MTCDP-H5-1.0
MTCDP-H5-1.0
    MULTI-TECHSYSTEMS
    Module
    ROUTER 3G HSPA ETH
MTCDP-H5-1.0 数据手册
MultiConnect® OCG-D Open Communications Gateways - Device DEVELOPMENT HARDWARE The MultiConnect® OCG-D open communications gateways with ·· Application-ready hardware platform ·· Includes GPS and cellular modem CoreCDP® comprise an open Linux development environment ·· Multiple interfaces available (serial, USB, Ethernet) and a fully certified hardware offering that includes multiple ·· FCC, IC, UL, PTCRB and R&TTE certified ·· 36-pin GPIO interface CORECDP SOFTWARE interfaces and internal peripherals in one application-ready ·· Custom Linux distribution end user solution. Applications that require device networking ·· Provides complete Linux build environment capability can now be embedded directly onto select MultiTech ·· Cross-compile thousands of open source software packages hardware, providing a flexible, quick and cost-effective way to bring your solution to market. ·· Create custom applications in a short period of time SUPPORT ·· Advanced developer support available ·· Established developer community available at www.multitech.net ·· Two-year warranty DEPLOYMENT MODELS ·· Non-cellular, cellular-only and cellular/ GPS models available ·· Standard and customized deployment models available ·· FCC, IC, UL, PTCRB and R&TTE certified BENEFITS ·· Linux-based open source software ·· Proven hardware for the development and deployment of custom applications ·· Cost-effective alternative to custom manufacturing ·· Comprehensive service and developer support 1 Datasheet • www.multitech.com/ocg-d SPECIFICATIONS Model MTCDP-H5 MTCDP-EV3 MTCDP-E1 MTCDP-G2 Performance HSPA+ EV-DO CDMA2000 1xRTT EDGE: E-GPRS Class 12 GPRS: Class 10 GPRS Class 10 Frequency Bands (MHz) Hepta-band: 800/850/900/AWS 1700/1900/2100 Triple-band: 2100/1900/850 with Rx diversity Dual-band: 800/1900 CDMA; Up to 3.1 Mbps downlink/Up to 1.8Mbps uplink Quad-band: GSM/ GPRS/EDGE 850/900/1800/1900 Quad-band: GSM 850/900/1800/1900 -22° to +140° F (-30° to +60° C)* -40° to +167° F (-40° to +75° C)* -31° to +167° F (-35° to +75° C)* -40° to +185° F (-40° to +85° C)* Environmental† Operating Temperature* * UL Listed @ 104° F (40° C), limited by power supply. UL Certification does not apply or extend to an ambient above 104° F (40° C) and has not been evaluated by UL for ambient greater than 104° F (40° C). Storage Temperature -40° to +185° F (-40° to +85° C) Humidity 20% to 90% RH, noncondensing Physical Description Dimensions (L x W x H) 2.8" x 7.0" x 1.2" (7.1 cm x 17.8 cm x 3.0 cm) Weight 11.5 oz (326 g) Certifications EMC Compliance† FCC Class B, EN55022, EN55024 FCC Class B Radio Compliance FCC Part 22, 24, RSS132, 133, EN301 489-1, EN489-3 (-GP only), EN301 489-7, EN301 511, AS/ACIF S042.1, S042.3 FCC Part 22, 24, RSS132, 133 Safety† UL60950-1, cUL60950-1, IEC60950-1 UL60950-1, cUL60950-1, IEC60950-1 Network PTCRB N/A FCC Class B, EN55022, EN55024 FCC Part 22, 24, RSS132,133, EN301 489-1, EN489-3 (-GP only), EN301 489-7, EN301 511, AS/ACIF S042.1, S042.3 UL60950-1, cUL60950-1, IEC60950-1 UL60950-1, cUL60950-1, IEC60950-1, AS/NZS60950-1 PTCRB † Specifications for non-cellular versions. CORECDP SOFTWARE SPECIFICATIONS (Version 2.3.3) Linux Kernel 2.6.35.14 Utilizes OpenEmbedded framework Tested with the following Linux OS: Ubuntu 10.04 to 12.10, Debian 6 and 7 openSUSE 11.4 - 12.2, Fedora Core 12 – 17, CentOS 6.5 Networking: PPP, iptables Drivers to support all peripherals included on the platform hardware Database: sqlite3 Notable Software Versions: Python 2.6.6, JamVM 1.5.4 (Java), Perl 5.10.1. Ruby 1.9.3-p392, PHP 5.3.6 2 A complete list of software versions is available at www.multitech.net Web Server: lighttpd Remote shell: SSH Network file system: samba Security: OpenSSL Software Development Kit: MultiConnect SDK HARDWARE SPECIFICATIONS HIGHLIGHTS Processor & Memory Custom Application Development and Deployment 400 MHz ARM9 CPU 256MB NAND flash 