 Pc. Security Bits & Ratchet Collector Set Item No. Description Case Pack 71988 Bits Collector Set 3 Security TORX: T8s-T40s Security Hex: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Tri-Wing: 1, 2, 3, 4 & Torq Set: 6, 8, 10 Spanner: 4, 6, 8, 10 & Pozidriv: 0, 1, 2, 3 Slotted: 6.5, 8.0mm & Phillips: 1, 2 & Square: 1, 2, 3 1/4” Handle, 1/4” Magnetic Bit Holder, 1/4” Bit Holding Socket Adapter Tri-Wing 1/4” Insert Bits - 6 Bit Pack Item No. Description 71954 Tri-Wing Bit Pack Tri-Wing: 0, 1, 2, 3, 4, 5 x 25mm 2 Bit Pack Item No. 71911 71912 71957 71958 71959 6 Pc. Security Hex 1/4” Insert Bits PokitPak Item No. Description Case Pack 71995 6 Pc. PokitPak 3 Security Hex: 2.5, 3.0, 4.0, 5.0, 6.0, 8.0mm x 25mm Security Hex Inch 1/4” Insert Bits - 10 Pack Item No. 71939 71941 71942 71943 71944 71945 71946 Torq Set 1/4” Insert Bits - 10 Pack Item No. 71906 71907 71908 71909 71910 71921 71922 71923 71924 29 Pc. Security Bits & CentroFix Handle Set Item No. Description Case Pack 71987 Bits Collector Set 1 Security TORX: T9s - T40s Security Hex: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” & Tri-Wing: #4, 5 & Torq Set: #5, 8 Spanner: #6, 8, 10 & Pozidriv: #2 & Square: #1, 2 CentroFix Cushion Grip Handle 1/4” Magnetic Bit Holder 1/4” Bit Holding Socket Adapter Case Pack 3 3 3 3 3 3 3 Item No. Description Case Pack 71994 Bits Collector Set 3 TORX: T7, T8, T9, T10, T15, T20, T25, T27, T30, T40 Slotted: 4.5, 5.5, 6.0mm & Phillips: 0, 1, 2, 3 Square: 1, 2, 3 & Pozidriv: 1, 2, 3 Hex Inch: 1/16, 5/64, 3/32, 1/8, 5/32, 3/16, 7/32, 1/4” Hex Metric: 2.5, 3.0, 4.0, 5.0, 6.0mm 1/4” Handle & 1/4” Bit Holder Impact Bit Holding Sockets W/Retaining Ring Item No. Description 72004 5/16” x 25mm (1/4” Dr.) 72005 5/16” x 30mm (3/8” Dr.) 72006 5/16” x 35mm (1/2” Dr.) Case Pack 3 3 3 41 www.wihatools.com • USA | www.wihatools.ca • CANADA 1/4” Bit 1/4” Bit 5/16” Bit With Set Screw & Retaining Ring Bit Socket Replacement Parts Item No. 72014 72038 72040 Description 1/4” Drive For 1/4” Bit 3/8” Drive For 1/4” Bit 3/8” Drive For 5/16” Bit Case Pack 3 3 3 100 pack Pozdriv® 1/4” Insert Bits - 100 Pack Item No. 72205 72206 72207 Description 1 x 25mm 2 x 25mm 3 x 25mm Hex Metric 1/4” Power Bits - 2.0” - 100 Pack Case Pack 1 1 1 Item No. 72263 72264 72265 72266 72267 Description 2.5 x 50mm 3.0 x 50mm 4.0 x 50mm 5.0 x 50mm 6.0 x 50mm Case Pack 1 1 1 1 1 Slotted 5/16” Insert Bits - 2 Bit Pack Case Pack 3 3 Item No. 72209 72210 72211 72212 72213 72214 Description 2.0 x 25mm 2.5 x 25mm 3.0 x 25mm 4.0 x 25mm 5.0 x 25mm 6.0 x 25mm Case Pack 1 1 1 1 1 1 Slotted 5/16” Insert Bits - 10 Pack Item No. Description 72050 10.0 x 41mm 72051 12.0 x 41mm Case Pack 3 3 Hex Inch 1/4” Insert Bits - 100 Pack Item No. 72217 72218 72220 72221 72222 72223 72224 72225 72226 72227 Description 1/16 x 25mm 5/64 x 25mm 3/32 x 25mm 7/64 x 25mm 1/8 x 25mm 9/64 x 25mm 5/32 x 25mm 3/16 x 25mm 7/32 x 25mm 1/4 x 25mm 100 pack Case Pack 3 2 Bit Pack Case Pack 3 3 Case Pack 1 1 1 1 1 1 1 1 1 1 Description T15 x 50mm T20 x 50mm T25 x 50mm T27 x 50mm T30 x 50mm Description T15 x 25mm T20 x 25mm T25 x 25mm T27 x 25mm T30 x 25mm Case Pack 1 1 1 1 1 Case Pack 1 1 1 Item No. Description 72110 1/4” x 25mm 72115 3/8” x 30mm Case Pack 3 3 Case Pack 1 1 1 100 pack Hex Inch 1/4” Power Bits - 2.0” OAL - 100 Pack 100 pack Phillips 1/4” Insert Bits - 100 Pack Item No. 72201 72202 72203 Description 1 x 25mm 2 x 25mm 3 x 25mm Case Pack 1 1 1 Item No. 72255 72256 72257 72258 72259 72260 72261 72262 Description 3/32 x 50mm 7/64 x 50mm 1/8 x 50mm 9/64 x 50mm 5/32 x 50mm 3/16 x 50mm 7/32 x 50mm 1/4 x 50mm 250 pack Case Pack 1 1 1 1 1 1 1 1 Description 1 x 50mm 2 x 50mm 3 x 50mm Case Pack 1 1 1 250 pack Phillips 1/4” Insert Bits - 250 Pack Hex Inch 1/4” Power Bits - 2.0” OAL - 250 Pack Item No. 72301 72302 72303 Description 1 x 25mm 2 x 25mm 3 x 25mm Case Pack 1 1 1 Item No. 72305 72306 72307 Description 1 x 25mm 2 x 25mm 3 x 25mm Case Pack 1 1 1 Item No. 72309 72310 72311 72312 72313 72314 Description 2.0 x 25mm 2.5 x 25mm 3.0 x 25mm 4.0 x 25mm 5.0 x 25mm 6.0 x 25mm Case Pack 1 1 1 1 1 1 Phillips 1/4” Power Bits - 2.0” OAL - 100 Pack Description 1 x 50mm 2 x 50mm 3 x 50mm Case Pack 1 1 1 250 pack Hex Metric 1/4” Insert Bits - 250 Pack Square 1/4” Insert Bits - 100 Pack Item No. 72248 72249 72250 Description 1 x 25mm 2 x 25mm 3 x 25mm Phillips 1/4” Power Bits - 2.0” OAL - 250 Pack Case Pack 1 1 1 Pozdriv® 1/4” Insert Bits - 250 Pack Case Pack 1 1 1 1 1 100 pack Description 1 x 25mm 2 x 25mm 3 x 25mm Square 1/4” Insert Bits - 250 Pack Item No. 72344 72345 72346 Item No. 72348 72349 72350 Description 1 x 50mm 2 x 50mm 3 x 50mm 250 pack Item No. 72244 72245 72246 250 pack Square 1/4” Power Bits - 2.0” OAL - 100 Pack 100 pack Hex To Square 1/4” & 3/8” Socket Bit Adapter Case Pack 1 1 1 1 1 Item No. 72285 72286 72287 250 pack TORX® 1/4” Insert Bits - 100 Pack Item No. 72238 72239 72240 72241 72242 Phillips 5/16” Insert Bits - 2 Bit Pack Item No. Description 72102 2 x 32mm 72103 3 x 32mm TORX® 1/4” Power Bits - 2.0” OAL - 100 Pack Item No. 72279 72280 72281 72282 72283 100 pack 3 Pc. Impact Bit Holding Socket Set Item No. Description 72090 Retaining Ring Sockets Includes: 1/4, 3/8, 1/2” Description T15 x 25mm T20 x 25mm T25 x 25mm T27 x 25mm T30 x 25mm 100 pack 100 pack 10 Pack TORX® 1/4” Insert Bits - 250 Pack Item No. 72338 72339 72340 72341 72342 100 pack Hex Metric 1/4” Insert Bits - 100 Pack Item No. Description 72039 10.0 x 41mm 72047 12.0 x 41mm 250 pack 100 pack 250 pack Item No. 72355 72356 72357 72358 72359 72360 72361 72362 Description 3/32 x 50mm 7/64 x 50mm 1/8 x 50mm 9/64 x 50mm 5/32 x 50mm 3/16 x 50mm 7/32 x 50mm 1/4 x 50mm 250 pack Hex Metric 1/4” Power Bits - 2.0” - 250 Pack Item No. 72363 72364 72365 72366 72367 Description 2.5 x 50mm 3.0 x 50mm 4.0 x 50mm 5.0 x 50mm 6.0 x 50mm Description 1/16 x 25mm 5/64 x 25mm 3/32 x 25mm 7/64 x 25mm 1/8 x 25mm 9/64 x 25mm 5/32 x 25mm 3/16 x 25mm 7/32 x 25mm 1/4 x 25mm Case Pack 1 1 1 1 1 1 1 1 1 1 Case Pack 1 1 1 1 1 250 pack TORX® 1/4” Power Bits - 2.0” OAL - 250 Pack Item No. 72379 72381 72382 72383 72384 Description T15 x 50mm T20 x 50mm T25 x 50mm T27 x 50mm T30 x 50mm Case Pack 1 1 1 1 1 250 pack Hex Inch 1/4” Insert Bits - 250 Pack Item No. 72317 72318 72320 72321 72322 72323 72324 72325 72326 72327 Case Pack 1 1 1 1 1 1 1 1 Square 1/4” Power Bits - 2.0” OAL - 250 Pack Item No. 72387 72389 72390 Description 1 x 50mm 2 x 50mm 3 x 50mm Case Pack 1 1 1 Hex Metric Long Insert Bit On 5/16” Stock Item No. Description 72388 5/16” x 75mm Case Pack 10 42 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA 2 Bit Pack 1/4” Hex To Socket Adapter Item No. Description 72401 1/4” x 100mm (1/4” Dr.) 72405 1/4” x 50mm (1/4” Dr.) 72415 1/4” x 50mm (3/8” Dr.) Case Pack 3 3 3 TORX® 5/16” Insert Bits - 2 Bit Pack Item No. Description 72569 T60 x 35mm 30 Pc. Bit Box Description 1/16 x 25mm (30 bits) 5/64 x 25mm (30 bits) 3/32 x 25mm (30 bits) 7/64 x 25mm (30 bits) 1/8 x 25mm (30 bits) 9/64 x 25mm (30 bits) 5/32 x 25mm (30 bits) 3/16 x 25mm (30 bits) 7/32 x 25mm (30 bits) 1/4 x 25mm (30 bits) Case Pack 3 10 Pc. Blister 1/4” Insert Bit Set Item No. Description Case Pack 72593 Blister Bit Set 3 Slt: 4.5, 5.5, 6.0mm & Ph: 0, 1, 2, 3 & Sq: 1, 2, 3 Slotted 1/4” Power Bits - 2.75” OAL Item No. 73905 73906 73907 73908 73909 73910 Description 2.5 x 70mm 3.0 x 70mm 3.5 x 70mm 4.0 x 70mm 5.5 x 70mm 6.5 x 70mm Case Pack 3 3 3 3 3 3 30 Pc. Bit Box 30 Pc. Hex Inch 1/4” Insert Bits Item No. 72502 72503 72504 72506 72507 72508 72509 72511 72512 72513 2 Bit Pack Case Pack 10 10 10 10 10 10 10 10 10 10 30 Pc. Slotted 1/4” Insert Bits Item No. 72534 72535 72536 Description 4.5 x 25mm 5.5 x 25mm 6.0 x 25mm Case Pack 10 10 10 2 Bit Pack 10 Pc. Blister 1/4” Insert TORX® Bit Set Item No. Description Case Pack 72595 TORX Blister Bit Set 3 TORX: T7, T8, T9, T10, T15, T20, T25, T27, T30, T40 Phillips 1/4” Power Bits - 2.75” OAL Item No. 73912 73913 73914 73915 73916 Description 00 x 70mm 0 x 70mm 1 x 70mm 2 x 70mm 3 x 70mm Case Pack 3 3 3 3 3 30 Pc. Bit Box Square 30Pc. Contractor Grade Insert Bit Packs Item No. 72537 72538 72539 Description #1 x 25mm #2 x 25mm #3 x 25mm 10 pack Description T25s x 35mm T27s x 35mm T30s x 35mm T40s x 35mm T45s x 35mm T60s x 35mm Case Pack 3 3 3 3 3 3 Description T25s x 35mm T27s x 35mm T30s x 35mm T40s x 35mm T45s x 35mm T50s x 35mm T55s x 35mm T60s x 35mm Case Pack 10 10 10 10 30 Pc. Bit Box Pozdriv® 1/4” Insert Bits - 30 Pack Item No. 72524 72526 72532 Description 1 x 25mm (30 bits) 2 x 25mm (30 bits) 3 x 25mm (30 bits) 30 Pc. TORX® 1/4” Insert Bits Item No. 72572 72573 72574 72575 72576 72577 72578 72579 72580 72581 Description T7 x 25mm T8 x 25mm T9 x 25mm T10 x 25mm T15 x 25mm T20 x 25mm T25 x 25mm T27 x 25mm T30 x 25mm T40 x 25mm TORX® 5/16” Insert Bits - 10 Pack Description T25 x 35mm T27 x 35mm T30 x 35mm T55 x 35mm T60 x 35mm Case Pack 10 10 10 10 10 10 10 10 10 10 Case Pack 10 10 10 Case Pack 3 3 3 3 3 Hex Inch & Metric 1/4” Power Bits - 2.75” OAL Inch 73928 73929 73930 73931 73932 73933 73934 Description 2.0 x 25mm 2.5 x 25mm 3.0 x 25mm 4.0 x 25mm 5.0 x 25mm 6.0 x 25mm 8.0 x 25mm 10.0 x 25mm Description 2.0mm x 25mm 2.5mm x 25mm 3.0mm x 25mm 4.0mm x 25mm 5.0mm x 25mm 6.0mm x 25mm Case Pack 10 10 10 10 10 10 Case Pack 3 3 3 3 3 3 3 2 Bit Pack Hex Metric 1/4” Insert Bits - 2 Bit Pack Item No. 73302 73303 73304 73305 73306 73307 73308 73309 Case Pack 3 3 3 3 3 3 3 3 2 Bit Pack TORX® 1/4” Power Bits - 2.75” OAL Item No. 73936 73937 73938 73939 73940 73941 73942 73943 73944 73945 73946 Description T6 x 70mm T7 x 70mm T8 x 70mm T9 x 70mm T10 x 70mm T15 x 70mm T20 x 70mm T25 x 70mm T27 x 70mm T30 x 70mm T40 x 70mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 10 Pack TORX® Align 1/4” Insert Bits - 2 Bit Pack Item No. 73310 73311 73312 73314 73315 73316 73317 73318 73319 Description T6 x 25mm T7 x 25mm T8 x 25mm T10 x 25mm T15 x 25mm T20 x 25mm T25 x 25mm T27 x 25mm T30 x 25mm Case Pack 3 3 3 3 3 3 3 3 3 Slotted 1/4” Power Bits - 2.0” OAL - 10 Pack Item No. 74003 74006 74009 74010 74012 74015 74018 74021 Description 3.0 x 50mm 3.5 x 50mm 4.0 x 50mm (0.5mm) 4.0 x 50mm (0.8mm) 4.5 x 50mm 5.5 x 50mm 6.5 x 50mm 8.0 x 50mm (1.2mm) Case Pack 3 3 3 3 3 3 3 3 10 Pack 30 Pc. Hex Metric 1/4” Insert Bits Item No. 72582 72583 72584 72585 72586 72587 Description 2.0 x 70mm 2.5 x 70mm 3.0 x 70mm 4.0 x 70mm 5.0 x 70mm 6.0 x 70mm 8.0 x 70mm 2 Bit Pack 30 Pc. Bit Box 10 pack Item No. 72525 72527 72530 72555 72570 Case Pack 3 3 3 3 3 3 3 3 30 Pc. Bit Box Phillips 30Pc. Contractor Grade Insert Bits Description #0 x 25mm (30 bits) #1 x 25mm (30 bits) #2 x 25mm (30 bits) #3 x 25mm (30 bits) 10 Pc. Blister 1/4” Insert Hex Inch Bit Set Item No. Description Case Pack 72596 Hex Blister Bit Set 3 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Security TORX® 5/16” Insert Bits - 2 Bit Pack Item No. 72559 72560 72561 72562 72563 72564 72567 72568 30 Pc. Bit Box Item No. 72519 72521 72522 72523 2 Bit Pack 2 Bit Pack Security TORX® 5/16” Insert Bits Item No. 72514 72515 72516 72542 72547 72558 Case Pack 10 10 10 2 Bit Pack Pozidriv 1/4” Power Bits - 2.75” OAL ® Item No. 73901 73902 73903 Description 0 x 70mm 1 x 70mm 2 x 70mm Case Pack 3 3 3 Slotted 1/4” Power Bits - 2.75” OAL - 10 Pack Item No. 74033 74034 74035 74036 74039 74041 Description 2.5 x 70mm 3.0 x 70mm 3.5 x 70mm 4.0 x 70mm 5.5 x 70mm 6.5 x 70mm Case Pack 3 3 3 3 3 3 43 www.wihatools.com • USA | www.wihatools.ca • CANADA 2 Bit Pack Slotted 1/4” Power Bits - 3 Bit Pack Item No. Description 74050 Slotted Power Bit Pack Slotted: 4.5, 5.5, 6.5 x 50mm Case Pack 3 Phillips 1/4” Power Bits - 5.0” OAL Item No. 74113 74123 74133 Description 1 x 127mm 2 x 127mm 3 x 127mm Case Pack 3 3 3 Pozidriv® 1/4” Power Bits 2” OAL - 2 Bit Pack Item No. Description 74262 2 x 50mm Case Pack 3 2 Bit Pack Description 3.0 x 50mm 3.5 x 50mm 4.0 x 50mm (0.5mm) 4.0 x 50mm (0.8mm) 4.5 x 50mm 5.5 x 50mm 6.5 x 50mm 8.0 x 50mm (1.2mm) 8.0 x 50mm (1.6mm) Case Pack 3 3 3 3 3 3 3 3 3 Phillips 1/4” Power Bits - 5.9” OAL Item No. 74116 74126 74136 Description 1 x 150mm 2 x 150mm 3 x 150mm Case Pack 3 3 3 10 Pack Description 3.0 x 50mm 4.0 x 50mm 5.0 x 50mm 6.0 x 50mm Case Pack 10 10 10 10 10 Pack Hex Metric 1/4” Power Bits 2.75” OAL-10 Pk Item No. Description 74150 Phillips Power Bit Pack Phillips: 1, 2, 3 x 50mm Case Pack 3 10 Pack Phillips 1/4” Power Bits - 2.0” OAL - 10 Pack Description 0 x 50mm 1 x 50mm 2 x 50mm 3 x 50mm Case Pack 3 3 3 3 2 Bit Pack Phillips 1/4” Power Bits 2.0” OAL - 2 Bit Pack Phillips 1/4” Power Bits - 3.5” OAL Item No. 74104 74107 74109 74118 74130 Description 00 x 90mm 0 x 90mm 1 x 90mm 2 x 90mm 3 x 90mm Item No. 74158 74164 74165 74166 Case Pack 3 3 3 3 3 Description 0 x 50mm 1 x 50mm 2 x 50mm 3 x 50mm Case Pack 3 3 3 3 10 Pack Phillips 1/4” Power Bits - 2.75” OAL - 10 Pack Description 1 x 70mm 2 x 70mm 3 x 70mm 00 x 70mm 0 x 70mm Case Pack 3 3 3 3 3 15 Pc. Bit Box Hex Inch 1/4” Power Bits - 2.0” OAL - 10 Pack Item No. 74311 74312 74313 74314 74315 74316 74317 74318 Description 3/32 x 50mm 7/64 x 50mm 1/8 x 50mm 9/64 x 50mm 5/32 x 50mm 3/16 x 50mm 7/32 x 50mm 1/4 x 50mm Description 1 x 50mm 2 x 50mm 3 x 50mm Case Pack 10 10 10 Phillips 1/4” Power Bits - 4.33” OAL Item No. 74111 74121 74131 Description 1 x 110mm 2 x 110mm 3 x 110mm Case Pack 3 3 3 Description 2.0 x 70mm 2.5 x 70mm 3.0 x 70mm 4.0 x 70mm 5.0 x 70mm 6.0 x 70mm 8.0 x 70mm Case Pack 3 3 3 3 3 3 3 3 15 Pc. Bit Box Item No. 74201 74205 74214 Description 0 x 70mm 1 x 70mm 2 x 70mm Case Pack 3 3 3 10 Pack Hex Inch 1/4” Power Bits - 2.0” OAL - 15 Pack Item No. 74321 74322 74323 74324 74326 74328 74331 74338 Description 3/32 x 50mm 7/64 x 50mm 1/8 x 50mm 9/64 x 50mm 5/32 x 50mm 3/16 x 50mm 7/32 x 50mm 1/4 x 50mm Case Pack 10 10 10 10 10 10 10 10 Pozidriv® 1/4” Power Bits - 2.0” OAL - 10 Pack Item No. Description 74212 2 x 50mm Case Pack 3 3 3 3 3 3 3 2 Bit Pack 15 Pc. Bit Box Hex Metric 1/4” Power Bits - 2.0” OAL-15 Pk Pozidriv® 1/4” Power Bits - 3.5” OAL Item No. 74231 74232 74233 Description Case Pack 1 x 90mm (single pk.) 3 2 x 90mm (single pk.) 3 3 x 90mm (single pk.) 3 Item No. 74339 74358 74359 74367 74368 Description 2.5 x 50mm 3.0 x 50mm 4.0 x 50mm 5.0 x 50mm 6.0 x 50mm Pozidriv® 1/4” Power Bits - 3.5” OAL - 10 Pack Item No. 74236 74237 74238 Description 1 x 90mm 2 x 90mm 3 x 90mm Case Pack 3 3 3 Description 2.5 x 50mm 3.0 x 50mm 4.0 x 50mm 5.0 x 50mm 6.0 x 50mm 8.0 x 50mm Case Pack 3 3 3 3 3 3 Screw Holding Hex Metric 1/4” Power Bits - 2.0” OAL-10 Pk Item No. 74325 74330 74340 74350 74360 74380 Description 2.5 x 50mm 3.0 x 50mm 4.0 x 50mm 5.0 x 50mm 6.0 x 50mm 8.0 x 50mm Item No. 74369 74371 74373 74375 74379 Description 1/8 x 50mm 9/64 x 50mm 5/32 x 50mm 3/16 x 50mm 1/4 x 50mm Case Pack 10 10 10 10 10 10 Pack 10 Bit Pack Item No. 74361 74362 74363 74364 74365 74366 MagicRing Inch 1/4” Power Bits Case Pack 3 Phillips 1/4” Power Bits - 2.0” OAL - 15 Pack Item No. 74110 74114 74117 Item No. 74351 74352 74353 74354 74355 74356 74357 Hex Metric 1/4” Power Bits - 2 Bit Pack 10 Pack Pozidriv® 1/4” Power Bits - 2.75” OAL-10 Pk Item No. 74106 74115 74127 74167 74168 Case Pack 3 3 3 3 3 3 MagicRing Metric 1/4” Power Bits Item No. 74301 74305 74307 74319 Phillips 1/4” Power Bits - 3 Bit Pack Item No. 74102 74103 74112 74124 Description 2.0 x 90mm 2.5 x 90mm 3.0 x 90mm 4.0 x 90mm 5.0 x 90mm 6.0 x 90mm Screw Holding Slotted 1/4” Power Bits 2” OAL - 2 Bit Pack Item No. 74061 74062 74063 74064 74065 74066 74067 74068 74069 Hex Metric 1/4” Power Bits - 3.5” OAL Item No. 74332 74333 74334 74335 74336 74337 Case Pack 3 3 3 3 3 3 Case Pack 10 10 10 10 10 2 Bit Pack Hex Inch 1/4” Power Bits - 2 Bit Pack Item No. 74381 74382 74383 74384 74385 74386 74387 74388 Description 3/32 x 50mm 7/64 x 50mm 1/8 x 50mm 9/64 x 50mm 5/32 x 50mm 3/16 x 50mm 7/32 x 50mm 1/4 x 50mm Case Pack 3 3 3 3 3 3 3 3 44 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA 2 Bit Pack TORX® 1/4” Power Bits - 2.75” OAL TORX® 1/4” Power Bits - 2 Bit Pack Item No. 74501 74502 74503 74504 74506 74508 74510 74514 74515 74516 74525 74527 74530 74540 74559 Description T6 x 50mm T7 x 50mm T8 x 50mm T9 x 50mm T10 x 50mm T15 x 50mm T20 x 50mm T25 x 50mm T27 x 50mm T30 x 50mm T1 x 50mm T2 x 50mm T3 x 50mm T4 x 50mm T5 x 50mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Item No. 74536 74538 74542 74544 74546 74548 74551 74553 74556 74558 74561 Description T6 x 70mm T7 x 70mm T8 x 70mm T9 x 70mm T10 x 70mm T15 x 70mm T20 x 70mm T25 x 70mm T27 x 70mm T30 x 70mm T40 x 70mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 Ball End TORX® 1/4” Power Bits - 2 Bit Pack Item No. 74520 74522 74543 74545 74547 74549 74550 Description T10 x 50mm T15 x 50mm T20 x 50mm T25 x 50mm T27 x 50mm T30 x 50mm T40 x 50mm Case Pack 3 3 3 3 3 3 3 Description IP5 x 50mm IP6 x 50mm IP7 x 50mm IP8 x 50mm IP9 x 50mm IP10 x 50mm IP15 x 50mm IP20 x 50mm IP25 x 50mm IP27 x 50mm IP30 x 50mm IP40 x 50mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 Square 1/4” Power Bits - 3.5” OAL Item No. 74811 74812 74814 Description 1 x 90mm 2 x 90mm 3 x 90mm Case Pack 3 3 3 10 Pack Square 1/4” Power Bits - 2.0” OAL - 10 Pack Item No. 74813 74816 74819 Description 1 x 50mm 2 x 50mm 3 x 50mm Case Pack 3 3 3 2 Bit Pack 2 Bit Pack TORX® 1/4” Power Bits - 3.5” OAL 2 Bit Pack TORXPlus® 1/4” Power Bits - 2.0” OAL Item No. 74601 74602 74603 74604 74608 74612 74616 74620 74624 74628 74632 74636 Item No. 74563 74565 74567 74569 74571 74573 74575 74577 74579 74581 74583 Description T6 x 90mm T7 x 90mm T8 x 90mm T9 x 90mm T10 x 90mm T15 x 90mm T20 x 90mm T25 x 90mm T27 x 90mm T30 x 90mm T40 x 90mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 Square 1/4” Power Bits 2.0” OAL - 2 Bit Pack TORXPlus® 1/4” Power Bits 2.0” OAL-2 Bit Pk Item No. 74611 74613 74614 74617 74659 74660 74661 74662 74663 74664 74665 74666 74667 74668 74669 74670 Description IP1 x 50mm IP2 x 50mm IP3 x 50mm IP4 x 50mm IP5 x 50mm IP6 x 50mm IP7 x 50mm IP8 x 50mm IP9 x 50mm IP10 x 50mm IP15 x 50mm IP20 x 50mm IP25 x 50mm IP27 x 50mm IP30 x 50mm IP40 x 50mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 5 Bit Packs Item No. 74860 74861 74862 Description 1 x 50mm 2 x 50mm 3 x 50mm Case Pack 3 3 3 15 Pc. Bit Box Square 1/4” Power Bits - 2.0” OAL - 15 Pack Item No. 74863 74864 74865 Description 1 x 50mm 2 x 50mm 3 x 50mm Case Pack 10 10 10 Square 1/4” Power Bits 2.0” OAL - 3 Bit Pack Item No. Description 74890 3 Bit Pack Square: 1, 2, 3 x 50mm Case Pack 3 Square 1/4” Power Bits 2.0” OAL - 6 Bit Pack Proturn Sec. TORX® 1/4” Power Bits - 3.0” OAL 10 Pack TORX® 1/4” Power Bits - 2.0” OAL - 10 Pack Item No. 74511 74512 74513 74517 74519 74521 74523 74529 74531 74533 Description T6 x 50mm T7 x 50mm T8 x 50mm T9 x 50mm T10 x 50mm T15 x 50mm T20 x 50mm T25 x 50mm T27 x 50mm T30 x 50mm Case Pack 3 3 3 3 3 3 3 3 3 3 Item No. 74568 74570 74574 74576 Case Pack 3 3 3 3 10 Pack TORX® 1/4” Power Bits - 6.0” OAL Description T6 x 150mm T7 x 150mm T8 x 150mm T9 x 150mm T10 x 150mm T15 x 150mm T20 x 150mm T25 x 150mm T27 x 150mm T30 x 150mm Case Pack 3 3 3 3 3 3 3 3 3 Item No. 74711 74714 74717 74721 74724 74728 74732 74736 74739 74742 Description T6 x 50mm T7 x 50mm T8 x 50mm T9 x 50mm T10 x 50mm T15 x 50mm T20 x 50mm T25 x 50mm T27 x 50mm T30 x 50mm Case Pack 3 3 3 3 3 3 3 3 3 3 Ball End TORX 1/4” Power Bits 2.0” - 10Pk. ® Description T9 x 50mm T10 x 50mm T15 x 50mm T20 x 50mm T25 x 50mm T27 x 50mm T30 x 50mm T40 x 50mm Case Pack 3 3 3 3 3 3 3 3 15 Pc. Bit Box TORX® 1/4” Power Bits - 2.0” OAL - 15 Pack Item No. 74592 74593 74594 74596 74597 Description T15 x 50mm T20 x 50mm T25 x 50mm T27 x 50mm T30 x 50mm Case Pack 10 10 10 10 10 Torq Set 1/4” Power Bits - 2.0” OAL Item No. 74911 74912 74913 74914 74915 Description 4 x 50mm 5 x 50mm 6 x 50mm 8 x 50mm 10 x 50mm 2 Bit Pack TORX® Align 1/4” Power Bits - 2 Bit Pack Item No. 74524 74526 74528 74532 74534 74537 74539 74541 Case Pack 3 TORX® Align 1/4” Power Bits - 2.0” OAL Item No. 74580 74582 74584 74585 74586 74587 74588 74589 74590 74591 10 Pack Description T15s x 75mm T20s x 75mm T27s x 75mm T30s x 75mm Item No. Description 74895 6 Bit Pack 2 of each 1, 2, 3 x 50mm Item No. 74760 74761 74762 74763 74764 74765 74766 74767 74768 Description T6 x 50mm T7 x 50mm T8 x 50mm T9 x 50mm T10 x 50mm T15 x 50mm T20 x 50mm T25 x 50mm T27 x 50mm Case Pack 3 3 3 3 3 3 3 3 3 Case Pack 3 3 3 3 3 2 Bit Pack Torq Set 1/4” Power Bits - 2.0” OAL Item No. 74964 74965 74966 74967 74968 Description 4 x 50mm 5 x 50mm 6 x 50mm 8 x 50mm 10 x 50mm Case Pack 3 3 3 3 3 45 www.wihatools.com • USA | www.wihatools.ca • CANADA Power Bit Belt Pack With TORX® Align Bits Item No. Description 74981 Power Bit Belt Pack TORX Align: T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 Case Pack 3 29 Pc. 1/4” Ratchet Bit Belt Pack Set Item No. Description Case Pack 74992 1/4” Ratchet Bit Belt Pack 3 Slotted: 5.5, 6.0mm & Phillips: #0, 1, 2 & Sq.: #1, 2 Pozidriv: #1, 2 & TORX: T8, T9, T10, T15, T20, T25 Hex MM: 2.0, 2.5, 3.0, 4.0, 5.0mm/Hex In: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16”, 1/4” Bit Holder & 1/4” Bit Ratchet SYSTEM 4 ESD Prec. Interchangeable Bit Set Item No. Description Case Pack 75095 ESD Interchange Set 3 Slotted: 1.5, 2.0, 2.5, 3.0mm & Phillips: #00, 0, 1 Hex Metrc: .