PM28B3375
PM28B3375
    LEADERTECH
    Molded
    FERRITE 140OHM HINGED 4.80MM
PM28B3375 数据手册
ENCLOSuRE shielding SOLUTIONS SHIELDING SELECTION CONSIDERATIONS Consider these important factors in the selection of appropriate shielding products for your design: n Operating Frequency n Cycle Life n Nuclear, Biological, n Materials Compatibility n Cost n Load/Forces n Material Thickness/Alloy n n Corrosive Considerations n Attenuation Performance n n Commercial or Military n Fastening/Mounting n Methods n Storage Environment n Worldwide Compliance n Operating Environment n Chemical (NBC) Shielding/Grounding/Other Electrical Requirements Space/Weight Considerations Product Safety Recyclability QUICK REFERENCE PRODUCT SELECTION CHART PARAMETERS High Cycling Wiping Applications TechSIL ELASTOMER SHEETS TechSIL ELASTOMER GASKETS CuBe METAL GASKETS FSG FABRIC SHIELDING GASKETS CFS CONDUCTIVE FOAM TechMESH KNITTED WIRE TechMESH COMBO STRIP Good Good Excellent Very Good Fair Good Good N/A Good Excellent Good N/A Fair Fair Dust Protection Excellent Excellent N/A Very Good Very Good Fair Excellent Moisture Protection Excellent Excellent N/A N/A N/A N/A Excellent Deflection % 10-20% 15-50% 15-85% 30-50% 30-60% 20-50% 20-50% Design Flexibility Excellent Excellent Very Good Excellent Excellent Good Very Good Finish Options Very Good Very Good Excellent Good Fair Good Good I/O Applications Excellent Fair Fair Very Good Excellent Fair Fair Shield Effectiveness Excellent Excellent Excellent Excellent Very Good Excellent Excellent Tooling/NRE Low None None None/Low Low None Low Part Cost $$$ $$$ $$$ $ $$ $ $$ Very Good Very Good Excellent Excellent Very Good Very Good Good Lead Times Notice: Leader Tech cannot guarantee that the same test data as described herein will be obtained. Thus, it is recommended that each user make their own tests to confirm laboratory test data and determine suitability of products for their particular application. The products described in this catalog shall be standard quality, however, the products in this catalog are sold without warranty of fitness for a particular purpose, either expressed or implied, except to the extent expressly stated on Leader Tech's quotation or order acknowledgment. Leader Tech does not warrant that devices incorporating one or more of the products described in this catalog will be free of conflict with existing or future patents of third parties. All risks of lack of fitness, patent infringement, and the like are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to make, use, or sell any product or process in conflict with existing or future patents. 2 TABLE OF CONTENTS 4 5 6 7 8 8 9 9 10 12 14 16 18 19 22 23 24 25 26 27 28 29 30 35 36 37 39 Application of Fingerstock Gaskets Compression/Deflection Performance and EMI Shielding Effectiveness Ordering Information & Adhesive Mounting Instructions 4 Metals Galvanic Compatibility Chart 3 4 D 2 1 3 4 2 3 1D 2 1 D D BeCu Low Profile Series ............................................................................................. D D C C PITCH 8 7 6 5 4 FINGER 3 2 BeCu PCI Series.......................................................................................................... 4 3 1 2 1 C C D D D B D B BeCu Adhesive Mount Series..................................................................................... B A C C PSA TAPE 4 3 PITCH 4 PITCH 2 3 FINGER A PREPARED CUST. NAME THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF MATERIAL SPEC LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR .0035 BeCu 172 WARRANTY THE PERFORMANCE CHARACTERISTICS. PITCH C D FINGER 4 DATE SIZE CUST. NAME CUSTOMER DWG NO. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO.#2 PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR MATERIAL SPEC WARRANTY THE PERFORMANCE CHARACTERISTICS.2 .002 BeCu 172 3 4 A C D C SHEET PREPARED DATE M. Paul 1/23/2009 1 OF 1 D C GASKET, PCI SERIES ENGINEERING A MFG APPROVAL SIZE BeCu Folded Series.................................................................................................... B 4J674 1 - 4 FSCM NO. REV C 8-45-LPAH-XX-16 SCALE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX ± .005 .XX  .01 .1 .X ± ANGLES    C B DWG NO C 2 BeCu Slot Mount Series.............................................................................................. A D LOW PROFILE SERIES 12/3/2008 DJM ENG B B QA 3 A 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XX .01 .X .1 ANGLES 2 FINGER D 1 2 BeCu Dome Top Series............................................................................................... B REV DWG NO CB QA APPROVAL 8-19PCI-XX-XX B SCALE FSCM NO. 1 B 3 4J674 B A SHEET 1 OF 1 2 1 C C A PITCH FINGER B D BeCu Twist Series........................................................................................................ C 4 2 D D PITCH MATERIAL SPEC LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR NAME BeCu 172 WARRANTY THE PERFORMANCE CHARACTERISTICS. CUST..0035 FINGER C FINGER SIZE D 3 FSCM NO. DATE 1 PITCH .056 TYP B A PITCH C D 7 6 5 4 B 3 PREPARED CUST. NAME 4 CUST. NAME A 4 4 .XXX ± .005 .XX  .013 .X ± .1 2 CUST. NAME PREPARED CUSTOMER DWG NO. ENGINEERING DATE 3 2 C REV SIZE SCALE FSCM NO. SHEET 1 OF 1 SCALE 1 OF 1 REV FSCM NO. 4J674 P1 A SHEET 1 OF 1 1 REV DWG NO 10-26UD-XX-16 FSCM NO. SHEET 1 14-18ML SCALE 4J674 A DWG NO C C P1 6-34T REV A 1 CONTACT SERIES SIZE A A DWG NO SIZE B GROUNDING GASKET 8/28/2008 B 1 1 DATE DATE 2 REV SHEET 1 OF 1 T TWIST SERIES MFG APPROVAL DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR MATERIAL SPEC PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF NAME PREPARED CUST. LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION .0045"CuBe C17200 1/4 H WARRANTY THE PERFORMANCE CHARACTERISTICS. DJM OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. QA PRIVATE EXPENSE,3 AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH ENG ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF MATERIAL SPEC LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR .006 BeCu 172 WARRANTY THE PERFORMANCE CHARACTERISTICS. TechSIL Oriented Wire................................................................................................ A A REV B DATE CLIP ON GASKET TechSIL Conductive Elastomers................................................................................. 4 B B PREPARED B CUSTOMER PREPAREDDWG NO.#2 - 4 B 2 C CUSTOMER DWG NO.#2 MFG APPROVAL UNLESS - OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XX FINISH .01 QA APPROVAL THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN .X .1 2 PRIVATE EXPENSE, AND MAY NOT USED, HT TO ANGLES FULL HARD A 1 OF 1 PSA TAPE C ANGLES   CUST. NAME A SHEET SLOT MOUNT SERIES FOLDED SERIES THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION - DVG 11/15/2007 OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. QA PRIVATE EXPENSE, AND MAY NOT USED, THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION FINISH QA APPROVAL FOR DUPLICATED OR DISCLOSED IN WHOLE OR OWNED IN PART BY LEADERTECH, OR DEVELOPED AT IT'S OWN - ENG SIZE DWG NO PRIVATE EXPENSE, MAY NOT USED, ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR ANDFINISH PART FOR DUPLICATED OR DISCLOSED IN WHOLE H.T. OR TOINDPH 383 C 25-55CPS PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF ANY PURPOSE INCLUDING DESIGN, MANUFACTURE UNLESS OR OTHERWISE SPECIFIED, MATERIAL SPEC DIMENSIONS ARE IN INCHES. PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF FSCM NO. SCALE MATERIAL SPEC LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR LEADERTECH. LEADERTECH DOES NOT .XXX GUARANTEE OR ± .005 .004 BeCu ALLOY 172 CuBe C17200 1/4 H 4J674 WARRANTY THE PERFORMANCE CHARACTERISTICS. WARRANTY THE PERFORMANCE CHARACTERISTICS. .XX  .01 3 2   .X ± .1 ANGLES 3 2 Precision Metal Stampings......................................................................................... B 4J674 1 DATE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. A .XXX .005 .07 CUSTOMER DWG NO. ENGINEERING .XX .01 .X .1 ANGLES 2- A A C A PREPARED DATE CUST. NAME THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION DJM 10/14/2008 .50 TYP OWNED BY LEADERTECH, OROWN DEVELOPED AT IT'S OWN DJM OWNED BY LEADERTECH, OR DEVELOPED AT IT'S CUSTOMER DWG NO. MFG CUSTOMER DWG NO. QA PRIVATE EXPENSE, C PRIVATE EXPENSE, AND MAY NOT USED, AND MAY NOT USED, C FINGER WHOLE OR IN PART FOR DUPLICATED OR DISCLOSED B INSIDE DUPLICATED OR DISCLOSED IN WHOLE OR IN PARTINFOR SIZE DWG NO FINISH ENG ENG SIZE DWG NO ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR FINISH ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR D 11-S-32AF-XX-16 PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF AS REQ'D C 14-37FS-XX PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF FSCM NO. SCALE MATERIAL SPEC LEADERTECH. LEADERTECH DOES GUARANTEE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. FSCM NO. MATERIAL SPEC AOR SCALE LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR NOT .0025 CuBe172 C17200 1/4 HT 4J674 WARRANTYCHARACTERISTICS. THE PERFORMANCE CHARACTERISTICS. .003 BeCu SHEET 1 OF 1 ALLOY 4J674 WARRANTY THE PERFORMANCE Metal D-Subs.............................................................................................................. 8 FSCM NO. D C BeCu Contact Series.................................................................................................. A REV 8-S-21AH-XX-16 B UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. B .XXX .005 .XXX .005 .XX .01 .XX .01 .X .1 ANGLES .X2.1 ANGLES 2 FINGER C SCALE PSA TAPE 2 C PITCH GASKET, STYLEB AH DWG NO AC C A SHEET 1 OF 1 1 A SIZE B FINGER A 4J674 12/21/2007 B REV 14-45DT-XX-15 SCALE B D DWG NO C PREPARED BeCu Grounding Series.............................................................................................. A DOME TOP SERIES 3/31/2009 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION 3 2 DVG OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. QA PRIVATE EXPENSE, AND MAY NOT USED, 3 2 DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH ENG ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR H.T. TO 373 DPH PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF MATERIAL SPEC LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR .0025 BeCu ALLOY 172 WARRANTY THE PERFORMANCE CHARACTERISTICS. 4 4 C 4 C PREPARED DATE CUST. NAME UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION DJM OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN.XXX .005 CUSTOMER DWG NO. QA PRIVATE EXPENSE, AND MAY NOT USED, .XX -.01 DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH .1 ANGLES 2ENG  ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR .X  HEAT TREAT TO 373 DPH PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF B PITCH D PSA TAPE 1 A UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XX .01 .X .1 ANGLES 2 BeCu Clip-On Series................................................................................................... A PSA TAPE C 3 A B A B 4J674 SHEET 1 OF 1 1 TechMESH Knitted Wire............................................................................................... TechMESH Elastomer Core Wire................................................................................. TechMESH Combo Strip.............................................................................................. TechMESH Tape.......................................................................................................... FSG Fabric Shielding Gaskets.................................................................................... Shielding Fabrics & Conductive Tapes...................................................................... CFS Conductive Foam Shielding Material................................................................ Custom and Die-Cut Shielding Gaskets.................................................................... Products and Literature.............................................................................................. EMI Enclosure Shielding Solutions 3 Copper Beryllium Fingerstock APPLICATION OF FINGERSTOCK GASKETS EMI designers know and trust the consistent performance of Fingerstock (CuBe) gaskets. To date, CuBe yields the best electrical spring contact available in this industry. The copper beryllium mills have well established techniques and for decades have produced CuBe alloys per ASTM, SAE, JIS, and DIN specifications. Copper Beryllium – The Material of Choice Leader Tech uses only proven technology in creating copper beryllium springs, contacts and gaskets. Beginning with Alloy 25 (1/4 hard) BeCu, we stamp, form, and post heat-treat to a hardness of 340 to 390 DPH. This process is preferred in the EMI shielding industry because it has proven to produce the best electrical spring contacts. Leader Tech CuBe EMI shielding gaskets are the most reliable in the industry. Leader Tech manufactures a wide variety of standard styles and sizes of CuBe gaskets. These gaskets operate in spaces from .010 inches up to .410 inches. Using CuBe materials as thin as .002 inch, we also offer many styles as soft gaskets that provide the low compression force needed in many applications. Leader Tech also designs and manufactures custom spring contacts and gaskets. FINGERSTOCK GASKETS DO TWO THINGS VERY WELL: 1. Their mechanical spring characteristics far surpass all other gaskets in the industry. 2. They offer the highest EMI shielding effectiveness. Leader Tech has been designing and manufacturing Fingerstock Gaskets since the early days of the computer and electronics industries. We combine these years of manufacturing and EMI experience with one key ingredient – the needs of the customer. Our innovative Fingerstock Gasket designs are a direct result of our experience and customer input. Our Compact PCI line of EMI Gaskets is an example of a design that was driven by the needs of a customer and evolved into a line of gaskets that meet all the requirements for Compact PCI faceplate standards while providing superior mechanical and shielding performance. Leader Tech offers many standard off-the-shelf Fingerstock Gaskets as well as the engineering and custom manufacturing experience to help you solve your application. Whether you need one prototype or a large quantity order, our team at Leader Tech is available to respond to your needs. 4 Phone: 866.832.4364 Fax: 813.855.3291 Web: www.leadertechinc.com Copper Beryllium Fingerstock COMPRESSION/DEFLECTION PERFORMANCE Design Compressed Height Compression Force (lbs./linear ft.) 3-23T 0.018 (0.46) 25 6-34T 0.049 (1.24) 33 6-50T2 0.049 (1.24) 9-19UD 0.072 (1.83) 11-32RH 11-45C Leader Tech. Part No. Design Compressed Height Compression Force (lbs./linear ft.) 14-45DT 0.098 (2.49) 24 22-60AH 0.140 (3.56) 25 43 22-60RH 0.070 (1.78) 48 30 23-76FSC 0.130 (3.30) 34 0.035 (0.89) 34 25-109C 0.140 (3.56) 36 0.090 (2.29) 19 25-78FS 0.150 (3.81) 36 Leader Tech. Part No. 11-28FS Average Force/Linear Foot vs. Compressed Height 70 Force per Linear Foot (lb/ft) 60 50 40 30 20 10 0 0.110 0.100 0.090 0.080 0.070 0.060 0.050 Height Under Compression (in) The data presented is based on testing and to our knowledge is accurate and true. Since applications, test methods, and test procedures may vary, we recommend that users of our products perform their own test to assure the suitability of these specific applications. We offer no product warranty, either expressed or implied, except that any product proven defective will be replaced. Freedom from present or future patent infringement cannot be guaranteed, nor can the suitability of our products for specific applications. EMI Enclosure Shielding Solutions 5 Copper Beryllium Fingerstock ORDERING INFORMATION When placing an order or requesting a quotation, please give part number, your required finish I.D. from the chart below, and required length. PART NUMBER EXAMPLE: Stock Item Finish Code Length 11-S-32RH – SN – 16 The above example is the “Slot Mount Series” gasket shown on page 11. The height is .11 inch and the width is .32 inch. The “-S-” indicates a soft gasket. The “SN” indicates a bright tin finish. See list below for available finishes. This part is available in lengths of 16 inches. Consult factory for custom lengths or for availability in 25’ coils. Available Plating Finishes: Finish Type Bright Finish Applicable Specifications Leader Tech Finish Code - BD Bright Tin ASTM B-545, CLASS A SN Satin/Matte Tin ASTM B-545, CLASS A ST ASTM B-579, SC2 SNpb Tin Lead Electro-less Nickel RoHS ASTM B-733, SC 1, CLASS 1 NI Zinc/Chromate Clear ASTM B-633, SC1, TYPE III Zinc Zinc/Chromate Yellow ASTM B-633, SC1, TYPE II ZincY Clear Cadmium Chromate ASTM B-766, CLASS 5, TYPE III CDC Yellow Cadmium Chromate ASTM B-766,CLASS 5, TYPE II CDY Bright Silver ASTM B-700, TYPE 2, GRADE B, CLASS N AG Satin/Matte Silver ASTM B-700, TYPE 2, GRADE A, CLASS N MAG Gold ASTM B-488, TYPE I, CODE C, CLASS 1.25 AU - SU Solderable Unplated Standard plating finish is .0001 inch (.0025 mm) minimum. Plating processes and thicknesses may be varied to meet customer needs. Standard plating finish for gold is 0.00005 inches. See adjacent list of available finishes and consult factory for additional options. ADHESIVE MOUNTING OF FINGERSTOCK GASKETS Leader Tech tape mounted CuBe gaskets offer pressure-sensitive, double-sided adhesive for strong bonding to a wide variety of surface conditions. Ideal for all-purpose contact strips used in metal cabinets and electronic enclosures and is unaffected by temperatures from -67 to +250°F (-55 to 121°C) Simply follow these four easy steps: 1. Remove all grease and oily residue with a solvent such as isopropyl alcohol/water mixture (rubbing alcohol) or heptane. Dry and smooth the mounting surface with emery cloth if necessary. 