64MB SDRAM 2GB industrial grade SD Flash Card (included w/ development models) Internal Peripherals RTC (Real Time Clock) Dedicated GPS receiver Cellular modem Debug 3 pin serial console port Temperature sensor Linux-Based Open Source Connections LAN: RJ-45, 10/100BaseT RS-232 Data: DB-9 female, 921.6K bps max serial speed GSM/GPS Antenna: 50 ohm SMA female Power: 2.5mm miniature screw SIM: Standard 1.8V & 3V SIM receptacle (mini SIM) GPIO: 36-pin Molex connection The MultiConnect OCG-D uses the OpenEmbedded framework as the base to provide a custom Linux distribution, known as CoreCDP. This allows developers to cross-compile thousands of open source software packages and to create custom applications in a very short period of time. In many cases, existing applications can easily be run with little or no modification. SD Memory Flash Card: SD memory card slot Carrier Approved USB Host: USB 2.0 Full Speed (12 Mbps) Host Connector USB Device: USB 2.0 Full Speed (12 Mbps) mini-B device connector GPIO Functions:* Pins 1-9: General Purpose Input Pins 30-31: Debug Pins 10-14: Analog Input Pins 33-34: I2C Pins 15-24: General Purpose Output Pins 25-29: SPI Pin 32: GPS PPS Pin 35: No Connect Pin 36: Ground (SPI, I2C, Serial) * For more specifications on GPIO functionality, visit www.multitech.net Interfaces General Purpose LEDs: Power, Cellular Link Status, Ethernet Link, & Speed Programmable LEDs: 5 user-defined, applicationspecific LEDs Short Message Services SMS Text & PDU Point-to-Point (MO/MT) Acquisition: Hot start 1 second; cold start 29 seconds avg. Power Requirements Input Power: 9 to 32VDC 3 All MultiConnect OCG-D developer kits and deployment models are PTCRB approved, relieving customers the burden and expense of obtaining these approvals independently. This also provides a faster time-to-market and improved return on investment. Multiple Interface Options The MultiConnect OCG-D provides the broadest range of interface options, including serial, USB host, and Ethernet, giving customers seamless connectivity to their applications. GPIO The 36-pin general purpose input/output connection, which includes SPI, I2C, serial, ADC, and GPS connections, provides multiple ways of interfacing with any application. Proof of Concept GPS Position: 2.5 meters The MultiConnect OCG-D offers customers the opportunity to develop and deploy custom applications on the same product platform. Developer kits include all the hardware, cables and accessories required to develop unique applications. Once complete, deployment models are available for the sale and distribution of the solution within a proven and approved hardware platform. Sensitivity: Tracking -161 dBm Protocol: NMEA-0183 V3.01, GGA, GLL, GSA, GSV, RMC, VTG Customers planning their own internal custom developments can use the MultiConnect OCG-D to create beta units and prototypes for use in voice of customer and proof of concept activities. These models can be generated quickly and with little additional expense. The input from these activities can improve the feature set of the customer’s final product. ORDERING INFORMATION SERVICES & WARRANTY Developer Kits Developer kits include: Modem with GPS receiver, universal power supply, GSM/GPS antenna, GPIO cable, serial debug cable, Ethernet cable, RS-232 cable, compact flash, USB cables, DVD, and screwdriver. Product Description MTCDP-H5-GP-DK-1.0 3G HSPA+ Developer Kit Region Global MTCDP-EV3-GP-N3-DK-1.0 3G EV-DO Developer Kit (Verizon Wireless) MTCDP-EV3-GP-N16-DK-1.0 3G EV-DO Developer Kit (Aeris Communications) US MTCDP-E1-GP-DK-1.0 2.5G EDGE Developer Kit Global MTCDP-G2-GP-DK-1.0 2G GPRS Developer Kit Global MTCDP-GP-DK-1.0 Non-Cellular Developer Kit Global US Deployment Models (includes GPS receiver)* Deployment models are modem only. All accessories are sold separately. Product Description MTCDP-H5-GP-1.0 3G HSPA+ Deployment Model Region Global MTCDP-EV3-GP-N3-1.0 3G EV-DO Deployment Model (Verizon Wireless) US