WD3UE04GX818-1333L-PD
    WINTECINDUSTRIES
    UDIMM240
    MODULE DDR3 SDRAM 4GB 240UDIMM
WD3UE04GX818-1333L-PD 数据手册
Wintec Industries – OEM Embedded Design Center Where to Buy | Contact Us CONSUMER EMBEDDED OEM SUPPLY CHAIN   CLOUD SERVICES DISTRIBUTION Submit SUPPORT ABOUT WINTEC     Embedded OEM   Home >   Embedded OEM  >  DRAM  >  DDR3   DRAM DRAM DDR3 DDR3 UDIMM DDR2 DDR RDIMM SDR UDIMM SODIMM mini DIMM Speciality   Flash DDR3 is the current mainstream dram technology standardized by JEDEC, bringing further improvements in power consumption and increased bandwidth over DDR2. Available in power supply voltages of 1.5V (DDR3) and 1.35V (DDR3L) and with transfer data rates from 800Mb/s to 1.6Gb/s and beyond, DDR3 has become the de facto mainstream memory technology especially for server and notebook applications in the 1H of 2010. Many other applications are available in the market today to take advantage of the superior performance features of DDR3 and DDR3L. Wintec currently offers following DDR3 and DDR3L Modules and will continue to add more solutions as DDR3/DDR3L enabled applications will proliferate. SSD ADD2 Modems   DDR3 240-Pin Unbuffered-ECC DIMMs Standard Profile (1.181”) with Nominal Voltage (1.5V) Density 1GB Part Number DIMM Component Config Config Rank Voltage WD3UE01GX809-xxxxx-yy 1 rank 128x72 128Mx8 1.5V WD3UE02GX818-xxxxx-yy 2 rank 256x72 128Mx8 1.5V WD3UE02GX809-xxxxx-yy 1 rank 256x72 256Mx8 1.5V WD3UE04GX818-xxxxx-yy 2 rank 512x72 256Mx8 1.5V DIMM Component Config Config 2GB 4GB Very Low Profile (0.72”) with Nominal Voltage (1.5V) Density Part Number Rank   1GB 2GB Voltage   WD3UE01GX809V-xxxxx-yy 1 rank 128x72 128Mx8 1.5V WD3UE02GX818V-xxxxx-yy 2 rank 256x72 128Mx8 1.5V Wintec Industries – OEM Embedded Design Center 4GB WD3UE02GX809V-xxxxx-yy 1 rank 256x72 256Mx8 1.5V WD3UE04GX818V-xxxxx-yy 2 rank 512x72 256Mx8 1.5V DIMM Component Config Config DDR3 240-Pin DIMM - Unbuffered Non-ECC Standard Profile (1.181”) with Nominal Voltage (1.5V) Density Part Number 1GB Rank Voltage WD3UN01GX808-xxxxx-yy 1 rank 128x64 128Mx8 1.5V WD3UN02GX816-xxxxx-yy 2 rank 256x64 128Mx8 1.5V WD3UN02GX808-xxxxx-yy 1 rank 256x64 256Mx8 1.5V 4GB WD3UN04GX816-xxxxx-yy 2 rank 512x64 256Mx4 1.5V 8GB WD3UN08GX816-xxxxx-yy 2 rank 1024x64 512Mx4 1.5V 2GB   (xxxxx) Module speed (MHz) and Cas Latency 1066J : 1066MHz CL 7 = 1333L : 1333Mhz CL9 1600N :1600MHz CL11 (yy) = (z) = DRAM Manufacturer and Die Revision A: A-Die P: Samsung B: B-Die H: Micron C: C-Die C: Hynix      Buffer / Register set (Only applies to Registered/Buffered modules) I: Inphi D: IDT L: Intel           CONTACT US | SITEMAP | JOBS | PRESS | PRIVACY | WEBSITE FEEDBACK COPYRIGHT © 2011 WINTEC INDUSTRIES ALL RIGHTS RESERVED http://www.wintecind.com/oem/DRAM/DDR3/UDIMM.html[4/20/2012 1:21:21 PM]
WD3UE04GX818-1333L-PD 价格&库存
很抱歉,暂时无法提供与“WD3UE04GX818-1333L-PD”相匹配的价格&库存,您可以联系我们找货