2. Peal off the protective paper backing from the pressure sensitive adhesive tape. 3. Place the gasket in correct position. Press firmly to ensure a good bond to surface. Avoid repositioning, which might impair the effectiveness of the adhesive or may bend or kink the strip. NOTE: On strips where fingers cover the solid portion of the gasket, pressure may be applied by inserting a mandrel in the strip and pressing down. 4. At room temperature approximately 50% of the ultimate strength will be achieved after 20 minutes, 90% after 24 hours, and 100% after 72 hours. In some cases, bond strength can be increased and ultimate bond strength can be achieved more quickly by exposure of the bond to elevated temperature, e.g., 150°F (66°C) for 1 hour. 6 Phone: 866.832.4364 Fax: 813.855.3291 Web: www.leadertechinc.com Copper Beryllium Fingerstock METALS GALVANIC COMPATIBILITY CHART Group Number 1 Metallurgical Category Gold, solid and plated, Wrought platinum, graphite carbon 2 Anodic Index (V) Gold 0.10 4 Silver, high-silver alloys 0.15 5 0.20 6 0.25 7 Nickel, nickel-copper alloys, titanium, titanium alloys, Monel 0.30 8 BerylliumCopper,lowbrassesorbronzes,silversolder,copper,Ni-Cralloys,austeniticcorrosion resistant steels, most chrome-moly steels, specialty high-temp stainless steels 0.35 9 Commercial yellow brasses and bronzes 0.40 10 High brasses and bronzes, naval brass, Muntz metal 0.45 11 18% Cr type corrosion resistant steels, common 300 series stainless steels 0.50 12 13 0.60 14 Terreplate, tin-lead solder 0.65 15 Lead; high-lead alloys 0.70 16 Wrought 2000 series aluminum alloys 0.75 17 Sn-Pb Zinc 0.80 Wrought aluminum alloys except 2000 series cast Al-Si alloys, 6000 series aluminum 19 0.85 0.90 Cast aluminum alloys other than Al-Si; cadmium plating 0.95 21 1.00 22 1.05 23 1.10 24 1.15 25 Hot Dipped galvanized or electrogalvanized steel 1.20 26 Wrought zinc; zinc die cast alloys 1.25 27 1.30 28 1.35 29 1.40 30 1.45 31 1.50 32 1.55 33 1.60 34 1.65 35 1.70 Wrought and cast magnesium alloys 37 38 Tin 0.55 Chromium or tin plating; 12% Cr type corrosion resistant steels, most 400 series stainless steels, i.e., 410 and some cast stainless steels 36 Be-Cu 0.05 Rhodium plating 20 Nickel 0.00 3 18 Compatible Surface Finishes Silver 1.75 1.80 Beryllium *Harsh Environment .10 volts Max 1.85 *Normal Environment .25 volts Max. *Office Environment .50 volts Max EMI Enclosure Shielding Solutions 7 4 3 2 Copper Beryllium Fingerstock D 3 2 1 C LOW PROFILE SERIES H R D LPAH | Low Profile Adhesive Mount PART NUMBER C A B FINGER PITCH MAT. THICK LENGTH FINGERS TAPE 8-45LPAH-XX-16 0.08 2.03 0.45 11.43 0.100 2.54 0.125 3.18 0.004 0.102 16 406 128 0.145 8-S-45LPAH-XX-16 0.08 2.03 0.45 11.43 0.100 2.54 0.125 3.18 0.003 0.076 16 406 128 0.145 12-60LPAH-XX-16 4 0.12 3.05 0.60 15.24 0.100 2.54 0.125 3.18 0.0043 0.102 16 406 128 0.200 12-S-60LPAH-XX-16 0.12 3.05 0.60 15.24 0.100 2.54 0.125 3.18 0.003 0.076 16 406 128 0.200 2 B Thelowprofileseriesgasketsincorporatedesignfeaturesthatallowforsomeofthelowest compressionforcesintheindustry,whileachievinghighperformanceshieldingeffectiveness. These gaskets are ideally suited for small aperture applications. MOUNTING OPTIONS ■ Tape PITCH B A FINGER Directional Force D Black = inches Blue = mm C XX - Select material/finish (see page 6) PSA TAPE LPH | Low Profile Hook PART NUMBER A 6-45LPH-060-XX-16 0.06 6-S-45LPH-060-XX-16 0.06 B 1.52 0.45 FINGER 11.43 0.100 2.54 0.125 3.18 CUST. NAME PREPARED 16 DJM 406 QA ENG 0.145 DATE 128 0.060 12/3/2008 0.145 SIZE 2 REV 8-45-LPAH-XX-16 FSCM NO. C 4J674 SHEET 1 OF 1 B 1 A 1 A LOW PROFILE SERIES DWG NO C B 2 3 TAPE SCALE 3 Directional Force C PITCH THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION 1.52 0.45 11.43 0.100 2.54 0.125 3.18 0.003 0.076 OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR XX Select material/finish (see page 6) FINISH MOUNTING ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR OPTIONS PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF MATERIAL SPEC LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR ■ Tape .0035 BeCu 172 WARRANTY THE PERFORMANCE CHARACTERISTICS. B 4 Black = inches Blue = mm UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. MAT. THICK LENGTH FINGERS HOOK ID .XXX .005 .XX .01 .1 .X  ANGLES 2 0.004 0.102 16 406 128 0.060 PSA TAPE PCI SERIES D High performance Compact PCI Gaskets designed for easy card insertion in rack mount applications. This gasket is available in two different sizes to accommodate different customer extrusions. They are available in both Copper Beryllium and Stainless Steel. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. PREPARED DATE CUST. NAME UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX ± .005 .XX  .01 .1 .X ± ANGLES    .XXX .005 - 4 PITCH PCI | Contact A PART NUMBER A B 7-19PCI-XX-4.6 0.07 1.78 D 7-19PCI-XX-9.0 0.07 1.78 7-19PCI-XX-14.4 0.07 7-19PCI-SS-4.6 A 1.27 0.18 4.57 0.05 1.27 1.78 0.18 4.57 0.05 1.27 0.07 1.78 0.18 4.57 0.05 7-19PCI-SS-9.0 0.07 1.78 0.18 4.57 7-19PCI-SS-14.4 0.07 1.78 0.18 4.57 8-19PCI-XX-4.6 0.07 1.78 0.19 8-19PCI-XX-9.0 0.07 1.78 8-19PCI-XX-14.4 0.07 8-19PCI-SS-4.6 8-19PCI-SS-9.0 3 0.18 C 0.05 MFG APPROVAL C 0.25 0.180 4.57 0.200 1.27 0.01 0.25 0.180 4.57 0.200 0.05 1.27 0.01 0.25 0.180 4.57 0.05 1.27 0.01 0.25 0.180 4.57 4.83 0.05 1.27 0.02 0.51 0.180 0.19 4.83 0.05 1.27 0.02 0.51 1.78 0.19 4.83 0.05 1.27 0.02 0.07 1.78 0.19 4.83 0.05 1.27 0.07 1.78 0.19 4.83 0.05 1.27 4 0.07 1.78 0.19 4.83 0.05 1.27 8-45LPH-060 B SHEET 1 OF 1 ENG 72 5.08 0.002 0.051 4.60 117 23 0.200 5.08 0.002 0.051 9.00 229 45 0.200 5.08 0.002 0.051 14.40 366 72 4.57 0.200 5.08 0.002 0.051 4.60 117 23 0.180 4.57 0.200 5.08 0.002 SPECIFIED, DIMENSIONS ARE IN INCHES. 0.051 UNLESS 9.00 OTHERWISE 229 45 0.51 0.180 4.57 0.200 5.08 0.002 0.051 .XX  14.40 .01 366 0.02 0.51 0.180 4.57 0.200 5.08 0.002 0.051 .X ± 4.60 .1 117 0.02 0.51 0.180 4.57 0.200 5.08 0.002 0.051- 0.02 0.51 0.180 4.57 0.200 5.08 CUST. NAME 0.002 0.051- D 14.40 2 229 366 23 45 72 - FINISH - PREPARED ENGINEERING DATE LPH, LOW PRO B MFG APPROVAL SIZE QA APPROVAL C SCALE MATERIAL ASPEC .0035" CuBe C17200 1/4 H OTHERWISE SPECIFIED, DIMENSIONS ARE INWeb: INCHES. www.leadertechinc.com Phone: 866.832.4364UNLESS Fax: 813.855.3291 PSA TAPE 72 CUSTOMER DWG NO.#2 C C ANGLES    CUSTOMER DWG NO. B 3 9.00 SIZE A S 366 .XXX ± .005 12/3/2008 A1 QA 14.40 3 DATE REV DJM 0.051 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. .XXX ± .005 .XX  .01 PREPARED 0.002 XX - Select material/finish (see page 6) 4 2A ANGLES 2 5.08 Directional Force 8 .X .1 CUST. NAME FINISH 0.01 MOUNTING OPTIONS ■ Extrusion C CUSTOMER DWG NO.#2 .01 LPH, LOW .XX PROFILE HOOK SERIES 3 SIZE DWG NO BlackINFORMATION = inches Blue- = mm THIS DOCUMENT CONTAINS PROPRIETARY QA APPROVAL OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. PRIVATE AND MAY NOT D FINGEREXPENSE, PITCH MAT.USED, THICK LENGTHFSCM NO. -FINGERS MATERIAL SPEC SCALE DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR 4J674 .0035" CuBe C17200 1/4 H INCLUDING 0.01 0.25 ANY 0.180 PURPOSE 4.57 20.200 5.08 DESIGN, 0.002 MANUFACTURE 0.051 4.60 OR117 FINISH - 23 1 PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF 0.01 0.25 LEADERTECH. 0.180 4.57 0.200 5.08 DOES 0.002 NOT0.051 9.00 OR 229 MATERIAL 45 SPEC LEADERTECH GUARANTEE C 172 .0035 BeCu WARRANTY THE PERFORMANCE CHARACTERISTICS. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. 4.57 8-19PCI-SS-14.4 ENGINEERING - FINGER B CUSTOMER DWG NO. - 2 DWG NO 8-45L FSCM NO. 4J 1 D Copper Beryllium Fingerstock D ADHESIVE MOUNT SERIES AH | Adhesive Mount PART NUMBER PITCH FINGER 1 4 Black = inches Blue = mm Comp = Compressed A B C FINGER PITCH MAT. THICK COMP WIDTH COMP HEIGHT LENGTH FINGERS TAPE 11-32AH-XX-16 0.11 2.79 0.32 8.13 0.20 5.08 0.170 4.32 0.187 4.75 0.003 0.076 0.39 9.91 0.04 1.02 16 406 86 11-S-32AH-XX-16 0.11 2.79 0.32 8.13 0.20 5.08 4 0.170 4.32 0.187 4.75 0.002 0.051 0.39 3 9.91 0.04 1.02 16 406 86 13-37AH-XX-16 0.13 3.30 0.37 9.40 0.21 5.33 0.225 5.72 0.250 6.35 0.003 0.076 0.51 12.95 0.05 1.27 16 406 64 0.145 13-S-37AH-XX-16 0.13 3.30 0.37 9.40 0.21 5.33 0.225 5.72 0.250 6.35 0.002 0.051 0.51 12.95 0.05 1.27 16 406 64 0.145 14-38AH-XX-16 0.14 3.56 0.38 3 9.65 0.20 5.08 0.343 8.71 0.375 9.53 0.004 2 0.102 0.53 13.46 0.05 1.27 16 406 431 0.145 22-60AH-XX-16 0.22 5.59 0.60 15.24 0.28 7.11 0.344 8.74 0.375 9.53 0.005 0.127 0.73 18.54 0.09 2.29 16 406 43 0.200 22-S-60AH-XX-16 0.22 5.59 0.60 15.24 0.28 7.11 0.344 8.74 0.375 9.53 0.003 0.076 0.73 18.54 0.09 2.29 16 406 43 0.200 0.32 8.13 0.78 19.81 0.45 11.43 0.344 8.74 0.375 9.53 0.004 0.102 0.98 24.89 0.12 3.05 16 406 43 0.375 0.32 8.13 0.78 19.81 0.45 11.43 0.344 8.74 0.375 9.53 0.003 0.076 0.98 24.89 0.12 3.05 16 406 43 0.375 D 32-78AH-XX-16 32-S-78AH-XX-16 C D C 0.145 2 0.145 D B MOUNTING OPTIONS ■ Tape Directional Force TheAHseriesgasketsareadhesivemountedgeneral-purposegasketsusedinbothcompression and wiping applications. Sizes range from .11”(2.8mm) to .32”(8.1 mm) in height. Applications include electronic enclosures, shielded cabinets, and MRI chamber doors. B A XX - Select material/finish (see page 6) C DOME TOP SERIESB PSA TAPE C PITCH FINGER UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. B .XXX .005area for electrical contact and smooth wiping action. Also The Dome Top Gaskets are known for their large surface .XX .01 available in a solid top profile allowing for omni-directional wiping. Together with the Slot Mount Series, the Dome Top .X .1 ANGLES 2 GasketsCare a mainstay in the enclosure/chassis industries. Commonly PREPAREDmounted DATEwith adhesive tape. CUST. NAME PITCH 4 FINGER 3 2 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION 12/21/2007 DVG OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. QA PRIVATE EXPENSE, AND MAY NOT USED, Black = inches Blue = mm Comp = Compressed DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR SIZE DWG NO FINISH ENG ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR H.T. TO 373 DPHCOMP WIDTH C 8-S-21AH-XX-16 PROCUREMENT THE WRITTEN PERMISSION 4 B WITHOUTFINGER PITCH OFMAT. THICK COMP HEIGHT 3 LENGTH FINGERS TAPE FSCM NO. MATERIAL SPEC SCALE LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR B .0025 BeCu ALLOY 172 4J674 WARRANTY THE PERFORMANCE CHARACTERISTICS. A 4 A 11-35DT-XX-15 0.11 2.79 0.35 8.89 11-S-35DT-XX-15 0.11 2.79 0.35 8.89 14-45DT-XX-15 0.14 3.56 0.45 14-S-45DT-XX-15 0.14 3.56 0.22 0.22 22-62DT-XX-15 1 22-S-62DT-XX-15 0.169 4.29 0.187 4.75 0.003 0.076 0.38 9.65 0.169 4.29 0.187 4.75 0.002 0.051 0.38 9.65 11.43 0.228 5.79 0.250 6.35 0.003 0.076 0.51 0.45 11.43 0.228 5.79 0.250 6.35 0.002 0.051 0.51 5.59 0.62 15.75 0.345 8.76 0.375 9.53 0.004 0.102 5.59 0.62 15.75 0.345 8.76 0.375 9.53 0.003 0.076 LOW PROFILE SERIES B Directional Force 8-45-LPAH-XX-16 SCALE FSCM NO. 4J674 3 A D 0.06 1.52 15 381 80 0.100 0.06 1.52 15 381 80 0.100 12.95 0.07 1.78 15 381 60 0.100 12.95 0.07 1.78 15 381 60 0.100 0.76 19.30 0.10 2.54 15 381 40 0.200 0.76 19.30 0.10 2.54 15 381 40 0.200 XX - Select material/finish (see page 6) D SHEET 1 OF 1 OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PSA TAPE PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. FINGER 1 PITCH FINGER DTS | Dome Top Solid PART NUMBER 4 J674 B FINGER 0.11 2.79 0.35 8.89 11-S-35DTS-XX-15 0.11 2.79 0.35 8.89 14-45DTS-XX-15 0.14 14-S-45DTS-XX-15 0.14 22-62DTS-XX-15 0.22 22-S-62DTS-XX-15A 0.22 REV LPH-060 A A1 D 4.29 0.187 0.169 4.29 0.187 0.62 MOUNTING OPTIONS ■ Tape 15.75 3 0.345 8.76 0.375 .XXX .005 .XX0.003 .01 0.076 0.38 .X .1 ANGLES 2 4.75 4.75 B THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED LEADERTECH, DEVELOPED IT'S OWN6.35 3.56 BY0.45 11.43 OR0.250 6.35 AT 0.250 PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR 3.56 0.45 11.43 0.250 6.35 0.250 6.35 ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF 5.59 0.62 15.75 0.345 8.76 0.375 9.53 LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. 5.59 MAT. OTHERWISE THICK COMP WIDTH COMP UNLESS SPECIFIED, DIMENSIONS ARE HEIGHT IN INCHES. 1 0.06 9.65 0.06 0.002 0.051 0.38 PREPARED 0.003 0.076 0.51 QA 0.002 0.051 0.51 ENG - CUSTOMER DWG NO. - FINISH HEAT TREAT TO 373 DPH 0.004 0.102 MATERIAL SPEC 9.53 .0035 BeCu 172 0.003 0.076 0.76 0.76 DJM 1 A B A CUSTOMER DWG NO. C XX - Select material/finish (see page 6) PITCH 4 TAPE 80 0.100 381 80 0.100 1.78 15 381 15SIZE 381DWG NO 60 0.100 C 14-45DT-XX-15 15 SCALE381 FSCM NO. 40 0.200 4J674 15 381 40 0.200 0.07 1.78 0.10 2.54 19.30 0.10 2.54 2 FINGERS 381 19.30 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. PSA LEADERTECH TAPE DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. GAS SIZE C 2 DWG NO C 8-S-21AH SCALE FSCM NO 2 A DOME TOP 60 0.100 SERIES B 3 12/21/2007 .0025 BeCu ALLOY 172 15 12.95 DATE DVG ENG H.T. TO 373 DPH MATERIAL SPEC PREPARED QA FINISH 15 3/31/2009 PSA TAPE C CUST. NAME 1.52 0.07 B D UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XX .01 .X .1 ANGLES 2 1.52 DATE 12.95 The Dome Top “Solid” Series gaskets have a strip that connects each finger along the top. C This allows for unique angular wiping action without snagging. Other features A are the same as the Dome Top Series. SHEET 1 OF 1 Directional Force 9.65 CUST. NAME LENGTH 1 SHEET 1 OF 1 3 3 PITCH 0.169 REV A 2 Black = inches Blue = mm Comp = Compressed 4 4 11-35DTS-XX-15 OFILE HOOK SERIES 2 B MOUNTING The Dome Top gaskets have fully independent fingers that are adhesive mounted. OPTIONS Their smooth curve provides a large area for electrical contact and smooth ■ Tape REV wiping action. A PITCH THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION C C DWG NO A 1 GASKET, STYLE AH DT | Dome Top PSA TAPE PART NUMBER C B REV A A PSA TAPE SHEET 1 OF 1 1 B UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XX .01 .X .1 ANGLES 2 CUST. NAME PREPARED CUSTOMER DWG NO. A - QA FINISH ENG - DJM DATE DOME TOP SE 3/31/2009 HEAT TREAT TO 373 DPH MATERIAL SPEC SIZE C SCALE .0035 BeCu 172 DWG NO 14-45DT-XX-15 FSCM NO. 4J674 2 FINGER EMI Enclosure Shielding Solutions SHEE 1 9 Copper Beryllium Fingerstock SLOT MOUNT SERIES Slot mount gaskets are a standard in the electronic enclosure industry. These gaskets are used in shorter lengths as ESD contacts and longer lengths as EMI gaskets, which clip into slots or slide onto mounted tracks. 8 7 6 5 4 3 2 1 AF | Alternate Finger Slot Mount PART NUMBER 11-32AF-XX-16 8 A Black = inches Blue = mm B C 0.11 2.79 0.32 8.13 0.08 11-32AF3-XX-16 0.11 2.79 0.32 8.13 11-32AF4-XX-16 0.11 2.79 0.32 11-S-32AF-XX-16 0.11 2.79 0.32 11-S-32AF3-XX-16 0.11 2.79 11-S-32AF4-XX-16 0.11 22-60AF-XX-16 D *E *F Recommended 2.03 0.02 0.51 0.09 2.29 0.08 2.03 0.02 0.51 0.09 8.13 0.08 2.03 0.02 0.51 8.13 0.08 2.03 0.02 0.51 0.32 8.13 0.08 2.03 0.02 2.79 0.32 8.13 0.08 2.03 0.22 5.59 0.60 15.24 0.14 22-60AF3-XX-16 0.22 5.59 0.60 15.24 22-S-60AF-XX-16 0.22 5.59 0.60 22-S-60AF3-XX-16 0.22 5.59 0.60 7 Recommended *G Recommended FINGER 0.26 6.60 0.04 1.02 0.169 2.29 0.26 6.60 0.04 1.02 0.09 2.29 0.26 6.60 0.04 0.09 2.29 0.26 6.60 0.04 0.51 0.09 2.29 0.26 6.60 0.02 0.51 0.09 2.29 0.26 3.56 0.04 1.02 0.14 3.56 0.14 3.56 0.04 1.02 0.14 15.24 0.14 3.56 0.04 1.02 15.24 0.14 3.56 0.04 1.02 6 MAT. THICK 0.187 4.75 0.004 0.102 0.169 4.29 0.187 4.75 0.004 1.02 0.169 4.29 0.187 4.75 1.02 0.169 4.29 0.187 4.75 0.04 1.02 0.169 4.29 0.187 6.60 0.04 1.02 0.169 4.29 0.52 13.21 0.07 1.78 0.250 3.56 0.52 13.21 0.07 1.78 0.14 3.56 0.52 13.21 0.07 0.14 3.56 0.52 13.21 0.07 LENGTH FINGERS 16 406 85 0.102 16 406 85 0.004 0.102 16 406 85 0.002 0.051 16 406 85 4.75 0.002 0.051 16 406 85 0.187 4.75 0.002 0.051 16 406 85 6.35 0.282 7.16 0.005 0.127 16 406 57 0.250 6.35 0.282 7.16 0.005 0.127 16 406 58 1.78 0.250 6.35 0.282 7.16 0.003 0.076 16 406 57 1.78 0.250 6.35 0.282 7.16 0.003 0.076 16 406 58 4 MOUNTING *May vary depending on application OPTIONS ■ Slot XX - Select material/finish (see page 6) PITCH FINGER PITCH 4.29 5 3 D 2 C B Directional Force A D C B PITCH 8 8 Mounting concepts FINGER 10 Alternate Finger Mounting Hole Recommendations 6 PATTERN PITCH FOR 11-32AF AND 11-S-32AF A PATTERN PITCH = PATTERN PITCH FOR 11-32AF AND 11-S-32AF .XXX .005 A PATTERN PITCH FOR 11-32AF AND 11-S-32AF PREPARED CUST. NAME 5 4 F UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XX .01 .X .1 2 FINGER PITCHES DATE SIZE B PATTERN PITCHFOR = 11-32AF3 AND 11-S-32AF3 PATTERN PITCH 3 FINGER PITCHES DWG NO D REV 11-S-32AF-XX-16 SCALE .0025 CuBe C17200 1/4 HT PATTERN PITCH FOR 11-32AF3 AND 11-S-32AF3 C - MATERIAL SPEC B A SLOT MOUNT SERIES 10/14/2008 - A D ANGLES 2 PATTERN PITCH = DJM MFG 2 FINGER PITCHES PATTERN PITCH = FINISH ENG AS REQ'D 2 FINGER PITCHES - CUSTOMER DWG NO. 3 B B Variable Slot Mount Chart THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. E 7 A FSCM NO. 4J674 2 B SHEET 1 OF 1 1 PATTERN PITCH PATTERN PITCHFOR = 11-32AF3 AND 11-S-32AF3 3 FINGER PITCHES PATTERN PITCH = 3 FINGER PITCHES UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XX .01 .X .1 ANGLES 2 CUST. NAME C G 7 Material Thickness Phone: 866.832.4364 Length of slot and distance between slots is dependent on hole mounting pattern 6 Fax: 813.855.3291 C 5 C THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH ANY PURPOSE DESIGN, MANUFACTURE OR PATTERN PITCHINCLUDING = PROCUREMENT WITHOUT THE11-S-32AF4 WRITTEN PERMISSION OF AS REQ'D PATTERN PITCHPITCHES FOR 11-32AF4 AND 4 FINGER MATERIAL SPEC LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR .0025 CuBe C17200 1/4 HT WARRANTY THE PERFORMANCE CHARACTERISTICS. PATTERN PRIVATE PITCH FOR 11-32AF4 AND NOT 11-S-32AF4 EXPENSE, AND MAY USED, PATTERN PITCH = PATTERN 4PITCH FOR 11-32AF4 AND 11-S-32AF4 4 FINGER PITCHES PATTERN PITCH = 4 FINGER PITCHES Web: www.leadertechinc.com 3 