WD3RE02GX809-1333L-PDI
    WINTECINDUSTRIES
    RDIMM240
    MODULE DDR3 SDRAM 2GB 240RDIMM
WD3RE02GX809-1333L-PDI 数据手册
Wintec Industries – OEM Embedded Design Center Where to Buy | Contact Us CONSUMER EMBEDDED OEM SUPPLY CHAIN   CLOUD SERVICES DISTRIBUTION Submit SUPPORT ABOUT WINTEC       Embedded OEM Home >   Embedded OEM  >  DRAM  >  DDR3   DRAM DRAM DDR3 DDR3 RDIMM DDR2 DDR RDIMM SDR UDIMM SODIMM mini DIMM Speciality   Flash DDR3 is the current mainstream dram technology standardized by JEDEC, bringing further improvements in power consumption and increased bandwidth over DDR2. Available in power supply voltages of 1.5V (DDR3) and 1.35V (DDR3L) and with transfer data rates from 800Mb/s to 1.6Gb/s and beyond, DDR3 has become the de facto mainstream memory technology especially for server and notebook applications in the 1H of 2010. Many other applications are available in the market today to take advantage of the superior performance features of DDR3 and DDR3L. Wintec currently offers following DDR3 and DDR3L Modules and will continue to add more solutions as DDR3/DDR3L enabled applications will proliferate. SSD ADD2 Modems   DDR3 240-Pin Registered-ECC DIMMs Standard Profile (1.181”) with Nominal Voltage (1.5V) Density 1GB 2GB 4GB 8GB Part Number DIMM Component Config Config Rank Voltage WD3RE01GX809-xxxxx-yyz 1 rank 128x72 128Mx8 1.5V WD3RE02GX818-xxxxx-yyz 2 rank 256x72 128Mx8 1.5V WD3RE02GX809-xxxxx-yyz 1 rank 256x72 256Mx8 1.5V WD3RE02GX418-xxxxx-yyz 1 rank 256x72 256Mx4 1.5V WD3RE04GX418-xxxxx-yyz 1 rank 512x72 512Mx4 1.5V WD3RE04GX818-xxxxx-yyz 2 rank 512x72 256Mx8 1.5V WD3RE04GX436-xxxxx-yyz 2 rank 512x72 256Mx4 1.5V WD3RE08GX436-xxxxx-yyz 2 rank 1024x72 512Mx4 1.5V WD3RE08GX836-xxxxx-yyz 4 rank 1024x72 256Mx8 1.5V Wintec Industries – OEM Embedded Design Center WD3RE08GX418-xxxxx-yyz 1 rank 1024x72 1024Mx4 DIMM Component Config Config 1.5V Very Low Profile (0.72”) with Nominal Voltage (1.5V) Density 1GB 2GB   Part Number Rank Voltage WD3RE01GX809V-xxxxx-yyz 1 rank 128x72 128Mx8 1.5V WD3RE02GX818V-xxxxx-yyz 2 rank 256x72 128Mx8 1.5V WD3RE02GX809V-xxxxx-yyz 1 rank 256x72 256Mx8 1.5V WD3RE02GX418V-xxxxx-yyz 1 rank 256x72 256Mx4 1.5V WD3RE04GX418V-xxxxx-yyz 1 rank 512x72 512Mx4 1.5V WD3RE04GX818V-xxxxx-yyz 2 rank 512x72 256Mx8 1.5V WD3RE08GX418V-xxxxx-yyz 1 rank 1024x72 1024Mx4 1.5V DIMM Component Config Config   4GB 8GB Standard Profile (1.181”) with Low Voltage (1.35V) Density 1GB 2GB 4GB 8GB Part Number Rank Voltage WD3LE01GX809-xxxxx-yyz 1 rank 128x72 128Mx8 1.35V WD3LE02GX818-xxxxx-yyz 2 rank 256x72 128Mx8 1.35V WD3LE02GX809-xxxxx-yyz 1 rank 256x72 256Mx8 1.35V WD3LE02GX418-xxxxx-yyz 1 rank 256x72 256Mx4 1.35V WD3LE04GX418-xxxxx-yyz 1 rank 512x72 512Mx4 1.35V WD3LE04GX818-xxxxx-yyz 2 rank 512x72 256Mx4 1.35V WD3LE04GX436-xxxxx-yyz 2 rank 512x72 256Mx4 1.35V WD3LE08GX436-xxxxx-yyz 2 rank 1024x72 512Mx4 1.35V WD3LE08GX836-xxxxx-yyz 4 rank 1024x72 256Mx8 1.35V WD3LE08GX418-xxxxx-yyz 1 rank 1024x72 1024Mx4 1.35V DIMM Component Config Config Very Low Profile (0.72”) with Low Voltage (1.35V) Density 1GB 2GB Part Number Rank Voltage WD3LE01GX809V-xxxxx-yyz 1 rank 128x72 128Mx8 1.35V WD3LE02GX818V-xxxxx-yyz 2 rank 256x72 128Mx8 1.35V WD3LE02GX809V-xxxxx-yyz 1 rank 256x72 256Mx8 1.35V WD3LE02GX418V-xxxxx-yyz 1 rank 256x72 256Mx4 1.35V WD3LE04GX418V-xxxxx-yyz 1 rank 512x72 512Mx4 1.35V WD3LE04GX418V-xxxxx-yyz 2 rank 512x72 256Mx4 1.35V WD3LE08GX418V-xxxxx-yyz 1 rank 1024x72 1024Mx4 1.35V 4GB 8GB Wintec Industries – OEM Embedded Design Center   (xxxxx) Module speed (MHz) and Cas Latency 1066J : 1066MHz CL 7 = 1333L : 1333Mhz CL9 1600N :1600MHz CL11 (yy) = (z) = DRAM Manufacturer and Die Revision A: A-Die P: Samsung B: B-Die H: Micron C: C-Die C: Hynix      Buffer / Register set (Only applies to Registered/Buffered modules) I: Inphi D: IDT L: Intel           CONTACT US | SITEMAP | JOBS | PRESS | PRIVACY | WEBSITE FEEDBACK COPYRIGHT © 2011 WINTEC INDUSTRIES ALL RIGHTS RESERVED http://www.wintecind.com/oem/DRAM/DDR3/RDIMM.html[4/20/2012 1:11:54 PM]
WD3RE02GX809-1333L-PDI 价格&库存
很抱歉,暂时无法提供与“WD3RE02GX809-1333L-PDI”相匹配的价格&库存,您可以联系我们找货
