BWA-9O2-C
BWA-9O2-C
    BANNER(邦纳)
    SMA(DO-214AC)
    900MHz 通用 鞭状,倾斜 RF 天线 2dBi RP-SMA 公头 连接器安装
BWA-9O2-C 数据手册
W1063 Datasheet Version 1.1. February 2008 Wireless External Antenna for 900 MHz Applications Pulse Part Number: W1063 Features - Ideal for lower frequency wireless applications in the ISM 900 MHz band - Omni-directional radiation pattern provides broad 360° coverage - One-eighth wavelength dipole configuration - Connection and color options easily integrate with OEM designs Color Options - Black* - Gray (Pantone cool gray 8C) - Gray (Pantone 429C) - Gray (Pantone cool gray 7C) Connector Options - Reverse SMA (Male)* - SMA (Male) * Default Configuration – Please contact Pulse Applications Engineering for assistance in ordering colors and connectors Weight......................................................25.6 grams Carton...........................................20/bag; 500/carton Inches mm Unless otherwise specified, all tolerances are ± .010 0.25 Dimensions: Electrical Specifications @ 25 ºC Note: This part number is lead-free and RoHS compliant. No additional suffix or identifier is required. Antenna Part No. Frequency [MHz] Gain [dBi] Impedance [Nom] VSWR Polarization Electrical Length Radiation Color W1063 868 – 928 3.0 50 Ω ≤ 2.0 Vertical 1/4, dipole Omni Black Pulse Antennas Takatie 6 90440 Kempele Finland Tel: +358 207 935 500 www.pulseeng.com/antennas External Antennas Sales Contacts USA UK France Singapore 858 674 8100 44 1483 401 700 33 3 84 35 04 04 65 6287 8998 Shanghai 86 21 32181071 China 86 769 5538070 Taiwan 886 2 26980228 © 2008 All Rights Reserved. W1063 Datasheet Version 1.1. February 2008 Wireless External Antenna for 900 MHz Applications Pulse Part Number: W1063 Application Notes Omni-directional antennas provide a uniform, donutshaped, 360° radiation pattern. The omni-directional pattern is suitable for point-to-multipoint broadcasting in all directions. This antenna is primarily used for WLAN applications. However, it can also be used for a variety of other applications within the specified frequency range. When used as an access point, the antenna is ideally located at the center of the coverage area. Gain Performance W1063 Horizontal Position 915 MHz 902MHz 0 345 345 15 330 315 300 285 75 -10 0 dB 255 90 105 240 60 -30 0 90 dB 240 75 -30 0 90 dB 240 120 225 135 210 165 180 -10 105 150 195 -20 255 135 210 60 270 120 225 45 285 105 165 180 -10 30 300 255 150 195 -20 15 315 75 135 210 45 270 0 330 285 120 225 30 300 60 -20 345 315 45 -30 928 MHz 15 330 30 270 0 150 195 165 180 Vertical Position 0 15 345 330 30 45 60 285 -10 0 dB 255 90 105 240 120 225 135 210 180 Pulse Antennas Takatie 6 90440 Kempele Finland Tel: +358 207 935 500 www.pulseeng.com/antennas 30 45 -20 -10 0 dB 255 90 105 240 120 225 135 210 165 150 195 180 165 30 45 300 75 -30 15 315 285 270 0 330 60 150 195 345 300 75 -20 15 315 300 -30 0 330 315 270 928MHz 915 MHz 902MHz 345 60 285 75 270 -30 -20 -10 0 dB 255 90 105 240 120 225 135 210 150 195 180 165 External Antennas Sales Contacts USA UK France Singapore 858 674 8100 44 1483 401 700 33 3 84 35 04 04 65 6287 8998 Shanghai 86 21 32181071 China 86 769 5538070 Taiwan 886 2 26980228 © 2008 All Rights Reserved.
BWA-9O2-C 价格&库存
很抱歉,暂时无法提供与“BWA-9O2-C”相匹配的价格&库存,您可以联系我们找货