PREPARED DJM DATE 10/14/2008 MFG - SIZE ENG - - D SC 2 Copper Beryllium Fingerstock 7 6 7 4 5 3 4 2 3 1 2 1 SLOT MOUNT SERIES CONT. D RH | Slot Mount PART NUMBER B C D *N *O Recommended *P Recommended FINGER Recommended PITCH MAT. THICK LENGTH FINGERS 11-28RH-XX-16 0.11 2.79 0.28 7.11 0.08 2.03 0.02 0.51 0.09 2.29 0.22 5.59 0.04 1.02 0.169 4.29 0.187 4.75 0.003 0.076 16 406 86 11-S-28RH-XX-16 0.11 2.79 0.28 7.11 0.08 2.03 0.02 0.51 0.09 2.29 0.22 5.59 0.04 1.02 0.169 4.29 0.187 4.75 0.002 0.054 16 406 86 11-32RH-XX-16 0.11 2.79 0.32 8.13 0.09 2.29 0.02 0.51 0.09 2.29 0.26 6.60 0.04 1.02 0.169 4.29 0.187 4.75 0.003 0.076 16 406 11-S-32RH-XX-16 0.11 2.79 0.32 8.13 0.09 2.29 0.02 0.51 0.09 2.29 0.26 6.60 0.04 1.02 0.169 4.29 0.187 4.75 0.002 0.054 16 406 13-30RH-XX-16 0.13 3.30 0.30 7.62 0.09 2.29 0.03 0.76 0.09 2.29 0.25 6.35 0.05 1.27 0.169 4.29 0.187 4.75 0.004 0.102 16 406 86 13-37RH-XX-16 0.13 3.30 0.37 9.40 0.09 2.29 0.02 0.51 0.09 2.29 0.31 7.87 0.04 1.02 0.225 5.72 0.250 6.35 0.003 0.076 16 406 64 0.13 3.30 0.37 9.40 0.09 2.29 0.02 0.51 0.09 2.29 0.31 7.87 0.04 1.02 0.225 5.72 0.250 6.35 0.002 0.054 16 406 64 22-60RH-XX-16 0.22 5.59 0.60 15.24 0.14 3.56 0.04 1.02 0.14 3.56 0.52 13.21 0.06 1.52 0.250 6.23 0.282 7.16 0.005 0.127 16 406 57 22-S-60RH-XX-16 0.22 5.59 0.60 15.24 0.14 3.56 0.04 1.02 0.14 3.56 0.52 13.21 0.06 1.52 0.250 6.35 0.282 7.16 0.003 0.076 16 406 57 1 13-S-37RH-XX-16 D MOUNTING OPTIONS Slot ■ R D Black = inches Blue = mm A H 86 C 86 C *May vary depending on application B B B B XX - Select material/finish (see page 6) Directional Force D C D A C A UNLESS OTHERWISE SPECIFIED:SPECIFIED: UNLESS OTHERWISE C THIRD ANGLE THIRD ANGLE - ALL DIMENSIONS ARE IN INCHES - ALL DIMENSIONS ARE IN INCHES PROJECTION PROJECTION - PART SHALL BE SHALL FREE OF AND SHARP EDGES - PART BEBURRS FREE OF BURRS AND SHARP EDGES - ALL DIMENSIONS SHOWN APPLY BEFORE - ALL DIMENSIONS SHOWN APPLY BEFORE PLATINGSPLATINGS AND COATINGS AND COATINGS - RoHS COMPLIANT PER EU DIRECTIVE 2011/65/EU - RoHS COMPLIANT PER EU DIRECTIVE 2011/65/EU - POI = POINT INTERSECTION - POIOF = POINT OF INTERSECTION TITLE: TITLE: .XXX +/-.XXX .005+/-.XX +/- .010 +/- .020 +/- 2 +/- 2 .005 .XX +/-.X.010 .X +/-ANGLES .020 ANGLES DRAWN BY: DRAWN BY: THIS DOCUMENT INFORMATION THIS CONTAINS DOCUMENTPROPRIETARY CONTAINS PROPRIETARY INFORMATION FINISH: OWNED BY LEADERTECH, OR DEVELOPED IT'S OWN AT IT'S OWNED BY LEADERTECH, OR AT DEVELOPED OWN PRIVATE EXPENSE, AND MAY NOT BE MAY USED,NOT DUPLICATED PRIVATE EXPENSE, AND BE USED, DUPLICATED OR DISCLOSED WHOLE ORININWHOLE PART FOR ANY PURPOSE ORIN DISCLOSED OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THEWITHOUT WRITTEN THE PERMISSION LEADERTECH. MATERIAL: WRITTEN OF PERMISSION OF LEADERTECH. LEADERTECHLEADERTECH DOES NOT GUARANTEE OR WARRANTY THE DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. PERFORMANCE CHARACTERISTICS. - - - - FINISH: MATERIAL: 5 6 RH6 Mounting Hole Pattern 4 5 4 - - SIZE: SCALE: 0.004 CuBe 1/4 HT 1/4 HT 0.004C17200 CuBe C17200 7 - B AS REQ'D AS REQ'D 7 A SLOTSLOT MOUNT SERIES MOUNT SERIES APPROVED BY: APPROVED BY: - 3 3 DWG. NO.: DWG. NO.: SIZE: REV: 11-32RH D B 11-32RH SCALE: 3:1 CAGE CODE:CAGE CODE:SHEET: 3:1 2 Slot 2Mount Series REV: D SHEET: 4J674 4J674 1 OF 1 1 OF 1 1 1 N B 0 O Length of slot is dependent on the number of fingers used A SLOT MOUNT SERIES REV DWG NO 11-S-32AF-XX-16 FSCM NO. 4J674 SHEET 1 OF 1 P B A Mounting concepts CALE 5 6 Material Thickness 1 EMI Enclosure Shielding Solutions 11 Copper Beryllium Fingerstock FOLDED SERIES Leader Tech's Folded Gasket series are industry standard, general-purpose gaskets that allow a large range of deflection and compression forces. These gaskets are available with or without tape for alternate attachment methods. Also available in a2 snag-free version where, under 3 compression, the leading edge of the gasket slides into an extended and folded base which prevents possible damage to the gasket. FS | Folded Black = inches Blue = mm Comp = Compressed 11-28FS-XX-16 0.11 2.79 0.28 7.11 0.24 6.10 0.170 4.32 0.188 4.78 0.003 0.076 COMP LENGTH 0.37 9.40 16 406 85 11-28FS-XX-300 0.11 2.79 0.28 7.11 0.24 6.10 0.170 4.32 0.188 4.78 0.003 0.076 0.37 9.40 0.07 1.78 300 7620 1596 0.145 11-S-28FS-XX-16 0.11 2.79 0.28 7.11 0.24 6.10 0.170 4.32 0.188 4.78 0.002 0.051 0.37 9.40 0.07 1.78 16 406 85 0.145 PART NUMBER D 1 A B C FINGER PITCH MAT. THICK COMP HEIGHT 0.07 1.78 LENGTH FINGERS TAPE 0.145 11-S-28FS-XX-300 0.11 2.79 0.28 7.11 0.24 6.10 0.170 4.32 0.188 4.78 0.002 0.051 0.37 9.40 0.07 1.78 300 7620 1596 14-37FS-XX-16 4 0.14 3.56 0.37 9.40 0.32 8.13 0.228 5.79 0.250 6.35 30.003 0.076 0.50 12.70 0.10 2.54 16 406 64 0.145 0.200 2 14-37FS-XX-300 0.14 3.56 0.37 9.40 0.32 8.13 0.228 5.79 0.250 6.35 0.003 0.076 0.50 12.70 0.10 2.54 300 7620 1200 0.200 14-S-37FS-XX-16 0.14 3.56 0.37 9.40 0.31 7.87 0.228 5.79 0.250 6.35 0.002 0.051 0.50 12.70 0.10 2.54 16 406 64 0.200 23-60FS-XX-24 0.23 5.84 0.60 15.24 0.50 12.70 0.343 8.71 0.375 9.53 0.004 0.102 0.77 19.56 0.12 3.05 24 610 64 0.250 23-60FS-XX-300 0.23 5.84 0.60 15.24 0.50 12.70 0.343 8.71 0.375 9.53 0.004 0.102 0.77 19.56 0.12 3.05 300 7620 800 0.250 25-78FS-XX-24 0.25 6.35 0.78 19.81 0.53 13.46 0.335 8.51 0.375 9.53 0.005 0.127 0.94 23.88 0.15 3.81 24 610 64 0.375 0.375 25-78FS-XX-300 0.25 6.35 0.78 19.81 0.53 13.46 0.340 8.64 0.375 9.53 0.005 0.127 0.94 23.88 0.15 3.81 300 7620 800 25-S-78FS-XX-24 0.25 6.35 0.78 19.81 0.53 13.46 0.335 8.51 0.375 9.53 0.003 0.076 0.94 23.88 0.15 3.81 24 610 64 0.375 25-S-78FS-XX-300 0.25 6.35 0.78 19.81 0.53 13.46 0.335 8.51 0.375 9.53 0.003 0.076 0.94 23.88 0.15 3.81 300 7620 800 0.375 41-113FS-XX-12 0.41 10.41 1.13 28.70 0.80 20.32 0.460 11.68 0.500 12.70 0.007 0.178 1.94 49.28 0.23 5.84 12 305 24 0.375 4 3 MOUNTING OPTIONS ■ Tape ■ Solder ■ Rivet PITCH NGER Directional Force D 2 C 1 The LeaderTech FS gaskets are industry standard, general-purpose gaskets that allow a largerangeofdeflectionandcompressionforces.Thesegasketsareavailablewithouttape for alternate attachment methods. Consult factory for information. D B B XX - Select material/finish (see page 6) A C 3 FSC | Folded PITCH B FINGER PITCH 0.08 2.03 0.25 6.35 0.170 4.32 0.188 14-51FSC-XX-16 0.14 3.56 0.51 12.95 0.228 5.79 0.250 0.14 3.56 0.51 12.95 0.228 5.79 0.250 23-76FSC-XX-24 B A 8-25FSC-XX-16 14-S-51FSC-XX-16 2 Black = inches Blue = mm Comp = Compressed PART NUMBER D MAT. THICK COMP HEIGHT 6.35 0.002 CUST. NAME 0.051 0.100PREPARED 2.54 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION DJM OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN DWG NO. 0.102 0.23 EXPENSE, 5.84 0.76 19.30 0.343 8.64 0.375 CUSTOMER 9.53 0.004 0.115QA 2.92 PRIVATE AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH ENG ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF MATERIAL SPEC LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR PITCH .003 BeCu ALLOY 172 WARRANTY THE PERFORMANCE CHARACTERISTICS. 3 FINGER MOUNTING OPTIONS ■ Tape ■ Solder Directional Force ■ Rivet LENGTH FINGERS UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX 4.78 .005 0.003 0.076 0.048 1.22 16 406 .XX .01 .1 0.003ANGLES .X 6.35 0.0762 0.100 2.54 16 406 TAPE 85 0.145 64 0.375 0.375 16 DATE 406 64 24 610 64 C A FOLDED SERIES 0.375 SIZE C REV DWG NO 14-37FS-XX SCALE FSCM NO. 2 B 4J674 SHEET 1 OF 1 B 1 TheFSCwascreatedtoprovidesnagfreegasketswithFSgasketfeatures.Thebaseofthegasket isextendedfromthemountingareaandthenfoldedup,over,down,andthencomestorestover theleadingedgeoftheformedspring.Undercompression,theleadingedgeofthegasketslides underandis“captured.”This“nosnag”featureisalsousedtopreventpossiblegasketdamage. A B XX - Select material/finish (see page 6) FINGER PSA TAPE C 4 C B A OPTIONAL PSA TAPE C 12 A Phone: 866.832.4364 Fax: 813.855.3291 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XX .01 .X .1 ANGLES 2 Web: www.leadertechinc.com UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. CUST. NAME PREPARED DATE PSA Copper Beryllium Fingerstock 4 3 4 2 3 1 2 1 FOLDED SERIES CONT. D 4 FSV | Folded 3 2 Black = inches Blue = mm Comp = Compressed 11-28FSV23-XX-16 0.11 2.79 0.28 7.11 0.24 6.10 0.06 1.52 0.188 4.78 0.170 4.32 0.188 4.78 0.003 0.076 COMP WIDTH 0.37 9.40 11-S-28FSV23-XX-16 0.11 2.79 0.28 7.11 0.24 6.10 0.06 1.52 0.188 4.78 0.170 4.32 0.188 4.78 0.002 0.051 0.37 9.40 0.07 1.78 16 406 85 14-37FSV30-XX-16 D 0.14 3.66 0.37 9.40 0.32 8.13 0.06 1.52 0.250 6.35 0.228 5.79 0.250 6.35 0.003 0.076 0.50 12.70 0.10 2.54 16 406 64 14-S-37FSV30-XX-16 0.14 3.66 0.37 9.40 0.32 8.13 0.06 1.52 0.250 6.35 0.228 5.79 0.250 6.35 0.002 0.051 0.50 12.70 0.10 2.54 16 406 64 23-60FSV50-XX-24 0.23 5.84 0.60 15.24 0.50 12.70 0.08 2.03 0.375 9.53 0.343 8.71 0.375 9.50 0.004 0.102 0.77 19.56 0.12 3.05 24 610 64 25-78FSV50-XX-24 0.25 6.35 0.78 19.81 0.50 12.70 0.14 3.56 0.375 9.53 0.335 8.51 0.375 9.50 0.005 0.127 0.94 23.88 0.15 3.81 24 610 64 25-S-78FSV50-XX-24 0.25 6.35 0.78 19.81 0.50 12.70 0.14 3.56 0.375 9.53 0.335 8.51 0.375 9.50 0.003 0.076 0.94 23.88 0.15 3.81 24 610 64 41-113FSV-XX-12 0.41 10.41 1.13 28.70 0.80 20.32 0.14 3.56 0.500 12.70 0.460 11.68 0.500 12.70 0.007 0.178 1.94 49.28 0.23 5.84 12 305 24 PART NUMBER C D A B C D E FINGER PITCH MAT. THICK COMP HEIGHT 0.07 1.78 16 406 85 LENGTH FINGERS C 1 Directional Force PITCH C FINGER TheFSVisanFSgasketthathasthebasebentatarightangletothecurveofthespringform, withalltheotherfeaturesoftheFSgasketmaintained.Tapeoptional-pleaseconsultfactory. MOUNTING OPTIONS ■ Tape ■ Rivet ■ Solder XX - Select material/finish (see page 6) D PITCH B FINGER B B B A 4 D 3 4 2 3 1 2 C 4 D A 1 C 3 2 D E PART NUMBER A D 0.25 6.35 OWNED BY LEADERTECH, OR DEVELOPED AT IT'S 8.51 OWN 1.09 0.16 4.06 0.14 3.56 9.65 0.335 OWNED27.69 BY LEADERTECH, OR DEVELOPED AT IT'S 0.38 OWN CUSTOMER DWG NO. 25-109FSDS-XX-300 0.25 6.35 DUPLICATED DISCLOSED IN WHOLE OR IN PART DUPLICATED DISCLOSED IN WHOLE IN PART 1.09 27.69 OR0.16 4.06 0.14 OROR 3.56 0.38FOR 9.65 0.335 8.51FOR 0.375 9.53 FINISHENG FINISH 25-S-109FSDS-XX-24 0.25 6.35 H.T. TO DPH 373 OF H.T. TO DPH 373 PROCUREMENT THEOFWRITTEN PERMISSION PROCUREMENT WITHOUT THE WRITTEN PERMISSION 1.09 27.69 0.16 4.06 0.14 WITHOUT 3.56 0.38 9.65 0.335 8.51 0.375 9.53 1.27 25-S-109FSDS-XX-300 0.25 6.35 25 WARRANTY PERFORMANCE CHARACTERISTICS. WARRANTY PERFORMANCE CHARACTERISTICS. 1.09 27.69 THE0.16 4.06 0.14 THE3.56 0.38 9.65 0.335 .003 8.51 BeCu 0.375ALLOY9.53 .003 BeCu ALLOY 25 1.27 32.26 41-163FSDS-XX-24 0.41 10.41 1.63 41.40 0.19 4.83 0.14 3.56 0.50 12.70 0.460 11.68 0.500 12.70 1.90 48.26 41-163FSDS-XX-300 0.41 10.41 1.63 41.40 0.19 4.83 0.14 3.56 0.50 12.70 0.460 11.68 0.500 12.70 1.90 48.26 4 C Directional Force PITCH PITCH FINGER FINGER D B A TAPE C C COMP COMP PITCH WIDTH DATE HEIGHT PREPARED CUST.PREPARED NAME DJM 0.375 9.53 1.27 32.26 DJM 0.15 3.81 CUSTOMER QA QA DWG NO. A FINGER B C D E CUST. NAME FINGER C THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION 25-109FSDS-XX-24 B 1 4 UNLESS DIMENSIONS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. UNLESS OTHERWISE SPECIFIED, ARE IN INCHES. .XXX .005 .XXX .005 .XX .01 .XX .01 Black = inches Blue = mm Comp ANGLES 2 .X .1 ANGLES 2 .X .1 PITCH FSDS | Folded PRIVATE EXPENSE, AND MAY NOT USED, PRIVATE EXPENSE, AND MAY NOT USED, PURPOSE INCLUDING OR DESIGN, MANUFACTURE OR ANY PURPOSE INCLUDINGANY DESIGN, MANUFACTURE SPEC LEADERTECH. LEADERTECHOR DOESMATERIAL NOT GUARANTEE OR LEADERTECH. LEADERTECH DOES NOT GUARANTEE D 3 3 MATERIAL SPEC 2 1.27 32.26 32.26 0.15 ENG LENGTH 24 B FINGERS 610 A 64 FOLDED SERIES FOLDED SERIES 0.15 3.81 0.005 0.127 300 7620 800 SIZE DWG NO REV SIZE DWG NO A 14-37FSV30-XX-16 14-37FSV30-XX-16 3.81C 0.003 0.076 24C 610 64 FSCM NO. FSCM NO. SCALE SCALE SHEET 1 SHEET 1 4J674 OF 1 3.81 0.003 0.076 4J674 300 7620 800 0.23 5.84 0.007 0.178 24 610 0.23 5.84 0.007 0.178 300 7620 0.15 2 1 OF 1 1 48 C 600 C C XX - Select material/finish (see page 6) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XX .01 .X .1 ANGLES 2 B A THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR B PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. D 4 C E = Compressed TheFSDSisanFSgasketwithitsbaselyingonthesameplaneasthecurveinthespringform, withthemountingareashortened.Thismountingisoftenmodifiedforcustomapplications. MOUNTING OPTIONS ■ Tape ■ Rivet ■ Solder C MATERIAL THICK DATE 0.005 0.127 D PITCH CUSTOMER DWG NO. FINISH BH.T. QA ENG B B .003 BeCu ALLOY 25 2 A EMI Enclosure Shielding Solutions A DATE DJM TO DPH 373 MATERIAL SPEC 3 A FINGER PREPARED CUST. NAME UNLESS OTHERWISE SPECIFIED, DIMENSIONS UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. ARE IN INCHES. .XXX .005 .XXX .005 .XX .01 13 Copper Beryllium Fingerstock TWIST SERIES 3 2 1 The Twist series gaskets are designed for demanding compression applications. This series can compress to material thickness and provide excellent shielding performance. Profiles include standard flat, right angle, double twist, and clip-on. T | Twist Black = inches Blue = mm Comp = Compressed 3-20T-XX-24 0.03 0.76 0.20 5.08 0.11 2.79 0.080 2.03 0.095 2.41 MATERIAL THICK 0.003 0.076 3-20T-XX-300 0.03 0.76 0.20 5.08 0.11 2.79 0.080 2.03 0.095 2.41 0.003 0.076 300 7620 3158 0.100 0.03 0.76 0.23 5.84 0.14 3.56 0.080 2.03 0.095 2.41 0.003 0.076 24 610 253 0.100 0.100 PART NUMBER 3-23T-XX-24 D A 4 C FINGER PITCH 3 LENGTH FINGERS TAPE 24 610 253 0.100 3-23T-XX-300 0.03 0.76 0.23 5.84 0.14 3.56 0.080 2.03 0.095 2.41 0.003 0.076 300 7620 3158 3-S-23T-XX-24 0.03 0.76 0.23 5.84 0.14 3.56 0.080 2.03 0.095 2.41 0.002 0.051 24 610 253 0.100 3-S-23T-XX-300 0.03 0.76 0.23 5.84 0.14 3.56 0.080 2.03 0.095 2.41 0.002 0.051 300 7620 3158 0.100 6-30T-XX-24 0.07 1.78 0.30 7.62 0.15 3.81 0.150 3.81 0.165 4.19 0.003 0.076 24 610 146 0.100 6-30T-XX-300 0.07 1.78 0.30 7.62 0.15 3.81 0.150 3.81 0.165 4.19 0.003 0.076 300 7620 1818 0.100 6-S-30T-XX-24 0.07 1.78 0.30 7.62 0.15 3.81 0.150 3.81 0.165 4.19 0.002 0.051 24 610 146 0.145 6-S-30T-XX-300 0.07 1.78 0.30 7.62 0.15 3.81 0.150 3.81 0.165 4.19 0.002 0.051 300 7620 1818 0.145 6-34T-XX-24 0.07 1.78 0.34 8.64 0.18 4.57 0.150 3.81 0.165 4.19 0.003 0.076 24 610 146 0.145 6-34T-XX-300 0.07 1.78 0.34 8.64 0.18 4.57 0.150 3.81 0.165 4.19 0.003 0.076 300 7620 1818 0.145 6-S-34T-XX-24 0.07 1.78 0.34 8.64 0.18 4.57 0.150 3.81 0.165 4.19 0.002 0.051 24 610 146 0.145 6-S-34T-XX-300 0.07 1.78 0.34 8.64 0.18 4.57 0.150 3.81 0.165 4.19 0.002 0.051 300 7620 1818 0.145 MOUNTING OPTIONS 3 ■ Tape ■ Solder Directional Force C B D 2 C XX - Select material/finish (see page 6) 2 1 A B B C D PSA TAPE 4 3 2 TV | Twist Black = inches Blue = mm PITCH PART NUMBER A FINGER B 3-23TV-XX-24 0.03 0.76 0.08 2.03 ± .005 0.16.XXX 4.06 0.080 .XX  .01 3-23TV-XX-30 0.03 0.76 0.08 2.03 0.16 4.06 CUST. NAME 3-23TV30-XX-24 0.03 0.76 0.08 2.03 0.30 7.62 0.080 2.03 3-S-23TV-XX-24 0.03 0.76 0.08 2.03 0.16 - 4.06 0.080 2.03 3-S-23TV30-XX-300 0.03 0.76 0.08 2.03 0.30 7.62 0.080 2.03 6-34TV-XX-24 0.07 5.08 0.150 3.81 6-34TV-XX-300 6-S-34TV-XX-300 - 1.78 0.14 3.56 .1 CUSTOMER DWG NO.#2 FINISH 0.20 0.095 2.41   0.080ANGLES 2.03 PREPARED 0.095 2.41 CUSTOMER DWG NO. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. MATERIAL SPEC 0.003 FINGERS TAPE 0.076 24 610 253 0.100 0.003 DATE0.076 300 7620 3158 0.100 0.095 2.41 0.003 0.076 24 610 253 0.250 0.095 2.41 0.002 0.051 24 610 253 0.100 0.095 2.41 0.002 0.051 300SIZE 7620 DWG NO3158 0.250 0.165 4.19 0.003 0.076 ENGINEERING MFG APPROVAL QA APPROVAL 24 C 610 SCALE 0.14 3.56 0.20 5.08 1/4 0.150 CuBe C17200 H 3.81 0.165 4.19 0.003 0.076 300 1818 1.78 0.14 3.56 0.20 5.08 0.150 3.81 0.165 4.19 0.002 0.051 24 610 146 0.145 0.07 1.78 0.14 3.56 0.20 5.08 0.150 3.81 0.165 4.19 0.002 0.051 300 7620 1818 0.145 7620 P1 UNLESS .XXX ± .XX  .X ± A A PSA TAPE C 1 OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .005 .01 .1 ANGLES    CUST. NAME PREPARED CUSTOMER DWG NO. ENGINEERING CUSTOMER DWG NO.#2 MFG APPROVAL FINISH QA APPROVAL - THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. 4 FINGER PSA TAPE SHEET 1 OF 1 - PITCH C C XX - Select material/finish (see page 6) B 14 B A REV 6-34T 0.145 146 FSCM NO. 1.78 2 A T TWIST SERIES 0.07 MOUNTING OPTIONS Directional ■ Tape Force ■ Solder GER .X ± 2.03 4J674 0.145 0.07 3 6-S-34TV-XX-24 CH MATERIAL LENGTH C FINGER PITCH UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARETHICK IN INCHES. B Phone: 866.832.4364 - MATERIAL SPEC Fax: 813.855.3291 Web: www.leadertechinc.com UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XX .01 TT B SIZE 2 DWG NO C SCALE CuBe C17200 1/4 H 3 DATE FSCM NO 4 3 2 D Copper Beryllium Fingerstock D TWIST SERIES CONT. C T2 | Twist Black = inches Blue = mm 6-50T2-XX-24 0.07 1.78 0.50 12.70 0.18 4.57 0.150 3.81 0.165 4.19 MATERIAL THICK 0.003 0.076 6-50T2-XX-300 0.07 1.78 0.50 12.70 0.18 4.57 0.150 3.81 0.165 4.19 0.003 0.076 300 7620 1818 0.145 6-S-50T2-XX-24 0.07 1.78 0.50 12.70 0.18 4.57 0.150 3.81 0.165 4.19 0.002 0.051 24 610 146 0.145 6-S-50T2-XX-300 0.07 1.78 0.50 12.70 0.18 4.57 0.150 3.81 0.165 4.19 0.002 0.051 300 7620 1818 0.145 PART NUMBER A 3 1 C B C FINGER PITCH 2 LENGTH FINGERS 24 610 146 TAPE 0.145 1 D XX - Select material/finish (see page 6) MOUNTING OPTIONS ■ Tape A Directional Force 4 B 3 D 2 C B PSA TAPE D A UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XX .01 MATERIAL .X .1 B ANGLES 2 FINGER PITCH UT | Twist B PART NUMBER A THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION 3-23UT-040-XX-16 0.03 0.76 OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, 3 3-23UT-070-XX-16 0.03 0.76 DUPLICATED OR DISCLOSED IN WHOLE IN PART FOR PSAOR TAPE ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR 3-23UT-070-DL-XX-16 0.76 C 0.03 PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR 6-34UT-040-XX-16 0.07 1.78 WARRANTY THE PERFORMANCE CHARACTERISTICS. 