MTCDP-EV3-GP-N16-1.0 3G EV-DO Deployment Model (Aeris Communications) MTCDP-E1-GP-1.0 2.5G EDGE Deployment Model Global MTCDP-G2-GP-1.0 2G GPRS Deployment Model Global MTCDP-GP-1.0 Non-Cellular Deployment Model Global US Deployment Models* MultiTech’s comprehensive Support Services programs offer a full array of options to suit your specific needs. These services are aimed at protecting your investment, extending the life of your solution or product, and reducing total cost of ownership. Our seasoned technical experts, with an average tenure of more than 10 years, can walk you through smooth installations, troubleshoot issues and help you with configurations. INSTALLATION SUPPORT MultiTech’s Installation Support Service delivers priority service with the ability to work one-on-one with an experienced MultiTech technical support engineer, to guide you through the installation process for our products. Deployment models are modem only. All accessories are sold separately. Product Description MTCDP-H5-1.0 3G HSPA+ Deployment Model Region Global MTCDP-EV3-N3-1.0 3G EV-DO Deployment Model (Verizon Wireless) US MTCDP-EV3-N16-1.0 3G EV-DO Deployment Model (Aeris Communications) US MTCDP-E1-1.0 2.5G EDGE Deployment Model Global MTCDP-G2-1.0 2G GPRS Deployment Model Global MTCDP-1.0 Non-Cellular Deployment Model Global ILS deviceWISE® Models This OCG product variant comes ready to integrate directly with the deviceWISE Application Enablement Platform (AEP). The deviceWISE AEP provides seamless connectivity and integration across any remote device, any network and any enterprise application in the back office – without any programming. The doit-yourself platform reduces the risk, time-to-market, complexity and cost of deploying solutions for remote monitoring and control, industrial automation, asset tracking and field service operations. See www.devicewise.com for more information. Product Description MTCDP-H5-1.0-DW 3G HSPA+ deviceWISE Deployment Model Region Global MTCDP-H5-GP-1.0-DW 3G HSPA+ deviceWISE Deployment Model w/ GPS Global MTCDP-H5-GP-DK-1.0-DW 3G HSPA+ deviceWISE Developer Kit Global MTCDP-EV3-N3-1.0-DW 3G EV-DO deviceWISE Deployment Model (Verizon Wireless) MTCDP-EV3-GP-N3-1.0-DW 3G EV-DO deviceWISE Deployment Model w/ GPS (Verizon Wireless) MTCDP-EV3-GP-N3-DK-1.0-DW 3G EV-DO deviceWISE Developer Kit (Verizon Wireless) Accessories US GPIO Cable and Break-out Board 36-pin, General Purpose Input/Output Cable (open ended) PS-9VCB-LBC-U-Global 100 - 240V 9V-1.7A changeable blade power supply with three interchangeable blades (U.S., Euro, UK) ANGSM-GPS-1MM GSM/GPS Combination Antenna, 9.8 feet (3 meters) CA-CDP-DEBUG 3-Pin, Serial Debug Cable, 6 feet (1.8 meters) CA9-9-D RS-232 Cable, DB9F-DB9M, 6 feet (1.8 meters) CA-RJ-45 RJ45 (CAT5E, 10/100 Mbps) Cable, 6 feet (1.8 meters) CA-USB USB A/B Cable, 4.9 feet (1.5 meters) CA-USB-A-MINI-B USB A-to-Mini-B Cable, 3.9 feet (1.2 meters) 4 For additional information on Support Services as well as other service offerings, please contact your MultiTech representative or visit www.multitech.com/support.go US CA-CDP-GPIO Visit www.multitech.com/solplat/celldev.go for additional product offerings and information. At MultiTech, we’re committed to providing you personalized attention and quality service while providing you a quick response to your product support needs. We have several options of support for you to choose from. USA MTOCG-BOB-DK * Custom deployment options available. Contact your MultiTech representative for details. TECHNICAL SUPPORT SERVICES World Headquarters Multi-Tech Systems, Inc. 2205 Woodale Drive Mounds View, MN 55112 U.S.A. Tel: 763-785-3500 Toll-Free: 800-328-9717 Email: sales@multitech.com www.multitech.com EMEA Headquarters Multi-Tech Systems (EMEA) Strata House 264-270 Bath Road Harlington UB3 5JJ United Kingdom Tel: +(44) 118 959 7774 Email: sales@multitech.co.uk www.multitech.co.uk
MTCDP-H5-1.0 价格&库存
很抱歉,暂时无法提供与“MTCDP-H5-1.0”相匹配的价格&库存,您可以联系我们找货
