704.600.2
704.600.2
    EAO
    SIL
    PROTECTIVE FRONT RING NATURAL D2
704.600.2 数据手册
with VDE and UKCA Series 04 Versatile. Robust and reliable. https://eao.com/04 Series 04 04 Information about the Series Key advantages Mounting cut-outs § Versatile and reliable range of products § Ideal for driver’s cabs § Modern and robust design § Safe and ergonomically friendly in use § Pronounced tactile feedback § Customised and standardised markings § Ø 22.3 mm § Ø 30.5 mm § 30 mm x 30 Typical application areas § Driver's desks § Control panels § Control cabinets § Special vehicles § Machinery Functions § Pushbutton § Illuminated pushbutton § Mushroom-head pushbutton § Selector switch § Keylock switch § Key insert switch § Lever switch § Indicator § Potentiometer § Stop switch § Emergency stop switch Design § Flush § Raised § IP40 § IP54 § IP65 § IP67 Raitings 48 Terminal § Plug-in terminal § Double plug-in terminal § Screw terminal § Push-in terminal (PIT) Lens Material § Aluminium § Stainless steel § Plastic Markings § Engraving § Hot stamping § Pad printing § Screen print § Under eloxal printing Approvals § CB (IEC 60947) § cULus § DNV § GOST § NFF 16-102 Conformities IP front protection § 500 mm § CE § EN 45545 § ECE R 118 § 2006/42/EU § 2011/65/EU § REACH § CCC § UKCA (MD) (RoHS) VAC (10 A) ​ eao.com § 08/2022 Index 04 Flush design Pushbutton square 52 Pushbutton round 54 Pushbutton square 56 Pushbutton round 57 Illuminated pushbutton square 58 Illuminated pushbutton round 60 Illuminated pushbutton square 62 Illuminated pushbutton round 63 Mushroom-head pushbutton 64 Selector switch illuminated, 2 positions, short lever, square 65 Selector switch illuminated 2 positions short lever, round 66 Selector switch 2 positions short lever, square 67 Selector switch 2 positions, short lever, round 68 Selector switch 2 positions, short lever, square 69 Selector switch 2 positions, short lever, round 70 Selector switch illuminated, 2 positions, long lever, square 71 Selector switch illuminated, 2 positions, long lever, round 72 Selector switch 2 positions, long lever, square 73 Selector switch 2 positions, long lever, round 74 Selector switch 2 positions, 12 o‘clock, long lever, square 75 Selector switch 2 positions, long lever, round 76 Selector switch illuminated, 3 positions, short lever, square 77 Selector switch illuminated, 3 positions, short lever, round 79 Selector switch 3 positions, short lever, square 81 Selector switch 3 positions, short lever, round 82 Selector switch illuminated, 3 positions, long lever, square 83 Selector switch illuminated, 3 positions long lever, round 85 Selector switch 3 positions, long lever, quare 87 Selector switch 3 positions, long lever, round 88 Selector rotary switch, short lever rounded, round 89 Selector rotary switch, short lever, square 90 Selector rotary switch short lever, round 91 Selector rotary switch, long lever rounded, round 92 Selector rotary switch long lever, square 93 Selector rotary switch long lever, round 94 Keylock switch 2 positions, square 95 Keylock switch 2 positions, round 96 Keylock switch 3 positions, square 97 Keylock switch 3 positions, round 99 Keylock rotary switch 100 Key-insert switch 2 positions  101 Key-insert switch 3 positions 102 Key-insert switch 3 positions, conductor switch 103 Lever switch 104 Indicator square 105 Indicator round 106 Indicator square 107 Indicator round 108 Flasher without LED square 109 Flasher without LED round 111 Flasher square 112 08/2022 § eao.com ​ 49 01 02 03 04 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 04 Index 01 Flush design 02 03 Flasher round 113 Buzzer 114 Potentiometer 115 Stop switch 116 Raised design Pushbutton square 117 Pushbutton round 119 Pushbutton square 122 Pushbutton round 123 Illuminated pushbutton square 124 Illuminated pushbutton round 126 Illuminated pushbutton square 128 Illuminated pushbutton round 129 17 Mushroom-head pushbutton 130 Mushroom-head pushbutton illuminated 132 18 Selector switch illuminated, 2 positions, short lever, square 133 Selector switch illuminated, 2 positions, short lever, round 134 Selector switch 2 positions, short lever, square 135 Selector switch 2 positions, short lever, round 136 Selector switch 2 positions, short lever, square 137 Selector switch 2 positions, short lever, round 138 Selector switch illuminated, 2 positions, long lever, square 139 31 Selector switch illuminated, 2 positions, long lever, round 140 Selector switch 2 positions, long lever, square 141 41 Selector switch 2 positions, long lever, round 142 Selector switch 2 positions, long lever, square 143 Selector switch 2 positions, long lever, round 144 Selector switch illuminated, 3 positions, short lever, square 145 Selector switch illuminated, 3 positions, short lever, round 147 Selector switch 3 positions, short lever, square 149 Selector switch 3 positions, short lever, round 150 Selector switch illuminated, 3 positions, long lever, square 151 Selector switch illuminated, 3 positions, long lever, round 153 Selector switch 3 positions, long lever, square 155 Selector switch 3 positions, long lever, round 156 Selector rotary switch, short lever, rounded, square 157 Selector rotary switch, short lever rounded, round 158 Selector rotary switch, short lever, square 159 Selector rotary switch, short lever, round 160 Selector rotary switch, long lever rounded, square 161 Selector rotary switch, long lever rounded, round 162 Selector rotary switch, long lever, square 163 Selector rotary switch, long lever, round 164 Keylock switch 2 positions, square 165 Keylock switch 2 positions, round 166 Keylock switch 3 positions, square 167 Keylock switch 3 positions, round 168 Indicator full-face illumination compact, round 169 Indicator full-face illumination compact, round 171 Indicator full-face illumination, square 172 Indicator full-face illumination, round 173 04 09 14 19 22 45 51 56 57 61 70 71 82 84 92 96 50 ​ eao.com § 08/2022 Index 04 Raised design Indicator full-face illumination, square 174 Indicator full-face illumination, round 175 Indicator front illumination, square 176 Indicator front illumination, round 178 Indicator front illumination, square 180 Indicator front illumination, round 181 Flasher full-face illumination, square 182 Flasher full-face illumination, round 183 Flasher full-face illumination, square 185 Flasher full-face illumination, round 186 Flasher front illumination,square 187 Flasher front illumination, round 189 Flasher front illumination, square 191 Flasher front illumination, round 192 Buzzer 193 Potentiometer 194 Stop switch Ø 37 mm 195 Stop switch Ø 40 mm 196 Emergency stop switch, foolproof EN IEC 60974-5-5 197 Emergency call switch 198 Components 199 Accessories 237 Technical data 250 Marking 263 Application guidelines 269 01 02 03 04 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 08/2022 § eao.com 51 04 Flush design 01 Pushbutton square, IP65 3 02 39 23 Equipment consisting of (schematic overview) 23 Lens A A 37 03 Lens holder 04 2 ... 6 Product can differ from the current configuration. Dimensions [mm] A = Screw terminal Press frame General information • Max. 3 switching elements can be clipped on A 35 min. 17 Bayonet flange R1.2 max. C D 30 + 0.5 0 18 65 min. 14 Actuator 50 min. 09 B Switching element Page 213 + 0.5 0 19 30 22 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm Each Part Number listed below includes all the black components shown in the 3D-drawing. 31 To obtain a complete unit, please select the red components from the pages shown. 41 Actuator, Front dimension 35 mm x 35 mm 45 51 Switching action Front bezel colour Front bezel material Lens colour Lens material Housing colour Housing material Part No. Wiring diagram Momentary Black Plastic Black Plastic Black Plastic 704.209.000 72 Black Plastic Red Plastic Black Plastic 704.209.200 72 Black Plastic Yellow Plastic Black Plastic 704.209.400 72 Black Plastic Green Plastic Black Plastic 704.209.500 72 Black Plastic Blue Plastic Black Plastic 704.209.600 72 Black Plastic Colourless Plastic Black Plastic 704.209.700 72 Silver Plastic Black Plastic Black Plastic 704.210.008 72 Silver Plastic Red Plastic Black Plastic 704.210.208 72 Silver Plastic Yellow Plastic Black Plastic 704.210.408 72 Silver Plastic Green Plastic Black Plastic 704.210.508 72 Silver Plastic Blue Plastic Black Plastic 704.210.608 72 Silver Plastic Colourless Plastic Black Plastic 704.210.708 72 Black Plastic Red Plastic Black Plastic 704.239.200 73 Black Plastic Yellow Plastic Black Plastic 704.239.400 73 Black Plastic Blue Plastic Black Plastic 704.239.600 73 Black Plastic Colourless Plastic Black Plastic 704.239.700 73 Silver Plastic Red Plastic Black Plastic 704.240.208 73 Silver Plastic Yellow Plastic Black Plastic 704.240.408 73 Silver Plastic Green Plastic Black Plastic 704.240.508 73 Silver Plastic Colourless Plastic Black Plastic 704.240.708 73 56 57 61 70 Maintained 71 82 84 92 96 52 eao.com § 08/2022 Flush design 04 Wiring diagrams 01 02 03 04 Wiring diagram 72 Wiring diagram 73 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 08/2022 § eao.com ​ 53 04 Flush design Pushbutton round, IP65 2 02 40 03 23 23 A A Equipment consisting of (schematic overview) Front bezel set 37 01 04 Lens 2 ... 6 Product can differ from the current configuration. Dimensions [mm] A = Screw terminal Actuator General information • Max. 3 switching elements can be clipped on 17 A 35 min. • The colour of anodised aluminium parts can vary due to technical production reasons 18 B 65 min. 14 Marking Plate 50 min. 09 C D Bayonet flange Switching element +0.5 Ø30.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 41 45 51 Actuator, Front dimension Ø 35 mm Switching action Momentary 56 57 61 70 71 Maintained 82 84 Front bezel colour Front bezel material Front bezel surface Lens colour Lens material Housing colour Housing material Wiring diagram Part No. Nature Aluminium anodised Black Aluminium Grey Plastic 704.011.018 72 Nature Aluminium anodised Red Aluminium Grey Plastic 704.011.218 72 Nature Aluminium anodised Gold Aluminium Grey Plastic 704.011.418 72 Nature Aluminium anodised Olive green Aluminium Grey Plastic 704.011.518 72 Nature Aluminium anodised Blue Aluminium Grey Plastic 704.011.618 72 Nature Aluminium anodised Nature Aluminium Grey Plastic 704.011.818 72 Nature Aluminium anodised Black Plastic Grey Plastic 704.012.018 72 Nature Aluminium anodised Red Plastic Grey Plastic 704.012.218 72 Nature Aluminium anodised Yellow Plastic Grey Plastic 704.012.418 72 Nature Aluminium anodised Green Plastic Grey Plastic 704.012.518 72 Nature Aluminium anodised Blue Plastic Grey Plastic 704.012.618 72 Nature Aluminium anodised Colourless Plastic Grey Plastic 704.012.718 72 Nature Aluminium anodised Black Plastic Grey Plastic 704.042.018 73 Nature Aluminium anodised Red Plastic Grey Plastic 704.042.218 73 Nature Aluminium anodised Yellow Plastic Grey Plastic 704.042.418 73 Nature Aluminium anodised Green Plastic Grey Plastic 704.042.518 73 Nature Aluminium anodised Blue Plastic Grey Plastic 704.042.618 73 Nature Aluminium anodised Colourless Plastic Grey Plastic 704.042.718 73 92 96 54 eao.com § 08/2022 Flush design 04 Wiring diagrams 01 02 03 04 Wiring diagram 72 Wiring diagram 73 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 08/2022 § eao.com ​ 55 04 Flush design Pushbutton square, IP65 3 02 39 23 03 Equipment consisting of (schematic overview) 23 A A Lens Page 199 Lens holder Page 201 37 01 04 2 ... 6 Product can differ from the current configuration. Dimensions [mm] A = Screw terminal Press frame General information • Max. 3 switching elements can be clipped on A 35 min. 17 R1.2 max. 30 + 0.5 0 18 B 65 min. 14 Actuator 50 min. 09 C D Bayonet flange Page 203 Switching element Page 213 + 0.5 0 19 30 22 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm Each Part Number listed below includes all the black components shown in the 3D-drawing. 31 To obtain a complete unit, please select the red components from the pages shown. 41 Actuator, Front dimension 35 mm x 35 mm 45 51 56 57 Switching action Front bezel colour Front bezel material Housing colour Housing material Part No. Wiring diagram Momentary Black Plastic Black Plastic 704.741.0 72 Silver Plastic Black Plastic 704.741.8 72 Black Plastic Black Plastic 704.742.0 73 Silver Plastic Black Plastic 704.742.8 73 Maintained Wiring diagrams 61 70 71 82 Wiring diagram 72 Wiring diagram 73 84 92 96 56 eao.com § 08/2022 Flush design 04 Pushbutton round, IP65 01 Front bezel set Page 202 Lens Page 199 Marking Plate Page 201 2 40 23 23 A A 02 04 2 ... 6 Dimensions [mm] A = Screw terminal 14 General information A B Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Ø30.5 65 min. Page 203 50 min. 35 min. Switching element 09 Product can differ from the current configuration. Actuator Bayonet flange 03 37 Equipment consisting of (schematic overview) C D • Max. 3 switching elements can be clipped on • The colour of anodised aluminium parts can vary due to technical production reasons 17 18 +0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Actuator, Front dimension Ø 35 mm 45 Switching action Housing colour Housing material Part No. Wiring diagram Momentary Grey Plastic 704.631.1 72 Maintained Grey Plastic 704.632.1 73 51 56 Wiring diagrams 57 61 70 Wiring diagram 72 71 Wiring diagram 73 82 84 92 96 08/2022 § eao.com 57 04 Flush design 01 Illuminated pushbutton square, IP65 2 02 39 15.5 23 Equipment consisting of (schematic overview) 23 Lens A A A 40 03 Lens holder 04 2 ... 6 Product can differ from the current configuration. Dimensions [mm] A = Screw terminal Press frame General information • Max. 3 switching elements can be clipped on 17 A 35 min. • The lamp block will be delivered with screw terminal Bayonet flange R1.2 max. C D 30 + 0.5 0 18 65 min. 14 Actuator 50 min. 09 B LED Page 204 + 0.5 0 19 30 22 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm Lamp block 31 Switching element Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. 41 To obtain a complete unit, please select the red components from the pages shown. 45 51 Actuator, Front dimension 35 mm x 35 mm 56 57 Switching action Front bezel colour Front bezel material Lens colour Lens material Housing colour Housing material Part No. Wiring diagram Momentary Black Plastic Red Plastic Black Plastic 704.229.200 74 Black Plastic Yellow Plastic Black Plastic 704.229.400 74 Black Plastic Green Plastic Black Plastic 704.229.500 74 Black Plastic Blue Plastic Black Plastic 704.229.600 74 Black Plastic Colourless Plastic Black Plastic 704.229.700 74 Silver Plastic Red Plastic Black Plastic 704.230.208 74 Silver Plastic Yellow Plastic Black Plastic 704.230.408 74 Silver Plastic Green Plastic Black Plastic 704.230.508 74 Silver Plastic Blue Plastic Black Plastic 704.230.608 74 Silver Plastic Colourless Plastic Black Plastic 704.230.708 74 Black Plastic Red Plastic Black Plastic 704.259.200 75 Black Plastic Yellow Plastic Black Plastic 704.259.400 75 Black Plastic Green Plastic Black Plastic 704.259.500 75 Black Plastic Blue Plastic Black Plastic 704.259.600 75 Black Plastic Colourless Plastic Black Plastic 704.259.700 75 Silver Plastic Red Plastic Black Plastic 704.260.208 75 Silver Plastic Yellow Plastic Black Plastic 704.260.408 75 Silver Plastic Green Plastic Black Plastic 704.260.508 75 Silver Plastic Blue Plastic Black Plastic 704.260.608 75 Silver Plastic Colourless Plastic Black Plastic 704.260.708 75 61 70 71 82 Maintained 84 92 96 58 eao.com § 08/2022 Flush design 04 Wiring diagrams 01 X2+ X2+ X1- X1- 02 03 04 Wiring diagram 74 Wiring diagram 75 09 14 17 18 19 22 31 41 45 51 EAO Downloads. www.eao.com/downloads 56 EAO creates possibilities. Since 1947. 57 61 70 71 On our website you can download technical data, assembly instructions, catalogs, brochures and much more. 82 84 92 www.eao.com 08/2022 § eao.com 96 ​ 59 04 Flush design Illuminated pushbutton round, IP65 2 02 40 15.5 23 23 A A A 03 Equipment consisting of (schematic overview) Front bezel set 40 01 04 Lens 2 ... 6 Product can differ from the current configuration. Dimensions [mm] A = Screw terminal Actuator General information • Max. 3 switching elements can be clipped on 17 18 A 35 min. • The lamp block will be delivered with screw terminal • The colour of anodised aluminium parts can vary due to technical production reasons B 65 min. 14 Marking Plate 50 min. 09 C D Bayonet flange LED +0.5 Ø30.5 0 19 Lamp block Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Page 204 Switching element Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 45 51 56 57 Actuator, Front dimension Ø 35 mm Switching action Momentary 61 70 Maintained 71 82 Front bezel colour Front bezel material Front bezel surface Lens colour Lens material Housing colour Housing material Wiring diagram Part No. Nature Aluminium anodised Red Plastic Grey Plastic 704.032.218 74 Nature Aluminium anodised Yellow Plastic Grey Plastic 704.032.418 74 Nature Aluminium anodised Green Plastic Grey Plastic 704.032.518 74 Nature Aluminium anodised Blue Plastic Grey Plastic 704.032.618 74 Nature Aluminium anodised Colourless Plastic Grey Plastic 704.032.718 74 Nature Aluminium anodised Red Plastic Grey Plastic 704.062.218 75 Nature Aluminium anodised Yellow Plastic Grey Plastic 704.062.418 75 Nature Aluminium anodised Green Plastic Grey Plastic 704.062.518 75 Nature Aluminium anodised Blue Plastic Grey Plastic 704.062.618 75 Nature Aluminium anodised Colourless Plastic Grey Plastic 704.062.718 75 84 92 96 60 eao.com § 08/2022 Flush design 04 Wiring diagrams 01 X2+ X2+ X1- X1- 02 03 04 Wiring diagram 74 Wiring diagram 75 09 14 17 18 19 22 31 41 45 51 56 57 61 Modern. Tactile and long-lasting. Series 04 illuminated selector switches. 70 71 Intuitive and reliable operation for enhanced safety in public transportation. . Bright, single or bi-colour LED illumination . Modern, ergonomic design . Rounded edges (in accordance with DIN 5566-1) . Excellent tactile feedback . Long service life and robust construction . Wide range of possible combinations and options 82 84 92 www.eao.com 08/2022 § eao.com 96 ​ 61 04 Flush design Illuminated pushbutton square, IP65 2 02 39 03 15.5 23 A Equipment consisting of (schematic overview) 23 A A Lens Page 199 Lens holder Page 201 40 01 04 2 ... 6 Product can differ from the current configuration. Dimensions [mm] A = Screw terminal Press frame General information • Max. 3 switching elements can be clipped on A 35 min. 17 R1.2 max. 30 + 0.5 0 18 B 65 min. 14 Actuator 50 min. 09 C D Page 203 LED Page 204 Lamp block Page 210 Switching element Page 213 + 0.5 0 19 30 22 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 31 Bayonet flange Each Part Number listed below includes all the black components shown in the 3D-drawing. 41 To obtain a complete unit, please select the red components from the pages shown. 45 51 Actuator, Front dimension 35 mm x 35 mm 56 57 61 70 Switching action Front bezel colour Front bezel material Housing colour Housing material Part No. Wiring diagram Momentary Black Plastic Black Plastic 704.741.0 72 Silver Plastic Black Plastic 704.741.8 72 Black Plastic Black Plastic 704.742.0 73 Silver Plastic Black Plastic 704.742.8 73 Maintained Wiring diagrams 71 82 84 92 Wiring diagram 72 Wiring diagram 73 96 62 eao.com § 08/2022 Flush design 04 Illuminated pushbutton round, IP65 Front bezel set Page 202 Lens Page 199 Marking Plate Page 201 2 40 15.5 23 23 A A A 02 04 2 ... 6 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. Actuator 14 General information A B LED Page 204 Lamp block Page 210 Switching element Page 213 Ø30.5 65 min. Page 203 50 min. 35 min. Bayonet flange 03 40 Equipment consisting of (schematic overview) 01 C D • Max. 3 switching elements can be clipped on • The colour of anodised aluminium parts can vary due to technical production reasons 17 18 +0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 45 51 56 Actuator, Front dimension Ø 35 mm Switching action Housing colour Housing material Part No. Wiring diagram Momentary Grey Plastic 704.631.1 72 Maintained Grey Plastic 704.632.1 73 57 61 Wiring diagrams 70 71 82 Wiring diagram 72 84 Wiring diagram 73 92 96 08/2022 § eao.com 63 04 Flush design Mushroom-head pushbutton, IP65 2 02 40 03 23 23 A A Equipment consisting of (schematic overview) Actuator 37 01 04 Dimensions [mm] A = Screw terminal General information 60min. Ø 60 • Max. 3 switching elements can be clipped on Switching element • The colour of anodised aluminium parts can vary due to technical production reasons 18 65min. 40min. Ø 40 50min. 17 Bayonet flange 60min. 14 Product can differ from the current configuration. 65min. 09 Pressure ring 2 ...6 14 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. A 19 Ø30.5 +0.3 0 B C Page 213 D Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 45 51 Actuator, Front dimension Ø 40 mm Switching action Momentary 56 57 Front bezel colour Front bezel material Front bezel surface Lens colour Lens material Housing colour Housing material Wiring diagram Part No. Black Aluminium anodised Red Plastic Grey Plastic 704.071.210 72 Nature Aluminium anodised Red Plastic Grey Plastic 704.071.218 72 Black Aluminium anodised Yellow Plastic Grey Plastic 704.071.410 72 Nature Aluminium anodised Yellow Plastic Grey Plastic 704.071.418 72 Wiring diagrams 61 70 71 Wiring diagram 72 82 84 92 96 64 eao.com § 08/2022 Flush design 04 Selector switch illuminated, 2 positions, short lever, square, IP65 Equipment consisting of (schematic overview) 16 39 15.5 23 23 A A 01 02 Actuator 37 03 Press frame 04 2 ... 6 09 Bayonet flange Dimensions [mm] A = Screw terminal LED Product can differ from the current configuration. Page 204 A 35 min. Page 213 17 30 B 30 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 0 0 65 min. Switching element • Max. 3 switching elements can be clipped on R1.2 max. 50 min. Page 210 + 0.5 0 Lamp block 14 General information C D 18 + 0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 I 41 I 45 Actuator, Front dimension 35 mm x 35 mm 51 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained Black Plastic 90° right 704.510.000I 85 Silver Plastic 90° right 704.510.008I 85 Black Plastic 42° right 704.512.000I 84 Silver Plastic 42° right 704.512.008I 84 Rest - Momentary 56 57 61 Wiring diagrams x2+ 70 x2+ 71 x1- Wiring diagram 84 x1- 82 Wiring diagram 85 84 92 96 08/2022 § eao.com 65 04 Flush design Selector switch illuminated 2 positions short lever, round, IP65 15 02 15.5 40 03 23 23 A A Equipment consisting of (schematic overview) Actuator 37 01 04 Pressure ring 2 ... 6 Dimensions [mm] X = Screw terminal General information • Max. 3 switching elements can be clipped on 17 Bayonet flange A 35 min. • The colour of anodised aluminium parts can vary due to technical production reasons 18 B 31 0 0 LED Page 204 Lamp block Page 210 Switching element Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. I I 45 51 57 D Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 56 C +0.5 Ø30.5 0 19 41 65 min. 14 Product can differ from the current configuration. 50 min. 09 Actuator, Front dimension Ø 35 mm Switching action Front bezel colour Front bezel material Switching angle Front bezel surface Part No. Wiring diagram Rest - Maintained Black Aluminium 90° right anodised 704.411.010I 85 Nature Aluminium 90° right anodised 704.411.018I 85 Black Aluminium 42° right anodised 704.413.010I 84 Nature Aluminium 42° right anodised 704.413.018I 84 Rest - Momentary 61 Wiring diagrams 70 x2+ x2+ x1- x1- 71 82 84 Wiring diagram 84 Wiring diagram 85 92 96 66 eao.com § 08/2022 Flush design 04 Selector switch 2 positions short lever, square, IP65 Equipment consisting of (schematic overview) 16 39 01 23 23 A A 02 Actuator 37 03 04 Press frame 2 ... 6 09 Bayonet flange Dimensions [mm] A = Screw terminal Switching element Product can differ from the current configuration. A 35 min. 17 30 65 min. B 50 min. + 0.5 0 To obtain a complete unit, please select the red components from the pages shown. • Max. 3 switching elements can be clipped on R1.2 max. 30 Each Part Number listed below includes all the black components shown in the 3D-drawing. 14 General information Page 213 C D 18 + 0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 0 I 0 22 31 I 41 45 Actuator, Front dimension 35 mm x 35 mm 51 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained Black Plastic 90° right 704.510.000 87 Silver Plastic 90° right 704.510.008 87 Black Plastic 42° right 704.512.000 86 Silver Plastic 42° right 704.512.008 86 Rest - Momentary 56 57 61 Wiring diagrams 70 71 82 Wiring diagram 86 Wiring diagram 87 84 92 96 08/2022 § eao.com 67 04 Flush design Selector switch 2 positions, short lever, round, IP65 01 15 02 40 03 23 23 A A Equipment consisting of (schematic overview) 37 Actuator 04 2 ... 6 Dimensions [mm] A = Screw terminal General information • Max. 3 switching elements can be clipped on 17 Bayonet flange A 35 min. • The colour of anodised aluminium parts can vary due to technical production reasons 18 B C D +0.5 Ø30.5 0 19 Switching element Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 65 min. 14 Product can differ from the current configuration. 50 min. 09 Pressure ring 0 I 0 I 45 Actuator, Front dimension Ø 35 mm 51 56 Switching action Front bezel colour Front bezel material Switching angle Front bezel surface Part No. Wiring diagram Rest - Maintained Black Aluminium 90° right anodised 704.411.010 87 Nature Aluminium 90° right anodised 704.411.018 87 Black Aluminium 42° right anodised 704.413.010 86 Nature Aluminium 42° right anodised 704.413.018 86 Rest - Momentary 57 61 Wiring diagrams 70 71 82 Wiring diagram 86 Wiring diagram 87 84 92 96 68 eao.com § 08/2022 Flush design 04 Selector switch 2 positions, short lever, square, IP65 Equipment consisting of (schematic overview) 39 16 01 23 23 A A 02 Actuator 37 03 04 Press frame 2 ... 6 09 Bayonet flange Dimensions [mm] A = Screw terminal Switching element Product can differ from the current configuration. A 35 min. 17 30 65 min. B 50 min. + 0.5 0 To obtain a complete unit, please select the red components from the pages shown. • Max. 3 switching elements can be clipped on R1.2 max. 30 Each Part Number listed below includes all the black components shown in the 3D-drawing. 14 General information Page 213 C D 18 + 0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 0 41 I 45 Actuator, Front dimension 35 mm x 35 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained Black Plastic 90° right 704.510.000.12 87 Silver Plastic 90° right 704.510.008.12 87 51 56 57 Wiring diagrams 61 70 71 82 Wiring diagram 87 84 92 96 08/2022 § eao.com 69 04 Flush design Selector switch 2 positions, short lever, round, IP65 15 02 40 03 23 23 A A Equipment consisting of (schematic overview) Actuator 37 01 04 2 ... 6 Dimensions [mm] X = Screw terminal General information • Max. 3 switching elements can be clipped on 17 Bayonet flange A 35 min. Switching element • The colour of anodised aluminium parts can vary due to technical production reasons 18 B 65 min. 14 Product can differ from the current configuration. 50 min. 09 Pressure ring C D +0.5 Ø30.5 0 19 Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 0 41 I 45 Actuator, Front dimension Ø 35 mm 51 56 57 Switching action Front bezel colour Front bezel material Switching angle Front bezel surface Part No. Wiring diagram Rest - Maintained Black Aluminium 90° right anodised 704.411.010.12 87 Nature Aluminium 90° right anodised 704.411.018.12 87 Wiring diagrams 61 70 71 82 Wiring diagram 87 84 92 96 70 eao.com § 08/2022 Flush design 04 Selector switch illuminated, 2 positions, long lever, square, IP65 Equipment consisting of (schematic overview) 16 15.5 40 23 23 A A 01 02 03 37 31.5 Actuator Press frame 04 2 ... 6 09 Bayonet flange Dimensions [mm] A = Screw terminal LED Product can differ from the current configuration. Page 204 A 42 min. Page 213 17 30 B 30 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 0 0 65 min. Switching element • Max. 3 switching elements can be clipped on R1.2 max. 50 min. Page 210 + 0.5 0 Lamp block 14 General information C D 18 + 0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3v x 0.8 mm 22 31 I 41 I 45 Actuator, Front dimension 35 mm x 35 mm 51 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained Black Plastic 90° right 704.300.000I 85 Silver Plastic 90° right 704.300.008I 85 Black Plastic 42° right 704.302.000I 84 Silver Plastic 42° right 704.302.008I 84 Rest - Momentary 56 57 61 Wiring diagrams x2+ 70 x2+ 71 x1- Wiring diagram 84 x1- 82 Wiring diagram 85 84 92 96 08/2022 § eao.com 71 04 Flush design Selector switch illuminated, 2 positions, long lever, round, IP65 15 02 03 15.5 40 23 23 A A Equipment consisting of (schematic overview) 31.5 Actuator 37 01 04 Pressure ring 2 ... 6 Dimensions [mm] A = Screw terminal General information • Max. 3 switching elements can be clipped on 17 Bayonet flange • The colour of anodised aluminium parts can vary due to technical production reasons B 31 0 0 Page 210 C D Switching element Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. I I 45 51 61 Lamp block Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 57 Page 204 +0.5 Ø30.5 0 19 56 LED 42min. 18 41 A 65min. 14 Product can differ from the current configuration. 50min. 09 Actuator, Front dimension Ø 35 mm Switching action Front bezel colour Front bezel material Switching angle Front bezel surface Part No. Wiring diagram Rest - Maintained Black Aluminium 90° right anodised 704.101.010I 85 Nature Aluminium 90° right anodised 704.101.018I 85 Nature Aluminium 42° right anodised 704.103.018I 84 Rest - Momentary Wiring diagrams 70 x2+ x2+ x1- x1- 71 82 84 Wiring diagram 84 Wiring diagram 85 92 96 72 eao.com § 08/2022 Flush design 04 Selector switch 2 positions, long lever, square, IP65 Equipment consisting of (schematic overview) 16 39 01 23 23 A A 02 Actuator 25 37 03 04 Press frame 2 ... 6 09 Bayonet flange Dimensions [mm] A = Screw terminal Switching element Product can differ from the current configuration. A 42 min. 17 30 65 min. B 50 min. + 0.5 0 To obtain a complete unit, please select the red components from the pages shown. • Max. 3 switching elements can be clipped on R1.2 max. 30 Each Part Number listed below includes all the black components shown in the 3D-drawing. 