Description:
As required by ANSI/ESD S20.20 Packaging standard ANSI/ESD S541 these
conductive boxes are marked with the ESD protective symbol. They contain one
piece of high density foam for insertion of component leads and one piece of low
density foam which acts as a cushioning material.
57000 has only 1 piece of foam, all other sizes have 2 pieces of foam.
*Low density foam not included in item 57000
Properties:
ITEM NO.
INSIDE DIMENSIONS WITHOUT FOAM
Material:
Black conductive polypropylene
Resistance:
Less than 1 x10E5 ohms
(per ANSI EOS/ESD S11.11)
Size Tolerance:
± 1/32"
SIZE - MM
SIZE - INCHES
57000
33 x 33 x 12
1.3 x 1.3 x 0.46
57002
73 x 51 x 16
2.9 x 2 x 0.63
Temperature Limits:
0° to 120° F
57004
90 x 64 x 16
3.5 x 2.5 x 0.63
57006
107 x 82 x 13
4.2 x 3.2 x 0.52
Hinge:
Molded one-piece (57000-57006),
Pin two-piece (57008-57012)
57010
229 x 126 x 21
9 x 5 x 0.81
57008
229 x 126 x 30
9 x 5 x 1.19
Closure:
Snap
57012
229 x 126 x 40
9 x 5 x 1.58
Top Foam:
1/4" (.25", 6mm) thick low density foam
Bottom Foam:
1/4" (.25", 6mm) thick high density foam
* All boxes have the ESD Protective Symbol molded into them.
ANSI/ESD S541 section 6.1 Inside an EPA “Packaging used within an EPA (that
satisfies the minimum requirements of ANSI/ESD S20.20) shall be:
1. Low charge generation.
2. Dissipative or conductive materials for intimate contact.”
ANSI/ESD S541 section 7.2.2 Resistance of Dissipative Materials “A static
dissipative material shall have a surface resistance of greater than or equal to
1.0 x 10^4 Ohms but less than 1.0 x 10^11 Ohms. Packaging materials that are
in intimate contact with devices should be dissipative.”
Conductive Hinged Box with Foam
PROTEKTIVE PAK
13520 MONTE VISTA AVENUE, CHINO, CA 91710
PHONE (909) 627-2578, FAX (909) 363-7331
ProtektivePak.com
© 2010 DESCO INDUSTRIES INC.
Employee Owned
Made in America
Specifications and procedures subject to change without notice
DRAWING NUMBER
57000
DATE:
April
2010
很抱歉,暂时无法提供与“57010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+176.177681+22.79128
- 10+156.2126510+20.20849
- 25+150.1753225+19.42747
- 50+146.1513650+18.90691
- 100+142.52470100+18.43775
- 250+138.26006250+17.88605
- 500+135.38086500+17.51358
