WD3SE01GX809-1333L-PG
    WINTECINDUSTRIES
    SODIMM204
    MODULE DDR3 SDRAM 1GB 204SOUDIMM
WD3SE01GX809-1333L-PG 数据手册
Wintec Industries – OEM Embedded Design Center Where to Buy | Contact Us CONSUMER EMBEDDED OEM SUPPLY CHAIN   CLOUD SERVICES DISTRIBUTION Submit SUPPORT ABOUT WINTEC     Embedded OEM   Home >   Embedded OEM  >  DRAM  >  DDR3   DRAM DRAM DDR3 DDR3 SODIMM DDR2 DDR RDIMM SDR UDIMM SODIMM mini DIMM Speciality   Flash DDR3 is the current mainstream dram technology standardized by JEDEC, bringing further improvements in power consumption and increased bandwidth over DDR2. Available in power supply voltages of 1.5V (DDR3) and 1.35V (DDR3L) and with transfer data rates from 800Mb/s to 1.6Gb/s and beyond, DDR3 has become the de facto mainstream memory technology especially for server and notebook applications in the 1H of 2010. Many other applications are available in the market today to take advantage of the superior performance features of DDR3 and DDR3L. Wintec currently offers following DDR3 and DDR3L Modules and will continue to add more solutions as DDR3/DDR3L enabled applications will proliferate. SSD ADD2 Modems   DDR3 - 204-Pin SODIMM - Registered ECC Standard Profile (1.181”) with Nominal Voltage (1.5V) Density 1GB Part Number DIMM Component Config Config Rank Voltage WD3AE01GX809-xxxx-yyz 1 rank 128x72 128Mx8 1.5V WD3AE02GX809-xxxx-yyz 1 rank 256x72 256Mx8 1.5V WD3AE02GX818-xxxx-yyz 2 rank 256x72 128Mx8 1.5V WD3AE02GX418-xxxx-yyz 2 rank 512x72 256Mx8 1.5V WD3AE04GX436-xxxx-yyz 1 rank 512x72 512Mx8 1.5V DIMM Component Config Config 2GB 4GB DDR3 - 204-Pin SODIMM - Unbuffered ECC Standard Profile (1.181”) with Nominal Voltage (1.5V) Density   Part Number Rank Voltage   Wintec Industries – OEM Embedded Design Center 1GB WD3SE01GX809-xxxxx-yy 1 rank 128x72 128Mx8 1.5V WD3SE02GX809-xxxxx-yy 1 rank 256x72 256Mx8 1.5V WD3SE02GX818-xxxxx-yy 2 rank 128x72 128Mx8 1.5V WD3SE04GX818-xxxxx-yy 2 rank 512x72 256Mx8 1.5V WD3SE04GX809-xxxxx-yy 1 rank 512x72 512Mx8 1.5V WD3SE08GX818-xxxxx-yy 2 rank 1024x72 512Mx8 1.5V 2GB 4GB 8GB DDR3 - 204-Pin SODIMM - Unbuffered Non-ECC Standard Profile (1.181”) with Nominal Voltage (1.5V) Density Part Number 1GB DIMM Component Config Config Rank Voltage WD3SN01GX808-xxxxx-yy 1 rank 128x64 128Mx8 1.5V WD3SN02GX808-xxxxx-yy 1 rank 256x64 256Mx8 1.5V WD3SN02GX816-xxxxx-yy 2 rank 256x64 128Mx8 1.5V WD3SN04GX816-xxxxx-yy 2 rank 512x64 256Mx8 1.5V WD3SN04GX808-xxxxx-yy 1 rank 512x64 512Mx8 1.5V 2GB 4GB   (xxxxx) Module speed (MHz) and Cas Latency = 1066J : 1066MHz CL 7 1333L : 1333Mhz CL9 1600N :1600MHz CL11 (yy) = (z) = DRAM Manufacturer and Die Revision A: A-Die P: Samsung B: B-Die H: Micron C: C-Die C: Hynix      Buffer / Register set (Only applies to Registered/Buffered modules) I: Inphi D: IDT L: Intel           CONTACT US | SITEMAP | JOBS | PRESS | PRIVACY | WEBSITE FEEDBACK COPYRIGHT © 2011 WINTEC INDUSTRIES ALL RIGHTS RESERVED http://www.wintecind.com/oem/DRAM/DDR3/SODIMM.html[4/20/2012 1:27:32 PM]
WD3SE01GX809-1333L-PG 价格&库存
很抱歉,暂时无法提供与“WD3SE01GX809-1333L-PG”相匹配的价格&库存,您可以联系我们找货