3 CUST. NAME PREPARED LENGTH FINGERS 2.41 THICK 8/28/2008 0.003 0.076 16 406 2.41 0.003 0.076 16 406 DATE CLIP ID 0.15 3.81 0.080 2.03DJM 0.095 0.15 3.81 0.080 2.03 AS 0.15REQ'D 3.81 0.080 2.03 0.095 2.41 0.003 0.076 C 16 3.81 0.165 4.19 0.003 0.076 16 406 97 0.04 4J674 0.165 4.19 0.003 0.076 16 406 97 0.165 4.19 0.003 0.076 16 406 97 - CUSTOMER DWG NO. - B FINISH C MATERIAL SPEC 0.003" 0.22 BeCu 5.59C17200 0.1501/4H QA ENG 6-34UT-070-XX-16 0.07 1.78 0.22 5.59 0.150 3.81 6-34UT-070-DL-XX-16 0.07 1.78 0.22 5.59 0.150 3.81 2 0.095 2 C Black = inches Blue = mm SIZE SCALE 168 0.04 1.02 TWISTED SERIES DWG NO 406 6-50T2 FSCM NO. LANCE PITCH A n/a LANCE n/a 168 0.07 1.78 1 n/a 168 0.07 1.78 D 1.02 n/a n/a 0.07 1.78 n/a n/a 0.07 1.78 D 1” SHEET 1 OF 1 1 n/a REV 1” B D 1 XX - Select material/finish (see page 6) MOUNTING OPTIONS ■ Clip C A B Directional Force 4 A 3 UT3 | Twist PART NUMBER A4 6-34UT3-050-XX-16 0.07 B 1.78 0.38 PITCH THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION 0.07 AT 1.78IT'S OWN 0.38 OWNED6-34UT3-050-DL-XX-16 BY LEADERTECH, OR DEVELOPED FINGER PRIVATE EXPENSE, AND MAY NOT USED, 6-34UT3-070-XX-16 0.07 OR1.78 FOR DUPLICATED OR DISCLOSED IN WHOLE IN PART0.38 ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR 6-34UT3-070-DL-XX-16 0.07 PERMISSION 1.78 0.38OF PROCUREMENT WITHOUT THE WRITTEN LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. B B CUST. NAME D B D MOUNTING OPTIONS ■ Clip 3 Directional C TWIST SERIESForce THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR AS REQ'D PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR = MATERIAL Black inches SPEC Blue = mm C C17200 1/4H 0.003" BeCu THE PERFORMANCE CHARACTERISTICS. UNLESS OTHERWISE SPECIFIED, DIMENSIONS WARRANTY ARE IN INCHES. .XXX .005 C .XX .01 .X .1 ANGLES 2 FINGER 9.65 0.22 5.59 0.150 9.65 0.22 5.59 0.150 9.65 0.22 5.59 0.150 AS REQ'D 9.65 0.22 5.59 0.150 CUST. NAME CUSTOMER DWG NO. FINISH MATERIAL THICK 3 0.003 0.076 LENGTH 3.81 0.165 4.19 M. Paul 3.81 0.165 4.198/19/2008 0.003 0.076 16 3.81 0.165 4.19 0.003 0.076 16 3.81 0.165 4.19 0.003 0.076 C PREPARED QA ENG MATERIAL SPEC DATE SIZE SCALE 0.003" BeCu C17200 1/4H XX - Select material/finish (see page 6) PITCH 2 16 C 4J674 SHEET CLIP ID 97 1.27 n/a 406 TWIST 97 0.05 1.27 UT, SERIES D A 1.78 n/a n/a 16 406 97 6-34UT-040-D 0.07 1.78 DB 1” 4J674 REV 8/28/2008 QA S ENG 2 1” 0.07 FSCM NO. DATE DJM LANCE PITCH n/a 97 DWG NO 406 0.05 LANCE PREPARED SHEET 1 OF 1 1 A A P1 6-34T FINGERS 406 B B REV O. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 2 .XX .01 .X .1 ANGLES 2 C 1 OF 1 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XX .01 .X .1 ANGLES 2 A EMI Enclosure Shielding Solutions CUST. NAME THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION - PREPARED M. Paul DATE 15 8/19/2008 D 2 Copper Beryllium Fingerstock A 2 CLIP-ON SERIES B The Clip-On Gaskets are used in enclosures, shielded cabinets, and on circuit cards as ESD contacts and EMI gaskets. For edge mount applications, close attention must be given to clip size, lance requirements, deflection parameters and finger configuration. Leader Tech provides application assistance in the development of specifications. C LANCE PITCH INSIDE Black = inches Blue = mm Comp = Compressed CA| Clip-On PART NUMBER B A B C FINGER MATERIAL THICK PITCH COMP WIDTH COMP HEIGHT LANCE START LANCE PITCH FINGERS LANCE 10-30CD-XX-16 0.10 2.54 0.30 7.62 0.07 8 1.78 0.135 3.43 0.182 4.62 0.005 0.127 7 0.33 8.38 0.05 1.27 0.341 8.66 0.728 6 18.49 88 D 10-30CT-XX-16 0.10 2.54 0.30 7.62 0.07 1.78 0.135 3.43 0.182 4.62 0.005 0.127 0.33 8.38 0.05 1.27 0.341 8.66 0.728 18.49 88 T 11-45CD-XX-16 0.11 2.79 0.45 11.43 0.07 1.78 0.147 3.73 0.193 4.90 0.005 0.127 0.47 11.94 0.06 1.52 0.267 6.78 0.748 19.00 84 D 11-45CT-XX-16 0.11 2.79 0.45 11.43 0.07 1.78 0.147 3.73 0.193 4.90 0.005 0.127 0.47 11.94 0.06 1.52 0.651 16.54 1.352 34.34 84 T A C ■ Clip INSIDE 5 2 LANCE PITCH XX - Select material/finish (see page 6) D Directional Force B 4 4 444 4 4 4 4 4 4 3 3 4 333 A A. 3 3 3 A.10-30CD PATTERN PATTERN PITCH PITCH FOR FOR 10-30CD 10-30CD A.CPATTERN PATTERN PITCH FOR 10-30CD A. PITCH FOR 10-30CD PATTERN PITCH 10-30CD A. A. PATTERN PITCH FORFOR 10-30CD PATTERN PITCH FOR 10-30CD PATTERN PITCH FOR 10-30CD PITCH PITCH PITCH PITCH PATTERN PITCH FOR 10-30CD A.A.A. PATTERN PITCH FOR 10-30CD A.A. PATTERN FOR 10-30CD PITCH INSIDE PITCHPITCH FINGER FINGER FINGER PITCH PITCH FINGER PITCH PITCH A FINGER FINGER PITCH PITCH FINGER FINGER B 3 3 3 B B BBB B BB B B B B B B C C C C C C INSIDE INSIDE INSIDE CCC CINSIDE INSIDE INSIDE C C INSIDE INSIDE INSIDE INSIDE INSIDE INSIDE A A AAA AA A B B BBB B B B B A A A A B B C C C LANCELANCE PITCHPITCH LANCE PITCH LANCE PITCH LANCE PITCH LANCE LANCE PITCHPITCH .60 .60 LANCE PITCH LANCE PITCH LANCE PITCH LANCELANCE PITCHPITCH .60 CC CINSIDE INSIDE CINSIDE INSIDE INSIDE INSIDE INSIDE INSIDE D. D. PATTERN PITCH FOR 11-45CT PATTERN PITCH FOR 11-45CT D.PATTERN PATTERN PITCH FOR 11-45CT D. PITCH FOR 11-45CT PATTERN PITCH FOR 11-45CT D. D. PATTERN PITCH FOR 11-45CT INSIDE A D. PATTERN PITCH FOR 11-45CT D. PATTERN PITCH FOR 11-45CT 11-45CT D. PATTERN PITCH FOR 11-45CT PITCH PITCH PITCH FOR PATTERN PITCH FOR11-45CT 11-45CT D.D. PATTERN PITCH PITCH LANCE PITCH HOLE HOLE PITCHPITCH HOLE PITCH HOLE PITCH HOLEHOLE PITCHPITCH HOLE PITCH HOLE HOLE PITCHPITCH B B B B BBB B BB A PATTERN PATTERN PITCH= PITCH= PATTERN PITCH= PATTERN PITCH= PATTERN PITCH= PATTERN PITCH= 7 FINGERS 7 FINGERS PITCHES 7PITCHES FINGERS PITCHES 7 FINGERS PITCHES PATTERN PITCH= PATTERN PITCH= PATTERN PITCH= 7PITCH= FINGERS PITCHES 7 PATTERN FINGERS PITCHES PITCH= PATTERN PITCH= PATTERN FINGERS PITCHES 77 FINGERS PITCHES 7FINGERS FINGERS PITCHES 7 FINGERS PITCHES 7 PITCHES 7 FINGERS PITCHES C INSIDE A A A A A AAA A AA B B B B A A C C C C C C INSIDE INSIDE INSIDE CCC CINSIDE INSIDE INSIDE C C INSIDE INSIDE INSIDE INSIDE INSIDE INSIDE LANCE PITCH A 16 LANCELANCE PITCHPITCH LANCE PITCH LANCE PITCH LANCE LANCE PITCHPITCH LANCEPITCH PITCH LANCE LANCE PITCH LANCE PITCH LANCE PITCH LANCE PITCH UNLESS UNLESS OTHERWISE OTHERWISE SPECIFIED, SPECIFIED, DIMENSIONS DIMENSIONS ARE IN ARE INCHES. IN INCHES. UNLESS OTHERWISE SPECIFIED, DIMENSIONS IN INCHES. UNLESS OTHERWISE SPECIFIED, DIMENSIONS AREARE IN INCHES. UNLESS SPECIFIED, DIMENSIONS ARE IN INCHES. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX ± .XXX ± OTHERWISE .005 .005 SPECIFIED, ± UNLESS OTHERWISE SPECIFIED, DIMENSIONSARE AREIN INCHES. UNLESS OTHERWISE .XXX.XXX ± SPECIFIED, .005.005 DIMENSIONS UNLESS OTHERWISE DIMENSIONS ARE INININCHES. INCHES. UNLESS OTHERWISE DIMENSIONS ARE IN INCHES. .XXX ± .005 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX ± .005 .XX .XX   .01 .01.XX UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES.  SPECIFIED, .01 .XX  .01 .XXX ± .005 .XXX .005 .XXX ± .005 .XX .XX   .1 .1 ANGLES .X ±± .X ±.005.01 ANGLES    ANGLES .XXX ±.01   .XXX ± .005 .XXX ± .005 .X ±.X ± .1 .1 ANGLES   .XX .01 .XX  .01 .XX  .01 .X ± ANGLES  .1NAME .X.XX ± ANGLES  PREPARED  PREPARED  .01 .1CUST. DATE DATE CUST. NAME CUST. .XX  .01 PREPARED DATE NAME .XX  .01 .1 .X ± ANGLES .1 .X ± PREPARED DATE ANGLES    CUST. NAME   .1 .X ±  -CUST. - .1 NAME .1 ANGLES ± ANGLES -ANGLES PREPARED DATE DATE NAME ±.X CUST. ANGLES   PREPARED .1 .X .X ±  PREPARED DATE CUST. NAME PREPARED DATE CUST. NAME - NAME - CUST. PREPARED DATE CUST. NAME PREPARED PREPARED DATEDATE NAME CUSTOMER DWG NO. DWG NO. DWG ENGINEERING PREPARED DATE CUST. NAME CUSTOMER NO. ENGINEERING ENGINEERING -CUST. -- -CUSTOMER CUSTOMER DWG NO. ENGINEERING - CUSTOMER - -CUSTOMER - NO. DWG ENGINEERING DWG NO. ENGINEERING - NO. CUSTOMER DWG ENGINEERING CUSTOMER NO. ENGINEERING - DWG - CUSTOMER CUSTOMER DWG NO. NO. ENGINEERING DWG ENGINEERING DWG NO. ENGINEERING CUSTOMER DWG NO.#2 DWG NO.#2 DWG MFG APPROVAL MFG APPROVAL CUSTOMER DWG NO. ENGINEERING CUSTOMER NO.#2 MFG APPROVAL -CUSTOMER - -CUSTOMER CUSTOMER DWG NO.#2 MFG APPROVAL A - CUSTOMER - - -CUSTOMER - NO.#2 DWG MFG APPROVAL DWG NO.#2 MFG APPROVAL REV SIZE SIZE DWG NO DWG SIZE NO DWG NO - NO.#2 CUSTOMER DWG MFG APPROVAL SIZE DWG NO CUSTOMER NO.#2 MFG APPROVAL - DWG - CUSTOMER CUSTOMER DWG NO.#2 MFG APPROVAL DWG NO.#2 MFG APPROVAL DWG NO REV SIZE SIZE DWG NO CUSTOMER DWG NO.#2 MFG APPROVAL FINISH QA APPROVAL QA APPROVAL CUSTOMER DWG NO.#2 MFG APPROVAL THIS DOCUMENT THIS DOCUMENT CONTAINS PROPRIETARY CONTAINS PROPRIETARY INFORMATION INFORMATION FINISH QA APPROVAL THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION -- -FINISH VARIABLE VARIABLE CLIP CLIP ON SERIES ONCLIP SERIES CHART CHART REV C SIZE DWG NO VARIABLE ON SERIES FINISH QA APPROVAL REV SIZE DWG NO UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. Phone:B866.832.4364 Fax: C .XXX ± 813.855.3291 .005 INSIDE.XX  C LANCE PITCH B C A A LANCELANCE PITCHPITCH LANCE PITCH LANCE PITCH LANCE LANCE PITCHPITCH LANCEPITCH PITCH LANCE LANCE PITCH LANCE PITCH LANCE PITCH C LANCE PITCH C C INSIDE INSIDE INSIDE CC INSIDE PATTERN PITCH= PATTERN PITCH= 7 FINGERS 7 FINGERS PITCHES 7PITCHES FINGERS PITCHES PATTERN PITCH= PATTERN PITCH= 7 FINGERS PITCHES PATTERN PITCH= 7PITCH= FINGERS PITCHES PATTERN PITCH= 7 PATTERN FINGERS PITCHES PITCH= PATTERN FINGERS PITCHES 7 7FINGERS PITCHES 7 FINGERS PITCHES 7 FINGERS PITCHES 7 FINGERS PITCHES 7 FINGERS PITCHES B 1 A A HOLE HOLE PITCHPITCH HOLE PITCH HOLE PITCH HOLEHOLE PITCHPITCH HOLE PITCH HOLE PITCH HOLE PITCH PITCHPITCH FINGER FINGER FINGER PITCH PITCH PITCH FINGER PITCH PITCH FINGER FINGER PITCH FINGER FINGER FINGER FINGER FINGER FINGER 1 LANCE PITCH A A A B B C INSIDEPATTERN PATTERN PITCH= PITCH= PATTERN PITCH= PATTERN PITCH= B B 1 1 LANCELANCE PITCHPITCH LANCE PITCH LANCE PITCH LANCE LANCE PITCHPITCH LANCEPITCH PITCH LANCE LANCE PITCH LANCE PITCH LANCE PITCH LANCE PITCH LANCE PITCH B B BBB BB B A 1 1 111 1 1 1 D C C C C C C INSIDE INSIDE INSIDE CCC CINSIDE INSIDE INSIDE C CINSIDE INSIDE INSIDE INSIDE INSIDE INSIDE C. C. PATTERN PITCH FOR PATTERN PITCH FOR 11-45CD PATTERN PITCH FOR 11-45CD C. C.PATTERN PITCH FOR 11-45CD C11-45CD PATTERN PITCH FOR 11-45CD C. C. PATTERN PITCH FOR 11-45CD C. PATTERN PITCH FOR 11-45CD C. PATTERN PITCH FOR 11-45CD C. PATTERN PITCH FOR 11-45CD C. PATTERN PITCH FOR 11-45CD C. 11-45CD PATTERN PITCH FOR 11-45CD INSIDE PITCHPITCH PITCH PITCH PITCHPITCH FINGER FINGER FINGER PITCH PITCH FINGER PITCH PITCH PITCH FINGER FINGER PITCH FINGER FINGER FINGER FINGER FINGER FINGER 2 B B PATTERN PATTERN PITCH= PITCH= PATTERN PITCH= PATTERN PITCH= PATTERN PITCH= PATTERN PITCH= 4 FINGERS 4 FINGERS PITCHES 4PITCHES FINGERS PITCHES 4 FINGERS PITCHES PATTERN PITCH= PATTERN PITCH= PATTERN PITCH= 4 FINGERS PITCHES 4 FINGERS PITCHES PATTERN PITCH= PATTERN PITCH= PATTERN PITCH= FINGERS PITCHES 444FINGERS PITCHES FINGERS PITCHES 4 FINGERS PITCHES 4 FINGERS PITCHES 4 FINGERS PITCHES A 2 A A A AAA AA A B C C B B A A AAA AA A PATTERN PITCH= PITCH= PATTERN PITCH= PATTERN PITCH= C PATTERN PATTERN PITCH= PATTERN PITCH= 4 FINGERS 4 FINGERS PITCHES 4PITCHES FINGERS PITCHES 4 FINGERS PITCHES PATTERN PITCH= PATTERN PITCH= PATTERN PITCH= 4 FINGERS PITCHES 4 FINGERS PITCHES PATTERN PITCH= PATTERN PITCH= PATTERN PITCH= FINGERS PITCHES INSIDE 444FINGERS PITCHES FINGERS PITCHES 4 FINGERS PITCHES C 4 FINGERS PITCHES 4 FINGERS PITCHES B. B. PATTERN PITCH FOR 10-30CT PATTERN PITCH FOR 10-30CT PATTERN PITCH FOR 10-30CT CPATTERN B. B. PITCH FOR 10-30CT PATTERN PITCH FOR 10-30CT PATTERN PITCH FOR 10-30CT B. B. PATTERN PITCH FOR 10-30CT PATTERN PITCH FOR 10-30CT B. PATTERN PITCH FOR 10-30CT B.B.10-30CT PATTERN PITCH FOR 10-30CT B.B. PATTERN PITCH FOR 10-30CT INSIDE PITCH PITCH A PITCH PITCH PITCHPITCH FINGER FINGER FINGER FINGER PITCH PITCH PITCH FINGER FINGER PITCH PITCH PITCH FINGER FINGER FINGER FINGER FINGER FINGER 2 2 LANCE PITCH A A FINGER FINGER FINGER FINGER D D 2 2 222 2 2 2 3 .01 Web: www.leadertechinc.com LANCE PITCH CLIP-ON CLIP-ON SERIES SERIES CLIP-ON SERIES CLIP-ON SERIES CLIP-ON SERIES CLIP-ON SERIES CLIP-ON SERIES CLIP-ON SERIES CLIP-ON SERIES CLIP-ON SERIES CLIP-ON SERIES 1 4 3 2 Copper Beryllium Fingerstock C PITCH FINGER 1 D CLIP-ON SERIES CONT. C | Mini-Clip Black = inches Blue = mm PART NUMBER A 7-21C-045-DL-XX-16 B 0.07 ■ 1.78 0.25 C 6.35 0.03 FINGER 0.76 0.170 4.32 PITCH B 0.200 5.08 MATERIAL THICK 0.003 LANCE START 0.076 0.49 LANCE PITCH 12.45 1.00 LENGTH 25.40 16 FINGERS CLIP ID LANCE 80 0.045 D 406 XX - Select material/finish (see page 6) Clip C D 4 Directional Force A 2 3 1 B 1 D UNLESS OTHE .XXX .005 .XX .01 .X .1 A PITCH A FINGER C | Clip-On C D PART NUMBER 4 C FINGER PITCH MATERIAL THICK COMP WIDTH COMP HEIGHT LANCE START LANCE PITCH - - - 86 n/a 86 n/a FINGERS LANCE 86 n/a 86 n/a 10-30C-065-XX-16 0.10 2.54 0.30 7.62 0.065 31.65 0.140 3.56 0.187 4.75 0.005 0.127 0.33 8.38 2 0.05 1.27 10-30C-070-XX-16 0.10 2.54 0.30 7.62 0.070 1.78 0.140 3.56 0.187 4.75 0.005 0.127 0.33 8.38 0.05 1.27 - 10-30C-045-DL-XX-16 0.10 2.54 0.30 7.62 0.045 1.14 0.140 3.56 0.187 4.75 0.005 0.127 0.33 8.38 0.05 1.27 0.5 12.7 1 25.4 86 D 10-30C-050-DL-XX-16 0.10 2.54 0.30 7.62 0.050 1.27 0.140 3.56 0.187 4.75 0.005 0.127 0.33 8.38 0.05 1.27 0.5 12.7 1 25.4 86 D 0.10 C 2.54 0.30 7.62 0.065 1.65 0.140 3.56 0.187 4.75 0.005 0.127 0.33 8.38 0.05 1.27 0.5 12.7 1 25.4 86 D 10-30C-070-DL-XX-16 0.10 2.54 0.30 7.62 0.070 1.78 0.140 3.56 0.187 4.75 0.005 0.127 0.33 8.38 0.05 1.27 0.5 12.7 1 25.4 86 D - - - 0.10 2.54 0.30 7.62 0.045 1.14 0.140 3.56 0.187 4.75 0.005 0.127 0.33 8.38 0.05 1.27 0.10 2.54 0.30 7.62 0.050 1.27 0.140 3.56 0.187 4.75 0.005 0.127 0.33 8.38 0.05 1.27 C 11-45C-045-XX-16 0.11 2.79 0.45 11.43 0.045 1.14 0.140 3.56 0.187 4.75 0.005 0.127 0.47 11.94 0.06 1.52 11-45C-050-XX-16 0.11 2.79 0.45 11.43 0.050 1.27 0.140 3.56 0.187 4.75 0.005 0.127 0.47 11.94 0.06 1.52 B 11-45C-065-XX-16 0.11 2.79 0.45 11.43 0.065 1.65 0.140 3.56 0.187 4.75 0.005 0.127 0.47 11.94 0.06 1.52 11-45C-070-XX-16 4 0.11 2.79 0.45 11.43 0.070 1.78 0.140 3.56 0.187 3 4.75 0.005 0.127 0.47 11.94 0.06 1.52 - - CUSTOMER DWG N - FINISH - MATERIAL SPEC .003 BeCu 172 C 86 n/a 86 n/a 86 n/a 2 86 n/a 1 D 11-45C-045-DL-XX-16 0.11 2.79 0.45 11.43 0.045 1.14 0.140 3.56 0.187 4.75 0.005 0.127 0.47 11.94 0.06 1.52 0.5 12.7 1 25.4 86 D 11-45C-050-DL-XX-16 0.11 2.79 0.45 11.43 0.050 1.27 0.140 3.56 0.187 4.75 0.005 0.127 0.47 11.94 0.06 1.52 0.5 12.7 1 25.4 86 D 11-45C-065-DL-XX-16 0.11 2.79 0.45 11.43 0.065 1.65 0.140 3.56 0.187 4.75 0.005 0.127 0.47 11.94 0.06 1.52 SPECIFIED, DIMENSIONS ARE IN INCHES. 0.5UNLESS 12.7 OTHERWISE 1 25.4 86 D 11-45C-070-DL-XX-16 0.11 2.79 0.45 11.43 0.070 1.78 0.140 3.56 0.187 4.75 0.005 0.127 0.47 11.94 0.06 1.52 0.5.XX  12.7.01 1 25-109C-070-XX-16 0.25 6.35 1.09 27.69 0.070 1.78 0.340 8.64 0.375 9.53 0.005 0.127 1.27 32.26 0.08 2.03 0.25 CB 25-S-109C-070-XX-16 FINGER B 10-30C-050-XX-16 25-109C-070-DL-XX-16 PITCH A CUST. NAME 3 Black = inches Blue = mm Comp = Compressed 4 10-30C-045-XX-16 10-30C-065-DL-XX-16 A THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. 6.35 1.09 27.69 0.070 1.78 0.25 6.35 1.09 27.69 0.070 1.78 25-S-109C-070-DL-XX-16 0.25 6.35 1.09 27.69 0.070 1.78 25-109C-120-XX-16 0.25 6.35 1.09 27.69 0.120 3.05 25-109C-130-XX-16 0.25 6.35 1.09 27.69 0.130 3.30 4 Directional Force ■ .XXX .005 -.X .1- CUST. NAME 0.340 0.375 9.53 0.005 PROPRIETARY 0.127 1.27 32.26 0.08 2.03 0.5 THIS8.64 DOCUMENT CONTAINS INFORMATION - OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN 0.340 8.64 0.375 9.53 0.003 0.076 1.27 32.26 0.08 2.03 PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED IN WHOLE IN PART 0.340 8.64 0.375OR DISCLOSED 9.53 0.003 0.076 1.27 OR 32.26 0.08 FOR 2.03 ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR 0.340 8.64 0.375 9.53 0.005 0.127 1.27 32.26 0.08 PROCUREMENT WITHOUT THE WRITTEN PERMISSION2.03 OF LEADERTECH. 0.340 8.64 0.375 LEADERTECH 9.53 0.005 DOES 0.127 NOT 1.27 GUARANTEE 32.26 0.08 OR 2.03 WARRANTY THE PERFORMANCE CHARACTERISTICS. 86 D ANGLES 43 2B - 25.4 n/a 12.7 1 25.4 43 - - - - 43 0.5 12.7 1 25.4 CUSTOMER DWG NO. - FINISH 43 -- - MATERIAL SPEC -.003 BeCu - -172 - 3 Consult factory for optional clip sizes and optional lance features. Clip - PREPARED D DJM QA ENG n/a C DATE 4/8/2008 D 43 n/a 43 n/a 2 A XX - Select material/finish (see page 6) B CUST. NAME PREPARED CUSTOMER DWG NO. ENGINEERING CUSTOMER DWG NO.#2 MFG APPROVAL FINISH QA APPROVAL - THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. - MATERIAL SPEC CuBe C17200 1/4 H B B UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX ± .005 .XX  .01 .1 .X ± ANGLES    DATE C INSIDESERIES CLIP-ON SIZE D A REV DWG NO P1 10-30CT EMI Enclosure Shielding Solutions SCALE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. FSCM NO. 4J674 SHEET 1 OF 1 17 4 3 2 Copper Beryllium Fingerstock 3 2 1 C CLIP-ON SERIES CONT. D CPS | Clip-On Black = inches Blue = mm PART NUMBER A 25-55CPS-XX-16 0.25 B 6.35 0.55 C 13.97 XX - Select material/finish (see page 6) 0.04 FINGER 1.02 0.220 5.59 PITCH 0.250 6.35 MATERIAL THICK LENGTH 0.004 16 0.102 3 PART NUMBER 6-31CPG-XX-12 A 0.06 1.52 0.31 7.87 D B A C INSIDE 0.04 1.02 CUST. NAME 0.500 12.70 0.545 PREPARED THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION DVG OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN 6-31CPG-XX-16 0.06 1.52 0.31 7.87 0.04 1.02DWG0.500 12.70 QA0.545 CUSTOMER NO. PRIVATE EXPENSE, AND MAY NOT USED, PITCH DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH ENG ANY PURPOSE INCLUDING DESIGN, OR material/finish (see page MANUFACTURE 6) H.T. TO DPH 383 FINGERXX - Select PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF MATERIAL SPEC LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR .004 BeCu ALLOY 172 WARRANTY THE PERFORMANCE CHARACTERISTICS. 