14 General information Page 213 C D 18 + 0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3v x 0.8 mm 0 I 0 22 31 I 41 45 Actuator, Front dimension 35 mm x 35 mm 51 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained Black Plastic 90° right 704.300.000 87 Silver Plastic 90° right 704.300.008 87 Black Plastic 42° right 704.302.000 86 Silver Plastic 42° right 704.302.008 86 Rest - Momentary 56 57 61 Wiring diagrams 70 71 82 Wiring diagram 86 Wiring diagram 87 84 92 96 08/2022 § eao.com 73 04 Flush design Selector switch 2 positions, long lever, round, IP65 01 15 02 40 03 23 23 A A Equipment consisting of (schematic overview) 25 37 Actuator 04 Pressure ring 2 ... 6 Dimensions [mm] A = Screw terminal General information • Max. 3 switching elements can be clipped on 17 Bayonet flange A 42min. • The colour of anodised aluminium parts can vary due to technical production reasons 18 B C D +0.5 Ø30.5 0 19 Switching element Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 65min. 14 Product can differ from the current configuration. 50min. 09 0 I 0 I 45 Actuator, Front dimension Ø 35 mm 51 56 57 61 Switching action Front bezel colour Front bezel material Switching angle Front bezel surface Part No. Wiring diagram Rest - Maintained Black Aluminium 90° right anodised 704.101.010 87 Nature Aluminium 90° right anodised 704.101.018 87 Nature Aluminium 42° right anodised 704.103.018 86 Rest - Momentary Wiring diagrams 70 71 82 Wiring diagram 86 Wiring diagram 87 84 92 96 74 eao.com § 08/2022 Flush design 04 Selector switch 2 positions, 12 o‘clock, long lever, square, IP65 Equipment consisting of (schematic overview) 16 39 23 23 A A 01 02 Actuator 25 37 03 04 Press frame 2 ... 6 09 Bayonet flange Dimensions [mm] A = Screw terminal Switching element Product can differ from the current configuration. A 42 min. 17 30 65 min. B 50 min. + 0.5 0 To obtain a complete unit, please select the red components from the pages shown. • Max. 3 switching elements can be clipped on R1.2 max. 30 Each Part Number listed below includes all the black components shown in the 3D-drawing. 14 General information Page 213 C D 18 + 0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3v x 0.8 mm 22 31 0 41 I 45 Actuator, Front dimension 35 mm x 35 mm 51 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained Black Plastic 90° right 704.300.000.12 87 Silver Plastic 90° right 704.300.008.12 87 56 57 Wiring diagrams 61 70 71 82 Wiring diagram 87 84 92 96 08/2022 § eao.com 75 04 Flush design Selector switch 2 positions, long lever, round, IP65 15 02 40 03 23 23 A A Equipment consisting of (schematic overview) Actuator 25 37 01 04 Pressure ring 2 ... 6 Dimensions [mm] A = Screw terminal General information • Max. 3 switching elements can be clipped on 17 Bayonet flange A 42min. • The colour of anodised aluminium parts can vary due to technical production reasons 18 B 65min. 14 Product can differ from the current configuration. 50min. 09 C D +0.5 Ø30.5 0 19 Switching element Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 0 41 I 45 Actuator, Front dimension Ø 35 mm 51 56 57 Switching action Front bezel colour Front bezel material Switching angle Front bezel surface Part No. Wiring diagram Rest - Maintained Black Aluminium 90° right anodised 704.101.010.12 87 Nature Aluminium 90° right anodised 704.101.018.12 87 Wiring diagrams 61 70 71 82 Wiring diagram 87 84 92 96 76 eao.com § 08/2022 Flush design 04 Selector switch illuminated, 3 positions, short lever, square, IP65 Equipment consisting of (schematic overview) 16 15.5 39 23 23 A A 01 02 Actuator 37 03 Press frame 04 2 ... 6 09 Bayonet flange Dimensions [mm] A = Screw terminal LED Product can differ from the current configuration. Page 204 A 35 min. Page 213 17 30 B 30 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. I 0 II I 0 II I 0 II I 0 65 min. Switching element • Max. 3 switching elements can be clipped on R1.2 max. 50 min. Page 210 + 0.5 0 Lamp block 14 General information C D 18 + 0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 II 41 45 Actuator, Front dimension 35 mm x 35 mm 51 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Maintained - Rest - Maintained Black Plastic 42° left / 42° right 704.502.000I 91 Silver Plastic 42° left / 42° right 704.502.008I 91 Black Plastic 42° left / 42° right 704.504.000I 90 Silver Plastic 42° left / 42° right 704.504.008I 90 Black Plastic 42° left / 42° right 704.506.000I 89 Silver Plastic 42° left / 42° right 704.506.008I 89 Black Plastic 42° left / 42° right 704.508.000I 88 Silver Plastic 42° left / 42° right 704.508.008I 88 Momentary - Rest - Momentary Maintained - Rest - Momentary Momentary - Rest - Maintained 56 57 61 70 Wiring diagrams 71 x2+ x2+ x2+ 82 x1- Wiring diagram 88 x1- Wiring diagram 89 84 x1- 92 Wiring diagram 90 96 08/2022 § eao.com 77 04 Flush design 01 Wiring diagrams x2+ 02 03 x1- 04 Wiring diagram 91 09 14 17 18 19 22 31 41 45 51 Follow us. We are on LinkedIn! 56 EAO creates possibilities. Since 1947. 57 61 70 71 Come take a look at our LinkedIn profi le today! Be sure to give us a follow so that you can fully interact with us. 82 https://www.linkedin.com/company/eao/ 84 92 www.eao.com 96 78 ​ eao.com § 08/2022 Flush design 04 Selector switch illuminated, 3 positions, short lever, round, IP65 Equipment consisting of (schematic overview) 15 15.5 40 23 23 A A 01 02 03 37 Actuator 04 Pressure ring 2 ... 6 Dimensions [mm] X = Screw terminal Bayonet flange 09 Product can differ from the current configuration. 14 General information Page 210 B Switching element Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. I 0 II I 0 II I 0 II I 0 Ø30.5 Page 213 65 min. Lamp block A 35 min. Page 204 50 min. LED C D • Max. 3 switching elements can be clipped on • The colour of anodised aluminium parts can vary due to technical production reasons 17 18 +0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 II 45 51 Actuator, Front dimension Ø 35 mm Switching action Front bezel colour Front bezel material Switching angle Front bezel surface Part No. Wiring diagram Maintained - Rest - Maintained Black Aluminium 42° left / 42° right anodised 704.403.010I 91 Nature Aluminium 42° left / 42° right anodised 704.403.018I 91 Black Aluminium 42° left / 42° right anodised 704.405.010I 90 Nature Aluminium 42° left / 42° right anodised 704.405.018I 90 Black Aluminium 42° left / 42° right anodised 704.407.010I 89 Nature Aluminium 42° left / 42° right anodised 704.407.018I 89 Black Aluminium 42° left / 42° right anodised 704.409.010I 88 Nature Aluminium 42° left / 42° right anodised 704.409.018I 88 Momentary - Rest - Momentary Maintained - Rest - Momentary Momentary - Rest - Maintained 56 57 61 70 Wiring diagrams 71 x2+ x2+ 82 x2+ 84 x1- x1- x1- 92 Wiring diagram 88 Wiring diagram 89 Wiring diagram 90 96 08/2022 § eao.com 79 04 Flush design 01 Wiring diagrams x2+ 02 03 x1- 04 Wiring diagram 91 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 80 ​ eao.com § 08/2022 Flush design 04 Selector switch 3 positions, short lever, square, IP65 Equipment consisting of (schematic overview) 16 39 01 23 23 A A 02 Actuator 37 03 04 Press frame 2 ... 6 09 Bayonet flange Dimensions [mm] A = Screw terminal Switching element Product can differ from the current configuration. 14 General information Page 213 A 35 min. • Max. 3 switching elements can be clipped on 17 B 30 65 min. + 0.5 0 30 To obtain a complete unit, please select the red components from the pages shown. 50 min. R1.2 max. Each Part Number listed below includes all the black components shown in the 3D-drawing. C D 18 + 0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm I 0 II I 0 II I 0 II I 0 22 31 II 41 45 Actuator, Front dimension 35 mm x 35 mm 51 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Maintained - Rest - Maintained Black Plastic 42° left / 42° right 704.502.000 95 Silver Plastic 42° left / 42° right 704.502.008 95 Black Plastic 42° left / 42° right 704.504.000 94 Silver Plastic 42° left / 42° right 704.504.008 94 Black Plastic 42° left / 42° right 704.506.000 93 Silver Plastic 42° left / 42° right 704.506.008 93 Black Plastic 42° left / 42° right 704.508.000 92 Silver Plastic 42° left / 42° right 704.508.008 92 Momentary - Rest - Momentary Maintained - Rest - Momentary Momentary - Rest - Maintained 56 57 61 70 Wiring diagrams 71 82 84 Wiring diagram 92 Wiring diagram 93 Wiring diagram 94 92 Wiring diagram 95 96 08/2022 § eao.com 81 04 Flush design Selector switch 3 positions, short lever, round, IP65 01 15 02 40 03 23 23 A A Equipment consisting of (schematic overview) 37 Actuator 04 2 ... 6 Product can differ from the current configuration. 14 Dimensions [mm] A = Screw terminal Bayonet flange General information • Max. 3 switching elements can be clipped on • The colour of anodised aluminium parts can vary due to technical production reasons 18 B C D +0.5 Ø30.5 0 19 Switching element Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 65 min. 17 A 35 min. 50 min. 09 Pressure ring 0 I II I 0 II I 0 II I 0 II 45 Actuator, Front dimension Ø 35 mm 51 56 Switching action Front bezel colour Front bezel material Switching angle Front bezel surface Part No. Wiring diagram Maintained - Rest - Maintained Black Aluminium 42° left / 42° right anodised 704.403.010 95 Nature Aluminium 42° left / 42° right anodised 704.403.018 95 Black Aluminium 42° left / 42° right anodised 704.405.010 94 Nature Aluminium 42° left / 42° right anodised 704.405.018 94 Black Aluminium 42° left / 42° right anodised 704.407.010 93 Nature Aluminium 42° left / 42° right anodised 704.407.018 93 Black Aluminium 42° left / 42° right anodised 704.409.010 92 Nature Aluminium 42° left / 42° right anodised 704.409.018 92 Momentary - Rest - Momentary 57 61 70 Maintained - Rest - Momentary Momentary - Rest - Maintained Wiring diagrams 71 82 84 92 Wiring diagram 92 Wiring diagram 93 Wiring diagram 94 Wiring diagram 95 96 82 eao.com § 08/2022 Flush design 04 Selector switch illuminated, 3 positions, long lever, square, IP65 Equipment consisting of (schematic overview) 16 15.5 40 23 23 A A 01 02 03 37 31.5 Actuator Press frame 04 2 ... 6 09 Bayonet flange Dimensions [mm] A = Screw terminal LED Product can differ from the current configuration. Page 204 A 42 min. Page 213 17 30 B 30 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. I 0 II I 0 II I 0 II I 0 65 min. Switching element • Max. 3 switching elements can be clipped on R1.2 max. 50 min. Page 210 + 0.5 0 Lamp block 14 General information C D 18 + 0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3v x 0.8 mm 22 31 II 41 45 Actuator, Front dimension 35 mm x 35 mm 51 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Maintained - Rest - Maintained Black Plastic 42° left / 42° right 704.292.000I 91 Silver Plastic 42° left / 42° right 704.292.008I 91 Black Plastic 42° left / 42° right 704.294.000I 90 Silver Plastic 42° left / 42° right 704.294.008I 90 Black Plastic 42° left / 42° right 704.296.000I 89 Silver Plastic 42° left / 42° right 704.296.008I 89 Black Plastic 42° left / 42° right 704.298.000I 88 Silver Plastic 42° left / 42° right 704.298.008I 88 Momentary - Rest - Momentary Maintained - Rest - Momentary Momentary - Rest - Maintained 56 57 61 70 Wiring diagrams 71 x2+ x2+ x2+ 82 x1- Wiring diagram 88 x1- Wiring diagram 89 84 x1- 92 Wiring diagram 90 96 08/2022 § eao.com 83 04 Flush design 01 Wiring diagrams x2+ 02 03 x1- 04 Wiring diagram 91 09 14 17 18 19 22 31 41 45 51 56 57 61 Modern. Tactile and long-lasting. Series 04 illuminated selector switches. 70 71 Intuitive and reliable operation for enhanced safety in public transportation. . Bright, single or bi-colour LED illumination . Modern, ergonomic design . Rounded edges (in accordance with DIN 5566-1) . Excellent tactile feedback . Long service life and robust construction . Wide range of possible combinations and options 82 84 92 www.eao.com 96 84 ​ eao.com § 08/2022 Flush design 04 Selector switch illuminated, 3 positions long lever, round, IP65 Equipment consisting of (schematic overview) 15 40 15.5 23 23 A A 01 02 03 37 31.5 Actuator 04 Pressure ring 2 ... 6 Dimensions [mm] A = Screw terminal Bayonet flange 09 Product can differ from the current configuration. 14 General information Page 210 B Switching element Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. I 0 II I 0 II I 0 II I 0 Ø30.5 Page 213 65min. Lamp block A 42min. Page 204 50min. LED C D • Max. 3 switching elements can be clipped on • The colour of anodised aluminium parts can vary due to technical production reasons 17 18 +0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 II 45 51 Actuator, Front dimension Ø 35 mm Switching action Front bezel colour Front bezel material Switching angle Front bezel surface Part No. Wiring diagram Maintained - Rest - Maintained Black Aluminium 42° left / 42° right anodised 704.093.010I 91 Nature Aluminium 42° left / 42° right anodised 704.093.018I 91 Black Aluminium 42° left / 42° right anodised 704.095.010I 90 Nature Aluminium 42° left / 42° right anodised 704.095.018I 90 Black Aluminium 42° left / 42° right anodised 704.097.010I 89 Nature Aluminium 42° left / 42° right anodised 704.097.018I 89 Black Aluminium 42° left / 42° right anodised 704.099.010I 88 Nature Aluminium 42° left / 42° right anodised 704.099.018I 88 Momentary - Rest - Momentary Maintained - Rest - Momentary Momentary - Rest - Maintained 56 57 61 70 71 Wiring diagrams x2+ x2+ 82 x2+ 84 x1- Wiring diagram 88 08/2022 § eao.com x1- Wiring diagram 89 x1- 92 Wiring diagram 90 96 85 04 Flush design 01 Wiring diagrams x2+ 02 03 x1- 04 Wiring diagram 91 09 14 17 18 19 22 31 41 45 51 Individual. According to customer requirements. 56 EAO creates possibilities. Since 1947. 57 61 70 71 With our value-added services, we individually modify our standard components in accordance with our customers’ needs – quickly and cost-effectively. 82 . Customer-specific marking . Individual illumination . Customized software . Customized cables and connectors . Mechanical and electronic adaptations . Manufacturing of mounting sets 84 92 www.eao.com 96 86 ​ eao.com § 08/2022 Flush design 04 Selector switch 3 positions, long lever, quare, IP65 Equipment consisting of (schematic overview) 16 39 01 23 23 A A 02 Actuator 25 37 03 04 Press frame 2 ... 6 09 Bayonet flange Dimensions [mm] A = Screw terminal Switching element Product can differ from the current configuration. 14 General information Page 213 A 42 min. • Max. 3 switching elements can be clipped on 17 B 30 65 min. + 0.5 0 30 To obtain a complete unit, please select the red components from the pages shown. 50 min. R1.2 max. Each Part Number listed below includes all the black components shown in the 3D-drawing. C D 18 + 0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3v x 0.8 mm I 0 II I 0 II I 0 II I 0 22 31 II 41 45 Actuator, Front dimension 35 mm x 35 mm 51 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Maintained - Rest - Maintained Black Plastic 42° left / 42° right 704.292.000 95 Silver Plastic 42° left / 42° right 704.292.008 95 Black Plastic 42° left / 42° right 704.294.000 94 Silver Plastic 42° left / 42° right 704.294.008 94 Black Plastic 42° left / 42° right 704.296.000 93 Silver Plastic 42° left / 42° right 704.296.008 93 Black Plastic 42° left / 42° right 704.298.000 92 Silver Plastic 42° left / 42° right 704.298.008 92 Momentary - Rest - Momentary Maintained - Rest - Momentary Momentary - Rest - Maintained 56 57 61 70 Wiring diagrams 71 82 84 Wiring diagram 92 Wiring diagram 93 Wiring diagram 94 92 Wiring diagram 95 96 08/2022 § eao.com 87 04 Flush design Selector switch 3 positions, long lever, round, IP65 01 15 02 40 03 23 23 A A Equipment consisting of (schematic overview) 25 37 Actuator 04 Pressure ring 2 ... 6 Product can differ from the current configuration. 14 Dimensions [mm] A = Screw terminal Bayonet flange General information • Max. 3 switching elements can be clipped on • The colour of anodised aluminium parts can vary due to technical production reasons 18 B C D +0.5 Ø30.5 0 19 Switching element Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 65min. 17 A 42min. 50min. 09 0 I II I 0 II I 0 II I 0 II 45 Actuator, Front dimension Ø 35 mm 51 56 57 Switching action Front bezel colour Front bezel material Switching angle Front bezel surface Part No. Wiring diagram Maintained - Rest - Maintained Black Aluminium 42° left / 42° right anodised 704.093.010 95 Nature Aluminium 42° left / 42° right anodised 704.093.018 95 Black Aluminium 42° left / 42° right anodised 704.095.010 94 Nature Aluminium 42° left / 42° right anodised 704.095.018 94 Black Aluminium 42° left / 42° right anodised 704.097.010 93 Nature Aluminium 42° left / 42° right anodised 704.097.018 93 Black Aluminium 42° left / 42° right anodised 704.099.010 92 Nature Aluminium 42° left / 42° right anodised 704.099.018 92 Momentary - Rest - Momentary Maintained - Rest - Momentary 61 Momentary - Rest - Maintained 70 71 Wiring diagrams 82 84 92 Wiring diagram 92 Wiring diagram 93 Wiring diagram 94 Wiring diagram 95 96 88 eao.com § 08/2022 Flush design 04 Selector rotary switch, short lever rounded, round, IP65 Equipment consisting of (schematic overview) 01 1 15 02 A 03 Actuator 44 04 Pressure ring 12 2 ... 6 Bayonet flange 2 14 General information 15 B • The colour of anodised aluminium parts can vary due to technical production reasons 13.5 17 Page 227 18 38 Switching element 09 Product can differ from the current configuration. Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 19 2 ... 6 22 Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66.5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65.5 mm 31 41 52 min. 50 min. 45 51 Ø30.5 +0.5 0 56 Mounting cut-outs [mm] 57 61 Actuator, Front dimension Ø 35 mm 70 Front bezel colour Front bezel material Switching positions Front bezel surface Part No. Black Aluminium Rest = 12 o‘clock anodised 704.411.010KNI Nature Aluminium Rest = 12 o‘clock anodised 704.411.018KNI Aluminium Rest = 9 o‘clock anodised 704.411.118KNI 71 82 84 92 96 08/2022 § eao.com 89 04 Flush design 01 Selector rotary switch, short lever, square, IP65 Equipment consisting of (schematic overview) 1 02 16 A-1 Actuator 03 09 Press frame 44 04 14 Bayonet flange 12 2 ... 6 Product can differ from the current configuration. 2 16 B-1 17 13.5 Switching element 38 18 Page 227 Each Part Number listed below includes all the black components shown in the 3D-drawing. 19 2 ... 6 22 To obtain a complete unit, please select the red components from the pages shown. Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66.5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65.5 mm 31 41 52 min. 30 + 0.5 0 50 min. R1.2 max. 45 51 30 + 0.5 0 56 Mounting cut-outs [mm] 57 61 70 71 Actuator, Front dimension 35 mm x 35 mm Front bezel colour Front bezel material Switching positions Part No. Black Plastic Rest = 9 o‘clock 704.510.100KN Silver Plastic Rest = 9 o‘clock 704.510.108KN 82 84 92 96 90 eao.com § 08/2022 Flush design 04 Selector rotary switch short lever, round, IP65 Equipment consisting of (schematic overview) 01 1 15 02 A 03 Actuator 44 04 Pressure ring 12 2 ... 6 09 Product can differ from the current configuration. Bayonet flange 2 B • The colour of anodised aluminium parts can vary due to technical production reasons 13.5 17 Page 227 18 38 Switching element 14 General information 15 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 19 2 ... 6 22 Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66.5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65.5 mm 31 41 52 min. 50 min. 45 51 Ø30.5 +0.5 0 56 Mounting cut-outs [mm] 57 61 70 Actuator, Front dimension Ø 35 mm Front bezel colour Front bezel material Switching positions Front bezel surface Part No. Black Aluminium Rest = 12 o‘clock anodised 704.411.010KN Nature Aluminium Rest = 12 o‘clock anodised 704.411.018KN Black Aluminium Rest = 9 o‘clock anodised 704.411.110KN Nature Aluminium Rest = 9 o‘clock anodised 704.411.118KN 71 82 84 92 96 08/2022 § eao.com 91 04 Flush design 01 Selector rotary switch, long lever rounded, round, IP65 Equipment consisting of (schematic overview) 1 02 15 A 03 09 14 17 31.5 04 44 Actuator Pressure ring 12 2 ... 6 Product can differ from the current configuration. Bayonet flange 2 General information 15 B • The colour of anodised aluminium parts can vary due to technical production reasons 13.5 31.5 18 19 Each Part Number listed below includes all the black components shown in the 3D-drawing. 2 ... 6 22 Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66.5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65.5 mm 31 Page 227 38 Switching element 41 To obtain a complete unit, please select the red components from the pages shown. 52 min. 50 min. 45 51 Ø30.5 +0.5 0 56 Mounting cut-outs [mm] 57 61 70 71 82 Actuator, Front dimension Ø 35 mm Front bezel colour Front bezel material Switching positions Front bezel surface Part No. Nature Aluminium Rest = 12 o‘clock anodised 704.101.018KNI Black Aluminium Rest = 9 o‘clock anodised 704.101.110KNI Nature Aluminium Rest = 9 o‘clock anodised 704.101.118KNI 84 92 96 92 eao.com § 08/2022 Flush design 04 Selector rotary switch long lever, square, IP65 Equipment consisting of (schematic overview) 01 1 16 02 A-1 Actuator 03 44 04 25 Press frame Bayonet flange 09 12 2 ... 6 Product can differ from the current configuration. 2 16 13.5 Page 227 17 18 Each Part Number listed below includes all the black components shown in the 3D-drawing. 25 38 Switching element 14 B-1 19 2 ... 6 To obtain a complete unit, please select the red components from the pages shown. 22 Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66.5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65.5 mm 31 41 52 min. R1.2 max. 30 + 0.5 0 50 min. 45 51 + 0.5 30 0 56 Mounting cut-outs [mm] 57 61 70 Actuator, Front dimension 35 mm x 35 mm Front bezel colour Front bezel material Switching positions Part No. Black Plastic Rest = 9 o‘clock 704.300.100KN Silver Plastic Rest = 9 o‘clock 704.300.108KN 71 82 84 92 96 08/2022 § eao.com 93 04 Flush design 01 Selector rotary switch long lever, round, IP65 Equipment consisting of (schematic overview) 1 02 15 A 03 Actuator 44 04 25 Pressure ring 09 14 17 12 2 ... 6 Product can differ from the current configuration. Bayonet flange 2 General information 15 B • The colour of anodised aluminium parts can vary due to technical production reasons 13.5 Switching element 25 38 18 Page 227 19 Each Part Number listed below includes all the black components shown in the 3D-drawing. 2 ... 6 22 Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66.5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65.5 mm 31 41 To obtain a complete unit, please select the red components from the pages shown. 52 min. 50 min. 45 51 Ø30.5 +0.5 0 56 Mounting cut-outs [mm] 57 61 70 71 82 Actuator, Front dimension Ø 35 mm Front bezel colour Front bezel material Switching positions Front bezel surface Part No. Nature Aluminium Rest = 12 o‘clock anodised 704.101.018KN Black Aluminium Rest = 9 o‘clock anodised 704.101.110KN Nature Aluminium Rest = 9 o‘clock anodised 704.101.118KN 84 92 96 94 eao.com § 08/2022 Flush design 04 Keylock switch 2 positions, square, IP65 Equipment consisting of (schematic overview) 01 10.5 39 23 23 A A 02 03 37 Actuator 04 Press frame 33.5 Bayonet flange Switching element 2 ... 6 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information Page 213 A 35 min. • Max. 3 switching elements can be clipped on 30 65 min. B 50 min. + 0.5 0 30 To obtain a complete unit, please select the red components from the pages shown. 17 • The standard lock Ronis 251 R1.2 max. Each Part Number listed below includes all the black components shown in the 3D-drawing. C D 18 + 0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 0 I 0 22 31 I 41 45 Actuator, Front dimension 35 mm x 35 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained (a) Black Plastic 90° right 704.340.000 79 Silver Plastic 90° right 704.340.008 79 Black Plastic 90° right 704.341.000 79 Silver Plastic 90° right 704.341.008 79 Black Plastic 90° right 704.342.000 79 Silver Plastic 90° right 704.342.008 79 Black Plastic 42° right 704.343.000 78 Silver Plastic 42° right 704.343.008 78 Rest (a) - Maintained Rest (a) - Maintained (a) Rest (a) - Momentary 51 56 57 61 a = Key remove 70 Wiring diagrams 71 82 84 92 Wiring diagram 78 Wiring diagram 79 96 08/2022 § eao.com 95 04 Flush design Keylock switch 2 positions, round, IP65 2 02 71.5 03 Equipment consisting of (schematic overview) 23 A A Actuator 37 01 04 23 Dimensions [mm] A = Screw terminal General information • Max. 3 switching elements can be clipped on 17 18 Pressure ring • The standard lock Ronis 251 • The colour of anodised aluminium parts can vary due to technical production reasons B C D Switching element To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 0 I 0 Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. +0.5 Ø30.5 0 19 41 Bayonet flange A 35 min. 65 min. 14 Product can differ from the current configuration. Anti-twist device 50 min. 09 2 ... 6 I 45 Actuator, Front dimension Ø 35 mm 51 56 57 61 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained (a) Nature Aluminium 90° right 704.120.018 79 Rest (a) - Maintained Nature Aluminium 90° right 704.121.018 79 Rest (a) - Maintained (a) Nature Aluminium 90° right 704.122.018 79 Rest (a) - Momentary Nature Aluminium 42° right 704.123.018 78 a = Key remove Wiring diagrams 70 71 82 84 Wiring diagram 78 Wiring diagram 79 92 96 96 eao.com § 08/2022 Flush design 04 Keylock switch 3 positions, square, IP65 Equipment consisting of (schematic overview) 01 10.5 39 23 23 A A 02 03 37 Actuator 04 Press frame 33.5 Bayonet flange 2 ... 6 Dimensions [mm] A = Screw terminal Switching element A 35 min. • Max. 3 switching elements can be clipped on 17 • The standard lock Ronis 251 30 65 min. + 0.5 0 30 B 50 min. R1.2 max. To obtain a complete unit, please select the red components from the pages shown. 14 General information Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. 09 Product can differ from the current configuration. C D 18 + 0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 0 I I 0 II I 0 II I 0 II I 0 22 31 II 41 II 45 Actuator, Front dimension 35 mm x 35 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Maintained (a) - Rest (a) - Maintained (a) Black Plastic 90° left / 90° right 704.333.000 83 Silver Plastic 90° left / 90° right 704.333.008 83 Black Plastic 42° left / 42° right 704.334.000 83 Silver Plastic 42° left / 42° right 704.334.008 83 Black Plastic 42° left / 42° right 704.335.000 82 Silver Plastic 42° left / 42° right 704.335.008 82 Black Plastic 42° left / 42° right 704.336.000 83 Silver Plastic 42° left / 42° right 704.336.008 83 Black Plastic 42° left / 42° right 704.337.000 81 Silver Plastic 42° left / 42° right 704.337.008 81 Black Plastic 42° left / 42° right 704.338.000 80 Silver Plastic 42° left / 42° right 704.338.008 80 Black Plastic 42° left / 42° right 704.344.000 81 Silver Plastic 42° left / 42° right 704.344.008 81 Maintained - Rest (a) - Maintained Momentary - Rest (a) - Momentary Maintained (a) - Rest - Maintained (a) Maintained (a) - Rest - Momentary Momentary - Rest (a) - Maintained Maintained (a) - Rest (a) - Momentary 51 56 57 61 70 71 82 a = Key remove 84 92 96 08/2022 § eao.com 97 04 Flush design 01 Wiring diagrams 02 03 04 Wiring diagram 80 Wiring diagram 81 Wiring diagram 82 Wiring diagram 83 09 14 17 18 19 22 31 41 45 51 Follow us. We are on YouTube! 56 EAO ermöglicht. Seit 1947. 57 61 70 71 Come take a look at our YouTube profi le today! Be sure to give us a follow so that you can fully interact with us. 82 https://www.youtube.com/user/eaoswitches 84 92 www.eao.com 96 98 ​ eao.com § 08/2022 Flush design 04 Keylock switch 3 positions, round, IP65 2 71.5 Actuator 23 A A 02 03 37 Equipment consisting of (schematic overview) 01 04 23 Anti-twist device 2 ... 6 Dimensions [mm] A = Screw terminal Pressure ring 09 Product can differ from the current configuration. 14 General information Bayonet flange A 35 min. • Max. 3 switching elements can be clipped on 17 Page 213 B Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 0 I I 0 II I 0 II I 0 II I 0 Ø30.5 65 min. Switching element 50 min. • The standard lock Ronis 251 C D • The colour of anodised aluminium parts can vary due to technical production reasons +0.5 0 18 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 II 41 II 45 Actuator, Front dimension Ø 35 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Maintained (a) - Rest (a) - Maintained (a) Nature Aluminium 90° left / 90° right 704.113.018 83 Maintained - Rest (a) - Maintained Nature Aluminium 42° left / 42° right 704.114.018 83 Momentary - Rest (a) - Momentary Nature Aluminium 42° left / 42° right 704.115.018 82 Maintained (a) - Rest - Maintained (a) Nature Aluminium 42° left / 42° right 704.116.018 83 Maintained (a) - Rest - Momentary Nature Aluminium 42° left / 42° right 704.117.018 81 Momentary - Rest (a) - Maintained Nature Aluminium 42° left / 42° right 704.118.018 80 Maintained (a) - Rest (a) - Momentary Nature Aluminium 42° left / 42° right 704.124.018 81 51 56 57 61 a = Key remove 70 Wiring diagrams 71 82 84 Wiring diagram 80 Wiring diagram 81 Wiring diagram 82 92 Wiring diagram 83 96 08/2022 § eao.com 99 04 Flush design 01 Keylock rotary switch, IP65 Equipment consisting of (schematic overview) 1 02 22.5 2 A 12 03 44 Actuator 04 Anti-twist device 09 14 2 ... 4 Product can differ from the current configuration. Pressure ring 2 22.5 General information 2 B 13.5 • The standard lock Ronis 251 • The colour of anodised aluminium parts can vary due to technical production reasons 38 17 Bayonet flange 18 Switching element Page 227 2 ... 6 19 22 Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66,5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65,5 mm 31 41 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 52 min. 50 min. 45 51 Ø30.5 +0.5 0 56 Mounting cut-outs [mm] 57 61 70 71 82 Actuator, Front dimension Ø 35 mm Switching action Front bezel colour Front bezel material Switching positions Part No. Maintained - Rest (a) Nature Aluminium Rest = 12 o‘clock 704.123.018KN Nature Aluminium Rest = 9 o‘clock 704.123.118KN a = Key remove 84 92 96 100 eao.com § 08/2022 Flush design 04 Key-insert switch 2 positions , IP67 01 Equipment consisting of (schematic overview) 2 02 68 03 Actuator Fixing nut 37 A 04 2 ... 