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm 100mm Bit Extension Power Bit Belt Pack With TORXPlus® Bits Item No. Description Case Pack 74982 Power Bit Belt Pack 3 TORXPlus: IP6, IP7, IP8, IP9, IP10, IP15, IP20, IP25, IP27, IP30 35 Pc. 1/4” Ratchet Bit Set In Metal Box Power Bit Belt Pack With Slot/Ph/TORX® Bits Item No. Description Case Pack 74983 Power Bit Belt Pack 3 Slotted: 4.5, 5.5, 6.5mm & Phillips: #1, 2, 3 TORX: T10, T15, T20, T25 Item No. Description Case Pack 74996 1/4” Ratchet Bit Set 3 Slotted: 5.5, 6.0mm & Phillips:#0, 1, 2, 3 & Sq.: #1, 2 TORX: T8, T10, T15, T20, T27, T25, T30 & Hex MM: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0mm & Hex In: 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” 1/4” Hex-1/4” Sq. Adptr, 1/4” Bit Holder & 1/4” Bit Ratchet 18 Pc. SYS 4 Interchangeable Micro Bit Set Item No. Description Case Pack 75395 Interchange Bit Set 3 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Hex Metrc: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm 100mm Bit Extension & ESD Safe Precision Handle SYSTEM 4 ESD Prec. Interchangeable Bit Set Item No. Description Case Pack 75096 ESD Interchange Set 3 Hex Inch: 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Hex Metrc: .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm 100mm Bit Extension MagicRing Screw Holding SYSTEM 4 Slotted 4mm Micro Bits - 10 Pack Item No. 75602 75603 75604 75605 75606 75607 75608 75609 75610 Description 0.8 x 28mm 1.2 x 28mm 1.5 x 28mm 1.8 x 28mm 2.0 x 28mm 2.5 x 28mm 3.0 x 28mm 3.5 x 28mm 4.0 x 28mm Case Pack 3 3 3 3 3 3 3 3 3 Power Bit Belt Pack With TORX® Bits Item No. Description Case Pack 74985 Power Bit Belt Pack 3 TORX: T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 Power Bit Belt Pack With MR Ball End Hex Bits Item No. Description 74999 Power Bit Belt Pack Inch: 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Metric: 3.0, 4.0, 5.0, 6.0mm Case Pack 3 Power Bit Belt Pack With Hex Inch/Metric Bits Item No. Description 74986 Power Bit Belt Pack Inch: 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Metric: 3.0, 4.0, 5.0, 6.0mm SYSTEM 4 ESD Prec. Interchangeable Bit Set Item No. Description Case Pack 75097 ESD Interchange Set 3 Slotted: 1.2, 1.5, 2.0, 2.5, 3.0mm & Phillips: #000, 00, 0, 1, 2 & Pentalobe: P1, P2, P3, P4 100mm Bit Extension Case Pack 3 Power Bit Belt Pack With Security TORX® Bits Item No. Description Case Pack 74987 Power Bit Belt Pack 3 Security TORX: T7s, T8s, T9s, T10s, T15s, T20s, T25, T27s, T30s, T40s Power Bit Belt Pack With Slot/Ph/Sq. Bits Item No. Description Case Pack 74988 Power Bit Belt Pack 3 Slotted: 3.0, 4.5, 5.5, 6.5mm & Phillips: #1, 2, 3 Square: 1, 2, 3 SYSTEM 4 Slotted Micro Bits - 4mm Item No. 75008 75012 75015 75018 75020 75025 75030 75035 75040 Description 0.8 x 28mm 1.2 x 28mm 1.5 x 28mm 1.8 x 28mm 2.0 x 28mm 2.5 x 28mm 3.0 x 28mm 3.5 x 28mm 4.0 x 28mm Case Pack 3 3 3 3 3 3 3 3 3 19 Pc. Quick Change Bit Belt Pack Set SYSTEM 4 ESD Prec. Interchangeable Bit Set Item No. Description Case Pack 74990 Quick Change Belt Pack 43Slotted: 4.5, 5.5, 6.5mm & Phillips: #1, 2, 3 Square: #1, 2, 3 & TORX: T10, T15, T20, T25, T30 Nut Setters: 1/4, 5/16, 3/8” magnetic 1/4” Magnetic Bit Holder Item No. Description Case Pack 75094 ESD Interchange Set 3 Slotted: 1.5, 2.0, 2.5, 3.0mm & Phillips: #00, 0, 1 Hex Inch: .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8” 100mm Bit Extension Description 000 x 28mm 00 x 28mm 0 x 28mm 1 x 28mm 2 x 28mm Case Pack 3 3 3 3 3 SYSTEM 4 Phillips Micro Bits - 4mm Item No. 75105 75110 75115 75120 75125 Description 000 x 28mm 00 x 28mm 0 x 28mm 1 x 28mm 2 x 28mm Case Pack 3 3 3 3 3 SYSTEM 4 ESD Prec. Interchangeable Bit Set Item No. Description Case Pack 75093 ESD Interchange Set 3 Slotted: 1.5, 2.0, 2.5, 3.0mm & Phillips: #00, 0, 1 TORX: T6, T7, T8, T9, T10, T15, T20 100mm Bit Extension SYSTEM 4 Phillips 4 mm Micro Bits - 10 Pack Item No. 75611 75612 75613 75614 75615 SYSTEM 4 Hex 4mm Micro Bits - 10 Pack Item No. 75616 75617 75618 75619 75620 75621 75622 75623 Description .7(0.028”) x 28mm .9(0.035”) x 28mm 1.3(.050”) x 28mm 1.5 x 28mm 2.0 x 28mm 2.5 x 28mm 3.0 x 28mm 4.0(5/32”) x 28mm Case Pack 3 3 3 3 3 3 3 3 SYSTEM 4 Hex Micro Bits - 4mm Item No. Description Metric 75307 .7(0.028”) x 28mm 75309 .9(0.035”) x 28mm 75313 1.3(.050”) x 28mm 75315 1.5 x 28mm 75320 2.0 x 28mm 75325 2.5 x 28mm 75330 3.0 x 28mm 75340 4.0(5/32”) x 28mm Inch 75350 1/16 x 1.1” 75352 5/64 x 1.1” 75354 3/32 x 1.1” 75356 7/64 x 1.1” 75358 1/8 x 1.1” 75360 9/64 x 1.1” Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 SYSTEM 4 Hex 4mm Micro Bits - 10 Pack Item No. 75628 75629 75630 75631 75632 75633 75634 75635 75636 75637 Description .028 x 1.1” .035 x 1.1” .050 x 1.1” 1/16 x 1.1” 5/64 x 1.1” 3/32 x 1.1” 7/64 x 1.1” 1/8 x 1.1” 9/64 x 1.1” 5/32 x 1.1” Case Pack 3 3 3 3 3 3 3 3 3 3 46 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA 4mm Micro Bit Inch Nut Setters - 10 Pack Item No. 75644 75645 75646 75647 75648 75649 75650 75651 Description 5/64” x 1.2” 3/32” x 1.2” 7/64” x 1.2” 1/8” x 1.2” 9/64” x 1.2” 5/32” x 1.2” 3/16” x 1.2” 7/32” x 1.2” Case Pack 3 3 3 3 3 3 3 3 SYSTEM 4 TORX® Micro Bits - 4mm Item No. 75701 75702 75703 75704 75705 75706 75707 75708 75709 75710 75715 75720 Description T1 x 28mm T2 x 28mm T3 x 28mm T4 x 28mm T5 x 28mm T6 x 28mm T7 x 28mm T8 x 28mm T9 x 28mm T10 x 28mm T15 x 28mm T20 x 28mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 Micro Bit 4mm To 1/4” Socket Adapter Item No. Description 75806 1.125”/28mm OAL Case Pack 3 65 Pc. SYS 4 Master Tech ESD, Ratchet & Bit Set Item No. Description Case Pack 75965 Interchange Bit Set 3 Slotted: .8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: #000, 00, 0, 1 TORX: T3, T4, T5, T6, T7, T8, T9, T10, T15, T20 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Hex Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Nut Drv In: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32” Nut Drv MM: 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 72 Tooth Bit Ratchet & Magnetic 1/4” to 4mm Adapter ESD Safe Precision Handle & 100mm Bit Extension 4mm Micro Bit Metric Nut Setters - 10 Pack Item No. 75652 75653 75654 75655 75656 75657 75658 75659 Description 2.0mm x 30mm 2.5mm x 30mm 3.0mm x 30mm 3.5mm x 30mm 4.0mm x 30mm 4.5mm x 30mm 5.0mm x 30mm 5.5mm x 30mm Case Pack 3 3 3 3 3 3 3 3 SYSTEM 4 Pentalobe Micro Bits - 4mm Item No. 75743 75744 75745 75746 75747 75748 Description PL1 x 28mm PL2 x 28mm PL3 x 28mm PL4 x 28mm PL5 x 28mm PL6 x 28mm Case Pack 3 3 3 3 3 3 Description T1 x 28mm T2 x 28mm T3 x 28mm T4 x 28mm T5 x 28mm T6 x 28mm T7 x 28mm T8 x 28mm T9 x 28mm T10 x 28mm T15 x 28mm T20 x 28mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 SYSTEM 4 Pentalobe 4mm Micro Bits-10 Pk Item No. 75672 75673 75674 75675 75676 Description PL1 x 28mm PL2 x 28mm PL3 x 28mm PL4 x 28mm PL5 x 28mm Case Pack 3 3 3 3 3 Item No. 75810 75811 75812 75813 75814 75815 75816 75817 Description 5/64” x 1.2” 3/32” x 1.2” 7/64” x 1.2” 1/8” x 1.2” 9/64” x 1.2” 5/32” x 1.2” 3/16” x 1.2” 7/32” x 1.2” Case Pack 3 3 3 3 3 3 3 3 With Dust Cover 68 Pc. SYS 4 Master Tech ESD Micro Bit Set Item No. Description Case Pack 75968 Interchange Bit Set 3 Slotted: .8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: #000, 00, 0, 1, 2 TORX: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T15, T20 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Hex Metrc: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Nut Drv In: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32” Nut Drv MM: 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 100mm Bit Extension, Magnetic 1/4” to 4mm Adapter ESD Safe Precision Handle & Micro Bit Storage Handle Micro Bit Metric Nut Setters - 4mm SYSTEM 4 TORX® 4mm Micro Bits - 10 Pack Item No. 75660 75661 75662 75663 75664 75665 75666 75667 75668 75669 75670 75671 Micro Bit Inch Nut Setters - 4mm SYSTEM 4 MicroBit To 1/4” Insert Bit Adapter Item No. Description 75802 4.0mm x 25mm Description 2.0mm x 30mm 2.5mm x 30mm 3.0mm x 30mm 3.5mm x 30mm 4.0mm x 30mm 4.5mm x 30mm 5.0mm x 30mm 5.5mm x 30mm Case Pack 3 3 3 3 3 3 3 3 Case Pack 3 SYS 4 Long MicroBit To 1/4” Insert Bit Adapter Item No. Description 75803 4.0mm x 39mm Item No. 75820 75821 75822 75823 75824 75825 75826 75827 Case Pack 3 68 Pc. SYS 4 Master Tech ESD Micro Bit Set Item No. Description Case Pack 75971 Interchange Bit Set 3 Slotted: .8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: #000, 00, 0, 1, 2 TORX: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T15, T20 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Hex Metrc: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Nut Drv In: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32” Nut Drv MM: 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 100mm Bit Extension, Magnetic 1/4” to 4mm Adapter ESD Safe Precision Handle & Micro Bit Storage Handle SYSTEM 4 Extension Blade For Micro Bits Item No. Description 75900 4.0 x 100mm Case Pack 3 23 Pc. Micro Bit Set With PicoFinish® Handle SYSTEM 4 Micro Bit Storage Handle Item No. Description 75805 4.0mm x 108mm Case Pack 3 Micro Bit 1/4” Drive Power Tool Adapter Item No. Description 75902 4.0 x 60mm Case Pack 3 Item No. Description Case Pack 75973 Interchange Bit Set 3 Slotted: 1.5, 2.0, 2.5, 3.0, 3.5mm Phillips: #000, 00, 0, 1, 2 TORX: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Micro Bit Extension Holder 100mm Micro Bit Socket Adapter - 1/4” PicoFinish® Precision Handle 47 www.wihatools.com • USA | www.wihatools.ca • CANADA SYSTEM 4 Micro Bit Handle Storage Set 68 Pc. SYS 4 Master Tech ESD Micro Bit Set Item No. Description Case Pack 75977 Interchange Bit Set 3 Slotted: .8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: #000, 00, 0, 1, 2 TORX: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T15, T20 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Hex Metrc: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Nut Drv In: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32” Nut Drv MM: 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 100mm Bit Extension, Magnetic 1/4” to 4mm Adapter ESD Safe SYSTEM 4 Precision Handle & ESD Fine Round Point Tweezers 3cSA Item No. Description 75983 Micro Bit Set Hex: .050, 1/16, 5/64, 3/32, 7/64, 1/8” Case Pack 3 27 Pc. SYSTEM 4 Interchangeable Bit Set 40 Pc. SYSTEM 4 Interchangeable Bit Set Item No. Description Case Pack 75991 Interchangeable Bit Set 3 Slt: 1.5, 2.0, 3.0, 4.0mm & Ph: #000, 00, 0, 1 TORX: T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex In: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension & Standard Precision Handle Item No. Description Case Pack 75996 Interchangeable Bit Set 3 Slotted: .8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: #000, 00, 0, 1 TORX: T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Hex Metric: 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm 100mm Bit Extension & ESD Safe Precision Handle 10 Piece Slotted Micro Bit Set Item No. Description Case Pack 75984 Micro Bit Set 3 Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5(2), 3.0, 3.5, 4.0mm 8 Piece Hex Metric Micro Bit Set Item No. Description Case Pack 75978 Micro Bit Set 3 Hex Metric: 0.7, 0.9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm 27 Pc. SYSTEM 4 Interchangeable Bit Set 26 Pc. SYSTEM 4 Interchangeable Bit Set Item No. Description Case Pack 75992 Interchangeable Bit Set 3 Slotted: 1.5, 2.0, 3.0, 4.0mm & Ph: #000, 00, 0, 1 TORX: T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex In: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension & ESD Safe Precision Handle Item No. Description Case Pack 75999 Interchangeable Bit Set 3 Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: #000, 00, 0, 1 Hex In: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Hex Metric: .71, .89, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm 100mm Bit Extension & Standard Precision Handle SYSTEM 4 Micro Bit Handle Storage Set Item No. Description 75985 Micro Bit Set TORX: T3, T4, T5, T6, T7, T8 Case Pack 3 28 Pc. ESD Safe Micro Bit & Tweezer Set Item No. Description Case Pack 75993 ESD Safe Precision Set 3 Slotted: 0.8, 1.5, 2.0, 2.5, 3.0, 3.5mm Phillips: #000, #00, #0, #1 TORX: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Tweezers: 5SA ESD, 7aSA ESD, 2ASA ESD, AASA ESD, OOSA ESD ESD Micro Bit Precision Handle, 100mm Bit Holder & 1/4” to 4mm Adapter 39 Piece Mini Micro Bit Set In Metal Box Item No. Description Case Pack 75980 Mini Micro Bit Set 3 Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: #000, 00, 0, 1, 2 TORX: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Hex Metric: 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 ESD Safe Precision Handle 100mm Bit Extension & 4.0mm to 1/4” Adapter 10 Piece Phillips & Pentalobe Micro Bit Set Item No. Description Case Pack 75986 Micro Bit Set 3 Phillips: #000, 00, 0, 1 Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 27 Pc. SYSTEM 4 Interchangeable Bit Set SYSTEM 4 Micro Bit Handle Storage Set Item No. Description Case Pack 75981 Micro Bit Set 3 Slotted: 1.2, 1.5, 2.0 Phillips: #000, 00, 0 10 Piece Slotted & Phillips Micro Bit Set Item No. Description 75987 Micro Bit Set Slotted: 1.5, 2.0, 2.5, 3.0, 3.5mm Phillips: #000, 00, 0, 1, 2 Case Pack 3 Item No. Description Case Pack 75994 Interchangeable Bit Set 3 Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: #000, 00, 0, 1 TORX: T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Metric: .71, .89, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm 100mm Bit Extension & ESD Safe Precision Handle 1/4” Square Drive TORX® Sockets Item No. 76106 76107 76109 76111 76113 76117 76119 76121 76123 76129 76131 Description T6 x 38mm T7 x 38mm T8 x 38mm T9 x 38mm T10 x 38mm T15 x 38mm T20 x 38mm T25 x 38mm T27 x 38mm T30 x 38mm T40 x 38mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3/8” Square Drive Security Hex Metric Sockets Item No. 76132 76133 76134 76135 76136 76137 76138 Description 2.0 X 42MM 2.5 x 42mm 3.0 x 42mm 4.0 x 42mm 5.0 x 42mm 6.0 x 42mm 8.0 x 42mm Case Pack 3 3 3 3 3 3 3 3/8” Square Drive Security Hex Inch Sockets 26 Pc. SYSTEM 4 Interchangeable Bit Set 10 Piece Hex Inch Micro Bit Set 10 Piece TORX Micro Bit Set Item No. Description Case Pack 75982 Micro Bit Set 3 Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Item No. Description Case Pack 75988 Micro Bit Set 3 TORX: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Item No. Description Case Pack 75995 Interchangeable Bit Set 3 Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: #000, 00, 0, 1 TORX: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 Bit Extension & ESD Safe Precision Handle Item No. 76164 76165 76166 76167 76168 76169 76170 76171 76172 Description 5/64 x 42mm 3/32 x 42mm 7/64 x 42mm 1/8 x 42mm 9/64 x 42mm 5/32 x 42mm 3/16 x 42mm 7/32 x 42mm 1/4 x 42mm Case Pack 3 3 3 3 3 3 3 3 3 48 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA 6 Pc. 1/4” Sq. Dr. TORX® Socket Set Item No. Description 76194 TORX Socket Set TORX: T10, T15, T20, T25, T27, T30 Case Pack 3 3/8” Square Drive TORX® Sockets Item No. 76312 76314 76316 76318 76322 76324 76326 76328 Description T9 x 42mm T10 x 42mm T15 x 42mm T20 x 42mm T25 x 42mm T27 x 42mm T30 x 42mm T40 x 42mm Case Pack 3 3 3 3 3 3 3 3 9 Pc. 1/4” & 3/8” Sq. Dr. Security Sockets Item No. Description Case Pack 76397 Security TORX Sockets 3 1/4”: T10s, T15s, T20s, T25s, T27s, T30s 3/8”: T40s (1/4” bit), T45s & T50s (5/16” Bit) 1/2” Square Drive TORX® Sockets Item No. 76403 76406 76407 Description T30 x 59mm T50 x 59mm T55 x 59mm Case Pack 3 3 3 1/4” Phillips Insert Terminator Impact Bits Item No. 76501 76502 76503 Description 1 x 29mm - 10pk 2 x 29mm - 10pk 3 x 29mm - 10pk Case Pack 3 3 3 1/4” Pozidriv® Insert Terminator Impact Bits Item No. 76506 76507 76508 Description 1 x 29mm - 10pk 2 x 29mm - 10pk 3 x 29mm - 10pk Case Pack 3 3 3 1/4” TORX® Insert Terminator Impact Bits 1/4” Square Drive Security TORX® Sockets Item No. 76330 76331 76332 76333 76334 76335 76336 76337 76338 Description T8s x 38mm T9s x 38mm T10s x 38mm T15s x 38mm T20s x 38mm T25s x 38mm T27s x 38mm T30s x 38mm T40s x 38mm Case Pack 3 3 3 3 3 3 3 3 3 3/8” Square Drive Security TORX® Sockets Item No. 76339 76340 76341 Description T40s x 51mm T45s x 51mm T50s x 51mm Case Pack 3 3 3 1/2” Square Drive Security TORX® Sockets Item No. 76411 76412 76413 76414 Description T40s x 59mm T45s x 59mm T50s x 59mm T55s x 59mm Case Pack 3 3 3 3 1/2” Square Drive Slotted Sockets Item No. Description 76418 10 x 59mm 76419 12 x 59mm Case Pack 3 3 Item No. 76510 76511 76512 76513 76514 76516 76517 Description T10 x 29mm - 10pk T15 x 29mm - 10pk T20 x 29mm - 10pk T25 x 29mm - 10pk T27 x 29mm - 10pk T30 x 29mm - 10pk T40 x 29mm - 10pk Case Pack 3 3 3 3 3 3 3 Item No. Description 76352 T50 x 51mm 76354 T55 x 51mm Case Pack 3 3 8 Pc. 3/8” Sq. Dr. TORX® Socket Set Item No. Description Case Pack 76395 TORX Socket Set 3 TORX: T9, T10, T15, T20, T25, T27, T30, T40 1/2” Square Drive Phillips Sockets Item No. Description 76422 2 x 59mm 76423 3 x 59mm Case Pack 3 3 Description 1 x 49mm - 10pk 2 x 49mm - 10pk 3 x 49mm - 10pk Case Pack 3 3 3 1/4” Pozidriv® Power Terminator Impact Bits Item No. 76548 76549 76550 Description 1 x 49mm - 10pk 2 x 49mm - 10pk 3 x 49mm - 10pk Case Pack 3 3 3 1/4” TORX® Power Terminator Impact Bits Item No. 76553 76554 76555 76556 76557 76558 76559 Description T10 x 49mm - 10pk T15 x 49mm - 10pk T20 x 49mm - 10pk T25 x 49mm - 10pk T27 x 49mm - 10 pk T30 x 49mm - 10pk T40 x 49mm - 10pk Case Pack 3 3 3 3 3 3 3 1/4” Hex Metric Insert Terminator Impact Bits 1/4” Hex Metric Power Terminator Impact Bits Item No. 76523 76524 76525 76526 Item No. 76563 76564 76565 76566 Description 3 x 29mm - 10pk 4 x 29mm - 10pk 5 x 29mm - 10pk 6 x 29mm - 10pk Case Pack 3 3 3 3 1/4” Hex Inch Insert Terminator Impact Bits 3/8” Square Drive TORX® Sockets - 5/16” Bits 1/4” Phillips Power Terminator Impact Bits Item No. 76543 76544 76545 Item No. 76530 76531 76532 76533 76534 76535 Description 1/8 x 29mm - 10pk 9/64 x 29mm - 10pk 5/32 x 29mm - 10pk 3/16 x 29mm - 10pk 7/32 x 29mm - 10pk 1/4 x 29mm - 10pk Case Pack 3 3 3 3 3 3 1/4” Square Insert Terminator Impact Bits Item No. 76538 76539 76540 Description 1 x 29mm - 10pk 2 x 29mm - 10pk 3 x 29mm - 10pk Case Pack 3 3 3 Description 3 x 49mm - 10pk 4 x 49mm - 10pk 5 x 49mm - 10pk 6 x 49mm - 10pk Case Pack 3 3 3 3 1/4” Hex Inch Power Terminator Impact Bits Item No. 76570 76571 76572 76573 76574 76575 Description 1/8 x 49mm - 10pk 9/64 x 49mm - 10pk 5/32 x 49mm - 10pk 3/16 x 49mm - 10pk 7/32 x 49mm - 10pk 1/4 x 49mm - 10pk Case Pack 3 3 3 3 3 3 1/4” Square Power Terminator Impact Bits Item No. 76578 76579 76580 Description 1 x 49mm - 10pk 2 x 49mm - 10pk 3 x 49mm - 10pk Case Pack 3 3 3 49 www.wihatools.com • USA | www.wihatools.ca • CANADA 250 Packs 100 Packs 15 Pack In Bit Box 25 Pack In Bit Box 1/4” Phillips Insert Terminator Impact Bits Item No. Description 73501 1 x 29mm - 100pk 73502 2 x 29mm - 100pk Case Pack 1 1 1/4” Pozidriv® Insert Terminator Impact Bits Item No. 73504 73505 73506 Description 1 x 29mm - 100pk 2 x 29mm - 100pk 3 x 29mm - 100pk Case Pack 1 1 1 1/4” Phillips Insert Terminator Impact Bits Item No. 76581 76582 76500 Description 1 x 29mm - 250pk 2 x 29mm - 250pk 3 x 29mm - 250pk Case Pack 1 1 1 1/4” Phillips Insert Terminator Impact Bits Item No. 76601 76602 76603 Case Pack 1 1/4” Hex Metric Insert Terminator Impact Bits Item No. 76583 76584 76537 1/4” TORX Insert Terminator Impact Bits 1/4” Phillips Power Terminator Impact Bits Item No. 76641 76642 76643 Case Pack 1 1 Description 1 x 49mm - 15pk 2 x 49mm - 15pk 3 x 49mm - 15pk Case Pack 10 10 10 Description T15 x 29mm - 250pk T20 x 29mm - 250pk T25 x 29mm - 250pk T27 x 29mm - 250pk T30 x 29mm - 250pk Case Pack 1 1 1 1 1 15 Pack In Bit Box 25 Pack In Bit Box 1/4” TORX® Insert Terminator Impact Bits Item No. Description 73508 T20 x 29mm - 100pk Case Pack 10 10 10 1/4” Pozidriv® Insert Terminator Impact Bits Item No. Description 76504 1 x 29mm - 250pk 76505 2 x 29mm - 250pk Item No. 76585 76586 76587 76588 76589 ® Description 1 x 29mm - 25pk 2 x 29mm - 25pk 3 x 29mm - 25pk 1/4” Pozidriv® Insert Terminator Impact Bits Item No. 76606 76607 76608 Description 1 x 29mm - 25pk 2 x 29mm - 25pk 3 x 29mm - 25pk Case Pack 10 10 10 1/4” Square Power Terminator Impact Bits Item No. 76644 76645 76646 Description 1 x 49mm - 15pk 2 x 49mm - 15pk 3 x 49mm - 15pk Case Pack 10 10 10 1/4” Square Insert Terminator Impact Bits Item No. Description 73512 3.0mm x 29mm - 100pk 73514 5.0mm x 29mm - 100pk Case Pack 1 1 1/4” Phillips