4 64 406 2 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 MATERIAL .XX C.01 FINGER PITCH THICK .X .1 ANGLES 2 B LANCE B Perpendicular Shielding Gaskets • Finger design allows for continuous contact across the length of the strip • "D" lance provides superior retention of gasket to the mounting surface • 0.80 D-clip is retained with .100 D-hole CPG | Clip-On FINGERS/ STRIP 13.84 13.84 0.004 DATE0.102 0.004 11/15/2007 0.102 C Black = inches Blue = mm LENGTH 12 305 16 406 SIZE C 22 D A REV DWG NO 25-55CPS A FSCM NO. C INSIDE A 4J674 BB SHEET 1 OF 1 1 B A 3 4 LANCE 29 CLIP OND GASKET SCALE Perpendicular Electrical Grounding Strips 3 • Finger extension provides grounding from card or PCB 2to a backplane housing surface • Wide clip-on area with "D" lance offers reliable retention • .0035 material offers significant resiliency FINGERS/ STRIP 2 1 3 2 C INSIDE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XX .01 .X .1 ANGLES 2 GROUNDING SERIES PREPARED CUST. NAME THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION DVG OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. QA PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH ENG ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR H.T. TO 373 DPH PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF Black MATERIAL SPEC LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR .0035 BeCu ALLOY 172 WARRANTY THE PERFORMANCE CHARACTERISTICS. ML | Gasket PART NUMBER PITCH A 3 B C FINGER 2 PITCH D DATE A 11/30/2007 GASKET, CLIP-ON SIZE 14-18ML-XX-16 0.14 3.56 0.28 14-18ML-XX-24FINGER 0.14 3.56 LEADERTECH, IT'S 0.005 OWN 0.127 0.28OWNED 7.11 BY 0.18 4.57 0.080OR DEVELOPED 2.03 0.500 AT 12.70 48 CUSTOMER DWG NO. XX - Select material/finish (see page 6) MOUNTING OPTIONS ■ Tape .056 TYP 7.11 0.18 4.57 0.080 2.03 0.500 12.70 REV DWG NO P1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. C 6-31CPG = inches Blue = mm FSCM NO. SCALE .XXX .005 SHEET 1 OF 1 4J674 MATERIAL .XX .01 1 .1 ANGLES 2 THICK .X FINGERS 0.005 0.127CUST. NAME 32 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. 4 FINISH 11/15/2007 A ENG C INSIDE CLIP ON SIZE B .004 BeCu ALLOY 172 3 PITCH DATE DVG QA H.T. TO DPH 383 MATERIAL SPEC PREPARED C DWG NO C 25-55CPS SCALE FSCM NO. 4J674 2 .50 TYP FINGER B .056 TYP A UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 C .XX .01 .X .1 ANGLES 2 18 Phone: CUST. NAME PREPARED .50 TYPPROPRIETARY INFORMATION THIS DOCUMENT CONTAINS DVG OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. QA PRIVATE EXPENSE, AND MAY NOT USED, 866.832.4364 Fax: 813.855.3291 Web: www.leadertechinc.com B DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH ENG ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR H.T. TO 373 DPH PITCH B DATE 11/30/2007 GASKET, CL FINGER SIZE DWG NO 1 D 3 2 1 D Copper Beryllium Fingerstock 4 3 2 D PITCH D FINGER D CONTACT SERIES PITCH ContactC gaskets are primarily used for grounding and C shielding in high frequency applications. These gaskets provide engineers and designers with flexibility to solve D their shielding and grounding issues. They are available in a variety of different lengths, widths and profiles. Standard factory length for Contact Series strips is 16". Individual contacts available in tape & reel packaging. Adhesive tape is optional - please consult factory. FINGER C 1 2 C 1 2 C 4 3 A A 2 B A A D .05 9-19UD 4 10-26UD 16-44UD D 3 2 D 4 B 4 PART NUMBER A B B NFORMATION T IT'S OWN IN PART FOR CTURE OR RMISSION OF RANTEE OR ISTICS. CUST. NAME D FINGER D PITCH MAT. THICK 0.19 4.83 0.11 2.79 0.13 3.30 0.040 1.02 0.060 1.52 0.004 10-26UD-XX-16 0.11 2.79 0.26 6.60 0.17 4.32 0.22 5.59 0.050 1.27 0.075 1.90 0.006 16-44UD-XX-16 PREPARED 0.16 4.06 DATE 0.44 11.18 0.24 6.10 0.33 THIS DOCUMENT 8.38 0.062 ACONTAINS 1.57 PROPRIETARY 0.093 2.36INFORMATION 0.010 -0.254 FINISH MATERIAL SPEC .004 BeCu C PITCH 1 A LENGTH D FINGERS/STRIP 0.102 16 406 266 0.152 16 406 213 FINGER STOCK, UD SERIES NO 16 406 NO 4-53D NO 2 C DWG N 16-44UD-XX-16 10-2 4J674 SHEET F 1 OF 1 1 A C C REV B 1 B B B B C D B B B B C B 9° 9˚ D D CC B C B 4 3 A D SIZE SCALE D C D 8/28/2008 FINGER 2 C B DATE FINGER STOCK, UD SERI C 9-78D-A 9-78D 3 C PREPARED CUST. NAME 172 CONTACT SERIES 4-38D D TAPE PREPARED DATE CUST. NAME THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION DJM OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN 7/18/2008 M. Paul CUSTOMER DWG NO. QA PRIVATE EXPENSE, AND MAY NOT USED, CUSTOMER DWG NO. QA DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH ENG ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF SIZE DWG NO FINISH ENG MATERIAL SPEC LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR .006 BeCu 172 BRIGHT DIP WARRANTY THE PERFORMANCE CHARACTERISTICS. FSCM MATERIAL SPEC SCALE 3 C 2 NO. OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN DJM 5/5/2009 PRIVATE EXPENSE, AND MAY NOT USED, QA DUPLICATED ORARE DISCLOSED IN WHOLE OR IN PART FOR UNLESS OTHERWISE SPECIFIED, DIMENSIONS INC INCHES. Select material/finish (see page 6) ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR .XXX .005 REV WITHOUT SIZE DWG NO ENG PROCUREMENT C THE WRITTEN PERMISSION OF .XX .01 A LEADERTECH4 DOES NOT GUARANTEE OR LEADERTECH. C PITCH 9-19UD-XX-16 .X .1 ANGLES 2 .010 CuBe C17200 1/4 H WARRANTY THE PERFORMANCE CHARACTERISTICS. FSCM NO. SCALE SHEET 1 OF 1 4 3 DATE PREPARED CUST. 4J674 NAME C FINGER THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION 2 1 8/28/2008 DJM OWNED BY B LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. QA PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR SIZE DWG NO FINISH ENG C PURPOSE INCLUDING DESIGN, MANUFACTURE OR ANY PITCH C 10-26UD-XX-16 PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF PITCH FINGER FSCM NO. PITCH MATERIAL SPEC SCALE LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR .006 BeCu 172 4J674 FINGERSHEET 1 OF 1 WARRANTY THE PERFORMANCE CHARACTERISTICS. 4-34D FINGER 3 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XXX .010 .XX .01 .XX .01 .X .1 ANGLES 2 .X .1 ANGLES 2 2.29 XX - - C 0.09 CUSTOMER DWG NO. 1 2 Black = inches Blue = mm 9-19UD-XX-16 D UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XX .01 .X .1 ANGLES 2 A B 3 9-19UD 10-26UD 16-44UD | Contact Series D .07 1 B .07 D B B C 1 C C B C 1 2 3 D A B B 2 A A A .07 A UNLESS OTHERWISE SP .XXX ± .005 .XX  .01 .1 .X ± ANGLES B CUST. NAME UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. A B DIMENSIONS ARE IN INCHES. UNLESS SPECIFIED, .005 D .XXX ±OTHERWISE CUSTOMER DWG NO. A THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION .XXX  .005 .XX  .01 OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN .XX.X±.01 .1 ANGLES    CUSTOMER DWG NO.#2 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. PRIVATE EXPENSE, AND MAY NOT USED, B2 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .1 NAME ANGLES  .XCUST. .XXX .005 PREPARED DATE DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR .XXX .005 FINISH - NAME ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR .XX .01 PREPARED DATE CUST. .XX .01 A PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF ARY INFORMATION .X .1 ANGLES 2 .X .1 ANGLES 2 REV - ENGINEERING CUSTOMER DWG NO. LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR MATERIAL SPEC UNLESS OTHERWISE SPECIFIED, ED AT INFORMATION IT'S OWN A DIMENSIONS ARE IN INCHES. ETARY WARRANTY THE PERFORMANCE CHARACTERISTICS. CUSTOMER DWG NO. QA PREPARED DATE CUST. NAME PREPARED DATE CUST. NAME .004 BeCu 172 A A A .XXX .005 D, THIS DOCUMENT OPED AT IT'S OWN THIS DOCUMENTA CONTAINS PROPRIETARY INFORMATION - CONTAINS PROPRIETARY INFORMATION M. Paul 4 7/29/2008 3 CUSTOMER DWG NO.#2 MFG APPROVAL .XXORDEVELOPED .01 EED, OR IN PART FOR OWNED BY LEADERTECH, AT IT'S OWN OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. QA REV DWG NO. NO PRIVATE EXPENSE, SIZE FINISH ENG CUSTOMER DWG QA AND.X MAY NOT USED, .1 SIZE DWG NO ANGLES REV 2 NUFACTURE OR FOR LE OR IN PART PRIVATE EXPENSE, AND MAY NOT USED, A FOR IN WHOLE OR IN PART C 4-38DDUPLICATED OR DISCLOSED N PERMISSION OF SHEET 1FINISH OF 1 QA APPROVAL PREPARED DATE ENG MANUFACTURE OR CUST. NAME DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR REV SIZE DWG NO A PURPOSE INCLUDING DESIGN, MANUFACTURE OR SIZE FINISHDWG NO REV FSCMANY NO. INFORMATION SPEC SCALE TTEN GUARANTEE OR OF MATERIAL FINISH ENG THIS DOCUMENT PROPRIETARY A PERMISSION - THE WRITTEN PERMISSION OFM. Paul OR CONTAINS ANY PURPOSE INCLUDING DESIGN, MANUFACTURE FINISH 7/28/2008 9-78D-A-XX-16 PROCUREMENT WITHOUT SHEET 1 OF 1 A C .006 BeCu 172 4J674 CTERISTICS. OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN FINISHSCALE 4-53D OT GUARANTEE PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF FSCM NO. 1 OR MATERIAL FSCM NO. SPEC SPEC SCALE LEADERTECH. LEADERTECH DOESDWG NOTNO. GUARANTEE OR C CUSTOMER QA MATERIAL EXPENSE, MAY NOT SHEET 1 OF 1 SHEET 1 OF 1 -1 MATERIAL SPEC USED,WARRANTY 4J674 SCALE RACTERISTICS. .010 BeCu FSCM NO. LEADERTECH GUARANTEE OR AND 2 DOES NOTPRIVATE 4J674 THE PERFORMANCE CHARACTERISTICS. .004 LEADERTECH. BeCu 172 DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR SHEET 1 OF 1 .006 BeCu 4J674 2 SIZE WARRANTY THE PERFORMANCE CHARACTERISTICS. 3 FINISH 1 REV DWG NO ENG 2 4 1 ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR B 3 1C FINISH 9-78D-XX-16 PROCUREMENT WITHOUT THE WRITTEN PERMISSION2 OF UNLESS FSCM NO.OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. MATERIAL SPEC SCALE LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR SHEET 1 OF 1 .010 BeCu .XXX .005 4J674 WARRANTY THE PERFORMANCE CHARACTERISTICS. C N GASKET 4-34D 4-38D 4-53D 9-78D 9-78D-A | Contact Series CONTACT SERIES PART NUMBER 4 4 LIP-ON A B C D Black = inches Blue = mm FINGER PITCH MATERIAL SERIES CONTACT LENGTH THICK FINGERS/ TAPE 9-78D-A FINGERSTOCK STRIP 266 NO 4-34D-XX-16 0.04 1.02 0.34 8.63C 0.29 4-34D-XX-16 7.37 0.13 3.30 0.040 1.02 A 0.060 1.52 0.004 0.102 16 406 4-38D-XX-16 0.05 1.27 0.38 9.65 0.31 7.87 0.062 15.75 0.050 1.27 0.075 1.90 0.006 0.152 16 406 213 NO 4-53D-XX-16 0.05 1.27 0.53 13.46 0.47 11.94 0.22 5.59 0.050 1.27 0.075 1.90 0.006 0.152 16 406 213 NO 9-78D-XX-16 0.05 1.27 0.78 19.81 0.66 16.76 0.31 7.87 0.062 1.57 0.093 2.36 0.010 0.254 16 406 172 NO 9-78D-A-XX-16 0.09 2.29 0.78 19.81 0.66 16.76 0.31 7.87 0.062 1.57 0.093 2 2.36 0.010 0.254 16 .X .1 406 172ANGLES NO 2 3 9-78D FINGERSTOCK .XX .01 CUST. NAME A 1 PREPARED THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION DJM OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. QA PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH ENG ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF MATERIAL SPEC LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR .006 BeCu 172 WARRANTY THE PERFORMANCE CHARACTERISTICS. XX - Select material/finish (see page 6) C 4 3 DATE 8/28/2008 CONTACT S SIZE C SCALE DWG NO 10-26UD-XX-16 FSCM NO. 4J674 2 A PITCH FINGER REV P1 EMI Enclosure Shielding Solutions 19 D D D D D D Copper Beryllium Fingerstock 4 PITCH 3 CONTACT SERIES CONT. 2 FINGER C C C C C C PITCH FINGER D D 4 3 D 2 1 C C C C D B B B B 7-13U A 13-28U* A B 28-49U B B 4 3 C 7-13U 13-28U 28-49U | Contact Series PITCH PART NUMBER A 2 C D 1 Black = inches Blue = mm FINGER 0.07 1.78 0.13 3.30 0.07 1.78 0.09 2.29 13-28U-XX-16 0.13 3.30 0.28 7.11 0.16 4.06 0.23 5.84 DATE PITCH 0.28 7.11 0.49 12.45 0.34 8.64 U CONTACT SERIES 0.38 LENGTH 9.65 *Finger width starts at .095 and tapers to .092. C 1.02 0.060 1.52 0.004 0.102 16 406 266 NO 2.41 0.135 3.43 0.010 0.254 16 406 118 NO 0.125 3.17 0.187 4.75 0.006 C U CONTACT SERIES DATE 0.152 PREPARED DJM 16 A NO CONTACT SERIES FSCM NO. 4J674DWG NO SIZE C 2 1 SCALE A A SHEET REV 1 OF 1 B1 28-49U-XX-16 FSCM NO. 4J674 SHEET 1 OF 1 C 1 B D 2 C REV 7-13U REV SCALE D A 85 DWG NO SIZE A 406 A 6/2/2009 U STYLE CONTACTENGINEERING SERIES C 7-13U TAPE 0.095 DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR CUSTOMER DWG NO.#2 MFG APPROVAL SIZE SPEC DWG NO REVOR FINISH DWG LEADERTECH. ENG SIZE NO LEADERTECH DOES NOT GUARANTEE MATERIAL ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. .004CBeCu 172 FINISH QA APPROVAL 13-28U-XX-16 PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF QA APPROVAL THIS DOCUMENT CONTAINS INFORMATION FINISH 4 3 PROPRIETARY FSCM NO. SCALE LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR DMATERIAL SPEC 4 3 2 OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, N/A SHEET 1 OF 1 C .010 4J674 WARRANTY THE PERFORMANCE CHARACTERISTICS. FSCM NO. BeCu ALLOY 25 DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR SCALE MATERIAL SPEC PITCH ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR SHEET 1PROCUREMENT OF 1 WITHOUT THE WRITTEN PERMISSION OF MATERIAL SPEC 4J6742 .004 BeCu 172 3 1 LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR .0063 CuBe C17200 1/4 HT WARRANTY THE PERFORMANCE CHARACTERISTICS. 2FINGER 1 4 3 2 - FINGERS/STRIP 0.040 UNLESS SPECIFIED, DIMENSIONS ARE IN INCHES. ANGLES OTHERWISE   .XXX ± .005PREPARED DATE 3 .XX  .01 .1 ENGINEERING .X ± ANGLES    CUSTOMER DWG NO. THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION CUST. NAME PREPARED DATEOWN CUST. NAME OWNED BY LEADERTECH, OR DEVELOPED AT IT'S CUSTOMER DWG NO.#2 MFG APPROVAL THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION PRIVATE EXPENSE, AND MAY NOT USED, CUSTOMER DWG NO. ENGINEERING 6/2/2010 DJM D OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR A CUSTOMER DWG NO. CUSTOMER DWG NO. QA APRIVATE EXPENSE, AND MAY NOT USED, FINISH QA APPROVAL ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR XX APPROVAL - Select material/finish (see page 6) PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF CUSTOMER DWG NO.#2 MFG 28-49U-XX-16 MAT. THICK UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX ± .005 7-13U-XX-16 PREPARED CUST. NAMEA B FINGER UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XX  .01 .1 .X ± .XXX .005 CUST. NAME 4 .XX .01 .X .1 ANGLES 2 B B PITCH FINGER UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX ± .005 D .XX  .01 .1 .X ± ANGLES    B A A C 4 3 2 D A 1 B C B PITCH D FINGER D A B UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX ± .005 C B 11-78R2 | Contact Series C PART NUMBER B 3.30 0.78 C 19.81 0.20 FINGER 5.08 0.140 PITCH 3.56 0.187 4.75 0.005 0.127 16 PITCH 4 FINGER 86 DATE - C 1 U CONT ENGINEERING NO MFG APPROVAL - QA APPROVAL LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. 3 MATERIAL SPEC.XXX .005 3 .XX.0045 .01 BeCu 172 .X .1 ANGLES 2 SCALE C B D FSCM NO. B 2 4J674 SHEET 4 1 OF 1 1 PREPARED DATE THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION M. Paul OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. QA PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH ENG ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF HEAT TREAT TO 373 DPH MATERIAL SPEC LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR .0045 BeCu 172 WARRANTY THE PERFORMANCE CHARACTERISTICS. B 3 2 C B 7 SCALE REV 2 CUST. NAME A FSCM NO. DWG NO SIZE A C THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION 3/8/2008 FINISH M. Paul MANUFACTURE OR OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN ANY PURPOSE INCLUDING DESIGN, CUSTOMER DWG NO. QA PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR MATERIAL SPEC SIZE DWG NO FINISH ENG ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. .004 BeCu 172 TO 373OTHERWISE DPH SPECIFIED, DIMENSIONS ARE IN INCHES. C 11-78R2-XX-16 PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF HEAT TREATUNLESS 4 B 406 B PREPARED FINGER STOCK, CONTACT FINGER 4 CUST. NAME FINGERS/STRIP TAPE - PRIVATE EXPENSE, AND MAY NOT USED, DATE FOR CUST. NAME DUPLICATED OR DISCLOSEDPREPARED IN WHOLE OR IN PART XX - Select material/finish PITCH(see page 6) D LENGTH UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. A .XXX CUSTOMER DWG NO. 2 3 .005 THIS CONTAINS PROPRIETARY INFORMATION .XX DOCUMENT .01 OWNED .X .1 BY LEADERTECH, ANGLES 2 OR DEVELOPED AT IT'S OWN B CUSTOMER DWG NO.#2 C C MAT. THICK ANGLES    .1 .X ± A 40.13 11-78R2-XX-16 A Black = inches .XX Blue .01= mm A 3/8/2008 FINGER STOCK, CONTACT B SIZE REV DWG NO C C 11-78R2-XX-16 SCALE FSCM NO. B 4J674 B SHEET 1 OF 1 1 B A D B A A 11-90S | Contact Series PART NUMBER C 11-90S-XX-16 A 0.11 B 2.79 0.90 C 22.86 0.66 16.76 0.38 FINGER PITCH MAT. THICK UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX ± .005 LENGTH 0.125 16 .XXX ± .005 .XX  .01 .1 .X ± 9.65 CUST. NAME A PITCH 20 - FINGER A 3.17 ANGLES 0.172 4.37   PREPARED .XX  .X ± 0.010 .01 .1 0.254 406 ANGLES    FINGERS/ STRIP 93 CUST. NAME DATE - PREPARED M. Paul Phone: 866.832.4364 4 1/28/2009 .XX .01 Fax: 813.855.3291 3 C 11-90S-SALES Web: www.leadertechinc.com WARRANTY THE PERFORMANCE CHARACTERISTICS. 2 3 ANGLES  2 11-90S, CONTACT SERIES 11-90S, CONTACT SERIES EXPENSE, AND MAY NOT LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WITHOUT PROCUREMENT THE WRITTEN PERMISSION PRIVATE OF FSCM NO.USED, MATERIAL SPEC SCALE WARRANTY THE PERFORMANCE CHARACTERISTICS. 4J674 LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR OR IN DUPLICATED OR DISCLOSED IN WHOLE .01 BeCu MATERIAL SPEC 4 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 DATE M. Paul 1/28/2009 CUSTOMER DWG NO. ENGINEERING CUSTOMER DWG NO. ENGINEERING .X .1A THIS DOCUMENT CONTAINS PROPRIETARY THISINFORMATION DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWNED BYOWN LEADERTECH, AT IT'S OWN CUSTOMER OR DWGDEVELOPED NO.#2 MFG APPROVAL CUSTOMER DWG NO.