5 Dimensions [mm] A = Screw terminal Bayonet flange 09 Product can differ from the current configuration. 14 General information Switching element A NJO Page 213 • Max. 3 switching elements can be clipped on • In the Part-No. „x“ stands for not defined actuator 0 I PLQ B PLQ To obtain a complete unit, please select the red components from the pages shown. ±  Each Part Number listed below includes all the black components shown in the 3D-drawing.  3 C D 17 18    19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 0 41 I 45 Actuator, Front dimension Ø 38 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained Nature Stainless steel 90° right 704.101.0x28 97 Rest - Momentary Nature Stainless steel 45° left 704.103.0x28 98 51 56 57 Wiring diagrams 61 70 71 Wiring diagram 97 82 Wiring diagram 98 84 92 96 08/2022 § eao.com 101 04 Flush design Key-insert switch 3 positions, IP67 01 Equipment consisting of (schematic overview) 02 2 68 03 Actuator 04 Product can differ from the current configuration. 14 Dimensions [mm] A = Screw terminal Bayonet flange General information • Max. 3 switching elements can be clipped on A NJO • In the Part-No. „x“ stands for not defined actuator Switching element Page 213 3 ±   18 19 B PLQ 17 Each Part Number listed below includes all the black components shown in the 3D-drawing. C D To obtain a complete unit, please select the red components from the pages shown.    Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Fixing nut 2 ... 5 PLQ 09 37 A I 0 II I 0 II I 0 II I 0 II 45 Actuator, Front dimension Ø 38 mm 51 56 57 61 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Maintained - Rest - Maintained Nature Stainless steel 45° left / 45° right 704.093.0x28 99 Momentary - Rest - Momentary Nature Stainless steel 45° left / 45° right 704.095.0x28 100 Maintained - Rest - Momentary Nature Stainless steel 45° left / 45° right 704.097.0x28 101 Momentary - Rest - Maintained Nature Stainless steel 45° left / 45° right 704.099.0x28 102 Wiring diagrams 70 71 82 84 Wiring diagram 99 Wiring diagram 100 Wiring diagram 101 Wiring diagram 102 92 96 102 eao.com § 08/2022 Flush design 04 Key-insert switch 3 positions, conductor switch, IP67 01 Equipment consisting of (schematic overview) 3 39 02 23 9 A 03 37 9 7.7 Actuator 04 Actuator 2 ... 10 Switching element 09 Page 213 Dimensions [mm] A = Screw terminal Product can differ from the current configuration. Each Part Number listed below includes all the black components shown in the 3D-drawing. 14 General information A NJO To obtain a complete unit, please select the red components from the pages shown. • Max. 1 switching element can be clipped on PLQ ±   PLQ 17 18 3NBY    B C 19 D Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm I 0 22 31 II 41 45 Actuator, Front dimension Ø 38 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Momentary - Rest - Momentary Nature Stainless steel 42° left / 42° right 704.095.0T28N 100 51 56 Wiring diagrams 57 61 70 71 Wiring diagram 100 82 84 92 96 08/2022 § eao.com 103 04 Flush design 01 Lever switch, IP54 02 03 04 09 Product can differ from the current configuration. 14 General information 17 • For all units are the levers 02 (black), 03, 04, 05, 06 (yellow) 13, 14, 15 and 16 available (levers 6 + 16 according UIC 612). Special levers on request 18 19 22 31 41 • Front bezel can also be delivered in black version • Functions and properties, including lever style and switching positions of the lever switch are being produced according to customer specifications. Please contact your local EAO Sales Office • Micro-switch contacts: The micro-switch is available with a silver contact or a gold plated silver contact. Contact without positive opening operation is used in the lever switches S41, S42 and S43 • Each lever switch includes a maximum of five micro-switches. Contact with positive opening operation is used in the lever switches S44 and S45. Each lever switch includes a maximum of four micro-switches 45 51 56 Actuator, Front dimension Ø 40 mm 57 Front bezel colour Front bezel material Front bezel surface Switching system Contacts Part No. S41: Cage clamp 1.0 mm … 1.5 mm², 1 contact element Nature Aluminium anodised Snap-action switching element 1 NC / 1 NO 704.151.XXX S42: JST connector max. 0.2 mm² (counter plug is supplied), 1 contact element Nature Aluminium anodised Snap-action switching element 1 NC / 1 NO 704.152.XXX S43: Plug-in terminal 6.3 mm x 0.8 mm, 1 contact element Nature Aluminium anodised Snap-action switching element 1 NC / 1 NO 704.153.XXX S44: Cage clamp 1.0 mm … 1.5 mm², 1 contact element positive opend Nature Aluminium anodised Snap-action switching element 1 NC / 1 NO 704.154.XXX S45: Screw terminal or plug-in terminal 6.3 mm x 0.8 mm, 1 contact element positive opend Nature Aluminium anodised Snap-action switching element 1 NC / 1 NO 704.155.XXX Product attributes 61 70 71 82 Contacts: NC = Normally closed, NO = Normally open 84 92 96 104 ​ eao.com § 08/2022 Flush design 04 Indicator square, IP65 01 Equipment consisting of (schematic overview) 3 39 17.5 02 Lens 03 40 A Lens holder 04 2 ... 6 Actuator Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 Press frame 35 min. Bayonet flange 17 LED A 18 30 + 0.5 0 50 min. R1.2 max. Page 204 30 + 0.5 0 19 Lamp block Mounting cut-outs [mm] A = Screw terminal Each Part Number listed below includes all the black components shown in the 3D-drawing. 22 31 To obtain a complete unit, please select the red components from the pages shown. 41 45 Actuator, Front dimension 35 mm x 35 mm Housing colour Housing material Lens colour Front bezel colour Front bezel material Marking plate colour Marking plate optics Part No. Wiring diagram Black Plastic Red Silver Plastic White translucent 704.202.208 4 Plastic Yellow Silver Plastic White translucent 704.202.408 4 Plastic Green Silver Plastic White translucent 704.202.508 4 Plastic Blue Silver Plastic White translucent 704.202.608 4 Plastic Colourless Silver Plastic White translucent 704.202.708 4 Plastic Red Black Plastic White translucent 704.206.200 4 Plastic Yellow Black Plastic White translucent 704.206.400 4 Plastic Green Black Plastic White translucent 704.206.500 4 Plastic Blue Black Plastic White translucent 704.206.600 4 Plastic Colourless Black Plastic White translucent 704.206.700 4 51 56 57 61 70 71 Wiring diagrams 82 x2+ 84 x1- 92 Wiring diagram 4 08/2022 § eao.com 96 105 04 Flush design Indicator round, IP65 40 2 02 03 Equipment consisting of (schematic overview) 17.5 Front bezel set 40 01 A 04 Lens 2 ... 6 09 Marking Plate Product can differ from the current configuration. Dimensions [mm] A = Screw terminal 14 Actuator 35min. 50min. 17 18 Ø30.5 19 Bayonet flange A LED +0.5 0 Lamp block Mounting cut-outs [mm] A = Screw terminal 22 Page 204 Each Part Number listed below includes all the black components shown in the 3D-drawing. 31 To obtain a complete unit, please select the red components from the pages shown. 41 45 51 56 Actuator, Front dimension Ø 35 mm Housing colour Grey 57 61 70 Lens colour Front bezel colour Front bezel material Front bezel surface Wiring diagram Part No. Plastic Red Nature Aluminium anodised 704.006.218 4 Plastic Yellow Nature Aluminium anodised 704.006.418 4 Plastic Green Nature Aluminium anodised 704.006.518 4 Plastic Blue Nature Aluminium anodised 704.006.618 4 Plastic Colourless Nature Aluminium anodised 704.006.718 4 Wiring diagrams x2+ 71 82 84 Housing material x1- Wiring diagram 4 92 96 106 eao.com § 08/2022 Flush design 04 Indicator square, IP65 01 Equipment consisting of (schematic overview) 39 17.5 02 Page 199 A Lens holder 03 40 Lens 3 Page 201 04 2 ... 6 Actuator Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 Press frame A 35 min. Page 204 30 B 30 Lamp block 65 min. LED 17 R1.2 max. 50 min. Page 203 + 0.5 0 Bayonet flange C D 18 + 0.5 0 19 Page 210 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 45 Actuator, Front dimension 35 mm x 35 mm Housing colour Housing material Front bezel colour Front bezel material Part No. Wiring diagram Black Plastic Black Plastic 704.743.0 4 Plastic Silver Plastic 704.743.8 4 51 56 57 Wiring diagrams 61 x2+ 70 x1- 71 Wiring diagram 4 82 84 92 96 08/2022 § eao.com 107 04 Flush design Indicator round, IP65 40 2 02 Equipment consisting of (schematic overview) 17.5 03 A 04 2 ... 6 09 Product can differ from the current configuration. Front bezel set Page 202 Lens Page 199 Marking Plate Page 201 40 01 Dimensions [mm] A = Screw terminal 14 Actuator A 18 B 65 min. 17 50 min. 35 min. C D +0.5 Ø30.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 Bayonet flange Page 203 LED Page 204 Lamp block Page 210 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 41 45 Actuator, Front dimension Ø 35 mm 51 56 57 Housing colour Housing material Part No. Wiring diagram Grey Plastic 704.633.1 4 Wiring diagrams 61 x2+ 70 x1- 71 82 Wiring diagram 4 84 92 96 108 eao.com § 08/2022 Flush design 04 Flasher without LED square, IP65 01 Equipment consisting of (schematic overview) 3 39 15.5 28 02 Lens 03 40 A Marking foil 04 Lens holder 2 ... 6 Dimensions [mm] A = Screw terminal Actuator 09 Product can differ from the current configuration. 14 A 35 min. Press frame 17 30 LED 18 B 30 Page 204 65 min. + 0.5 0 Bayonet flange 50 min. R1.2 max. + 0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) Lamp block 22 31 Flasher element Page 235 41 Each Part Number listed below includes all the black components shown in the 3D-drawing. 45 To obtain a complete unit, please select the red components from the pages shown. 51 56 Actuator, Front dimension 35 mm x 35 mm 57 Housing colour Housing material Lens colour Front bezel colour Front bezel material Marking plate colour Marking plate optics Part No. Wiring diagram Black Plastic Red Silver Plastic White translucent 704.202.208 4 Plastic Yellow Silver Plastic White translucent 704.202.408 4 Plastic Green Silver Plastic White translucent 704.202.508 4 Plastic Blue Silver Plastic White translucent 704.202.608 4 Plastic Colourless Silver Plastic White translucent 704.202.708 4 Plastic Red Black Plastic White translucent 704.206.200 4 Plastic Yellow Black Plastic White translucent 704.206.400 4 Plastic Green Black Plastic White translucent 704.206.500 4 Plastic Blue Black Plastic White translucent 704.206.600 4 Plastic Colourless Black Plastic White translucent 704.206.700 4 61 70 71 82 84 92 96 08/2022 § eao.com 109 04 Flush design 01 Wiring diagrams x2+ 02 03 x1- 04 Wiring diagram 4 09 14 17 18 19 22 31 41 45 51 Green Touch. Offering sustainability. 56 EAO creates possibilities. Since 1947. 57 61 70 71 As a successful company with production sites around the world, EAO is actively committed to the effective implementation of a sustainable environmental policy. 82 We act responsibly. In our environmental focus, we set benchmarks for ourselves, our products and our customers. Throughout our entire value chain, we think and work in a way that is resource-efficient and environmentally-friendly. When selecting our components and raw materials, we ensure that we have partnerships in place with certified manufacturers and that we adhere to EC guidelines on hazardous materials (RoHS). 84 92 www.eao.com 96 110 ​ eao.com § 08/2022 Flush design 04 Flasher without LED round, IP65 Equipment consisting of (schematic overview) 01 2 40 15.5 28 02 03 A 40 Front bezel set 04 Lens 2 ... 6 Marking Plate Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 Actuator A 35 min. Flasher element 18 B Page 204 Lamp block 65 min. 50 min. Bayonet flange LED 17 Ø30.5 +0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) 22 31 Page 235 41 Each Part Number listed below includes all the black components shown in the 3D-drawing. 45 To obtain a complete unit, please select the red components from the pages shown. 51 56 Actuator, Front dimension Ø 35 mm Housing colour Grey Housing material Lens colour Front bezel colour Front bezel material Front bezel surface Part No. Wiring diagram Plastic Red Nature Aluminium anodised 704.006.218 4 Plastic Yellow Nature Aluminium anodised 704.006.418 4 Plastic Green Nature Aluminium anodised 704.006.518 4 Plastic Blue Nature Aluminium anodised 704.006.618 4 Plastic Colourless Nature Aluminium anodised 704.006.718 4 57 61 70 71 Wiring diagrams 82 x2+ 84 x1- 92 Wiring diagram 4 08/2022 § eao.com 96 111 04 Flush design Flasher square, IP65 3 02 39 15.5 03 Equipment consisting of (schematic overview) 28 A Lens Page 199 Lens holder Page 201 40 01 04 2 ... 6 09 Actuator Product can differ from the current configuration. Dimensions [mm] A = Screw terminal 14 Press frame A 35 min. 17 30 19 Page 203 LED Page 204 Lamp block Page 210 Flasher element Page 235 B 30 + 0.5 0 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) 22 Bayonet flange 65 min. + 0.5 0 18 50 min. R1.2 max. 31 Each Part Number listed below includes all the black components shown in the 3D-drawing. 41 To obtain a complete unit, please select the red components from the pages shown. 45 51 56 57 Actuator, Front dimension 35 mm x 35 mm Housing colour Housing material Front bezel colour Front bezel material Part No. Wiring diagram Black Plastic Black Plastic 704.743.0 4 Plastic Silver Plastic 704.743.8 4 61 70 Wiring diagrams x2+ 71 82 84 x1- Wiring diagram 4 92 96 112 eao.com § 08/2022 Flush design 04 Flasher round, IP65 01 Equipment consisting of (schematic overview) 40 15.5 28 02 03 Page 202 A Lens Page 199 Marking Plate Page 201 40 Front bezel set 2 04 2 ... 6 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 Actuator A 35 min. Page 203 LED Page 204 Lamp block Page 210 Flasher element Page 235 65 min. 50 min. Bayonet flange 17 18 B Ø30.5 +0.5 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) 22 31 41 Each Part Number listed below includes all the black components shown in the 3D-drawing. 45 To obtain a complete unit, please select the red components from the pages shown. 51 56 Actuator, Front dimension Ø 35 mm Housing colour Housing material Part No. Wiring diagram Grey Plastic 704.633.1 4 57 61 Wiring diagrams 70 x2+ 71 x1- 82 Wiring diagram 4 84 92 96 08/2022 § eao.com 113 04 Flush design 01 Buzzer, IP65 Equipment consisting of (schematic overview) 2 ... 6 02 Actuator Ø 35 03 04 46.5 2 09 14 Product can differ from the current configuration. Pressure ring Dimensions [mm] Fixing nut General information Each Part Number listed below includes all the black components shown in the 3D-drawing. NJO • Further information see Technical data PLQ 17 18  19 ± 22 Mounting cut-outs [mm] 31 Actuator, Front dimension Ø 35 mm 41 45 51 Terminal Operating voltage Front cap colour Front cap material Front cap surface Part No. Wiring diagram Plug-in terminal 24 V DC Black Aluminium anodised 14-810.910 71 24 V DC Nature Aluminium anodised 14-810.918 71 Wiring diagrams 56 x1+ 57 x2- 61 70 Wiring diagram 71 71 82 84 92 96 114 eao.com § 08/2022 Flush design 04 Potentiometer, IP65 01 Equipment consisting of (schematic overview) 2.5 02 Lever 03 04 Actuator 4 max. 21.5 Front bezel set Page 202 39 Dimensions [mm] ​ 09 Product can differ from the current configuration. 41 max. Fixing nut 14 General information A 36 min. • For front dimensions 36 mm x 36 mm, Ø 36 mm 17 50 min. Mounting 18 Potentiometer Ø30.5 Each Part Number listed below includes all the black components shown in the 3D-drawing. 19 +0.5 0 Mounting cut-outs [mm] A = Action range of aligning pins 22 To obtain a complete unit, please select the red components from the pages shown. 31 41 45 Actuator, Front dimension Ø 36 mm Housing material Front bezel colour Plastic Matt grey Front bezel material Front bezel surface Resistance Part No. Wiring diagram Metal matt chrome 10 kOhm 44-745.20-10K1 104 10 kOhm 44-745.60-10K1 104 Plastic 51 56 Wiring diagrams 57 61 1 2 70 3 71 Wiring diagram 104 82 84 92 96 08/2022 § eao.com ​ 115 04 Flush design Stop switch, IP65 2 02 40 03 23 23 A A Equipment consisting of (schematic overview) Actuator 37 01 04 Anti-twist device 14 Dimensions [mm] A = Screw terminal Bayonet flange General information • Max. 3 switching elements can be clipped on 17 A 42min. • Twist to unlock clockwise Switching element 18 B 19 Ø30.5 65min. 14 Pressure ring Product can differ from the current configuration. 50min. 09 2 ... 6 C D +0.5 0 Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Actuator, Front dimension Ø 40 mm 45 Switching action Lens colour Front bezel colour Front bezel material Front bezel surface Marking Part No. Wiring diagram Maintained Red Black Aluminium anodised Arrows 704.074.210 76 Red Nature Aluminium anodised Arrows 704.075.218 76 Red Black Aluminium anodised Stop 704.075.310 76 56 Red Nature Aluminium anodised Stop 704.075.318 76 57 Wiring diagrams 51 61 70 71 Wiring diagram 76 82 84 92 96 116 eao.com § 08/2022 Raised design 04 Pushbutton square, IP67 01 Equipment consisting of (schematic overview) 53 13 23 02 Front bezel A 03 37 A Lens 04 2…7 Lens holder Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. Actuator 14 General information A 30 min. • Max. 3 switching elements can be clipped on 17 Page 213 B 65 min. Switching element 50 min. Bayonet flange C D 18 +0.4 0 19 Ø22.3 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Actuator, Front dimension 30 mm x 30 mm Switching action Front bezel colour Front bezel material Lens colour Lens material Housing colour Housing material Part No. Wiring diagram Momentary Black Plastic Black Plastic Black Plastic 704.209.0 72 Black Plastic Red Plastic Black Plastic 704.209.2 72 Black Plastic Yellow Plastic Black Plastic 704.209.4 72 Black Plastic Green Plastic Black Plastic 704.209.5 72 Black Plastic Blue Plastic Black Plastic 704.209.6 72 Black Plastic Colourless Plastic Black Plastic 704.209.7 72 Grey Plastic Black Plastic Black Plastic 704.210.0 72 Grey Plastic Red Plastic Black Plastic 704.210.2 72 Grey Plastic Yellow Plastic Black Plastic 704.210.4 72 Grey Plastic Green Plastic Black Plastic 704.210.5 72 Grey Plastic Blue Plastic Black Plastic 704.210.6 72 Grey Plastic Colourless Plastic Black Plastic 704.210.7 72 Black Plastic Black Plastic Black Plastic 704.239.0 73 Black Plastic Red Plastic Black Plastic 704.239.2 73 Black Plastic Green Plastic Black Plastic 704.239.5 73 Black Plastic Colourless Plastic Black Plastic 704.239.7 73 Grey Plastic Black Plastic Black Plastic 704.240.0 73 Grey Plastic Red Plastic Black Plastic 704.240.2 73 Grey Plastic Yellow Plastic Black Plastic 704.240.4 73 Grey Plastic Green Plastic Black Plastic 704.240.5 73 Grey Plastic Colourless Plastic Black Plastic 704.240.7 73 Maintained 45 51 56 57 61 70 71 82 84 92 96 08/2022 § eao.com 117 04 Raised design 01 Wiring diagrams 02 03 04 Wiring diagram 72 Wiring diagram 73 09 14 17 18 19 22 31 41 45 51 56 57 61 Modern. Tactile and long-lasting. Series 04 illuminated selector switches. 70 71 Intuitive and reliable operation for enhanced safety in public transportation. . Bright, single or bi-colour LED illumination . Modern, ergonomic design . Rounded edges (in accordance with DIN 5566-1) . Excellent tactile feedback . Long service life and robust construction . Wide range of possible combinations and options 82 84 92 www.eao.com 96 118 ​ eao.com § 08/2022 Raised design 04 Pushbutton round 01 Equipment consisting of (schematic overview) 53 13 23 02 Front bezel A 03 37 A Lens 04 Marking Plate 2…7 Actuator Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information • Max. 3 switching elements can be clipped on Page 213 B 65 min. 17 50 min. Switching element A 30 min. Bayonet flange C D 18 +0.4 0 19 Ø22.3 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Actuator, Front dimension Ø 29 mm Switching action Front bezel colour Front bezel material Momentary Black Front bezel surface Lens colour Lens material Housing colour Housing material IP front protection Part No. Wiring diagram Plastic Black Plastic Grey Plastic IP65 704.009.0 72 Black Plastic Red Plastic Grey Plastic IP65 704.009.2 72 Black Plastic Yellow Plastic Grey Plastic IP65 704.009.4 72 Black Plastic Green Plastic Grey Plastic IP65 704.009.5 72 Black Plastic Blue Plastic Grey Plastic IP65 704.009.6 72 Black Plastic Colourless Plastic Grey Plastic IP65 704.009.7 72 Grey Plastic Black Plastic Grey Plastic IP65 704.010.0 72 Grey Plastic Red Plastic Grey Plastic IP65 704.010.2 72 Grey Plastic Yellow Plastic Grey Plastic IP65 704.010.4 72 Grey Plastic Green Plastic Grey Plastic IP65 704.010.5 72 Grey Plastic Blue Plastic Grey Plastic IP65 704.010.6 72 Grey Plastic Colourless Plastic Grey Plastic IP65 704.010.7 72 Nature Aluminium Black Aluminium Grey Plastic IP65 704.011.0 72 anodised 45 51 56 57 61 70 71 82 84 92 96 08/2022 § eao.com 119 04 Raised design 01 Switching action Front bezel colour Front bezel material Front bezel surface Lens colour Lens material Housing colour Housing material IP front protection Part No. Wiring diagram Momentary Nature Aluminium anodised Red Aluminium Grey Plastic IP65 704.011.2 72 Nature Aluminium anodised Gold Aluminium Grey Plastic IP65 704.011.4 72 Nature Aluminium anodised Olive green Aluminium Grey Plastic IP65 704.011.5 72 Nature Aluminium anodised Blue Aluminium Grey Plastic IP65 704.011.6 72 Nature Aluminium anodised Nature Aluminium Grey Plastic IP65 704.011.8 72 Nature Aluminium anodised Black Plastic Grey Plastic IP65 704.012.0 72 Nature Aluminium anodised Red Plastic Grey Plastic IP65 704.012.2 72 Nature Aluminium anodised Yellow Plastic Grey Plastic IP65 704.012.4 72 Nature Aluminium anodised Green Plastic Grey Plastic IP65 704.012.5 72 Nature Aluminium anodised Blue Plastic Grey Plastic IP65 704.012.6 72 Nature Aluminium anodised Colourless Plastic Grey Plastic IP65 704.012.7 72 02 03 04 09 14 17 Maintained 18 19 22 31 41 45 51 56 57 61 Momentary Black Plastic Black Plastic Grey Plastic IP65 704.039.0 73 Black Plastic Red Plastic Grey Plastic IP65 704.039.2 73 Black Plastic Yellow Plastic Grey Plastic IP65 704.039.4 73 Black Plastic Green Plastic Grey Plastic IP65 704.039.5 73 Black Plastic Blue Plastic Grey Plastic IP65 704.039.6 73 Black Plastic Colourless Plastic Grey Plastic IP65 704.039.7 73 Grey Plastic Red Plastic Grey Plastic IP65 704.040.2 73 Grey Plastic Yellow Plastic Grey Plastic IP65 704.040.4 73 Grey Plastic Green Plastic Grey Plastic IP65 704.040.5 73 Grey Plastic Blue Plastic Grey Plastic IP65 704.040.6 73 Grey Plastic Colourless Plastic Grey Plastic IP65 704.040.7 73 Nature Aluminium anodised Black Aluminium Grey Plastic IP65 704.041.0 73 Nature Aluminium anodised Red Aluminium Grey Plastic IP65 704.041.2 73 Nature Aluminium anodised Olive green Aluminium Grey Plastic IP65 704.041.5 73 Nature Aluminium anodised Aluminium Grey Plastic IP65 704.041.6 73 Nature Aluminium anodised Nature Aluminium Grey Plastic IP65 704.041.8 73 Nature Aluminium anodised Black Plastic Grey Plastic IP65 704.042.0 73 Nature Aluminium anodised Red Plastic Grey Plastic IP65 704.042.2 73 Nature Aluminium anodised Yellow Plastic Grey Plastic IP65 704.042.4 73 Nature Aluminium anodised Green Plastic Grey Plastic IP65 704.042.5 73 Nature Aluminium anodised Blue Plastic Grey Plastic IP65 704.042.6 73 Nature Aluminium anodised Colourless Plastic Grey Plastic IP65 704.042.7 73 Nature Aluminium anodised Black Plastic Grey Plastic IP67 704.013.0 72 Nature Aluminium anodised Red Plastic Grey Plastic IP67 704.013.2 72 70 Nature Aluminium anodised Yellow Plastic Grey Plastic IP67 704.013.4 72 Nature Aluminium anodised Green Plastic Grey Plastic IP67 704.013.5 72 Nature Aluminium anodised Blue Plastic Grey Plastic IP67 704.013.6 72 71 Nature Aluminium anodised Colourless Plastic Grey Plastic IP67 704.013.7 72 Nature Aluminium anodised Red Plastic Grey Plastic IP67 704.043.2 73 82 Nature Aluminium anodised Colourless Plastic Grey Plastic IP67 704.043.7 73 84 92 96 120 ​ eao.com § 08/2022 Raised design 04 Wiring diagrams 01 02 03 04 Wiring diagram 72 Wiring diagram 73 09 14 17 18 19 22 31 41 45 51 EAO. Award winning. 56 EAO creates possibilities. Since 1947. 57 61 70 71 EAO provides outstanding design – based almost exclusively on functional and technological considerations. 82 EAO's products and solutions have won numerous design awards over the years. 84 92 www.eao.com 08/2022 § eao.com 96 ​ 121 04 Raised design Pushbutton square, IP65 53 13 02 Equipment consisting of (schematic overview) 23 03 A A Front bezel Page 202 Lens Page 199 Lens holder Page 201 37 01 04 2…7 09 14 Product can differ from the current configuration. Dimensions [mm] A = Screw terminal Actuator General information • Max. 3 switching elements can be clipped on A 30 min. B 65 min. 18 50 min. 17 C D Bayonet flange Page 203 Switching element Page 213 +0.4 0 19 Ø22.3 Each Part Number listed below includes all the black components shown in the 3D-drawing. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 To obtain a complete unit, please select the red components from the pages shown. 41 Actuator, Front dimension 30 mm x 30 mm 45 51 56 57 Switching action Housing colour Housing material Part No. Wiring diagram Momentary Black Plastic 704.731.0 72 Grey Plastic 704.731.1 72 Black Plastic 704.732.0 73 Grey Plastic 704.732.1 73 Maintained Wiring diagrams 61 70 71 82 Wiring diagram 72 Wiring diagram 73 84 92 96 122 eao.com § 08/2022 Raised design 04 Pushbutton round, IP65 01 Front bezel Page 202 Lens Page 199 Marking Plate Page 201 53 13 23 A A 02 03 37 Equipment consisting of (schematic overview) 04 2…7 Actuator Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information Page 213 B C D • Frontring with protective cover to be mounted with a torque of 0.4 Nm onto actuator 17 • Max. 3 switching elements can be clipped on 18 +0.4 0 19 Ø22.3 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 65 min. Switching element A 30 min. Page 203 50 min. Bayonet flange Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Actuator, Front dimension Ø 29 mm Switching action Housing colour Housing material Part No. Wiring diagram Momentary Grey Plastic 704.631.1 72 Maintained Grey Plastic 704.632.1 73 45 51 56 Wiring diagrams 57 61 70 Wiring diagram 72 Wiring diagram 73 71 82 84 92 96 08/2022 § eao.com 123 04 Raised design 01 Illuminated pushbutton square, IP65 13 02 69 Equipment consisting of (schematic overview) 23 03 A A 40 Front bezel Lens 04 2 ... 7 09 14 Product can differ from the current configuration. Lens holder Dimensions [mm] A = Screw terminal Actuator General information • Max. 3 switching elements can be clipped on A 30 min. 17 B 65 min. 18 50 min. Bayonet flange C D LED Page 204 +0.4 0 19 Ø22.3 Lamp block Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 Switching element Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. 41 To obtain a complete unit, please select the red components from the pages shown. 45 51 Actuator, Front dimension 30 mm x 30 mm 56 57 Switching action Front bezel colour Front bezel material Lens colour Lens material Housing colour Housing material Part No. Wiring diagram Momentary Black Plastic Red Plastic Black Plastic 704.229.2 74 Black Plastic Yellow Plastic Black Plastic 704.229.4 74 Black Plastic Green Plastic Black Plastic 704.229.5 74 Black Plastic Blue Plastic Black Plastic 704.229.6 74 Black Plastic Colourless Plastic Black Plastic 704.229.7 74 Grey Plastic Red Plastic Black Plastic 704.230.2 74 Grey Plastic Yellow Plastic Black Plastic 704.230.4 74 Grey Plastic Green Plastic Black Plastic 704.230.5 74 Grey Plastic Blue Plastic Black Plastic 704.230.6 74 Grey Plastic Colourless Plastic Black Plastic 704.230.7 74 Black Plastic Red Plastic Black Plastic 704.259.2 75 Black Plastic Yellow Plastic Black Plastic 704.259.4 75 Black Plastic Green Plastic Black Plastic 704.259.5 75 Black Plastic Blue Plastic Black Plastic 704.259.6 75 Black Plastic Colourless Plastic Black Plastic 704.259.7 75 Grey Plastic Red Plastic Black Plastic 704.260.2 75 Grey Plastic Yellow Plastic Black Plastic 704.260.4 75 Grey Plastic Green Plastic Black Plastic 704.260.5 75 Grey Plastic Blue Plastic Black Plastic 704.260.6 75 Grey Plastic Colourless Plastic Black Plastic 704.260.7 75 61 70 71 82 Maintained 84 92 96 124 eao.com § 08/2022 Raised design 04 Wiring diagrams 01 X2+ X2+ X1- X1- 02 03 04 Wiring diagram 74 Wiring diagram 75 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 08/2022 § eao.com ​ 125 04 Raised design 01 Illuminated pushbutton round 13 02 69 Equipment consisting of (schematic overview) 23 03 A 40 Front bezel A Lens 04 Marking Plate 2 ... 7 17 18 Actuator Dimensions [mm] A = Screw terminal General information • Frontring with protective cover to be mounted with a torque of 0.4 Nm onto actuator A 30 min. • Max. 3 switching elements can be clipped on • The colour of anodised aluminium parts can vary due to technical production reasons B 65 min. 14 Product can differ from the current configuration. 50 min. 09 C D Bayonet flange LED +0.4 Ø22.3 0 19 Lamp block Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 Page 204 Switching element Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. 41 To obtain a complete unit, please select the red components from the pages shown. 