WD3SN01GX808-1333L-PG 数据手册
Wintec Industries – OEM Embedded Design Center
Where to Buy | Contact Us
CONSUMER
EMBEDDED OEM
SUPPLY CHAIN
CLOUD SERVICES
DISTRIBUTION
Submit
SUPPORT
ABOUT WINTEC
Embedded OEM
Home > Embedded OEM > DRAM > DDR3
DRAM
DRAM DDR3
DDR3
SODIMM
DDR2
DDR
RDIMM
SDR
UDIMM
SODIMM
mini DIMM
Speciality
Flash
DDR3 is the current mainstream dram technology
standardized by JEDEC, bringing further improvements
in power consumption and increased bandwidth over
DDR2. Available in power supply voltages of 1.5V
(DDR3) and 1.35V (DDR3L) and with transfer data
rates from 800Mb/s to 1.6Gb/s and beyond, DDR3 has
become the de facto mainstream memory technology
especially for server and notebook applications in the
1H of 2010. Many other applications are available in the
market today to take advantage of the superior
performance features of DDR3 and DDR3L. Wintec
currently offers following DDR3 and DDR3L Modules
and will continue to add more solutions as
DDR3/DDR3L enabled applications will proliferate.
SSD
ADD2
Modems
DDR3 - 204-Pin SODIMM - Registered ECC
Standard Profile (1.181”) with Nominal Voltage (1.5V)
Density
1GB
Part Number
DIMM
Component
Config
Config
Rank
Voltage
WD3AE01GX809-xxxx-yyz
1 rank
128x72
128Mx8
1.5V
WD3AE02GX809-xxxx-yyz
1 rank
256x72
256Mx8
1.5V
WD3AE02GX818-xxxx-yyz
2 rank
256x72
128Mx8
1.5V
WD3AE02GX418-xxxx-yyz
2 rank
512x72
256Mx8
1.5V
WD3AE04GX436-xxxx-yyz
1 rank
512x72
512Mx8
1.5V
DIMM
Component
Config
Config
2GB
4GB
DDR3 - 204-Pin SODIMM - Unbuffered ECC
Density
Part Number
Rank
Voltage
1GB
WD3SE01GX809-xxxxx-yy
1 rank
128x72
128Mx8
1.5V
WD3SE02GX809-xxxxx-yy
1 rank
256x72
256Mx8
1.5V
WD3SE02GX818-xxxxx-yy
2 rank
128x72
128Mx8
1.5V
WD3SE04GX818-xxxxx-yy
2 rank
512x72
256Mx8
1.5V
WD3SE04GX809-xxxxx-yy
1 rank
512x72
512Mx8
1.5V
WD3SE08GX818-xxxxx-yy
2 rank
1024x72
512Mx8
1.5V
2GB
4GB
8GB
DDR3 - 204-Pin SODIMM - Unbuffered Non-ECC
Density
Part Number
1GB
DIMM
Component
Config
Config
Rank
Voltage
WD3SN01GX808-xxxxx-yy
1 rank
128x64
128Mx8
1.5V
WD3SN02GX808-xxxxx-yy
1 rank
256x64
256Mx8
1.5V
WD3SN02GX816-xxxxx-yy
2 rank
256x64
128Mx8
1.5V
WD3SN04GX816-xxxxx-yy
2 rank
512x64
256Mx8
1.5V
WD3SN04GX808-xxxxx-yy
1 rank
512x64
512Mx8
1.5V
2GB
4GB
(xxxxx) Module speed (MHz) and Cas Latency
1066J : 1066MHz CL 7
1333L : 1333Mhz CL9
1600N :1600MHz CL11
(yy) =
(z) =
DRAM Manufacturer and Die Revision
A: A-Die
P: Samsung
B: B-Die
H: Micron
C: C-Die
C: Hynix
Buffer / Register set (Only applies to Registered/Buffered modules)
I: Inphi
D: IDT
L: Intel
CONTACT US
SITEMAP
JOBS |
PRESS
PRIVACY
WEBSITE FEEDBACK
COPYRIGHT © 2011 WINTEC INDUSTRIES ALL RIGHTS RESERVED
http://www.wintecind.com/oem/DRAM/DDR3/SODIMM.html[4/20/2012 1:27:32 PM]
WD3SN01GX808-1333L-PG 价格&库存
很抱歉,暂时无法提供与“WD3SN01GX808-1333L-PG”相匹配的价格&库存,您可以联系我们找货
