WD2SN02GX816-667I-PF 数据手册
Wintec Industries – OEM Embedded Design Center
Where to Buy | Contact Us
CONSUMER
EMBEDDED OEM
SUPPLY CHAIN
CLOUD SERVICES
DISTRIBUTION
Submit
SUPPORT
ABOUT WINTEC
Embedded OEM
Home > Embedded OEM > DRAM > DDR2
DRAM
DRAM DDR2
DDR3
SODIMM
DDR2
DDR
RDIMM
SDR
UDIMM
SODIMM
mini DIMM
Speciality
Flash
DDR2 has been the standard memory solutions for
applications in virtually all market segments from
Servers, PCs and Notebooks to Printers, Networking
and Storage systems and many more for several years
providing superior cost and performance criteria. DDR2
has started to relinquish its role as the memory
industry’s mainstream technology to DDR3 and is
forecasted to become a legacy product by early 2011
SSD
ADD2
Modems
Available in power supply voltages of 1.8V (and 1.55V
for FBDIMMs) and with transfer data rates from
400Mb/s to 800Mb/s and beyond, DDR2 has been
designed in a wide range of applications providing
designers with numerous module options to choose
from. Wintec offers a wide range of DDR2 Module
solutions. Please click on the link to find out more about
our solutions.
DDR2 - 200-Pin SODIMM - Registered ECC
Standard Profile (1.181”) with Nominal Voltage (1.8V)
Density
Part Number
DIMM
Component
Config
Config
Rank
Voltage
1GB
WD2AE01GX809-xxxx-yyz
1 rank
128x72
128Mx8
1.8V
2GB
WD2AE02GX809-xxxx-yyz
1 rank
256x72
256Mx8
1.8V
4GB
WD2AE04GD809-xxxx-yyz
2 rank
512x72
512Mx8
1.8V
DIMM
Component
DDR2 - 200-Pin SODIMM - Unbuffered ECC
Density
1GB
Part Number
WD2SE01GX809-xxxx-yy
http://www.wintecind.com/oem/DRAM/DDR2/SODIMM.html[4/20/2012 3:08:45 PM]
Rank
1 rank
Voltage
Config
Config
128x72
128Mx8
1.8V
WD2SE02GX818-xxxx-yy
2 rank
256x72
128Mx8
1.8V
WD2SE02GX809-xxxx-yy
1 rank
256x72
256Mx8
1.8V
WD2SE04GX818-xxxx-yy
2 Rank
512x72
256Mx8
1.8V
2GB
4GB
DDR2 - 200-Pin SODIMM - Unbuffered Non-ECC
Density
Part Number
1GB
DIMM
Component
Config
Config
Rank
Voltage
WD2SN01GX808-xxxx-yy
1 rank
128x64
128Mx8
1.8V
WD2SN02GX816-xxxx-yy
2 rank
256x64
128Mx8
1.8V
WD2SN02GX808-xxxx-yy
1 rank
256x64
256Mx8
1.8V
WD2SN04GX816-xxxx-yy
2 rank
512x64
256Mx8
1.8V
WD2SN04GX808-xxxx-yy
1 rank
512x64
512Mx8
1.8V
2GB
4GB
(xxxxx) Modules Speed (MHz) and CAS Latency
800I: 800MHz CL6
800G : 800MHz CL5
667G : 667MHz CL5
533E : 533MHz CL4
(yy) =
(z) =
DRAM Manufacturer and Die Revision
A: A-Die
P: Samsung
B: B-Die
H: Micron
C: C-Die
C: Hynix
Buffer / Register set (Only applies to Registered/Buffered modules)
I: Inphi
D: IDT
L: Intel
CONTACT US
SITEMAP
JOBS |
PRESS
PRIVACY
WEBSITE FEEDBACK
COPYRIGHT © 2011 WINTEC INDUSTRIES ALL RIGHTS RESERVED
WD2SN02GX816-667I-PF 价格&库存
很抱歉,暂时无法提供与“WD2SN02GX816-667I-PF”相匹配的价格&库存,您可以联系我们找货