#2 MFG APPROVAL PRIVATE EXPENSE, AND MAY NOT USED, CUST. NAME PRIVATE EXPENSE,- AND MAY NOT USED, SIZE DWG NO DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR THIS- DOCUMENT CONTAINS PROPRIETARY INFORMATION -REV SIZE DUPLICATED IN WHOLE OR QA INAPPROVAL PART FOR FINISH ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OROR DISCLOSED BY LEADERTECH, OR DEVELOPED FINISH QA APPROVAL AT IT'S OWN ANY PURPOSEOF INCLUDING DESIGN, MANUFACTURE OROWNED PROCUREMENT WITHOUT THE WRITTEN PERMISSION XX - Select material/finish (see page 6) A Black = inches Blue = mm UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. D A C DWG NO DATE M. Paul REV 3/8/2008 QA 11-90S-SALES CUSTOMER DWG NO. A PREPARED PARTSHEET FOR1 OF 1 FSCM NO. SCALE FINISH ENG 4J674 1 ANY .01 PURPOSE OR BeCu INCLUDING DESIGN, MANUFACTURE PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF HEAT TREAT TO 373 DPH 2 SHEET 1 A 1 OF 1 S 4 3 2 1 Copper Beryllium Fingerstock D D 4 4 3 2 3 1 2 D 1 CONTACT SERIES CONT. D C 4 4 3 3 2 C 2 1 1 PITCH PITCH FINGER FINGER D A C D D C B D D PITCH .200 B FINGER PSA TAPE 12-75RS | Contact Series PART NUMBER A 12-75RS-XX-16 4 0.12 3.05 0.75 C 19.05 .XXX ±.005 .XX  .01  .X ± .1 ANGLES  CUST. NAME - D THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. DATE DJM 5/6/2009 CUSTOMER DWG NO. ENGINEERING MFG APPROVAL - C C 4 PITCH 3 PITCH 0.005 16 0.127 CONTACT SERIES MATERIAL SPEC 406 FSCM NO. A 4J674 D D A 1 OF 1 1 .XXX ±.005 C .XX  .01 3 3 CUST. NAME CUSTOMER DWG NO. A CUSTOMER DWG NO.#2 - 8-92RB-XX-16 B C D 0.09 2.29 B 0.92 C 23.37 D FINGER 0.30 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. 7.62 0.61 15.49 0.140 3.56 0.187 .XXX ± .005 .XX  .01 .1 .X ± CUST. NAME PREPARED CUSTOMER DWG NO. ENGINEERING PITCH CUSTOMER DWG NO.#2 MFG APPROVAL - THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. FINGER PITCH FINGER 3 4.75 MAT. THICK LENGTH 0.005 16 0.127 CONTACT R-SERIES 3 8-92RC-XX-16 A FINISH C QA APPROVAL - MATERIAL SPEC SCALE 2.29 2 0.92 C C D 23.37 0.30 4J674 D 7.62 0.63 FINGER 16.00 0.140 3.56 PITCH 0.187 REV A 3 FINGER 3 4 PITCH .06 11-89RA-XX-16 MAT. THICK 4.75 0.005 0.127 FINGERS/ TAPE - PREPARED STRIP CUSTOMER DWG NO. 16CUSTOMER 406DWG NO. 85- ENGINEERING NO LENGTH CUST. NAME A 3.30 0.89 D 22.61 C 0.81 D D 3 20.57 0.60 15.24 0.140 3.56 0.187 4.75 4 MAT. THICK LENGTH 0.005 16 0.127 .XX  .X ± A PART NUMBER A 0.23 5.84 B 0.77 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN C 0.64 DD 16.26 4 SCALE .005 BeCu 172 FINGER STOCK, CONTACT D PITCH REV B 2 2 FINGERS/ STRIP 85 2 FINGER 15.75 PREPARED .01 .1 FSCM NO. A 0.140 3.56 FINGER 12- SCALE SHEET FSCM N 1 OF A DATE R, CONTACT SER DWG NO B 8-92RC FSCM NO. 4J674 SHEET 2 1 PREPARED - FINISH 4J674 1 NO ANGLES    DWG NO C 8-92RB TAPE DATE QA APPROVAL PREPARED DATE CONTACT R DWG NO SIZE C 8-92 EXPENSE, AND MAY NOT USED, THIS DOCUMENTPRIVATE CONTAINS PROPRIETARY INFORMATION DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR 2/6/2008 DVG OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR A FSCM NO. MATERIAL SPEC DWG NO. SCALE CUSTOMER QA C B PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF PRIVATE EXPENSE, AND MAY NOT USED, LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR THE PERFORMANCE CHARACTERISTICS. FOR CuBe C17200 1/4 H DUPLICATED ORWARRANTY DISCLOSED IN WHOLE OR IN PART.0050 SIZE DWG NO FINISH ENG ANY3PURPOSE INCLUDING DESIGN, MANUFACTURE OR 2 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. C 11-89RA-XX-16 PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF .XXX .005 FSCM NO. MATERIAL SPEC SCALE LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR .XX  .01 .005 CuBe C17200 1/4 H 4J674 WARRANTY THE PERFORMANCE CHARACTERISTICS. PITCH 0.187 4.75 MAT. THICK LENGTH 0.005 16 0.127 406 FINGERS/ STRIP 85 TAPE ANGLES 2 2 SH 1 PREPARED THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION C B OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. QA PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR FINISH ENG ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR BD (BRIGHT) PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF A MATERIAL SPEC LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR .005 BeCu ARE ALLOY 172 UNLESS OTHERWISE SPECIFIED, DIMENSIONS IN INCHES. WARRANTY THE PERFORMANCE CHARACTERISTICS. EMI Enclosure Shielding Solutions .XXX ± .005 CONTACT,4J674 STY NO .X .1 CUST. NAME A 11-78R2-XX-16 0.62 SIZE DWG NO C MATERIAL SPEC 3 A DWG NO SIZE - CUST. NAME Black = inches Blue = mm 19.56 B C QA APPROVAL CON BCONTACT R-SERIES CUSTOMER DWG NO. ENGINEERING A UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 CUSTOMER DWG NO.#2 MFG APPROVAL .XX .01 .X .1 ANGLES 2 FINGER XX - Select material/finish (see page 6) SIZE MFG APPROVAL MFG APPROVAL - - PITCH B 4 5/6/2009 CUSTOMER DWG NO.#2 CUST. NAME PITCH C22-77RR-XX-16 C 406 3 FINGER 22-77RR | ContactA Series DATE ENGINEERING .0050 CuBe C17200 1/4 H PITCH 1 C DJM C .06 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION B C OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN CUSTOMER DWG NO. QA PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR SIZE FINISH ENG ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR BD (BRIGHT) C PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. MATERIAL SPEC SCALE LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR .005 BeCu ALLOY 172 .XXX ± .005 WARRANTY THE PERFORMANCE CHARACTERISTICS. FINGER B XX - Select material/finish (see pageB6) DATE FINISHQA APPROVAL Black = inches Blue = mm CUST. NAME B C 0.13 A - THIS DOCUMENT FINISH CONTAINS PROPRIETARY INFORMATION THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED LEADERTECH, OR DEVELOPED AT IT'S OWN OWNED BY LEADERTECH, OR DEVELOPED AT IT'SBY OWN PRIVATE EXPENSE, AND MAY NOT USED,PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE DUPLICATED OR IN PART FOR OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR INCLUDING DESIGN, MANUFACTURE OR ANY PURPOSE MATERIAL SPEC PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS. WARRANTY THE PERFORMANCE CHARACTERISTICS. B A C C 2 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. .XXX .005 .XX .01 .X .1 ANGLES 2 11-89RA | Contact Series PART NUMBER 1 B .XXX ±DIMENSIONS .005 UNLESS OTHERWISE SPECIFIED, ARE IN INCHES. .XX  .01 .XXX ± .005  B .X ± .1 .XX  .01 ANGLES  .1 .X ± ANGLES  NAME  PREPARED CUST. FINGER D SHEET 1 1 OF 1 - PITCH 4 4 1 SHEET 1 3 D B D 4J674 A2 - SHEET 1 OF 1 FSCM NO. 2 A CUSTOMER DWG NO.#2 XX - Select material/finish (see page 6) A 12-75RS-XX-16 SCALE Black = inches Blue = mm B D C DWG NO C QA APPROVAL A 8-92RB FSCM NO. .0050 CuBe C17200 1/4 H 4 A A 0.09 .005 BeCu 172 REV C C SIZE MATERIAL SPEC FINGERS/ TAPE STRIP PSA TAPE 85 NO 406 DWG NO SIZE 8-92RC | Contact Series B PART NUMBER 1 CONTACT SERIES DATE - - D 5/6/2009 ANGLES    - B 4 PITCH D XXC - Select material/finish (see page 6) 4 DATE Black = inches Blue = mm .200 D 8-92RB | Contact Series A 2 DJM MFG APPROVAL B - 3 D PART NUMBER B A FINISH THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OWNED BY LEADERTECH, OR DEVELOPED AT IT'S OWN PRIVATE EXPENSE, AND MAY NOT USED, DUPLICATED OR DISCLOSED IN WHOLE OR IN PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR PROCUREMENT WITHOUT THE WRITTEN PERMISSION OF LEADERTECH. LEADERTECH DOES NOT GUARANTEE OR WARRANTY THE PERFORMANCE CHARACTERISTICS.  PREPARED ENGINEERING - 4 4J674 2 - D 7-13U  ANGLES  .X ± .1 B TACT SERIES A UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. B FINGER 1 .200 A SHEET 2 PITCH 4 1 B 2 PSA TAPE C 4 2 FINGERS/ TAPE STRIP 85 YES REV 12-75RS-XX-16 SCALE .005 BeCu 172 4.75 DWG NO C QA APPROVAL FINGER 3 LENGTH D C SIZE FINISH - MAT. THICK B  PREPARED CUSTOMER DWG NO.#2 - PITCH PITCH D FINGER FINGER FINGER 0.12UNLESS3.05 0.65 16.51 0.140 3.56 0.187 OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. C XX - Select material/finish (see page 6) A D A C Black = inches Blue = mm 3 B 4 B DATE R C 21 SIZE SCALE DWG N 8-9 Metal Shielding Gaskets 7 METAL D-SUBS 6 7 5 6 2 4 A 4 3 2 3 2 1 3 1 A B B C C G Standard Finish and Plating Options G SPECIFICATIONS LEADER TECH FINISH CODE As Heat Treated BD (Standard) E BRIGHT TIN ASTM B-545 SN D SATIN TIN/MATTE TIN ASTM B-545 ST ELECTROLESS BRIGHT NICKEL ROHS ASTM B 733 NI FINISH TYPE D 4X R .050 4X R .050 H D BRIGHT FINISH D 2X FULL 2XRFULL R E H FD F 1 C COPPER COPPER BERYLLIUM BERYLLIUM AB BC CD DE N .41 .74 N .28 N .93 N 1.41 .98 1.74 1.31 2.28 1.85 2.93 2.50 .98 .78 1.31 1.11 1.85 1.65 2.50 2.29 .78 .44 1.11 .44 1.65 .44 2.29 .44 .44 .22 .22 .69 .69 .025 .44 .22 .22 .69 .69 .025 .44 .22 .22 .69 .69 .025 PART NUMBER .44 .22 .22 .69 .69 .025 .025 .13 .13 TYPE .025 .13 .13 .84 N 2.84 2.41 2.41 2.11 2.11 .55 .55 .28 .28 .80 .80 .025 09D-110-XX .025 .24 EF FG GH H .025 .13 .13 D-Sub Miniature - Solid .025 .13 .13 STAINLESS STAINLESS STEEL STEEL 09D-100-SS AB BC CD DE EF 15D-110-XX 1.41 .98 .98 .78 .78 .44 .44 .22 .22 .69 1.74 1.31 1.31 1.11 1.11 .44 .44 .22 .22 .69 15D-100-SS 2.28 1.85 1.85 1.65 1.65 .44 .44 .22 .22 .69 2.93 2.50 2.50 2.29 2.29 .44 .44 .22 .22 .69 25D-110-XX 2.84 2.41 2.41 2.11 2.11 .55 .55 .28 .28 .80 25D-100-SS FG .69 .025 C .69 .025 .69 .025 .69 .025 .80 .025 GH .025 .13 .025 .13 .025 .13 .025 .13 .025 .24 Black = inches Blue = mm A B C D 0.98 24.89 0.78 19.81 0.44 11.18 0.22 5.59 0.69 17.53 0.025 9 Pin 1.41 35.81 0.98 24.89 0.78 19.81 0.44 11.18 0.22 5.59 0.69 17.53 B 0.025 15 .13 Pin 1.74 44.20 1.31 33.27 1.11 28.19 0.44 11.18 0.22 5.59 0.69 17.53 15 .13 Pin 1.74 44.20 1.31 33.27 1.11 28.19 0.44 11.18 0.22 5.59 0.69 2.28 57.91 1.85 46.99 1.65 41.91 0.44 11.18 0.22 5.59 2.28 57.91 1.85 46.99 1.65 41.91 0.44 11.18 0.22 5.59 11.18 0.22 25 Pin 50 Pin 172.14 2.84 0.63 0.13 3.30 0.025 0.63 0.13 3.30 17.53 0.025 0.63 0.13 3.30 0.69 17.53 0.025 0.63 0.13 3.30 0.69 17.53 0.025 0.63 0.13 3.30 A 5.59 0.69 17.53 0.025 0.63 0.13 3.30 B 0.22 5.59 0.69 17.53 0.025 0.63 0.13 3.30 13.97 G 0.28 7.11 0.80 20.32 0.63 0.24 6.10 2.41 61.21 2.11 53.59 0.63 0.24 6.10 11.18 TITLE SOLID SOLID D-SUB D-SUB CONNECTOR CONNECTOR SIZE NO. DWG. NO. DWG. XX - Denotes the availability of5 finish/plating options. See chart SS3 - Denotes stainless steel. 6 4 above. 4 Example: 09D-110-BD 2 3 5 6 6 5 5 4 4 D A A B B C C 2 1 2 2 3 3 REV A A 0.025 REV 3.30 C 3 FSCM NO. SHEET 1 1 OF 1 4J674 4J674 SHEET 1 OF FSCM NO. SCALE: 4:1 SCALE: 4:1 6 7 B PN AND PNPLATING AND PLATING OPTIONS OPTIONS B A2 0.025 A 13.97 B 0.28 7.11 0.80 20.32 0.55 CUSTOMER APPR. CUSTOMER APPR. PER P/N, .004" PER P/N, THICK .004" THICK CHARACTERISTICS. CHARACTERISTICS. 0.13 TITLE SIZE H 0.63 UNLESS OTHERWISE UNLESS OTHERWISE SPECIFIED,SPECIFIED, DIMENSIONS DIMENSIONS ARE IN INCHES: ARE IN INCHES: FINISH FINISH PROCUREMENT PROCUREMENT WITHOUT THE WITHOUT WRITTEN THE WRITTEN PERMISSION OF PERMISSION LEADERTECH. OF LEADERTECH. PER P/N PER P/N LEADERTECH LEADERTECH DOES NOT GUARANTEE DOES NOT GUARANTEE MATERIAL SPEC MATERIAL SPEC OR WARRANTY ORTHE WARRANTY PERFORMANCE THE PERFORMANCE D G 35.81 .13 25 .13 Pin .24 50D-100-SS F 1.41 H NISH/PLATING ITY OF FINISH/PLATING OPTIONS. OPTIONS. SEE CHART. SEE CHART. E .24 9 Pin ARD TANDARD FINISHFINISH AND PLATING AND PLATING OPTIONS* OPTIONS* .XXX +/- .005 .XXX +/- .005 +/- .01 .XX +/- .01 37D-110-XX 37 Pin 2.93 74.42 .XX 63.50 2.29 0.44 .X2.50 +/- .1 .X ANGLES +/.1 +/-ANGLES 2 DEG +/- 2 DEG 58.17 SPECIFICATIONS SPECIFICATIONS LEADER LEADER TECH FINISH TECH FINISH CODE CODE PREPARED PREPARED CUST. NAMECUST. NAME BD (STANDARD) BD (STANDARD) 37D-100-SS 37 Pin THIS DOCUMENT 2.93 74.42 -CUST. 2.50DWG. NO. 63.50 2.29 58.17 0.44 CUST. DWG. NO. THISCONTAINS DOCUMENT CONTAINS SN SN MIL-T-10727 MIL-T-10727 / ASTM/ BASTM 545 B 545 ENGINEERING ENGINEERING APPR. APPR. PROPRIETARYPROPRIETARY INFORMATION INFORMATION OWNED BY OWNED BY LEADERTECH,LEADERTECH, OR DEVELOPED ORAT DEVELOPED IT'S AT IT'S OWN EXPENSE, PRIVATE AND EXPENSE, MAY NOT AND MAY NOTDWG. NO. N ST ST 50 Pin OWN PRIVATE2.84 MIL-T-10727 MIL-T-10727 / ASTM/ BASTM 54550D-110-XX B 545 CUST. CUST. 261.21 DWG. NO. 2 72.14 2.41 2.11 53.59 0.55 BE USED, DUPLICATED BE USED, OR DUPLICATED DISCLOSED ORINDISCLOSED IN MFG APPR. MFG APPR. WHOLE OR INWHOLE PART FOR OR ANY IN PART PURPOSE FOR ANY PURPOSE OHS KEL ROHS AMS 2404 AMS/ 2404 ASTM/ BASTM 733 B 733 NI NI INCLUDING DESIGN, INCLUDING MANUFACTURE DESIGN, MANUFACTURE OR OR 7 C 20° TYP20° TYP EA EA N .41 .74 N .28 N .93 N .84 N 1 5 1 C 1 1 E G G F D B D D 2XRFULL R 2X FULL 4X R .050 4X R .050 H E E H D F PYT °02 C PPER BERYLLIUM ERYLLIUM CD DE C .025 TYP .025 TYP 878 .78 .44 1 1.11 .11 .44 5 1.65 .65 .44 0 2.29 .29 .44 .44 .22 .44 .22 EF .22 .69 .22 .69 .44 .22 .44 .22 .22 .69 .22 .69 FG GH H .69 .025 .025 .13 .13 .69 .025 .025 .13 .13 .69 .025 .025 .13 .13 PART.025 NUMBER .69 .025 .13 .13 1 2.11 .11 .55 .55 .28 .28 .80 .80 .025 .025 .24 AINLESS SS STEEL STEEL CD DE C 878 .78 .44 .44 .22 31 .11 1.11 .44 .44 .22 85 .65 1.65 .44 .44 .22 50 .29 2.29 .44 .44 .22 41 .11 2.11 .55 .55 .28 EF .22 .69 .22 .69 .22 .69 .22 .69 .28 .80 TYPE .24 FG GH 15D-210-XX .69 .025 .025 .13 .69 .025 .025 .13 9 Pin .13 .13 15D-200-SS .69 .025 .13 .025 .13 .69 .025 .025 .13 25D-210-XX .80 .025 .025 .24 .13 .24 25D-200-SS VER G OPTIONS. SEE CHART. NS. SEE CHART. 6 22 6 B 35.81 0.98 C 24.89 0.78 15 Pin 1.74 44.20 1.31 33.27 1.11 15 Pin 1.74 44.20 1.31 33.27 1.11 1P25 Pin D 19.81 0.44 57.91 41.85 76J446.99 28.19 .ON MCSF 1.65 .ON GWD REMOTSUC B 0.025 0.631 REB0.13 3.30 MUN REMOTSUC 0.63 0.13 3.30 41.91 0.44 11.18 0.22 5.59 0.69 0.63 0.13 3.30N/P REP C ELACS 41.91 2.50 63.50 2.29 58.17 72.14 2.41 61.21 2.11 53.59 50 Pin 2.84 72.14 2.41 61.21 2.11 53.59 0.44 11.18 0.44 TITLE ENGINEERING APPR. ENGINEERING APPR. 0.025 5.59 0.69 17.53 5.59 0.69 17.53 2 0.025 0.63 0.13 3.30 0.63 KCIH0.13 T "4003.30 . ,N/P REP 11.18 5.59 0.69 3.30 17.53 0.025 0.63 0.13 0.55 SLOTTED D-SUB CONNECTOR A 13.97SLOTTED 0.28 D-SUB 7.11CONNECTOR 0.80 20.32 A 0.025 0.63 0.24 6.10 0.55 0.28PLATING 7.11 OPTIONS 0.80 20.32 PNPLATING AND PN 13.97 AND OPTIONS 0.025 0.63 0.24 6.10 TITLE 0.22 0.025 C SIZE DWG. NO. DWG. NO. REV A A REV A OF 1 1 OF 1 4J674 4J674 SHEET 1 SHEET FSCM NO. FSCM NO. 1 Fax: 813.855.3291 A NOITAMROFNI YRATEIRPORP SNIATNOC TNEMUCOD SIHT NWO S'TI TA DEPOLEVED RO ,HCETREDAEL YB DENWO ,DESU TON YAM DNA ,ESNEPXE ETAVIRP ROF TRAP NI RO ELOHW NI DESOLCSID RO DETACILPUD RO ERUTCAFUNAM ,NGISED GNIDULCNI ESOPRUP YNA FO NOISSIMREP NETTIRW EHT TUOHTIW TNEMERUCORP RO EETNARAUG TON SEOD HCETREDAEL .HCETREDAEL .SCITSIRETCARAHC ECNAMROFREP EHT YTNARRAW B C 3 1 ROTCENNOC BUS-D DILOS VER D Web: www.leadertechinc.com EZIS ON GWD 1P .SEHCN E E F B HSINIF CEPS LAIRETAM 0.22 B B SIZE APPR. CUSTOMER CUSTOMER APPR. 0.44 17.53 2#.0.13 ON GWD3.30 REMOTSUC 2 REBMUN REMOTSUC 11.18 G 0.22 SCALE: 4:1 SCALE: 4:1 steel. XX - Denotes the availability of finish/plating options. See chart above. Example: SS - Denotes stainless THICK 09D-210-BD 4 2 3 5 4 2 3 5 * For fabric option - See page 34. Phone: 866.832.4364 17.53B 0.63 74.42- MFG APPR. MFG APPR. GNIREENIGNE 0.69 LAV17.53 0.025 ORPPA AQ 2.84 OR IN PART FOR ANY PURPOSE WHOLE OR INWHOLE PART FOR ANY PURPOSE INCLUDING DESIGN, MANUFACTURE OR INCLUDING DESIGN, MANUFACTURE OR FINISH FINISH PROCUREMENT PROCUREMENT WITHOUT THEWITHOUT WRITTEN THE WRITTEN PERMISSION OF LEADERTECH. PERMISSION OF LEADERTECH. PER P/N PER P/N DOES NOT GUARANTEE LEADERTECHLEADERTECH DOES NOT GUARANTEE MATERIAL SPEC MATERIAL SPEC ORTHE WARRANTY THE PERFORMANCE OR WARRANTY PERFORMANCE CHARACTERISTICS. .004" CHARACTERISTICS. PER P/N, PER .004"P/N, THICK 0.69 EMAN .TSUC EMAN R3.30 EMOTSUC 0.13 RPPA GF0.025 M 0.69LAVO17.53 50 Pin PREPARED PREPARED 5.59 H 0.63 5.59 THIS CONTAINS DOCUMENT CONTAINS CUST. DWG. CUST. NO. DWG. NO. THIS DOCUMENT INFORMATION PROPRIETARYPROPRIETARY INFORMATION OWNED BY OWNED BY OR AT DEVELOPED AT -IT'S LEADERTECH,LEADERTECH, OR DEVELOPED IT'S OWN PRIVATE EXPENSE, AND MAY NOT OWN PRIVATE EXPENSE, AND MAY NOT CUST. DWG. CUST. NO. 2 DWG. NO. 2 BE USED, DUPLICATED ORIN DISCLOSED IN BE USED, DUPLICATED OR DISCLOSED CUST. NAMECUST. NAME 0.22 G 0.025 5.59 58.17 - 11.18 DERAPERP 17.53 0.22 2.29 2.93 0.69 0.22 63.50 37 Pin 5.59 11.18 EZIS UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES: UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES: .XXX +/- .005 .XXX +/- .005 .XX +/- .01 .XX +/- .01 .1 ANGLES .X +/- .1 .X +/ANGLES +/2 DEG +/- 2 DEG F 0.22 11.18 2.50 2.93 E ETAD 11.18 0.44 1 74.42 37 Pin 0.44 D .SEHCNI NI ERA SNOISNEMID ,DEIFICEPS ESIWREHTO SSELNU B . ± XXX. Black = inches Blue 5=00mm 10.  XX. 1. ± X.    SELGNA 28.19 ON GWD XX57.91 -0X1.851-D PP 46.99 1.65 2.28 FO 1 TEE2.28 HS 251 Pin SH AND PLATING OPTIONS* 37D-210-XX D PLATING OPTIONS* SPECIFICATIONS LEADER LEADER TECH FINISH CIFICATIONS TECH FINISH CODECODE 37D-200-SS BD (STANDARD) BD (STANDARD) L-T-10727 ASTM SN 27 / ASTM/ B 545 B 545 SN 50D-210-XX ST L-T-10727 / ASTM B 545 ST 27 / ASTM B 545 MS/2404 ASTM NI 50D-200-SS 04 ASTM/ B 733 B 733 NI A 1.41 R ENN35.81OC0.98BU24.89 S-D0.78DIL19.81OS0.44 9 PinOTC1.41 H C 20° TYP 20° TYP D-Sub Miniature - Slotted 09D-210-XX C 09D-200-SS A G 1 D F XX-0X1-DPP 476J4 1 FO 1 TEEHS 1 .ON MCSF C ELACS G Precision Metal Stampings 4 THIN GAUGE CUSTOM MECHANICAL SPRINGS & STAMPINGS For over 30 years, Leader Tech has been supplying customers with high quality precision custom prototypes, short run and high volume stampings. Our in-house tool & die design and build expertise, combined with our extensive manufacturing capabilities, allow us to manufacture custom precision D components for many applications. Our expertise is not limited to just the stamping portion of the application but can include value added operations such as the addition of insulating materials, hardware and other required features. From prototype to high volume production runs, Leader Tech can meet your custom needs with the shortest and most reliable lead times in the industry. 2 3 4 From prototypes within days to long production runs, your Leader Tech Team is ready to assist you. Please call us at 813-855-6921 or email us at sales@leadertechinc.com with your requirements. D C 4 R LLUF X2 C 050.R X4 H D A B B C 2 3 4 R LLUF X2 050.R X4 E F D H D B C A PYT °02 NI ERA SNOISNEMID ,DEIFICEPS ESIWREHTO SSELNU 4 500. ± XXX. 10.  XX. 1. ± X.    