45 51 Actuator, Front dimension Ø 29 mm 56 Switching action Momentary 57 Front bezel colour Front bezel material Front bezel surface Lens colour Lens material Housing colour Housing material Part No. Wiring diagram Black Plastic Red Plastic Grey Plastic 704.029.2 74 Black Plastic Yellow Plastic Grey Plastic 704.029.4 74 Black Plastic Green Plastic Grey Plastic 704.029.5 74 61 Black Plastic Blue Plastic Grey Plastic 704.029.6 74 Black Plastic Colourless Plastic Grey Plastic 704.029.7 74 70 Grey Plastic Red Plastic Grey Plastic 704.030.2 74 Grey Plastic Yellow Plastic Grey Plastic 704.030.4 74 Grey Plastic Green Plastic Grey Plastic 704.030.5 74 71 Grey Plastic Blue Plastic Grey Plastic 704.030.6 74 Grey Plastic Colourless Plastic Grey Plastic 704.030.7 74 82 Nature Aluminium anodised Red Plastic Grey Plastic 704.032.2 74 Nature Aluminium anodised Yellow Plastic Grey Plastic 704.032.4 74 84 92 Nature Aluminium anodised Green Plastic Grey Plastic 704.032.5 74 Nature Aluminium anodised Blue Plastic Grey Plastic 704.032.6 74 Nature Aluminium anodised Colourless Plastic Grey Plastic 704.032.7 74 Nature Aluminium anodised Red Plastic Grey Plastic 704.033.2 74 96 126 eao.com § 08/2022 Raised design 04 Switching action Front bezel colour Front bezel material Front bezel surface Lens colour Lens material Housing colour Housing material Part No. Wiring diagram Momentary Nature Aluminium anodised Yellow Plastic Grey Plastic 704.033.4 74 Maintained Nature Aluminium anodised Green Plastic Grey Plastic 704.033.5 74 Nature Aluminium anodised Blue Plastic Grey Plastic 704.033.6 74 Nature Aluminium anodised Colourless Plastic Grey Plastic 704.033.7 74 Black Plastic Red Plastic Grey Plastic 704.059.2 75 Black Plastic Yellow Plastic Grey Plastic 704.059.4 75 Black Plastic Green Plastic Grey Plastic 704.059.5 75 Black Plastic Colourless Plastic Grey Plastic 704.059.7 75 Grey Plastic Red Plastic Grey Plastic 704.060.2 75 Grey Plastic Yellow Plastic Grey Plastic 704.060.4 75 Grey Plastic Green Plastic Grey Plastic 704.060.5 75 Grey Plastic Blue Plastic Grey Plastic 704.060.6 75 Grey Plastic Colourless Plastic Grey Plastic 704.060.7 75 Nature Aluminium anodised Red Plastic Grey Plastic 704.062.2 75 Nature Aluminium anodised Yellow Plastic Grey Plastic 704.062.4 75 Nature Aluminium anodised Green Plastic Grey Plastic 704.062.5 75 Nature Aluminium anodised Blue Plastic Grey Plastic 704.062.6 75 Nature Aluminium anodised Colourless Plastic Grey Plastic 704.062.7 75 Nature Aluminium anodised Red Plastic Grey Plastic 704.063.2 75 Nature Aluminium anodised Yellow Plastic Grey Plastic 704.063.4 75 Nature Aluminium anodised Green Plastic Grey Plastic 704.063.5 75 Nature Aluminium anodised Blue Plastic Grey Plastic 704.063.6 75 Nature Aluminium anodised Colourless Plastic Grey Plastic 704.063.7 75 02 03 04 09 14 17 18 19 22 31 Wiring diagrams 41 X2+ X2+ X1- X1- Wiring diagram 74 01 45 51 56 Wiring diagram 75 57 61 70 71 82 84 92 96 08/2022 § eao.com ​ 127 04 Raised design Illuminated pushbutton square, IP65 13 02 69 Equipment consisting of (schematic overview) 23 03 A A Front bezel Page 202 Lens Page 199 Lens holder Page 201 40 01 04 2 ... 7 17 Dimensions [mm] A = Screw terminal Actuator General information • Frontring with protective cover to be mounted with a torque of 0.4 Nm onto actuator A 30 min. • Max. 3 switching elements can be clipped on 18 B 65 min. 14 Product can differ from the current configuration. 50 min. 09 C D Bayonet flange Page 203 LED Page 204 Lamp block Page 210 Switching element Page 213 +0.4 0 19 Ø22.3 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 Each Part Number listed below includes all the black components shown in the 3D-drawing. 41 To obtain a complete unit, please select the red components from the pages shown. 45 51 Actuator, Front dimension 30 mm x 30 mm 56 57 61 70 Switching action Housing colour Housing material Part No. Wiring diagram Momentary Black Plastic 704.731.0 72 Grey Plastic 704.731.1 72 Black Plastic 704.732.0 73 Grey Plastic 704.732.1 73 Maintained Wiring diagrams 71 82 84 92 Wiring diagram 72 Wiring diagram 73 96 128 eao.com § 08/2022 Raised design 04 Illuminated pushbutton round, IP65 Front bezel Page 202 Lens Page 199 Marking Plate Page 201 13 69 23 A A 02 03 40 Equipment consisting of (schematic overview) 01 04 2 ... 7 Actuator Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information Page 204 B Lamp block Page 210 Switching element Page 213 65 min. LED A 30 min. Page 203 50 min. Bayonet flange C D • Frontring with protective cover to be mounted with a torque of 0.4 Nm onto actuator 17 • Max. 3 switching elements can be clipped on 18 +0.4 0 19 Ø22.3 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 Each Part Number listed below includes all the black components shown in the 3D-drawing. 41 To obtain a complete unit, please select the red components from the pages shown. 45 51 Actuator, Front dimension Ø 29 mm Switching action Housing colour Housing material Part No. Wiring diagram Momentary Grey Plastic 704.631.1 72 Maintained Grey Plastic 704.632.1 73 56 57 Wiring diagrams 61 70 71 82 Wiring diagram 72 Wiring diagram 73 84 92 96 08/2022 § eao.com 129 04 Raised design Mushroom-head pushbutton, IP65 53 25 02 Equipment consisting of (schematic overview) 23 03 Actuator A A 37 01 04 Bayonet flange 2… 7 Dimensions [mm] A = Screw terminal General information Page 213 60min. Ø 60 • Max. 3 switching elements can be clipped on Each Part Number listed below includes all the black components shown in the 3D-drawing. 40min. Ø 40 18 To obtain a complete unit, please select the red components from the pages shown. 65min. • The colour of anodised aluminium parts can vary due to technical production reasons 50min. 17 Switching element 60min. 14 Product can differ from the current configuration. 65min. 09 A 19 +0.4 Ø22.3 0 B C D Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 45 51 Actuator, Front dimension Ø 40 mm Switching action Momentary 56 57 61 Maintained 70 71 Front bezel colour Front bezel material Front bezel surface Lens colour Lens material Housing colour Housing material Part No. Wiring diagram Grey Plastic Black Plastic Grey Plastic 704.070.0 72 Grey Plastic Red Plastic Grey Plastic 704.070.2 72 Grey Plastic Yellow Plastic Grey Plastic 704.070.4 72 Grey Plastic Green Plastic Grey Plastic 704.070.5 72 Nature Aluminium anodised Black Plastic Grey Plastic 704.071.0 72 Nature Aluminium anodised Red Plastic Grey Plastic 704.071.2 72 Nature Aluminium anodised Yellow Plastic Grey Plastic 704.071.4 72 Nature Aluminium anodised Green Plastic Grey Plastic 704.071.5 72 Nature Aluminium anodised Grey Plastic Grey Plastic Nature Aluminium anodised Red Aluminium Grey Plastic 704.079.2 72 Black Plastic Grey Plastic 704.072.0 73 Red Plastic Grey Plastic 704.072.2 73 Black Plastic Grey Plastic 704.073.0 73 Nature Aluminium anodised Red Plastic Grey Plastic 704.073.2 73 Nature Aluminium anodised Yellow Plastic Grey Plastic 704.073.4 73 Nature Aluminium anodised Green Plastic Grey Plastic 704.073.5 73 Nature Aluminium anodised Red Aluminium Grey Plastic 704.075.2I 73 82 84 92 96 130 eao.com § 08/2022 Raised design 04 Wiring diagrams 01 02 03 04 Wiring diagram 72 Wiring diagram 73 09 14 17 18 19 22 31 41 45 51 56 57 61 Modern. Tactile and long-lasting. Series 04 illuminated selector switches. 70 71 Intuitive and reliable operation for enhanced safety in public transportation. . Bright, single or bi-colour LED illumination . Modern, ergonomic design . Rounded edges (in accordance with DIN 5566-1) . Excellent tactile feedback . Long service life and robust construction . Wide range of possible combinations and options 82 84 92 www.eao.com 08/2022 § eao.com 96 ​ 131 04 Raised design Mushroom-head pushbutton illuminated, IP65 69 25 02 03 Equipment consisting of (schematic overview) 23 Actuator A A 37 01 04 Bayonet flange 2 …7 09 14 Product can differ from the current configuration. Dimensions [mm] A = Screw terminal Page 204 General information 35min. • Max. 3 switching elements can be clipped on • The lamp block will be delivered with screw terminal Lamp block 50min. 17 LED 18 Ø30.5 19 A Switching element +0.5 0 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal 22 Page 213 31 41 45 Actuator, Front dimension Ø 40 mm Switching action Front bezel colour Front bezel material Lens colour Lens material Housing colour Housing material Part No. Wiring diagram Momentary Grey Plastic Red Plastic Grey Plastic 704.084.2 74 Grey Plastic Yellow Plastic Grey Plastic 704.084.4 74 Grey Plastic Green Plastic Grey Plastic 704.084.5 74 Grey Plastic Blue Plastic Grey Plastic 704.084.6 74 Grey Plastic Colourless Plastic Grey Plastic 704.084.7 74 Grey Plastic Red Plastic Grey Plastic 704.086.2 75 Grey Plastic Yellow Plastic Grey Plastic 704.086.4 75 Grey Plastic Green Plastic Grey Plastic 704.086.5 75 51 56 Maintained 57 61 Wiring diagrams 70 X2+ X2+ X1- X1- 71 82 Wiring diagram 74 Wiring diagram 75 84 92 96 132 eao.com § 08/2022 Raised design 04 Selector switch illuminated, 2 positions, short lever, square, IP65 01 Equipment consisting of (schematic overview) 27 28.5 15.5 23 23 A A 02 Actuator Bayonet flange 37 03 04 2 …7 LED Page 204 Lamp block Page 210 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information A 30 min. • Max. 3 switching elements can be clipped on Page 213 B Each Part Number listed below includes all the black components shown in the 3D-drawing. 65 min. Switching element 50 min. 17 C D 18 +0.4 0 19 Ø22.3 To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 0 0 22 31 I 41 I 45 Actuator, Front dimension 30 mm x 30 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained Grey Plastic 90° right 704.510.0i 85 Rest - Momentary Grey Plastic 42° right 704.512.0i 84 51 56 57 Wiring diagrams x2+ 61 x2+ 70 x1- Wiring diagram 84 x1- 71 82 Wiring diagram 85 84 92 96 08/2022 § eao.com 133 04 Raised design Selector switch illuminated, 2 positions, short lever, round, IP65 Equipment consisting of (schematic overview) 02 27 28.5 15.5 03 04 23 23 A A Actuator 37 01 2 …7 Bayonet flange Dimensions [mm] A = Screw terminal • Max. 3 switching elements can be clipped on 17 Page 204 Lamp block Page 210 Switching element Page 213 A 30 min. • The colour of anodised aluminium parts can vary due to technical production reasons 18 B C D +0.4 0 19 Ø22.3 Each Part Number listed below includes all the black components shown in the 3D-drawing. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 LED General information 65 min. 14 Product can differ from the current configuration. 50 min. 09 0 0 I 0 To obtain a complete unit, please select the red components from the pages shown. I I 45 Actuator, Front dimension Ø 29 mm 51 56 57 61 Part No. Wiring diagram 90° right 704.410.0i 85 90° right (-45° … +45°) 704.410.1i 85 Switching action Front bezel colour Front bezel material Switching angle Rest - Maintained Grey Plastic Grey Plastic Nature Aluminium 90° right Grey Plastic 42° right Nature Aluminium 42° right Rest - Momentary Front bezel surface anodised anodised 704.411.0i 85 704.412.0i 84 704.413.0i 84 Wiring diagrams 70 x2+ x2+ x1- x1- 71 82 84 Wiring diagram 84 Wiring diagram 85 92 96 134 eao.com § 08/2022 Raised design 04 Selector switch 2 positions, short lever, square, IP65 Equipment consisting of (schematic overview) 28.5 27 01 23 23 A A 02 Actuator 37 03 04 Bayonet flange 2 …7 Switching element Page 213 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information Each Part Number listed below includes all the black components shown in the 3D-drawing. A 30 min. • Max. 3 switching elements can be clipped on 65 min. B 50 min. 17 To obtain a complete unit, please select the red components from the pages shown. C D 18 +0.4 0 19 Ø22.3 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 0 I 0 22 31 I 41 45 Actuator, Front dimension 30 mm x 30 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained Grey Plastic 90° right 704.510.0 87 Rest - Momentary Grey Plastic 42° right 704.512.0 86 51 56 57 Wiring diagrams 61 70 71 Wiring diagram 86 82 Wiring diagram 87 84 92 96 08/2022 § eao.com 135 04 Raised design Selector switch 2 positions, short lever, round, IP65 28.5 27 02 03 23 23 A A Equipment consisting of (schematic overview) Actuator 37 01 04 2 …7 Product can differ from the current configuration. Dimensions [mm] A = Screw terminal Switching element • Max. 3 switching elements can be clipped on 17 A 30 min. Each Part Number listed below includes all the black components shown in the 3D-drawing. • The colour of anodised aluminium parts can vary due to technical production reasons 18 B C D To obtain a complete unit, please select the red components from the pages shown. +0.4 Ø22.3 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Page 213 General information 65 min. 14 Bayonet flange 50 min. 09 0 I 0 I 45 Actuator, Front dimension Ø 29 mm 51 56 Switching action Front bezel colour Front bezel material Switching angle Rest - Maintained Grey Plastic 90° right Nature Aluminium 90° right Grey Plastic 42° right Nature Aluminium 42° right Rest - Momentary 57 61 Front bezel surface anodised anodised Part No. Wiring diagram 704.410.0 87 704.411.0 87 704.412.0 86 704.413.0 86 Wiring diagrams 70 71 82 Wiring diagram 86 Wiring diagram 87 84 92 96 136 eao.com § 08/2022 Raised design 04 Selector switch 2 positions, short lever, square, IP65 Equipment consisting of (schematic overview) 27 28.5 01 23 23 A A 02 Actuator 37 03 04 Bayonet flange 2 …7 Switching element Page 213 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information Each Part Number listed below includes all the black components shown in the 3D-drawing. A 30 min. • Max. 3 switching elements can be clipped on 65 min. B 50 min. 17 To obtain a complete unit, please select the red components from the pages shown. C D 18 +0.4 0 19 Ø22.3 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 0 41 I 45 Actuator, Front dimension 30 mm x 30 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained Grey Plastic 90° right 704.510.0.12 87 51 56 Wiring diagrams 57 61 70 71 Wiring diagram 87 82 84 92 96 08/2022 § eao.com 137 04 Raised design Selector switch 2 positions, short lever, round, IP65 27 02 28.5 03 23 23 A A Equipment consisting of (schematic overview) Actuator 37 01 04 2 …7 Product can differ from the current configuration. Dimensions [mm] A = Screw terminal Switching element General information • Max. 3 switching elements can be clipped on 17 Page 213 A 30 min. • The colour of anodised aluminium parts can vary due to technical production reasons 18 B 65 min. 14 Bayonet flange 50 min. 09 C D Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. +0.4 Ø22.3 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 0 41 I 45 Actuator, Front dimension Ø 29 mm 51 56 Switching action Front bezel colour Front bezel material Switching angle Front bezel surface Rest - Maintained Grey Plastic 90° right Nature Aluminium 90° right anodised Nature Aluminium 90° right anodised Part No. Wiring diagram 704.410.0.12 87 704.411.0.12 87 704.411.0B.12 87 57 Wiring diagrams 61 70 71 82 Wiring diagram 87 84 92 96 138 eao.com § 08/2022 Raised design 04 Selector switch illuminated, 2 positions, long lever, square, IP65 01 Equipment consisting of (schematic overview) 27 28.5 15.5 23 23 A A 02 Actuator 20 37 03 Bayonet flange 04 2 …7 LED Page 204 Lamp block Page 210 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information A NJO • Max. 3 switching elements can be clipped on Page 213 B Each Part Number listed below includes all the black components shown in the 3D-drawing. PLQ Switching element PLQ 17 C D 18  19 ±  To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 0 0 22 31 I 41 I 45 Actuator, Front dimension 30 mm x 30 mm 51 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained Grey Plastic 90° right 704.300.0i 85 Rest - Momentary Grey Plastic 42° right 704.302.0i 84 56 57 Wiring diagrams x2+ 61 x2+ 70 x1- Wiring diagram 84 71 x1- 82 Wiring diagram 85 84 92 96 08/2022 § eao.com 139 04 Raised design Selector switch illuminated, 2 positions, long lever, round, IP65 Equipment consisting of (schematic overview) 02 27 28.5 15.5 23 A A Actuator 20 03 23 37 01 04 2 …7 Bayonet flange Dimensions [mm] A = Screw terminal • Max. 3 switching elements can be clipped on 17 Page 204 Lamp block Page 210 Switching element Page 213 A NJO • The colour of anodised aluminium parts can vary due to technical production reasons 18 B C D  19 ±  Each Part Number listed below includes all the black components shown in the 3D-drawing. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 LED General information PLQ 14 Product can differ from the current configuration. PLQ 09 0 0 To obtain a complete unit, please select the red components from the pages shown. I I 45 51 56 57 61 Actuator, Front dimension Ø 29 mm Switching action Front bezel colour Front bezel material Switching angle Rest - Maintained Grey Plastic 90° right Nature Aluminium 90° right Grey Plastic 42° right Nature Aluminium 42° right Rest - Momentary Front bezel surface anodised anodised Part No. Wiring diagram 704.100.0i 85 704.101.0i 85 704.102.0i 84 704.103.0i 84 Wiring diagrams 70 x2+ x2+ x1- x1- 71 82 84 Wiring diagram 84 Wiring diagram 85 92 96 140 eao.com § 08/2022 Raised design 04 Selector switch 2 positions, long lever, square, IP65 Equipment consisting of (schematic overview) 01 28.5 27 23 23 A A 02 Actuator 25 37 03 04 Bayonet flange 2 …7 Switching element Page 213 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information Each Part Number listed below includes all the black components shown in the 3D-drawing. A NJO • Max. 3 switching elements can be clipped on PLQ B PLQ 17 To obtain a complete unit, please select the red components from the pages shown. C D 18  19 ±  Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 0 I 0 22 31 I 41 45 51 Actuator, Front dimension 30 mm x 30 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained Grey Plastic 90° right 704.300.0 87 Rest - Momentary Grey Plastic 42° right 704.302.0 86 56 57 Wiring diagrams 61 70 71 Wiring diagram 86 82 Wiring diagram 87 84 92 96 08/2022 § eao.com 141 04 Raised design Selector switch 2 positions, long lever, round, IP65 28.5 27 02 23 A A Equipment consisting of (schematic overview) Actuator 25 03 23 37 01 04 2 …7 Dimensions [mm] A = Screw terminal A NJO • The colour of anodised aluminium parts can vary due to technical production reasons 18 B C D Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown.  ±  19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Page 213 General information • Max. 3 switching elements can be clipped on 17 Switching element PLQ 14 Product can differ from the current configuration. PLQ 09 Bayonet flange 0 I 0 I 45 Actuator, Front dimension Ø 29 mm 51 56 57 61 Switching action Front bezel colour Front bezel material Switching angle Rest - Maintained Grey Plastic 90° right Nature Aluminium 90° right Grey Plastic 42° right Nature Aluminium 42° right Rest - Momentary Front bezel surface anodised anodised Part No. Wiring diagram 704.100.0 87 704.101.0 87 704.102.0 86 704.103.0 86 Wiring diagrams 70 71 82 84 Wiring diagram 86 Wiring diagram 87 92 96 142 eao.com § 08/2022 Raised design 04 Selector switch 2 positions, long lever, square, IP65 Equipment consisting of (schematic overview) 27 28.5 01 23 23 A A 02 Actuator 25 37 03 04 Bayonet flange 2 …7 Switching element Page 213 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information Each Part Number listed below includes all the black components shown in the 3D-drawing. A NJO • Max. 3 switching elements can be clipped on PLQ B PLQ 17 To obtain a complete unit, please select the red components from the pages shown. C D 18  19 ±  Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 0 41 I 45 Actuator, Front dimension 30 mm x 30 mm 51 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained Grey Plastic 90° right 704.300.0.12 87 56 57 Wiring diagrams 61 70 71 Wiring diagram 87 82 84 92 96 08/2022 § eao.com 143 04 Raised design Selector switch 2 positions, long lever, round, IP65 27 02 28.5 23 A A Equipment consisting of (schematic overview) Actuator 25 03 23 37 01 04 2 …7 Dimensions [mm] A = Screw terminal Switching element • Max. 3 switching elements can be clipped on 17 Page 213 General information A NJO Each Part Number listed below includes all the black components shown in the 3D-drawing. • The colour of anodised aluminium parts can vary due to technical production reasons 18 B PLQ 14 Product can differ from the current configuration. PLQ 09 Bayonet flange C D To obtain a complete unit, please select the red components from the pages shown.  ±  19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 0 41 I 45 Actuator, Front dimension Ø 29 mm 51 56 57 Switching action Front bezel colour Front bezel material Switching angle Rest - Maintained Grey Plastic 90° right Nature Aluminium 90° right Front bezel surface anodised Part No. Wiring diagram 704.100.0.12 87 704.101.0.12 87 Wiring diagrams 61 70 71 82 Wiring diagram 87 84 92 96 144 eao.com § 08/2022 Raised design 04 Selector switch illuminated, 3 positions, short lever, square, IP65 01 Equipment consisting of (schematic overview) 27 28.5 15.5 23 23 A A 02 Actuator Bayonet flange 37 03 04 2 …7 LED Page 204 Lamp block Page 210 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information A 30 min. • Max. 3 switching elements can be clipped on Page 213 B Each Part Number listed below includes all the black components shown in the 3D-drawing. 65 min. Switching element 50 min. 17 C D 18 +0.4 0 19 Ø22.3 To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm I 0 II I 0 II I 0 II I 0 22 31 II 41 45 Actuator, Front dimension 30 mm x 30 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Maintained - Rest - Maintained Grey Plastic 42° left / 42° right 704.502.0i 91 Momentary - Rest - Momentary Grey Plastic 42° left / 42° right 704.504.0i 90 Maintained - Rest - Momentary Grey Plastic 42° left / 42° right 704.506.0i 89 Momentary - Rest - Maintained Grey Plastic 42° left / 42° right 704.508.0i 88 51 56 57 Wiring diagrams 61 x2+ x2+ 70 x2+ 71 x1- x1- x1- 82 Wiring diagram 88 Wiring diagram 89 Wiring diagram 90 84 92 96 08/2022 § eao.com 145 04 Raised design 01 Wiring diagrams x2+ 02 03 x1- 04 Wiring diagram 91 09 14 17 18 19 22 31 41 45 51 EAO Downloads. www.eao.com/downloads 56 EAO creates possibilities. Since 1947. 57 61 70 71 On our website you can download technical data, assembly instructions, catalogs, brochures and much more. 82 84 92 www.eao.com 96 146 ​ eao.com § 08/2022 Raised design 04 Selector switch illuminated, 3 positions, short lever, round, IP65 01 Equipment consisting of (schematic overview) 28.5 15.5 Actuator 23 23 A A 02 03 37 27 04 2 …7 Bayonet flange LED Page 204 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information A Switching element Page 213 B I 0 II I 0 II I 0 II I 0 C D • Max. 3 switching elements can be clipped on • The colour of anodised aluminium parts can vary due to technical production reasons 17 18 +0.4 0 19 Ø22.3 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 65 min. Page 210 50 min. 30 min. Lamp block Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 II 41 45 Actuator, Front dimension Ø 29 mm Switching action Front bezel colour Front bezel material Switching angle Maintained - Rest - Maintained Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Momentary - Rest - Momentary Maintained - Rest - Momentary Momentary - Rest - Maintained Front bezel surface anodised anodised anodised anodised Part No. Wiring diagram 704.402.0i 91 704.403.0i 91 704.404.0i 90 704.405.0i 90 704.406.0i 89 704.407.0i 89 704.408.0i 88 704.409.0i 88 51 56 57 61 70 Wiring diagrams 71 x2+ x2+ x2+ 82 x1- Wiring diagram 88 x1- Wiring diagram 89 84 x1- 92 Wiring diagram 90 96 08/2022 § eao.com 147 04 Raised design 01 Wiring diagrams x2+ 02 03 x1- 04 Wiring diagram 91 09 14 17 18 19 22 31 41 45 51 56 57 61 Modern. Tactile and long-lasting. Series 04 illuminated selector switches. 70 71 Intuitive and reliable operation for enhanced safety in public transportation. . Bright, single or bi-colour LED illumination . Modern, ergonomic design . Rounded edges (in accordance with DIN 5566-1) . Excellent tactile feedback . Long service life and robust construction . Wide range of possible combinations and options 82 84 92 www.eao.com 96 148 ​ eao.com § 08/2022 Raised design 04 Selector switch 3 positions, short lever, square, IP65 Equipment consisting of (schematic overview) 28.5 27 01 23 23 A A 02 Actuator 37 03 04 Bayonet flange 2 …7 Switching element Page 213 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information Each Part Number listed below includes all the black components shown in the 3D-drawing. A 30 min. • Max. 3 switching elements can be clipped on 65 min. B 50 min. 17 To obtain a complete unit, please select the red components from the pages shown. C D 18 +0.4 0 19 Ø22.3 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm I 0 II I 0 II I 0 II I 0 22 31 II 41 45 Actuator, Front dimension 30 mm x 30 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Maintained - Rest - Maintained Grey Plastic 42° left / 42° right 704.502.0 95 Momentary - Rest - Momentary Grey Plastic 42° left / 42° right 704.504.0 94 Maintained - Rest - Momentary Grey Plastic 42° left / 42° right 704.506.0 93 Momentary - Rest - Maintained Grey Plastic 42° left / 42° right 704.508.0 92 51 56 57 61 Wiring diagrams 70 71 82 Wiring diagram 92 Wiring diagram 93 Wiring diagram 94 Wiring diagram 95 84 92 96 08/2022 § eao.com 149 04 Raised design Selector switch 3 positions, short lever, round, IP65 28.5 27 02 03 23 23 A A Equipment consisting of (schematic overview) Actuator 37 01 04 2 …7 Bayonet flange Product can differ from the current configuration. 14 Dimensions [mm] A = Screw terminal Switching element • Max. 3 switching elements can be clipped on A 30 min. Each Part Number listed below includes all the black components shown in the 3D-drawing. • The colour of anodised aluminium parts can vary due to technical production reasons 18 B 65 min. 17 C D To obtain a complete unit, please select the red components from the pages shown. +0.4 Ø22.3 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Page 213 General information 50 min. 09 I 0 II I 0 II I 0 II I 0 II 45 Actuator, Front dimension Ø 29 mm 51 56 Switching action Front bezel colour Front bezel material Switching angle Maintained - Rest - Maintained Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Momentary - Rest - Momentary 57 61 70 Maintained - Rest - Momentary Momentary - Rest - Maintained Front bezel surface anodised anodised anodised anodised Part No. Wiring diagram 704.402.0 95 704.403.0 95 704.404.0 94 704.405.0 94 704.406.0 93 704.407.0 93 704.408.0 92 704.409.0 92 Wiring diagrams 71 82 84 92 Wiring diagram 92 Wiring diagram 93 Wiring diagram 94 Wiring diagram 95 96 150 eao.com § 08/2022 Raised design 04 Selector switch illuminated, 3 positions, long lever, square, IP65 01 Equipment consisting of (schematic overview) 27 28.5 15.5 23 23 A A 02 Actuator 20 37 03 Bayonet flange 04 2 …7 LED Page 204 Lamp block Page 210 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information A NJO • Max. 3 switching elements can be clipped on Page 213 B Each Part Number listed below includes all the black components shown in the 3D-drawing. PLQ Switching element PLQ 17 C D 18  19 ±  To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm I 0 II I 0 II I 0 II I 0 22 31 II 41 45 Actuator, Front dimension 30 mm x 30 mm 51 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Maintained - Rest - Maintained Grey Plastic 42° left / 42° right 704.292.0i 91 Momentary - Rest - Momentary Grey Plastic 42° left / 42° right 704.294.0i 90 Maintained - Rest - Momentary Grey Plastic 42° left / 42° right 704.296.0i 89 Momentary - Rest - Maintained Grey Plastic 42° left / 42° right 704.298.0i 88 56 57 61 Wiring diagrams x2+ x2+ 70 x2+ 71 x1- Wiring diagram 88 x1- Wiring diagram 89 x1- 82 Wiring diagram 90 84 92 96 08/2022 § eao.com 151 04 Raised design 01 Wiring diagrams x2+ 02 03 x1- 04 Wiring diagram 91 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 152 ​ eao.com § 08/2022 Raised design 04 Selector switch illuminated, 3 positions, long lever, round, IP65 01 Equipment consisting of (schematic overview) 28.5 15.5 23 A A 02 03 20 Actuator 23 37 27 04 2 …7 Bayonet flange LED Page 204 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information A Switching element Page 213 B PLQ Page 210 PLQ NJO Lamp block C D • Max. 3 switching elements can be clipped on • The colour of anodised aluminium parts can vary due to technical production reasons 18  To obtain a complete unit, please select the red components from the pages shown. I 0 II I 0 II I 0 II I 0 19 ±  Each Part Number listed below includes all the black components shown in the 3D-drawing. 17 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 II 41 45 Actuator, Front dimension Ø 29 mm 51 Switching action Front bezel colour Front bezel material Switching angle Maintained - Rest - Maintained Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Momentary - Rest - Momentary Maintained - Rest - Momentary Momentary - Rest - Maintained Front bezel surface anodised anodised anodised anodised Part No. Wiring diagram 704.092.0i 91 704.093.0i 91 704.094.0i 90 704.095.0i 90 704.096.0i 89 704.097.0i 89 704.098.0i 88 704.099.0i 88 56 57 61 70 Wiring diagrams 71 x2+ x2+ x2+ 82 x1- Wiring diagram 88 x1- Wiring diagram 89 84 x1- 92 Wiring diagram 90 96 08/2022 § eao.com 153 04 Raised design 01 Wiring diagrams x2+ 02 03 x1- 04 Wiring diagram 91 09 14 17 18 19 22 31 41 45 51 Follow us. We are on LinkedIn! 56 EAO creates possibilities. Since 1947. 57 61 70 71 Come take a look at our LinkedIn profi le today! Be sure to give us a follow so that you can fully interact with us. 82 https://www.linkedin.com/company/eao/ 84 92 www.eao.com 96 154 ​ eao.com § 08/2022 Raised design 04 Selector switch 3 positions, long lever, square, IP65 Equipment consisting of (schematic overview) 28.5 27 01 23 23 A A 02 Actuator 25 37 03 04 Bayonet flange 2 …7 Switching element Page 213 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information Each Part Number listed below includes all the black components shown in the 3D-drawing. A NJO • Max. 3 switching elements can be clipped on PLQ B PLQ 17 To obtain a complete unit, please select the red components from the pages shown. C D 18  19 ±  Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm I 0 II I 0 II I 0 II I 0 22 31 II 41 45 51 Actuator, Front dimension 30 mm x 30 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Maintained - Rest - Maintained Grey Plastic 42° left / 42° right 704.292.0 95 Momentary - Rest - Momentary Grey Plastic 42° left / 42° right 704.294.0 94 Maintained - Rest - Momentary Grey Plastic 42° left / 42° right 704.296.0 93 Momentary - Rest - Maintained Grey Plastic 42° left / 42° right 704.298.0 92 56 57 61 Wiring diagrams 70 71 82 Wiring diagram 92 Wiring diagram 93 Wiring diagram 94 84 Wiring diagram 95 92 96 08/2022 § eao.com 155 04 Raised design Selector switch 3 positions, long lever, round, IP65 28.5 27 02 23 A A Equipment consisting of (schematic overview) Actuator 25 03 23 37 01 04 2 …7 Product can differ from the current configuration. 14 Dimensions [mm] A = Screw terminal Switching element • Max. 3 switching elements can be clipped on A NJO • The colour of anodised aluminium parts can vary due to technical production reasons 18 B PLQ 17 C D Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown.  ±  19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Page 213 General information PLQ 09 Bayonet flange I 0 II I 0 II I 0 II I 0 II 45 Actuator, Front dimension Ø 29 mm 51 56 57 Switching action Front bezel colour Front bezel material Switching angle Maintained - Rest - Maintained Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Grey Plastic 42° left / 42° right Nature Aluminium 42° left / 42° right Momentary - Rest - Momentary Maintained - Rest - Momentary 61 Momentary - Rest - Maintained 70 71 Front bezel surface anodised anodised anodised anodised Part No. Wiring diagram 704.092.0 95 704.093.0 95 704.094.0 94 704.095.0 94 704.096.0 93 704.097.0 93 704.098.0 92 704.099.0 92 Wiring diagrams 82 84 92 Wiring diagram 92 Wiring diagram 93 Wiring diagram 94 Wiring diagram 95 96 156 eao.com § 08/2022 Raised design 04 Selector rotary switch, short lever, rounded, square, IP65 Equipment consisting of (schematic overview) 01 1 27 02 A 12 03 44 Actuator 04 Bayonet flange 09 2 ... 7 Product can differ from the current configuration. Switching element Page 227 2 27 14 B 13.5 17 18 38 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 19 2 ... 7 22 Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66.5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65.5 mm 31 41 NJO PLQ 45 51  ±  56 Mounting cut-outs [mm] 57 61 Actuator, Front dimension 30 mm x 30 mm Front bezel colour Front bezel material Switching positions Part No. Grey Plastic Rest = 9 o‘clock 704.510.1KNI 70 71 82 84 92 96 08/2022 § eao.com 157 04 Raised design 01 Selector rotary switch, short lever rounded, round, IP65 Equipment consisting of (schematic overview) 1 02 27 A 12 03 44 Actuator 04 09 14 17 Bayonet flange 2 ... 7 Product can differ from the current configuration. 2 General information 27 B • The colour of anodised aluminium parts can vary due to technical production reasons Switching element 13.5 38 18 Page 227 Each Part Number listed below includes all the black components shown in the 3D-drawing. 19 To obtain a complete unit, please select the red components from the pages shown. 2 ... 7 22 Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66.5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65.5 mm 31 41 NJO PLQ 45 51  ±  56 Mounting cut-outs [mm] 57 61 70 Actuator, Front dimension Ø 29 mm Front bezel colour Front bezel material Switching positions Front bezel surface Part No. Nature Aluminium Rest = 9 o‘clock anodised 704.411.1KNI 71 82 84 92 96 158 eao.com § 08/2022 Raised design 04 Selector rotary switch, short lever, square, IP65 Equipment consisting of (schematic overview) 01 1 27 02 A 12 03 44 Actuator 04 Bayonet flange 09 2 ... 7 Product can differ from the current configuration. 2 Switching element Page 227 27 14 B 13.5 17 18 38 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 19 2 ... 7 22 Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66.5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65.5 mm 31 41 NJO PLQ 45 51  ±  56 Mounting cut-outs [mm] 57 61 Actuator, Front dimension 30 mm x 30 mm Front bezel colour Front bezel material Switching positions Part No. Grey Plastic Rest = 9 o‘clock 704.510.1KN 70 71 82 84 92 96 08/2022 § eao.com 159 04 Raised design 01 Selector rotary switch, short lever, round, IP65 Equipment consisting of (schematic overview) 1 02 27 A 12 03 44 Actuator 04 09 14 17 Bayonet flange 2 ... 7 Product can differ from the current configuration. 2 General information 27 B • The colour of anodised aluminium parts can vary due to technical production reasons Switching element 13.5 38 18 Page 227 Each Part Number listed below includes all the black components shown in the 3D-drawing. 19 To obtain a complete unit, please select the red components from the pages shown. 2 ... 7 22 Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66.5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65.5 mm 31 41 NJO PLQ 45 51  ±  56 Mounting cut-outs [mm] 57 61 Actuator, Front dimension Ø 29 mm 70 Front bezel colour Front bezel material Switching positions Front bezel surface Part No. Nature Aluminium Rest = 9 o‘clock anodised 704.411.1KN 71 82 84 92 96 160 eao.com § 08/2022 Raised design 04 Selector rotary switch, long lever rounded, square, IP65 Equipment consisting of (schematic overview) 01 1 27 02 A 12 03 31.5 44 Actuator 04 Bayonet flange 2 ... 7 2 Switching element Page 227 09 Product can differ from the current configuration. 27 14 B 13.5 31.5 Each Part Number listed below includes all the black components shown in the 3D-drawing. 38 17 To obtain a complete unit, please select the red components from the pages shown. 18 2 ... 7 19 22 Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66.5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65.5 mm 31 41 NJO PLQ 45 51  ±  56 Mounting cut-outs [mm] 57 61 Actuator, Front dimension 30 mm x 30 mm Front bezel colour Front bezel material Switching positions Part No. Grey Plastic Rest = 9 o‘clock 704.300.1KNI 70 71 82 84 92 96 08/2022 § eao.com 161 04 Raised design 01 Selector rotary switch, long lever rounded, round, IP65 Equipment consisting of (schematic overview) 1 02 27 A 12 03 31.5 04 17 Product can differ from the current configuration. 2 27 General information B 13.5 • The colour of anodised aluminium parts can vary due to technical production reasons 18 Page 227 Each Part Number listed below includes all the black components shown in the 3D-drawing. 2 ... 7 19 22 Switching element 38 14 Bayonet flange 2 ... 7 31.5 09 44 Actuator To obtain a complete unit, please select the red components from the pages shown. Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66.5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65.5 mm 31 41 NJO PLQ 45 51  ±  56 Mounting cut-outs [mm] 57 61 70 Actuator, Front dimension Ø 29 mm Front bezel colour Front bezel material Switching positions Front bezel surface Part No. Nature Aluminium Rest = 9 o‘clock anodised 704.101.1KNI 71 82 84 92 96 162 eao.com § 08/2022 Raised design 04 Selector rotary switch, long lever, square, IP65 Equipment consisting of (schematic overview) 01 1 27 02 A 12 03 44 Actuator 04 25 Bayonet flange 2 ... 7 2 Switching element 27 Page 227 09 Product can differ from the current configuration. 14 B 13.5 18 25 Each Part Number listed below includes all the black components shown in the 3D-drawing. 38 17 To obtain a complete unit, please select the red components from the pages shown. 2 ... 7 19 22 Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66.5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65.5 mm 31 41 NJO PLQ 45 51  ±  56 Mounting cut-outs [mm] 57 61 Actuator, Front dimension 30 mm x 30 mm 70 Front bezel colour Front bezel material Switching positions Part No. Grey Plastic Rest = 9 o‘clock 704.300.1KN 71 82 84 92 96 08/2022 § eao.com 163 04 Raised design 01 Selector rotary switch, long lever, round, IP65 Equipment consisting of (schematic overview) 1 02 27 A 12 03 44 Actuator 09 14 Bayonet flange 2 ... 7 Product can differ from the current configuration. 2 27 General information B 13.5 • The colour of anodised aluminium parts can vary due to technical production reasons Switching element Page 227 38 17 25 04 25 18 Each Part Number listed below includes all the black components shown in the 3D-drawing. 2 ... 7 19 22 To obtain a complete unit, please select the red components from the pages shown. Dimensions [mm] 1 = Kraus & Naimer switching element A = (Number of stages x 12) + 66.5 mm 2 = Santon switching element B = (Number of stages x 13,5) + 65.5 mm 31 41 NJO PLQ 45 51  ±  56 Mounting cut-outs [mm] 57 61 Actuator, Front dimension Ø 29 mm 70 71 Front bezel colour Front bezel material Switching positions Front bezel surface Part No. Nature Aluminium Rest = 12 o‘clock anodised 704.101.0KN Aluminium Rest = 9 o‘clock anodised 704.101.1KN 82 84 92 96 164 eao.com § 08/2022 Raised design 04 Keylock switch 2 positions, square, IP65 23 21 53 Actuator 23 A A 02 03 37 Equipment consisting of (schematic overview) 01 04 2 …7 Bayonet flange Switching element Page 213 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information A 30 min. Each Part Number listed below includes all the black components shown in the 3D-drawing. • Max. 3 switching elements can be clipped on 17 65 min. B 50 min. • The standard lock Ronis 251 To obtain a complete unit, please select the red components from the pages shown. C D 18 +0.4 0 19 Ø22.3 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 0 I 0 22 31 I 41 45 Actuator, Front dimension 30 mm x 30 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained (a) Grey Plastic 90° right 704.340.0 79 Rest (a) - Maintained Grey Plastic 90° right 704.341.0 79 Rest (a) - Maintained (a) Grey Plastic 90° right 704.342.0 79 Rest (a) - Momentary Grey Plastic 42° right 704.343.0 78 51 56 57 a = Key remove 61 Wiring diagrams 70 71 82 Wiring diagram 78 84 Wiring diagram 79 92 96 08/2022 § eao.com 165 04 Raised design Keylock switch 2 positions, round, IP65 23 02 21 53 03 Equipment consisting of (schematic overview) 23 A A 37 01 Actuator 04 2 …7 General information • Max. 3 switching elements can be clipped on 17 18 Bayonet flange Dimensions [mm] A = Screw terminal Page 213 • The standard lock Ronis 251 • The colour of anodised aluminium parts can vary due to technical production reasons B C D Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. +0.4 0 19 Ø22.3 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Switching element A 30 min. 65 min. 14 Product can differ from the current configuration. 50 min. 09 0 I 0 I 45 Actuator, Front dimension Ø 29 mm 51 56 57 61 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Rest - Maintained (a) Nature Aluminium 90° right 704.120.0 79 Rest (a) - Maintained Nature Aluminium 90° right 704.121.0 79 Rest (a) - Maintained (a) Nature Aluminium 90° right 704.122.0 79 Rest (a) - Momentary Nature Aluminium 42° right 704.123.0 78 a = Key remove Wiring diagrams 70 71 82 84 Wiring diagram 78 Wiring diagram 79 92 96 166 eao.com § 08/2022 Raised design 04 Keylock switch 3 positions, square, IP65 23 21 53 Actuator 23 A A 02 03 37 Equipment consisting of (schematic overview) 01 04 2 …7 Bayonet flange Switching element Page 213 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information A 30 min. Each Part Number listed below includes all the black components shown in the 3D-drawing. • Max. 3 switching elements can be clipped on 17 65 min. B 50 min. • The standard lock Ronis 251 To obtain a complete unit, please select the red components from the pages shown. C D 18 +0.4 0 19 Ø22.3 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 0 I I 0 II I 0 II I 0 22 31 II 41 II 45 Actuator, Front dimension 30 mm x 30 mm Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Maintained (a) - Rest (a) - Maintained (a) Grey Plastic 90° left / 90° right 704.333.0 83 Maintained - Rest (a) - Maintained Grey Plastic 42° left / 42° right 704.334.0 83 Momentary - Rest (a) - Momentary Grey Plastic 42° left / 42° right 704.335.0 82 Maintained (a) - Rest - Momentary Grey Plastic 42° left / 42° right 704.337.0 81 Maintained (a) - Rest (a) - Momentary Grey Plastic 42° left / 42° right 704.344.0 81 51 56 57 a = Key remove 61 Wiring diagrams 70 71 82 Wiring diagram 81 Wiring diagram 82 84 Wiring diagram 83 92 96 08/2022 § eao.com 167 04 Raised design Keylock switch 3 positions, round, IP65 23 02 21 53 Equipment consisting of (schematic overview) 23 03 A A 37 01 Actuator 04 2 …7 Product can differ from the current configuration. 14 Bayonet flange Dimensions [mm] A = Screw terminal General information • Max. 3 switching elements can be clipped on 17 Page 213 • The colour of anodised aluminium parts can vary due to technical production reasons B 65 min. • The standard lock Ronis 251 18 C D Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. +0.4 0 19 Ø22.3 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 0 41 Switching element A 30 min. 50 min. 09 I I 0 II I 0 II I 0 II I 0 II II 45 Actuator, Front dimension Ø 29 mm 51 56 57 61 Switching action Front bezel colour Front bezel material Switching angle Part No. Wiring diagram Maintained (a) - Rest (a) - Maintained (a) Nature Aluminium 90° left / 90° right 704.113.0 83 Maintained - Rest (a) - Maintained Nature Aluminium 42° left / 42° right 704.114.0 83 Momentary - Rest (a) - Momentary Nature Aluminium 42° left / 42° right 704.115.0 82 Maintained (a) - Rest - Maintained (a) Nature Aluminium 42° left / 42° right 704.116.0 83 Maintained (a) - Rest - Momentary Nature Aluminium 42° left / 42° right 704.117.0 81 Momentary - Rest (a) - Maintained Nature Aluminium 42° left / 42° right 704.118.0 80 Maintained (a) - Rest (a) - Momentary Nature Aluminium 42° left / 42° right 704.124.0 81 a = Key remove 70 Wiring diagrams 71 82 84 92 Wiring diagram 80 Wiring diagram 81 Wiring diagram 82 Wiring diagram 83 96 168 eao.com § 08/2022 Raised design 04 Indicator full-face illumination compact, round, IP65 Equipment consisting of (schematic overview) 01 52 13 02 Lens cap 03 Marking cap 04 LED 2 ... 7 Page 204 Dimensions [mm] 09 Product can differ from the current configuration. 14 Actuator NJO PLQ 17 18 Fixing nut  ±  19 Mounting cut-outs [mm] 22 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 31 41 Actuator, Front dimension Ø 29 mm Product attributes Housing colour Housing material Lens cap colour Marking cap colour Part No. Wiring diagram Filament lamp max. 2.6 W or LED Grey 4 Filament lamp 130 V, max. 2.6 W with integrated series resistor 230/130 V Plastic Red White 704.020.2 Grey Plastic Yellow White 704.020.4 4 Grey Plastic Green White 704.020.5 4 Grey Plastic Blue White 704.020.6 4 Grey Plastic Colourless White 704.020.7 4 Grey Plastic Red Colourless 704.021.2 4 Grey Plastic Yellow Colourless 704.021.4 4 Grey Plastic Green Colourless 704.021.5 4 Grey Plastic Blue Colourless 704.021.6 4 Grey Plastic Colourless Colourless 704.021.7 4 Grey Plastic Red White 704.022.2 105 Grey Plastic Yellow White 704.022.4 105 Grey Plastic Green White 704.022.5 105 Grey Plastic Blue White 704.022.6 105 Grey Plastic Colourless White 704.022.7 105 45 51 56 57 61 70 71 82 84 92 96 08/2022 § eao.com 169 04 Raised design 01 Wiring diagrams x2+ X2+ x1- X1 - Wiring diagram 4 Wiring diagram 105 02 03 04 09 14 17 18 19 22 31 41 45 51 EAO Downloads. www.eao.com/downloads 56 EAO creates possibilities. Since 1947. 57 61 70 71 On our website you can download technical data, assembly instructions, catalogs, brochures and much more. 82 84 92 www.eao.com 96 170 ​ eao.com § 08/2022 Raised design 04 Indicator full-face illumination compact, round, IP65 Equipment consisting of (schematic overview) Lens cap 01 52 13 02 Page 200 03 Marking cap Page 201 04 LED 2 ... 7 Page 204 Dimensions [mm] 09 Product can differ from the current configuration. 14 Actuator NJO PLQ 17 18 Fixing nut  ±  19 Mounting cut-outs [mm] 22 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 31 41 Actuator, Front dimension Ø 29 mm Product attributes Housing colour Housing material Part No. Wiring diagram Without built-in series resistor Grey Plastic 704.642.0 4 With series resistor for 220/240 V and filament lamp 130 V, 20 mA Grey Plastic 704.642.1 105 With series resistor for 110/125 V and filament lamp 60 V, 33 mA Grey Plastic 704.642.2 105 45 51 56 Wiring diagrams x2+ 57 X2+ 61 x1- X1 - Wiring diagram 4 Wiring diagram 105 70 71 82 84 92 96 08/2022 § eao.com 171 04 Raised design 01 Indicator full-face illumination, square, IP65 13 02 Equipment consisting of (schematic overview) 46 Lens cap 40 03 Diffusor cap 04 2…7 09 Actuator Product can differ from the current configuration. Dimensions [mm] 14 Bayonet flange 30 min. 17 50 min. LED 18 Page 204 Lamp block +0.4 0 Ø22.3 19 Each Part Number listed below includes all the black components shown in the 3D-drawing. Mounting cut-outs [mm] 22 To obtain a complete unit, please select the red components from the pages shown. 31 41 Actuator, Front dimension 30 mm x 30 mm 45 Housing colour 51 Grey 56 57 61 70 Front bezel colour Lens cap colour Marking cap colour Diffusor cap colour Part No. Wiring diagram Plastic Black Red White White 704.199.2 4 Plastic Black Yellow White White 704.199.4 4 Plastic Black Green White White 704.199.5 4 Plastic Black Colourless White White 704.199.7 4 Plastic Grey Red White White 704.200.2 4 Plastic Grey Yellow White White 704.200.4 4 Plastic Grey Green White White 704.200.5 4 Plastic Grey Blue White White 704.200.6 4 Plastic Grey Colourless White White 704.200.7 4 Wiring diagrams x2+ 71 82 84 Housing material x1- Wiring diagram 4 92 96 172 eao.com § 08/2022 Raised design 04 Indicator full-face illumination, round, IP65 Equipment consisting of (schematic overview) 01 13 46 02 Lens cap 40 03 Marking cap 04 2…7 Actuator Dimensions [mm] 09 Product can differ from the current configuration. 14 Bayonet flange 30 min. 17 Page 204 50 min. LED Lamp block 18 +0.4 0 Ø22.3 Each Part Number listed below includes all the black components shown in the 3D-drawing. 19 Mounting cut-outs [mm] 22 To obtain a complete unit, please select the red components from the pages shown. 31 41 Actuator, Front dimension Ø 29 mm Wiring diagram Housing colour Housing material Lens cap colour Marking cap colour Diffusor cap colour Part No. Grey Plastic Red White White 704.000.2 4 Plastic Yellow White White 704.000.4 4 Plastic Green White White 704.000.5 4 Plastic Blue White White 704.000.6 4 Plastic Colourless White White 704.000.7 4 Plastic Red Colourless White 704.001.2 4 Plastic Yellow Colourless White 704.001.4 4 Plastic Green Colourless White 704.001.5 4 Plastic Blue Colourless White 704.001.6 4 Plastic Colourless Colourless White 704.001.7 4 45 51 56 57 61 70 Wiring diagrams 71 x2+ 82 x1- 84 Wiring diagram 4 92 96 08/2022 § eao.com 173 04 Raised design Indicator full-face illumination, square, IP65 13 02 28.5 Equipment consisting of (schematic overview) 17.5 03 A 40 01 Lens cap Page 200 Diffusor cap Page 201 04 2…7 09 Actuator Product can differ from the current configuration. Dimensions [mm] A = Screw terminal 14 Bayonet flange Page 203 LED Page 204 Lamp block Page 210 A 30 min. B 65 min. 18 50 min. 17 C D +0.4 Ø22.3 0 19 Each Part Number listed below includes all the black components shown in the 3D-drawing. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 To obtain a complete unit, please select the red components from the pages shown. 41 Actuator, Front dimension 30 mm x 30 mm 45 51 56 Housing colour Housing material Part No. Wiring diagram Black Plastic 704.730.0 4 Grey Plastic 704.730.1 4 Wiring diagrams 57 x2+ 61 70 x1- 71 Wiring diagram 4 82 84 92 96 174 eao.com § 08/2022 Raised design 04 Indicator full-face illumination, round, IP65 Equipment consisting of (schematic overview) Lens cap 01 13 28.5 17.5 02 Page 200 Marking cap 03 40 A Page 201 04 2…7 Actuator Dimensions [mm] A = Screw terminal Bayonet flange 09 Product can differ from the current configuration. 14 Page 203 A 30 min. B Page 210 65 min. Lamp block Page 204 50 min. 17 LED C D 18 +0.4 0 19 Ø22.3 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Actuator, Front dimension Ø 29 mm Housing colour Housing material Part No. Wiring diagram Grey Plastic 704.630.1 4 45 51 Wiring diagrams 56 x2+ 57 61 x1- 70 Wiring diagram 4 71 82 84 92 96 08/2022 § eao.com 175 04 Raised design 01 Indicator front illumination, square, IP65 13 02 Equipment consisting of (schematic overview) 46 Front bezel 40 03 Lens 04 2…7 09 Product can differ from the current configuration. Lens holder Dimensions [mm] Actuator 14 30 min. 17 50 min. Bayonet flange 18 LED Page 204 +0.4 Ø22.3 0 19 Lamp block Mounting cut-outs [mm] 22 Each Part Number listed below includes all the black components shown in the 3D-drawing. 31 To obtain a complete unit, please select the red components from the pages shown. 41 45 Actuator, Front dimension 30 mm x 30 mm 51 Housing colour 56 Black 57 61 70 71 82 Housing material Front bezel colour Lens colour Marking plate colour Marking plate optics Part No. Wiring diagram Plastic Grey Red White translucent 704.202.2 4 Plastic Grey Yellow White translucent 704.202.4 4 Plastic Grey Green White translucent 704.202.5 4 Plastic Grey Blue White translucent 704.202.6 4 Plastic Grey Colourless White translucent 704.202.7 4 Plastic Grey Red Colourless transparent 704.203.2 4 Plastic Grey Yellow Colourless transparent 704.203.4 4 Plastic Grey Green Colourless transparent 704.203.5 4 Plastic Grey Colourless Colourless transparent 704.203.7 4 Plastic Black Red White translucent 704.206.2 4 Plastic Black Yellow White translucent 704.206.4 4 Plastic Black Green White translucent 704.206.5 4 Plastic Black Blue White translucent 704.206.6 4 Plastic Black Colourless White translucent 704.206.7 4 Plastic Black Green Colourless transparent 704.207.5 4 84 92 96 176 eao.com § 08/2022 Raised design 04 Wiring diagrams 01 x2+ 02 03 x1- 04 Wiring diagram 4 09 14 17 18 19 22 31 41 45 51 56 57 61 Modern. Tactile and long-lasting. Series 04 illuminated selector switches. 70 71 Intuitive and reliable operation for enhanced safety in public transportation. . Bright, single or bi-colour LED illumination . Modern, ergonomic design . Rounded edges (in accordance with DIN 5566-1) . Excellent tactile feedback . Long service life and robust construction . Wide range of possible combinations and options 82 84 92 www.eao.com 08/2022 § eao.com 96 ​ 177 04 Raised design 01 Indicator front illumination, round, IP65 13 02 Equipment consisting of (schematic overview) 46 Front bezel 40 03 Lens 04 Marking Plate 2…7 09 Product can differ from the current configuration. Actuator Dimensions [mm] 14 30 min. Bayonet flange 50 min. 17 18 LED Page 204 +0.4 0 Ø22.3 19 Lamp block Mounting cut-outs [mm] 22 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 31 41 45 51 56 Actuator, Front dimension Ø 29 mm Product attributes Filament lamp or LED 57 61 70 71 Filament lamp or LED 82 Housing colour Housing material Front bezel colour Lens colour Marking plate colour Marking plate optics Part No. Wiring diagram Grey Plastic Grey Red White translucent 704.002.2 4 Grey Plastic Grey Yellow White translucent 704.002.4 4 Grey Plastic Grey Green White translucent 704.002.5 4 Grey Plastic Grey Blue White translucent 704.002.6 4 Grey Plastic Grey Colourless White translucent 704.002.7 4 Grey Plastic Grey Red Colourless transparent 704.003.2 4 Grey Plastic Grey Yellow Colourless transparent 704.003.4 4 Grey Plastic Grey Green Colourless transparent 704.003.5 4 Grey Plastic Grey Blue Colourless transparent 704.003.6 4 Grey Plastic Grey Colourless Colourless transparent 704.003.7 4 Grey Plastic Black Red White translucent 704.006.2 4 Grey Plastic Black Yellow White translucent 704.006.4 4 Grey Plastic Black Green White translucent 704.006.5 4 Grey Plastic Black Blue White translucent 704.006.6 4 Grey Plastic Black Colourless White translucent 704.006.7 4 84 92 96 178 eao.com § 08/2022 Raised design 04 Wiring diagrams 01 x2+ 02 03 x1- 04 Wiring diagram 4 09 14 17 18 19 22 31 41 45 51 Follow us. We are on YouTube! 56 EAO ermöglicht. Seit 1947. 57 61 70 71 Come take a look at our YouTube profi le today! Be sure to give us a follow so that you can fully interact with us. 82 https://www.youtube.com/user/eaoswitches 84 92 www.eao.com 08/2022 § eao.com 96 ​ 179 04 Raised design Indicator front illumination, square, IP65 13 02 28.5 Equipment consisting of (schematic overview) 17.5 03 A 40 01 Front bezel Page 202 Lens Page 199 Lens holder Page 201 04 2…7 09 Product can differ from the current configuration. Dimensions [mm] A = Screw terminal Actuator 14 A 30 min. B 65 min. 18 50 min. 17 C D Bayonet flange Page 203 LED Page 204 Lamp block Page 210 +0.4 0 19 Ø22.3 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 41 45 Actuator, Front dimension 30 mm x 30 mm 51 56 57 Housing colour Housing material Part No. Wiring diagram Black Plastic 704.733.0 4 Grey Plastic 704.733.1 4 Wiring diagrams 61 x2+ 70 x1- 71 82 Wiring diagram 4 84 92 96 180 eao.com § 08/2022 Raised design 04 Indicator front illumination, round, IP65 Front bezel Page 202 Lens Page 199 Marking Plate Page 201 13 28.5 17.5 02 A 03 40 Equipment consisting of (schematic overview) 01 04 2…7 Actuator Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 LED Page 204 A 30 min. 17 B Lamp block Page 210 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 65 min. Page 203 50 min. Bayonet flange C D 18 +0.4 0 19 Ø22.3 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 45 Actuator, Front dimension Ø 29 mm Housing colour Housing material Part No. Wiring diagram Grey Plastic 704.633.1 4 51 56 Wiring diagrams 57 x2+ 61 x1- 70 Wiring diagram 4 71 82 84 92 96 08/2022 § eao.com 181 04 Raised design 01 Flasher full-face illumination, square, IP65 13 02 43.5 Equipment consisting of (schematic overview) 28 Lens cap 03 40 A Diffusor cap 04 2…7 17 Product can differ from the current configuration. Dimensions [mm] A = Screw terminal Bayonet flange General information • The lamp block will be delivered with screw terminal A 30 min. 18 LED 65 min. 14 Actuator 50 min. 09 Page 204 Lamp block B +0.4 Ø22.3 0 19 Flasher element Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) 22 Page 235 Each Part Number listed below includes all the black components shown in the 3D-drawing. 31 To obtain a complete unit, please select the red components from the pages shown. 41 45 51 56 Actuator, Front dimension 30 mm x 30 mm Housing colour Housing material Front bezel colour Front bezel material Diffusor cap colour Lens cap colour Marking cap colour Part No. Wiring diagram Grey Plastic Black Plastic White Red White 704.199.2 4 Plastic Black Plastic White Yellow White 704.199.4 4 Plastic Black Plastic White Green White 704.199.5 4 Plastic Black Plastic White Colourless White 704.199.7 4 Plastic Grey Plastic White Red White 704.200.2 4 Plastic Grey Plastic White Yellow White 704.200.4 4 Plastic Grey Plastic White Green White 704.200.5 4 Plastic Grey Plastic White Blue White 704.200.6 4 Plastic Grey Plastic White Colourless White 704.200.7 4 57 61 70 71 Wiring diagrams 82 x2+ 84 x1- 92 96 Wiring diagram 4 182 eao.com § 08/2022 Raised design 04 Flasher full-face illumination, round, IP65 Equipment consisting of (schematic overview) 01 13 43.5 28 02 Lens cap 03 40 A Marking cap 04 2…7 Actuator Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information Bayonet flange A Page 204 50 min. LED • The lamp block will be delivered with screw terminal 17 65 min. 30 min. 18 B Lamp block Ø22.3 Flasher element Page 235 +0.4 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) 22 31 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 41 45 51 Actuator, Front dimension Ø 29 mm Housing colour Housing material Diffusor cap colour Grey Plastic Diffusor cap surface Lens cap colour Marking cap colour White Red Plastic White Plastic White Plastic Marking cap surface Part No. Wiring diagram White 704.000.2 4 Yellow White 704.000.4 4 Green White 704.000.5 4 White Blue White 704.000.6 4 Plastic White Colourless White 704.000.7 4 Plastic White Red Colourless ribbed 704.001.2 4 Plastic White ribbed Yellow Colourless ribbed 704.001.4 4 Plastic White ribbed Green Colourless ribbed 704.001.5 4 Plastic White ribbed Blue Colourless ribbed 704.001.6 4 Plastic White ribbed Colourless Colourless ribbed 704.001.7 4 56 57 61 70 71 82 84 92 96 08/2022 § eao.com 183 04 Raised design 01 Wiring diagrams x2+ 02 03 x1- 04 Wiring diagram 4 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 184 ​ eao.com § 08/2022 Raised design 04 Flasher full-face illumination, square, IP65 Equipment consisting of (schematic overview) 13 43.5 28 02 Page 200 A Diffusor cap 03 40 Lens cap 01 Page 201 04 2…7 Actuator Dimensions [mm] A = Screw terminal Bayonet flange 14 Page 203 A 30 min. Lamp block Page 210 18 B Ø22.3 Page 235 17 65 min. Page 204 50 min. LED Flasher element 09 Product can differ from the current configuration. +0.4 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) 22 Each Part Number listed below includes all the black components shown in the 3D-drawing. 31 To obtain a complete unit, please select the red components from the pages shown. 41 45 51 Actuator, Front dimension 30 mm x 30 mm Housing colour Housing material Part No. Wiring diagram Black Plastic 704.730.0 4 Grey Plastic 704.730.1 4 56 57 Wiring diagrams 61 x2+ 70 71 x1- 82 Wiring diagram 4 84 92 96 08/2022 § eao.com 185 04 Raised design Flasher full-face illumination, round, IP65 13 02 43.5 Equipment consisting of (schematic overview) 28 03 A Lens cap Page 200 Marking cap Page 201 40 01 04 2…7 09 Actuator Product can differ from the current configuration. Dimensions [mm] A = Screw terminal 14 50 min. 18 65 min. 30 min. 17 Bayonet flange Page 203 LED Page 204 Lamp block Page 210 Flasher element Page 235 A B +0.4 Ø22.3 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) 22 31 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 41 45 51 56 57 Actuator, Front dimension Ø 29 mm Housing colour Housing material Part No. Wiring diagram Grey Plastic 704.630.1 4 Wiring diagrams 61 x2+ 70 x1- 71 82 Wiring diagram 4 84 92 96 186 eao.com § 08/2022 Raised design 04 Flasher front illumination,square, IP65 Equipment consisting of (schematic overview) 01 13 43.5 28 02 Front bezel 03 40 A Lens 04 2…7 Lens holder Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. Actuator 14 General information A 30 min. LED Page 204 17 65 min. 50 min. Bayonet flange • The lamp block will be delivered with screw terminal 18 B Ø22.3 +0.4 0 19 Lamp block Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) Flasher element 22 Page 235 31 Each Part Number listed below includes all the black components shown in the 3D-drawing. 41 To obtain a complete unit, please select the red components from the pages shown. 