WD2UE01GX809-667I-PF
    WINTECINDUSTRIES
    UDIMM240
    MODULE DDR2 SDRAM 1GB 240UDIMM
WD2UE01GX809-667I-PF 数据手册
Wintec Industries – OEM Embedded Design Center Where to Buy | Contact Us CONSUMER EMBEDDED OEM SUPPLY CHAIN   CLOUD SERVICES DISTRIBUTION Submit SUPPORT ABOUT WINTEC     Embedded OEM   Home >   Embedded OEM  >  DRAM  >  DDR2   DRAM DRAM DDR2 DDR3 UDIMM DDR2 DDR RDIMM SDR UDIMM SODIMM mini DIMM Speciality   Flash DDR2 has been the standard memory solutions for applications in virtually all market segments from Servers, PCs and Notebooks to Printers, Networking and Storage systems and many more for several years providing superior cost and performance criteria. DDR2 has started to relinquish its role as the memory industry’s mainstream technology to DDR3 and is forecasted to become a legacy product by early 2011 SSD ADD2 Modems Available in power supply voltages of 1.8V (and 1.55V for FBDIMMs) and with transfer data rates from 400Mb/s to 800Mb/s and beyond, DDR2 has been designed in a wide range of applications providing designers with numerous module options to choose from. Wintec offers a wide range of DDR2 Module solutions. Please click on the link to find out more about our solutions.   DDR2 - 240-Pin DIMM - Unbuffered ECC Standard Profile (1.181”) with Nominal Voltage (1.8V) Density Part Number DIMM Component Config Config Rank Voltage 1GB WD2UE01GX809-xxxx-yy 1 rank 128x72 128Mx8 1.8V 2GB WD2UE02GX818-xxxx-yy 2 rank 256x72 128Mx8 1.8V 4GB WD2UE04GX818-xxxx-yy 2 rank 512x72 256Mx8 1.8V 8GB WD2UE08GX818-xxxx-yy 2 rank 1024x72 512Mx8 1.8V Very Low Profile (0.72”) with Nominal Voltage (1.8V)   Density 1GB Part Number WD2UE01GX809V-xxxx-yy DIMM Component Config Config 128x72 128Mx8 Rank 1 rank Voltage 1.8V   Wintec Industries – OEM Embedded Design Center WD2UE02GX818V-xxxx-yy 2 rank 256x72 128Mx8 1.8V WD2UE02GX809V-xxxx-yy 1 rank 256x72 256Mx8 1.8V WD2UE04GX818V-xxxx-yy 2 rank 512x72 256Mx8 1.8V WD2UE04GX809V-xxxx-yy 1 rank 512x72 512Mx8 1.8V DIMM Component Config Config 2GB 4GB DDR2 - 240-Pin DIMM - Unbuffered Non-ECC Standard Profile (1.181”) with Nominal Voltage (1.8V) Density Part Number 1GB Rank Voltage WD2UN01GX808-xxxx-yy 1 rank 128x64 128Mx8 1.8V WD2UN02GX816-xxxx-yy 2 rank 256x64 128Mx8 1.8V WD2UN02GX808-xxxx-yy 1 rank 256x64 256Mx8 1.8V WD2UN04GX818-xxxx-yy 2 rank 512x64 256Mx8 1.8V 2GB 4GB   (xxxxx) Modules Speed (MHz) and CAS Latency 800I: 800MHz CL6 = 800G : 800MHz CL5 667G : 667MHz CL5 533E : 533MHz CL4 (yy) = (z) = DRAM Manufacturer and Die Revision A: A-Die P: Samsung B: B-Die H: Micron C: C-Die C: Hynix      Buffer / Register set (Only applies to Registered/Buffered modules) I: Inphi D: IDT L: Intel           CONTACT US | SITEMAP | JOBS | PRESS | PRIVACY | WEBSITE FEEDBACK COPYRIGHT © 2011 WINTEC INDUSTRIES ALL RIGHTS RESERVED http://www.wintecind.com/oem/DRAM/DDR2/UDIMM.html[4/20/2012 3:03:51 PM]
WD2UE01GX809-667I-PF 价格&库存
很抱歉,暂时无法提供与“WD2UE01GX809-667I-PF”相匹配的价格&库存,您可以联系我们找货
