CTAR-12
CTAR-12
    CHEMTRONICS
    Conformal
    AR ACRYLIC CONFORMAL COATING
CTAR-12 数据手册
Rev. O (10/23) Page 1 of 2 Konform® AR Product# CTAR-12, CTAR-1 Product Description Konform AR is ideal for providing insulation against highvoltage arcing and corona shorts. This extremely effective acrylic conformal coating provides a hard, durable protective barrier against humidity, salt, corrosive vapors and fungus for printed circuit board and electronic assemblies. Clear transparent coating Excellent dielectric strength Helps prevent arcing and shorts Increases life of electronic assemblies Will not discolor over time under normal use Contains a UV indicator for thorough Quality Control inspection • UL Recognized, File QMJU2.E76307 • Compliant with IPC-CC-830A • • • • • • Typical Applications Konform AR is ideal for applications in: • • • • • • Aerospace Data Communications Instrumentation Automotive Manufacturing Marine Manufacturing Process Control Typical Product Data and Physical Properties Usable Temp. Range of Cured Coatings Tack Free Time Curing Conditions (@30-60% R.H.) Specific Gravity: (water = 1@ 68ºF) Viscosity (cps @ 77ºF) Flash Point (TCC) Volume Resistivity (ohm/cm) Dielectric Breakdown (volts/mil) Comparative Tracking Index (CTI) Coefficient of Thermal Expansion (in/in/ºC) Coverage (1 mil/ft2) -75°F to 270°F (-59°C to 132°C) 30 min. 24 Hours @ 77°F (25°C) 8 Hours @ 170°F (77°C) 0.93 (Liquid Only) 70± 5 cps 30°F / -1ºC 1 x 1014 6300 250 (PLC of 2) 5 x 10-5 Shelflife CTAR-1 254.0 CTAR-12 20.2 2 years RoHS Compliant Yes 1-770-424-4888  www.chemtronics.com Rev. O (10/23) Page 2 of 2 Konform® AR Product# CTAR-12, CTAR-1 Compatibility Konform AR is generally compatible with most materials found on printed circuit boards. As with any chemical product, product/component compatibility must be determined on a noncritical area prior to use. Performance Moisture Resistance Removability Ease of Repair Flexibility Adhesion Abrasion Resistance Solvent Resistance Availability CTAR-12 CTAR-1 Environmental Impact Data CFC HCFC CL Solv. VOC HFC ODP Good Excellent Excellent Fair Excellent Excellent Fair 11.5 oz. / 326 g Aerosol 1 Gal / 3.7 L Liquid 0.0% 0.0% 0.0% 88.9 % 0.0% 0.00 CFC, HCFC, CL. SOLV., VOC, and HFC numbers shown are the content by weight. Ozone depletion potential (ODP) is determined in accordance with the Montreal Protocol and U.S. Clean Air Act of 1990. Usage Instructions For industrial use only. Read SDS carefully prior to use. Before applying Konform AR conformal coatings, clean circuit boards to remove contamination and allow to dry. Cleaning may be performed with Chemtronics Flux-Off products. SPRAY APPLICATION: Apply top to bottom, allowing coating to flow evenly around components. Rotate PCB 90° and repeat application. Rotate and apply coating two additional times, then allow board to cure. If additional thickness is desired, apply additional coatings. When using liquid spray with automatic dispensing equipment, adjustments may be required in application rate and viscosity. Technical and Application Assistance Chemtronics provides a technical hotline to answer your technical and application related questions. The toll free number is: 1-800-TECH-401. Note: This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. CHEMTRONICS does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. DIP APPLICATION: Using automatic equipment or hand immersion technique, slowly immerse PCB into the coating and remove slowly. Use an average rate of approximately 1 foot per minute. After allowing the board to cure, process may be repeated to achieve desired thickness. BRUSH APPLICATIONS: Evenly apply coating to areas desired at thickness required. Allow time for curing before reapplying to achieve a thick coating. Use Chemask to protect components during conformal coating process. REMOVAL: After application, cured Konform AR may be removed by soaking in Chemtronics Electro-Wash Two Step. 8125 Cobb Center Drive, Kennesaw, GA 30152  1-770-424-4888  www.chemtronics.com 1-770-424-4888  www.chemtronics.com
CTAR-12 价格&库存
很抱歉,暂时无法提供与“CTAR-12”相匹配的价格&库存,您可以联系我们找货
