ADC0844, ADC0848
www.ti.com
SNAS523D – JUNE 1999 – REVISED MARCH 2013
ADC0844/ADC0848 8-Bit μP Compatible A/D Converters with Multiplexer Options
Check for Samples: ADC0844, ADC0848
FEATURES
DESCRIPTION
The ADC0844 and ADC0848 are CMOS 8-bit
successive approximation A/D converters with
versatile analog input multiplexers. The 4-channel or
8-channel multiplexers can be software configured for
single-ended, differential or pseudo-differential modes
of operation.
1
2
Easy Interface to All Microprocessors
Operates Ratiometrically or with 5 VDC Voltage
Reference
No Zero or Full-Scale Adjust Required
4-Channel or 8-Channel Multiplexer with
Address Logic
Internal Clock
0V to 5V Input Range with Single 5V Power
Supply
Standard Width 20-Pin or 24-Pin PDIP
28 Pin PLCC Package
KEY SPECIFICATIONS
Resolution: 8 Bits
Total Unadjusted Error: ±½ LSB and ± 1 LSB
Single Supply: 5 VDC
Low Power: 15 mW
Conversion Time: 40 μs
The differential mode provides low frequency input
common mode rejection and allows offsetting the
analog range of the converter. In addition, the A/D's
reference can be adjusted enabling the conversion of
reduced analog ranges with 8-bit resolution.
The A/Ds are designed to operate from the control
bus of a wide variety of microprocessors. TRI-STATE
output latches that directly drive the data bus permit
the A/Ds to be configured as memory locations or I/O
devices to the microprocessor with no interface logic
necessary.
Block Diagram
* ADC0848 shown in PDIP Package CH5-CH8 not included on the ADC0844
1
2
Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of
Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet.
All trademarks are the property of their respective owners.
PRODUCTION DATA information is current as of publication date.
Products conform to specifications per the terms of the Texas
Instruments standard warranty. Production processing does not
necessarily include testing of all parameters.
Copyright © 1999–2013, Texas Instruments Incorporated
ADC0844, ADC0848
www.ti.com
Connection Diagram
Figure 1. PLCC Package (Top View)
Figure 2. 20-Pin PDIP (Top View)
Figure 3. 28-Pin PDIP (Top View)
These devices have limited built-in ESD protection. The leads should be shorted together or the device placed in conductive foam
during storage or handling to prevent electrostatic damage to the MOS gates.
Absolute Maximum Ratings (1) (2) (3)
Supply Voltage (VCC)
6.5V
−0.3V to +15V
Logic Control Inputs
Voltage
−0.3V to VCC+0.3V
At Other Inputs and Outputs
Input Current at Any Pin (4)
Package Input Current
5 mA
(4)
20 mA
−65°C to +150°C
Storage Temperature
Package Dissipation at TA=25°C
ESD Susceptibility
875 mW
(5)
800V
PDIP Package
Lead Temperature (Soldering, 10 seconds)
(1)
(2)
(3)
(4)
(5)
2
PLCC Package
260°C
Vapor Phase (60 seconds)
215°C
Infrared (15 seconds)
220°C
Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. DC and AC electrical specifications do not
apply when operating the device beyond its specified operating conditions.
All voltages are measured with respect to the ground pins.
If Military/Aerospace specified devices are required, please contact the Texas Instruments Sales Office/Distributors for availability and
specifications.
When the input voltage (VIN) at any pin exceeds the power supply rails (VIN < V−or VIN > V+) the absolute value of the current at that pin
should be limited to 5 mA or less. The 20 mA package input current limits the number of pins that can exceed the power supply
boundaries with a 5 mA current limit to four.
Human body model, 100 pF discharged through a 1.5 kΩ resistor.
Submit Documentation Feedback
Product Folder Links: ADC0844 ADC0848
ADC0844, ADC0848
www.ti.com
Operating Conditions (1) (2)
4.5 VDC to 6.0 VDC
0°C≤TA≤70°C
ADC0844CCN, ADC0848BCN, ADC0848CCN
Temperature Range (TMIN≤TA≤TMAX)
(1)
(2)
(3)
ADC0844BCJ (3), ADC0844CCJ (3), ADC0848BCV,
ADC0848CCV
−40°C≤TA≤85°C
Product/package combination obsolete; shown for reference only.
Electrical Characteristics
The following specifications apply for VCC = 5 VDC unless otherwise specified. Boldface limits apply from TMIN to TMAX; all
other limits TA = Tj = 25°C.