Power Terminator Impact Bits Case Pack 1 1 Case Pack 1 1 1 1/4” Hex Metric Insert Terminator Impact Bits Item No. 73515 73518 73519 73520 Item No. Description 73526 2 x 49mm - 100pk 73527 3 x 49mm - 100pk Description 1 x 29mm - 250pk 2 x 29mm - 250pk 3 x 29mm - 250pk Description 3.0mm x 29mm - 250pk 4.0mm x 29mm - 250pk 5.0mm x 29mm - 250pk 6.0mm x 29mm - 250pk Case Pack 1 1 1 1 15 Pack In Bit Box 25 Pack In Bit Box 1/4” TORX® Insert Terminator Impact Bits Item No. 76610 76611 76612 76613 76614 76616 76617 Description T10 x 29mm - 25pk T15 x 29mm - 25pk T20 x 29mm - 25pk T25 x 29mm - 25pk T27 x 29mm - 25pk T30 x 29mm - 25pk T40 x 29mm - 25pk Case Pack 10 10 10 10 10 10 10 Description 1/8 x 29mm - 250pk 9/64 x 29mm - 250pk 5/32 x 29mm - 250pk 3/16 x 29mm - 250pk 7/32 x 29mm - 250pk 1/4 x 29mm - 250pk Case Pack 1 1 1 1 1 1 Item No. 73528 73529 73530 Description 1 x 49mm - 100pk 2 x 49mm - 100pk 3 x 49mm - 100pk Case Pack 1 1 1 1/4” Phillips Power Terminator Impact Bits Item No. 76590 76591 76541 Description 1 x 49mm - 250pk 2 x 49mm - 250pk 3 x 49mm - 250pk Case Pack 1 1 1 Description 1 x 49mm - 15pk 2 x 49mm - 15pk 3 x 49mm - 15pk Case Pack 10 10 10 15 Pack In Bit Box 1/4” Hex Inch Insert Terminator Impact Bits Item No. 73521 73522 73527 73528 73529 73536 1/4” TORX® Power Terminator Impact Bits 25 Pack In Bit Box 1/4” Hex Metric Insert Terminator Impact Bits 1/4” Pozidriv® Power Terminator Impact Bits 1/4” Pozidriv® Power Terminator Impact Bits Item No. 76647 76648 76649 Item No. 76623 76624 76625 76626 Description 3.0mm x 29mm - 25pk 4.0mm x 29mm - 25pk 5.0mm x 29mm - 25pk 6.0mm x 29mm - 25pk Case Pack 10 10 10 10 Item No. 76650 76651 76652 76653 76654 76655 76656 Description T10 x 49mm - 15pk T15 x 49mm - 15pk T20 x 49mm - 15pk T25 x 49mm - 15pk T27 x 49mm - 15pk T30 x 49mm - 15pk T40 x 49mm - 15pk Case Pack 10 10 10 10 10 10 10 15 Pack In Bit Box 1/4” Pozidriv® Power Terminator Impact Bits 1/4” Hex Metric Power Terminator Impact Bits Item No. 73536 73537 73538 Description 3.0mm x 49mm - 100pk 4.0mm x 49mm - 100pk 5.0mm x 49mm - 100pk Case Pack 1 1 1 Item No. 73542 73546 73547 Description 1 x 49mm - 250pk 2 x 49mm - 250pk 3 x 49mm - 250pk Case Pack 1 1 1 1/4” TORX® Power Terminator Impact Bits Item No. 76594 76595 76596 76597 76598 Description T15 x 49mm - 250pk T20 x 49mm - 250pk T25 x 49mm - 250pk T27 x 49mm - 250pk T30 x 49mm - 250pk Case Pack 1 1 1 1 1 25 Pack In Bit Box 1/4” Hex Metric Power Terminator Impact Bits 1/4” Hex Inch Insert Terminator Impact Bits Item No. 76630 76631 76632 76633 76634 76635 Description 1/8 x 29mm - 25pk 9/64 x 29mm - 25pk 5/32 x 29mm - 25pk 3/16 x 29mm - 25pk 7/32 x 29mm - 25pk 1/4 x 29mm - 25pk Case Pack 10 10 10 10 10 10 Item No. 76592 76593 76599 Description 1 x 49mm - 250pk 2 x 49mm - 250pk 3 x 49mm - 250pk Case Pack 1 1 1 Description 3 x 49mm - 15pk 4 x 49mm - 15pk 5 x 49mm - 15pk 6 x 49mm - 15pk Case Pack 10 10 10 10 15 Pack In Bit Box 1/4” Hex Inch Power Terminator Impact Bits 25 Pack In Bit Box 1/4” Square Power Terminator Impact Bits Item No. 76663 76664 76665 76666 1/4” Square Insert Terminator Impact Bits Item No. 76638 76639 76640 Description 1 x 29mm - 25pk 2 x 29mm - 25pk 3 x 29mm - 25pk Case Pack 10 10 10 Item No. 76670 76671 76672 76673 76674 76675 Description 1/8 x 49mm - 15pk 9/64 x 49mm - 15pk 5/32 x 49mm - 15pk 3/16 x 49mm - 15pk 7/32 x 49mm - 15pk 1/4 x 49mm - 15pk Case Pack 10 10 10 10 10 10 50 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA Power Bits 1/4” Phillips Insert Terminator Impact Bits Item No. 76801 76802 76803 Description 1 x 29mm - 2pk 2 x 29mm - 2pk 3 x 29mm - 2pk Case Pack 3 3 3 1/4” TORX® Power Terminator Impact Bits Item No. 76853 76854 76855 76856 76857 76858 76859 Description T10 x 49mm - 2pk T15 x 49mm - 2pk T20 x 49mm - 2pk T25 x 49mm - 2pk T27 x 49mm - 2pk T30 x 49mm - 2pk T40 x 49mm - 2pk Case Pack 3 3 3 3 3 3 3 1/4” Pozidriv® Insert Terminator Impact Bits Item No. 76806 76807 76808 Description 1 x 29mm - 2pk 2 x 29mm - 2pk 3 x 29mm - 2pk Case Pack 3 3 3 1/4” TORX® Insert Terminator Impact Bits Item No. 76810 76811 76812 76813 76814 76816 76817 Description T10 x 29mm - 2pk T15 x 29mm - 2pk T20 x 29mm - 2pk T25 x 29mm - 2pk T27 x 29mm - 2pk T30 x 29mm - 2pk T40 x 29mm - 2pk Case Pack 3 3 3 3 3 3 3 1/4” Hex Metric Insert Terminator Impact Bits Item No. 76823 76824 76825 76826 Description 3 x 29mm - 2pk 4 x 29mm - 2pk 5 x 29mm - 2pk 6 x 29mm - 2pk 1/4” Hex Metric Power Terminator Impact Bits Item No. 76863 76864 76865 76866 Description 3 x 49mm - 2pk 4 x 49mm - 2pk 5 x 49mm - 2pk 6 x 49mm - 2pk Case Pack 3 3 3 3 Terminator Impact Bit Buddy Sets In Pouch Phillips, Square & TORX® Bit Buddy Set Item No. Description Case Pack 76886 34 Pc. Impact Bit Sets 1 29mm Insert Bits Phillips: #2, 3 & Square: #2, 3 TORX®: T20, T25, T30 & Hex Metric: 4.0, 5.0, 6.0mm Hex Inch: 5/32, 3/16, 7/32, 1/4” 49mm Insert Bits Phillips: #2, 3 & Square: #2, 3 & TORX®: T20, T25, T30 & Hex Metric: 4.0, 5.0, 6.0mm Hex Inch: 5/32, 3/16, 7/32, 1/4” 2 Magnetic Bit Holders 1/4” x 59mm 2 SlimFix Locking Bit Holder 2 Belt Clips for Bit Buddy Cases Item No. Description Case Pack 76892 7 Pc. Terminator Set 3 Phillips: #2, 3 & Sq.: #2, 3 & TORX: T20, T25, T30 Includes magnetic bit holder Insert Bits Hex Inch & Metric Terminator Bit Buddy Set Item No. Description Case Pack 76893 7 Pc. Terminator Set 3 Inch: 5/32, 3/16, 7/32, 1/4 & Metric: 4.0, 5.0, 6.0mm 1/4” Hex Inch Power Terminator Impact Bits Item No. 76870 76871 76872 76873 76874 76875 Description 1/8 x 49mm - 2pk 9/64 x 49mm - 2pk 5/32 x 49mm - 2pk 3/16 x 49mm - 2pk 7/32 x 49mm - 2pk 1/4 x 49mm - 2pk Case Pack 3 3 3 3 3 3 Case Pack 3 3 3 3 1/4” Square Power Terminator Impact Bits Item No. 76878 76879 76880 Description 1 x 49mm - 2pk 2 x 49mm - 2pk 3 x 49mm - 2pk Case Pack 3 3 3 32 Pc. Go Box Impact Bit Set Item No. Description Case Pack 76889 32 Pc. Impact Bit Set 6 Phillips: #1, 2, 3 (2 of each) ® Pozidriv : #1, 2, 3 & Square: #1, 2, 3 Hex Inch: 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Hex Metric: 3.0, 4.0, 5.0, 6.0mm TORX: T10, T15, T20, T25, T27, T30, T40 72 Tooth ratchet bit holder handle 1/4” SlimFix Bit Holder 1/4” Square Socket Adapter Power Bits Hex Inch & Metric Terminator Bit Buddy Set Item No. Description Case Pack 76894 7 Pc. Terminator Set 3 Inch: 5/32, 3/16, 7/32, 1/4 & Metric: 4.0, 5.0, 6.0mm 1/4” Hex Inch Insert Terminator Impact Bits Item No. 76830 76831 76832 76833 76834 76835 Description 1/8 x 29mm - 2pk 9/64 x 29mm - 2pk 5/32 x 29mm - 2pk 3/16 x 29mm - 2pk 7/32 x 29mm - 2pk 1/4 x 29mm - 2pk Case Pack 3 3 3 3 3 3 Power Bits Includes magnetic bit holder Insert Bits Hex Inch & Metric Bit Buddy Set 1/4” Square Insert Terminator Impact Bits Item No. 76838 76839 76840 Description 1 x 29mm - 2pk 2 x 29mm - 2pk 3 x 29mm - 2pk Case Pack 3 3 3 Item No. Description 76876 10 Pc. Terminator Set Inch: 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Metric: 3.0, 4.0, 5.0, 6.0mm Case Pack 3 Phillips, Square & TORX® Bit Buddy Set TORX Terminator Impact Power Bit Buddy Set Item No. Description Case Pack 76890 7 Pc. Terminator Set 3 3 Phillips: #2 & Sq.: #2 & TORX: T15, T20, T25 Item No. Description Case Pack 76896 7 Pc. Terminator Set 3 TORX: T10, T15, T20, T25, T27, T30, T40 TORX® Bit Buddy Set 1/4” Phillips Power Terminator Impact Bits Item No. 76843 76844 76845 Description 1 x 49mm - 2pk 2 x 49mm - 2pk 3 x 49mm - 2pk Case Pack 3 3 3 1/4” Pozidriv® Power Terminator Impact Bits Item No. 76848 76849 76850 Description 1 x 49mm - 2pk 2 x 49mm - 2pk 3 x 49mm - 2pk Case Pack 3 3 3 Item No. Description Case Pack 76877 10 Pc. Terminator Set 3 TORX®: T10, T15, T20 (2), T25 (2), T27, T30 (2), T40 TORX®, Phillips & Square Bit Buddy Set Item No. Description 76881 10 Pc. Terminator Set TORX®: T20, T25, T30, T40 Phillips: #1, 2, 3 & Square: #1, 2, 3 Case Pack 3 Insert Bits Insert Bits Includes magnetic bit holder Includes magnetic bit holder Phillips, Square & TORX® Bit Buddy Set TORX Terminator Impact Insert Bit Buddy Set Item No. Description Case Pack 76891 7 Pc. Terminator Set 3 Phillips: #2, 3 & Sq.: #2, 3 & TORX: T20, T25, T30 Item No. Description Case Pack 76895 7 Pc. Terminator Set 3 TORX: T10, T15, T20, T25, T27 T30, T40 51 www.wihatools.com • USA | www.wihatools.ca • CANADA 1/4” Drive TORX® 6” Long Sockets 28 Pc. Terminator Impact Bit Set Item No. Description Case Pack 76897 28 Pc. Terminator Set 3 1/4” Bit Holder & Phillips: #1, 2 (2), 3 Pozidriv: #1, 2, 3 & Square: #1, 2, 3 Hex Inch: 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Hex Metric: 3.0, 4.0, 5.0, 6.0mm TORX: T10, T15, T20, T25 (2), T30, T40 Item No. 77151 77152 77153 77154 77156 77158 77160 77162 77164 Description T8 x 6” OAL T10 x 6” OAL T9 x 6” OAL T15 x 6” OAL T20 x 6” OAL T25 x 6” OAL T27 x 6” OAL T30 x 6” OAL T40 x 6” OAL Case Pack 3 3 3 3 3 3 3 3 3 22 Pc. 1/4” Drive 6” Long Blade Socket Set Item No. Description Case Pack 77198 22 Pc. Long Socket Set 1 Hex In: 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Hex Metric: 2.5, 3.0, 4.0, 5.0, 6.0mm TORX: T8, T9, T10, T15, T20, T25, T27, T30, T40 Fits 26inOne Ultra Driver 1/4” Socket Adapter 30mm OAL - 2 Pack Item No. Description 77741 1/4” Socket Adapter 3/8” Drive Hex Inch 6” Long Sockets 34 Pc. Terminator Impact Bit Set Item No. Description Case Pack 76899 34 Pc. Terminator Set 3 Phillips: #1, 2, 3 (2 of each) Pozidriv: #1, 2, 3 & Square: #1, 2 (2), 3 Hex Inch: 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Hex Metric: 3.0, 4.0, 5.0, 6.0mm TORX: T10, T15, T20 (2), T25 (2), T30 (2), T40 1/4” Bit Holding Handle & 1/4” Bit Holder Item No. 77165 77167 77169 77171 77173 77175 77177 77179 Description 3/32 x 6” OAL 7/64 x 6” OAL 1/8 x 6” OAL 9/64 x 6” OAL 5/32 x 6” OAL 3/16 x 6” OAL 7/32 x 6” OAL 1/4 x 6” OAL Case Pack 3 3 3 3 3 3 3 3 3/8” Drive Hex Metric 6” Long Sockets Item No. 77180 77182 77184 77186 77188 Description 2.5 x 6” OAL 3.0 x 6” OAL 4.0 x 6” OAL 5.0 x 6” OAL 6.0 x 6” OAL Case Pack 3 3 3 3 3 HVAC Ultra Driver Bit Reload Item No. Description Case Pack 77784 13 Pc. Bit Reload 3 Slotted: 3.0x4.5, 5.5x6.5mm & Phillips: #1x2, #0x3 Square: #1x2 & TORX: T10xT15, T20xT25 Hex Inch: 5/32x3/16, 7/32x1/4, 3/8” Adapters: 1/4” Hex to 1/4” Square Stem Valve: Double End Core Stem Valve 1/4” Valve Socket Adapter Case Pack 3 HVAC In Clamshell Tradesman Bit Reload 22 Tips HVAC Ultra Driver 13 Pc. Set 13 Pc. Double End Bit Reload For Ultra Driver Item No. Description Case Pack 77780 13 Pc. Bit Reload 3 Slotted: 3.0x4.5, 5.5x6.5mm & Phillips: #1x2, #0x3 ® Square: #1x2, #0x3 & Pozidriv : #1x2 TORX: T10xT15, T20xT25 & Hex Inch: 1/8x9/64, 5/32x3/16” & Hex Metric: 3.0x4.0, 5.0x6.0mm Technician’s Bit Reload Item No. Description Case Pack 77785 23inOne Set-1/4” Bits 3 Slotted: 3.0x4.5, 5.5x6.5mm & Phillips: #1x2, #0x3 Square: #1x2 & TORX: T10xT15, T20xT25 Hex Inch: 5/32x3/16, 7/32x1/4, 3/8” Adapters: 1/4” Hex to 1/4” Square Stem Valve: Double End Core Stem Valve 1/4” Valve Socket Adapter Security 26inOne Security Ultra Driver 14 Pc. Set 13 Pc. Double End Bit Reload For Ultra Driver Item No. Description Case Pack 77781 13 Pc. Bit Reload 3 Slotted: 3.0x4.5, 4.0x6.0, 5.5x6.5mm & Pozidriv: #1x2 Phillips: #1x2, #0x3 & Square: #1x2, #0x3 TORX: T6xT7, T8xT9, T10xT15, T20xT25, T27xT30 Item No. Description Case Pack 77789 26inOne Set-1/4” Bits 3 Spanner: #4 x #6, #8 x #10 & Square: #1x #2 Phillips/Slotted: #2 x 5.5mm & Security TORX: T8s x T9s, T10s x T15s, T20s x T25s, T27s x T30s Security Hex Inch: 1/8 x 9/64, 5/32 x 3/16, 7/32 x 1/4” Security Hex Metric: 3.0 x 4.0, 5.0 x 6.0mm 3/8” Drive TORX® 6” Long Sockets Item No. 77101 77103 77105 77107 77109 77111 77113 77115 77117 Description T8 x 6’ OAL T9 x 6” OAL T10 x 6’ OAL T15 x 6” OAL T20 x 6” OAL T25 x 6” OAL T27 x 6” OAL T30 x 6” OAL T40 x 6” OAL Case Pack 3 3 3 3 3 3 3 3 3 Industrial Bit Reload 13 Pc. Double End Bit Reload For Ultra Driver 8 Pc. 1/4” Drive Hex Inch 6” Long Socket Set 1/4” Drive Hex Inch 6” Long Sockets Item No. 77128 77130 77132 77134 77136 77138 77139 77141 Description 3/32 x 6” OAL 7/64 x 6” OAL 1/8 x 6” OAL 9/64 x 6” OAL 5/32 x 6” OAL 3/16 x 6” OAL 7/32 x 6” OAL 1/4 x 6” OAL Case Pack 3 3 3 3 3 3 3 3 Item No. Description Case Pack 77191 8 Pc. Long Socket Set 3 Inch: 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” 5 Pc. 1/4” Drive Hex Metric 6” Long Socket Set Item No. Description 77192 5 Pc. Long Socket Set Metric: 2.5, 3.0, 4.0, 5.0, 6.0mm 7 Pc. 1/4” Drive TORX® 6” Long Socket Set 1/4” Drive Hex Metric 6” Long Sockets Description 2.5 x 6” OAL 3.0 x 6” OAL 4.0 x 6” OAL 5.0 x 6” OAL 6.0 x 6” OAL Case Pack 3 3 3 3 3 Tradesman 26inOne Ultra Driver 14 Pc. Set Item No. Description Case Pack 77790 26inOne Set-1/4” Bits 3 Slotted: 3.0x4.5, 5.5x6.5mm & Phillips: #1x2, #0x3 ® Square: #1x2, #0x3 & Pozidriv : #1x2 TORX: T10xT15, T20xT25 Hex Inch: 1/8x9/64, 5/32x3/16” Hex Metric: 3.0x4.0, 5.0x6.0mm Case Pack 3 Item No. Description Case Pack 77193 7 Pc. Long Socket Set 3 TORX: T10, T15, T20, T25, T27, T30, T40 Item No. 77140 77142 77144 77146 77148 Item No. Description Case Pack 77782 13 Pc. Bit Reload 3 Slotted: 4.0x6.0mm & Phillips: #1x2 TORX: T8xT9, T10xT15, T20xT25, T27xT30 Hex Inch: 3/32x7/64, 1/8x9/64, 5/32x3/16, 7/32x1/4” Hex Metric: 2.0x2.5, 3.0x4.0, 5.0x6.0mm 9 Pc. 3/8” Drive TORX 6” Long Socket Set ® Item No. Description Case Pack 77195 9 Pc. Long Socket Set 3 TORX: T8, T9, T10, T15, T20, T25, T27, T30, T40 Security Technician’s 13 Pc. Double End Bit Reload For Ultra Driver Item No. Description Case Pack 77783 13 Pc. Bit Reload 3 Spanner: #4 x #6, #8 x #10 & Square: #1x #2 Phillips/Slotted: #2 x 5.5mm & Security TORX: T8s x T9s, T10s x T15s, T20s x T25s, T27s x T30s Security Hex In: 1/8 x 9/64, 5/32 x 3/16, 7/32 x 1/4” Security Hex Metric: 3.0 x 4.0, 5.0 x 6.0mm 26inOne Ultra Driver 14 Pc. Set Item No. Description Case Pack 77791 26inOne Set-1/4” Bits 3 Slotted: 3.0x4.5, 4.0x6.0, 5.5x6.5mm & Pozidriv: #1x2 Phillips: #1x2, #0x3 & Square: #1x2, #0x3 TORX: T6xT7, T8xT9, T10xT15, T20xT25, T27xT30 52 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA Tradesman In Clamshell Industrial Security Hex Inch Bit-Selector Set 26inOne Ultra Driver 14 Pc. Set Item No. Description Case Pack 77792 26inOne Set-1/4” Bits 3 Slotted: 4.0x6.0mm & Phillips: #1x2 TORX: T8xT9, T10xT15, T20xT25, T27xT30 Hex Inch: 3/32x7/64, 1/8x9/64, 5/32x3/16, 7/32x1/4” Hex Metric: 2.0x2.5, 3.0x4.0, 5.0x6.0mm 26inOne Ultra Driver 14 Pc. Set Item No. Description Case Pack 77797 26inOne Set-1/4” Bits 3 Slotted: 3.0x4.5, 5.5x6.5mm & Phillips: #1x2, #0x3 Square: #1x2, #0x3 & Pozidriv®: #1x2 TORX: T10xT15, T20xT25 Hex Inch: 1/8x9/64, 5/32x3/16” Hex Metric: 3.0x4.0, 5.0x6.0mm Slotted, Phillips & TORX® Bit-Selector Set Item No. Description Case Pack 79243 Bit-Selector Set 3 Slotted: 4.5, 5.5, 6.0mm & Phillips: #0, 1, 2, 3 TORX: T10, T15, T20 & 1/4” Bit Holder Item No. Description Case Pack 79266 Bit-Selector Set 3 Inch: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” & 1/4” Bit Holder Ball End Hex Inch Bit-Selector Set Item No. Description Case Pack 79276 Hex Bit-Selector Set 3 Inch: 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” 1/4” Bit Holder Tradesman 29 Pc. Ultra Driver & 1/4” Drive Sockets Item No. Description Case Pack 77793 29 Pc. Combo Set 3 Slotted: 3.0x4.5, 5.5x6.5mm & Phillips: #1x2, #0x3 ® Square: #1x2, #0x3 & Pozidriv : #1x2 TORX: T10xT15, T20xT25 Hex Inch: 1/8x9/64, 5/32x3/16” Hex Metric: 3.0x4.0, 5.0x6.0mm Inch Sockets: 5/32, 3/16, 7/32, 1/4, 9/32, 5/16, 3/8” Metric Sockets: 4.0, 4.5, 5.0, 5.5, 6.0, 7.0, 8.0mm 1/4” x 1/4” Drive Socket Adapter TORX® Bit-Selector Set Technician’s In Clamshell Item No. Description Case Pack 79245 TORX Bit-Selector Set 3 TORX: T7, T8, T9, T10, T15, T20, T25, T27, T30, T40 1/4” Bit Holder 26inOne Ultra Driver 14 Pc. Set Item No. Description Case Pack 77798 26inOne Set-1/4” Bits 3 Slotted: 3.0x4.5, 4.0x6.0, 5.5x6.5mm & Pozidriv: #1x2 Phillips: #1x2, #0x3 & Square: #1x2, #0x3 TORX: T6xT7, T8xT9, T10xT15, T20xT25, T27xT30 6 Pc. TORX® Align 1/4” Insert Bits PokitPak Item No. Description Case Pack 79283 6 Pc. PokitPak 3 TORX Align: T10, T15, T20, T25, T30, T40 x 25mm Hex Inch Bit-Selector Set Item No. Description 79246 Hex Bit-Selector Set 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” & 1/4” Bit Holder Industrial In Clamshell Case Pack 43Inch: Slotted, Phillips & TORX® XSelector Bit Set Item No. Description Case Pack 79443 11 Pc. XSelector Set 3 Slotted: 5.5, 6.5, 8.0mm & Phillips: #0, 1, 2, 3 TORX: T10, T15, T20 & 1/4” Quick Release Bit Holder 26inOne Ultra Driver 14 Pc. Set 23 Piece Ultra Driver Bonus Pack Item No. Description Case Pack 77795 Ultra Driver Set-1/4” Bits 3 Slotted: 3.0x4.5, 4.0x6.0, 5.5x6.5mm Phillips: #1x2, #0x3 Square: #1x2, #0x3 & Pozidriv®: #1x2 TORX: T6xT7, T8xT9, T10xT15, T20xT25, T27xT30 Hex Metric: 2.0x2.5, 3.0x4.0, 5.0x6.0mm Hex Inch: 3/32x7/64, 1/8x9/64, 5/32x3/16, 7/32x1/4” 1/4” Hex to 1/4” Square Socket Adapter Double End Valve Stem Tool Item No. Description Case Pack 77799 26inOne Set-1/4” Bits 3 Slotted: 4.0x6.0mm & Phillips: #1x2 TORX: T8xT9, T10xT15, T20xT25, T27xT30 Hex Inch: 3/32x7/64, 1/8x9/64, 5/32x3/16, 7/32x1/4” Hex Metric: 2.0x2.5, 3.0x4.0, 5.0x6.0mm Security TORX® Bit-Selector Set Item No. Description Case Pack 79247 Bit-Selector Set 3 Security TORX: T7s, T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s & 1/4” Bit Holder TORX® XSelector Bit Set Item No. Description Case Pack 79445 11 Pc. XSelector Set 3 TORX: T7, T8, T9, T10, T15, T20, T25, T27, T30, T40 1/4” Quick Release Bit Holder 1/4” Shank Stubby High Speed Drill Bits Item No. 78002 78005 78008 78011 78015 78018 Description 1/16 x 1.26” 3/32 x 1.41” 1/8 x 1.57” 5/32 x 1.73” 3/16 x 1.97” 1/4 x 1.97” Case Pack 3 3 3 3 3 3 Slotted, Phillips & Square Bit-Selector Set Item No. Description Case Pack 79248 Bit-Selector Set 3 Slotted: 4.5, 5.5, 6.0mm & Phillips: #0, 1, 2, 3 Square: 1, 2, 3 & 1/4” Bit Holder Security In Clamshell 26inOne Security Ultra Driver 14 Pc. Set Hex Inch XSelector Bit Set Item No. Description Case Pack 77796 26inOne Set-1/4” Bits 3 Spanner: #4 x #6, #8 x #10 & Square: #1x #2 Phillips/Slotted: #2 x 5.5mm & Security TORX: T8s x T9s, T10s x T15s, T20s x T25s, T27s x T30s Security Hex In: 1/8 x 9/64, 5/32 x 3/16, 7/32 x 1/4” Security Hex Metric: 3.0 x 4.0, 5.0 x 6.0mm Item No. Description Case Pack 79446 11 Pc. XSelector Set 3 Hex Inch: 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” & 1/4” Quick Release Bit Holder TORX® Bit-Selector Set Hex Metric Bit-Selector Set Item No. Description Case Pack 79242 TORX Bit-Selector Set 3 TORX: T5, T6, T7, T8, T9, T10, T15, T20, T25, T30 1/4” Bit Holder Item No. Description Case Pack 79256 Hex Bit-Selector Set 3 Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0mm 1/4” Bit Holder 53 www.wihatools.com • USA | www.wihatools.ca • CANADA Security TORX® XSelector Bit Set Slotted/Phillips/TORX®/Hex XLSelector Bit Set Item No. Description Case Pack 79447 11 Pc. XSelector Set 3 Security TORX: T7s, T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s & 1/4” Quick Release Holder Item No. Description Case Pack 79495 31 Pc. XLSelector Set 3 Slotted: 5.5, 6.0, 8.0mm & Phillips: 0, 1, 2, 3 TORX: T6, T7, T8, T9, T10, T15, T20, T25 Hex Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0mm Hex Inch: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” & 1/4” x 59mm Magnetic Bit Holder Tradesman 30 Piece 26inOne Ultra Drivers Display Item No. Description Case Pack 97790 26inOne Display 1 Tradesman Ultra Drivers - Each Driver Includes: Slotted: 3.0x4.5, 5.5x6.5mm & Phillips: #1x2, #0x3 Square: #1x2, #0x3 & Pozidriv®: #1x2 TORX: T10xT15, T20xT25 Hex Inch: 1/8x9/64, 5/32x3/16” Hex Metric: 3.0x4.0, 5.0x6.0mm Security Pentalobe 5 Point XSelector Bit Set Item No. Description Case Pack 79450 8 Pc. XSelector Set 3 Security Pentalobe: PLS8, PLS10, PLS15, PLS20, PLS25, PLS27, PLS30 & 1/4” Quick Release Holder XLSelector 1/4” Ratchet & Bit Set Item No. Description 79499 17 Pc. XLSelector Set Slotted: 4.5, 5.5, 6.0mm, Phillips: 0, 1, 2 & Square: 1, 2 TORX: T7, T8, T9, T10, T15, T20, T25 1/4” Ratchet Bit Handle & Bit Holder Case Pack 3 Technician’s 30 Piece 26inOne Ultra Drivers Display Item No. Description Case Pack 97791 26inOne Display 1 Technician’s Ultra Drivers - Each Driver Includes: Slotted: 3.0x4.5, 4.0x6.0, 5.5x6.5mm & Pozidriv: #1x2 Phillips: #1x2, #0x3 & Square: #1x2, #0x3 TORX: T6xT7, T8xT9, T10xT15, T20xT25, T27xT30 XLSelector 1/4” Insert Bit Set Item No. Description Case Pack 79490 31 Pc. XLSelector Set 3 Slotted: 6.0mm, Phillips: 1, 2 & Spanner: 4, 6, 8, 10 Security TORX: T8s, T10s, T15s, T20s, T25s Security Hex: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16” Torq Set: 6, 8, 10, Square: 1, 2 & Pozidriv: 1, 2, Tri-Wing: 2, 3, 4, 5 & 1/4” Magnetic Bit Holder Black Cartridge Holder For 4mm Micro Bits Item No. Description 91109 Holds 14 Micro Bits Case Pack 3 Tradesman 26inOne Ultra Drivers - 6 Pack XLSelector 1/4” Ratchet & Bit Set Item No. Description Case