BWC-2MRSFRS9
BWC-2MRSFRS9
    BANNER(邦纳)
    SMA(DO-214AC)
    同轴电缆组件 RP-SMA 至 RP-SMA PFP 195 360.0"(9.1m)30.0'
BWC-2MRSFRS9 数据手册
VALUE ADDED SOLUTIONS - ACCESSORIES High Performance Coaxial Cable PFP195 Premium Low-Loss RF Communications Cable PCTEL’s PFP195 Cable is an ideal cable for longer RF cable runs that require high flexibility as well as low signial attenuation. PFP195 cable balances flexibility and high performance, making this cable uniquely suited for jumpers or long cable runs that require low levels of attenuation. PCTEL’s PFP line of cable is specifically designed to optimize radio frequency communications from 30MHz up to 6GHz. PCTEL offers a complete line of bulk cable for large installation projects, premium pre-made cable assemblies, and a wide variety of connector types, including reverse polarity, are available for most PFP cable sizes. Features • • • • Typical Attentuation By Frequency Frequency Attenuation (dB/100ft) 30 MHz 2.0 dB 50 MHz 2.5 dB 150 MHz 4.4 dB 220 MHz 5.4 dB 450 MHz 7.8 dB 700 MHz 9.8 dB 800 MHz 10.5 dB 900 MHz 11.1 dB 1500 MHz 14.5 dB 2000 MHz 16.9 dB 2500 MHz 19.0 dB 5800 MHz 29.9 dB Ordering Information* Part Number Description PFP195-REEL-1K 1000ft Reel of PFP195 Premium Cable Outdoor rated: UV stable jacket and water resistant construction Easily routed, flexible construction High performance, lightweight design Ideal for RF applications including GPS, LMR, WLAN, SCADA, PTC, etc. Electrical Characteristics Capacitance (pF/ft) Impedance (Ohms) Velocity (%) 25.4 50 80 DC Resistance (Ω/1000ft) Shielding Effectiveness (dB) Inner Outer Conductor Conductor < 7.6 < 4.9 > 90 Jacket Spark (VAC) Cut Off Frequency (GHz) Peak Power (kW) 3000 41 2.5 Mechanical/Environmental Specifications Bend Installation Radius (Min.) Bend Repeated Radius (Min.) Storage Temp. Installation Temp. Operating Temp. 12.7 mm 50.8 mm -70 to +85°C -94 to +185°F -40 to +85°C -40 to +185°F -40 to +85°C -40 to +185°F Construction Specifications Cable Section Material Diameter Jacket Polyethylene .195 in (4.95mm) Braid Tin Plated Copper .139 in (3.53mm) Outer Conductor Aluminum Tape .116 in (2.94mm) Dielectric Foam Polyethylene .110 in (2.79mm) Inner conductor Solid BC .037 in (.94mm) *Standard configuration. Please contact PCTEL Customer Service at (800)323-9122 for custom reel size and Custom Cable Assemblies. PCTEL, Inc. WEB: www.antenna.pctel.com
BWC-2MRSFRS9 价格&库存
很抱歉,暂时无法提供与“BWC-2MRSFRS9”相匹配的价格&库存,您可以联系我们找货