Parameter
Conditions
ADC0844CCN,
ADC0848BCN,
ADC0848CCN,
ADC0848BCV,
ADC0848CCV
ADC0844BCJ (1)
ADC0844CCJ (1)
Typ (2)
Tested Design
Limit (3) Limit (4)
Typ (2)
Limit
Units
Tested Design
Limit (3) Limit (4)
CONVERTER AND MULTIPLEXER CHARACTERISTICS
Maximum Total
ADC0844BCN,
ADC0848BCN, BCV
Unadjusted
Error
ADC0844CCN,
ADC0848CCN, CCV
±½
±½
LSB
±1
±1
LSB
VREF = 5.00 VDC (5)
ADC0844CCJ (1)
±1
LSB
Minimum Reference Input Resistance
2.4
1.1
2.4
1.2
1.1
kΩ
Maximum Reference Input Resistance
2.4
5.9
2.4
5.4
5.9
kΩ
VCC +
0.05
VCC +
0.05
V
GND −
0.05
GND −
0.05
V
Maximum Common-Mode Input Voltage
See (6)
VCC +
0.05
Minimum Common-Mode Input Voltage
See (6)
GND −
0.05
DC Common-Mode Error
Differential Mode
±1/16
±¼
±1/16
±¼
±¼
LSB
Power Supply Sensitivity
VCC = 5V±5%
±1/16
±⅛
±1/16
±⅛
±⅛
LSB
Off Channel Leakage Current
On Channel = 5V, Off
Channel = 0V (7)
−1
−0.1
−1
μA
On Channel = 0V, Off
Channel = 5V
1
0.1
1
μA
2.0
2.0
2.0
V
0.8
DIGITAL AND DC CHARACTERISTICS
VIN(1), Logical “1” Input Voltage (Min)
VCC = 5.25V
VIN(0), Logical “0” Input Voltage (Max)
VCC = 4.75V
0.8
V
IIN(1), Logical “1” Input Current (Max)
VIN = 5.0V
0.005
1
0.005
1
μA
IIN(0), Logical “0” Input Current (Max)
VIN = 0V
−0.005
−1
−0.005
−1
μA
(1)
(2)
(3)
(4)
(5)
(6)
(7)
0.8
This product/package combination is obsolete. Shown for reference only.
Typical figures are at 25°C and represent most likely parametric norm.
Tested limits are specified to TI's AOQL (Average Outgoing Quality Level).
Design limits are specified by not 100% tested. These limits are not used to calculate outgoing quality levels.
Total unadjusted error includes offset, full-scale, linearity, and multiplexer error.
For VIN (−) ≥ VIN(+) the digital output code will be 0000 0000. Two on-chip diodes are tied to each analog input, which will forwardconduct for analog input voltages one diode drop below ground or one diode drop greater than VCC supply. Be careful during testing at
low VCC levels (4.5V), as high level analog inputs (5V) can cause this input diode to conduct, especially at elevated temperatures, and
cause errors for analog inputs near full-scale. The spec allows 50 mV forward bias of either diode. This means that as long as the
analog VIN does not exceed the supply voltage by more than 50 mV, the output code will be correct. To achieve an absolute 0 VDC to 5
VDC input voltage range will therefore require a minimum supply voltage of 4.950 VDC over temperature variations, initial tolerance and
loading.
Off channel leakage current is measured after the channel selection.
3
ADC0844, ADC0848
www.ti.com
Electrical Characteristics (continued)
Parameter
Conditions
Typ (2)
VOUT(1), Logical “1” Output Voltage (Min)
VOUT(0), Logical “0” Output Voltage (Max)
ADC0844CCN,
ADC0848BCN,
ADC0848CCN,
ADC0848BCV,
ADC0848CCV
ADC0844BCJ (1)
ADC0844CCJ (1)
Tested Design
Limit (3) Limit (4)
Limit
Units
Tested Design
Limit (3) Limit (4)
Typ (2)
VCC = 4.75V, IOUT = −360 μA
2.4
2.8
2.4
V
IOUT = −10 μA
4.5
4.6
4.5
V
VCC = 4.75V, IOUT = 1.6 mA
0.4
0.34
0.4
V
μA
VOUT = 0V
−0.01
−3
−0.01
−0.3
−3
VOUT = 5V
0.01
3
0.01
0.3
3
μA
ISOURCE, Output Source Current (Min)
VOUT = 0V
−14
−6.5
−14
−7.5
−6.5
mA
ISINK, Output Sink Current (Min)
VOUT = VCC
16
8.0
16
9.0
8.0
mA
ICC, Supply Current (Max)
CS = 1, VREF Open
1
2.5
1
2.3
2.5
mA
IOUT, TRI-STATE Output Current (Max)
AC Electrical Characteristics
The following specifications apply for VCC = 5VDC, tr = tf = 10 ns unless otherwise specified. Boldface limits apply from TMIN
to TMAX; all other limits TA = Tj = 25°C.