Pack 79491 17 Pc. XLSelector Set 3 Slotted: 4.5, 6.0mm, Phillips: 1, 2, 3 Hex Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0mm Square: 1, 2 & Pozidriv: 1, 2, 1/4” Ratchet Bit Handle & Bit Holder Item No. Description Case Pack 97780 26inOne Set-6 Pack 1 6 Tradesman Ultra Drivers - Each Driver Includes: Slotted: 3.0x4.5, 5.5x6.5mm & Phillips: #1x2, #0x3 Square: #1x2, #0x3 & Pozidriv®: #1x2 TORX: T10xT15, T20xT25 Hex Inch: 1/8x9/64, 5/32x3/16” Hex Metric: 3.0x4.0, 5.0x6.0mm Industrial XLSelector 1/4” Insert Bit Set 26inOne Ultra Drivers - 6 Pack Item No. Description Case Pack 79493 31 Pc. XLSelector Set 3 Slotted: 4.5, 5.5, 6.0mm & Phillips: 1, 2, 3 TORX: T7, T8, T9, T10, T15, T20, T25 & Square: 1, 2 Hex Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0mm Hex Inch: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” & 1/4” x 59mm Magnetic Bit Holder Item No. Description Case Pack 97782 26inOne Set-6 Pack 1 6 Industrial Ultra Drivers - Each Driver Includes: Slotted: 4.0x6.0mm & Phillips: #1x2 TORX: T8xT9, T10xT15, T20xT25, T27xT30 Hex Inch: 3/32x7/64, 1/8x9/64, 5/32x3/16, 7/32x1/4” Hex Metric: 2.0x2.5, 3.0x4.0, 5.0x6.0mm Industrial 30 Piece 26inOne Ultra Drivers Display Item No. Description Case Pack 97792 26inOne Display 1 Industrial Ultra Drivers - Each Driver Includes: Slotted: 4.0x6.0mm & Phillips: #1x2 TORX: T8xT9, T10xT15, T20xT25, T27xT30 Hex Inch: 3/32x7/64, 1/8x9/64, 5/32x3/16, 7/32x1/4” Hex Metric: 2.0x2.5, 3.0x4.0, 5.0x6.0mm 54 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA Hex Tools Exact fit precision machined tip for reduced cam-out T-handle Metric Hex Drivers Item No. 33401 33402 33403 33404 33405 33406 33407 33408 33409 33410 33411 33412 33414 33415 33416 33417 33419 33421 33423 33425 33427 33429 33434 33435 33436 33437 33438 Description 2.0 x 100mm 2.5 x 100mm 3.0 x 100mm 3.0 x 150mm 3.0 x 200mm 4.0 x 100mm 4.0 x 150mm 4.0 x 200mm 5.0 x 100mm 5.0 x 150mm 5.0 x 200mm 5.0 x 350mm 6.0 x 100mm 6.0 x 150mm 6.0 x 200mm 6.0 x 350mm 7.0 x 200mm 8.0 x 100mm 8.0 x 200mm 10.0 x 100mm 10.0 x 200mm 12.0 x 200mm 8.0 x 350mm 3.0 x 350mm 2.0 x 200mm 2.5 x 200mm 4.0 x 350mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 11Pc. Soft Grip Ball End Inch Hex T-handle Set T-handle Inch Hex Drivers Item No. 33453 33456 33459 33462 33465 33468 33471 33474 33477 33480 Description 3/32” x 6.0” 7/64” x 6.0” 1/8” x 6.0” 9/64” x 6.0” 5/32” x 6.0” 3/16” x 6.0” 7/32” x 6.0” 1/4” x 6.0” 5/16” x 6.0” 3/8” x 6.0” Case Pack 10 10 10 10 10 10 10 10 10 10 8 Pc. Metric Hex T-handle Set In Metal Stand Item No. Description Case Pack 33494 Dual Drive T-handle Set 1 Inch: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Item No. Description Case Pack 33488 Hex Metric T-handle Set 1 Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm 8 Pc. Soft Grip Ball End Metric Hex T-handle Set Item No. Description Case Pack 33496 Dual Drive T-handle Set 1 Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm In Metal Stand 6 Pc. Hex Inch T-handle Set Item No. Description 33475 Hex Inch T-handle Set 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Case Pack 3 8 Pc. Soft Grip Metric Hex T-handle Set Item No. Description Case Pack 33489 Dual Drive T-handle Set 1 Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm 8 Pc. Soft Grip Ball End Inch Hex T-handle Set Item No. Description Case Pack 33498 Dual Drive T-handle Set 1 Inch: 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” SoftGrip Ball End Inch Hex Dual Dr. T-handle Item No. 33418 33420 33422 33424 33426 33428 33430 33432 33433 33439 33440 Description 5/64” x 5.9” no ball 3/32” x 5.9” no ball 7/64” x 5.9” no ball 1/8” x 5.9” no ball 9/64” x 5.9” no ball 5/32” x 5.9” 3/16” x 5.9” 7/32” x 5.9” 1/4” x 5.9” 5/16” x 7.9” 3/8” x 7.9” Case Pack 10 10 10 10 10 10 10 10 10 10 10 In Metal Stand 6 Pc. Hex Metric T-handle Set Item No. Description 33476 Hex Metric T-handle Set 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm Case Pack 3 10 Pc. Inch Hex T-handle Set 8 Pc. Soft Grip Ball End Inch Hex T-handle Set Item No. Description Case Pack 33492 Hex Inch T-handle Set 3 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Item No. Description Case Pack 33499 Dual Dr. T-handle Set 1 Inch: 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Short Arm Hex Metric L-keys - Nickel Finish SoftGrip Ball End Metric Hex Dual Dr. T-handle Item No. 33442 33444 33446 33448 33450 33452 33454 33458 Description 2.0 x 150mm-no ball 2.5 x 150mm-no ball 3.0 x 150mm-no ball 4.0 x 150mm 5.0 x 150mm 6.0 x 150mm 8.0 x 200mm 10.0 x 200mm Case Pack 10 10 10 10 10 10 10 10 In Metal Stand 8 Pc. Inch Hex T-handle Set In Metal Stand 8 Pc. Metric Hex T-handle Set Item No. Description Case Pack 33484 Hex Inch T-handle Set 1 Inch: 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Item No. Description Case Pack 33493 Hex MM T-handle Set 3 Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm Item No. 35101 35102 35103 35105 35106 35107 35109 35110 35113 Description 1.5mm - 10 Pack 2.0mm - 10 Pack 2.5mm - 10 Pack 3.0mm - 10 Pack 4.0mm - 10 Pack 5.0mm - 10 Pack 6.0mm - 10 Pack 8.0mm - 10 Pack 10.0mm - 10 Pack Case Pack 3 3 3 3 3 3 3 3 3 55 www.wihatools.com • USA | www.wihatools.ca • CANADA Short Arm Hex Inch L-keys - Nickel Finish Item No. 35111 35114 35115 35117 35118 35119 35121 35122 35123 35125 35126 35127 35129 Description .050 - 10 Pack 1/16” - 10 Pack 5/64” - 10 Pack 3/32” - 10 Pack 7/64” - 10 Pack 1/8” - 10 Pack 9/64” - 10 Pack 5/32” - 10 Pack 3/16” - 10 Pack 7/32” - 10 Pack 1/4” - 10 Pack 5/16” - 10 Pack 3/8” - 10 Pack Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 13 Pc. Inch Hex L-key Set - Nickel Finish 9 Pc. Metric Hex L-key Set - Nickel Finish Item No. Description Case Pack 35194 Hex L-key Set 6 Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Item No. Description Case Pack 35297 Hex L-key Set 3 Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm 7 Pc. Metric Hex PocketStar Fold Out 13 Pc. Inch Hex L-key Set - Black Finish Item No. Description Case Pack 35195 Hex PocketStar Set 6 Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0mm Item No. Description Case Pack 35391 Short Arm L-key Set 3 Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Short Arm Hex Metric L-keys - Nickel Finish Item No. Description 35120 4.0 x 72mm Case Pack 10 Short Arm Hex Inch L-keys - Nickel Finish Item No. 35143 35147 35152 Description .050 x 1.6” 5/64 x 2.0” 7/64 x 2.1” 9 Pc. Inch Hex PocketStar Fold Out Item No. Description Case Pack 35197 Hex PocketStar Set 6 In: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Case Pack 10 10 10 Description 1.5mm - 10 Pack 2.0mm - 10 Pack 2.5mm - 10 Pack 3.0mm - 10 Pack 4.0mm - 10 Pack 5.0mm - 10 Pack 6.0mm - 10 Pack 8.0mm - 10 Pack 10.0mm - 10 Pack Case Pack 3 3 3 3 3 3 3 3 3 Long Arm Hex Inch L-keys - Nickel Finish Item No. 35410 35411 35412 35413 35414 35415 35416 35417 35418 35419 35420 35421 35422 Description .050 - 10 Pack 1/16” - 10 Pack 5/64” - 10 Pack 3/32” - 10 Pack 7/64” - 10 Pack 1/8” - 10 Pack 9/64” - 10 Pack 5/32” - 10 Pack 3/16” - 10 Pack 7/32” - 10 Pack 1/4” - 10 Pack 5/16” - 10 Pack 3/8” - 10 Pack Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 5 Pc. Metric Hex L-key Set - Black Finish Item No. Description 35392 Short Arm L-key Set Metric: 0.7, 0.9, 1.3, 1.5, 2.0mm Case Pack 6 Ball End Hex Metric L-keys - Black Finish Long Arm Hex Metric L-keys - Nickel Plated 9 Pc. Metric Hex L-key Set - Nickel Finish Long Arm Hex Metric L-keys - Nickel Finish Item No. 35401 35402 35403 35404 35405 35406 35407 35408 35409 Item No. Description 35217 10.0 x 219mm Case Pack 10 Item No. Description Case Pack 35191 Hex L-key Set 6 Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm 5 Pc. Inch Hex L-key Set - Black Finish Item No. Description 35393 Short Arm L-key Set Inch: .028, .035, .050, 1/16, 5/64” Case Pack 6 Item No. 36904 36908 36912 36916 36920 36924 36928 36936 36944 Description 1.5 x 90mm 2.0 x 99mm 2.5 x 111mm 3.0 x 125mm 4.0 x 138mm 5.0 x 158mm 6.0 x 178mm 8.0 x 198mm 10.0 x 221mm Case Pack 10 10 10 10 10 10 10 10 10 Long Arm Hex Inch L-keys - Nickel Plated 8 Pc. Inch Hex L-key Set - Nickel Finish Item No. Description Case Pack 35192 Hex L-key Set 6 Inch: 5/64, 3/32, 1/8, 5/32, 3/16, 7/32, 1/4, 5/16” Item No. Description 35231 .050 x 3.0” Case Pack 10 Ball End Hex Metric L-keys - Stainless Steel Item No. 36915 36917 36918 36919 36921 36922 6 Pc. Metric Hex L-key Set - Nickel Finish Item No. Description 35193 Hex L-key Set Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0mm Case Pack 6 13 Pc. Inch Hex L-key Set - Nickel Finish 9 Pc. Metric Hex L-key Set - Black Finish Item No. Description Case Pack 35295 Hex L-key Set 3 Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Item No. Description Case Pack 35390 Short Arm L-key Set 3 Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm Description 3.0 x 125mm 4.0 x 138mm 5.0 x 158mm 6.0 x 178mm 8.0 x 198mm 10.0 x 221mm Case Pack 10 10 10 10 10 10 56 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA Screw Holding Ball End Hex Inch L-keys - Black Finish Item No. 36945 36946 36947 36950 36952 36953 36955 36956 36959 36962 36965 36968 36971 Description .050 x 2.8” 1/16 x 3.1” 5/64 x 3.5” 3/32 x 3.9” 7/64 x 4.3” 1/8 x 4.6” 9/64 x 5.2” 5/32 x 5.7” 3/16 x 6.2” 7/32 x 6.7” 1/4 x 7.3” 5/16 x 8.0” 3/8 x 8.8” Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 6 Pc. Ball End Hex Metric Long Arm L-key Set Item No. Description 36992 Black Finish L-key Set Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0mm Case Pack 3 In Metal Stand MagicRing Ball End Hex Inch T-handle Item No. 54012 54014 54016 54018 54022 54024 Description 5/32 x 5.8” 3/16 x 5.8” 7/32 x 5.8” 1/4 x 5.8” 5/16 x 7.8” 3/8 x 7.8” Case Pack 10 10 10 10 10 10 8 Pc. Ball End Hex Metric Dual Drive T-handle Item No. Description Case Pack 54092 Soft Grip T-handle Set 1 Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm 8 Pc. Ball End Hex Inch Dual Drive T-handle Item No. Description Case Pack 54094 Soft Grip T-handle Set 1 Inch: 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Dual Drive 8 Pc. Ball End Hex Inch Long Arm L-key Set Item No. Description Case Pack 36993 Black Finish L-key Set 3 Inch: 5/64, 3/32, 1/8, 5/32, 3/16, 7/32, 1/4, 5/16” Ball End Hex Inch L-keys - Chrome Finish Item No. 36949 36951 36954 36957 36958 36960 36961 36963 Description 1/8 x 4.6” 9/64 x 4.6” 5/32 x 5.7” 3/16 x 6.2” 7/32 x 6.7” 1/4 x 7.3” 5/16 x 8.0” 3/8 x 8.8” Case Pack 10 10 10 10 10 10 10 10 Soft Grip Ball End Hex Metric T-handle Item No. 54020 54025 54030 54042 54052 54062 54082 54088 Description 2.0 x 150mm 2.5 x 150mm 3.0 x 150mm 4.0 x 150mm 5.0 x 150mm 6.0 x 150mm 8.0 x 200mm 10.0 x 200mm Case Pack 10 10 10 10 10 10 10 10 8 Pc. Ball End Hex Metric Dual Drive T-handle Item No. Description Case Pack 54095 Soft Grip T-handle Set 1 Metric: 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm 22 Pc. Ball End Hex Inch & Metric L-key Sets Item No. Description Case Pack 36995 Black Finish L-key Sets 3 Inch: .050 - 3/8” & Metric: 1.5 - 10.0mm Screw Holding MagicRing Ball End Hex Metric T-handle Ball End Hex Inch L-keys - Stainless Steel Item No. 36974 36976 36982 36983 Description 3/32 x 113mm 1/8 x 127mm 5/16 x 208mm 3/8 x 233mm Case Pack 10 10 10 10 13 Pc. Ball End Hex Inch Long Arm L-key Set Item No. Description Case Pack 36998 Chrome Finish L-key Set 3 Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Item No. 54040 54050 54060 54080 54086 Description 4.0 x 150mm 5.0 x 150mm 6.0 x 150mm 8.0 x 200mm 10.0 x 200mm Case Pack 10 10 10 10 10 No Stand 10 Pc. Ball End Hex Inch Dual Drive T-handle Item No. Description Case Pack 54097 Soft Grip T-handle Set 1 Inch: 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Screw Holding 9 Pc. Ball End Hex Metric Long Arm L-key Set Soft Grip Ball End Hex Inch Dual Drive T-handle 5 Pc. MagicRing Ball End Hex Metric T-handle Item No. Description Case Pack 36990 Black finish L-ket Set 3 Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0 6.0, 8.0, 10.0mm Item No. 54001 54002 54003 54004 54005 54006 54007 54008 54009 54010 Item No. Description Case Pack 54090 Screw Holding T-handle Set 3 Metric: 4.0, 5.0, 6.0, 8.0, 10.0mm Description 5/32 x 5.9” 3/16 x 5.9” 7/32 x 5.9” 1/4 x 5.9” 5/16 x 7.9” 3/8 x 7.9” 3/32 x 5.9” 7/64 x 5.9” 1/8 x 5.9” 9/64 x 5.9” Case Pack 10 10 10 10 10 10 10 10 10 10 Screw Holding 13 Pc. Ball End Hex Inch Long Arm L-key Set 6 Pc. MagicRing Ball End Hex Inch T-handle Item No. Description Case Pack 36991 Black Finish L-key Set 3 Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Item No. Description Case Pack 54091 Screw Holding T-handle Set 3 In: 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Color Coded Ball End Inch Hex L-key Item No. 66900 66901 66902 66903 66905 66906 66907 66909 66910 66911 66913 66914 66915 Description .050 x 81mm 1/16 x 92mm 5/64 x 102mm 3/32 x 114mm 7/64 x 129mm 1/8 x 129mm 9/64 x 140mm 5/32 x 144mm 3/16 x 165mm 7/32 x 176mm 1/4 x 186mm 5/16 x 208mm 3/8 x 234mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 57 www.wihatools.com • USA | www.wihatools.ca • CANADA Screw Holding Color Coded Ball End Metric Hex L-key Item No. 66923 66925 66927 66929 66931 66932 66933 66934 66935 Description 1.5 x 92mm 2.0 x 102mm 2.5 x 115mm 3.0 x 129mm 4.0 x 144mm 5.0 x 165mm 6.0 x 186mm 8.0 x 208mm 10.0 x 234mm Case Pack 10 10 10 10 10 10 10 10 10 9 Pc. Metric Ball End Color Coded Hex L-keys 22 Pc. MagicRing Ball End Hex L-key Set Item No. Description Case Pack 66980 Color Coded L-key Set 3 Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm Item No. Description Case Pack 66992 Screw Holding L-key Set 3 Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm 13 Pc. Inch Ball End Color Coded Hex L-keys Item No. Description Case Pack 66981 Color Coded L-key Set 3 Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” 2 Pack Inch/Metric Ball End Hex L-key Sets Item No. Description Case Pack 66993 Long L-key Sets 3 Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm Ball End Metric Hex L-key Item No. 66904 66908 66912 66918 66922 66926 66930 66937 66938 Description 1.5 x 90mm 2.0 x 99mm 2.5 x 111mm 3.0 x 125mm 4.0 x 138mm 5.0 x 158mm 6.0 x 178mm 8.0 x 198mm 10.0 x 221mm Case Pack 10 10 10 10 10 10 10 10 10 22Pc. ErgoStar In/MM Ball End Hex L-keys 9 Pc. Metric Ball End Hex L-key Set Item No. Description Case Pack 66982 Long L-key Set 3 Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm Item No. Description Case Pack 66994 Long L-key Set 3 Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm Screw Holding MagicRing Ball End Metric Hex L-key Item No. 66916 66920 66924 66928 66936 66944 Description 3.0 x 125mm 4.0 x 138mm 5.0 x 158mm 6.0 x 178mm 8.0 x 198mm 10.0 x 221mm Case Pack 10 10 10 10 10 10 MagicRing Ball End Inch Hex L-key Item No. 66945 66946 66947 66950 66952 66953 66955 66956 66959 66962 66965 66968 66971 Description .050 x 2.8” no ring 1/16 x 3.1” no ring 5/64 x 3.5” no ring 3/32 x 3.9” no ring 7/64 x 4.3” no ring 1/8 x 4.6” 9/64 x 5.2” 5/32 x 5.7” 3/16 x 6.2” 7/32 x 6.7” 1/4 x 7.3” 5/16 x 8.0” 3/8 x 8.8” Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 13 Pc. ErgoStar Inch Ball End Hex L-key Set Item No. Description Case Pack 66988 Long L-key Set 3 Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” 6 Pc. Metric Ball End Hex L-key Set Item No. Description 66995 Long L-key Set Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0mm Case Pack 3 Screw Holding 9 Pc. ErgoStar Metric Ball End Hex L-key Set Item No. Description Case Pack 66996 Long L-key Set 3 Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm 9 Pc. MagicRing Ball End Metric Hex L-key Set Item No. Description Case Pack 66990 Screw Holding L-key Set 3 Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0, 10.0mm Screw Holding 11 Pc. Ball End Hex Metric L-key Set Item No. Description Case Pack 66998 Ball End Hex Set 3 Hex Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0mm 13 Pc. MagicRing Ball End Inch Hex L-key Set Item No. Description Case Pack 66991 Screw Holding L-key Set 3 Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4, 5/16, 3/8” 58 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA TORX® Tools Exact fit precision machined tip for reduced cam-out In Metal Stand Short Arm TORXPlus® L-keys - Black Finish Item No. 36107 36108 36109 36110 36115 36120 36125 36127 36130 36140 Description IP7 x 42mm IP8 x 45mm IP9 x 48mm IP10 x 51mm IP15 x 55mm IP20 x 58mm IP25 x 63mm IP27 x 68mm IP30 x 73mm IP40 x 81mm Case Pack 10 10 10 10 10 10 10 10 10 10 9 Pc. TORX® L-key Set - Black Finish Item No. Description 36390 Black Finish L-key Set TORX: T10, T15, T20, T25, T30, T40, T50, T55, T60 Case Pack 1 6 Pc. Security TORX® L-key Set Item No. Description Case Pack 36391 Black Finish Set 3 Security TORX: T10s, T15s, T20s, T25s, T27s, T30s 7 Pc. TORX® L-key Set In Plastic Holder 9 Pc. TORXPlus® L-key Set - Black Finish Item No. Description 36199 Short Arm L-key Set TORXPlus: IP8, IP9, IP10, IP15, IP20, IP25, IP27, IP30, IP40 Item No. Description 36392 Black Finish L-key Set TORX: T6, T7, T8, T9, T10, T15, T20 Case Pack 3 TORX® T-handles Item No. 36409 36410 36415 36417 36420 36422 36425 36427 36430 36432 36435 36437 36440 36442 36452 Description T9 x 100mm T10 x 100mm T15 x 100mm T15 x 200mm T20 x 100mm T20 x 200mm T25 x 100mm T25 x 200mm T27 x 100mm T27 x 200mm T30 x 100mm T30 x 200mm T40 x 100mm T40 x 200mm T50 x 250mm Item No. 36461 36463 36466 36469 36472 36474 36476 36478 Description IP9 x 100mm IP10 x 100mm IP15 x 100mm IP20 x 100mm IP25 x 150mm IP27 x 150mm IP30 x 150mm IP40 x 150mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 7 Pc. TORX® T-handle Set Item No. Description Case Pack 36492 T-handle TORX Set 3 TORX: T9, T10, T15, T20, T25, T27, T30 8 Pc. TORX® T-handle Set - In Metal Stand Item No. Description Case Pack 36494 T-handle TORX Set 1 TORX: T9, T10, T15, T20, T25, T30, T35, T40 Case Pack 3 6 Pc. TORXPlus® T-handle Set TORXPlus® T-handles 9 Pc. Security TORX® L-key Set Short Arm TORX® L-keys - Black Finish Item No. 36306 36307 36308 36309 36310 36315 36320 36325 36327 36330 36340 36345 36355 36360 Description T6 x 39mm T7 x 42mm T8 x 45mm T9 x 48mm T10 x 51mm T15 x 54mm T20 x 58mm T25 x 63mm T27 x 67mm T30 x 73mm T40 x 79mm T45 x 82mm T55 x 108mm T60 x 120mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Item No. Description Case Pack 36393 Black Finish L-key Set 3 Security TORX: T8s, T9s, T10s, T15s, T20s, T25s, T27s, T30s, T40s Case Pack 10 10 10 10 10 10 10 10 Item No. Description Case Pack 36496 T-handle TORXPlus Set 3 TORXPlus: IP10, IP15, IP20, IP25, IP27, IP30 9 Pc. TORX® L-key Set - Black Finish Item No. Description 36394 Black Finish L-key Set TORX: T8, T9, T10, T15, T20, T25, T27, T30, T40 Case Pack 3 7 Pc. Soft Grip TORX® Dual Drive T-handle Set Soft Grip TORX® Dual Drive T-handles Item No. 36480 36481 36482 36483 36484 36486 36487 Description T10 x 100mm T15 x 100mm T20 x 100mm T25 x 150mm T27 x 150mm T30 x 150mm T40 x 150mm Case Pack 10 10 10 10 10 10 10 Item No. Description Case Pack 36497 T-handle TORX Set 1 TORX: T10, T15, T20, T25, T27, T30, T40 10 Pack Short Arm Security TORX® L-keys Item No. 36323 36326 36328 36329 36332 36335 36337 36339 36342 36346 Description T8s x 45mm T9s x 48mm T10s x 51mm T15s x 54mm T20s x 58mm T25s x 63mm T27s x 67mm T30s x 73mm T40s x 79mm T45s x 82mm Case Pack 10 10 10 10 10 10 10 10 10 10 7 Pc. TORX® PocketStar Fold Out Item No. Description 36396 PocketStar Fold Out Set TORX: T7, T8, T9, T10, T15, T20, T25 Case Pack 3 TORX® Wing Handle Screwdriver - 10 Pack 7 Pc. TORX® T-handle Set - In Metal Stand Item No. Description Case Pack 36490 T-handle TORX Set 1 TORX: T10, T15, T20, T25, T30, T40, T50 Item No. 36511 36513 36514 36534 36536 36537 36538 Description T6 x 35mm T7 x 35mm T8 x 40mm T9 x 40mm T10 x 40mm T15 x 45mm T20 x 45mm Case Pack 3 3 3 3 3 3 3 59 www.wihatools.com • USA | www.wihatools.ca • CANADA 2 Pack TORX® Wing Handle Screwdriver - 2 Pack Item No. 36516 36517 36518 36519 36521 36522 36523 Description T6 x 35mm T7 x 35mm T8 x 40mm T9 x 40mm T10 x 40mm T15 x 45mm T20 x 45mm Case Pack 3 3 3 3 3 3 3 7 Pc. TORX® Wing Handle Set - In Metal Stand Ball End TORX® Long Arm L-keys-Black Finish Item No. Description 36590 Wing Handle Set TORX: T6, T7, T8, T9, T10, T15, T20 Item No. 36631 36632 36633 36634 36635 36636 36637 36638 36639 Case Pack 3 Description T9 x 111mm T10 x 121mm T15 x 136mm T20 x 148mm T25 x 163mm T27 x 176mm T30 x 191mm T40 x 210mm T45 x 220mm Case Pack 3 3 3 3 3 3 3 3 3 (No Metal Stand) Item No. Description 36591 Wing Handle Set TORX: T6, T7, T8, T9, T10, T15, T20 Case Pack 3 TORXPlus® Wing Handle Screwdriver - 2 Pack Item No. 36524 36526 36527 36528 36529 36531 36532 36533 Description IP5 x 35mm IP6 x 35mm IP7 x 35mm IP8 x 40mm IP9 x 40mm IP10 x 40mm IP15 x 45mm IP20 x 45mm Case Pack 3 3 3 3 3 3 3 3 7 Pc. TORXPlus® Wing Handle Set Case Pack 3 8 Pc. Ball End TORX® Long Arm L-key Set 7 Pc. TORX® Wing