SELGNA AD DERAPERP GNIREENIGNE EMAN .TSUC C R LLUF X2 EMAN REMOTSUC .ON GWD REMOTSUC A 1 REBMUN REMOTSUC 50.RLAXV4ORPPA GFM 2#.ON GWD REMOTSUC LAVORPPA AQ 2 REBMUN REMOTSUC H HSINIF N/P REP CEPS LAIRETAM KCIHT "400. ,N/P REP 2 NOITAMROFNI YRATEIRPORP SNIATNOC TNEMUCOD SIHT NWO S'TI TA DEPOLEVED RO ,HCETREDAEL YB DENWO ,DESU TON YAM DNA ,ESNEPXE ETAVIRP ROF TRAP NI RO ELOHW NI DESOLCSID RO DETACILPUD RO ERUTCAFUNAM ,NGISED GNIDULCNI ESOPRUP YNA FO NOISSIMREP NETTIRW EHT TUOHTIW TNEMERUCORP RO EETNARAUG TON SEOD HCETREDAEL .HCETREDAEL .SCITSIRETCARAHC ECNAMROFREP EHT YTNARRAW B A B C EMI Enclosure Shielding Solutions 3 4 23 Elastomer CONDUCTIVE ELASTOMER EMI SHIELDING GASKETS FOR ELECTRONIC ENCLOSURES Leader Tech’s complete line of TechSIL Conductive Elastomer compounds is QPL certification by the Defense Logistics Agency. This unrivaled commitment to excellence distinguishes our company as the only MIL-SPEC approved & certified manufacturer of all 12 conductive elastomer formulations. This prestigious designation authorizes us to formulate, extrude and mold conductive elastomers to stringent MIL-DTL-83528D specifications. Leader Tech’s high-performance TechSIL gaskets are manufactured using proprietary base formulations of silicone, fluorosilicone and EPDM rubber that are embedded with highly conductive fillers including: Silver, Silver/Copper, Silver/ Aluminum, Silver/Nickel, Silver/Glass, and Nickel Coated Graphite. We offer numerous standard gasket profiles as well as unlimited variations of extruded, molded, sheet stock, and die-cut finishes. TechSIL Conductive Elastomers provide engineers with a highly customizable gasketing solution that delivers a shielding effectiveness of up to 110 dB across wide temperature variations and environmental conditions. An onsite applications engineer is also available to help formulate materials to meet your custom requirements. To learn more about this product line and our capabilities, make sure to request or download the complete TechSIL Conductive Elastomer catalog from our website. MATERIAL TYPES & PROFILES Sheet Material Extrusions Molded Die Cut Rectangle Flange Mount Round Flat Circular Washer Hollow Round O-Rings D Cross Section Solid D Hollow D Hollow P U Channel O-Rings Rectangle D Cross Section Rectangle O Cross Section Waveguide A Waveguide B Get your catalog today! Download from our website. The Only MIL-SPEC Approved & Certified Manufacturer of All 12 Conductive Elastomer Compounds! MIL-DTL-83528 Approved 24 Phone: 866.832.4364 Fax: 813.855.3291 Web: www.leadertechinc.com Specials Elastomer ORIENTED WIRE SERIES Leader Tech’s TechSIL 8000 Oriented Wire gasketing is designed for use in suppressing EMI/RFI up to 100 dB in the E-Field/up to 50 dB in the H-Field, while offering an effective environmental seal between mating surfaces. This material is comprised of monel or aluminum wire oriented perpendicular to the mating surfaces and embedded in solid or sponge silicone elastomer. The wires are crimped for additional resiliency and to optimize the mechanical performance of the gasket. The silicone based TechSIL has 700-900 wires per sq./ in. and is capable of withstanding temperatures from -80° to a maximum of 500° F (-62° to 260°C). TechSIL Oriented Wire materials are available in strip or sheet form and can easily be die cut into complex shapes or fabricated into custom frame gaskets. All TechSIL 8000 materials meet the DESC drawing 90046. TechSIL® | Sheet PART NUMBER TechSIL® | Strip HEIGHT WIDTH 8100-0005-XX 0.032* 0.81 3.00 76.20 8100-0010-XX 0.032* 0.81 4.50 114.30 8100-0015-XX 0.032* 0.81 6.00 8100-0020-XX 0.062 1.57 8100-0025-XX 0.062 8100-0030-XX PART NUMBER H W HEIGHT WIDTH 8200-0005-XX 0.062 1.57 0.093 2.36 8200-0010-XX 0.062 1.57 0.125 3.18 152.40 8200-0015-XX 0.062 1.57 0.188 4.78 3.00 76.20 8200-0020-XX 0.062 1.57 0.250 6.35 1.57 4.50 114.30 8200-0025-XX 0.062 1.57 0.375 9.53 0.062 1.57 6.00 152.40 8200-0030-XX 0.062 1.57 0.500 12.70 8100-0035-XX 0.093 2.36 3.00 76.20 8200-0035-XX 0.093 2.36 0.093 2.36 8100-0040-XX 0.093 2.36 4.50 114.30 8200-0040-XX 0.093 2.36 0.125 3.18 8100-0045-XX 0.093 2.36 6.00 152.40 8200-0045-XX 0.093 2.36 0.188 4.78 8100-0050-XX 0.125 3.18 3.00 76.20 8200-0050-XX 0.093 2.36 0.250 6.35 8100-0055-XX 0.125 3.18 4.50 114.30 8200-0055-XX 0.093 2.36 0.375 9.53 8100-0060-XX 0.125 3.18 6.00 152.40 8200-0060-XX 0.093 2.36 0.500 12.70 8100-0065-XX 0.188 4.78 3.00 76.20 8200-0065-XX 0.125 3.18 0.125 3.18 8100-0070-XX 0.188 4.78 4.50 114.30 8200-0070-XX 0.125 3.18 0.188 4.78 8100-0075-XX 0.188 4.78 6.00 152.40 8200-0075-XX 0.125 3.18 0.250 6.35 8100-0080-XX 0.250 6.35 3.00 76.20 8200-0080-XX 0.125 3.18 0.375 9.53 8100-0085-XX 0.250 6.35 4.50 114.30 8200-0085-XX 0.125 3.18 0.500 12.70 8100-0090-XX 0.250 6.35 6.00 152.40 8200-0090-XX 0.188 4.78 0.188 4.78 8200-0095-XX 0.188 4.78 0.250 6.35 8200-0100-XX 0.188 4.78 0.375 9.53 W Black = inches Blue = mm *0.032" thickness is only available in Silicone Solid 8200-0105-XX 0.188 4.78 0.500 12.70 Elastomer 8200-0110-XX 0.250 6.35 0.250 6.35 Monel Wire - 0.0045 Dia. (0.10) Per QQ-N-281 Silicone Sponge Per AMS 3195 8200-0115-XX 0.250 6.35 0.375 9.53 8200-0120-XX 0.250 6.35 0.500 12.70 -82 Monel Wire - 0.0045 Dia. (0.10) Per QQ-N-281 Silicone Solid ZZR765, Class 2B, Grade 40 -83 Aluminum Wire - 0.005 Dia. (0.13) Alloy 5056 Silicone Sponge Per AMS 3195 -84 Aluminum Wire - 0.005 Dia. (0.13) Alloy 5056 Silicone Solid ZZR765, Class 2B, Grade 40 Material Code -81 Wire Specification H Black = inches Blue = mm Part Number Example 8 All materials available with tape. The data presented is accurate and true to our knowledge. Since applications, test methods and test procedures may vary, we recommend that users perform their own tests to assure suitability for specific applications. We offer no product warranty, either expressed or implied, except we will replace any product found to be defective. X X X - 9 X X X - X X Profile Style 9 if tape required Assigned by Leader Tech Material Code EMI Enclosure Shielding Solutions 25 Knitted Wire Series TECHMESH KNITTED WIRE Leader Tech’s TechMESH Knitted Wire gaskets are designed to provide EMI/RFI Shielding of joints and seams of electronic enclosures. The unique construction of the TechMESH Knitted Wire consists of many interlocking loops that act as small springs which provide for a resilient all-metal conductive gasket with high attenuation characteristics. TechMESH provides shielding effectiveness up to 130 dB in the E-Field and up to 80 dB in the H-Field. The standard wire materials are Tin Plated Copper Clad Steel, Monel and Aluminum in cross-sections of rectangular, round, round-with-fin, and double-round-with-fin. All cross-sections are available in both ALL Mesh or Elastomer Core configurations. The TechMESH Knitted Wire gaskets are supplied on spools of 25 ft. or cut to our customers specification. Additional wire options are available upon request Round | All Mesh PART NUMBER Rectangular | All Mesh DIAMETER PART NUMBER H D 0.062 1.57 7200-0005-XX 0.062 1.57 0.062 1.57 7000-0010-XX 0.093 2.36 7200-0010-XX 0.062 1.57 0.125 3.18 7000-0015-XX 0.125 3.18 7200-0015-XX 0.062 1.57 0.250 6.35 7000-0020-XX 0.156 3.96 7200-0020-XX 0.093 2.36 0.093 2.36 7000-0025-XX 0.188 4.78 7200-0025-XX 0.093 2.36 0.125 3.18 7000-0030-XX 0.250 6.35 7200-0030-XX 0.093 2.36 0.250 6.35 7000-0035-XX 0.312 7.92 7200-0035-XX 0.125 3.18 0.125 3.18 7000-0040-XX 0.375 9.53 7200-0040-XX 0.125 3.18 0.250 6.35 7000-0055-XX 0.500 12.70 7200-0045-XX 0.125 3.18 0.500 12.70 7200-0050-XX 0.188 4.78 0.188 4.78 7200-0055-XX 0.188 4.78 0.500 12.70 7200-0060-XX 0.250 6.35 0.250 6.35 7200-0065-XX 0.250 6.35 0.500 12.70 Black = inches Blue = mm Round | All Mesh with Fin PART NUMBER H WIDTH 7000-0005-XX Tape is not available. W Black = inches Blue = mm Double Round | All Mesh with Fin DIAMETER WIDTH 7100-0005-XX 0.062 1.57 0.375 9.53 7100-0010-XX 0.062 1.57 0.500 12.70 7100-0015-XX 0.093 2.36 0.375 9.53 7100-0020-XX 0.093 2.36 0.500 12.70 7100-0025-XX 0.125 3.18 0.375 9.53 7100-0030-XX 0.125 3.18 0.500 7100-0035-XX 0.188 4.78 7100-0040-XX 0.188 4.78 7100-0045-XX 0.250 7100-0050-XX PART NUMBER DIAMETER WIDTH 7300-0005-XX 0.062 1.57 0.38 9.65 7300-0010-XX 0.062 1.57 0.50 12.70 7300-0015-XX 0.062 1.57 0.75 19.05 7300-0020-XX 0.093 2.36 0.50 12.70 7300-0025-XX 0.125 3.18 0.50 12.70 12.70 7300-0030-XX 0.125 3.18 0.75 19.05 0.500 12.70 7300-0035-XX 0.125 3.18 1.00 25.40 0.750 19.05 7300-0040-XX 0.188 4.78 0.63 16.00 6.35 0.500 12.70 7300-0045-XX 0.188 4.78 0.75 19.05 0.250 6.35 0.750 19.05 7300-0050-XX 0.188 4.78 1.00 25.40 7100-0055-XX 0.312 7.92 0.875 22.23 7300-0055-XX 0.250 6.35 0.75 19.05 7100-0060-XX 0.375 9.53 0.750 19.05 7300-0060-XX 0.250 6.35 1.00 25.40 7100-0065-XX 0.500 12.70 0.750 19.05 7300-0065-XX 0.375 9.53 1.00 25.40 D W Black = inches Blue = mm Tape is not available. 26 HEIGHT D W Black = inches Blue = mm Tape is not available. Material Code Wire Specification -71 Tin Plated Copper Clad Steel - 0.0045 Dia. (0.10) ASTM-B-520 -72 Monel Wire - 0.0045 Dia. (0.10) Per QQ-N-281 -73 Aluminum Wire - 0.005 Dia. (0.13) Alloy 5056, Per AMS-4182 Phone: 866.832.4364 Fax: 813.855.3291 Part Number Example 7 X X X - 9 X X X - X X Profile Style 9 if tape required Assigned by Leader Tech Web: www.leadertechinc.com Material Code Knitted Wire Series TECHMESH ELASTOMER CORE WIRE Material Code Wire Specification Elastomer -74 Monel Wire - 0.0045 Dia. (0.10) Per QQ-N-281B Neoprene Sponge MIL-R-6130B, Type II, Grade A -75 Monel Wire - 0.0045 Dia. (0.10) Per QQ-N-281B Silicone Sponge Per AMS 3195 -76 Monel Wire - 0.0045 Dia. (0.10) Per QQ-N-281B Silicone Solid Per ZZR765, Class 2B, Grade 40 -77 Tin Plated Copper Clad Steel 0.0045 Dia. (0.10)  ASTM-B-520 Neoprene Sponge MIL-R-6130B, Type II, Grade A -78 Tin Plated Copper Clad Steel 0.0045 Dia. (0.10)  ASTM-B-520 Silicone Sponge Per AMS 3195 -79 Tin Plated Copper Clad Steel 0.0045 Dia. (0.10)  ASTM-B-520 Silicone Solid Per ZZR765, Class 2B, Grade 40 W Solid | Elastomer Mesh PART NUMBER Rectangular | Elastomer Mesh D DIAMETER PART NUMBER HEIGHT 0.062 1.57 7500-0005-XX 0.125 3.18 0.125 3.18 7400-0010-XX 0.125 3.18 7500-0010-XX 0.125 3.18 0.188 4.78 7400-0015-XX 0.188 4.78 7500-0015-XX 0.125 3.18 0.250 6.35 7400-0020-XX 0.250 6.35 7500-0020-XX 0.188 4.78 0.188 4.78 7400-0025-XX 0.312 7.92 7500-0025-XX 0.250 6.35 0.250 6.35 7400-0030-XX 0.375 9.53 7500-0030-XX 0.250 6.35 0.375 9.53 7400-0035-XX 0.500 12.70 7500-0035-XX 0.250 6.35 0.500 12.70 7500-0040-XX 0.375 9.53 0.500 12.70 7500-0045-XX 0.500 12.70 0.500 12.70 7500-0050-XX 0.500 12.70 0.750 19.05 Black = inches Blue = mm Tape is not available. Hollow | Elastomer Mesh PART NUMBER D DIAMETER 7600-0005-XX 0.188 4.78 7600-0010-XX 0.250 6.35 P-Bulb | Elastomer Mesh PART NUMBER 7600-0015-XX 0.375 9.53 7600-0020-XX 0.500 12.70 Black = inches Blue = mm Tape is not available. Not available in -75 or -78 material H WIDTH 7400-0005-XX DIAMETER Black = inches Blue = mm D WIDTH 7700-0005-XX 0.125 3.18 0.500 12.70 7700-0010-XX 0.125 3.18 0.625 15.88 7700-0015-XX 0.125 3.18 0.750 19.05 7700-0020-XX 0.188 4.78 0.500 12.70 7700-0025-XX 0.188 4.78 0.625 15.88 7700-0030-XX 0.188 4.78 0.750 19.05 7700-0035-XX 0.250 6.35 0.500 12.70 7700-0040-XX 0.250 6.35 0.750 19.05 7700-0045-XX 0.250 6.35 1.000 25.40 7700-0050-XX 0.500 12.70 1.000 25.40 W Black = inches Blue = mm Part Number Example 7 X X X - 9 X X X - X X Mesh Style 9 if tape required Assigned by Leader Tech Material Code EMI Enclosure Shielding Solutions 27 Knitted Wire Series TECHMESH COMBO STRIP Leader Tech’s TechMesh Combo Strip & Gaskets are designed for use in applications requiring EMI/RFI shielding and environmental sealing. These materials are comprised of monel or tin plated copper clad steel knitted wire mesh which are bonded to neoprene sponge, silicone sponge or silicone solid elastomer strips. The wire mesh provides shielding performance up to 125 dB in the E-Field and up to 80 dB in the H-Field while the elastomer materials can withstand temperatures from -103° to a maximum of 500° F (-75° to 260°C). These materials have an optional pressure sensitive adhesive backing for ease of installation. The TechMesh Combo Strip & Gaskets are available in standard and custom strip configurations. Leader Tech can also fabricate custom frame gaskets to customers specification. Additional wire options or metal compression stops are available upon request. KNITWIRE SHIELDING KNIT WIRE SHIELDING ELASTOMER B D D MESH PART NUMBER HEIGHT (C) WIDTH (D) 7900-0005-XX 0.062 1.57 0.250  6.35 0.062 1.57 0.125 3.18 3.18 7900-0010-XX 0.062 1.57 0.500 12.70 0.062 1.57 0.125 3.18 0.125 3.18 7900-0015-XX 0.093 2.36 0.250  6.35 0.093 2.36 0.125 3.18 0.125 3.18 7900-0020-XX 0.093 2.36 0.500  12.70 0.093 2.36 0.125 3.18 2.36 0.125 3.18 7900-0025-XX 0.125 3.18 0.250  6.35 0.125 3.18 0.125 3.18 2.36 0.125 3.18 7900-0030-XX 0.125 3.18 0.375  9.53 0.125 3.18 0.125 3.18 0.125 3.18 0.125 3.18 7900-0035-XX 0.125 3.18 0.500 12.70 0.125 3.18 0.125 3.18 9.53 0.125 3.18 0.125 3.18 7900-0040-XX 0.188 4.78 0.250  6.35 0.188 4.78 0.125 3.18 12.70 0.125 3.18 0.125 3.18 7900-0045-XX 0.188 4.78 0.500 12.70 0.188 4.78 0.125 3.18 WIDTH (D) 7800-0005-XX 0.062 1.57 0.250  6.35 0.062 1.57 0.125 3.18 7800-0010-XX 0.062 1.57 0.375  9.53 0.062 1.57 0.125 7800-0015-XX 0.062 1.57 0.500 12.70 0.062 1.57 7800-0020-XX 0.093 2.36 0.250  6.35 0.093 2.36 7800-0025-XX 0.093 2.36 0.375  9.53 0.093 7800-0030-XX 0.093 2.36 0.500 12.70 0.093 7800-0035-XX 0.125 3.18 0.250  6.35 7800-0040-XX 0.125 3.18 0.375  7800-0045-XX 0.125 3.18 0.500 7800-0050-XX 0.125 3.18 0.750 19.05 0.125 3.18 0.125 3.18 7800-0055-XX 0.188 4.78 0.375  9.53 0.188 4.78 0.125 3.18 7800-0060-XX 0.188 4.78 0.500 12.70 0.188 4.78 0.125 3.18 7800-0065-XX 0.188 4.78 0.750 19.05 0.188 4.78 0.125 3.18 7800-0070-XX 0.250 6.35 0.500 12.70 0.250 6.35 0.125 3.18 7800-0075-XX 0.250 6.35 0.750 19.05 0.250 6.35 0.125 3.18 Black = inches Blue = mm Material Code Wire Specification Elastomer -74 Monel Wire - 0.0045 Dia. (0.10) Per QQ-N-281B Neoprene Sponge MIL-R-6130B, Type II, Grade A -75 Monel Wire - 0.0045 Dia. (0.10) Per QQ-N-281B Silicone Sponge Per AMS 3195 -76 Monel Wire - 0.0045 Dia. (0.10) Per QQ-N-281B Silicone Solid Per ZZR765, Class 2B, Grade 40 -77 Tin Plated Copper Clad Steel 0.0045 Dia. (0.10)  ASTM-B-520 Neoprene Sponge MIL-R-6130B, Type II, Grade A -78 Tin Plated Copper Clad Steel 0.0045 Dia. (0.10)  ASTM-B-520 Silicone Sponge Per AMS 3195 -79 Tin Plated Copper Clad Steel 0.0045 Dia. (0.10)  ASTM-B-520 Silicone Solid Per ZZR765, Class 2B, Grade 40 Part Number Example X - 9 X X X - X X Mesh Style 9 if tape required Assigned by Leader Tech 28 Phone: 866.832.4364 MESH WIDTH (B) HEIGHT (C) X ELASTOMER HEIGHT (A) WIDTH (B) X D Double | Mesh Combo Gasket ELASTOMER HEIGHT (A) 7 B ELASTOMER Single | Mesh Combo Gasket PART NUMBER C C C A Material Code Fax: 813.855.3291 Black = inches Blue = mm The data presented is accurate and true to our knowledge. Since applications, test methods and test procedures may vary, we recommend that users perform their own tests to assure suitability for specific applications. We offer no product warranty, either expressed or implied, except we will replace any product found to be defective. Web: www.leadertechinc.com Knitted Wire Series TECHMESH TAPE Leader Tech's TechMESH Tape has double layered strip of knitted wire mesh to provide effective EMI shielding and grounding for electric and electronic cable assemblies. This is particularly useful in applications where the need for EMI protection is determined after the cable assembly is complete and standard braided shielded cable cannot be used. The flexible structure of Leader TechMESH Tape permits it to conform to irregular surfaces and the cable contours during the wrapping process. TechMESH Tape is 0.020" (0,51mm) thick. It is available in tin plated copper clad steel (-71) or Monel (-72) width 10-12 openings per inch. Performance Advantages • Tin plated for excellent solderability • Useful in both shielding and grounding applications for static discharge • Tin plated copper clad steel wire provides greater strength and performance than other mesh tape materials • Knit loop structure provides uniform coverage minimizing wrinkles and creases • Available in other alloys and wire dimensions • Supplied in 50 ft. (15,2mm) rolls (Note: When determining quantity needed, 50% overlap is recommended) 6000 | Tape PART NUMBER WIDTH 6000-0025-XX 0.250 +/– 0.40 6.4 +/– 1.0 6000-0038-XX 0.380+/– 0.40 9.7 +/– 1.0 6000-0050-XX 0.500+/– 0.60 12.7 +/– 1.5 6000-0075-XX 0.750+/– 0.60 19.1 +/– 24.4 6000-0100-XX 1.00+/– 0.60 25.4 +/– 1.5 6000-0150-XX 1.50+/– 0.120 38.1 +/– 3.1 6000-0175-XX 1.75+/– 0.120 44.5 +/– 3.1 6000-0225-XX 2.25+/– 0.120 57. 