电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
CW3300G
CW3300G
    CHEMTRONICS
    Conformal
    COAT ACRYLIC ADH PEN 4.9G GREEN
CW3300G 数据手册
Rev. L (7/18) Page 1 of 2 CircuitWorksâ Overcoat Pen Product# CW3300C, CW3300G, CW3300BLACK, CW3300WHITE Product Description CircuitWorks Overcoat Pen is ideal for protecting and insulating circuit board traces, components, and other delicate electronics. This highly effective acrylic conformal coating provides excellent protection against shorts, moisture, abrasion, fungus, and other environmental hazards. Allows for easy repair of solder mask in prototype, manufacture and repair of circuit boards. • • • • • • • • • Simple to use, single component system Hard, durable coating High dielectric strength Helps prevent arcing and shorts Contains fluorescent indicator Protects against moisture damage Meets requirements of MIL-I-46058C and IPC-A-610F Helps prevent static discharge problems on sensitive components Typical Applications CircuitWorks Overcoat Pen may be used for electronics applications in: • • • • • • Circuit Board Manufacturing Data Communications Aerospace Instrumentation Controls General Maintenance and Repair Chemical Resistance CircuitWorks Overcoat Pen has excellent resistance to waterbased cleaners and limited resistance to aggressive organic solvents such as acetone. The chemical resistance of CW3300 can be enhanced by heat curing. Typical Product Data and Physical Properties COMPOSITION: Material: Polymeric Conformal Coat Color: Clear, Green, Blue, Black, White VOC Content: 630 g/L CURED COMPOUND: Temperature Range: -67 to 255°F (-55 to 125°C) Tack-Free Time: < 5 Minutes Resistivity: >1012 ohm-cm @ 50 VDC Dielectric Breakdown: >500 volts/mil DC Dielectric Constant: 3-4 Dissipation Factor: < .001 @ 1 KHz Thermal Shock Resistance: Pass, 10 Cycles @ -67º to 311ºF (-55 to 155°C) Flexibility: Excellent Moisture Resistance Excellent Adhesion: Good to excellent Typical Thickness: 2 - 3 mil Shelflife 2 years RoHS Compliant Yes 1-770-424-4888 Ÿ www.chemtronics.com Rev. L (7/18) Page 2 of 2 CircuitWorksâ Overcoat Pen Product# CW3300C, CW3300G, CW3300BLACK, CW3300WHITE Availability Compatibility CircuitWorks Overcoat Pen material is generally compatible with materials used in printed circuit board fabrication. As with any adhesive/sealant, compatibility with substrate should be determined on a non-critical area prior to use. Usage Instructions CW3300C CW3300G CW3300B CW3300BLACK CW3300WHITE 4.9g / 0.16 oz. Clear 4.9g / 0.16 oz. Green 4.9g / 0.16 oz. Blue 4.9g / 0.16 oz. Black 4.9g / 0.16 oz. White Technical and Application Assistance For industrial use only. Read SDS carefully prior to use. Chemtronics provides a technical hotline to answer your technical and application related questions. The toll free number is: 1-800-TECH-401. Cleaning: For best adhesion, clean the board with a Chemtronics Electro-Wash cleaner in order to remove any surface contamination which may prevent adequate material contact. Note: This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. CHEMTRONICS does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. Application: The overcoat material is dispensed throughout the CircuitWorks Overcoat Pen. Squeezing the pen body while pressing down on the surface will allow the material to flow. Thinning: The overcoat material has been optimized for the CircuitWorks Overcoat Pen and thinning is not normally necessary. However, propyl acetate may be added with thorough mixing to make slight adjustments for ease of application in the bulk form. Drying: The overcoat material dries in 5 to 10 minutes at room temperature. A heat cure of 5 - 10 minutes at 200°F (93°C) is recommended for more demanding applications and for enhancing the chemical resistance. Clean-up / Removal: The overcoat material can be removed from surfaces using acetone. 8125 Cobb Center Drive, Kennesaw, GA 30152 Ÿ 1-770-424-4888 Ÿ www.chemtronics.com 1-770-424-4888 Ÿ www.chemtronics.com
CW3300G 价格&库存
很抱歉,暂时无法提供与“CW3300G”相匹配的价格&库存,您可以联系我们找货