Handle Set 2 Pack 9 Pc. TORXPlus® Long Arm L-key Set Item No. Description 36691 L-key Black Finish Set TORXPlus: IP8, IP9, IP10, IP15, IP20, IP25, IP27, IP30, IP40 TORX® Long Arm L-keys - Black Finish Item No. 36645 36646 36647 36648 36649 36650 36651 36652 36653 36654 36655 36659 36660 36661 Description T5 x 71mm T6 x 78mm T7 x 87mm T8 x 99mm T9 x 106mm T10 x 118mm T15 x 131mm T20 x 144mm T25 x 158mm T27 x 169mm T30 x 184mm T40 x 201mm T45 x 222mm T50 x 213mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 10 10 10 Item No. Description Case Pack 36592 Wing Handle Set 3 TORXPlus: IP6, IP7, IP8, IP9, IP10, IP15, IP20 Item No. Description Case Pack 36692 Black Finish L-key Set 3 TORX: T9, T10, T15, T20, T25, T27, T30, T40 Pacified Zinc Chromate Finish 13 Pc. Rust Free TORX® Long Arm L-key Set Item No. Description 36693 L-key Set TORX: T5, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30, T40, T45 Case Pack 3 10 Pack TORXPlus® Wing Handle Screwdriver - 10 Pack Item No. 36539 36541 36543 36545 36547 36549 36551 36553 Description IP5 x 35mm IP6 x 35mm IP7 x 35mm IP8 x 40mm IP9 x 40mm IP10 x 40mm IP15 x 45mm IP20 x 45mm Case Pack 3 3 3 3 3 3 3 3 In metal stand 7 Pc. MagicSpring TORX® Wing Handle Set 13 Pc. ErgoStar TORX® Long Arm L-key Set 26 Pc. TORX® & Hex Inch Long Arm L-key Sets Item No. Description Case Pack 36598 Wing Handle Set 3 MagicSpring TORX: T6, T7, T8, T9, T10, T15, T20 Item No. Description Case Pack 36689 Black Finish L-key Set 3 TORX: T5, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30, T40, T45 Item No. Description Case Pack 36694 Black Finish L-key Set 3 TORX: T5 - T50 & Hex Inch: .050 - 3/8” Screw Holding MagicSpring TORX® Wing Handle Screwdriver Item No. 36556 36557 36558 36559 36560 36561 36562 Description T6 x 35mm T7 x 35mm T8 x 40mm T9 x 40mm T10 x 40mm T15 x 45mm T20 x 45mm Case Pack 10 10 10 10 10 10 10 TORXPlus® Long Arm L-keys - Black Finish Item No. 36606 36607 36608 36609 36610 36615 36620 36625 36627 36630 36640 Description IP6 x 64mm IP7 x 68mm IP8 x 74mm IP9 x 78mm IP10 x 83mm IP15 x 88mm IP20 x 94mm IP25 x 98mm IP27 x 107mm IP30 x 114mm IP40 x 118mm Case Pack 10 10 10 10 10 10 10 10 10 10 10 7 Pc. TORXPlus® Long Arm L-key Set 8 Pc. TORXPlus® PocketStar Fold Out Item No. Description Case Pack 36690 L-key Black Finish Set 3 TORXPlus: IP6, IP7, IP8, IP9, IP10, IP15, IP20 Item No. Description Case Pack 36697 PocketStar Set 3 TORXPlus: IP6, IP7, IP8, IP9, IP10, IP15, IP20, IP25 60 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA Screw Holding 10 Pack 10 Pc. TORX® Long Arm L-key Set Item No. Description Case Pack 36698 Black Finish L-key Set 3 TORX: T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 TORXPlus® Flag Handle Screwdriver - 10 Pack 7 Pc. MagicSpring TORX® Long Arm L-key Set Item No. 37063 37064 37065 37066 37067 37068 37069 37070 Item No. Description 37190 L-key Set TORX: T6, T7, T8, T9, T10, T15, T20 Description IP5 x 35mm IP6 x 35mm IP7 x 35mm IP8 x 40mm IP9 x 40mm IP10 x 40mm IP15 x 45mm IP20 x 45mm Case Pack 3 3 3 3 3 3 3 3 13 Pc. TORX® Long Arm L-key Set Item No. Description Case Pack 36699 Black Finish L-key Set 3 TORX: T5, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30, T40, T50 2 Pack TORX® Flag Handle Screwdriver - 2 Pack Item No. 37005 37006 37007 37008 37009 37010 37011 37012 Description T5 x 35mm T6 x 35mm T7 x 35mm T8 x 40mm T9 x 40mm T10 x 40mm T15 x 45mm T20 x 45mm Case Pack 3 3 3 3 3 3 3 3 7 Pc. TORX® Flag Handle Set - In Metal Stand Item No. Description 37090 Flag Handle Set TORX: T6, T7, T8, T9, T10, T15, T20 Case Pack 3 7 Pc. TORX® Flag Handle Set Item No. Description 37091 Flag Handle Set TORX: T6, T7, T8, T9, T10, T15, T20 Case Pack 3 2 Pack TORXPlus® Flag Handle Screwdriver - 2 Pack Item No. 37014 37015 37017 37018 37021 37023 37024 37027 Description IP5 x 35mm IP6 x 35mm IP7 x 35mm IP8 x 40mm IP9 x 40mm IP10 x 40mm IP15 x 45mm IP20 x 45mm Case Pack 3 3 3 3 3 3 3 3 In Metal Stand 7 Pc. TORXPlus® Flag Handle Set Item No. Description Case Pack 37092 Flag Handle Set 3 TORX: IP6, IP7, IP8, IP9, IP10, IP15, IP20 Screw Holding 10 Pack MagicSpring TORX® Long Arm L-key TORX® Flag Handle Screwdriver - 10 Pack Item No. 37055 37056 37057 37058 37059 37060 37061 37062 Description T5 x 35mm T6 x 35mm T7 x 35mm T8 x 40mm T9 x 40mm T10 x 40mm T15 x 45mm T20 x 45mm Case Pack 3 3 3 3 3 3 3 3 Item No. 37106 37107 37108 37109 37110 37115 37120 37125 37127 37130 Description T6 - Black Finish T7 - Black Finish T8 - Black Finish T9 - Black Finish T10 - Black Finish T15 - Black Finish T20 - Black Finish T25 - Black Finish T27 - Black Finish T30 - Black Finish Case Pack 3 3 3 3 3 3 3 3 3 3 Case Pack 3 10Pc. MagicSpring TORX® Long Arm L-keys Item No. Description Case Pack 37192 L-key Set 3 TORX: T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 61 www.wihatools.com • USA | www.wihatools.ca • CANADA Mechanical Shop Tools Precision formed for exact fit Heavy Duty Solid Tapered Metric Punches Item No. Description 12411 1mm x 150mm 12424 14mm x 175mm Case Pack 3 3 Heavy Duty Solid Metric Parallel Punches Item No. 23420 23421 23422 23423 23424 23425 23426 23427 23428 23429 23432 23433 23434 Description 2mm x 150mm 2.5mm x 150mm 3mm x 150mm 3.5mm x 150mm 4mm x 150mm 4.5mm x 150mm 5mm x 150mm 6mm x 150mm 7mm x 150mm 8mm x 150mm 9mm x 150mm 10mm x 150mm 12mm x 150mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 In Canvas Pouch Combination Ratchet Wrenches Metric Item No. 30308 30309 30310 30311 30312 30313 30314 30315 30316 30317 30318 30319 30301 30302 30303 30304 30305 30306 30307 30320 30321 30326 30328 Description 8.0 x 136mm 9.0 x 142mm 10.0 x 160mm 11.0 x 168mm 12.0 x 174mm 13.0 x 180mm 14.0 x 190mm 15.0 x 200mm 16.0 x 215mm 17.0 x 230mm 18.0 x 240mm 19.0 x 248mm 20.0 x 288mm 21.0 x 288mm 22.0 x 288mm 23.0 x 288mm 24.0 x 322mm 25.0 x 322mm 26.0 x 322mm 27.0 x 359mm 28.0 x 359mm 29.0 x 359mm 30.0 x 425mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 1 1 1 1 Combination Ratchet Wrenches Inch 8 Pc. Metric Parallel Pin Punches Set Item No. Description 23490 Metric Parallel Pin Punches Metric: 2, 2.5, 3, 3.5, 4, 4.5, 5, 6mm Case Pack 3 In Canvas Pouch 15 Pc. Tapered & Parallel Pin Punches Set Item No. Description Case Pack 23493 Tapered/Parallel Punches 1 Parallel: 2, 2.5, 3, 3.5, 4, 4.5, 5, 6, 7, 8, 9, 10, 12mm Tapered: 1, 14mm Item No. 30322 30323 30324 30325 30327 30329 30331 30333 30334 30335 30336 30337 30338 30339 30340 30341 30343 30344 30345 Description 1/4 x 124mm 5/16 x 124mm 11/32 x 142mm 3/8 x 160mm 7/16 x 168mm 1/2 x 180mm 9/16 x 190mm 5/8 x 215mm 11/16 x 230mm 3/4 x 248mm 13/16 x 285mm 7/8” x 285mm 15/16 x 322mm 1” x 322mm 1-1/16 x 359mm 1-1/8 x 359mm 1-1/4 x 425mm 1-3/8 x 485mm 1-1/2 x 485mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 1 1 1 1 1 Storage rack with soft grip holder & secure locking mechanism holds wrenches securely in place Storage rack with soft grip holder & secure locking mechanism holds wrenches securely in place Includes Wire Rack Includes Wire Rack 7 Pc. Metric Combo Ratchet Wrench Set 7 Pc. Inch Combo Ratchet Wrench Set Item No. Description Case Pack 30390 Ratchet Wrench Set 3 Metric: 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0mm Item No. Description Case Pack 30393 Ratchet Wrench Set 3 Inch: 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8” Includes Wire Rack Includes Wire Rack 12 Pc. Inch Combo Ratchet Wrench Set 12 Pc. Metric Combo Ratchet Wrench Set Item No. Description Case Pack 30391 Ratchet Wrench Set 1 Metric: 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 17.0, 18.0, 19.0mm Item No. Description 30002 6.0 x 175mm OAL Combination Wrenches Metric 72 TOOTH Case Pack 10 20 Pc. Inch Combo Ratchet Wrench Set Round Awl Item No. Description 30102 6.0 x 185mm OAL Case Pack 10 Item No. Description Case Pack 30389 Ratchet Wrench Set 1 Inch: 1/4, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1, 1-1/16, 1-1/8, 1-3/16, 1-1/4, 1-3/8, 1-1/2” 24 Pc. Combination Wrench Sets Item No. Description Case Pack 30395 Combo Wrench Set 1 MM: 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19mm Inch: 1/4, 5/16, 11/32, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8” Large - 22” x 15.5” x 1.25” Square Reaming Awl Item No. Description Case Pack 30394 Ratchet Wrench Set 1 Inch: 1/4, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8” 31 Pc. Ratcheting Wrench Foam Tray Set Item No. Description Case Pack 30392 Inch/Metric Ratchet Wrenches 1 Inch: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1” Metric: 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25mm Item No. 30406 30407 30408 30409 30410 30411 30412 30413 30414 30415 30416 30417 30418 30419 30420 30422 30424 30425 30426 30427 30428 30429 30430 Description 6.0 x 120mm 7.0 x 130mm 8.0 x 140mm 9.0 x 150mm 10.0 x 160mm 11.0 x 170mm 12.0 x 175mm 13.0 x 180mm 14.0 x 195mm 15.0 x 200mm 16.0 x 225mm 17.0 x 230mm 18.0 x 240mm 19.0 x 250mm 20.0 x 260mm 22.0 x 295mm 24.0 x 315mm 25.0 x 340mm 26.0 x 340mm 27.0 x 365mm 28.0 x 395mm 29.0 x 395mm 30.0 x 395mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 62 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA 1/4” Drive Ratchet Combination Wrenches Inch Item No. 30433 30434 30435 30436 30437 30438 30440 30441 30442 30444 30445 30446 30447 30448 30449 30450 30451 30452 Description 1/4 x 130mm 5/16 x 140mm 3/8 x 160mm 7/16 x 170mm 1/2 x 180mm 9/16 x 190mm 5/8 x 210mm 11/16 x 230mm 3/4 x 250mm 13/16 x 270mm 7/8 x 290mm 15/16 x 320mm 1” x 340mm 1-1/16 x 360mm 1-1/8 x 390mm 1-1/4 x 430mm 1-3/8 x 470mm 1-1/2 x 500mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Item No. Description 33301 128mm/5” OAL Large - 22” x 15.5” x 1.25” 1/4” Universal Joint Socket Adapter 1/4” Drive Extension Bars Item No. Description 33303 76mm/3.0” OAL 33304 152mm/6.0” OAL Case Pack 3 3 Item No. Description 33360 31.75mm/1.25” OAL Case Pack 3 31 Pc. Combination Wrench Foam Tray Set Item No. Description Case Pack 30492 Inch/Metric Combo Wrenches 1 Inch: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1” Metric: 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25mm Storage rack with soft grip holder & secure locking mechanism holds wrenches securely in place Storage rack with soft grip holder & secure locking mechanism holds wrenches securely in place Includes Wire Rack 1/4” Drive Inch Sockets - 6 Points Item No. 33305 33306 33307 33308 33309 33310 33311 33312 33313 33314 33315 Description 5/32 x .98” 3/16 x .98” 7/32 x .98” 1/4 x .98” 9/32 x .98” 5/16 x .98” 11/32 x .98” 3/8 x .98” 7/16 x .98” 1/2 x .98” 9/16 x .98” Case Pack 3 3 3 3 3 3 3 3 3 3 3 14 Pc. 1/4” Drive Socket Set - Inch Item No. Description Case Pack 33390 1/4” Drive Socket Set 1 Inch: 5/32, 3/16, 7/32, 9/32, 5/16, 11/32, 3/8, 1/4, 7/16, 1/2, 9/16” 1/4” Ratchet - 5.0” OAL 1/4” Extension Bar - 3.0” & 6.0” OAL 1/4” Drive Metric Sockets - 6 Points 7 Pc. Inch Combination Wrench Set Includes Wire Rack Case Pack 3 Item No. Description Case Pack 30493 Combo Wrench Set 3 Inch: 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4” 7 Pc. Metric Combination Wrench Set Item No. Description Case Pack 30490 Combo Wrench Set 3 Metric: 10.0, 12.0, 13.0, 14.0, 15.0, 16.0, 17.0mm Item No. 33316 33317 33318 33319 33320 33321 33322 33323 33324 33325 33326 33327 33328 Description 4.0 x 25mm 5.0 x 25mm 5.5 x 25mm 6.0 x 25mm 7.0 x 25mm 8.0 x 25mm 9.0 x 25mm 10.0 x 25mm 4.5 x 25mm 11.0 x 25mm 12.0 x 25mm 13.0 x 25mm 14.0 x 25mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 16 Pc. 1/4” Drive Socket Set - Metric Item No. Description Case Pack 33391 1/4” Drive Socket Set 1 Metric: 4, 4.5, 5, 5.5, 6, 7, 8, 9, 10, 11, 12, 13, 14mm 1/4” Ratchet - 5.0” OAL 1/4” Extension Bar - 3.0” & 6.0” OAL Includes Wire Rack 12 Pc. Inch Combination Wrench Set Item No. Description Case Pack 30494 Combo Wrench Set 3 Inch: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16” Includes Wire Rack 12 Pc. Metric Combination Wrench Set Item No. Description Case Pack 30491 Combo Wrench Set 1 Metric: 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 17.0, 18.0, 19.0mm 1/4” Drive Deep Sockets - 6 Points Item No. 33329 33330 33331 33332 33333 33334 33337 33338 33339 33340 Description 5/32 x 2.0” 3/16 x 2.0” 1/4 x 2.0” 9/32 x 2.0” 5/16 x 2.0” 11/32 x 2.0” 3/8 x 2.0” 7/16 x 2.0” 1/2 x 2.0” 9/16 x 2.0” Case Pack 3 3 3 3 3 3 3 3 3 3 13 Pc. 1/4” Drive Deep Socket Set - Inch Item No. Description Case Pack 33392 1/4” Drive Socket Set 1 Inch: 5/32, 3/16, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16” 1/4” Ratchet - 5.0” OAL 1/4” Extension Bar - 3.0” & 6.0” OAL 1/4” Drive Deep Sockets - 6 Points 24 Pc. Combination Wrench Sets Item No. Description Case Pack 30495 Combo Wrench Set 1 MM: 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19mm Inch: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 5/16” Item No. 33341 33342 33343 33344 33345 33346 33347 33348 33349 33350 33351 Description 5.0 x 50mm 5.5 x 50mm 6.0 x 50mm 7.0 x 50mm 8.0 x 50mm 9.0 x 50mm 10.0 x 50mm 11.0 x 50mm 12.0 x 50mm 13.0 x 50mm 14.0 x 50mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 14 Pc. 1/4” Drive Deep Socket Set - Metric Item No. Description Case Pack 33393 1/4” Drive Socket Set 1 Metric: 5, 5.5, 6, 7, 8, 9, 10, 11, 12, 13, 14mm 1/4” Ratchet - 5.0” OAL 1/4” Extension Bar - 3.0” & 6.0” OAL 63 www.wihatools.com • USA | www.wihatools.ca • CANADA 3/8” Drive Inch Sockets - 12 Point Small - 11” x 7.75” x 1.25” 27 Pc. Metric 1/4” Drive Socket Tray Set Item No. Description Case Pack 33395 1/4” Drive Socket Set 1 Standard: 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0mm Deep Socket: 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0mm 1/4” Ratchet - 72 Tooth & 1/4” Universal Joint 1/4” Extension Bar - 3.0” & 6.0” OAL Item No. 33708 33709 33710 33711 33712 33713 33714 33715 33716 33717 33718 33719 33720 Description 1/4” x 1.1” 9/32 x 1.1” 5/16 x 1.1” 11/32 x 1.1” 3/8” x 1.1” 7/16 x 1.1” 1/2 x 1.1” 9/16 x 1.1” 5/8 x 1.1” 11/16 x 1.1” 3/4 x 1.1” 13/16 x 1.2” 7/8 x 1.2” Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3/8” Universal Joint Socket Adapter Item No. Description 33770 3/8” Socket Adapter Case Pack 3 Small - 11” x 7.75” x 1.25” 24 Pc. Metric 3/8” Drive Socket Tray Set Item No. Description Case Pack 33795 3/8” Drive Socket Set 1 Standard: 8.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 17.0, 18.0, 19.0mm Deep Socket: 8.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 17.0, 18.0, 19.0mm 3/8” Ratchet - 72 Tooth & 3/8” Universal Joint 3/8” Extension Bar - 3.0” & 6.0” OAL 17 Pc. 3/8” Drive Socket Set - Inch 3/8” Drive Metric Sockets - 12 Point Small - 11” x 7.75” x 1.25” 25 Pc. Inch 1/4” Drive Socket Tray Set Item No. Description Case Pack 33396 1/4” Drive Socket Set 1 Standard: 5/32, 3/16, 7/32, 9/32, 5/16, 11/32, 3/8, 1/4, 7/16, 1/2, 9/16” Deep Socket: 5/32, 3/16, 7/32, 9/32, 5/16, 11/32, 3/8, 1/4, 7/16, 1/2, 9/16” 1/4” Ratchet - 72 Tooth & 1/4” Universal Joint 1/4” Extension Bar - 3.0” & 6.0” OAL Item No. 33721 33722 33723 33724 33725 33726 33727 33728 33729 33730 33731 33732 33733 33734 33735 33736 33737 33738 Description 6.0 x 28mm 7.0 x 28mm 8.0 x 28mm 9.0 x 28mm 10.0 x 28mm 11.0 x 28mm 12.0 x 28mm 13.0 x 28mm 14.0 x 28mm 15.0 x 28mm 16.0 x 28mm 17.0 x 28mm 18.0 x 28mm 19.0 x 28mm 20.0 x 30mm 21.0 x 30mm 22.0 x 30mm 24.0 x 30mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Item No. Description Case Pack 33790 3/8” Drive Socket Set 1 Inch: 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8” 3/8” Ratchet - 5.0” OAL 3/8” Extension Bar - 3.0”, 6.0”, 10.0” OAL Small - 11” x 7.75” x 1.25” 22 Pc. Inch 3/8” Drive Socket Tray Set 22 Pc. 3/8” Drive Socket Set - Metric Item No. Description Case Pack 33796 3/8” Drive Socket Set 1 Standard: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4” Deep Socket: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4” 3/8” Ratchet - 72 Tooth & 3/8” Universal Joint 3/8” Extension Bar - 3.0” & 6.0” OAL Item No. Description Case Pack 33791 3/8” Drive Socket Set 1 Metric: 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 24mm 3/8” Ratchet - 5.0” OAL 3/8” Extension Bar - 3.0”, 6.0”, 10.0” OAL 1/2” Drive Ratchet Item No. Description 33801 257mm/10.0” OAL 49 Pc. Master 1/4” Drive Socket Set Item No. Description Case Pack 33399 1/4” Drive Socket Set 1 SAE Standard: 5/32, 3/16, 7/32, 9/32, 5/16, 11/32, 3/8, 1/4, 7/16, 1/2, 9/16” SAE Deep Socket: 5/32, 3/16, 7/32, 9/32, 5/16, 11/32, 3/8, 1/4, 7/16, 1/2, 9/16” Metric Standard: 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0mm Metric Deep Socket: 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0mm 1/4” Ratchet - 72 Tooth & 1/4” Universal Joint 1/4” Extension Bar - 3.0” & 6.0” OAL Case Pack 3 3/8” Drive Deep Inch Sockets - 12 Point Item No. 33739 33740 33741 33742 33743 33744 33745 33746 33747 33748 33749 Description 1/4” x 2.5” 5/16 x 2.5” 3/8” x 2.5” 7/16 x 12.5” 1/2 x 2.5” 9/16 x 2.5” 5/8 x 2.5” 11/16 x 2.5” 3/4 x 2.5” 13/16 x 2.5” 7/8 x 2.5” Case Pack 3 3 3 3 3 3 3 3 3 3 3 1/2” Drive Extension Bars 15 Pc. 3/8” Drive Deep Socket Set - Inch Item No. Description Case Pack 33792 3/8” Drive Socket Set 1 Inch: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8” 3/8” Ratchet - 5.0” OAL 3/8” Extension Bar - 3.0”, 6.0”, 10.0” OAL Item No. 33803 33804 33805 Description 76mm/3.0” OAL 152mm/6.0” OAL 254mm/10.0” OAL Case Pack 3 3 3 3/8” Drive Deep Metric Sockets - 12 Point 3/8” Drive Ratchet Item No. Description 33701 178mm/7” OAL Case Pack 3 3/8” Drive Extension Bars Item No. 33702 33703 33704 33705 Description 127mm/5.0” OAL 76mm/3.0” OAL 152mm/6.0” OAL 254mm/10.0” OAL Case Pack 3 3 3 3 Item No. 33750 33751 33752 33753 33754 33755 33756 33757 33758 33759 33760 33761 33762 33763 33764 33765 Description 7.0 x 63mm 8.0 x 63mm 9.0 x 63mm 10.0 x 63mm 11.0 x 63mm 12.0 x 63mm 13.0 x 63mm 14.0 x 63mm 15.0 x 63mm 16.0 x 63mm 17.0 x 63mm 18.0 x 63mm 19.0 x 63mm 20.0 x 63mm 21.0 x 63mm 22.0 x 63mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 63 Pc. Master 3/8” Drive Socket Set 20 Pc. 3/8” Drive Deep Socket Set - Metric Item No. Description Case Pack 33793 3/8” Drive Socket Set 1 Metric: 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22mm 3/8” Ratchet - 5.0” OAL 3/8” Extension Bar - 3.0”, 6.0”, 10.0” OAL Item No. Description Case Pack 33799 3/8” Drive Socket Set 1 SAE Standard: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8” SAE Deep Socket: 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8” Metric Standard: 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 17.0, 18.0, 19.0, 20.0, 21.0, 22.0, 24.0mm Metric Deep Socket: 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 17.0, 18.0, 19.0, 20.0, 21.0, 22.0mm 3/8” Ratchet - 72 Tooth & 3/8” Universal Joint 3/8” Extension Bar - 3.0” / 6.0” / 10.0” OAL 64 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA 1/2” Drive Inch Sockets - 12 Point Item No. 33807 33808 33809 33810 33811 33812 33813 33814 33815 33816 33817 33818 33819 33820 33821 33822 33823 Description 5/16 x 1.5” 11/32 x 1.5” 3/8 x 1.5” 7/16 x 1.5” 1/2 x 1.5” 9/16 x 1.5” 5/8 x 1.5” 11/16 x 1.5” 3/4 x 1.5” 13/16 x 1.5” 7/8 x 1.5” 15/16 x 1.6” 1 x 1.7” 1-1/16 x 1.7” 1-1/8 x 1.7” 1-3/16 x 1.7” 1-1/4 x 1.7” Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 1/2” Drive Metric Sockets - 12 Point Item No. 33824 33825 33826 33827 33828 33829 33830 33831 33832 33833 33834 33835 33836 33837 33838 33839 33840 33841 33842 33843 33844 33845 33846 33847 33848 33850 Description 8.0 x 38mm 9.0 x 38mm 10.0 x 38mm 11.0 x 38mm 12.0 x 38mm 13.0 x 38mm 14.0 x 38mm 15.0 x 38mm 16.0 x 38mm 17.0 x 38mm 18.0 x 38mm 19.0 x 38mm 20.0 x 38mm 21.0 x 38mm 22.0 x 38mm 23.0 x 40mm 24.0 x 40mm 25.0 x 42mm 26.0 x 42mm 27.0 x 44mm 28.0 x 44mm 29.0 x 44mm 30.0 x 44mm 31.0 x 44mm 32.0 x 44mm 34.0 x 44mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 1/2” Drive Metric Deep Sockets - 12 Point Item No. 33866 33867 33868 33869 33870 33871 33872 33873 33874 33875 33876 33877 33878 33879 33880 33881 33882 33884 33885 33886 33888 Description 10.0 x 77mm 11.0 x 77mm 12.0 x 77mm 13.0 x 77mm 14.0 x 77mm 15.0 x 77mm 16.0 x 77mm 17.0 x 77mm 18.0 x 77mm 19.0 x 77mm 20.0 x 77mm 21.0 x 77mm 22.0 x 77mm 23.0 x 77mm 24.0 x 77mm 25.0 x 77mm 26.0 x 77mm 28.0 x 77mm 29.0 x 77mm 30.0 x 77mm 32.0 x 77mm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 19 Pc. 1/2” Drive Deep Socket Set - Inch 84 Pc. Master 1/2” Drive Socket Set Item No. Description Case Pack 33892 1/2” Drive Socket Set 1 Inch: 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1, 1-1/16, 1-1/8, 1-3/16, 1-1/4” 1/2” Ratchet - 5.0” OAL 1/2” Extension Bar - 3.0”, 6.0”, 10.0” OAL Item No. Description Case Pack 33899 1/2” Drive Socket Set 1 SAE Standard: 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1, 1-1/16, 1-1/8, 1-3/16, 1-1/4” SAE Deep Socket: 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1, 1-1/16, 1-1/8, 1-3/16, 1-1/4” Metric Standard: 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 17.0, 18.0, 19.0, 20.0, 21.0, 22.0, 