45 51 56 Actuator, Front dimension 30 mm x 30 mm Housing colour Housing material Lens colour Front bezel colour Front bezel material Marking plate colour Marking plate optics Part No. Wiring diagram Black Plastic Red Grey Plastic White translucent 704.202.2 4 Plastic Yellow Grey Plastic White translucent 704.202.4 4 Plastic Green Grey Plastic White translucent 704.202.5 4 Plastic Blue Grey Plastic White translucent 704.202.6 4 Plastic Colourless Grey Plastic White translucent 704.202.7 4 Plastic Red Grey Plastic Colourless transparent 704.203.2 4 Plastic Yellow Grey Plastic Colourless transparent 704.203.4 4 Plastic Green Grey Plastic Colourless transparent 704.203.5 4 Plastic Colourless Grey Plastic Colourless transparent 704.203.7 4 Plastic Red Black Plastic White translucent 704.206.2 4 Plastic Yellow Black Plastic White translucent 704.206.4 4 Plastic Green Black Plastic White translucent 704.206.5 4 Plastic Blue Black Plastic White translucent 704.206.6 4 Plastic Colourless Black Plastic White translucent 704.206.7 4 Plastic Green Black Plastic Colourless transparent 704.207.5 4 57 61 70 71 82 84 92 96 08/2022 § eao.com 187 04 Raised design 01 Wiring diagrams x2+ 02 03 x1- 04 Wiring diagram 4 09 14 17 18 19 22 31 41 45 51 EAO Downloads. www.eao.com/downloads 56 EAO creates possibilities. Since 1947. 57 61 70 71 On our website you can download technical data, assembly instructions, catalogs, brochures and much more. 82 84 92 www.eao.com 96 188 ​ eao.com § 08/2022 Raised design 04 Flasher front illumination, round, IP65 Equipment consisting of (schematic overview) 01 13 43.5 28 02 Front bezel 03 40 A Lens 04 Marking Plate 2…7 Actuator Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. 14 General information A 50 min. LED Page 204 • The lamp block will be delivered with screw terminal 17 65 min. 30 min. Bayonet flange 18 B Ø22.3 Lamp block Flasher element Page 235 +0.4 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) 22 31 Each Part Number listed below includes all the black components shown in the 3D-drawing. 41 To obtain a complete unit, please select the red components from the pages shown. 45 51 Actuator, Front dimension Ø 29 mm Housing colour Housing material Lens colour Front bezel colour Front bezel material Marking plate colour Marking plate optics Part No. Wiring diagram Grey Plastic Red Grey Plastic White translucent 704.002.2 4 Plastic Yellow Grey Plastic White translucent 704.002.4 4 Plastic Green Grey Plastic White translucent 704.002.5 4 Plastic Blue Grey Plastic White translucent 704.002.6 4 Plastic Colourless Grey Plastic White translucent 704.002.7 4 Plastic Red Grey Plastic Colourless transparent 704.003.2 4 Plastic Yellow Grey Plastic Colourless transparent 704.003.4 4 Plastic Green Grey Plastic Colourless transparent 704.003.5 4 Plastic Blue Grey Plastic Colourless transparent 704.003.6 4 Plastic Colourless Grey Plastic Colourless transparent 704.003.7 4 Plastic Red Black Plastic White translucent 704.006.2 4 Plastic Yellow Black Plastic White translucent 704.006.4 4 Plastic Green Black Plastic White translucent 704.006.5 4 Plastic Blue Black Plastic White translucent 704.006.6 4 Plastic Colourless Black Plastic White translucent 704.006.7 4 56 57 61 70 71 82 84 92 96 08/2022 § eao.com 189 04 Raised design 01 Wiring diagrams x2+ 02 03 x1- 04 Wiring diagram 4 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 190 ​ eao.com § 08/2022 Raised design 04 Flasher front illumination, square, IP65 Equipment consisting of (schematic overview) 13 43.5 28 02 Page 202 A Lens 03 40 Front bezel 01 Page 199 04 Lens holder 2…7 Page 201 Dimensions [mm] A = Screw terminal 09 Product can differ from the current configuration. Actuator 14 A 30 min. LED Page 204 17 18 B Ø22.3 Lamp block 65 min. Page 203 50 min. Bayonet flange +0.4 0 19 Page 210 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) Flasher element 22 Page 235 31 Each Part Number listed below includes all the black components shown in the 3D-drawing. 41 To obtain a complete unit, please select the red components from the pages shown. 45 51 56 Actuator, Front dimension 30 mm x 30 mm Housing colour Housing material Part No. Wiring diagram Black Plastic 704.733.0 4 Grey Plastic 704.733.1 4 57 61 Wiring diagrams 70 x2+ 71 82 x1- 84 Wiring diagram 4 92 96 08/2022 § eao.com 191 04 Raised design Flasher front illumination, round, IP65 13 02 43.5 Equipment consisting of (schematic overview) 28 03 A 04 40 01 Front bezel Page 202 Lens Page 199 Marking Plate Page 201 2…7 09 Product can differ from the current configuration. Actuator Dimensions [mm] A = Screw terminal 14 A 50 min. 17 18 65 min. 30 min. Bayonet flange Page 203 LED Page 204 Lamp block Page 210 Flasher element Page 235 B +0.4 Ø22.3 0 19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) 22 31 Each Part Number listed below includes all the black components shown in the 3D-drawing. 41 To obtain a complete unit, please select the red components from the pages shown. 45 51 Actuator, Front dimension Ø 29 mm 56 57 61 Housing colour Housing material Part No. Wiring diagram Grey Plastic 704.633.1 4 Wiring diagrams x2+ 70 71 x1- 82 Wiring diagram 4 84 92 96 192 eao.com § 08/2022 Raised design 04 Buzzer, IP65 01 Equipment consisting of (schematic overview) 2 ... 6 02 03 30 Actuator 04 13.5 35.5 Fixing nut Dimensions [mm] 09 Product can differ from the current configuration. Each Part Number listed below includes all the black components shown in the 3D-drawing. 14 General information 30 min. 30 min. • Further information see Technical data Ø22.3 • The colour of anodised aluminium parts can vary due to technical production reasons 17 18 +0.4 0 19 Mounting cut-outs [mm] 22 31 Actuator, Front dimension Ø 29 mm Terminal Operating voltage Front cap colour Front cap material Plug-in terminal 24 V DC Black Plastic 24 V DC Nature Aluminium Front cap surface anodised Part No. Wiring diagram 14-810.002 71 14-810.902 71 41 45 51 Wiring diagrams 56 x1+ 57 x2- 61 Wiring diagram 71 70 71 82 84 92 96 08/2022 § eao.com 193 04 Raised design 01 Potentiometer, IP65 Equipment consisting of (schematic overview) 5 02 Lever 03 04 36 24 14 Fixing nut Product can differ from the current configuration. Dimensions [mm] ​ Mounting General information NJO • Resistor 10 kOhm / linear, series E3 17    Potentiometer 3NBY    18 PLQ 09 Actuator 6 max. 19  ±  Each Part Number listed below includes all the black components shown in the 3D-drawing. Mounting cut-outs [mm] ​ 22 31 Actuator, Front dimension Ø 28 mm 41 45 Housing material Front bezel colour Plastic Matt grey 51 Front bezel material Front bezel surface Resistance Part No. Wiring diagram Metal matt chrome 10 kOhm 44-745.20-10K1 104 10 kOhm 44-745.60-10K1 104 Plastic Wiring diagrams 56 57 1 2 3 61 70 Wiring diagram 104 71 82 84 92 96 194 ​ eao.com § 08/2022 Raised design 04 Stop switch Ø 37 mm, IP65 01 Equipment consisting of (schematic overview) 53 Actuator 02 23 A A 03 37 47 04 2 ... 7 09 Bayonet flange Dimensions [mm] A = Screw terminal Switching element Product can differ from the current configuration. 14 General information Page 213    • Max. 2 switching elements can be clipped on 17 3NBY    Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 18  ±  19 Mounting cut-outs [mm] 22 31 Actuator, Front dimension Ø 37 mm Switching action Housing colour Housing material Lens colour Marking Product attributes Part No. Wiring diagram Maintained Yellow Plastic Red Arrows Twist to unlock clockwise 704.064.2 363 Yellow Plastic Red Arrows Key to unlock clockwise 704.066.2 364 41 45 51 Wiring diagrams 56 57 61 Wiring diagram 363 70 Wiring diagram 364 71 82 84 92 96 08/2022 § eao.com 195 04 Raised design Stop switch Ø 40 mm, IP65 23 02 53 25 03 Equipment consisting of (schematic overview) 23 A A Actuator 37 01 04 2 …7 Product can differ from the current configuration. Dimensions [mm] A = Screw terminal Switching element • The standard lock Ronis 251 17 Page 213 General information A NJO Each Part Number listed below includes all the black components shown in the 3D-drawing. • The colour of anodised aluminium parts can vary due to technical production reasons 18 B PLQ 14 Bayonet flange PLQ 09 C D To obtain a complete unit, please select the red components from the pages shown.  ±  19 Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 45 51 Actuator, Front dimension Ø 40 mm Switching action Housing colour Housing material Lens colour Marking Product attributes Maintained Grey Plastic Red Arrows Grey Plastic Red Grey Plastic Grey 56 57 61 Front bezel colour Front bezel material Twist to unlock clockwise Grey Stop Twist to unlock clockwise Red Arrows Plastic Red Stop Grey Plastic Grey Plastic Front bezel surface Part No. Wiring diagram Plastic 704.074.2 363 Grey Plastic 704.074.3 363 Twist to unlock clockwise Nature Aluminium anodised 704.075.2 363 Twist to unlock clockwise Nature Aluminium anodised 704.075.3 363 Red Key to unlock clockwise Grey Plastic 704.076.0 364 Red Key to unlock clockwise Nature Aluminium 704.078.0 364 anodised 70 Wiring diagrams 71 82 84 92 Wiring diagram 363 Wiring diagram 364 96 196 eao.com § 08/2022 Raised design 04 Emergency stop switch, foolproof EN IEC 60974-5-5, IP65 01 Equipment consisting of (schematic overview) 53 Actuator 02 23 A A 03 37 47 04 2 ... 7 09 Bayonet flange Dimensions [mm] A = Screw terminal Switching element Product can differ from the current configuration. 14 General information Page 223    17 • Shaft yellow 3NBY    Each Part Number listed below includes all the black components shown in the 3D-drawing. • Max. 2 switching elements can be clipped on To obtain a complete unit, please select the red components from the pages shown. 18  ±  19 Mounting cut-outs [mm] 22 31 Actuator, Front dimension Ø 37 mm Switching action Housing colour Housing material Lens colour Marking Product attributes Part No. Wiring diagram Maintained Yellow Plastic Red Arrows Twist to unlock anti-clockwise 704.064.2A 363 Yellow Plastic Red Arrows Key release to unlock anti-clockwise 704.066.2A 364 41 45 51 Wiring diagrams 56 57 61 70 Wiring diagram 363 Wiring diagram 364 71 82 84 92 96 08/2022 § eao.com 197 04 Raised design 01 Emergency call switch, IP65 53 25 02 Equipment consisting of (schematic overview) 23 03 A A 37 Mushroom-head cap Actuator 04 2… 7 09 Product can differ from the current configuration. Bayonet flange Dimensions [mm] A = Screw terminal 14 B PLQ 18 PLQ 17 Switching element A NJO C D Page 213 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown.  19 ±  Mounting cut-outs [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 41 Actuator, Front dimension Ø 60 mm 45 51 56 Switching action Lens colour Lens material Housing colour Housing material Part No. Wiring diagram Maintained Red Plastic Grey Plastic 704.077.2D 364 Wiring diagrams 57 61 70 Wiring diagram 364 71 82 84 92 96 198 eao.com § 08/2022 Components 04 01 Lens plastic raised Lens material 02 Lens colour Plastic Lens optics Lens shape Lens illumination Dimensions Part No. Red transparent flush illuminative Ø 23,7 mm 704.611.2 Yellow transparent flush illuminative Ø 23,7 mm 704.611.4 Green transparent flush illuminative Ø 23,7 mm 704.611.5 Blue transparent flush illuminative Ø 23,7 mm 704.611.6 Colourless transparent flush illuminative Ø 23,7 mm 704.611.7 03 04 Additional information 09 • To obtain IP67, use marking plate Part Nr. 704.610.X 14 17 Lens plastic square Lens material Lens colour Lens optics Lens shape Lens illumination Dimensions Part No. Plastic Black opaque flush non illuminative 24,4 mm x 24,4 mm 704.702.0 White opaque flush non illuminative 24,4 mm x 24,4 mm 704.702.9 Red transparent flush illuminative 24,4 mm x 24,4 mm 704.702.2 Yellow transparent flush illuminative 24,4 mm x 24,4 mm 704.702.4 Green transparent flush illuminative 24,4 mm x 24,4 mm 704.702.5 Blue transparent flush illuminative 24,4 mm x 24,4 mm 704.702.6 Colourless transparent flush illuminative 24,4 mm x 24,4 mm 704.702.7 18 19 22 31 41 Lens metal round spot round 45 Lens material Lens colour Lens optics Lens shape Lens illumination Dimensions Part No. Aluminium Black opaque flush illuminative Ø 23,7 mm 704.601.01 Red opaque flush illuminative Ø 23,7 mm 704.601.21 Stainless steel Gold opaque flush illuminative Ø 23,7 mm 704.601.41 Olive green opaque flush illuminative Ø 23,7 mm 704.601.51 Blue opaque flush illuminative Ø 23,7 mm 704.601.61 Nature opaque flush illuminative Ø 23,7 mm 704.601.81 Nature opaque flush illuminative Ø 23,7 mm 704.601.91 Nature opaque flush illuminative Ø 23,7 mm 704.601.101 51 56 57 61 Additional information • The colour of anodised aluminium parts can vary due to technical production reasons 70 • To obtain IP65, it is necessary to use marking plate Part No.. 704.609.X 71 82 84 92 96 08/2022 § eao.com 199 04 Components 01 02 03 Lens metal round Lens material Lens colour Lens optics Lens shape Lens illumination Dimensions Part No. Aluminium Black opaque flush non illuminative Ø 23,7 mm 704.601.0 04 09 14 Stainless steel Red opaque flush non illuminative Ø 23,7 mm 704.601.2 Gold opaque flush non illuminative Ø 23,7 mm 704.601.4 Olive green opaque flush non illuminative Ø 23,7 mm 704.601.5 Blue opaque flush non illuminative Ø 23,7 mm 704.601.6 Nature opaque flush non illuminative Ø 23,7 mm 704.601.8 Nature opaque flush non illuminative Ø 23,7 mm 704.601.9 Nature opaque flush non illuminative Ø 23,7 mm 704.601.10 Additional information • The colour of anodised aluminium parts can vary due to technical production reasons 17 • To obtain IP65, it is necessary to use marking plate Part No.. 704.609.X 18 19 22 Lens plastic round Lens material Lens colour Lens optics Lens shape Lens illumination Dimensions Part No. Plastic Black opaque flush non illuminative Ø 23.7 mm 704.602.0 Red transparent flush illuminative Ø 23,7 mm 704.602.2 Yellow transparent flush illuminative Ø 23,7 mm 704.602.4 Green transparent flush illuminative Ø 23,7 mm 704.602.5 Blue transparent flush illuminative Ø 23,7 mm 704.602.6 Colourless transparent flush illuminative Ø 23,7 mm 704.602.7 Silver transparent flush illuminative Ø 23,7 mm 704.602.7A01 31 41 45 Symbol Ring Additional information • To obtain IP67, use marking plate Part No. 704.609.9 51 • To obtain IP67 use marking plate Part No. 704.609.9A01 (ring illumination) 56 57 61 Lens cap round for full face indicator Lens cap material Lens cap colour Lens cap optical effect Diameter Part No. Plastic Red transparent 29 mm 704.603.2 Yellow transparent 29 mm 704.603.4 Green transparent 29 mm 704.603.5 Blue transparent 29 mm 704.603.6 Colourless transparent 29 mm 704.603.7 70 71 Additional information • To obtain IP67, use marking plate Part Nr. 704.608.X 82 84 92 96 200 eao.com § 08/2022 Components 04 01 Lens holder 02 Marking plate material Marking plate colour Marking plate illumination Part No. Plastic Colourless illuminative 704.709.7 White illuminative 704.709.9 03 Additional information 04 • For square lens 09 14 Marking cap for lens cap round Marking cap material Marking cap colour Marking cap optics Dimensions Marking cap surface Part No. Plastic Colourless transparent Ø 29 mm ribbed 704.608.7 White translucent Ø 29 mm 17 704.608.9 18 19 Marking cap round raised profile Marking cap material Marking cap colour Marking cap optics Dimensions Marking cap surface Part No. Plastic Colourless transparent Ø 29 mm ribbed 704.610.7 White translucent Ø 29 mm 22 704.610.9 31 41 Marking cap round flat 45 Marking plate material Marking plate colour Marking plate optics Marking plate illumination Part No. Plastic Black opaque non illuminative 704.609.0 Colourless transparent illuminative 704.609.7 White translucent illuminative 704.609.9 White translucent ring illumination 704.609.9A01 51 56 57 61 Diffusor cap Product attributes Can be marked Diffusor cap colour Diffusor cap optics Diffusor cap illumination Part No. Colourless transparent illuminative 704.708.7 White translucent illuminative 704.708.9 70 71 82 84 92 96 08/2022 § eao.com 201 04 Components 01 Front bezel round, raised design 02 03 04 Front bezel material Front bezel colour Plastic Black Aluminium Stainless steel 09 14 Front bezel surface Dimensions Part No. Ø 29 mm 704.600.0 Grey Ø 29 mm 704.600.6 Grey Ø 29 mm x 16 mm 704.600.7 Nature anodised Ø 29 mm 704.600.1 Black anodised Ø 29 mm 704.600.1A Ø 29 mm 704.600.9 Nature Additional information • The colour of anodised aluminium parts can vary due to technical production reasons 17 18 19 Front bezel square, raised design Front bezel material Front bezel colour Plastic Black Chrome coloured 22 Front bezel surface chrome plated Grey Dimensions Part No. 30 mm x 30 mm 704.701.0 30 mm x 30 mm 704.701.4 30 mm x 30 mm 704.701.6 31 41 45 51 Front bezel set flush design Front bezel material Front bezel colour Front bezel surface Dimensions Part No. Aluminium Black anodised Ø 35 mm 704.955.0 Nature anodised Ø 35 mm 704.955.1 Stainless steel 304 Nature Ø 35 mm 704.955.9 Stainless steel 316 Nature Ø 35 mm 704.955.10 Additional information 56 • The colour of anodised aluminium parts can vary due to technical production reasons 57 61 70 Front bezel set protective membrane Product attributes Front bezel material Front bezel colour Front bezel surface Dimensions Part No. With transparent silicone membrane Aluminium Nature anodised Ø 35 mm 704.955.3 Aluminium Black anodised Ø 35 mm 704.955.4 Stainless steel Nature Ø 35 mm 704.955.9E 71 With transparent silicone membrane, resistant to sea water 82 Additional information • The colour of anodised aluminium parts can vary due to technical production reasons 84 92 96 202 eao.com § 08/2022 Components 04 01 02 Bayonet flange Material Part No. plastic 704.950.5 metal 704.960.5 20 20 04 27.6 09 44 32 29.5 03 14 17 Dimensions [mm] for Part No. 704.950.5 Dimensions [mm] for Part No. 704.960.5 18 19 22 31 41 45 51 Green Touch. Offering sustainability. 56 EAO creates possibilities. Since 1947. 57 61 70 71 As a successful company with production sites around the world, EAO is actively committed to the effective implementation of a sustainable environmental policy. 82 We act responsibly. In our environmental focus, we set benchmarks for ourselves, our products and our customers. Throughout our entire value chain, we think and work in a way that is resource-efficient and environmentally-friendly. When selecting our components and raw materials, we ensure that we have partnerships in place with certified manufacturers and that we adhere to EC guidelines on hazardous materials (RoHS). 84 92 www.eao.com 08/2022 § eao.com 96 203 04 Components 01 Single-LED, BA9s 02 Operating voltage Operation current Lumi. Intensity Dom. Wavelength Part No. Wiring diagram Red 6 V DC +10% 17 mA ±15 % 400 mcd 630 nm 10-2506.1082 70 12 V AC/DC +10% 16 mA ±15 % 390 mcd 630 nm 10-2509.1142 70 24 V AC/DC +10% 15 mA ±15 % 350 mcd 630 nm 10-2512.1142 70 28 V AC/DC +10% 13 mA ±15 % 300 mcd 630 nm 10-2513.1142 70 48 V AC/DC +10% 8 mA ±15 % 200 mcd 630 nm 10-2519.1052 70 130 V DC +10% 3 mA ±15 % 120 mcd 630 nm 10-2524.3042 70 130 V AC +10% 5 mA ±15 % 180 mcd 630 nm 10-2H24.2052 70 230 V AC +10% 3 mA ±15 % 120 mcd 630 nm 10-2H25.2042 70 6 V DC +10% 17 mA ±15 % 340 mcd 587 nm 10-2506.1084 70 12 V AC/DC +10% 16 mA ±15 % 340 mcd 587 nm 10-2509.1144 70 24 V AC/DC +10% 15 mA ±15 % 300 mcd 587 nm 10-2512.1144 70 28 V AC/DC +10% 13 mA ±15 % 270 mcd 587 nm 10-2513.1144 70 48 V AC/DC +10% 8 mA ±15 % 180 mcd 587 nm 10-2519.1054 70 130 V DC +10% 3 mA ±15 % 110 mcd 587 nm 10-2524.3044 70 130 V AC +10% 5 mA ±15 % 160 mcd 587 nm 10-2H24.2054 70 230 V AC +10% 3 mA ±15 % 110 mcd 587 nm 10-2H25.2044 70 6 V DC +10% 7 mA ±15 % 1050 mcd 525 nm 10-2506.1085 70 12 V AC/DC +10% 7 mA ±15 % 1050 mcd 525 nm 10-2509.1145 70 24 V AC/DC +10% 7 mA ±15 % 1050 mcd 525 nm 10-2512.1145 70 28 V AC/DC +10% 7 mA ±15 % 1050 mcd 525 nm 10-2513.1145 70 48 V AC/DC +10% 4 mA ±15 % 600 mcd 525 nm 10-2519.1055 70 130 V DC +10% 2 mA ±15 % 300 mcd 525 nm 10-2524.3045 70 130 V AC +10% 3 mA ±15 % 450 mcd 525 nm 10-2H24.2055 70 230 V AC +10% 2 mA ±15 % 300 mcd 525 nm 10-2H25.2045 70 6 V DC +10% 17 mA ±15 % 780 mcd 470 nm 10-2506.1086 70 12 V AC/DC +10% 16 mA ±15 % 720 mcd 470 nm 10-2509.1146 70 24 V AC/DC +10% 15 mA ±15 % 680 mcd 470 nm 10-2512.1146 70 28 V AC/DC +10% 13 mA ±15 % 590 mcd 470 nm 10-2513.1146 70 48 V AC/DC +10% 8 mA ±15 % 400 mcd 470 nm 10-2519.1056 70 130 V DC +10% 3 mA ±15 % 200 mcd 470 nm 10-2524.3046 70 130 V AC +10% 5 mA ±15 % 230 mcd 470 nm 10-2H24.2056 70 230 V AC +10% 3 mA ±15 % 200 mcd 470 nm 10-2H25.2046 70 6 V DC +10% 5 mA ±15 % 750 mcd x: 0.31 / y: 0.32 nm 10-2506.1089 70 12 V AC/DC +10% 8 mA ±15 % 1200 mcd x: 0.31 / y: 0.32 nm 10-2509.1149 70 24 V AC/DC +10% 7 mA ±15 % 1050 mcd x: 0.31 / y: 0.32 nm 10-2512.1149 70 28 V AC/DC +10% 5 mA ±15 % 750 mcd x: 0.31 / y: 0.32 nm 10-2513.1149 70 48 V AC/DC +10% 5 mA ±15 % 750 mcd x: 0.31 / y: 0.32 nm 10-2519.1059 70 130 V DC +10% 1,5 mA ±15 % 225 mcd x: 0.31 / y: 0.32 nm 10-2524.3049 70 130 V AC +10% 2 mA ±15 % 300 mcd x: 0.31 / y: 0.32 nm 10-2H24.2059 70 230 V AC +10% 1,5 mA ±15 % 225 mcd x: 0.31 / y: 0.32 nm 10-2H25.2049 70 04 09 14 Yellow 17 18 Green 19 22 31 Blue 41 45 51 White 56 57 61 70 71 82 84 Additional information • The specified 6 V DC, 24 V DC Bi-colour; 130 V AC, 130 V DC and 230 V AC versions are built with a protection diode 29 max. • The specified 130 VAC types are developed to run on a supply voltage of 130 VAC only • An operation at a higher supply voltage using commercial lampholders with integrated resistors, is not approved • If the 24VDC Bi-colour lamp is driven with normal polarity (plus on middle contact of the lamp) the first mentioned colour will light up, with inverted polarity the second colour will ligth up A B • The luminous intensity stated is for when used with DC • Electrical and optical data are measured at 25 °C 92 25 max. • The specified 12, 24, 28, 48 VAC/DC versions are built with a bridge rectifier Ø10 max. 03 Illumination colour Dimensions [mm] • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED 96 204 eao.com § 08/2022 Components 04 Wiring diagrams 01 x2+ 02 03 x1- 04 Wiring diagram 70 09 14 Single-LED super bright Illumination colour Operating voltage Operation current Lumi. Intensity Dom. Wavelength Part No. Wiring diagram Red 28 V AC/DC +10% 14 mA ±15 % 7700 mcd 630 nm 10-2413.1132R 70 Green 28 V AC/DC +10% 13 mA ±15 % 12400 mcd 525 nm 10-2413.1125R 70 Yellow 28 V AC/DC +10% 14 mA ±15 % 4200 mcd 589 nm 10-2413.1134R 70 17 18 19 Additional information • The specified 12, 24, 28, 48 VAC/DC versions are built with a bridge rectifier 22 • Electrical and optical data are measured at 25 °C • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED 25 max. 41 A B 45 Ø 10 max. 29 max. 31 51 56 Dimensions [mm] A = (standard) B = (super bright) 57 Wiring diagrams 61 x2+ 70 x1- 71 Wiring diagram 70 82 84 92 96 08/2022 § eao.com 205 04 Components 01 Single-LED with integrated Zener diode, BA9s 02 Illumination colour Operating voltage Operation current Lumi. Intensity Dom. Wavelength Part No. Wiring diagram Red 24 - 30 V AC/DC +10% 13 - 19 mA ±15 % 300 - 440 mcd 630 nm 10-2H13.3162Q 367 Green 24 - 30 V AC/DC +10% 12 - 18 mA ±15 % 1800 - 2700 mcd 525 nm 10-2H13.3165Q 367 Yellow 24 - 30 V AC/DC +10% 13 - 19 mA ±15 % 270 - 380 mcd 589 nm 10-2H13.3164Q 367 04 Blue 24 - 30 V AC/DC +10% 12 - 18 mA ±15 % 560 - 800 mcd 589 nm 10-2H13.3166Q 367 White 24 - 30 V AC/DC +10% 7 - 11 mA ±15 % 600 - 900 mcd 589 nm 10-2H13.3169Q 367 09 Additional information 14 • Electrical and optical data are measured at 25 °C 03 • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED • The specified 12, 24, 28, 48 VAC/DC versions are built with a bridge rectifier 17 25 max. 29 max. B Ø 10 max. 18 A 19 22 31 41 Dimensions [mm] A = (standard) B = (super bright) Wiring diagrams 45 x2+ 51 56 57 x1- Wiring diagram 367 61 70 71 82 84 92 96 206 eao.com § 08/2022 Components 04 01 Bi-colour LED, BA9s Illumination colour Operating voltage Operation current Lumi. Intensity Dom. Wavelength Product attributes Part No. Wiring diagram Red / Green 24 V AC/DC +10% 15 mA ±15 % 1200/900 mcd 625 / 525 nm X2: + = Red / X1: + = Green 10-2H12.314A 171 Red / Yellow 24 V AC/DC +10% 15 mA ±15 % 1200/550 mcd 625 / 589 nm X2: + = Red / X1: + = Yellow 10-2H12.314B 171 Green / Yellow 24 V AC/DC +10% 15 mA ±15 % 900/550 mcd 525 / 589 nm X2: + = Yellow / X1: + = Green 10-2H12.314C 171 02 03 04 Additional information • The max. overall length of the lamp may not exeed 25mm 09 • Electrical and optical data are measured at 25 °C • The specified 6 V DC, 24 V DC Bi-colour; 130 V AC, 130 V DC and 230 V AC versions are built with a protection diode 14 • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED 17 25 max. 18 B 19 Ø 10 max. 29 max. A 22 31 Dimensions [mm] A = (standard) B = (super bright) 41 45 Wiring diagrams 51 x2+ 56 57 x1- Wiring diagram 171 61 70 71 82 84 92 96 08/2022 § eao.com 207 04 Components 01 Multi-LED, BA9s, EN 50155, Fail Safe 02 03 Illumination colour Operating voltage Operation current Lumi. Intensity Dom. Wavelength Part No. Wiring diagram Red 72 V AC/DC 2,2 mA -30%/+25% 4 x 128 mcd 625 nm 10-4H21.1032P 368 110 V AC/DC 2 mA -30%/+25% 4 x 128 mcd 625 nm 10-4H22.1032P 368 72 V AC/DC 2,2 mA -30%/+25% 4 x 112 mcd 589 nm 10-4H21.1034P 368 110 V AC/DC 2 mA -30%/+25% 4 x 128 mcd 589 nm 10-4H22.1034P 368 72 V AC/DC 2,2 mA -30%/+25% 4 x 478 mcd 525 nm 10-4H21.1035P 368 110 V AC/DC 2 mA -30%/+25% 4 x 510 mcd 525 nm 10-4H22.1035P 368 72 V AC/DC 2,2 mA -30%/+25% 4 x 90 mcd 465 nm 10-4H21.1036P 368 110 V AC/DC 2 mA -30%/+25% 4 x 86 mcd 465 nm 10-4H22.1036P 368 72 V AC/DC 2,2 mA -30%/+25% 4 x 382 mcd 10-4H21.1039P 368 110 V AC/DC 2 mA -30%/+25% 4 x 446 mcd 10-4H22.1039P 368 Yellow 04 09 14 17 Green Blue White Additional information • A suitable LED remover Part No. 700.006.0 • The luminous intensity stated is for when used with DC 18 • Electrical and optical data are measured at 25 °C • The specified 72 and 110 VAC/VDC versions are built with a bridge rectifier 19 22 • The specified 72 and 110 VAC/VDC versions are built with a protection diode • In case one LED fails, the other pair of still functioning LED›s is working. The light output then is half in order to indicate the malfunction and shows this way the need for replacement • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED 31 41 Ø 10 max. 25 max. 45 51 56 57 Dimensions [mm] Wiring diagrams x2(+) 61 AC/DC x1(-) 70 71 Wiring diagram 368 82 84 92 96 208 eao.com § 08/2022 Components 04 01 LED BA9s, EN 50155 Illumination colour Operating voltage Operation current Lumi. Intensity Part No. Wiring diagram White 24 V AC/DC -30%/+25% 700 mcd 10-2412.1089P 369 02 03 Additional information • A suitable LED remover Part No. 700.006.0 04 • The luminous intensity stated is for when used with DC • Electrical and optical data are measured at 25 °C 09 • The specified 24 VAC/VDC versions are built with a protection diode • Specified 24 VAC/VDC versions are built with a bridge rectifier 14 • The new, white BA9s LED operates within a range of 16VDC to 34VDC. It conforms to the norms EN 50155 and IEEE 1476 • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED 17 18 25 max. Ø 10 max. 19 22 31 Dimensions [mm] 41 Wiring diagrams D1 45 D2 51 LED R1 D3 56 R2 57 D4 Wiring diagram 369 61 70 Filament lamp Operating voltage Operation current Part No. Wiring diagram 24 V AC/DC 50 mA ±10 % 10-1412.1279 432 36 V AC/DC 56 mA ±10 % 10-1416.1289 432 60 V AC/DC 33 mA ±10 % 10-1420.1219 432 110 V AC/DC 22 mA ±10 % 10-1422.1179 432 130 V AC/DC 20 mA ±10 % 10-1424.1179 432 71 82 84 Additional information 92 • The max. overall length of the lamp may not exeed 28 mm 96 08/2022 § eao.com 209 04 Components 01 Wiring diagrams x2+ 02 03 x1- 04 Wiring diagram 09 14 17 18 19 22 Lamp block for selector switch and illuminated pushbutton, 2 positions Terminal kind of Part No. Wiring diagram Screw terminal 704.950.0 4 Plug-in terminal 704.950.1 4 Double plug-in terminal 704.950.1/D 4 Push-in Terminal 704.950.3 4 Terminals nickel plated Cu/Sn Double plug-in terminal 704.950.2/D 4 For ring cable shoe Screw terminal 704.950.0B 4 Product attributes Terminals nickel plated and blank Cu/Sn D 44 C 50 B 44 31 41 18.5 19 51 57 61 27.5 A 40 37 45 56 18.5 15.3 17.5 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm Wiring diagrams 70 x2+ 71 82 x1- 84 Wiring diagram 4 92 96 210 eao.com § 08/2022 Components 04 01 02 Lamp block for selector switch 3 positions Product attributes Terminals nickel plated and blank Cu/Sn Terminal kind of Part No. Wiring diagram Screw terminal 704.951.0 4 Plug-in terminal Double plug-in terminal 704.951.1 704.951.1/D 4 4 Push-in Terminal 704.951.3 4 03 04 D 44 18.5 37 19 27.5 14 18.5 15.3 17 A 18 40 C 50 B 44 09 19 17.5 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 22 31 Wiring diagrams 41 x2+ 45 51 x1- 56 Wiring diagram 4 57 61 70 71 82 84 92 96 08/2022 § eao.com 211 04 Components 01 Dual lamp block 02 03 04 Component Layout Operating voltage Terminal kind of Part No. Wiring diagram 24 V AC/DC Push-in Terminal 704.952.129.3 375 104 110 V AC/DC Push-in Terminal 704.952.159.3 375 104 09 51.2 B 14 15.3 17 18 19 29 22.7 Dimensions [mm] B = Push-in terminal (PIT) Wiring diagrams 22 X21(–) X12(+) X22(+) X11(–) 31 41 45 51 Wiring diagram 375 Component layouts 56 57 X12 + + – – X11 – – + + X21 LED 1 LED 2 X22 61 70 Component layout 104 71 82 84 92 96 212 eao.com § 08/2022 Components 04 01 02 Snap-action switching element with push-in terminal Switching voltage Switching current Contacts Contact material Part No. Wiring diagram 250 V 6A 1 NO Gold-plated silver 704.907.1 376 6A 1 NC Gold-plated silver 704.907.2 377 6A 2 NO Gold-plated silver 704.907.3 378 6A 2 NC Gold-plated silver 704.907.4 379 6A 1 NC / 1 NO Gold-plated silver 704.907.5 380 6A 1 NO Silver 704.908.1 376 6A 1 NC Silver 704.908.2 377 6A 2 NO Silver 704.908.3 378 6A 2 NC Silver 704.908.4 379 6A 1 NC / 1 NO Silver 704.908.5 380 03 04 09 14 17 Contacts: NC = Normally closed, NO = Normally open Additional information 18 • For the third switching element the terminal marking insert is to be ordered separately C 26.5 D 40 B 40 44 19 22 25 25 37 A 32 31 41 23 29 45 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 51 56 Wiring diagrams 13 11 13 23 11 21 13 57 21 61 14 12 Wiring diagram 376 Wiring diagram 377 14 24 Wiring diagram 378 12 22 Wiring diagram 379 14 22 70 Wiring diagram 380 71 82 84 92 96 08/2022 § eao.com 213 04 Components 01 02 03 Slow-make switching element with push-in terminal Switching voltage Switching current Contacts Contact material Part No. Wiring diagram 250 V 6A 1 NO Gold-plated silver 704.917.1 376 6A 1 NC Gold-plated silver 704.917.2 377 6A 2 NO Gold-plated silver 704.917.3 378 6A 2 NC Gold-plated silver 704.917.4 379 6A 1 NC / 1 NO Gold-plated silver 704.917.5 380 6A 1 NO Silver 704.918.1 376 6A 1 NC Silver 704.918.2 377 6A 2 NO Silver 704.918.3 378 6A 2 NC Silver 704.918.4 379 6A 1 NC / 1 NO