Parameter
Typ (1)
Conditions
tC, Maximum Conversion Time (See Figure 7)
Tested
Limit (2)
Design
Limit (3)
Units
60
μs
30
40
tW(WR), Minimum WR Pulse Width
See (4)
50
150
tACC, Maximum Access Time (Delay from Falling Edge of RD to
Output Data Valid)
CL = 100 pF (4)
145
225
ns
t1H, t0H, TRI-STATE Control (Maximum Delay from Rising Edge of
RD to Hi-Z State)
CL = 10 pF, RL = 10k (4)
125
200
ns
tWI, tRI, Maximum Delay from Falling Edge of WR or RD to Reset
of INTR
tDS, Minimum Data Set-Up Time
See (4)
ns
200
400
ns
50
100
ns
tDH, Minimum Data Hold Time
ns
CIN, Capacitance of Logic Inputs
5
pF
COUT, Capacitance of Logic Outputs
5
pF
(1)
(2)
(3)
(4)
4
The temperature coefficient is 0.3%/°C.
ADC0844, ADC0848
www.ti.com
Typical Performance Characteristics
Logic Input Threshold Voltage
vs. Supply Voltage
Output Current vs. Temperature
Figure 4.
Figure 5.
Power Supply Current vs. Temperature
Linearity Error vs. VREF
Figure 6.
Figure 7.
Conversion Time vs. VSUPPLY
Conversion Time vs.Temperature
Figure 8.
Figure 9.
5
ADC0844, ADC0848
www.ti.com
Typical Performance Characteristics (continued)
Unadjusted Offset Error vs.
VREF Voltage
Figure 10.
TRI-STATE Test Circuits and Waveforms
t1H
t1H, CL = 10 pF
t0H
t0H, CL = 10 pF
tr = 20 ns
Leakage Current Test Circuit
6
ADC0844, ADC0848
www.ti.com
Timing Diagrams
Read strobe must occur at least 600 ns after the assertion of interrupt to ensure reset of INTR .
MA stands for MUX address.
Figure 11. Using the Previously Selected Channel Configuration and Starting a Conversion
7
ADC0844, ADC0848
www.ti.com
ADC0848 Functional Block Diagram
8
ADC0844, ADC0848
www.ti.com
Functional Description
The ADC0844 and ADC0848 contain a 4-channel and 8-channel analog input multiplexer (MUX) respectively.
Each MUX can be configured into one of three modes of operation differential, pseudo-differential, and single
ended. These modes are discussed in Applications Information. The specific mode is selected by loading the
MUX address latch with the proper address (see Table 1 and Table 2). Inputs to the MUX address latch (MA0MA4) are common with data bus lines (DB0-DB4) and are enabled when the RD line is high. A conversion is
initiated via the CS and WR lines. If the data from a previous conversion is not read, the INTR line will be low.
The falling edge of WR will reset the INTR line high and ready the A/D for a conversion cycle. The rising edge of
WR, with RD high, strobes the data on the MA0/DB0-MA4/DB4 inputs into the MUX address latch to select a
new input configuration and start a conversion. If the RD line is held low during the entire low period of WR the
previous MUX configuration is retained, and the data of the previous conversion is the output on lines DB0-DB7.
After the conversion cycle (tC ≤ 40 μs), which is set by the internal clock frequency, the digital data is transferred
to the output latch and the INTR is asserted low. Taking CS and RD low resets INTR output high and outputs the
conversion result on the data lines (DB0-DB7).
APPLICATIONS INFORMATION
MULTIPLEXER CONFIGURATION
The design of these converters utilizes a sampled-data comparator structure which allows a differential analog
input to be converted by a successive approximation routine.
The actual voltage converted is always the difference between an assigned “+” input terminal and a “−” input
terminal. The polarity of each input terminal of the pair being converted indicates which line the converter expects
to be the most positive. If the assigned “+” input is less than the “−” input the converter responds with an all zeros
output code.