24.0, 25.0, 26.0, 27.0, 28.0, 29.0, 30.0, 31.0, 32.0, 34.0mm Metric Deep Socket: 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 17.0, 18.0, 19.0, 20.0, 21.0, 22.0, 23.0, 24.0, 25.0, 26.0, 28.0, 29.0, 30.0, 32.0mm 1/2” Ratchet - 72 Tooth & 1/2” Universal Joint 1/2” Extension Bar - 3.0” / 6.0” / 10.0” OAL 25 Pc. 1/2” Drive Deep Socket Set - Metric Item No. Description Case Pack 33893 1/2” Drive Socket Set 1 Metric: 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 28, 29, 30, 32mm 1/2” Ratchet - 5.0” OAL 1/2” Extension Bar - 3.0”, 6.0”, 10.0” OAL 1/2” Universal Joint Socket Adapter Item No. Description 33889 1/2” Socket Adapter Case Pack 3 Digital Caliper DigiMax Item No. Description 41101 Reading 0.0005” 6”OAL Case Pack 3 Medium - 15.5” x 11” x 1.25” 29 Pc. Metric 1/2” Drive Socket Tray Set 21 Pc. 1/2” Drive Socket Set - Inch Item No. Description Case Pack 33890 1/2” Drive Socket Set 1 Inch: 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1, 1-1/16, 1-1/8” 1/2” Ratchet - 5.0” OAL 1/2” Extension Bar - 3.0”, 6.0”, 10.0” OAL Item No. Description Case Pack 33895 1/2” Drive Socket Set 1 Standard: 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 17.0, 18.0, 19.0, 20.0, 21.0mm Deep Socket: 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 17.0, 18.0, 19.0, 20.0, 21.0, 22.0mm 1/2” Ratchet - 72 Tooth & 1/2” Universal Joint 1/2” Extension Bar - 3.0” & 6.0” OAL Dial Caliper DigiMax - Metric & Inch Item No. Description 41102 Metric reading 0.1mm 41104 Inch reading .001” Case Pack 3 3 Vernier CaliperCaliMax Item No. Description 41103 Reading .1mm + 1/64” Case Pack 3 1/2” Drive Inch Deep Sockets - 12 Point Item No. 33851 33852 33853 33854 33855 33856 33857 33858 33859 33860 33861 33862 33863 33864 33865 Description 3/8 x 3.0” 7/16 x 3.0” 1/2 x 3.0” 9/16 x 3.0” 5/8 x 3.0” 11/16 x 3.0” 3/4 x 3.0” 13/16 x 3.0” 7/8 x 3.0” 15/16 x 3.0” 1 x 3.0” 1-1/16 x 3.0” 1-1/8 x 3.0” 1-3/16 x 3.0” 1-1/4 x 3.0” Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Medium - 15.5” x 11” x 1.25” 28 Pc. Inch 1/2” Drive Socket Tray Set 30 Pc. 1/2” Drive Socket Set - Metric Item No. Description Case Pack 33891 1/2” Drive Socket Set 1 Metric: 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 34mm 1/2” Ratchet - 5.0” OAL 1/2” Extension Bar - 3.0”, 6.0”, 10.0” OAL Item No. Description Case Pack 33896 1/2” Drive Socket Set 1 Standard: 5/32, 3/16, 7/32, 9/32, 5/16, 11/32, 3/8, 1/4, 7/16, 1/2, 9/16” Deep Socket: 5/32, 3/16, 7/32, 9/32, 5/16, 11/32, 3/8, 1/4, 7/16, 1/2, 9/16” 1/2” Ratchet - 72 Tooth & 1/2” Universal Joint 1/2” Extension Bar - 3.0” & 6.0” OAL ESD Safe Dial Caliper DigiMax - Metric & Inch Item No. Description 41105 Inch reading .001” 41106 Metric reading 0.1mm Case Pack 3 3 65 www.wihatools.com • USA | www.wihatools.ca • CANADA For Dead Blow Hammers 800 & 802 Series Universal Razor Edge Scraper Handle Item No. Description 43040 Cushion Grip Handle Only Handle Size: 140mm OAL Case Pack 3 3/8” Drive Converter To 1/4” Item No. Description 60270 Long Case Pack 3 1/2” Drive Converter To 3/8” Item No. Description 60368 Long Case Pack 3 MaxiFlex Inside Reading Long Life Ruler Item No. Description 61609 Increments 1/16” Case Pack 3 Medium Hard Faces For Dead Blow Hammers Item No. 80200 80202 80204 80206 80208 80210 Description 25mm (1.0”) 30mm (1.2”) 35mm (1.4”) 40mm (1.6”) 45mm (1.8”) 50mm (2.0”) Case Pack 3 3 3 3 3 3 MaxiFlex Outside Reading 6” Depth Extension Item No. Description 61620 Increments 1/16” Case Pack 3 Extra Hard Faces For Dead Blow Hammers Item No. Description 80203 30mm (1.2”) 80207 40mm (1.6”) 80211 50mm(2.0”) Universal Razor Edge Scraper Handle & Blades Item No. Description Case Pack 43090 Cushion Grip Handle 3 Size: 140mm OAL & 10 replacement blades (#43092) Case Pack 3 3 3 For Dead Blow Hammers 800 & 802 Series Medium Hard Faces For Sledge Hammers Item No. Description 80219 80mm (3.1”) 80222 100mm (3.9”) #43092 #43093 #43094 #43095 #43096 Replacement Blades For Universal Scraper Item No. 43092 43093 43094 43095 43096 Description 10 Pack Blades 10 Pack Blades 10 Pack Blades 10 Pack Blades 10 Pack Blades Case Pack 3 3 3 3 3 MaxiFlex Folding Ruler - 1/16” Increments Item No. Description 61601 39”/1m Compact Case Pack 3 MaxiFlex Combo MM/In Long Life Ruler Item No. Description 61662 Increments 1/16” Case Pack 3 Steel Tube Shaft Dead Blow Hammer - Medium Hard Face 10 Pc. Combo Pack Replacement Blades Item No. Description 43097 2 of each blades Case Pack 3 3 Case Pack 3 MaxiFlex Outside Reading Metric Long Life Item No. Description 61602 Increments 1mm to CM Case Pack 3 Dead Blow Hammer - Medium Hard Face Item No. 80025 80030 80035 80040 80045 80050 80070 Description 25 x 320mm 30 x 350mm 35 x 355mm 40 x 375mm 45 x 380mm 50 x 385mm 70 x 430mm Case Pack 3 3 3 3 3 3 3 Item No. 80225 80230 80235 80240 80245 80250 80260 80270 Description 25 x 288mm 30 x 290mm 35 x 300mm 40 x 305mm 45 x 310mm 50 x 365mm 60 x 375mm 70 x 385mm Case Pack 3 3 3 3 3 3 3 3 Dead Blow Sledge Hammer - Med. Hard Face Item No. Description 80280 80 x 882mm 80299 100 x 1002mm Composite Folding Ruler 1/4” Drive Converter To 3/8” Item No. Description 60140 27mm/1.06” OAL Case Pack 3 Long Life Metric Ruler With Reverse Scale Item No. Description 61604 Metric Folding Ruler Case Pack 3 Hickory Handles For Dead Blow Hammers Item No. Description 80071 25mm 80072 30/35mm 80074 40/45mm 80076 50mm 80081 100mm 3/8” Drive Converter To 1/2” Item No. Description 60260 35mm/1.38” OAL Case Pack 3 Case Pack 1 1 Long Life Inch/Metric Folding Ruler Item No. Description 61606 In/MM Folding Ruler Case Pack 3 Steel Tube Shaft Case Pack 3 3 3 3 3 Medium Hard Faces 3 Pc. Dead Blow Hammer Set Item No. Description 80290 3 Pc. Hammer Set 30, 40, 50mm Case Pack 1 66 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA TPE Malleable Cast Iron Split Head Housing Item No. 83221 83222 83223 83224 83225 Description 30mm x 260mm 40mm x 280mm 50mm x 310mm 60mm x 340mm 80mm x 400mm Case Pack 1 1 1 1 1 Latex Cell Rubber Polyurethane Acetate Nylon Color Coded Faces For H.D. Split Head Mallets Item No. 83241 83242 83243 83244 83245 Description 40mm, 21-D, Blue 40mm, 45-D, Black 40mm, 65-D, Yellow 40mm, 72-D, Orange 40mm, 80-D, White Case Pack 3 3 3 3 3 Replacement Heavy Duty Mallet Housing Item No. 83238 83248 83258 83268 83288 Description 30mm (1.2”) 40mm (1.6”) 50mm (2.0”) 60mm (2.4”) 80mm (3.1”) Case Pack 3 3 3 3 3 Universal Rails For 1/4”, 3/8” & 1/2” Sockets Item No. Description 91132 8” Universal Socket Rail 91134 14” Universal Socket Rail Case Pack 3 3 40mm/1.5” Hickory Replacement Handles TPE Malleable Cast Iron Split Head Mallets Item No. 83230 83240 83250 83260 Description 30mm x 260mm 40mm x 280mm 50mm x 310mm 60mm x 340mm Case Pack 1 1 1 1 Latex Cell Rubber Polyurethane Acetate Nylon Split Head Mallet Set Item No. Description Case Pack 83246 Split Head Mallet Set 1 40mm Mallet Housing w/Hickory Handle 40mm Soft, Med Soft, Med Hard, Hard & Ex Hard Faces Item No. 83273 83274 83275 83276 83277 83279 Description 30mm x 260mm 40mm x 280mm 50mm x 310mm 60mm x 340mm 80mm x 400mm 80mm x 800mm Case Pack 3 3 3 3 3 3 Item No. Description 91117 10 Pc. Clips For Rail Case Pack 3 3/8” Socket Replacement Clips For Socket Rail Item No. Description 91121 10 Pc. Clips For Rail Malleable Cast Iron Split Head Sledge Hammer Item No. Description 83289 80mm x 800mm 1/4” Socket Replacement Clips For Socket Rail Case Pack 1 Case Pack 3 Latex Rubber Nylon Color Coded Faces For H.D. Split Head Mallets TPE Latex Cell Rubber Polyurethane Acetate Item No. Description 83282 80mm, 45-D, Black 83285 80mm, 80-D, White Case Pack 3 3 Nylon Color Coded Faces For H.D. Split Head Mallets Item No. 83251 83252 83253 83254 83255 TPE Latex Cell Rubber Polyurethane Acetate Description 50mm, 21-D, Blue 50mm, 45-D, Black 50mm, 65-D, Yellow 50mm, 72-D, Orange 50mm, 80-D, White Case Pack 3 3 3 3 3 1/2” Socket Replacement Clips For Socket Rail Item No. Description 91124 10 Pc. Clips For Rail Nylon Color Coded Faces For H.D. Split Head Mallets Item No. 83231 83232 83233 83234 83235 Description 30mm, 21-D, Blue 30mm, 45-D, Black 30mm, 65-D, Yellow 30mm, 72-D, Orange 30mm, 80-D, White Case Pack 3 3 3 3 3 50mm/2.0” TPE Latex Cell Rubber Polyurethane Acetate Nylon Split Head Mallet Set Item No. Description Case Pack 83256 Split Head Mallet Set 1 50mm Mallet Housing w/Hickory Handle 50mm Soft, Med Soft, Med Hard, Hard & Ex Hard Faces 30mm/1.2” TPE Latex Cell Rubber Polyurethane Acetate Nylon Split Head Mallet Set Item No. Description Case Pack 83236 Split Head Mallet Set 1 30mm Mallet Housing w/Hickory Handle 30mm Soft, Med Soft, Med Hard, Hard & Ex Hard Faces TPE Latex Cell Rubber Polyurethane Acetate Nylon Color Coded Faces For H.D. Split Head Mallets Item No. 83261 83262 83263 83264 83265 Description 60mm, 21-D, Blue 60mm, 45-D, Black 60mm, 65-D, Yellow 60mm, 72-D, Orange 60mm, 80-D, White Case Pack 3 3 3 3 3 15 Pc. Split Head Mallet Set Item No. Description Case Pack 83290 Split Head Mallet Set 1 30mm & 50mm Mallet Housing w/Hickory Handle 30mm Soft, Med Soft, Med Hard, Hard & Ex Hard Faces 50mm Soft, Med Soft, Med Hard, Hard & Ex Hard Faces 5.0 & 8.0 Hex Assembly L-keys & Canvas Tool Bag Case Pack 3 67 www.wihatools.com • USA | www.wihatools.ca • CANADA TorqueControl Tools Precision formed for exact fit Direct Reading Scale +/-6% accuracy tolerance Certificate of calibration Direct Reading Window Scale TorqueFix Newton Meter Wing Handles Item No. 28349 28351 28355 28359 Description 0.5 Nm 0.6 Nm 1.4 Nm 3.8 Nm Case Pack 3 3 3 3 Adjustable TorqueVario With 4mm Bit Holder Item No. Description 28404 5-18 in/lbs. 28408 18-62 in/lbs. Direct Reading Scale Case Pack 1 1 ESD Safe Nm TorqueVario Handle Item No. Description 28500 4 - 46 Nm +/-6% accuracy tolerance Certificate of calibration Direct Reading Scale Adjustable TorqueVario With 1/4” Bit Holder TorqueFix Hex Inch & Metric Blades - 75mm Item No. 28361 28364 28365 Description 1.5 x 75mm - 0.9Nm 3.0 x 75mm - 5.5Nm 4.0 x 75mm - 8.0Nm Case Pack 3 3 3 Item No. Description 28410 15-80 in/oz. 28411 5-10 in/lbs. 28412 10-50 in/lbs. 28413 5-18 in/lbs. 28414 18-62 in/lbs. *28410 +/- 10% (This unit only) Case Pack 1 1 1 1 1 +/-10% accuracy tolerance Certificate of calibration Case 1Pack 1 Adj. TorqueVario w/Direct Reading Scale Item No. Description 28501* 15-80 in/oz. 28502 5-10 in/lbs. 28506 10-50 in/lbs. *28501 +/- 10% (This unit only) Case Pack 1 1 1 SoftFinish Cushion Grip TorqueFix Handle ® TorqueFix TORX Blades - 75mm Item No. 28374 28377 28378 28379 28380 28381 Description T6 x 75mm - 0.6Nm T9 x 75mm - 2.5Nm T10 x 75mm - 3.8Nm T15 x 75mm - 5.5Nm T20 x 75mm - 8.0Nm T25 x 75mm - 8.0Nm Case Pack 3 3 3 3 3 3 TorqueFix TORXPlus Blades - 75mm Item No. 28382 28383 28385 28386 28388 28389 Description IP6 x 75mm - 0.8Nm IP7 x 75mm - 1.3Nm IP9 x 75mm - 3.0Nm IP10 x 75mm - 4.5Nm IP20 x 75mm - 8.0Nm IP25 x 75mm - 8.0Nm Case Pack 3 3 3 3 3 3 Adjustable TorqueVario With 4mm Bit Holder Item No. 28415 28416 28417 28418 28419 Description 0.1 - 0.6 Nm 0.4 - 1.0 Nm 0.5 - 2.0 Nm 0.8 - 5.0 Nm 2.0 - 7.0 Nm Direct Reading Window Scale Case Pack 1 1 1 1 1 +/-6% accuracy tolerance Certificate of calibration ESD Safe Adjustable TorqueVario-S Item No. Description 28426 5-18 in/lbs. Case Pack 1 Item No. 28503 28505 28507 28509 28511 28513 28515 28517 28518 28519 28521 28523 Description 80oz. - 5lbs. 120oz. - 7.5lbs. 160oz. - 10lbs. 200oz. - 12.5lbs. 240oz. - 15lbs. 320oz. - 20lbs. 400oz. - 25lbs. 480oz. - 30lbs. 560oz. - 35lbs. 640oz. - 40lbs. 800oz. - 50lbs. 960oz. - 60lbs. Direct Reading Window Scale Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 +/-6% accuracy tolerance Certificate of calibration ESD Safe Adjustable TorqueVario-S Item No. Description 28522 15-80 in/oz. 28524 5-10 in/lbs. Description T6 x 175mm T7 x 175mm T8 x 175mm T9 x 175mm T10 x 175mm T15 x 175mm T20 x 175mm T25 x 175mm Case Pack 3 3 3 3 3 3 3 3 +/-6% accuracy tolerance Certificate of calibration +/-6% accuracy tolerance Certificate of calibration Direct Reading Scale TorqueControl MagicSpring TORX® Blade Item No. 28512 28527 28528 28529 28530 28531 28532 28533 Case Pack 1 1 TorqueControl Slotted Blade Item No. 28534 28535 28536 28537 28538 28539 Description 1.5 x 175mm 2.0 x 175mm 2.5 x 175mm 3.0 x 175mm 3.5 x 175mm 4.0 x 175mm Case Pack 3 3 3 3 3 3 TorqueControl Phillips Blade Item No. 28540 28541 28542 28543 28544 Description 000 x 175mm 00 x 175mm 0 x 175mm 1 x 175mm 2 x 175mm Case Pack 3 3 3 3 3 TorqueControl Hex Metric Blade Item No. 28545 28546 28547 28548 28549 Description 1.5 x 175mm 2.0 x 175mm 2.5 x 175mm 3.0 x 175mm 4.0 x 175mm Direct Reading Scale Case Pack 3 3 3 3 3 +/-6% accuracy tolerance Certificate of calibration Adj. TorqueVario w/Direct Reading Scale Item No. 28550 28551 28552 28553 28655 Description 0.1 - 0.6 Nm 0.4 - 1.0 Nm 0.5 - 2.0 Nm 0.8 - 5.0 Nm 2.0 - 7.0 Nm Case Pack 1 1 1 1 1 68 Toll Free: (800) 494-6104 • USA | Toll Free: (800) 494-0096 • CANADA In Canvas Pouch TorqueControl Hex Inch Blade Item No. 28555 28556 28557 28558 28559 28560 28587 28588 Description .050 x 175mm 1/16 x 175mm 5/64 x 175mm 3/32 x 175mm 7/64 x 175mm 1/8 x 175mm 9/64 x 175mm 5/32 x 175mm Case Pack 3 3 3 3 3 3 3 3 TorqueControl TORX® Blade Item No. 28561 28562 28563 28564 28565 28566 28567 28568 28569 Description T5 x 175mm T6 x 175mm T7 x 175mm T8 x 175mm T9 x 175mm T10 x 175mm T15 x 175mm T20 x 175mm T25 x 175mm Case Pack 3 3 3 3 3 3 3 3 3 59 Pc. TorqueVario-S Bit Set Item No. Description Case Pack 28589 TorqueVario Bit Set 1 Slotted: 4.5, 5.5, 6.0mm Phillips: #0, 1, 2 TORX: T5, T6, T7, T8, T9, T10, T15, T20, T25, T30 Pozidriv: #1, 2 Square: 1, 2, 3 Hex In: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Hex Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0mm Sockets In.: 5/32, 3/16, 7/32, 1/4, 9/32, 5/16, 3/8” Sockets Metric: 4.0, 4.5, 5.0, 5.5, 6.0, 7.0, 8.0mm 1/4” Bit Holder & 1/4” Hex to 1/4” Square Adapter 3 Adjustable TorqueVario-S Handles: 15-80 In/oz., 5-10 In/lbs. & 10-50 In/lbs. In durable storage box 53 Pc. TorqueVario-S Bit Set 20 Pc. TorqueControl Blade Set Item No. Description Case Pack 28595 TorqueVario-S Bit Set 1 Slotted: 4.5, 5.5, 6.5, 8.0mm Phillips: #0, 1, 2, 3 TORX: T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 Pozidriv: #0, 1, 2, 3 Square: #1, 2, 3 Hex In: 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16” Hex Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0mm Torq Set: #4, 5, 6, 8 Tri-wing: #0, 1, 2, 3, 4 TorqueVario-S Handle 10-50 In/lbs. 1/4” Bit Holder Adapter Item No. Description Case Pack 28600 TorqueControl Blade Set 1 Slotted: 2.5, 3.5, 4.0mm & Phillips: #0, 1, 2 TORX: T7, T8, T9, T10, T15, T20 Hex Inch: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” TorqueVario-S Handle 10-50 in/lbs. Screw Holding TorqueControl MagicSpring TORXPlus® Blade Item No. 28611 28612 28613 28614 28616 28617 28618 28619 In Canvas Pouch Description IP6 x 175mm IP7 x 175mm IP8 x 175mm IP9 x 175mm IP10 x 175mm IP15 x 175mm IP20 x 175mm IP25 x 175mm Case Pack 3 3 3 3 3 3 3 3 8 Pc. TorqueControl Slotted/Phillips Blade Set TorqueControl TORXPlus® Blade Item No. 28571 28572 28573 28574 28575 28576 28577 28578 28579 Description IP5 x 175mm IP6 x 175mm IP7 x 175mm IP8 x 175mm IP9 x 175mm IP10 x 175mm IP15 x 175mm IP20 x 175mm IP25 x 175mm Case Pack 3 3 3 3 3 3 3 3 3 24 Pc. TorqueVario-S Micro Bit Set Item No. Description Case Pack 28590 TorqueVario-S Micro Bit Set 1 Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: #00, 0, 1 Hex In: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” TORX: T6, T7, T8, T9, T10, T15 Adjustable Torque Handle: 5-18 In/lbs. Item No. Description Case Pack 28596 Slotted & Phillips Blade Set 1 Slotted: 2.5, 3.0, 3.5, 4.0mm & Phillips: #0, 1 TorqueVario-S Handle 5-18 in/lbs. Torque handles recommended #28552 & #28504 Torque Cable Key For Threaded Hex Connectors In Canvas Pouch In durable storage box Item No. 28620 28622 28627 28629 28633 Description Nm 8mm x 218mm 1.0 9mm x 218mm 1.0 13mm x 218mm 1.5 14mm x 218mm 1.5 18mm x 218mm 1.5 Case Pack 3 3 3 3 3 8 Pc. TorqueControl TORX® Blade Set TorqueControl Bit Holder Adapter For 1/4” Bits Item No. Description 28581 1/4” x 149mm Case Pack 3 24 Pc. ESD Safe TorqueVario-S Micro Bit Set Item No. Description Case Pack 28591 ESD Safe Torque Micro Bit Set 1 Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: #00, 0, 1 Hex In: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” TORX: T6, T7, T8, T9, T10, T15 ESD Safe Torque Handle: 5-10 In/lbs. Case Pack 3 59 Pc. TorqueControl Tool Set In Canvas Pouch Square Drive Adapter For 1/4” Sockets Item No. Description 28582 1/4” x 145mm Item No. Description Case Pack 28597 TorqueControl TORX Blade Set 1 TORX: T7, T8, T9, T10, T15, T20 TorqueVario-S Handle 10-50 in/lbs. In durable storage box TorqueControl Adapter For 4mm Micro Bits Item No. Description 28583 4.0 x 149mm Case Pack 3 8 Pc. TorqueControl TORXPlus® Blade Set 24 Pc. TorqueVario-S Micro Bit Set Item No. Description Case Pack 28593 TorqueVario-S Micro Bit Set 1 Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: #00, 0, 1 Hex In: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” TORX: T6, T7, T8, T9, T10, T15 Adjustable Torque Handle: 15-80 In/oz. Item No. Description Case Pack 28689 TorqueVario Bit Set 1 Slotted: 4.5, 5.5, 6.0mm Phillips: #0, 1, 2 TORX: T5, T6, T7, T8, T9, T10, T15, T20, T25, T30 Pozidriv: #1, 2 Square: 1, 2, 3 Hex In: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” Hex Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0mm Sockets In.: 5/32, 3/16, 7/32, 1/4, 9/32, 5/16, 3/8” Sockets Metric: 4.0, 4.5, 5.0, 5.5, 6.0, 7.0, 8.0mm 1/4” Bit Holder & 1/4” Hex to 1/4” Square Adapter 3 Adjustable TorqueVario w/Direct Reading Handles: 0.1 - 0.6Nm, 0.4 - 1.0Nm, 1.0 - 5.0Nm Item No. Description Case Pack 28598 Torque TORXPlus Blade Set 1 TORXPlus: IP7, IP8, IP9, IP10, IP15, IP20 TorqueVario-S Handle 10-50 in/lbs. 14 Pc. TorqueControl Blade Set Item No. Description Case Pack 28599 TorqueControl Blade Set 1 TORX: T7, T8, T9, T10, T15, T20 TORXPlus: IP7, IP8, IP9, IP10, IP15, IP20 TorqueVario-S Handle 10-50 in/lbs. TorqueControl Insulated Socket Adapter Item No. Description 28700 6.0 x 180mm Case Pack 3 69 www.wihatools.com • USA | www.wihatools.ca • CANADA ESD Safe TorqueControl Pentalobe Blade Item No. Description 28818 PL1 x 175mm *Use handle #28500 with this blade Case Pack 3 TorqueControl Bit Holder Adapter For 1/4” Bits Item No. Description 28882 ESD Safe 1/4”x162mm Case Pack 3 1/4” Bit Holder 52 Pc. iTorque Bit Set - 7-26 In/lbs. Item No. Description Case Pack 28892 iTorque Bit Set 1 Slotted: 4.5, 5.5, 6.5, 8.0mm Phillips: #0, 1, 2, 3 TORX: T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 Pozidriv: #0, 1, 2, 3 Square: #1, 2, 3 Hex In: 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16” Hex Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0mm Torq Set: #4, 5, 6, 8 Tri-wing: #0, 1, 2, 3, 4 iTorque Handle 7-26 In/lbs. & 1/4” Bit Holder Adapter T-Handle TorqueControl TORX® Blade Item No. 28903 28904 28905 28906 28907 28908 Description T15 x 130mm T20 x 130mm T25 x 130mm T27 x 130mm T30 x 130mm T40 x 130mm Case Pack 3 3 3 3 3 3 52 Pc. iTorque Bit Set - 9-50 In/lbs. Item No. Description Case Pack 28896 iTorque Bit Set 1 Slotted: 4.5, 5.5, 6.5, 8.0mm Phillips: #0, 1, 2, 3 TORX: T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 Pozidriv: #0, 1, 2, 3 Square: #1, 2, 3 Hex In: 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16” Hex Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0mm Torq Set: #4, 5, 6, 8 Tri-wing: #0, 1, 2, 3, 4 iTorque Handle 9-45 In/lbs. & 1/4” Bit Holder Adapter iTorque Screwdriver Handle With Adapter T-Handle TorqueControl TORXPlus® Blade Item No. 28910 28911 28912 28913 28914 Description IP15 x 130mm IP20 x 130mm IP25 x 130mm IP27 x 130mm IP30 x 130mm Case Pack 3 3 3 3 3 T-Handle TorqueControl Hex Metric Blade Item No. Description Case Pack 28883 60-210 In/oz.-40-150 Ncm 1 28884 7-26 In/lbs. - .8-3.0 Nm 1 28885 9-45 In/lbs.-1.0-6.0 Nm 1 In durable storage box Item No. 28916 28917 28918 28919 Description 3.0 x 130mm 4.0 x 130mm 5.0 x 130mm 6.0 x 130mm Case Pack 3 3 3 3 iTorque Screwdriver Handle Item No. Description Case Pack 28886 60-210 In/oz.-40-150 Ncm 1 28887 7-26 In/lbs. - .8-3.0 Nm 1 28889 9-45 In/lbs.