423
423
    MGCHEMICALS
    SMD
    拆焊 织物/棉芯 树脂,中度活性(RMA),无铅 静电耗散(SD) 白色 0.030"(0.76mm) 5'(1.524m)
423 数据手册
MG Chemicals AppGuide One company. Many solutions. Desoldering Braid How do I remove solder from an old circuit to replace a malfunctioning component? De-soldering is required when electronic components need to be removed from a circuit, usually because they are faulty. It may sometimes be necessary during testing or assembly, if a wrong part has been fitted or a modification has to be made. What you need for removing solder from a circuit: Soldering Iron MG Super Wick To professionally remove solder from a circuit, you will need the following materials: 1. MG Chemicals Super Wick de-soldering braid 2. Soldering iron PROCEDURE Step 1 Choosing the right braid Match the bead to the braid. One wide braid suitable for many small beads. Choose a braid width that matches the size of the solder bead to be removed. If there are many small beads, choosing a wider braid will also speed up the Desoldering process. AVAILABLE BRAID PRODUCTS (BY CAT. NO) WIDTH AND COLOUR CODE* LENGTHS Super Wick 5 ft 0.025” White 0.05” Yellow 0.075” Green 0.1” Blue 0.125” Brown 423 424 425 426 427 25 ft - 442 443 444 - 50 ft 451 452 453 454 - 100 ft 461 462 463 464 - 500 ft 471 472 473 474 - No Clean Super Wick 5 ft - 424-NS 425-NS 426-NS - 50 ft - 453-NS - 454-NS - *Colours are industry standard. They represent the width of a desoldering braid. E-mail Phone Fax salesusa@mgchemicals.com 1-800-201-8822 Ext. 130 1-604-888-3084 Ext. 130 1-800-708-9888 1-604-888-7754 For technical specifications, MSDS, tech support and more To customize this AppGuide for your own use please email www.mgchemicals.com info@mgchemicals.com ISO 9001:2000 Registered Quality System. QMI Certificate #004008 Toronto, Canada. MG Chemicals AppGuide One company. Many solutions. Step 2 Using the braid up a Heat soldering iron Many Place little Super beads Wick and heated solder bone c Place onwide to solder braid. bead iron on to braid a. Heat up soldering iron b. Place Super Wick on to solder bead c. Place heated solder iron on to braid Molten solder is drawn up by capillary action into the braid. Careful not to overheat, or 'drag whiskers' of solder over the board, nor let the braid solidify on the joint! Always remove braid and solder iron together in a vertical motion. Fine Braid Super Wick Clean, Fast, Reliable No Clean Super Wick Cleaner, Faster, More Consistent Oxide-free clean copper Oxide-free clean copper More strands of copper (more surface area) per square inch More strands of copper (more surface area) per square inch Designed to leave a residue which is environmentally safe Flux residue remaining on board does not need to be cleaned Uses pure type 'R' resin flux conforming to all the requirements of To be used in conjunction with processes using RMA type no-clean MIL-F-14256F, Type 'RMA' and ANSI/J-STD-004 fluxes; conforms to the requirements of ANSI/J-STD-004, Type LO Static free dissipative spools in compliance with the ESD Association Standard (Mil. Standard 2000 and DOD Standard 1686) Manufactured under SPC guidelines High SIR-conforming to Bellcore specification GR-78-CORE (TR-TSY- 000078), and IPC Test Method III Static free dissipative spools in compliance with the ESD Association Cleaned and manufactured utilizing the latest technology in Standard (Mil. Standard 2000 and DOD Standard 1686) Manufactured under SPC guidelines environmentally friendly chemicals and processes Packaged in 5, 10, 25, 100 and 500 foot lengths Cleaned and manufactured utilizing the latest technology in environmentally friendly chemicals and processes Packaged in 5, 10, 25 and 100 foot lengths E-mail Phone Fax salesusa@mgchemicals.com 1-800-201-8822 Ext. 130 1-604-888-3084 Ext. 130 1-800-708-9888 1-604-888-7754 For technical specifications, MSDS, tech support and more To customize this AppGuide for your own use please email www.mgchemicals.com info@mgchemicals.com ISO 9001:2000 Registered Quality System. QMI Certificate #004008 Toronto, Canada.
很抱歉,暂时无法提供与“423”相匹配的价格&库存,您可以联系我们找货