Silver 704.918.5 380 04 09 14 17 18 Contacts: NC = Normally closed, NO = Normally open Additional information • For the third switching element the terminal marking insert is to be ordered separately C D 40 B 40 44 19 22 26.5 25 25 37 A 32 31 41 23 29 45 51 56 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm Wiring diagrams 57 13 11 13 23 11 21 13 21 14 12 14 24 12 22 14 22 Wiring diagram 376 Wiring diagram 377 61 70 71 Wiring diagram 378 Wiring diagram 379 Wiring diagram 380 82 84 92 96 214 eao.com § 08/2022 Components 04 01 02 Snap-action switching element with plug-in terminal Switching voltage Switching current Contacts Contact material Part No. Wiring diagram 500 V 6A 1 NO Silver 704.905.1 376 6A 1 NC Silver 704.905.2 377 6A 2 NO Silver 704.905.3 378 6A 2 NC Silver 704.905.4 379 6A 1 NC / 1 NO Silver 704.905.5 380 03 04 09 Contacts: NC = Normally closed, NO = Normally open Additional information 14 • For the third switching element the terminal marking insert is to be ordered separately 26.5 25 40 D 18 25 A 19 37 C 32 B 40 44 17 22 23 29 31 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 41 45 Wiring diagrams 13 11 13 23 11 21 13 51 21 56 14 12 Wiring diagram 376 Wiring diagram 377 14 24 Wiring diagram 378 12 22 Wiring diagram 379 14 22 57 Wiring diagram 380 61 70 71 82 84 92 96 08/2022 § eao.com 215 04 Components 01 02 03 Slow-make switching element with plug-in terminal Switching voltage Switching current Contacts Contact material Part No. Wiring diagram 500 V 6A 1 NO Silver 704.915.1 376 6A 1 NC Silver 704.915.2 377 6A 2 NO Silver 704.915.3 378 6A 2 NC Silver 704.915.4 379 6A 1 NC / 1 NO Silver 704.915.5 380 04 09 14 Contacts: NC = Normally closed, NO = Normally open Additional information • For the third switching element the terminal marking insert is to be ordered separately 26.5 25 19 45 40 23 29 41 25 A 22 31 D 37 C 32 B 18 40 44 17 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm Wiring diagrams 51 13 11 13 23 11 21 13 21 14 12 14 24 12 22 14 22 Wiring diagram 376 Wiring diagram 377 56 57 61 Wiring diagram 378 Wiring diagram 379 Wiring diagram 380 70 71 82 84 92 96 216 eao.com § 08/2022 Components 04 01 02 Snap-action switching element with double plug-in terminal Switching voltage Switching current Contacts Contact material Part No. Wiring diagram 500 V 6A 1 NO Gold-plated silver 704.901.1/D 376 6A 1 NC Gold-plated silver 704.901.2/D 377 6A 2 NO Gold-plated silver 704.901.3/D 378 6A 2 NC Gold-plated silver 704.901.4/D 379 6A 1 NC / 1 NO Gold-plated silver 704.901.5/D 380 6A 1 NO Silver 704.905.1/D 376 6A 1 NC Silver 704.905.2/D 377 6A 2 NC Silver 704.905.4/D 379 6A 1 NC / 1 NO Silver 704.905.5/D 380 500 V 04 09 14 Contacts: NC = Normally closed, NO = Normally open 17 Additional information 25 18 40 19 22 25 A 31 37 26.5 D 32 C 40 44 • For the third switching element the terminal marking insert is to be ordered separately B 41 23 29 03 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 45 51 Wiring diagrams 56 13 11 13 23 11 21 13 21 14 12 14 24 12 22 14 22 Wiring diagram 376 Wiring diagram 377 Wiring diagram 378 Wiring diagram 379 57 61 70 Wiring diagram 380 71 82 84 92 96 08/2022 § eao.com 217 04 Components 01 02 03 Slow-make switching element with double plug-in terminal Switching voltage Switching current Contacts Contact material Part No. Wiring diagram 500 V 6A 1 NO Silver 704.915.1/D 376 6A 1 NC Silver 704.915.2/D 377 6A 2 NO Silver 704.915.3/D 378 6A 2 NC Silver 704.915.4/D 379 6A 1 NC / 1 NO Silver 704.915.5/D 380 04 09 14 Contacts: NC = Normally closed, NO = Normally open Additional information • For the third switching element the terminal marking insert is to be ordered separately 26.5 19 25 45 40 23 29 41 25 A 22 31 D 37 C 32 B 18 40 44 17 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm Wiring diagrams 51 13 11 13 23 11 21 13 21 57 14 12 14 24 12 22 14 22 61 Wiring diagram 376 Wiring diagram 377 56 Wiring diagram 378 Wiring diagram 379 Wiring diagram 380 70 71 82 84 92 96 218 eao.com § 08/2022 Components 04 01 02 Snap-action switching element with screw terminal Switching voltage Switching current Contacts Contact material Part No. Wiring diagram 500 V 10 A 1 NO Silver 704.900.1 376 10 A 1 NC Silver 704.900.2 377 10 A 2 NO Silver 704.900.3 378 10 A 2 NC Silver 704.900.4 379 10 A 1 NC / 1 NO Silver 704.900.5 380 10 A 1 NO Gold-plated silver 704.901.1 376 10 A 1 NC Gold-plated silver 704.901.2 377 10 A 2 NO Gold-plated silver 704.901.3 378 10 A 2 NC Gold-plated silver 704.901.4 379 10 A 1 NC / 1 NO Gold-plated silver 704.901.5 380 10 A 1 NO Palladium 704.902.1 376 10 A 1 NC Palladium 704.902.2 377 10 A 2 NO Palladium 704.902.3 378 10 A 2 NC Palladium 704.902.4 379 10 A 1 NC / 1 NO Palladium 704.902.5 380 03 04 09 14 17 18 Contacts: NC = Normally closed, NO = Normally open 19 Additional information 26.5 25 31 40 D 22 41 25 A 45 37 C 32 B 40 44 • For the third switching element the terminal marking insert is to be ordered separately 51 23 29 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 56 57 Wiring diagrams 61 13 11 13 23 11 21 13 21 14 12 14 24 12 22 14 22 Wiring diagram 376 Wiring diagram 377 70 71 82 Wiring diagram 378 Wiring diagram 379 Wiring diagram 380 84 92 96 08/2022 § eao.com 219 04 Components 01 02 03 Slow-make switching element with screw terminal Switching voltage Switching current Contacts Contact material Part No. Wiring diagram 500 V 10 A 1 NO Silver 704.910.1 376 10 A 1 NC Silver 704.910.2 377 10 A 2 NO Silver 704.910.3 378 10 A 2 NC Silver 704.910.4 379 10 A 1 NC / 1 NO Silver 704.910.5 380 10 A 1 NO Gold-plated silver 704.911.1 376 10 A 1 NC Gold-plated silver 704.911.2 377 10 A 2 NO Gold-plated silver 704.911.3 378 10 A 2 NC Gold-plated silver 704.911.4 379 10 A 1 NC / 1 NO Gold-plated silver 704.911.5 380 10 A 1 NO Palladium 704.912.1 376 10 A 2 NO Palladium 704.912.3 378 10 A 2 NC Palladium 704.912.4 379 10 A 1 NC / 1 NO Palladium 704.912.5 380 04 09 14 17 18 Contacts: NC = Normally closed, NO = Normally open 19 Additional information • For the third switching element the terminal marking insert is to be ordered separately 26.5 25 45 57 40 25 A 23 29 51 56 D 37 41 C 32 B 40 31 44 22 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm Wiring diagrams 61 13 11 13 23 11 21 13 21 71 14 12 14 24 12 22 14 22 82 Wiring diagram 376 Wiring diagram 377 70 Wiring diagram 378 Wiring diagram 379 Wiring diagram 380 84 92 96 220 eao.com § 08/2022 Components 04 01 02 Snap-action switching element for ring cable shoe with screw terminal Switching voltage Switching current Contacts Contact material Part No. Wiring diagram 500 V 10 A 1 NO Silver 704.900.1B 376 10 A 1 NC Silver 704.900.2B 377 10 A 2 NO Silver 704.900.3B 378 10 A 2 NC Silver 704.900.4B 379 10 A 1 NC / 1 NO Silver 704.900.5B 380 03 04 09 Contacts: NC = Normally closed, NO = Normally open C 40 B 40 44 14 D 17 26.5 25 25 37 32 18 A 19 23 29 22 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 31 Wiring diagrams 13 41 11 13 23 11 21 13 45 21 51 14 12 14 24 12 22 14 22 56 Wiring diagram 376 Wiring diagram 377 Wiring diagram 378 Wiring diagram 379 Wiring diagram 380 57 61 70 71 82 84 92 96 08/2022 § eao.com 221 04 Components 01 02 Switching voltage Switching current Contacts Contact material Part No. Wiring diagram 500 V 10 A 1 NO Silver 704.910.1B 376 10 A 1 NC Silver 704.910.2B 377 10 A 2 NO Silver 704.910.3B 378 10 A 2 NC Silver 704.910.4B 379 10 A 2 NO Gold-plated silver 704.911.3B 378 10 A 2 NC Gold-plated silver 704.911.4B 379 10 A 1 NC / 1 NO Gold-plated silver 704.911.5B 380 04 09 Contacts: NC = Normally closed, NO = Normally open 18 26.5 25 19 41 45 23 29 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm Wiring diagrams 13 11 13 23 11 21 13 21 14 12 14 24 12 22 14 22 Wiring diagram 376 Wiring diagram 377 51 56 57 25 A 22 31 D 40 C 37 B 40 17 44 14 32 03 Slow-make switching element for ring cable shoe with screw terminal Wiring diagram 378 Wiring diagram 379 Wiring diagram 380 61 70 71 82 84 92 96 222 eao.com § 08/2022 Components 04 01 02 Slow-make switching element for emergency stop switch with push-in terminal Switching voltage Switching current Contacts Contact material Part No. Wiring diagram 250 V 6A 1 NO Gold-plated silver 704.917.1 376 6A 1 NC Gold-plated silver 704.917.2 377 6A 2 NO Gold-plated silver 704.917.3 378 6A 2 NC Gold-plated silver 704.917.4 379 6A 1 NC / 1 NO Gold-plated silver 704.917.5 380 6A 1 NO Silver 704.918.1 376 6A 1 NC Silver 704.918.2 377 6A 2 NO Silver 704.918.3 378 6A 2 NC Silver 704.918.4 379 6A 1 NC / 1 NO Silver 704.918.5 380 03 04 09 14 17 Contacts: NC = Normally closed, NO = Normally open Additional information 18 • For the third switching element the terminal marking insert is to be ordered separately C D 40 B 40 44 19 22 26.5 25 25 37 A 32 31 41 23 29 45 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 51 56 Wiring diagrams 13 11 13 23 11 21 13 57 21 61 14 12 Wiring diagram 376 Wiring diagram 377 14 24 Wiring diagram 378 12 22 Wiring diagram 379 14 22 70 Wiring diagram 380 71 82 84 92 96 08/2022 § eao.com 223 04 Components 01 02 03 Slow-make switching element for emergency stop switch with plug-in terminal Switching voltage Switching current Contacts Contact material Part No. Wiring diagram 500 V 6A 1 NO Silver 704.915.1 376 6A 1 NC Silver 704.915.2 377 6A 2 NO Silver 704.915.3 378 6A 2 NC Silver 704.915.4 379 6A 1 NC / 1 NO Silver 704.915.5 380 04 09 14 Contacts: NC = Normally closed, NO = Normally open Additional information • For the third switching element the terminal marking insert is to be ordered separately 26.5 25 19 45 40 23 29 41 25 A 22 31 D 37 C 32 B 18 40 44 17 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm Wiring diagrams 51 13 11 13 23 11 21 13 21 14 12 14 24 12 22 14 22 Wiring diagram 376 Wiring diagram 377 56 57 61 Wiring diagram 378 Wiring diagram 379 Wiring diagram 380 70 71 82 84 92 96 224 eao.com § 08/2022 Components 04 01 02 Slow-make switching element for emergency stop switch with double plug-in terminal Switching voltage Switching current Contacts Contact material Part No. Wiring diagram 500 V 6A 1 NO Silver 704.915.1/D 376 6A 1 NC Silver 704.915.2/D 377 6A 2 NO Silver 704.915.3/D 378 6A 2 NC Silver 704.915.4/D 379 6A 1 NC / 1 NO Silver 704.915.5/D 380 03 04 09 Contacts: NC = Normally closed, NO = Normally open Additional information 14 • For the third switching element the terminal marking insert is to be ordered separately 26.5 25 40 D 18 25 A 19 37 C 32 B 40 44 17 22 23 29 31 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 41 45 Wiring diagrams 13 11 13 23 11 21 13 51 21 56 14 12 Wiring diagram 376 Wiring diagram 377 14 24 Wiring diagram 378 12 22 Wiring diagram 379 14 22 57 Wiring diagram 380 61 70 71 82 84 92 96 08/2022 § eao.com 225 04 Components 01 02 03 Slow-make switching element for emergency stop switch with screw terminal Switching voltage Switching current Contacts Contact material Part No. Wiring diagram 500 V 10 A 1 NO Silver 704.910.1 376 10 A 1 NC Silver 704.910.2 377 10 A 2 NO Silver 704.910.3 378 10 A 2 NC Silver 704.910.4 379 10 A 1 NC / 1 NO Silver 704.910.5 380 10 A 1 NO Gold-plated silver 704.911.1 376 10 A 1 NC Gold-plated silver 704.911.2 377 10 A 2 NO Gold-plated silver 704.911.3 378 10 A 2 NC Gold-plated silver 704.911.4 379 10 A 1 NC / 1 NO Gold-plated silver 704.911.5 380 10 A 1 NO Palladium 704.912.1 376 10 A 2 NO Palladium 704.912.3 378 10 A 2 NC Palladium 704.912.4 379 10 A 1 NC / 1 NO Palladium 704.912.5 380 04 09 14 17 18 Contacts: NC = Normally closed, NO = Normally open 19 Additional information • For the third switching element the terminal marking insert is to be ordered separately 26.5 25 45 57 40 25 A 23 29 51 56 D 37 41 C 32 B 40 31 44 22 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm Wiring diagrams 61 13 11 13 23 11 21 13 21 71 14 12 14 24 12 22 14 22 82 Wiring diagram 376 Wiring diagram 377 70 Wiring diagram 378 Wiring diagram 379 Wiring diagram 380 84 92 96 226 eao.com § 08/2022 Components 04 01 02 Slow-make switching element failsafe Part No. Wiring diagram 704.910.4FS 381 704.911.4FS 381 704.910.4BFS 381 704.911.4BFS 381 Plug-in terminal 704.915.4FS 381 Double plug-in terminal 704.911.4/DFS 381 Silver Double plug-in terminal 704.915.4/DFS 381 Gold-plated silver Push-in Terminal 704.917.4FS 381 Silver Push-in Terminal 704.918.4FS 381 Contacts Contact material Terminal Product attributes 1 NC / 1 FS Silver Screw terminal Gold-plated silver Screw terminal Silver Screw terminal For ring cable shoe Gold-plated silver Screw terminal For ring cable shoe Silver Gold-plated silver 03 04 09 14 Contacts: NC = Normally closed, NO = Normally open 26.5 19 25 A 32 25 18 40 D 22 37 C 40 B 44 17 23 29 31 Dimensions [mm] A = Screw terminal B = Push-in terminal (PIT) C = Plug-in terminal 6.3 mm x 0.8 mm D = Double plug-in terminal 6.3 mm x 0.8 mm 41 45 Wiring diagrams 51 A 11 21 B C 11 21 11 21 56 57 12 22 FS 12 22 FS 12 22 FS 61 Wiring diagram 381 70 71 Kraus Naimer rotary switching element 30° Switching positions Rotary positions Multi-step switch Stages Terminal Part No. Wiring diagram A = Rest, I = End 9 1-pole 5 Screw terminal 704.8A236 382 A = Rest, K = End 10 1-pole 5 Screw terminal 704.8A237 383 A = Rest, L = End 11 1-pole 6 Screw terminal 704.8A238 384 A = Rest, M = End 12 1-pole 6 Screw terminal 704.8A239 385 A = Rest (without stop) 12 1-pole 6 Screw terminal 704.8A639 385 82 84 92 96 08/2022 § eao.com 227 04 Components 01 02 03 Wiring diagrams 9 13 17 5 9 15 1 3 2 13 17 9 19 5 1 3 2 7 13 17 21 5 1 2 11 15 19 15 21 1 7 11 17 5 3 7 13 9 3 2 23 7 19 11 15 11 04 Wiring diagram 382 Wiring diagram 383 Wiring diagram 384 Wiring diagram 385 09 14 Kraus Naimer rotary switching element 45° 17 18 Switching positions Rotary positions Multi-step switch Stages Terminal Part No. Wiring diagram A = Rest, G = End 7 1-pole 4 Screw terminal 704.8A234 386 7 2-pole 7 Screw terminal 704.8A254 387 8 1-pole 4 Screw terminal 704.8A235 388 8 2-pole 8 Screw terminal 704.8A255 389 A = Rest, H = End 19 Additional information 22 31 • Switching positions and functions of the rotary switching element are being produced according to customer specifications. Please contact your local EAO Sales Office Wiring diagrams 41 5 45 1 9 13 3 2 5 1 25 9 13 7 51 11 56 Wiring diagram 386 3 2 11 7 Wiring diagram 387 17 5 15 21 2 27 19 23 1 15 9 3 2 11 7 Wiring diagram 388 25 9 13 13 5 1 3 2 15 21 7 11 17 15 19 18 31 23 27 Wiring diagram 389 57 61 70 71 82 84 92 96 228 eao.com § 08/2022 Components 04 01 Kraus Naimer rotary switching element 60° Switching positions Rotary positions Multi-step switch Stages Terminal Part No. Wiring diagram A = Rest, C = End 3 1-pole 2 Screw terminal 704.8A230 390 3 1-pole, galvanically isolated 2 Screw terminal 704.8A730 391 3 2-pole 3 Screw terminal 704.8A250 392 3 3-pole 5 Screw terminal 704.8A270 393 4 1-pole 2 Screw terminal 704.8A231 394 4 1-pole, galvanically isolated 2 Screw terminal 704.8A731 395 4 2-pole 4 Screw terminal 704.8A251 396 4 3-pole 6 Screw terminal 704.8A271 397 5 1-pole 3 Screw terminal 704.8A232 398 5 2-pole 5 Screw terminal 704.8A252 399 5 3-pole 8 Screw terminal 704.8A272 400 6 1-pole 3 Screw terminal 704.8A233 401 6 2-pole 6 Screw terminal 704.8A253 402 A = Rest, D = End A = Rest, E = End A = Rest, F = End 02 03 04 09 14 17 Additional information 18 • Switching positions and functions of the rotary switching element are being produced according to customer specifications. Please contact your local EAO Sales Office 19 22 31 41 45 51 EAO Downloads. www.eao.com/downloads 56 EAO creates possibilities. Since 1947. 57 61 70 71 On our website you can download technical data, assembly instructions, catalogs, brochures and much more. 82 84 92 www.eao.com 08/2022 § eao.com 96 229 04 Components 01 Wiring diagrams 3 02 5 1 3 1 2 03 3 5 4 2 7 1 6 11 5 9 2 6 04 Wiring diagram 390 09 14 9 5 1 Wiring diagram 391 11 7 3 2 Wiring diagram 392 15 13 4 17 5 7 1 14 3 2 17 18 Wiring diagram 393 Wiring diagram 394 5 19 1 2 7 6 5 8 3 4 7 1 13 3 2 15 9 11 10 22 31 Wiring diagram 395 41 45 5 1 Wiring diagram 396 7 13 3 2 9 21 15 11 10 17 23 5 19 18 1 9 3 2 9 5 1 3 2 7 11 17 13 15 2 7 19 51 56 57 Wiring diagram 397 Wiring diagram 399 Wiring diagrams 61 70 Wiring diagram 398 5 1 9 3 2 11 17 13 15 2 19 7 25 21 5 29 23 2 27 1 9 3 2 11 5 7 1 9 3 2 11 17 7 13 21 15 14 23 19 71 82 Wiring diagram 400 Wiring diagram 401 Wiring diagram 402 84 92 96 230 ​ eao.com § 08/2022 Components 04 01 Santon rotary switching element 30° Switching positions Rotary positions Multi-step switch Stages Terminal Part No. Wiring diagram A = Rest, I = End 9 1-pole 5 Screw terminal 704.F100001 443 A = Rest, K = End 10 1-pole 5 Screw terminal 704.F100002 444 A = Rest, L = End 11 1-pole 6 Screw terminal 704.F100003 445 A = Rest, M = End 12 1-pole 6 Screw terminal 704.F100004 442 A = Rest, M = End 12 1-pole 6 Screw terminal 704.F100015 442 A = Rest, I = End 9 1-pole 5 Plug-in terminal 704.F1A00001 443 A = Rest, K = End 10 1-pole 5 Plug-in terminal 704.F1A00002 444 A = Rest, L = End 11 1-pole 6 Plug-in terminal 704.F1A00003 445 A = Rest, M = End 12 1-pole 6 Plug-in terminal 704.F1A00004 442 A = Rest, M = End 12 1-pole 6 Plug-in terminal 704.F1A00015 442 02 03 04 09 14 Additional information 17 • Switching positions and functions of the rotary switching element are being produced according to customer specifications. Please contact your local EAO Sales Office 18 Wiring diagrams 19 9 13 17 5 9 21 1 4 2 24 13 17 5 1 4 2 8 20 16 12 Wiring diagram 442 9 16 13 17 5 1 4 2 8 12 Wiring diagram 443 9 20 13 16 Wiring diagram 444 5 22 21 1 4 2 8 12 4 17 5 1 2 8 20 16 31 12 Wiring diagram 445 41 Wiring diagram 446 45 51 56 57 61 70 71 82 84 92 96 08/2022 § eao.com 231 04 Components 01 Santon rotary switching element 45° 02 Switching positions 03 04 09 14 17 18 Multi-step switch Stages Terminal Wiring diagram Part No. A = Rest, G = End 7 1-pole 4 Screw terminal 704.F100019 459 A = Rest, G = End 7 2-pole 7 Screw terminal 704.F100020 460 A = Rest, H = End 8 1-pole 4 Screw terminal 704.F100021 461 A = Rest, H = End 8 2-pole 8 Screw terminal 704.F100022 462 A = Rest, G = End 7 1-pole 4 Plug-in terminal 704.F1A00019 459 A = Rest, G = End 7 2-pole 7 Plug-in terminal 704.F1A00020 460 A = Rest, H = End 8 1-pole 4 Plug-in terminal 704.F1A00021 461 A = Rest, H = End 8 2-pole 8 Plug-in terminal 704.F1A00022 462 Additional information • Switching positions and functions of the rotary switching element are being produced according to customer specifications. Please contact your local EAO Sales Office Wiring diagrams 19 22 Rotary positions 9 1 9 13 5 4 2 1 25 13 5 21 4 2 17 20 15 8 8 16 24 12 12 28 Wiring diagram 459 Wiring diagram 460 31 41 9 45 1 56 8 12 Wiring diagram 461 1 21 4 2 16 25 13 5 4 2 16 51 9 13 5 8 12 17 32 18 29 20 24 28 Wiring diagram 462 57 61 70 71 82 84 92 96 232 eao.com § 08/2022 Components 04 01 Santon rotary switching element 60° Switching positions Rotary positions Multi-step switch Stages Terminal Part No. Wiring diagram A = Rest, D = End 4 4-pole 2 Screw terminal 704.F100005 451 A = Rest, C = End 3 1-pole 2 Screw terminal 704.F100006 446 A = Rest, C = End 3 2-pole 3 Screw terminal 704.F100007 448 A = Rest, C = End 3 3-pole 5 Screw terminal 704.F100008 449 A = Rest, D = End 4 1-pole 2 Screw terminal 704.F100009 450 A = Rest, D = End 4 2-pole 4 Screw terminal 704.F100010 452 A = Rest, D = End 4 3-pole 6 Screw terminal 704.F100011 453 A = Rest, E = End 5 1-pole 3 Screw terminal 704.F100012 454 A = Rest, E = End 5 2-pole 5 Screw terminal 704.F100013 455 A = Rest, E = End 5 3-pole 8 Screw terminal 704.F100014 456 A = Rest, F = End 6 1-pole 3 Screw terminal 704.F100016 457 A = Rest, F = End 6 2-pole 6 Screw terminal 704.F100017 458 A = Rest, C = End 3 3-pole 2 Screw terminal 704.F100018 447 A = Rest, D = End 4 4-pole 2 Plug-in terminal 704.F1A00005 451 A = Rest, C = End 3 1-pole 2 Plug-in terminal 704.F1A00006 446 A = Rest, C = End 3 2-pole 3 Plug-in terminal 704.F1A00007 448 A = Rest, C = End 3 3-pole 5 Plug-in terminal 704.F1A00008 449 A = Rest, D = End 4 1-pole 2 Plug-in terminal 704.F1A00009 450 A = Rest, D = End 4 2-pole 4 Plug-in terminal 704.F1A00010 452 A = Rest, D = End 4 3-pole 6 Plug-in terminal 704.F1A00011 453 A = Rest, E = End 5 1-pole 3 Plug-in terminal 704.F1A00012 454 A = Rest, E = End 5 2-pole 5 Plug-in terminal 704.F1A00013 455 A = Rest, E = End 5 3-pole 8 Plug-in terminal 704.F1A00014 456 A = Rest, F = End 6 1-pole 3 Plug-in terminal 704.F1A00016 457 A = Rest, F = End 6 2-pole 6 Plug-in terminal 704.F1A00017 458 A = Rest, C = End 3 3-pole 2 Plug-in terminal 704.F1A00018 447 02 03 04 09 14 17 18 19 22 31 41 Additional information 45 • Switching positions and functions of the rotary switching element are being produced according to customer specifications. Please contact your local EAO Sales Office 51 56 57 61 70 71 82 84 92 96 08/2022 § eao.com 233 04 Components 01 Wiring diagrams 4 02 5 1 1 2 03 5 4 2 3 5 9 1 6 7 11 3 2 4 04 Wiring diagram 446 09 14 9 5 1 Wiring diagram 447 11 7 3 2 Wiring diagram 448 16 13 4 17 5 8 1 14 4 2 17 18 Wiring diagram 449 Wiring diagram 450 5 19 1 2 5 8 6 7 4 3 8 1 13 4 2 16 9 12 10 22 31 Wiring diagram 451 41 45 5 1 Wiring diagram 452 8 13 4 2 9 21 16 12 10 17 24 5 20 18 1 9 4 2 9 5 1 4 2 8 11 18 14 15 12 8 19 51 56 Wiring diagram 453 5 57 1 61 70 Wiring diagram 454 9 4 2 11 18 14 15 12 19 8 Wiring diagram 456 25 21 5 29 24 22 28 1 9 5 4 2 12 Wiring diagram 455 8 Wiring diagram 457 1 9 4 2 12 17 8 13 21 16 14 24 20 Wiring diagram 458 71 82 84 92 96 234 ​ eao.com § 08/2022 Components 04 01 Flasher element 02 Product attributes Terminal Part No. Wiring diagram Lamp voltage/-current 130 V, 20 mA Screw terminal 704.943.0 374 Lamp voltage/- current 60 V, 33 mA Screw terminal 704.943.1 374 Lamp voltage/-current 130 V, 3 mA Push-in Terminal 704.943.2P 374 Screw terminal 704.943.2 374 Screw terminal 704.943.5 374 Lamp voltage/-current 24 V, 10 … 85 mA 03 04 37 B 32 09 14 35 17 e c d f A 29 18 28 19 Dimensions [mm] A = Screw terminal Push-in terminal (PIT) 22 Wiring diagrams 31 (+) DC e d c f (-) x2+ 41 x1- 45 51 Wiring diagram 374 56 57 61 70 71 82 84 92 96 08/2022 § eao.com 235 04 Components 01 Lamp transformer 02 03 04 09 Part No. Wiring diagram 704.970.3 371 704.970.4 371 704.970.5 371 704.970.6 371 Additional information • Lamp voltage/-current 24 VAC, 50 mA, 50/60 Hz X1 2 34 1 X2 37 14 17 29.5 46 18 19 Dimensions [mm] 22 31 41 45 Wiring diagrams 115 VAC 230 VAC 400 VAC 440 VAC 1 x1 24 VAC 2 x2 51 Wiring diagram 371 56 57 61 70 71 82 84 92 96 236 eao.com § 08/2022 Accessories 04 Front side 01 02 03 04 Legend frame Product attributes Dimensions Material Colour Surface Mounting type Part No. For raised design 30 mm x 0.75 mm x 50 mm aluminium Black anodised adhesive 704.968.2 For flush design 35 mm x 0.75 mm x 57.5 mm aluminium Black anodised adhesive 704.968.3 09 14 Additional information • The colour of anodised aluminium parts can vary due to technical production reasons 0.75 4 14.5 18 0.75 19 Ø 30.6 40 57.5 4 14.5 23.5 Ø22.6 50 35 23.5 17 22 30 35 31 Dimensions [mm] for Part No. 704.968.2 Dimensions [mm] for Part No. 704.968.3 41 45 Legend plate 51 Dimensions Material Colour Surface Mounting type Part No. 14.5 mm x 23.5 mm aluminium Nature anodised adhesive 704.968.0 aluminium Black anodised adhesive 704.968.1 56 Additional information 57 • For legend frame Part No.704.968.2 and 704.968.3 • The colour of anodised aluminium parts can vary due to technical production reasons 61 70 71 Legend plate flush design Dimensions Material Colour Surface Mounting type Part No. 18 mm x 35 mm aluminium Nature anodised adhesive 704.968.4 aluminium Black anodised adhesive 704.968.5 82 84 Additional information • For devices square with flush design • The colour of anodised aluminium parts can vary due to technical production reasons 92 96 08/2022 § eao.com 237 04 Accessories 01 02 03 Emergency stop legend Dimensions Material Colour Mounting cut-out Marking Part No. Ø 60 mm plastic Yellow Ø 22.3 mm NOT AUS 704.963.5 04 09 Ø 90 mm 14 17 plastic Yellow Ø 22.3 mm EMERGENCY STOP 704.963.6 plastic Yellow Ø 22.3 mm ARRET D‘URGENCE 704.963.7 plastic Yellow Ø 22.3 mm NOT HALT 704.963.8 plastic Yellow Ø 22.3 mm EN ISO 13850 symbol 704.963.9 plastic Yellow Ø 22.3 mm NOT AUS 704.963.0 plastic Yellow Ø 22.3 mm EMERGENCY STOP 704.963.1 plastic Yellow Ø 22.3 mm ARRET D‘URGENCE 704.963.2 plastic Yellow Ø 22.3 mm NOT HALT 704.963.3 plastic Yellow Ø 22.3 mm EN ISO 13850 symbol 704.963.4 Additional information • Front panel thickness 3 mm max. 18 19 22 31 41 Legend plate rotary switch Product attributes Dimensions Material Colour Surface Mounting type Part No. For raised design Ø 29 mm 48 mm x 48 mm aluminium Black anodised adhesive 704.968.10 For flush design Ø 35 mm 48 mm x 48 mm aluminium Black anodised adhesive 704.968.11 For raised design Ø 29 mm 48 mm x 60 mm aluminium Black anodised adhesive 704.968.12 Additional information 45 • The colour of anodised aluminium parts can vary due to technical production reasons 51 56 57 61 70 71 82 84 92 96 238 eao.com § 08/2022 Accessories 04 01 Blind plug Dimensions Material Colour Mounting cut-out Part No. Ø 28 mm plastic Black Ø 22.3 mm 704.960.4 Ø 22.5 mm plastic Black Ø 22.3 mm 704.964.7 Ø 36 mm plastic Black Ø 30.5 mm 704.964.8 35 mm x 35 mm plastic Black 30 mm x 30 mm 704.964.9 02 03 04 Additional information • Please note that bigger minimum distances are necessary 4.8 09 20 2.5 12 2.6 14 Ø 35.6 18 2…6 Dimensions [mm] for Part No. 704.964.7 19 Dimensions [mm] for Part No. 704.964.8 22 15 31 35 x 35 3 17 2…6 2.5 ... 6 Dimensions [mm] for Part No. 704.960.4 Ø 36.2 Ø 27.5 30 x 30 Ø 30 Ø 28 14 41 2 ... 6 45 Dimensions [mm] for Part No. 704.964.9 51 56 Spare key Product attributes Material Part No. The standard lock Ronis 251 metal 704.989.251 57 61 70 Protective cap Product attributes Material Colour Optics Part No. Only together with lenses Part No. 704.602.X, 704.601.X and front rings Part No. 704.600.X silicone Colourless transparent 704.953.0 71 82 Additional information • For Indicator and Illuminated pushbutton for IP68 protection 84 92 96 08/2022 § eao.com 239 04 Accessories 01 Protective ring 02 Product attributes 03 04 Material With transparent silicone membrane (resistant to sea brass water), temperature resistance -40 °C … +85 °C aluminium With transparent Pebax membrane, temperature resistance -40 °C … +85 °C aluminium Colour Surface Part No. chrome 704.600.2 Nature anodised 704.600.3 Nature anodised 704.600.5/A Additional information 09 • For Illuminated pushbutton for front protection IP 67 • The colour of anodised aluminium parts can vary due to technical production reasons 14 17 22 Material Optics Part No. plastic transparent 704.925.0 With spring fitted, for pushbutton plastic transparent 704.925.3 For selector switch plastic transparent 704.925.2 Additional information • Hinged, with means for sealing 31 44 41 30 1.5 18 44 19 Product attributes For pushbutton 37 18 Protective cover raised design 45 3 20 51 Dimensions [mm] 56 57 61 70 71 82 84 92 96 240 eao.com § 08/2022 Accessories 04 01 Protective cover square flush design 02 Product attributes Dimensions Material Optics Mounting cut-out Part No. For pushbutton 38.5 mm x 45 mm plastic transparent 30 mm x 30 mm 704.925.8 For selector switch 38.5 mm x 45 mm plastic transparent 30 mm x 30 mm 704.925.9 03 Additional information 04 • Hinged, with means for sealing • Front panel thickness reduces by 2 mm 09 • Please note that bigger minimum distances are necessary 14 38.5 17 19 45 42 54 18 1.8 13 19 Dimensions [mm] 22 31 Protective cover round flush design Surface 41 Product attributes Dimensions Material Colour Part No. With means for sealing, for pushbutton with mounting cut-outs Ø 30.5 mm 37 mm x 44.5 mm plastic Colourless Without cover locking hole, with spring fitted, with window, for pushbuttonwith mounting cut-outs Ø 30.5 mm 38 mm x 50 mm aluminium Nature anodised 704.928.18 Without cover locking hole, for pushbutton and selector switch short lever with mounting cut-outs Ø 30.5 mm 38 mm x 50 mm aluminium Nature anodised 704.928.28 51 With means for sealing, for pushbutton and selector switch short lever with mounting cut-outs Ø 30.5 mm 38 mm x 50 mm aluminium Nature anodised 704.928.38 56 704.925.7 45 57 Additional information • Hinged 61 • Front panel thickness reduces by 2 mm • Please note that bigger minimum distances are necessary 70 • The colour of anodised aluminium parts can vary due to technical production reasons 9.5 58 71 38 24.5 50 54 50 82 24.5 44.5 38 44 52 37 22.5 44.5 9 84 19 92 Dimensions [mm] for Part No. 704.925.7 08/2022 § eao.com Dimensions [mm] for Part No. 704.928.18 Dimensions [mm] for Part No. 704.928.28, 704.928.38 96 241 04 Accessories 01 E stop protective shroud 02 03 Dimensions Material Colour Ø 65 mm plastic Yellow plastic Yellow plastic plastic 04 Marking IK Protection Part No. IK 07 704.927.6 NOT-AUS IK 07 704.927.6A Yellow EMERGENCY-STOP IK 07 704.927.6B Yellow EMERGENCY-STOP / NOT-AUS IK 07 704.927.6C Additional information 09 • Front panel thickness 1 … 2.5 mm other actuators • Front panel thickness 1 … 2.5 mm with emergency stop switch 14 • With anti-twist device • When using a protective shroud the e-stop or stop-switch has to be turned by 180° to be mounted. See dimensional drawing 17 • Do not use solvents when cleaning 18 20 1.8 Ø37 19 Ø 65 Ø22.5 ± 0.1 2 22 31 Dimensions [mm] 41 45 51 Protective shroud Product attributes Dimensions Material Colour Part No. Use only for Part No. 704.064.2 und 704.066.2 Ø 50 mm plastic Yellow 704.927.8 Ø 83 mm plastic Yellow 704.927.9 56 Additional information • Use only for Part No. 704.064.2 und 704.066.2 3 Ø83 +0.4 0 50 82 84 Ø22.3 71 Ø22.3 +0.4 0 20 70 30 61 • The protection shroud Part is not suitable for a proper use of emergency-stop. It can obstruct a spontaneous operation of the emergency-stop switch Ø50 57 3 50 Dimensions [mm] Dimensions [mm] 92 96 242 eao.com § 08/2022 Accessories 04 01 02 Marking foil square Product attributes Material Colour Optics Part No. For lens square, front illumination plastic Colourless transparent 704.707.7 For lens square, full-face illumination plastic Colourless transparent 704.706.7 03 04 Additional information 09 • Can be hot stamped 14 17 18 19 22 31 41 45 51 EAO Downloads. www.eao.com/downloads 56 EAO creates possibilities. Since 1947. 