-1.0-6.0 Nm 1 TorqueFix Quick Release Bit Holder Item No. Description 28925 1/4” x 125mm Case Pack 3 In durable storage box TorqueFix Adapter For 1/4” & 3/8” Sockets Item No. Description 28926 1/4” x 100mm 24 Pc. ESD Safe TorqueVario-S Micro Bit Set Item No. Description Case Pack 28890 ESD Safe Torque Micro Bit Set 1 Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: #00, 0, 1 Hex In: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” TORX: T6, T7, T8, T9, T10, T15 Adjustable Torque Handle: 15-80 In/oz. Case Pack 3 Torque QuickCheck Item No. Description Case Pack 28897 Torque Quick Checker 1 Torque Checker, Adapter blades & 2 batteries In metal storage box TorqueFix T-Handle 52 Pc. iTorque Bit Set - 60-210 In/oz. Item No. Description Case Pack 28891 iTorque Bit Set 1 Slotted: 4.5, 5.5, 6.5, 8.0mm Phillips: #0, 1, 2, 3 TORX: T6, T7, T8, T9, T10, T15, T20, T25, T27, T30 Pozidriv: #0, 1, 2, 3 Square: #1, 2, 3 Hex In: 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16” Hex Metric: 1.5, 2.0, 2.5, 3.0, 4.0, 5.0, 6.0, 8.0mm Torq Set: #4, 5, 6, 8 Tri-wing: #0, 1, 2, 3, 4 iTorque Handle 60-210 In/oz. & 1/4” Bit Holder Adapter Description 4.4 In/lbs. - 0.5 Nm 5.3 In/lbs. - 0.6 Nm 7.9 In/lbs. - 0.9 Nm 9.7 In/lbs. - 1.1 Nm 10.6 In/lbs. - 1.2 Nm 12.4 In/lbs. - 1.4 Nm 17.7 In/lbs. - 2.0 Nm 22.1 In/lbs. - 2.5 Nm 26.6 In/lbs. - 3.0 Nm 33.6 In/lbs. - 3.8 Nm 35.4 In/lbs. - 4.0 Nm 39.8 In/lbs. - 4.5 Nm 44.2 In/lbs. - 5.0 Nm Case Pack 3 3 3 3 3 3 3 3 3 3 3 3 3 easyTorque TORX Screwdrivers Item No. Description Case Pack 29232 T5 - 4.4 In/lbs.-0.5Nm 3 29233 T6 - 5.3 In/lbs.-0.6Nm 3 29234 T7 - 8.0 In/lbs.-0.9Nm 3 29236 T8 - 10.6 In/lbs.-1.2Nm 3 29237 T9 - 12.4 In/lbs.-1.4Nm 3 29239 T10 - 17.7 In/lbs.-2.0Nm 3 29242 T15 - 26.6 In/lbs.-3.0Nm 3 29243 T20 - 35.4 In/lbs.-4.0Nm 3 29244 T25 - 44.2 In/lbs.-5.0Nm 3 easyTorque TORXPlus Screwdrivers 24 Pc. ESD Safe TorqueVario-S Micro Bit Set Item No. Description Case Pack 28895 Torque Micro Bit Set 1 Slotted: .8, 1.2, 1.5, 1.8, 2.0mm Phillips: #000, 00, 0 & Hex: .7, .9, 1.3mm TORX: T1, T2, T3, T4, T5, T6 Pentelobe: PL1, PL2, PL3, PL4 Adjustable Torque Handle: .04-.46 Nm (+/- 10%) easyTorque Screwdriver Handles Item No. 29205 29206 29209 29211 29212 29214 29220 29225 29230 29238 29241 29245 29251 Item No. 28931 28933 28935 28937 28938 28939 Description 53.1 In/lbs.-6 Nm 70.8 In/lbs.-8 Nm 88.5 In/lbs.-10 Nm 106.2 In/lbs.-12 Nm 110.6 In/lbs.-12.5 Nm 123.9 In/lbs.-14 Nm Case Pack 1 1 1 1 1 1 Adjustable TorqueVario STplus T-Handle Item No. Description Case Pack 28940 44.3 - 123.9 In/lbs. 1 5 - 14 Nm (Scale is shown in Nm only) Item No. Description Case Pack 29246 IP5 - 4.4 In/lbs.-0.5Nm 3 29247 IP6 - 5.3 In/lbs.-0.6Nm 3 29248 IP7 - 8.0 In/lbs.-0.9Nm 3 29249 IP8 - 10.6 In/lbs.-1.2Nm 3 29252 IP9 - 12.4 In/lbs.-1.4Nm 3 29253 IP10 - 17.7 In/lbs.-2.0Nm 3 29254 IP15 - 26.6 In/lbs.-3.0Nm 3 29255 IP20 - 35.4 In/lbs.-4.0Nm 3 29256 IP25 - 44.2 In/lbs.-5.0Nm 3 70 Toll Free: (800) 494-6104 Available Storage Pouches Rugged Polyester Canvas Storage Pouch Item No. Description Case Pack 91118 Storage Pouch 1 Pouch Size: 14-1/2” W x 7-3/4” L Holds 8 precision tools up to 170mm in length. Folding pouch, has security flaps and velcro closure. 16” Cordura® Tool Bag Cordura® General Purpose Zipper Bag Item No. Description Case Pack 91473 Storage Pouch 1 Pouch Size: 9.75 x 7.25 x 3.0” Heavy duty nylon. Keeps Wiha tools and accessories organized. Item No. Description Case Pack 91487 Storage Pouch 1 Tool Bag Size: 16” x 8.5” x 11” Heavy duty canvas bag has 12 exterior pockets and 10 interior pockets. Handles with Velcro closure. Shoulder strap included. 23” Cordura® Tool Bag Roll-Up Tool Pouch Item No. Description Case Pack 91459 Storage Pouch 1 Pouch Size: 14” W x 7.5” L Holds 10 precision tools up to 170mm in length. Has security flaps and elastric strap. Cordura® Electrician’s Belt Pouch Item No. Description Case Pack 91488 Storage Pouch 1 Tool Bag Size: 23” x 12” x 12” Heavy duty canvas bag has 12 exterior pockets and 10 interior pockets. Handles with Velcro closure. Shoulder strap included. Item No. Description Case Pack 91482 Storage Pouch 1 Pouch Size: 10.5” x 9.0” x 3.0” Heavy duty nylon. Keeps Wiha tools and accessories organized. Tools not included Cordura Utility Organizer Zipper Pouch 12” Tool Bag Item No. Description Case Pack 91472 Storage Pouch 1 Pouch Size: 8.0” x 4.5” x 1.5” Multiple interior webbing positions to store tools and accessories. Item No. Description Case Pack 91486 Storage Pouch 1 Tool Bag Size: 12.5” x 9.0” Heavy duty canvas bag has 6 pockets. Handles with Velcro closure. 3 exterior pockets & 3 interior pockets ® Slim Bit Velcro Pouch Item No. Description Case Pack 91584 Storage Pouch 1 Folded Pouch Size: 8” x 4.5” x 2.25” Flat Pouch Size: 13.5” x 8.0” x .25” Heavy duty canvas tool pouch holds up to 20 SlimLine blades, handles & adapters 71 www.wihatools.com Numerical Index by Item Number Item No. Page 10250 10891 10892 10893 10895 11610 11950 11960 11975 11980 12326 12327 12411 12424 12851 12852 12853 12854 12855 12856 12857 12858 12859 13650 13651 13652 13653 13654 13655 13656 13657 13658 13659 13662 13663 13664 13665 13666 13667 13668 13669 13670 13671 13672 13673 13690 13691 13693 13694 15000 15003 15050 19767 20006 20007 20008 20009 20010 20011 20012 20013 20014 20015 20016 20017 20018 20019 20020 20022 20024 20027 20030 20032 20091 20093 20131 20133 20135 20136 20137 2 32 32 32 32 2 2 2 2 2 2 2 61 61 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Item No. Page 20138 20140 20141 20142 20144 20145 20146 20147 20148 20149 20151 20154 20190 20192 20194 20196 21008 21009 21010 21011 21012 21013 21014 21015 21017 21019 21020 21022 21024 21027 21030 21032 21040 21042 21044 21046 21048 21050 21052 21054 21056 21057 21058 21060 21062 21064 21066 21068 21093 21094 21095 21096 21103 21105 21208 21209 21210 21211 21212 21213 21214 21215 21216 21217 21218 21219 21290 21319 21321 21323 21325 21327 21329 21331 21333 21334 21335 21336 21337 21391 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 20 20 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 Item No. Page 23420 23421 23422 23423 23424 23425 23426 23427 23428 23429 23432 23433 23434 23490 23493 25505 25506 25511 26000 26003 26004 26008 26010 26012 26015 26018 26020 26022 26023 26025 26027 26028 26030 26032 26033 26034 26035 26040 26041 26042 26050 26051 26052 26053 26055 26060 26061 26065 26066 26068 26070 26072 26074 26076 26079 26090 26091 26092 26093 26099 26100 26101 26102 26103 26105 26107 26108 26109 26110 26113 26114 26115 26130 26132 26135 26136 26140 26187 26190 26191 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 4 4 4 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 Item No. Page 26192 26193 26194 26195 26196 26197 26198 26199 26205 26210 26307 26309 26313 26315 26316 26320 26323 26325 26327 26330 26331 26333 26336 26340 26341 26343 26345 26347 26349 26351 26353 26363 26367 26369 26371 26390 26391 26392 26393 26399 26413 26415 26416 26419 26420 26423 26425 26427 26430 26431 26436 26439 26440 26441 26443 26445 26447 26449 26455 26457 26459 26461 26463 26465 26467 26490 26491 26493 26499 26510 26515 26520 26523 26525 26527 26530 26531 26535 26536 26539 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 21 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 Item No. Page 26540 26545 26547 26550 26555 26556 26560 26563 26570 26571 26572 26573 26574 26575 26576 26577 26578 26579 26581 26582 26583 26584 26585 26586 26587 26588 26589 26590 26591 26592 26593 26596 26598 26599 26601 26631 26701 26702 26703 26704 26705 26706 26707 26708 26709 26710 26715 26720 26732 26733 26735 26736 26737 26739 26741 26743 26745 26747 26749 26751 26761 26762 26763 26764 26765 26766 26771 26772 26773 26774 26775 26776 26776 26790 26791 26792 26793 26794 26795 26796 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 23 23 Item No. Page 26799 26810 26906 26930 26958 26959 26960 26961 26970 26975 26976 26977 26978 26979 26980 26981 26982 26983 26984 26985 26994 27224 27228 27234 27238 27243 27270 27271 27272 27273 27274 27275 27276 27277 27278 27279 27280 27281 27316 27326 27330 27331 27332 27333 27334 27335 27392 27393 27394 27396 27550 27550 27551 27551 27552 27552 27553 27554 27554 27555 27556 27557 27558 27559 27560 27589 27770 27771 27772 27773 27774 27775 27776 27777 27780 27781 27782 27783 27784 27785 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 33 33 33 33 33 33 33 33 33 33 33 33 33 33 Item No. Page 27786 27787 27788 27789 27792 27860 27861 27862 27863 27864 27865 27866 27867 27868 27869 27870 27871 27892 27921 27922 28000 28002 28003 28004 28005 28006 28007 28008 28102 28103 28106 28107 28108 28109 28110 28112 28114 28116 28117 28118 28119 28120 28122 28123 28124 28126 28127 28128 28129 28130 28132 28133 28134 28135 28136 28137 28138 28139 28140 28142 28143 28149 28150 28151 28156 28157 28158 28159 28160 28161 28162 28163 28164 28168 28169 28170 28171 28172 28173 28174 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 33 23 23 23 23 23 23 23 23 23 35 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 23 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 72 Toll Free: (800) 494-6104 Numerical Index by Item Number Item No. Page 28175 28176 28177 28180 28184 28187 28188 28189 28194 28196 28197 28198 28199 28301 28302 28303 28304 28307 28308 28309 28310 28311 28312 28315 28316 28317 28319 28320 28321 28325 28326 28327 28328 28329 28330 28331 28332 28333 28334 28335 28336 28337 28338 28339 28340 28341 28342 28343 28344 28346 28347 28348 28349 28350 28351 28355 28359 28361 28364 28365 28366 28367 28368 28369 28371 28372 28373 28374 28377 28378 28379 28380 28381 28382 28383 28385 28386 28388 28389 28390 24 24 24 35 24 24 24 24 24 24 24 24 24 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 67 4 67 67 67 67 67 67 4 4 4 4 4 4 4 67 67 67 67 67 67 67 67 67 67 67 67 4 Item No. Page 28391 28392 28393 28394 28395 28396 28397 28398 28399 28404 28408 28410 28411 28412 28413 28414 28415 28416 28417 28418 28419 28426 28474 28476 28477 28479 28483 28485 28486 28488 28489 28500 28501 28502 28503 28505 28506 28507 28509 28511 28512 28513 28515 28517 28518 28519 28521 28522 28523 28524 28527 28528 28529 28530 28531 28532 28533 28534 28535 28536 28537 28538 28539 28540 28541 28542 28543 28544 28545 28546 28547 28548 28549 28550 28551 28552 28553 28555 28556 28557 4 4 4 4 4 4 4 5 5 67 67 67 67 67 67 67 67 67 67 67 67 67 24 24 24 24 24 24 24 24 24 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 67 68 68 68 Item No. Page 28558 28559 28560 28561 28562 28563 28564 28565 28566 28567 28568 28569 28571 28572 28573 28574 28575 28576 28577 28578 28579 28581 28582 28583 28587 28588 28589 28590 28591 28593 28595 28596 28597 28598 28599 28600 28611 28612 28613 28614 28616 28617 28618 28619 28620 28622 28627 28629 28633 28655 28689 28700 28700 28724 28726 28727 28734 28736 28738 28740 28741 28742 28750 28751 28752 28781 28789 28791 28792 28795 28818 28882 28883 28884 28885 28886 28887 28889 28890 28891 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 68 67 68 5 68 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 69 69 69 69 69 69 69 69 69 69 Item No. Page 28892 28895 28896 28897 28903 28904 28905 28906 28907 28908 28910 28911 28912 28913 28914 28916 28917 28918 28919 28925 28926 28931 28933 28935 28937 28938 28939 28940 29006 29009 29012 29205 29206 29209 29211 29212 29214 29220 29225 29230 29232 29233 29234 29236 29237 29238 29239 29241 29242 29243 29244 29245 29246 29247 29248 29249 29250 29251 29252 29253 29254 29255 29256 30002 30102 30114 30138 30152 30190 30192 30202 30203 30204 30205 30206 30208 30210 30211 30212 30215 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 5 5 5 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 69 5 69 69 69 69 69 69 61 61 5 5 5 5 5 25 25 25 25 25 25 25 25 25 25 Item No. Page 30216 30217 30218 30219 30220 30221 30222 30223 30225 30226 30227 30230 30232 30235 30236 30237 30238 30239 30240 30241 30242 30243 30244 30245 30246 30247 30248 30249 30250 30251 30252 30253 30254 30255 30256 30257 30258 30259 30260 30261 30262 30263 30264 30265 30266 30267 30268 30269 30270 30271 30272 30277 30278 30280 30286 30288 30289 30290 30291 30292 30293 30294 30295 30297 30298 30299 30301 30302 30303 30304 30305 30306 30307 30308 30309 30310 30311 30312 30313 30314 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 33 25 33 25 33 25 33 25 33 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 25 33 25 25 25 25 25 25 61 61 61 61 61 61 61 61 61 61 61 61 61 61 Item No. Page 30315 30316 30317 30318 30319 30320 30321 30322 30323 30324 30325 30326 30327 30328 30329 30331 30333 30334 30335 30336 30337 30338 30339 30340 30341 30343 30344 30345 30389 30390 30391 30392 30393 30394 30395 30406 30407 30408 30409 30410 30411 30412 30413 30414 30415 30416 30417 30418 30419 30420 30422 30424 30425 30426 30427 30428 30429 30430 30433 30434 30435 30436 30437 30438 30440 30441 30442 30444 30445 30446 30447 30448 30449 30450 30451 30452 30490 30491 30492 30493 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 61 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 Item No. Page 30494 30495 30700 30701 30711 30712 30746 30747 30770 30813 30814 30815 30816 30817 30820 30825 30830 30835 30901 30903 30905 30907 30909 30911 30912 30913 30915 30917 30919 30921 30923 30925 30926 30927 30928 30929 30931 30933 30936 30939 30940 30941 30942 30943 30944 30947 30960 30961 30963 30964 30965 30990 30993 31105 31110 31112 31114 31115 31117 31118 31120 31125 31135 31137 31140 31141 31142 31143 31144 31145 31146 31147 31148 31149 31150 31151 31152 31190 31191 31192 62 62 5 5 5 5 5 5 5 26 26 26 26 26 26 26 26 26 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 15 15 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 33 33 33 26 26 26 73 www.wihatools.com Numerical Index by Item Number Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 31193 31201 31203 31305 31310 31315 31316 31320 31326 31327 31328 31329 31330 31331 31332 31333 31334 31335 31336 31337 31338 31339 31340 31341 31342 31343 31344 31345 31349 31350 31351 31353 31354 31390 31391 31393 31394 31395 31396 31425 31428 31429 31430 31431 31432 31433 31434 31435 31436 31437 31438 31439 31450 31460 31491 31493 31495 31496 31506 31507 31508 31509 31510 31511 31512 31513 31514 31515 31516 31517 31518 31519 31520 31521 31522 31524 31590 31592 31593 31595 31596 31608 31609 31610 31611 31612 31613 31614 31615 31616 31617 31618 31619 31620 31621 31622 31623 31624 31626 31627 31628 31630 31632 31650 31691 31694 31703 31704 31705 31707 31708 31709 31710 31712 31713 31714 31715 31716 31718 31720 31722 31790 31792 31793 31796 31805 31807 31809 31811 31813 31815 31817 31830 31832 31834 31836 31838 31840 31842 31844 31890 32000 32001 32002 32003 32004 32005 32010 32012 32015 32017 32023 32024 32025 32026 32027 32028 32031 32034 32039 32042 32045 32046 32049 32052 32055 32058 32079 32080 32081 32083 32084 32085 32086 32087 32088 32089 32090 32091 32092 32093 32094 32095 32096 32097 32099 32100 32101 32102 32103 32104 32105 32106 32107 32108 32145 32146 32188 32189 32190 32192 32194 32195 32196 32197 32198 32199 32206 32209 32212 32215 32218 32221 32224 32227 32230 32233 32236 32238 32239 32240 32241 32255 32258 32261 32264 32267 32268 32270 32273 32276 32278 32280 32288 32291 32292 32293 32294 32296 32302 32303 32304 32305 32306 32308 32366 32400 32401 32402 32403 32490 32505 32511 32512 32513 32514 32515 32516 32517 32518 32519 32521 32526 32531 32536 32541 32546 32551 32556 32590 32592 32596 32600 32601 32602 32603 32604 32605 32606 32607 32608 32609 32611 32612 32613 32614 32615 32616 32617 32618 32618 32619 32619 32620 32621 32623 32624 32625 32626 32627 32628 32630 32631 32633 32634 32635 32636 32637 32638 32639 32640 32642 32644 32646 32647 32648 32649 32651 32652 32653 32654 32655 32656 32657 32658 32659 32660 32661 32662 32663 32664 32665 32666 32667 32669 32670 32675 32681 32682 32683 32684 32689 32690 32691 32692 32693 32694 32696 32697 32698 32699 32702 32703 32704 32705 32708 32710 32712 32714 32716 32720 32721 32724 32726 32734 32742 32744 32746 32748 32750 32752 32760 32762 32794 32800 32801 32807 32810 32814 32820 32821 32826 32828 32831 32832 32833 32835 32836 32837 32856 32857 32858 32860 32861 32862 32863 32864 32865 32867 32868 32869 32872 32873 32874 32875 32876 32877 32878 32879 32886 32888 32889 32891 32892 32894 32895 32900 32901 32902 32923 32926 32927 32928 32929 32930 32933 32934 32935 32936 32937 32938 32939 32941 32942 32944 32945 32947 32948 32951 32954 32956 32958 32960 32968 32970 32971 32972 32973 32975 32977 32978 32979 32980 32981 32983 32984 32985 32986 32987 32988 32989 32990 32996 32999 33301 33303 33304 33305 33306 33307 33308 33309 33310 33311 33312 33313 33314 33315 33316 33317 33318 33319 33320 33321 33322 33323 33324 33325 33326 33327 33328 33329 33330 33331 33332 33333 33334 33337 33338 33339 33340 33341 33342 33343 33344 33345 33346 33347 33348 33349 33350 33351 33360 33390 33391 33392 33393 33395 33396 33399 33401 33402 33403 33404 33405 33406 33407 33408 33409 33410 33411 33412 33414 33415 33416 33417 33418 33419 33420 33421 33422 33423 33424 33425 33426 33427 33428 33429 33430 33432 33433 33434 33435 33436 33437 33438 33439 33440 33441 33442 26 26 26 26 26 26 26 26 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 26 5 26 26 26 5 5 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 15 15 15 15 15 15 15 15 15 15 15 15 15 15 15 15 15 15 33 15 33 15 15 15 15 15 15 15 15 15 15 15 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 16 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 17 33 9 9 9 9 9 9 9 9 9 9 9 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 12 12 12 12 12 12 12 12 12 17 17 17 12 17 12 17 17 17 12 12 12 12 12 12 12 12 12 17 12 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 62 63 63 63 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 12 54 74 Toll Free: (800) 494-6104 Numerical Index by Item Number Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 33443 33444 33445 33446 33447 33448 33449 33450 33452 33453 33454 33456 33458 33459 33462 33465 33468 33471 33474 33475 33476 33477 33478 33480 33481 33482 33483 33484 33485 33486 33487 33488 33489 33490 33492 33493 33494 33496 33498 33499 33532 33603 33606 33607 33609 33612 33620 33622 33623 33632 33634 33637 33641 33653 33659 33665 33671 33674 33677 33690 33691 33701 33702 33703 33704 33705 33708 33709 33710 33711 33712 33713 33714 33715 33716 33717 33718 33719 33720 33721 33722 33723 33724 33725 33726 33727 33728 33729 33730 33731 33732 33733 33734 33735 33736 33737 33738 33739 33740 33741 33742 33743 33744 33745 33746 33747 33748 33749 33750 33751 33752 33753 33754 33755 33756 33757 33758 33759 33760 33761 33762 33763 33764 33765 33770 33790 33791 33792 33793 33795 33796 33799 33801 33803 33804 33805 33807 33808 33809 33810 33811 33812 33813 33814 33815 33816 33817 33818 33819 33820 33821 33822 33823 33824 33825 33826 33827 33828 33829 33830 33831 33832 33833 33834 33835 33836 33837 33838 33839 33840 33841 33842 33843 33844 33845 33846 33847 33848 33850 33851 33852 33853 33854 33855 33856 33857 33858 33859 33860 33861 33862 33863 33864 33865 33866 33867 33868 33869 33870 33871 33872 33873 33874 33875 33876 33877 33878 33879 33880 33881 33882 33884 33885 33886 33888 33889 33890 33891 33892 33893 33895 33896 33899 34120 34121 34122 34123 34124 34126 34127 34128 34129 34130 34131 34132 34133 34134 34135 34136 34137 34138 34139 34140 34141 34142 34143 34144 34145 34152 34154 34193 34194 34195 34302 34304 34306 34308 34310 34312 34314 34336 34338 34339 34340 34341 34342 34343 34390 34391 34474 34475 34476 34478 34592 34596 34612 34616 34617 34622 34626 34627 34680 34681 34682 34690 34691 34712 34715 34718 34721 34724 34727 34730 34753 34759 34765 34771 34774 34791 35101 35102 35103 35105 35106 35107 35109 35110 35111 35113 35114 35115 35117 35118 35119 35120 35121 35122 35123 35125 35126 35127 35129 35143 35147 35152 35191 35192 35193 35194 35195 35197 35217 35231 35295 35297 35390 35391 35392 35393 35401 35402 35403 35404 35405 35406 35407 35408 35409 35410 35411 35412 35413 35414 35415 35416 35417 35418 35419 35420 35421 35422 35800 35801 35802 35803 35811 35812 35820 35821 35822 35823 35844 35845 35890 35891 35894 36107 36108 36109 36110 36115 36120 36125 36127 36130 36140 36199 36200 36201 36202 36203 36204 36206 36207 36208 36209 36211 36214 36216 36217 32618 36219 36221 36222 36223 36224 36226 36227 36228 36229 36231 36232 36233 36234 36236 36237 36238 36239 36241 36242 36243 36244 36246 36247 36248 36249 36252 36253 36254 36255 36256 36258 36259 36260 36262 36263 36264 36265 36266 36267 36268 36269 36270 36271 36272 36273 36274 36275 36276 36277 36278 36279 36280 36281 36282 36283 36284 36285 36286 36287 36288 36289 36290 36291 36294 36296 36297 36298 36299 36306 36307 36308 36309 36310 36315 36320 36323 36325 36326 36327 36328 36329 36330 36332 36335 36337 36339 36340 36342 36345 36346 36355 36360 36364 36366 36368 36369 36370 36371 36372 36373 36374 36375 36376 36377 36378 36379 36380 36381 36382 36383 36384 36385 36386 36387 36388 36390 36391 36392 36393 36394 36396 36409 36410 36415 36417 36420 36422 36425 36427 36430 36432 36435 36437 36440 36442 36452 36461 36463 36466 36469 36472 36474 36476 36478 36480 36481 36482 36483 36484 36486 36487 36490 36492 36494 36496 36497 36511 36513 36514 12 54 12 54 12 54 12 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 12 54 12 12 12 54 12 12 12 54 54 12 54 54 54 54 54 54 13 26 26 26 26 26 26 26 26 13 13 13 13 26 26 26 26 26 26 26 26 