A unique input multiplexing scheme has been utilized to provide multiple analog channels. The input channels
can be software configured into three modes: differential, single ended, or pseudo-differential. Figure 12 shows
the three modes using the 4-channel MUX ADC0844. The eight inputs of the ADC0848 can also be configured in
any of the three modes. In the differential mode, the ADC0844 channel inputs are grouped in pairs, CH1 with
CH2 and CH3 with CH4. The polarity assignment of each channel in the pair is interchangeable. The singleended mode has CH1–CH4 assigned as the positive input with the negative input being the analog ground
(AGND) of the device. Finally, in the pseudo-differential mode CH1–CH3 are positive inputs referenced to CH4
which is now a pseudo-ground. This pseudo-ground input can be set to any potential within the input commonmode range of the converter. The analog signal conditioning required in transducer-based data acquisition
systems is significantly simplified with this type of input flexibility. One converter package can now handle ground
referenced inputs and true differential inputs as well as signals with some arbitrary reference voltage.
The analog input voltages for each channel can range from 50 mV below ground to 50 mV above VCC (typically
5V) without degrading conversion accuracy.
9
ADC0844, ADC0848
www.ti.com
Table 1. ADC0844 MUX ADDRESSING (1)
MUX Address
CS
RD
MA2
MA1
X
L
L
L
L
X
L
L
H
L
X
L
H
L
L
X
L
H
H
L
L
H
L
L
L
L
H
L
H
L
L
H
H
L
L
H
(1)
MA0
WR
MA3
NP
CH2
CH3
CH4
H
H
H
H
H
NP
L
H
H
H
L
H
H
L
L
L
H
H
H
L
H
L
H
H
H
L
L
X
X
X
X
L
H
L
MUX Mode
Differential
Single-Ended
H
NP
AGND
H
H
NP
Channel#
CH1
Pseudo- Differential
Previous Channel Configuration
X = don't care, NP = negative pulse
4 Single-Ended
2 Differential
3 Pseudo-Differential
Combined
Figure 12. Analog Input Multiplexer Options
REFERENCE CONSIDERATIONS
The voltage applied to the reference input of these converters defines the voltage span of the analog input (the
difference between VIN(MAX) and VIN(MIN)) over which the 256 possible output codes apply. The devices can be
used in either ratiometric applications or in systems requiring absolute accuracy. The reference pin must be
connected to a voltage source capable of driving the minimum reference input resistance of 1.1 kΩ. This pin is
the top of a resistor divider string used for the successive approximation conversion.
In a ratiometric system (Figure 13), the analog input voltage is proportional to the voltage used for the A/D
reference. This voltage is typically the system power supply, so the VREF pin can be tied to VCC. This technique
relaxes the stability requirements of the system reference as the analog input and A/D reference move together
maintaining the same output code for a given input condition. For absolute accuracy (Figure 14), where the
analog input varies between very specific voltage limits, the reference pin can be biased with a time and
temperature stable voltage source. The LM385 and LM336 reference diodes are good low current devices to use
with these converters.
The maximum value of the reference is limited to the VCC supply voltage. The minimum value, however, can be
quite small (see Typical Performance Characteristics) to allow direct conversions of transducer outputs providing
less than a 5V output span. Particular care must be taken with regard to noise pickup, circuit layout and system
error voltage sources when operating with a reduced span due to the increased sensitivity of the converter (1
LSB equals VREF/256).
10
ADC0844, ADC0848
www.ti.com
THE ANALOG INPUTS
Analog Differential Voltage Inputs and Common-Mode Rejection
The differential input of these converters actually reduces the effects of common-mode input noise, a signal
common to both selected “+” and “−” inputs for a conversion (60 Hz is most typical). The time interval between
sampling the “+” input and then the “−” inputs is ½ of a clock period. The change in the common-mode voltage
during this short time interval can cause conversion errors. For a sinusoidal common-mode signal this error is:
where
fCM is the frequency of the common-mode signal
Vpeak is its peak voltage value
tC is the conversion time
For a 60 Hz common-mode signal to generate a ¼ LSB error (≈5 mV) with the converter running at 40 μS, its
peak value would have to be 5.43V. This large a common-mode signal is much greater than that generally found
in a well designed data acquisition system.
