SKINTOP®
UNCONTROLLED COPY
Strain relief cable glands
Cable bushing systems
SKINTOP® CUBE
Modular multi-cable bushing system
frame
SKINTOP® CUBE
SKINTOP® CUBE provides an innovative approach to traditional multi-cable
bushing systems, providing many great improvements and advancements
including increased simplicity, ease of use, and safety.
Application advantage
• F aster and easier assembling and disassembling than other
multi-cable bushing systems
•C
able diameters ranging from 4 - 16 mm are covered
with just four SKINTOP® CUBE modules, greatly reducing
inventory
The patented SKINTOP® CUBE flexible clip modules provide extremely
quick and easy installation with far better sealing and clamping capabilities.
Additionally, service to the cables is greatly simplified, as removing the frame
from the enclosure is not necessary when replacing cables.
Approvals
module
•S
ecurely fixed SKINTOP® CUBE modules can be assembled
with the cable before installation in the frame
Complete the installation
• Materials are oil, grease, UV, and ozone resistant; the
perfect solution for industrial applications where harnessed
cables need to be installed
Rectangular
hole punch
page 430
• The SKINTOP® CUBE frame accommodates up to10
cables and fits within standard 16- and 24-pole industrial
connector entry holes
Technical data
Material:
- frame:
- frame seal:
- clip module:
- clip module seal:
Color: black
glass fiber reinforced polyamide
CR
special polypropylene
LSE 2
Frames
Temperature range: -20°C to +80°C
Protection: IP64
Modules
Part
number
Size
52220000
52220001
16 panel cut-out
24 panel cut-out
Dimensions
mm
Max. number
of inserts
Pack
size
36 x 86
36 x 112
8
10
1
1
Part
number
Description
20 x 20 mm modules
52220002
small module
52220003
large module
52220004
blank module
52220040
AS-i module
40 x 40 mm modules
52220005
small module
52220006
large module
52220007
blank module
Clamping range
in
mm
Pack
size
0.157 - 0.236
4-6
0.236 - 0.354
6-9
0.039 - 0.118
1-3
AS-i bus cable
5
5
5
5
0.354 - 0.472
0.472 - 0.630
5
5
5
9 - 12
12 - 16
If not otherwise specified, all values relating to the product are nominal values.
Photographs are not to scale and are not true representations of the products in question.
510
for current information see: www.lappusa.com • www.lappcanada.com
SKINTOP®
UNCONTROLLED COPY
SKINTOP® CUBE
Splittable plug-in sealing module
is simply fitted onto the cable
Patented sealing system
with flexible clamping range
Four-side sealing for
installation in any
direction
Simple to unlock with
a screwdriver
Only four modules for
clamping ranges
from 4 - 16 mm
Integrated flat seal for
perfect sealing
Full-length sealing edge
Fold-away clamping
brackets for easy plug-in
Possible module combinations
16 frame module
24 frame module
8x (20x20)
modules
10x (20x20)
modules
4x (20x20)
1x (40x40)
modules
6x (20x20)
1x (40x40)
modules
2x (40x40)
modules
2x (20x20)
2x (40x40)
modules
511
很抱歉,暂时无法提供与“52220003”相匹配的价格&库存,您可以联系我们找货