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 63 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 26 27 27 27 27 27 27 27 27 17 17 17 17 17 17 18 18 18 18 18 27 27 27 27 27 27 27 27 27 27 27 27 27 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 54 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 27 27 27 27 13 13 27 27 27 27 13 13 13 13 27 58 58 58 58 58 58 58 58 58 58 58 33 27 27 27 33 33 27 33 33 27 27 27 27 33 33 27 27 27 33 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 27 33 27 27 27 27 27 28 27 28 27 28 27 28 27 28 27 28 27 28 27 28 27 28 27 28 27 28 27 33 28 28 28 28 28 28 28 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 75 www.wihatools.com Numerical Index by Item Number Item No. Page Item No. Page 36516 36517 36518 36519 36521 36522 36523 36524 36526 36527 36528 36529 36531 36532 36533 36534 36536 36537 36538 36539 36541 36543 36545 36547 36549 36551 36553 36556 36557 36558 36559 36560 36561 36562 36590 36591 36592 36598 36606 36607 36608 36609 36610 36615 36620 36625 36627 36630 36631 36632 36633 36634 36635 36636 36637 36638 36639 36640 36645 36646 36647 36648 36649 36650 36651 36652 36653 36654 36655 36659 36660 36661 36689 36690 36691 36692 36693 36694 36697 36698 36699 36710 36713 36715 36716 36719 36720 36723 36725 36726 36728 36730 36732 36734 36736 36738 36740 36742 36744 36750 36760 36780 36786 36790 36791 36792 36793 36794 36904 36908 36912 36915 36916 36917 36918 36919 36920 36921 36922 36924 36928 36936 36944 36945 36946 36947 36949 36950 36951 36952 36953 36954 36955 36956 36957 36958 36959 36960 36961 36962 36963 36965 36968 36971 36974 36976 36982 36983 36990 36991 36992 36993 36995 36998 37005 37006 37007 37008 37009 37010 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 58 58 58 58 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 59 60 60 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 28 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 60 60 60 60 60 60 Item No. Page 37011 37012 37014 37015 37017 37018 37021 37023 37024 37027 37055 37056 37057 37058 37059 37060 37061 37062 37063 37064 37065 37066 37067 37068 37069 37070 37090 37091 37092 37106 37107 37108 37109 37110 37115 37120 37125 37127 37130 37190 37192 37220 37222 37226 37228 37230 37235 37236 37237 37238 37239 37241 37244 37291 38032 38035 38041 38042 38043 38044 38045 38046 38047 38048 38049 38050 38051 38056 38057 38058 38060 38090 38450 38451 38460 38490 38600 38701 38790 38800 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 28 28 28 28 28 28 28 28 28 28 28 28 28 35 35 35 35 35 35 35 35 35 35 35 13 13 35 35 35 35 35 35 35 35 35 35 35 35 35 Item No. Page Item No. Page Item No. Page Item No. Page 38801 38802 40010 40800 41101 41102 41103 41104 41105 41106 43040 43090 43092 43093 43094 43095 43096 43097 43612 43618 43624 43643 44216 44219 44501 44503 44504 44505 44506 44507 44508 44509 44510 44518 44520 44523 44525 44528 44531 44532 44593 45892 52005 52020 52097 52125 52650 52713 52716 52719 52722 53001 53002 53003 53004 53005 53006 53007 53010 53015 53020 53025 53027 53035 53040 53075 53090 53096 53097 53099 53110 53115 53120 53131 53132 53133 53180 53310 53315 53320 53325 53330 53390 53398 53405 53410 53425 54001 54002 54003 54004 54005 54006 54007 54008 54009 54010 54012 54014 54016 54018 54020 54022 54024 54025 54030 54040 54042 54050 54052 54060 54062 54080 54082 54086 54088 54090 54091 54092 54094 54095 54097 55531 55533 55534 55535 55536 55537 55538 55539 55546 55547 56801 56812 56813 56815 56818 56825 56830 56833 56871 57810 57812 57814 57816 57818 57820 57830 60140 60260 60270 60368 61601 61602 61604 61606 61609 61620 61630 61662 66904 66908 66912 66916 66918 66920 66922 66924 66926 66928 66930 66936 66937 66938 66944 66945 66946 66947 66950 66952 66953 66955 66956 66959 66962 66965 66968 66971 66980 66981 66982 66988 66990 66991 66992 66993 66994 66995 66996 66998 70002 70020 70025 70042 70060 70065 70096 70098 70107 70108 70109 70110 70113 70115 70117 70119 70121 70123 70127 70128 70129 70135 70139 70142 70144 70145 70146 70147 70148 70150 70151 70152 70153 70154 70155 70156 70157 70158 70159 70160 70163 70168 70190 70201 70202 70203 70218 70219 70220 70222 70223 70225 70242 70260 70265 70269 70277 70279 70282 70298 70302 70319 70320 70322 70325 70424 70427 70430 70437 70438 70440 70442 70445 70448 70450 70462 70463 70464 70466 70468 70469 70470 70472 70474 70476 70477 70479 70480 70482 70483 70484 70485 70486 70490 70491 70492 70493 70494 70507 70508 70509 70510 70515 70520 70525 70527 70530 70533 70534 70535 70536 70537 70538 70539 70540 70545 70550 70556 70557 70558 36 36 28 13 64 64 64 64 64 64 65 65 65 65 65 65 65 65 18 18 18 18 18 18 33 33 33 33 33 33 33 33 33 34 34 34 34 34 34 34 34 34 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 56 34 34 34 34 34 34 34 34 34 34 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 19 65 65 65 65 65 65 65 65 65 65 13 65 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 57 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 36 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 76 Toll Free: (800) 494-6104 Numerical Index by Item Number Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 70559 70560 70561 70562 70563 70564 70565 70566 70567 71001 71002 71003 71004 71051 71052 71053 71054 71056 71090 71095 71100 71101 71102 71103 71130 71131 71132 71139 71149 71151 71152 71153 71195 71198 71200 71201 71202 71203 71250 71251 71252 71253 71254 71300 71301 71302 71303 71304 71305 71306 71307 71308 71309 71310 71311 71312 71313 71314 71315 71316 71317 71318 71319 71320 71321 71322 71323 71324 71325 71326 71327 71328 71329 71330 71331 71332 71333 71336 71339 71340 71341 71342 71343 71345 71346 71348 71349 71351 71352 71353 71354 71356 71359 71360 71361 71362 71363 71364 71365 71366 71367 71368 71369 71370 71371 71372 71373 71374 71375 71376 71377 71378 71379 71380 71381 71382 71383 71384 71385 71386 71387 71388 71389 71390 71392 71393 71394 71396 71397 71398 71431 71433 71435 71437 71439 71441 71452 71453 71455 71456 71474 71475 71476 71477 71478 71479 71480 71491 71492 71493 71494 71496 71499 71505 71506 71507 71508 71509 71510 71515 71520 71523 71524 71525 71527 71530 71536 71537 71538 71540 71541 71542 71543 71544 71545 71546 71547 71548 71549 71550 71551 71552 71553 71554 71555 71556 71557 71558 71559 71560 71561 71570 71571 71603 71604 71605 71606 71607 71608 71609 71610 71615 71620 71625 71627 71630 71631 71632 71633 71634 71635 71636 71637 71638 71639 71640 71641 71642 71643 71644 71645 71648 71650 71652 71654 71656 71657 71658 71660 71661 71662 71663 71664 71665 71666 71667 71668 71669 71670 71671 71673 71674 71675 71676 71677 71678 71680 71681 71690 71692 71698 71701 71702 71703 71704 71705 71706 71707 71708 71711 71712 71713 71714 71715 71716 71717 71718 71719 71720 71721 71722 71723 71724 71725 71726 71728 71730 71732 71734 71736 71738 71740 71750 71760 71761 71762 71763 71764 71765 71766 71767 71768 71771 71772 71773 71774 71775 71776 71777 71797 71798 71801 71802 71803 71851 71852 71853 71854 71900 71901 71902 71903 71904 71906 71907 71908 71909 71910 71911 71912 71913 71914 71916 71918 71920 71921 71922 71923 71924 71930 71932 71934 71936 71938 71939 71940 71941 71942 71943 71944 71945 71946 71949 71950 71951 71952 71953 71954 71955 71956 71957 71958 71959 71960 71963 71964 71965 71966 71970 71971 71972 71973 71974 71975 71976 71977 71978 71979 71980 71981 71982 71983 71984 71985 71987 71988 71989 71990 71991 71994 71995 71996 71998 71999 72001 72002 72003 72004 72005 72006 72014 72038 72039 72040 72047 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 37 38 37 37 37 37 37 37 38 37 38 37 38 37 38 37 38 37 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 38 39 39 39 38 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 41 41 41 41 41 Item No. Page 72050 72051 72090 72102 72103 72110 72115 72201 72202 72203 72205 72206 72207 72209 72210 72211 72212 72213 72214 72217 72218 72220 72221 72222 72223 72224 72225 72226 72227 72238 72239 72240 72241 72242 72244 72245 72246 72248 72249 72250 72255 72256 72257 72258 72259 72260 72261 72262 72263 72264 72265 72266 72267 72279 72280 72281 72282 72283 72285 72286 72287 72301 72302 72303 72305 72306 72307 72309 72310 72311 72312 72313 72314 72317 72318 72320 72321 72322 72323 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 Item No. Page 72324 72325 72326 72327 72338 72339 72340 72341 72342 72344 72345 72346 72348 72349 72350 72355 72356 72357 72358 72359 72360 72361 72362 72363 72364 72365 72366 72367 72379 72381 72382 72383 72384 72387 72388 72389 72390 72401 72405 72415 72502 72503 72504 72506 72507 72508 72509 72511 72512 72513 72514 72515 72516 72519 72521 72522 72523 72524 72525 72526 72527 72530 72532 72534 72535 72536 72537 72538 72539 72542 72547 72555 72558 72559 72560 72561 72562 72563 72564 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 41 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 77 www.wihatools.com Numerical Index by Item Number Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 72567 72568 72569 72570 72572 72573 72574 72575 72576 72577 72578 72579 72580 72581 72582 72583 72584 72585 72586 72587 72593 72595 72596 73302 73303 73304 73305 73306 73307 73308 73309 73310 73311 73312 73314 73315 73316 73317 73318 73319 73501 73502 73504 73505 73506 73508 73512 73514 73526 73527 73528 73528 73529 73530 73536 73537 73538 73901 73902 73903 73905 73906 73907 73908 73909 73910 73912 73913 73914 73915 73916 73928 73929 73930 73931 73932 73933 73934 73936 73937 73938 73939 73940 73941 73942 73943 73944 73945 73946 74003 74006 74009 74010 74012 74015 74018 74021 74033 74034 74035 74036 74039 74041 74050 74061 74062 74063 74064 74065 74066 74067 74068 74069 74102 74103 74104 74106 74107 74109 74110 74111 74112 74113 74114 74115 74116 74117 74118 74121 74123 74124 74126 74127 74130 74131 74133 74136 74150 74158 74164 74165 74166 74167 74168 74201 74205 74212 74214 74231 74232 74233 74236 74237 74238 74262 74301 74305 74307 74311 74312 74313 74314 74315 74316 74317 74318 74319 74321 74322 74323 74324 74325 74326 74328 74330 74331 74332 74333 74334 74335 74336 74337 74338 74339 74340 74350 74351 74352 74353 74354 74355 74356 74357 74358 74359 74360 74361 74362 74363 74364 74365 74366 74367 74368 74369 74371 74373 74375 74379 74380 74381 74382 74383 74384 74385 74386 74387 74388 74501 74502 74503 74504 74506 74508 74510 74511 74512 74513 74514 74515 74516 74517 74519 74520 74521 74522 74523 74524 74525 74526 74527 74528 74529 74530 74531 74532 74533 74534 74536 74537 74538 74539 74540 74541 74542 74543 74544 74545 74546 74547 74548 74549 74550 74551 74553 74556 74558 74559 74561 74563 74565 74567 74568 74569 74570 74571 74573 74574 74575 74576 74577 74579 74580 74581 74582 74583 74584 74585 74586 74587 74588 74589 74590 74591 74592 74593 74594 74596 74597 74601 74602 74603 74604 74608 74611 74612 74613 74614 74616 74617 74620 74624 74628 74632 74636 74659 74660 74661 74662 74663 74664 74665 74666 74667 74668 74669 74670 74711 74714 74717 74721 74724 74728 74732 74736 74739 74742 74760 74761 74762 74763 74764 74765 74766 74767 74768 74811 74812 74813 74814 74816 74819 74860 74861 74862 74863 74864 74865 74890 74895 74911 74912 74913 74914 74915 74964 74965 74966 74967 74968 74981 74982 74983 74985 74986 74987 74988 74990 74992 74996 74999 75008 75012 75015 75018 75020 75025 75030 75035 75040 75093 75094 75095 75096 75097 75105 75110 75115 75120 75125 75205 75210 75215 75220 75302 75304 75307 75309 75313 75315 75320 75325 75330 75340 75350 75352 75354 75356 75358 75360 75395 75602 75603 75604 75605 75606 75607 75608 75609 75610 75611 75612 75613 75614 75615 75616 75617 75618 75619 75620 75621 75622 75623 75628 75629 75630 75631 75632 75633 75634 75635 75636 75637 75644 75645 75646 75647 75648 75649 75650 75651 75652 75653 75654 75655 75656 75657 75658 75659 75660 75661 75662 75663 75664 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 42 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 43 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 13 13 13 13 13 13 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 45 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 Item No. Page 75665 75666 75667 75668 75669 75670 75671 75672 75673 75674 75675 75676 75701 75702 75703 75704 75705 75706 75707 75708 75709 75710 75715 75720 75743 75744 75745 75746 75747 75748 75802 75803 75804 75805 75806 75810 75811 75812 75813 75814 75815 75816 75817 75820 75821 75822 75823 75824 75825 75826 75827 75900 75902 75965 75968 75971 75973 75977 75978 75980 75981 75982 75983 75984 75985 75986 75987 75988 75991 75992 75993 75994 75995 75996 75999 76000 76001 76002 76003 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 34 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 29 29 29 29 78 Toll Free: (800) 494-6104 Numerical Index by Item Number Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 76004 76005 76006 76007 76008 76009 76010 76011 76012 76013 76014 76015 76016 76017 76018 76019 76020 76021 76022 76023 76024 76025 76027 76030 76031 76032 76033 76034 76035 76036 76037 76038 76039 76040 76041 76042 76043 76044 76045 76045 76046 76047 76048 76049 76050 76051 76052 76053 76054 76056 76057 76058 76059 76060 76061 76062 76063 76064 76065 76066 76067 76068 76069 76070 76071 76072 76073 76074 76075 76076 76077 76078 76079 76080 76084 76085 76086 76088 76089 76090 76091 76092 76093 76094 76095 76096 76097 76098 76099 76106 76107 76109 76111 76113 76117 76119 76121 76123 76129 76131 76132 76133 76134 76135 76136 76137 76138 76164 76165 76166 76167 76168 76169 76170 76171 76172 76194 76208 76210 76212 76215 76290 76312 76314 76316 76318 76322 76324 76326 76328 76330 76331 76332 76333 76334 76335 76336 76337 76338 76339 76340 76341 76352 76354 76395 76397 76403 76406 76407 76411 76412 76413 76414 76418 76419 76422 76423 76500 76501 76502 76503 76504 76505 76506 76507 76508 76510 76511 76512 76513 76514 76516 76517 76523 76524 76525 76526 76530 76531 76532 76533 76534 76535 76537 76538 76539 76540 76541 76543 76544 76545 76548 76549 76550 76553 76554 76555 76556 76557 76558 76559 76563 76564 76565 76566 76570 76571 76572 76573 76574 76575 76578 76579 76580 76581 76582 76583 76584 76585 76586 76587 76588 76589 76590 76591 76592 76593 76594 76595 76596 76597 76598 76599 76601 76602 76603 76606 76607 76608 76610 76611 76612 76613 76614 76616 76617 76623 76624 76625 76626 76630 76631 76632 76633 76634 76635 76638 76639 76640 76641 76642 76643 76644 76645 76646 76647 76648 76649 76650 76651 76652 76653 76654 76655 76656 76663 76664 76665 76666 76670 76671 76672 76673 76674 76675 76801 76802 76803 76806 76807 76808 76810 76811 76812 76813 76814 76816 76817 76823 76824 76825 76826 76830 76831 76832 76833 76834 76835 76838 76839 76840 76843 76844 76845 76848 76849 76850 76853 76854 76855 76856 76857 76858 76859 76863 76864 76865 76866 76870 76871 76872 76873 76874 76875 76876 76877 76878 76879 76880 76881 76886 76889 76890 76891 76892 76893 76894 76895 76896 76897 76899 77101 77103 77105 77107 77109 77111 77113 77115 77117 77128 77130 77132 77134 77136 77138 77139 77140 77141 77142 77144 77146 77148 77151 77152 77153 77154 77156 77158 77160 77162 77164 77165 77167 77169 77171 77173 77175 77177 77179 77180 77182 77184 77186 77188 77191 77192 77193 77195 77198 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 29 30 30 30 30 29 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 47 48 13 13 13 13 13 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 49 48 48 48 49 49 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 49 48 48 48 49 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 49 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 51 Item No. Page 77741 77780 77781 77782 77783 77784 77785 77789 77790 77791 77792 77793 77795 77796 77797 77798 77799 77890 77891 77892 78002 78005 78008 78011 78015 78018 79242 79243 79245 79246 79247 79248 79256 79266 79276 79283 79443 79445 79446 79447 79450 79490 79491 79493 79495 79499 80025 80030 80035 80040 80045 80050 80070 80071 80072 80074 80076 80081 80200 80202 80203 80204 80206 80207 80208 80210 80211 80219 80222 80225 80230 80235 80240 80245 80250 80260 80270 80280 80290 80299 51 51 51 51 51 51 51 51 51 51 52 52 52 52 52 52 52 31 31 31 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 52 53 53 53 53 53 53 53 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 65 Item No. Page 83221 83222 83223 83224 83225 83230 83231 83232 83233 83234 83235 83236 83238 83240 83241 83242 83243 83244 83245 83246 83248 83250 83251 83252 83253 83254 83255 83256 83258 83260 83261 83262 83263 83264 83265 83268 83273 83274 83275 83276 83277 83279 83282 83285 83288 83289 83290 91109 91117 91118 91121 91124 91132 91134 91216 91459 91472 91473 91482 91486 91487 91488 91567 91579 91596 91597 91584 92000 92002 92004 92005 92006 92008 92010 92012 92014 92016 92018 92020 92022 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 53 66 31,70 66 66 66 66 19 70 70 70 70 70 70 70 19 19 19 19 70 13 13 13 13 13 13 13 13 13 13 13 13 13 79 www.wihatools.com Numerical Index by Item Number Item No. Page 92024 92026 92028 92031 92033 92035 92038 92040 92043 92045 92050 92052 92054 92056 92058 92060 92062 92063 92064 92065 92066 92067 92068 92069 92070 92071 92072 92075 92076 92077 92078 92079 92080 92081 92082 92093 92189 92190 92191 92206 92209 92212 92215 92218 92221 92224 92226 92230 92233 92236 92238 92239 92240 92241 92255 92258 92261 92264 92267 92268 92270 92273 92276 92278 92280 96008 96010 96012 96015 96018 96020 96025 96030 96035 96040 96100 96102 96105 96110 96307 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 34 31 31 31 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 13 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 Item No. Page 96309 96313 96315 96316 96320 96323 96325 96327 96330 96331 96413 96415 96416 96419 96420 96423 96425 96427 96430 96431 96436 96439 96510 96515 96520 96523 96525 96527 96530 96531 96535 96536 96539 96540 96545 96547 96550 96555 96556 96560 96563 96570 96703 96704 96705 96706 96707 96708 96709 96710 96715 96720 97780 97782 97790 97791 97792 34501 34502 34503 34504 34505 34506 34507 34508 66900 66901 66902 66903 66905 66906 66907 66909 66910 66911 66913 66914 66915 66923 66925 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 53 53 53 53 53 27 27 27 27 27 27 27 27 56 56 56 56 56 56 56 56 56 56 56 56 56 57 57 Item No. Page 66927 66929 66931 66932 66933 66934 66935 57 57 57 57 57 57 57 Item No. Page Item No. Page Item No. Page Item No. Page 1348 Dundas Circle Monticello, MN 55362 phone | (800) 494-6104 fax | (800) 494-7456 email | cservice@wihatools.com No Hassle Guarantee Wiha branded tools are regarded as the most durable, best designed and highly innovative products around. Our tools are used by demanding professional tradespeople and tool aficionados alike. They are meant to be used and utilized often. However, if you are not happy for any reason return them within 12 months of purchase with proof of purchase and we will Repair or Replace. Rest assured, if for some reason there is a defect in material or workmanship we will replace your tool free of charge for as long as you own the tool. Failures due to misuse, abuse or normal wear and tear are not covered by this guarantee. We stand by our products with what we believe is the best No Hassle Guarantee in the industry. Subject to change without notice ©2022 Willi Hahn Corporation ®Torx is a registered trademark of Acument Intellectual Properties LLC. Catalog Item No. 99060 version - 5/15/2022 Exclusions Wiha Tools has the right to exclude Bits, Tweezers and Ceramic Screwdrivers. These products are either consumable or wear easily. All torque tools are designed for 5,000 cycles or 1 year (whichever comes first). If a tool becomes out of specification within that period Wiha Tools will Repair or Replace. Visit www.wihatools.com to learn more about our Torque Control Service Program. Prop65 WARNING: Cancer or reproductive harm. For more information, go to www.P65Warnings.ca.gov/ Legal Some areas do not allow the exclusion or limitation of incidental or consequential damages, so the above limitation or exclusion may not apply to you. This guarantee gives you specific rights, and you may also have other rights, which vary, from state to state, province to province, or country to country. This No Hassle Guarantee is the sole and exclusive guarantee for the Willi Hahn Corporation dba Wiha Tools. No employee, agent, dealer, or other person is authorized to alter this guarantee or make any other guarantees on behalf of Wiha Tools. Willi Hahn Corporation USA Attn: No Hassle Guarantee 1348 Dundas Circle Monticello, MN 55362 2021 PROFESSIONAL INSULATED TOOLS Supporting Arc Flash Protection COMPLETE INSULATED PROGRAM 99007 - Merchandise Catalog 99919 - Insulated Catalog 99001 - TorqueControl Catalog
92191 价格&库存
很抱歉,暂时无法提供与“92191”相匹配的价格&库存,您可以联系我们找货
