57004
57004
    PROTEKTIVEPAK
    Molded
    板卡盒 储存,装运 聚丙烯 3.50" 长 x 2.50" 宽 x 0.63" 高(88.9mm x 63.5mm x 16.0mm)
57004 数据手册
Description: As required by ANSI/ESD S20.20 Packaging standard ANSI/ESD S541 these conductive boxes are marked with the ESD protective symbol. They contain one piece of high density foam for insertion of component leads and one piece of low density foam which acts as a cushioning material. 57000 has only 1 piece of foam, all other sizes have 2 pieces of foam. *Low density foam not included in item 57000 Properties: ITEM NO. INSIDE DIMENSIONS WITHOUT FOAM Material: Black conductive polypropylene Resistance: Less than 1 x10E5 ohms (per ANSI EOS/ESD S11.11) Size Tolerance: ± 1/32" * SIZE - MM SIZE - INCHES 57000 33 x 33 x 12 1.3 x 1.3 x 0.46 57002 73 x 51 x 16 2.9 x 2 x 0.63 Temperature Limits: 0° to 120° F 57004 90 x 64 x 16 3.5 x 2.5 x 0.63 57006 107 x 82 x 13 4.2 x 3.2 x 0.52 Hinge: Molded one-piece (57000-57006), Pin two-piece (57008-57012) 57010 229 x 126 x 21 9 x 5 x 0.81 57008 229 x 126 x 30 9 x 5 x 1.19 Closure: Snap 57012 229 x 126 x 40 9 x 5 x 1.58 Top Foam: 1/4" (.25", 6mm) thick low density foam Bottom Foam: 1/4" (.25", 6mm) thick high density foam * All boxes have the ESD Protective Symbol molded into them. ANSI/ESD S541 section 6.1 Inside an EPA “Packaging used within an EPA (that satisfies the minimum requirements of ANSI/ESD S20.20) shall be: 1. Low charge generation. 2. Dissipative or conductive materials for intimate contact.” ANSI/ESD S541 section 7.2.2 Resistance of Dissipative Materials “A static dissipative material shall have a surface resistance of greater than or equal to 1.0 x 10^4 Ohms but less than 1.0 x 10^11 Ohms. Packaging materials that are in intimate contact with devices should be dissipative.” Conductive Hinged Box with Foam PROTEKTIVE PAK 13520 MONTE VISTA AVENUE, CHINO, CA 91710 PHONE (909) 627-2578, FAX (909) 363-7331 ProtektivePak.com © 2010 DESCO INDUSTRIES INC. Employee Owned Made in America Specifications and procedures subject to change without notice DRAWING NUMBER 57000 DATE: April 2010
57004 价格&库存
很抱歉,暂时无法提供与“57004”相匹配的价格&库存,您可以联系我们找货