57 61 70 71 On our website you can download technical data, assembly instructions, catalogs, brochures and much more. 82 84 92 www.eao.com 08/2022 § eao.com 96 243 04 Accessories 01 Rear side 02 03 09 Terminal Part No. Wiring diagram Push-in Terminal 704.942.5P 370 Screw terminal 704.942.5 370 B 37 14 35 17 e c 18 d f A 29 19 22 31 32 04 Diode block 28 Dimensions [mm] A = Screw terminal Push-in terminal (PIT) Wiring diagrams 41 e d c f 45 51 Wiring diagram 370 56 57 61 70 Terminal cover Product attributes Material Part No. For covering of screw terminal plastic 704.964.5 38 42 71 82 29 3.5 84 92 Dimensions [mm] 96 244 eao.com § 08/2022 Accessories 04 01 Terminal marking Product attributes Marking Part No. 2 NO for 1st or 2nd switching element 13/23 33/43 704.965.1 24/14 44/34 704.965.2 53/63 73/83 704.965.3 64/54 84/74 704.965.4 11/21 31/41 704.965.5 22/12 42/32 704.965.6 51/61 71/81 704.965.7 62/52 82/72 704.965.8 13/21 33/41 704.965.9 22/14 42/34 704.966.0 53/61 73/81 704.966.1 62/54 82/74 704.966.2 2 NO for 3rd switching element 2 NC for 1st or 2nd switching element 2 NC for 3rd switching element 1 NC + 1 NO for 1st or 2nd switching element 1 NC + 1 NO for 3rd switching element 02 03 04 09 14 17 Side terminal plate empty Product attributes Dimensions Part No. 5 spaces 62.5 mm x 15 mm x 60 mm 02-912.1 10 spaces 125 mm x 15 mm x 60 mm 02-912.2 15 spaces 187.6 mm x 15 mm x 60 mm 02-912.3 20 spaces 250 mm x 15 mm x 60 mm 02-912.4 18 19 22 31 Contact bridge Material Part No. metal 704.990.1 41 45 Additional information • For switching element with screw terminals • Do not insert by Emergency-stopp switches and by stop switches 51 • Available in unit of 10 pieces 56 57 Resistor block Product attributes Material Operating voltage Terminal Part No. Wiring diagram Lamp voltage/-current 130 V, 20 mA plastic 130 - 230 V AC Screw terminal 704.941.0 372 Lamp voltage/- current 60 V, 33 mA plastic 33 - 60 V AC Push-in Terminal 704.941.5P 372 plastic 33 - 60 V AC Screw terminal 704.941.5 372 61 70 B 32 37 71 82 35 e c d f 29 84 A 92 28 Dimensions [mm] A = Screw terminal Push-in terminal (PIT) 08/2022 § eao.com 96 245 04 Accessories 01 02 03 Wiring diagrams 230 VAC 125 VAC d 130 VAC/20 mA 60 VAC/33 mA c 04 x1- x2+ Wiring diagram 372 09 14 Side resistor diode block 17 Material Operating voltage Terminal Part No. Wiring diagram Lamp voltage/-current 130 V, 20 mA plastic 130 - 230 V AC Screw terminal 704.941.9 373 19 37 B 22 35 31 e c 51 56 57 d f A 29 41 45 32 18 Product attributes 28 Dimensions [mm] A = Screw terminal Push-in terminal (PIT) Wiring diagrams 230 VAC d e 130 VAC/20 mA c 61 x1- Wiring diagram 373 70 71 82 84 92 96 246 eao.com § 08/2022 Accessories 04 Mounting 01 02 03 Enclosure Product attributes Dimensions Material Colour IP Protection Bottom grey similar RAL 7035; cover lead-sealable, yellow similar RAL 1004 94 mm x 81 mm x 94 mm plastic Grey IP66 Part No. 704.945.0 65 mm x 81 mm x 65 mm plastic Grey IP66 704.945.7 plastic Grey IP66 704.945.8 94 mm x 81 mm x 94 mm plastic Grey IP66 704.945.1 with mounting cut-out 2 x Ø 22.3 mm, with anti-twist device 130 mm x 81 mm x 94 mm plastic Grey IP66 704.945.2 with mounting cut-out 3 x Ø 22.3 mm, with anti-twist device 180 mm x 81 mm x 94 mm plastic Grey IP66 704.945.3 with mounting cut-out 4 x Ø 22.3 mm, with anti-twist device 180 mm x 110 mm x 182 mm plastic Grey IP66 704.945.4 with mounting cut-out 6 x Ø 22.3 mm, with anti-twist device 180 mm x 110 mm x 182 mm plastic Grey IP66 704.945.5 14 17 B 19 22 L H B L H 09 18 2.5 2.5 94 mm x 81 mm x 65 mm With mounting cut-out 1 x Ø 22.5 mm, with anti-twist device 04 31 Dimensions [mm] 41 Dimensions [mm] 45 Lens plug 51 Product attributes Material Part No. For mounting and dismantling of the round lens, flush design plastic 700.006.0 56 57 Lens remover Product attributes Material Part No. For dismantling of the square lens, flush design metal 98-968 61 70 71 Cable gland Product attributes Material Colour IP Protection Thread Part No. With traction relief plastic Grey IP68 M16 x 1.5 mm 61-9481.6 plastic Grey IP68 M20 x 1.5 mm 704.945.6 82 84 92 96 08/2022 § eao.com 247 04 Accessories 01 02 03 Mounting plate Product attributes Material Colour Part No. For separate mounting of lamp transformer, resistor block or capacitor block plastic Grey 704.940.8 32 3 04 09 29 14 10 1.5 17 18 Dimensions [mm] 19 22 Mounting tool indicator Product attributes Material Part No. For Indicators full-face illumination, compact metal 700.005.0 31 41 45 Mounting tool key insert switch and conductor switch Product attributes Material Part No. For key insert switch metal 704.990.0 51 56 Reducing ring 57 Product attributes 61 With slot for anti-twist device Material Colour Surface Part No. aluminium Black anodised 704.960.0 aluminium Nature anodised 704.960.8 aluminium Nature anodised 704.960.8A Additional information 70 • Devices Ø 22.3 mm in mounting cut-out Ø 30.5 mm • The colour of anodised aluminium parts can vary due to technical production reasons 71 2 92 96 Ø35 84 Ø22.6 Ø30.4 82 2.8 Dimensions [mm] 248 eao.com § 08/2022 Accessories 04 01 02 On base Material Colour plastic Black plastic Colourless 29 Optics 03 Part No. 704.940.9 transparent 704.941.1 04 09 37 43 32 Product attributes To snap-on, for seperate mounting of lamp transformer, resistor block or capacitor block 8 14 1.5 17 Dimensions [mm] 18 Dimensions [mm] 19 22 31 Reinforcement ring Dimensions Material Surface Part No. 44 mm x 3 mm x 29 mm steel_plate galvanized 704.960.9 41 Additional information 45 • For thin front panels and plastic case 51 56 57 61 70 71 82 84 92 96 08/2022 § eao.com 249 04 Technical data 01 Slow-make switching element with VDE and UKCA 02 When using the switching element, the application guidelines must be observed. 03 Switching system 04 The double-break, slow-make switching element is equipped with one or two independent contact systems, acting as normally open or normally closed contact. The normally closed contact has forced opening. 09 14 Plug-in terminal 1 x 6.3 mm x 0.8 mm or 2 x 2.8 mm x 0.8 mm For devises with plug-in connections, insulating sleeves are required and the mounting cut-out of 65 mm must be observed. Double plug-in terminal 2 x 6.3 mm x 0.8 mm For units with plug-in connections, insulating sleeves are required and the mounting cut-out of 65 mm must be observed. Tightening torque Slow-make contacts with forced action are ideal for high switch ratings. Screws at the plastic mounting flange max. 0.4 … 0.5 Nm Screws at the metal mounting flange max. 0.25 … 0.3 Nm Screws at switching element max. 0.8 Nm Up to three switching elements can be snapped to each actuator. 17 18 19 Actuating force For the emergency-stop switch use the slow-make switching element (max. 2). 1 Normally closed 2 N 1 Normally open 3 N Special requirements for positive-opening auxiliary current switches Actuating travel Positive opening travel Minimum force Approx. 5.8 mm ± 0.2 mm 22 Max. travel 31 Material 41 45 Emergency stop 12.5 mm Emergency stop 50 N (actuating force at which is safely switched) Emergency stop 12.5 mm Housing The indicator lights / switches may be installed in enclosures with protection class 2 according to DIN EN 61140. The enclosure must at least have enclosure class 2 according to UL50E. Mechanical lifetime (with 1 switching element) Pushbutton maintained action 1.5 million cycles of operation Pushbutton momentary action 3 million cycles of operation Selector switch maintained action 1.25 million cycles of operation Selector switch momentary action 2.5 million cycles of operation Emergency-stop switch 50 000 cycles of operation Keylock switch maintained action 25 000 cycles of operation Keylock switch momentary action 50 000 cycles of operation Electrical characteristics 51 Material of contact Hard silver, gold-silver, silver-palladium (for aggressive atmospheres) Standards 56 Switch housing The switches comply with the “Standards for low-voltage switching devices” DIN EN 60947-5-1 Plastic Rated Insulation Voltage Ui 57 500 V, as per DIN EN 60947-5-1 Mechanical characteristics 61 70 71 82 84 92 Rated impulse withstand voltage Uimp 4 kV, according to EN / IEC 60947-5-1 Terminals Screw terminal - max. wire cross section - stripping length wire - max. number of wire 2.5 mm2 10 mm 2 Electrical life 50 000 cycles of operation Thermal current Ith - max. strand cross section - stripping strands - max. number of strands 1.5 mm2 use stranded wires only with wire end ferrules of 10 mm length 2 Max. current at continuous operation and limit temperatures which do not exceed the specified max. values. 10 A Only one polarity is allowed on each side when wiring. 96 250 ​ eao.com § 08/2022 Technical data 04 Protection degree Switching voltage and switching current 01 IP00 as per EN IEC 60947-5-1 voltage DC13 AC15 Shock resistance 24 V 60 V 110 V 120 V 230 V 400 V 500 V 4.0 A 1.5 A 1.0 A 8.0 A 8.0 A (single impacts, semi-sinusoidal) 300 m / s² pulse width 11 ms, as per EN IEC 60068-2-27 8.0 A 7.0 A 5.0 A 4.0 A Vibration resistance 0.4 A 0.2 A 0.15 A 03 (sinusoidal) 100 m / s² at 10 Hz … 500 Hz, amplitude 0.75 mm, as per EN IEC 60068-2-6 Recommended minimum operational data Pollution degree Gold-silver contacts: Voltage 24 VDC 110 VDC Current 5 mA 2 mA 3 Hard silver contacts: Voltage 24 VDC 110 VDC Current 50 mA 10 mA 02 04 09 14 Climatic resistance Relative humidity 10 ... 95 % non-condensing 17 Approvals 18 Protection class Indicators and switches, fit for mounting into devices with protection class II Ambient conditions Storage temperature 19 Approbations CB (IEC 60947-5-1) DNV EAC NFF cULus VDE 22 31 – 40 °C … + 85 °C 41 Conformities Operating temperature – 40 °C … + 55 °C (other temperatures on request) CE CCC UKCA 45 51 Snap-action switching element with VDE and UKCA When using the switching element, the application guidelines must be observed. 56 Material 57 Housing Switching system The double-break, snap-action switching element is equipped with one or two independent contact systems, acting as normally open or normally closed contact. The snap-action switching element is fitted with self-cleaning contacts. The indicator lights / switches may be installed in enclosures with protection class 2 according to DIN EN 61140. The enclosure must at least have enclosure class 2 according to UL50E. Material of contact 61 70 Hard silver, gold-silver, silver-palladium (for aggressive atmospheres) 71 Switch housing 82 Up to three switching elements can be snapped to each actuator. Snap-action switching elements are not permissible for emergencystop pushbuttons! Plastic 84 92 96 08/2022 § eao.com ​ 251 04 Technical data 01 Mechanical characteristics Rated impulse withstand voltage Uimp 4 kV, according to EN / IEC 60947-5-1 Terminals 03 Screw terminal - max. wire cross section - stripping length wire - max. number of wire 04 - max. strand cross section - stripping strands 02 09 - max. number of strands Electrical life 2.5 mm2 10 mm 2 1.5 mm2 use stranded wires only with wire end ferrules of 10 mm length 2 14 Only one polarity is allowed on each side when wiring. 17 Plug-in terminal 1 x 6.3 mm x 0.8 mm or 2 x 2.8 mm x 0.8 mm For devises with plug-in connections, insulating sleeves are required and the mounting cut-out of 65 mm must be observed. 18 19 22 31 41 45 Double plug-in terminal 2 x 6.3 mm x 0.8 mm For units with plug-in connections, insulating sleeves are required and the mounting cut-out of 65 mm must be observed. Tightening torque Screws at the plastic mounting flange max. 0.4 – 0.5 Nm Screws at the metal mounting flange max. 0.25 – 0.3 Nm Screws at switching element max. 0.8 Nm 50 000 cycles of operation Thermal current Ith Max. current at continuous operation and limit temperatures which do not exceed the specified max. values. 10 A Switching voltage and switching current as per EN IEC 60947-5-1 voltage DC13 AC15 24 V 60 V 110 V 120 V 230 V 400 V 500 V 2.5 A 0.8 A 0.6 A 4.5 A 4.5 A 0.2 A 0.15 A 0.07 A 4.5 A 4.5 A 4.0 A 2.5 A Recommended minimum operational data Gold-silver contacts: Voltage 5 VDC 24 VDC Current 15 mA 5 mA 110 VDC 2 mA Actuating force Hard silver contacts: Voltage 24 VDC 110 VDC Current 50 mA 10 mA 1 Normally closed 1.9 N 1 Normally open 2 N Protection class Actuating travel Indicators and switches, fit for mounting into devices with protection class II. Approx. 5.8 mm ± 0.2 mm 51 56 57 61 Mechanical lifetime (with 1 switching element) 1.5 million cycles of operation Pushbutton maintained action Pushbutton momentary action 3 million cycles of operation Selector switch maintained action 1.25 million cycles of operation Selector switch momentary action 2.5 million cycles of operation Keylock switch maintained action 25 000 cycles of operation Keylock switch momentary action 50 000 cycles of operation Ambient conditions Storage temperature – 40 °C … + 85 °C Operating temperature – 40 °C … + 55 °C (other temperatures on request) Protection degree 70 71 82 Electrical characteristics IP00 Standards Shock resistance The switches comply with the “Standards for low-voltage switching devices” DIN EN 60947-5-1 (single impacts, semi-sinusoidal) 300 m / s² pulse width 11 ms, as per DIN EN 60068-2-27 Rated Insulation Voltage Ui Vibration resistance 500 V, as per DIN EN 60947-5-1 (sinusoidal) 100 m3 / s² at 10 Hz … 500 Hz, amplitude 0.75 mm, as per DIN EN 60068-2-6 84 92 96 252 eao.com § 08/2022 Technical data 04 Approvals Pollution degree 01 3 Approbations Climatic resistance Relative humidity 10 ... 95 % non-condensing CB (IEC 60947-5-1) DNV EAC NFF cULus VDE 02 03 04 Conformities CE CCC UKCA 09 14 17 Slow-make switching element PIT with VDE and UKCA When using the switching element, the application guidelines must be observed. 18 Mechanical characteristics 19 Terminals Switching system The double-break, slow-make switching element is equipped with one or two independent contact systems, acting as normally open or normally closed contact. The normally closed contact has forced opening. PIT push-in terminal - max. wire cross section - stripping length wire - max. number of wire - max. strand cross section - stripping strands Slow-make contacts with forced action are ideal for high switch ratings. - max. number of strands 1.0 mm2 8 mm 2 22 31 0.75 mm2 use stranded wires only with wire end ferrules of 8 mm length 2 41 45 Up to three switching elements can be snapped to each actuator. Only one polarity is allowed on each side when wiring. For the emergency-stop pushbutton use the slow-make switching element (max. 2). Tightening torque Special requirements for positive-opening auxiliary current switches Screws at the plastic mounting flange max. 0.4 – 0.5 Nm Screws at the metal mounting flange max. 0.25 – 0.3 Nm Positive opening travel Minimum force Actuating force Max. travel Emergency stop 12.5 mm Emergency stop 50 N (actuating force at which is safely switched) Emergency stop 12.5 mm 51 56 57 1 Normally closed 2 N 1 Normally open 3 N 61 Actuating travel Material approx. 5.8 mm ± 0.2 mm Housing Mechanical lifetime The indicator lights / switches may be installed in enclosures with protection class 2 according to DIN EN 61140. The enclosure must at least have enclosure class 2 according to UL50E. (with 1 switching element) Pushbutton maintained action 1.5 million cycles of operation Pushbutton momentary action 3 million cycles of operation Selector switch maintained action 1.25 million cycles of operation Selector switch momentary action 2.5 million cycles of operation Emergency-stop switch 50 000 cycles of operation Keylock switch maintained action 25 000 cycles of operation Keylock switch momentary action 50 000 cycles of operation Material of contact Hard silver and gold-silver 70 Switch housing 71 82 84 92 Plastic 96 08/2022 § eao.com 253 04 Technical data 01 02 03 04 Electrical characteristics Ambient conditions Standards Storage temperature The switches comply with DIN EN 60947-1/EN IEC 60947-5-1 – 40 °C … + 85 °C Rated Insulation Voltage Ui Operating temperature 500 V, as per DIN EN 60947-5-1 – 40 °C … + 55 °C (other temperatures on request) Rated impulse withstand voltage Uimp 4 kV, according to EN / IEC 60947-5-1 Protection degree IP20 09 Electrical life 50 000 cycles of operation Shock resistance 14 Thermal current Ith (single impacts, semi-sinusoidal) 300 m / s² pulse width 11 ms, as per DIN EN 60068-2-27 17 18 19 22 31 Max. current at continuous operation and limit temperatures which do not exceed the specified max. values. 6A Pollution degree Switching voltage and switching current Climatic resistance as per EN IEC 60947-5-1 Relative humidity 10 ... 95 % non-condensing voltage DC13 AC15 24 V 48 V 60 V 110 V 120 V 230 V 4,0 A 6,0 A 6,0 A Approvals 1,5 A 1,0 A 6,0 A 7,0 A Recommended minimum operational data 41 45 51 56 57 3 Gold-silver contacts: Voltage 24 VDC Current 5 mA Hard silver contacts: Voltage 24 VDC Current 50 mA Approbations CB (IEC 60947-5-1) DNV EAC NFF cULus VDE Conformities CE CCC UKCA Protection class Indicators and switches, fit for mounting into devices with protection class II 61 70 71 82 84 92 96 254 eao.com § 08/2022 Technical data 04 Snap-action switching element PIT with VDE and UKCA 01 When using the switching element, the application guidelines must be observed. Actuating travel Switching system Mechanical lifetime 02 Approx. 5.8 mm ± 0.2 mm 03 Up to three switching elements can be snapped to each actuator. (with 1 switching element) Pushbutton maintained action 1.5 million cycles of operation Pushbutton momentary action 3 million cycles of operation Selector switch maintained action 1.25 million cycles of operation Selector switch momentary action 2.5 million cycles of operation Keylock switch maintained action 25 000 cycles of operation Keylock switch momentary action 50 000 cycles of operation Snap-action switching elements are not permissible for emergency stop pushbuttons! Electrical characteristics The double-break, snap-action switching element is equipped with one or two independent contact systems, acting as normally open or normally closed contact. The snap-action switching element is fitted with self-cleaning contacts. 04 09 14 17 Standards Material The switches comply with DIN EN 60947-1/DIN EN 60947-5-1 Housing Rated Insulation Voltage Ui The indicator lights / switches may be installed in enclosures with protection class 2 according to DIN EN 61140. The enclosure must at least have enclosure class 2 according to UL50E. 500 V, as per DIN EN 60947-5-1 Material of contact Electrical life Hard silver and gold-silver 50 000 cycles of operation Switch housing Thermal current Ith 41 Plastic Max. current at continuous operation and limit temperatures which do not exceed the specified max. values. 6A 45 18 19 Rated impulse withstand voltage Uimp 22 4 kV, according to EN / IEC 60947-5-1 31 Mechanical characteristics 51 Switching voltage and switching current as per EN IEC 60947-5-1 Terminals PIT push-in terminal - max. wire cross section - stripping length wire - max. number of wire - max. strand cross section - stripping strands - max. number of strands 1.0 mm2 8 mm 2 0.75 mm use stranded wires only with wire end ferrules of 8 mm length 2 2 Only one polarity is allowed on each side when wiring. voltage DC13 AC15 24 V 48 V 60 V 110 V 120 V 230 V 2,5 A 6,0 A 6,0 A 56 0,8 A 0,6 A 57 6,0 A 6,0 A 61 Recommended minimum operational data 70 Gold-silver contacts: Voltage 24 VDC Current 5 mA 71 Screws at the plastic mounting flange max. 0.4 – 0.5 Nm Screws at the metal mounting flange max. 0.25 – 0.3 Nm Hard silver contacts: Voltage 24 VDC Current 50 mA 82 Actuating force Protection class 84 1 Normally closed 1.9 N 1 Normally open 2 N Indicators and switches, fit for mounting into devices with protection class II Tightening torque 92 96 08/2022 § eao.com 255 04 Technical data 01 02 03 04 09 14 17 18 Ambient conditions Approvals Storage temperature Approbations – 40 °C … + 85 °C CB (IEC 60947-5-1) DNV EAC NFF cULus VDE Operating temperature – 40 °C … + 55 °C (other temperatures on request) Protection degree IP20 Conformities Shock resistance CE CCC UKCA (single impacts, semi-sinusoidal) 300 m / s² pulse width 11 ms, as per DIN EN 60068-2-27 Vibration resistance (sinusoidal) 100 m / s² at 10 Hz … 500 Hz, as per DIN EN 60068-2-6 and EN 61373 Increased broad band noise, class 1B Pollution degree 19 22 3 Climatic resistance Relative humidity 10 ... 95 % non-condensing 31 41 45 51 56 Lamp block When using the lamp block, the application guidelines must be observed. Material Double plug-in terminal 2 x 6.3 mm x 0.8 mm For units with plug-in connections, insulating sleeves are required and the mounting cut-out of 65 mm must be observed. Housing Plastic 57 Tightening torque Mechanical characteristics 61 70 71 82 84 92 Plug-in terminal 1 x 6.3 mm x 0.8 mm or 2 x 2.8 mm x 0.8 mm For devises with plug-in connections, insulating sleeves are required and the mounting cut-out of 65 mm must be observed. Screws at lamp block max. 0.5 Nm Terminals Screw terminal - max. wire cross section - stripping length wire - max. number of wire - max. strand cross section - stripping strands - max. number of strands Electrical characteristics 2.5 mm2 10 mm 2 1.5 mm2 use stranded wires only with wire end ferrules of 10 mm length 2 Standards The switches comply with DIN EN 60947-1/DIN EN 60947-5-1 Illumination Voltage 250 V max. (many different lamp types available) Power 2.6 W max. (many different lamp types available) Only one polarity is allowed on each side when wiring. 96 256 eao.com § 08/2022 Technical data Ambient conditions Shock resistance Storage temperature (single impacts, semi-sinusoidal) 300 m / s² pulse width 11 ms, as per DIN EN 60068-2-27 04 01 – 40 °C … + 85 °C 02 Vibration resistance – 40 °C … + 55 °C (other temperatures on request) (sinusoidal) 100 m / s² at 10 Hz … 500 Hz, as per DIN EN 60068-2-6 and EN 61373 Increased broad band noise, class 1B Protection degree Climatic resistance IP00 Relative humidity 10 ... 95 % non-condensing Operating temperature 03 04 09 14 Lamp block PIT 17 When using the lamp block, the application guidelines must be observed. Ambient conditions 18 Storage temperature Material – 40 °C … + 85 °C Housing Operating temperature Plastic – 40 °C … + 55 °C (other temperatures on request) Mechanical characteristics Protection degree 19 22 31 IP20 Terminals PIT push-in terminal - max. wire cross section - stripping length wire - max. number of wire 41 Shock resistance 1.0 mm2 8 mm 2 (single impacts, semi-sinusoidal) 300 m / s² pulse width 11 ms, as per DIN EN 60068-2-27 45 Vibration resistance - max. strand cross section - stripping strands - max. number of strands 0.75 mm2 use stranded wires only with wire end ferrules of 8 mm length 2 (sinusoidal) 100 m / s² at 10 Hz … 500 Hz, as per DIN EN 60068-2-6 and EN 61373 Increased broad band noise, class 1B 51 56 Climatic resistance Relative humidity 10 ... 95 % non-condensing 57 Electrical characteristics 61 Standards The switches comply with EN IEC 60947-1/EN IEC 60947-5-1 70 Illumination Voltage 250 V max. (many different lamp types available) Power 2.6 W max. (many different lamp types available) 71 82 84 92 96 08/2022 § eao.com 257 04 Technical data 01 Dual lamp block Ambient conditions 02 When using the lamp block, the application guidelines must be observed. 03 Material – 40 °C … + 85 °C Housing Operating temperature Plastic – 40 °C … + 60 °C (other temperatures on request) Mechanical characteristics Degree of protection Storage temperature 04 09 IP20 14 17 18 Terminals PIT push-in terminal - max. wire cross section - stripping length wire - max. number of wire 31 500 m/s², pulse duration 11 ms, according to EN IEC 60068-2-27 (semi-sinusoidal) Broadband noise - max. strand cross section - stripping strands 19 22 Resistance to shock 1.0 mm2 8 mm 2 - max. number of strands 0.75 mm2 use stranded wires only with wire end ferrules of 8 mm length 2 5.72 m/s² per axis, 5 h (duration), class 1B according to DIN EN 61373 Climatic resistance Relative humidity 10 ... 95 % non-condensing Electrical characteristics Approvals Lighting 41 45 51 Illuminant = 2 SMD-LEDs white Approbations Operating voltages UL-94 V0 EN 45545 24 VDC (– 30 % / + 25 %) 110 VDC (– 30 % / + 25 %) Operating current Typ. 8 mA 56 57 61 70 71 82 84 92 96 258 eao.com § 08/2022 Technical data 04 Buzzer 01 Buzzer Electrical characteristics System Operation Voltage/Current Piezo disc Operation Voltage Operation Current 02 03 24 VDC ±10 % ≤ 25 mA 04 Material Ambient conditions Buzzer case Plastic 09 Storage temperature – 40 °C … + 85 °C 14 Front cap Flush design Aluminium black anodised Aluminium natural anodised Operating temperature Raised design Plastic Metal = nickel-plated brass (sea-water proof) Protection degree – 40 °C … + 55 °C (other temperatures on request) 17 18 As per DIN EN 60529, frontside IP65 19 Mechanical characteristics Approvals Terminals Conformities Plug-in terminal 2.8 mm x 0.5 mm CE 2014 / 35 / EU (LVD) 2011 / 65 / EC (RoHS) Tightening torque 22 31 For fixing nut max. 0.25 Nm 41 Acoustic characteristics 45 Frequency (tone) 51 Approx. 3.2 kHz continuous tone only 56 Sound pressure 95 db (A) ±8 dB at a distance of 0.1 m 57 61 70 71 82 84 92 96 08/2022 § eao.com 259 04 Technical data 01 02 03 Actuator Material Keylock switch Front ring Polyamide, Aluminium or Stainless steel 04 Mounting flange 09 Actuator housing Plastic, metal Electrical characteristics Plastic 14 Standards Mechanical characteristics 17 18 19 22 31 41 The standard lock number is 251, the last digit of the device Part No. = 0 (example: 704.335.0). Additional lock numbers are available: 252 last digit = 1; 253 last digit = 2; 254 last digit = 3 255 last digit = 4, 256 last digit = 5; 257 last digit = 6 258 last digit = 7; 259 last digit = 8; 260 last digit = 9 The switches comply with the “Rules for low-voltage switching devices” EN IEC 60947-5-1 Actuating force Mounting style square flush 6.2 N Other mounting styles 8 N Ambient conditions Actuating travel Storage temperature Approx. 5.8 mm ± 0.2 mm – 40 °C … + 85 °C Mechanical lifetime Operating temperature (with 1 switching element) Pushbutton Selector switch Stop switch Fool proofed E-stop Keylock switch Key insert switches ≤ 3 million cycles of operation ≤ 2.5 million cycles of operation ≤ 50 000 cycles of operation ≥ 50 000 cycles of operation ≤ 50 000 cycles of operation ≤ 250 000 cycles of operation – 40 °C … + 55 °C (other temperatures on request) Protection degree As per EN IEC 60529 IP65 front side (IP65 and IP67 Key insert switch) 45 51 Kraus Naimer rotary selector switching element 56 Mechanical characteristics 57 Terminals Switching angle Basic position of switching position “A” is 9 o’clock 61 70 71 82 84 Screw terminals Terminal lead material copper wires only Max. permissible wire gage: Single-core or stranded wire 2 x 1.5 mm² (2 x AWG 14) Flexible wire 2 x 1.5 mm² (2 x AWG 16) Maintained action 12 max. 8 max. 6 max. 4 max. Tightening torque For fixing nut max. 0.25 Nm Momentary action with release 24° (provide at the beginning or at the end) Number of stages Standard type of Kraus & Naimer 1 to 8 positions max. CG4 Hard Silver contacts with 1 μm Gold layer CG4-1 Hard Silver contacts with 35 μm Gold layer Switching angle 30° 45° 60° 90° Number of contacts 1 to 16 max. normally open contacts (contact positioning according circuit drawing) 92 96 260 ​ eao.com § 08/2022 Technical data Electrical characteristics AC-Direct-on-line starting, reversing, plugging and inching Minimum Voltage 3 phase, 3 pole 20 V 1 phase, 2 pole Rated Impulse Withstand Voltage Uimp 4 kV 220 V – 240 V 380 V – 440 V 110 V – 120 V 220 V – 240 V 380 V – 440 V 04 01 0.37 kW 0.55 kW 0.15 kW 0.25 kW 0.50 kW 02 03 Short Circuit Protection AC-23A Frequent switching of motors or other high inductive loads Max. fuse size (gL-characteristic) 10 A Rated short-time withstand current (1s-current) 90 A 3 phase, 3 pole 1 phase, 2 pole Electrical characteristics for AC 220 V – 240 V 380 V – 440 V 110 V – 120 V 220 V – 240 V 380 V – 440 V 1.80 kW 3.00 kW 0.37 kW 0.75 kW 1.10 kW 04 09 14 Standards The devices comply with: DIN EN 60947-3, VDE 0660 part 107 Overvoltage category 17 III, valid for lines with grounded common neutral termination Rated Operational Voltage Ue 440 V Degree of pollution 18 3, valid for lines with grounded common neutral termination Rated Insulation Voltage Ui 19 440 V Electrical characteristics for AC (UL/Canada) Rated Thermal Current Iu / Ith 10 A 22 Rated operational voltage 300 V Rated Operational Current Ie AC-15 Switching of control devices, contactors, valves etc. 31 Rated Insulation Voltage Ui 300 V 110 V – 120 V 220 V – 240 V 380 V – 440 V 2.5 A 2.5 A 1.5 A 41 Rated Thermal Current 10 A No load operation 10 A Ampere Rating AC-21A Switching of resistive loads, including moderate overloads For switching of power > 1 kW 10 A Ratings 45 Resisitve or low inductive loads, for switching of power > 1 kW, 10 A 56 Standard motor load, DOL Rating (similar AC-3) 3 phase, 3 pole AC-22A Switching of combined resistive or low inductive loads including moderate overloads 220 V – 240 V 10 A 1 phase, 2 pole 110 V – 120 V 220 V – 240 V 110 V – 120 V 220 V – 240 V 277 V – 277 V 51 0.75 HP 1.00 HP 0.33 HP 0.75 HP 0.75 HP 57 61 Rated Utilization Category AC-2 Slip ring motor starting, reversing and plugging, star-delta starting 3 phase, 3 pole 220 V – 240 V 380 V – 440 V 70 Pilot Duty, Heavy 300 VAC 71 2.5 kW 4.5 kW AC-3 Direct-on-line starting, star-delta starting 82 3 phase, 3 pole 84 1 phase, 2 pole 220 V – 240 V 380 V – 440 V 110 V – 120 V 220 V – 240 V 380 V – 440 V 2.50 kW 2.20 kW 0.30 kW 0.55 kW 0.75 kW 92 96 08/2022 § eao.com ​ 261 04 Technical data 01 Electrical characteristics for DC Switching voltage and switching current DC 02 03 04 09 14 Resistive loads T ≤ 1 ms Number of series contact(s) 1 2 3 4 24 V 48 V 70 V 95 V 48 V 95 V 140 V 190 V 60 V 120 V 180 V 240 V 110 V 220 V 330 V 440 V 220 V 440 V 660 V 440 V 660 V 5 120 V 240 V 300 V 550 V 6 8 145 V 190 V 290 V 350 V 360 V 450 V 660 V Inductive loads T = 50 ms Switch capacity 10.0 A 6.0 A 2.5 A 0.7 A 0
704.600.2 价格&库存
很抱歉,暂时无法提供与“704.600.2”相匹配的价格&库存,您可以联系我们找货
    • 1+255.77426
    • 5+245.54787
    • 10+235.31107
    • 25+229.78132
    库存:2
    704.600.2
      • 1+477.60840
      • 200+190.57680
      • 500+184.20480
        • 1+327.193311+42.53407