2 +/– 4.8 Black = inches Blue = mm 6000 | Tape Part Number Explanation MATERIAL CODE WIRE SPECIFICATION -71 Tin Plated Copper Clad Steel - 0.0045 Dia. (0.10) ASTM-B-520 -72 Monel Wire - 0.0045 Dia. (0.10) Per QQ-N-281 6 0 0 0 Profile Style - X X X X - Select Size from chart above X X Material Code EMI Enclosure Shielding Solutions 29 Fabric Shielding Gaskets TECHNICAL DATA Shielding gaskets are, very simply, connectors of two opposing metallic planes which make them appear as one continuous surface, by connecting across the openings. Depending on the frequencies involved, the openings must be reduced as closely as possible to a continuous seal. Leader Tech’s unique Fabric Shielding Gasket structure is a combination of a highly conductive nickel/copper ripstop fabric and a resilient polyurethane foam core. Leader Tech’s FSG products have superior shielding properties and ensure long performance life all in a cost effective manner. Leader Tech (FSG): Fabric: Nickel/Copper RipStop Foam: Open Cell Polyurethane Compression Set: Up to 105 dB (MIL-DTL-83528C) Pressure Sensitive Adhesive: Non-conductive, high peel strength ROHS: Compliant REACH: Compliant SHELF LIFE: If stored properly, product retains its performance and properties fo 24 months from date of manufacture. (It is suggested that products are stored at room temperature conditions of 70°F (21°C) and 50% relative humidity.) Tolerances: TYPICAL LENGTH TOLERANCES TYPICAL CROSS SECTION TOLERANCES ±.010 in. (0.25 mm) for all dimensions up to 0.04 in. (1.02 mm) ±.020 in. (0.50 mm) for all dimensions above 0.04 in. (1.02 mm) (Detailed part drawings are available upon request) 0.20 to 6.00 in. 6.01 to 18.00 in. 18.01 to 48.00 in. (5 - 152 mm) (153 - 457 mm) (458 - 1219 mm) *Other sizes available. Consult factory. Shelf-life is based on the pressure sensitive adhesive which is 24 months 30 Phone: 866.832.4364 Fax: 813.855.3291 Web: www.leadertechinc.com ±.03 in. ±.06 in. ±.08 in. (0.76 mm) (1.52 mm) (2.03 mm) Fabric Shielding Gaskets FSG FOR ELECTRONIC ENCLOSURES PART NUMBER Bell Shape W Square Shape HEIGHT WIDTH LENGTH PART NUMBER H HEIGHT WIDTH SG080080S 0.080 2.03 0.080 2.03 48 1219 SG070180B 0.070 1.78 0.180 4.57 48 1219 SG118118S 0.118 3.00 0.118 3.00 48 1219 SG090315B 0.090 2.29 0.315 8.00 48 1219 SG138138S 0.138 3.54 0.138 3.54 48 1219 SG098299B 0.098 2.49 0.299 7.59 48 1219 SG160160S 0.160 4.06 0.160 4.06 48 1219 SG100300B 0.100 2.54 0.300 7.62 48 1219 SG200200S 0.200 5.08 0.200 5.08 48 1219 SG130256B 0.130 3.30 0.256 6.50 48 1219 SG250250S 0.250 6.35 0.250 6.35 48 1219 SG157500B 0.157 3.99 0.500 12.70 48 1219 SG315315S 0.315 8.00 0.315 8.00 48 1219 SG200500B 0.200 5.08 0.500 12.70 48 1219 SG354354S 0.354 8.99 0.354 8.99 48 1219 SG375375S 0.375 9.52 0.375 9.52 48 1219 SG472472S 0.472 11.99 0.472 11.99 48 1219 SG500500S 0.500 12.70 0.500 12.70 48 1219 SG512512S 0.512 13.00 0.512 13.00 48 1219 SG551551S 0.551 14.00 0.551 14.00 48 1219 SG575575S 0.575 14.60 0.575 14.60 48 1219 SG157245T 0.157 3.99 0.245 6.22 48 1219 SG591591S 0.591 15.01 0.591 15.01 48 1219 SG175244T 0.175 4.44 0.244 6.20 48 1219 SG670670S 0.670 17.02 0.670 17.02 48 1219 SG244244T 0.244 6.20 0.244 6.20 48 1219 SG787787S 0.787 19.99 0.787 19.99 48 1219 WIDTH LENGTH SG196325C 0.196 4.98 0.325 8.25 48 1219 SG196535C 0.196 4.98 0.535 13.59 48 1219 SG240415C 0.240 6.10 0.415 10.54 48 1219 SG252280C 0.252 6.40 0.280 7.11 48 1219 SG315315C 0.315 8.00 0.315 8.00 48 1219 SG347685C 0.347 8.81 0.685 17.40 48 1219 SG380420C 0.380 9.65 0.420 10.67 48 1219 SG385420C 0.385 9.78 0.420 10.67 48 1219 SG465420C 0.465 11.811 0.420 10.67 48 1219 SG550590C 0.550 13.97 0.590 14.99 48 1219 SG675580C 0.675 17.14 0.580 14.73 48 1219 SG675600C 0.675 17.14 0.600 15.24 48 1219 Black = inches Blue = mm L PART NUMBER SG152235T Black = inches Blue = mm L1 HEIGHT W T-Shape C-Shape PART NUMBER H H LENGTH 0.152 3.86 WIDTH 0.235 H LENGTH 5.97 48 1219 W Black = inches Blue = mm Typical Performance H L2 W HEIGHT Shielding Effectiveness 80 - 115dB Frequency Range 20Mhz - 10GHz Dura-Layer Construction Polyurethane foam core with high-performance fabric Recommended Compression 30-50% of gasket height Black = inches Blue = mm Typical Cross Section Tolerances ±.010 in. ±.020 in. (0.25 mm) f or all dimensions up to (0.50 mm) for all dimensions above 0.04 in. 0.04 in. (1.02 mm) (1.02 mm) Detailed part drawings are available upon request. Part Number Explanation SG X X X X X X X Height Width Profile - X X . X X Typical Length Tolerances 0.20 to 6.00 in. 6.01 to 18.00 in. (5 - 152 mm) (153 - 457 mm) ±.03 in. ±.06 in. (0.76 mm) (1.52 mm) 18.01 to 48.00 in. (458 - 1219 mm) ±.08 in. (2.03 mm) #Start Length *Example: SG125250D-22.50: Gasket .125 tall, .250 wide, D-Shape and 22.5” long EMI Enclosure Shielding Solutions 31 Fabric Shielding Gaskets FSG FOR ELECTRONIC ENCLOSURES CONT. Rectangle Shape PART NUMBER Rectangle Shape cont. W HEIGHT WIDTH LENGTH H PART NUMBER HEIGHT WIDTH LENGTH SG020157R 0.020 0.51 0.157 3.99 48 1219 SG157590R 0.157 3.99 0.590 14.99 48 1219 SG020197R 0.020 0.51 0.197 5.00 48 1219 SG160354R 0.160 4.06 0.354 8.99 48 1219 SG020275R 0.020 0.51 0.275 6.98 48 1219 SG250375R 0.250 6.35 0.375 9.52 48 1219 SG0391181R 0.039 0.99 1.181 30.00 48 1219 SG250500R 0.250 6.35 0.500 12.70 48 1219 SG039118R 0.039 0.99 0.118 3.00 48 1219 SG250600R 0.250 6.35 0.600 15.24 48 1219 SG040125R 0.040 1.02 0.125 3.17 48 1219 SG187375R 0.187 4.75 0.375 9.52 48 1219 SG0401850R 0.040 1.02 1.850 46.99 48 1219 SG187750R 0.187 4.75 0.750 19.05 48 1219 SG040200R 0.040 1.02 0.200 5.08 48 1219 SG197315R 0.197 5.00 0.315 8.00 48 1219 SG040275R 0.040 1.02 0.275 6.98 48 1219 SG200200R 0.200 5.08 0.200 5.08 48 1219 SG040395R 0.040 1.02 0.395 10.03 48 1219 SG250250R 0.250 6.35 0.250 6.35 48 1219 SG040590R 0.040 1.02 0.590 14.99 48 1219 SG375500R 0.375 9.52 0.500 12.70 48 1219 SG040710R 0.040 1.02 0.710 18.03 48 1219 SG500500R 0.500 12.70 0.500 12.70 48 1219 SG050090R 0.050 1.27 0.090 2.29 48 1219 SG500750R 0.500 12.70 0.750 19.05 48 1219 SG051157R 0.051 1.30 0.157 3.99 48 1219 SG670670R 0.670 17.02 0.670 17.02 48 1219 SG051394R 0.051 1.30 0.394 10.01 48 1219 SG787787R 0.787 19.99 0.787 19.99 48 1219 SG060100R 0.060 1.52 0.100 2.54 48 1219 SG060125R 0.060 1.52 0.125 3.17 48 1219 SG060130R 0.060 1.52 0.130 3.30 48 1219 Knife Edge SG060160R 0.060 1.52 0.160 4.06 48 1219 PART NUMBER SG060200R 0.060 1.52 0.200 5.08 48 1219 SG060280R 0.060 1.52 0.280 7.11 48 1219 SG060394R 0.060 1.52 0.394 10.01 48 1219 SG060395R 0.060 1.52 0.395 10.03 48 1219 SG060750R 0.060 1.52 0.750 19.05 48 1219 SG079157R 0.079 2.00 0.157 3.99 48 1219 SG0801000R 0.080 2.03 1.000 25.40 48 1219 SG080100R 0.080 2.03 0.100 2.54 48 1219 SG080160R 0.080 2.03 0.160 4.06 48 1219 SG080200R 0.080 2.03 0.200 5.08 48 1219 SG080500R 0.080 2.03 0.500 12.70 48 1219 SG080750R 0.080 2.03 0.750 19.05 48 1219 SG100200R 0.100 2.54 0.200 5.08 48 1219 SG118118R 0.118 3.00 0.118 3.00 48 1219 SG120155R 0.120 3.05 0.155 3.94 48 1219 SG125250R 0.125 3.17 0.250 6.35 48 1219 SG125375R 0.125 3.17 0.375 9.52 48 1219 SG140250R 0.140 3.56 0.250 6.35 48 1219 HEIGHT WIDTH 0.070 1.78 0.340 8.64 48 SG106315K 0.106 2.69 0.315 8.00 48 1219 SG106445K 0.106 2.69 0.445 11.30 48 1219 SG106455K 0.106 2.69 0.455 11.56 48 1219 SG-160600K 0.106 2.69 0.600 15.24 48 1219 SG187236K 0.187 4.75 0.236 5.99 48 1219 SG250750K 0.250 6.35 0.750 19.05 48 1219 SG312707K 0.312 7.92 0.270 6.86 48 1219 SG350750K 0.350 8.89 0.750 19.05 48 1219 DIAMETER LENGTH SG100100Z 0.100 2.54 48 1219 SG125125Z 0.125 3.17 48 1219 SG160160Z 0.160 4.06 48 1219 SG200200Z 0.200 5.08 48 1219 W 1219 Round Shape Black = inches Blue = mm H LENGTH SG070340K PART NUMBER Black = inches Blue = mm Black = inches Blue = mm D Black = inches Blue = mm Tape is not available. Typical Cross Section Tolerances ±.010 in. (0.25 mm) f or all dimensions up to 0.04 in. (1.02 mm) ±.020 in. (0.50 mm) for all dimensions above 0.04 in. (1.02 mm) Detailed part drawings are available upon request. Part Number Explanation SG X X X X X X #Start Height Width X - X X . X X Typical Length Tolerances 32 0.20 to 6.00 in. (5 - 152 mm) ±.03 in. (0.76 mm) 6.01 to 18.00 in. (153 - 457 mm) ±.06 in. (1.52 mm) 18.01 to 48.00 in. (458 - 1219 mm) ±.08 in. (2.03 mm) Phone: 866.832.4364 Fax: 813.855.3291 Profile Length *Example: SG125250D-22.50: Gasket .125 tall, .250 wide, D-Shape and 22.5” long Web: www.leadertechinc.com Fabric Shielding Gaskets FSG FOR ELECTRONIC ENCLOSURES CONT. D-Shape W PART NUMBER HEIGHT WIDTH LENGTH W W Oval Shape H PART NUMBER HEIGHT WIDTH H H LENGTH SG040150D 0.040 1.02 0.150 3.81 48 1219 SG140200E 0.140 3.56 0.200 5.08 48 1219 SG040200D 0.040 1.02 0.200 5.08 48 1219 SG160790E 0.160 4.06 0.790 20.07 48 1219 SG050140D 0.050 1.27 0.140 3.56 48 1219 SG050250D 0.050 1.27 0.250 6.35 48 1219 SG060125D 0.060 1.52 0.125 3.17 48 1219 SG060150D 0.060 1.52 0.150 3.81 48 1219 SG060250D 0.060 1.52 0.250 6.35 48 1219 SG098500TR 0.098 2.49 0.500 12.70 48 1219 SG070135D 0.070 1.78 0.135 3.43 48 1219 SG090394TR 0.090 2.29 0.394 10.01 48 1219 SG70180D 0.070 1.78 0.180 4.57 48 1219 SG100400TR 0.100 2.54 0.400 10.16 48 1219 SG080080D 0.080 2.03 0.080 2.03 48 1219 SG140390TR 0.140 3.56 0.390 9.91 48 1219 SG080160D 0.080 2.03 0.160 4.06 48 1219 SG080394D 0.080 2.03 0.394 10.01 48 1219 SG090090D 0.090 2.29 0.090 2.29 48 1219 SG090150D 0.090 2.29 0.150 3.81 48 1219 SG094200D 0.094 2.39 0.200 5.08 48 1219 SG100300D 0.100 2.54 0.300 7.62 48 SG110180D 0.110 2.79 0.180 4.57 SG120150D 0.120 3.05 0.150 SG120250D 0.120 3.05 SG120360D 0.120 SG120475D Black = inches Blue = mm Triangle Shape PART NUMBER W W HEIGHT WIDTH LENGTH H H Black = inches Blue = mm P-Shape PART NUMBER HEIGHT WIDTH L1 LENGTH SG016195P 0.016 0.41 0.195 4.95 48 1219 1219 SG060275P 0.060 1.52 0.275 6.98 48 1219 48 1219 SG080200P 0.080 2.03 0.200 5.08 48 1219 3.81 48 1219 SG125750P 0.125 3.17 0.750 19.05 48 1219 0.250 6.35 48 1219 SG130520P 0.130 3.30 0.520 13.20 48 1219 3.05 0.360 9.14 48 1219 SG145520P 0.145 3.68 0.520 13.21 48 1219 0.120 3.05 0.475 12.06 48 1219 SG200395P 0.200 5.08 0.395 10.03 48 1219 SG125187D 0.125 3.17 0.187 4.75 48 1219 SG125250D 0.125 3.17 0.250 6.35 48 1219 SG130190D 0.130 3.30 0.190 4.83 48 1219 SG140250D 0.140 3.56 0.250 6.35 48 1219 SG150250D 0.150 3.81 0.250 6.35 48 1219 SG160240D 0.160 4.06 0.240 6.10 48 1219 SG180400D 0.180 4.57 0.400 10.16 48 1219 SG187250D 0.187 4.75 0.250 6.35 48 1219 SG195260D 0.195 4.95 0.260 6.60 48 1219 SG236236D 0.236 5.99 0.236 5.99 48 1219 SG250375D 0.250 6.35 0.375 9.52 48 1219 SG295355D 0.295 7.49 0.355 9.02 48 1219 SG315630D 0.315 8.00 0.630 16.00 48 1219 SG375500D 0.375 9.52 0.500 12.70 48 1219 SG430500D 0.430 10.92 0.500 12.70 48 1219 SG562709D 0.562 14.27 0.709 18.00 48 1219 SG670670D 0.670 17.02 0.670 17.02 48 1219 H H L1 W W Black = inches Blue = mm Typical Performance Shielding Effectiveness 80 - 115dB Frequency Range 20Mhz - 10GHz Dura-Layer Construction Polyurethane foam core with high-performance fabric Recommended Compression 30-50% of gasket height Black = inches Blue = mm Typical Cross Section Tolerances ±.010 in. (0.25 mm) f or all dimensions up to 0.04 in. (1.02 mm) ±.020 in. (0.50 mm) for all dimensions above 0.04 in. (1.02 mm) Detailed part drawings are available upon request. Part Number Explanation SG X X X X X X X #Start Height Width Profile - X X . X X Typical Length Tolerances 0.20 to 6.00 in. (5 - 152 mm) ±.03 in. (0.76 mm) 6.01 to 18.00 in. (153 - 457 mm) ±.06 in. (1.52 mm) 18.01 to 48.00 in. (458 - 1219 mm) ±.08 in. (2.03 mm) Length *Example: SG125250D-22.50: Gasket .125 tall, .250 wide, D-Shape and 22.5” long EMI Enclosure Shielding Solutions 33 Fabric Shielding Gaskets FSG FOR ELECTRONIC ENCLOSURES CONT. D-SUB MINIATURE very conformable to irregular surfaces. • Eliminates any gap problem between connector and I/O surface plates. Compresses from .100" to .025" (2.5 to 0.6mm) • Outside conductive surface is metalized CuNi fabric • 9, 15, 25, 37 and 50 pin connector gaskets available in stock • Available with adhesive tape. Please consult factory for ordering information • Consult factory for custom profiles, thicknesses and sizes available • For metal option - see page 22 A B C D G E F H D-Sub Miniature PART NUMBER TYPE A B C D E F G H SG140009DS 9 Pin 1.40 35.56 0.98 24.89 0.78 19.81 0.44 11.18 0.22 5.59 0.7 17.78 0.1 2.54 0.15 3.81 SG175015DS 15 Pin 1.75 44.45 1.31 33.27 1.11 28.19 0.44 11.18 0.22 5.59 0.7 17.78 0.1 2.54 0.15 3.81 SG228025DS 25 Pin 2.28 57.91 1.85 46.99 1.65 41.91 0.44 11.18 0.22 5.59 0.7 17.78 0.1 2.54 0.15 3.81 SG293037DS 37 Pin 2.93 74.42 2.50 63.54 2.29 58.17 0.44 11.18 0.22 5.59 0.7 17.78 0.1 2.54 0.15 3.81 SG284050DS 50 Pin 2.84 72.14 2.41 61.21 2.20 55.88 0.55 13.97 0.28 7.11 0.8 20.32 0.1 2.54 0.15 3.81 Typical Performance Shielding Effectiveness 80 - 115dB Frequency Range 20Mhz - 10GHz Dura-Layer Construction Polyurethane foam core with high-performance fabric Recommended Compression 30-50% of gasket height Typical Cross Section Tolerances ±.010 in. ±.020 in. (0.25 mm) f or all dimensions up to 0.04 in. (1.02 mm) (0.50 mm) for all dimensions above 0.04 in. Detailed part drawings are available upon request. (1.02 mm) Typical Length Tolerances 34 0.20 to 6.00 in. 6.01 to 18.00 in. (5 - 152 mm) (153 - 457 mm) ±.03 in. ±.06 in. (0.76 mm) (1.52 mm) 18.01 to 48.00 in. (458 - 1219 mm) ±.08 in. (2.03 mm) Phone: 866.832.4364 Fax: 813.855.3291 Web: www.leadertechinc.com Black = inches Blue = mm Fabrics & Tapes SHIELDING FABRICS & CONDUCTIVE TAPES Shielding Fabrics Shielding effectiveness is determined by a combination of the reflection and absorption of RF signals. Absorption depends on the thickness of the shield material. However, reflection occurs at the shield surface and its effectiveness is independent of thickness. Reflection is the determining factor for all high frequency signal attenuation. (Note: When using these materials for conductive shielding gaskets, conductivity is the determinant.) Maximum reflection occurs with the highest conductivity materials – the best being copper, nickel and combinations of both. Options • All materials are available in non-adhesive, hot melt or conductive adhesive backing • Standard sheets are 41” x 36” (1041 x 914 mm) • Longer lengths can be custom ordered – please consult factory for information • Full rolls are 325’ (99M) long – please consult factory for ordering information. Note: conductive adhesive versions are 164’ (50M) long Applications Bonding or laminating to complex geometric shapes with optional hot melt or conductive adhesive. • Large surface coverage with minimal seams due to 41” material width • ESD/RFI-EMI shielding attenuation > 70dB up to 10 GHz for CuNi type • Seal enclosure panels and frames, seams or joints • Use for architectural shielding or shielded room wall and ceiling finishing Shielding Fabrics PART NUMBER W/HOT MELT W/CONDUCTIVE W/O ADHESIVE ADHESIVE ADHESIVE SF005PCN SF005PCN-HM SF005PCN-CA Conductive CuNi Cloth 41 1041 36 914 SURFACE THICKNESS RESISTIVITY 0.003 0.076 .005 ohm/mm2 SF030PCU SF030PCU-HM SF030PCU-CA Conductive Cu Cloth 41 1041 36 914 0.003 0.076 SF050PNI SF050PNI-HM SF050PNI-CA Conductive Ni Cloth 41 1041 36 914 0.004 0.102 DESCRIPTION WIDTH LENGTH 500KHZ 100MHZ 300MHZ 79dB 81dB 86dB 1GHZ 82dB .035 ohm/mm2 60dB 67dB 65dB 62dB .050 ohm/mm2 60dB 72dB 67dB 63dB Black = inches Blue = mm Fabric Shielding Tapes Applications Cable shielding, enclosure seams, shielded room joints, PCB component shields, irregular surface/component shields, alternative to custom die-cut shielding gaskets or sections. • Service Temperature: -40°F to 212°F (-40°C to 100°C) • Adhesion: (peel) 50 oz/in. (54N/100mm) • Material: CuNi metalized fabric and conductive acrylic adhesive backing w/release liner Fabric Shielding Tapes PART NUMBER RESISTIVITY IMPEDANCE ST005PCN25 0.25 WIDTH 6.35 THICKNESS 0.005 0.13 85.0 ft. rolls LENGTH 25.0m 0.03 - 0.05 ohms/inch 69dB@100MHz ST005PCN50 0.50 12.70 0.005 0.13 85.0 ft. rolls 25.0m 0.03 - 0.05 ohms/inch 69dB@100MHz ST005PCN75 0.75 19.05 0.005 0.13 85.0 ft. rolls 25.0m 0.03 - 0.05 ohms/inch 69dB@100MHz ST005PCN100 1.00 25.40 0.005 0.13 85.0 ft. rolls 25.0m 0.03 - 0.05 ohms/inch 69dB@100MHz ST005PCN200 2.00 50.80 0.005 0.13 85.0 ft. rolls 25.0m 0.03 - 0.05 ohms/inch 69dB@100MHz Black = inches Blue = mm EMI Enclosure Shielding Solutions 35 Conductive Foam Shielding Material CFS CONDUCTIVE FOAM SHIELDING MATERIAL FOR DIE-CUT GASKETS CFS Conductive Foam Shielding Material consists of resilient Nickel-Copper polyurethane foam which is layered between two pieces of conductive polyester fabric. This CFS Conductive Foam is ideal for applications that require low compression forces but excellent shielding effectiveness. Performance Operating Temperatures: -40F – +156F (-40C - +70C) Surface Resistivity: T E>T D D 4. Recommend assign datum to hole C/L and not to edge of gasket. Tolerance Range Sample Dim. 0 - 4” 4.1 - 12” 12.1 - 24” Length/Width FEATURE TYPE A, B, W +/- .020 +/- .030 +/- .040 Hole Location C, F +/- .010 +/- .015 +/- .020 Hole Diameter D +/- .020 +/- .030 +/- .040 EMI Enclosure Shielding Solutions 37 ENGINEERS NOTES _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ ________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ _________________________________________________________________________________________________ 38 Phone: 866.832.4364 Fax: 813.855.3291 Web: www.leadertechinc.com PRODUCTS AND LITERATURE We’ve Got You Covered Reliable Board, Enclosure and Cable Shielding Solutions Leader Tech is a world-leading innovator and US-based manufacturer of EMI shielding products for circuit boards, enclosures and cables. In addition to our best selling standard, modified standard and custom CBS shields, Leader Tech offers an expansive line of beryllium copper fingerstock gaskets, conductive elastomers, advanced RF absorber materials and EMI/RFI ferrites. CBS Circuit Board Shielding Catalog FerriShield Ferrite Catalog TechSIL Conductive Elastomer Catalog EA EMI Microwave Absorbers Catalog LeaderTech Shielding Products Board Level Shielding • Standard and Multi-Cavity CBS • Modified Standard Options • Custom Circuit Board Shields FerriShield Ferrites Enclosure Shielding • Snap-On Bisected & Solid Bead Ferrites • Round & Flat Styles for Cables, Wires and Flex Circuits • Low, High, Microwave and Wideband Frequency-Specific Material EMI Problem? • • • • • • BeCu Fingerstock Gaskets TechSIL 5000 Conductive Elastomers Conductive Fabric Shielding Gaskets TechSIL 8000 Oriented Wire Gaskets TechMESH Knitted Wire Gaskets TechMESH Combo Strip & Gaskets Our sales engineers are waiting for your call: 866-TECH-EMI (866-832-4364) Visit our web site today to browse our complete product line, download literature and find your local sales engineer or sales representative! www.leadertechinc.com EMI Enclosure Shielding Solutions 39 0421
PM28B3375 价格&库存
很抱歉,暂时无法提供与“PM28B3375”相匹配的价格&库存,您可以联系我们找货
