SPD24RM20
SPD24RM20
    CARLOGAVAZZI
    Module
    AC/DC CONVERTER 24VDC 480W
SPD24RM20 数据手册
Switching Power Supply Redundant Module Type SPD24RM20 DIN rail mounting • • • • • • • • Product Description This SPD additional module allows the connection of 1 power supply +1 or more additional redundant power supplies. In this case, the continuity of the 24VDC output is always guaranteed, even in case of failure of one power supply. 2 relay outputs provide voltage free outputs in order to send the alarm to a control unit when a failure occurs. Installation on DIN Rail 7.5 or 15mm 2 “Power Rdy” relay outputs Up to 480W output Unlimited number of connectable redundant power supplies Very compact dimensions UL, cUL listed TUV approved Ce and RoHS compliant Ordering Key SP D 24 RM 20 Model Mounting ( D = Din rail ) Output voltage Redundant module Maximum current Approvals au art geprü f t B y p e T d Rheinland Product Safety e appro v Output Data Input Data Output voltage drop Output maximum Current Output Peak Current >5ms Max Reverse Voltage 0.5V 20A 30A 30V Rated input Voltage Number of inputs Maximum input current 21...28VDC 2 20A Controls and Protections Approvals and EMC Power RDY relay Output OK Fail Contact rating Shock resistance input 20...30V ±5% input 20...30V ±5% 1.0A (15G, 11ms, 3 Axis, 6 Faces, 3 times for each Face) Vibration resistance acc. to IEC 60068-2-6 (Mounting by rail: 10-500 Hz, 2G, along X, Y, Z each Axis, 60 min for each Axis) General Data UL / cUL Insulation Voltage Input / Relay contact Insulation Resistance Input / Relay contact @100VDC Operating temperature Storage temperature Relative Humidity MTBF (Bellcore issue 6 @ 40°C, GB) Cooling Case material Dimensions L x W x D Weight 1 acc. to IEC 60068-2-27 100VDC 100MΩ -25°C...+71°C -25°C...+85°C 20...95%RH 659,000h Free air convection Plastic 90 x 54 x 114mm 210g TUV CE UL 508 Listed UL 60950-1 Recognized EN 60950-1, CB scheme EN 55022 Class B, EN 55024, EN 61000-4-2, EN 61000-4-3, EN 61000-4-4, EN 61000-4-6, EN 61000-4-8, EN 61204-3 Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network. - 0940 Switching Power Supply Redundant Module Type SPD24RM20 DIN rail mounting Mechanical Drawings L1 mm (inches) 114.0 [4.49] L2 1 2 3 4 5 6 A OK B OK OK OK B Rdy 90.0 [ 3.6] A Rdy FAIL 54.00 [2.13] FAIL INPUT OUTPUT 7 8 9 10 11 12 Pin Assignment and Front Controls Pin No. Designation Description 1 2 3 4 5 6 7 8 9 10 11 12 A Rdy Fail A Rdy COM A Rdy OK B Rdy Fail B Rdy COM B Rdy OK Input A+ Input B+ Input Input Output Output + Relay normally closed contact (power supply A Fail) Relay common contact Relay normally open contact (power supply A OK) Relay normally closed contact (power supply B Fail) Relay common contact Relay normally open contact (power supply B OK) Positive Input power supply A Positive Input power supply B Negative Input power supply A Negative Input power supply B Positive Output terminal Negative Output terminal L1 L2 A OK B OK “A” power supply operation OK LED “B” power supply operation OK LED Typical Application Notes 1.) 1+1 Redundancy: Using 1 more PS as the redundant unit. PS #2 PS #1 SPD24RM20 SPD24RM20 Vin A Vout Load PS #1 Vin B Vin A Vin B SPD24RM20 PS #1 2.) Single Use: Connecting only one PS to one SPD24RM20 to reduce the stress of the diodes and hence increase the reliability. Vout Vout Load 3.) 1+N Redundancy: Using more than one PS as redundant units to increase the reliability. Vin B Vout PS #3 PS #4 Vin A Vin B Vout PS #N PS #N+1 Vin A SPD24RM20 SPD24RM20 Vin A PS #2 SPD24RM20 PS #1 Vin B Vout Load 0940 - Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network. Switching Power Supply Redundant Module Type SPD24RM20 DIN rail mounting Circuit Diagram Installation Ventilation and cooling Vin A+ Vin B+ Vin- / Vout- Relay A Control Circuit RDY A FAIL Relay B Control Circuit Vout+ SPD24RM20 3 OK OK RDY B FAIL Screw terminals Normal convection All sides 25mm free space for cooling is recommended 10-24AWG flexible or solid cable 8mm stripping recommend Max. torque for screws terminals Input terminals 1.008Nm (9.0lb-in) Output terminals 0.616Nm (5.5lb-in) 10-24AWG flexible or solid cable Plug-in connectors 7mm stripping recommend Max. torque for plug-in terminals Input terminals 0.784Nm (7.0lb-in) Output terminals 0.784Nm (7.0lb-in) Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network. - 0940
SPD24RM20 价格&库存
很抱歉,暂时无法提供与“SPD24RM20”相匹配的价格&库存,您可以联系我们找货