Table 2. ADC0848 MUX Addressing (1)
MUX Address
MA3
MA2
MA1
X
L
L
L
L
L
X
L
L
L
H
L
X
L
L
H
L
L
X
L
L
H
H
L
X
L
H
L
L
L
X
L
H
L
H
X
L
H
H
L
X
L
H
H
L
H
L
L
H
L
L
H
L
(1)
MA0
CS
MA4
WR
RD
Channel
CH5
CH6
H
L
H
L
H
H
L
H
L
L
L
H
L
H
L
H
L
H
L
L
H
H
L
H
H
L
L
H
H
L
L
L
H
L
H
H
L
H
L
H
L
H
H
H
L
L
H
NP
NP
CH1
CH2
CH3
CH4
H
H
H
H
L
H
H
H
H
L
H
H
L
L
L
L
H
H
H
L
L
H
L
H
H
H
L
H
L
L
H
H
L
H
H
L
H
H
H
L
L
L
H
H
H
H
L
H
L
H
H
H
H
H
L
L
H
X
X
X
X
X
L
L
H
NP
H
CH8
AGND
MUX Mode
Differential
H
H
CH7
Single-Ended
PseudoDifferential
11
ADC0844, ADC0848
www.ti.com
Input Current
Due to the sampling nature of the analog inputs, short duration spikes of current enter the “+” input and exit the
“−” input at the clock edges during the actual conversion. These currents decay rapidly and do not cause errors
as the internal comparator is strobed at the end of a clock period. Bypass capacitors at the inputs will average
these currents and cause an effective DC current to flow through the output resistance of the analog signal
source. Bypass capacitors should not be used if the source resistance is greater than 1 kΩ.
Input Source Resistance
The limitation of the input source resistance due to the DC leakage currents of the input multiplexer is important.
A worst-case leakage current of ± 1 μA over temperature will create a 1 mV input error with a 1 kΩ source
resistance. An op amp RC active low pass filter can provide both impedance buffering and noise filtering should
a high impedance signal source be required.
OPTIONAL ADJUSTMENTS
Zero Error
The zero of the A/D does not require adjustment. If the minimum analog input voltage value, VIN(MIN), is not
ground, a zero offset can be done. The converter can be made to output 0000 0000 digital code for this minimum
input voltage by biasing any VIN (−) input at this VIN(MIN) value. This is useful for either differential or pseudodifferential modes of input channel configuration.
The zero error of the A/D converter relates to the location of the first riser of the transfer function and can be
measured by grounding the V− input and applying a small magnitude positive voltage to the V+ input. Zero error
is the difference between actual DC input voltage which is necessary to just cause an output digital code
transition from 0000 0000 to 0000 0001 and the ideal ½ LSB value (½ LSB=9.8 mV for VREF=5.000 VDC).
Full-Scale
The full-scale adjustment can be made by applying a differential input voltage which is 1 ½ LSB down from the
desired analog full-scale voltage range and then adjusting the magnitude of the VREF input for a digital output
code changing from 1111 1110 to 1111 1111.
Adjusting for an Arbitrary Analog Input Voltage Range
If the analog zero voltage of the A/D is shifted away from ground (for example, to accommodate an analog input
signal which does not go to ground), this new zero reference should be properly adjusted first. A VIN (+) voltage
which equals this desired zero reference plus ½ LSB (where the LSB is calculated for the desired analog span, 1
LSB = analog span/256) is applied to selected “+” input and the zero reference voltage at the corresponding “−”
input should then be adjusted to just obtain the 00HEX to 01HEX code transition.
Figure 13. Referencing Examples - Ratiometric
12
ADC0844, ADC0848
www.ti.com
Figure 14. Referencing Examples - Absolute with a Reduced Span
The full-scale adjustment should be made [with the proper VIN (−) voltage applied] by forcing a voltage to the VIN
(+) input which is given by:
where
VMAX = the high end of the analog input range
VMIN = the low end (the offset zero) of the analog range. (Both are ground referenced.)
(1)
The VREF (or VCC) voltage is then adjusted to provide a code change from FEHEX to FFHEX. This completes the
adjustment procedure.
For an example see the Zero-Shift and Span Adjust circuit below.
Figure 15. Zero-Shift and Span Adjust (2V ≤ VIN ≤ 5V)
13
ADC0844, ADC0848
www.ti.com
Figure 16. Differential Voltage Input 9-Bit A/D
Figure 17. Span Adjust (0V ≤ VIN ≤ 3V)
Diodes are 1N914
DO = all 1s if VIN(+)>VIN(−)
DO = all 0s if VIN(+)
