Rev. L (7/18) Page 1 of 2
CircuitWorksâ Overcoat Pen
Product# CW3300C, CW3300G, CW3300BLACK,
CW3300WHITE
Product Description
CircuitWorks Overcoat Pen is ideal for protecting and insulating
circuit board traces, components, and other delicate
electronics. This highly effective acrylic conformal coating
provides excellent protection against shorts, moisture,
abrasion, fungus, and other environmental hazards. Allows for
easy repair of solder mask in prototype, manufacture and
repair of circuit boards.
Simple to use, single component system
Hard, durable coating
High dielectric strength
Helps prevent arcing and shorts
Contains fluorescent indicator
Protects against moisture damage
Meets requirements of MIL-I-46058C
and IPC-A-610F
Helps prevent static discharge problems on sensitive
components
Typical Applications
CircuitWorks Overcoat Pen may be used for electronics
applications in:
Circuit Board Manufacturing
Data Communications
Aerospace
Instrumentation
Controls
General Maintenance and Repair
Chemical Resistance
CircuitWorks Overcoat Pen has excellent resistance to waterbased cleaners and limited resistance to aggressive organic
solvents such as acetone. The chemical resistance of CW3300
can be enhanced by heat curing.
Typical Product Data and Physical Properties
COMPOSITION:
Material:
Polymeric Conformal Coat
Color:
Clear, Green, Blue, Black, White
VOC Content:
630 g/L
CURED COMPOUND:
Temperature Range:
-67 to 255°F (-55 to 125°C)
Tack-Free Time:
< 5 Minutes
Resistivity:
>1012 ohm-cm @ 50 VDC
Dielectric Breakdown:
>500 volts/mil DC
Dielectric Constant:
3-4
Dissipation Factor:
< .001 @ 1 KHz
Thermal Shock Resistance: Pass, 10 Cycles
@ -67º to 311ºF (-55 to 155°C)
Flexibility:
Excellent
Moisture Resistance
Excellent
Adhesion:
Good to excellent
Typical Thickness:
2 - 3 mil
Shelflife
2 years
RoHS Compliant
Yes
1-770-424-4888 www.chemtronics.com
Rev. L (7/18) Page 2 of 2
CW3300WHITE
Availability
Compatibility
CircuitWorks Overcoat Pen material is generally compatible
with materials used in printed circuit board fabrication. As with
any adhesive/sealant, compatibility with substrate should be
determined on a non-critical area prior to use.
Usage Instructions
CW3300C
CW3300G
CW3300B
CW3300BLACK
CW3300WHITE
4.9g / 0.16 oz. Clear
4.9g / 0.16 oz. Green
4.9g / 0.16 oz. Blue
4.9g / 0.16 oz. Black
4.9g / 0.16 oz. White
Technical and Application Assistance
For industrial use only. Read SDS carefully prior to use.
Chemtronics provides a technical hotline to answer your
technical and application related questions.
The toll free number is: 1-800-TECH-401.
Cleaning: For best adhesion, clean the board with a
Chemtronics Electro-Wash cleaner in order to remove any
surface contamination which may prevent adequate material
contact.
Note:
This information is believed to be accurate. It is intended for
professional end users having the skills to evaluate and use the
data properly. CHEMTRONICS does not guarantee the
accuracy of the data and assumes no liability in connection
with damages incurred while using it.
Application: The overcoat material is dispensed throughout
the CircuitWorks Overcoat Pen. Squeezing the pen body
while pressing down on the surface will allow the material to
flow.
Thinning: The overcoat material has been optimized for the
CircuitWorks Overcoat Pen and thinning is not normally
necessary. However, propyl acetate may be added with
thorough mixing to make slight adjustments for ease of
application in the bulk form.
Drying: The overcoat material dries in 5 to 10 minutes at
room temperature. A heat cure of 5 - 10 minutes at 200°F
(93°C) is recommended for more demanding applications and
for enhancing the chemical resistance.
Clean-up / Removal: The overcoat material can be removed
from surfaces using acetone.
8125 Cobb Center Drive, Kennesaw, GA 30152 1-770-424-4888 www.chemtronics.com
很抱歉,暂时无法提供与“CW3300C”相匹配的价格&库存,您可以联系我们找货
