52220006
52220006
    LAPP(缆普)
    Module
    套管 黑色
52220006 数据手册
SKINTOP® UNCONTROLLED COPY Strain relief cable glands Cable bushing systems SKINTOP® CUBE Modular multi-cable bushing system frame SKINTOP® CUBE SKINTOP® CUBE provides an innovative approach to traditional multi-cable bushing systems, providing many great improvements and advancements including increased simplicity, ease of use, and safety. Application advantage • F aster and easier assembling and disassembling than other multi-cable bushing systems •C  able diameters ranging from 4 - 16 mm are covered with just four SKINTOP® CUBE modules, greatly reducing inventory The patented SKINTOP® CUBE flexible clip modules provide extremely quick and easy installation with far better sealing and clamping capabilities. Additionally, service to the cables is greatly simplified, as removing the frame from the enclosure is not necessary when replacing cables. Approvals module •S  ecurely fixed SKINTOP® CUBE modules can be assembled with the cable before installation in the frame Complete the installation • Materials are oil, grease, UV, and ozone resistant; the perfect solution for industrial applications where harnessed cables need to be installed Rectangular hole punch page 430 • The SKINTOP® CUBE frame accommodates up to10 cables and fits within standard 16- and 24-pole industrial connector entry holes Technical data Material: - frame: - frame seal: - clip module: - clip module seal: Color: black glass fiber reinforced polyamide CR special polypropylene LSE 2 Frames Temperature range: -20°C to +80°C Protection: IP64 Modules Part number Size 52220000 52220001 16 panel cut-out 24 panel cut-out Dimensions mm Max. number of inserts Pack size 36 x 86 36 x 112 8 10 1 1 Part number Description 20 x 20 mm modules 52220002 small module 52220003 large module 52220004 blank module 52220040 AS-i module 40 x 40 mm modules 52220005 small module 52220006 large module 52220007 blank module Clamping range in mm Pack size 0.157 - 0.236 4-6 0.236 - 0.354 6-9 0.039 - 0.118 1-3 AS-i bus cable 5 5 5 5 0.354 - 0.472 0.472 - 0.630 — 5 5 5 9 - 12 12 - 16 — If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. 510 for current information see: www.lappusa.com • www.lappcanada.com SKINTOP® UNCONTROLLED COPY Cable bushing systems Strain relief cable glands SKINTOP® CUBE Modular multi-cable bushing system Splittable plug-in sealing module is simply fitted onto the cable Patented sealing system with flexible clamping range Four-side sealing for installation in any direction Simple to unlock with a screwdriver Only four modules for clamping ranges from 4 - 16 mm Integrated flat seal for perfect sealing Full-length sealing edge Fold-away clamping brackets for easy plug-in Possible module combinations 16 frame module 24 frame module 8x (20x20) modules 10x (20x20) modules 4x (20x20) 1x (40x40) modules 6x (20x20) 1x (40x40) modules 2x (40x40) modules 2x (20x20) 2x (40x40) modules If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. for current information see:  www.lappusa.com • www.lappcanada.com 511
52220006 价格&库存
很抱歉,暂时无法提供与“52220006”相匹配的价格&库存,您可以联系我们找货
