9121S-19.200N33DT1JL 数据手册
TEMPERATURE COMPENSATED
V O L T A G E
C O N T R O L L E D
C R Y S T A L
O S C I L L A T O R
9121S
TCVCXO UNIT WITH CLIPPED SINE WAVE OUTPUT IN SMD 2.0X1.6MM CERAMIC SEAM SEAL PACKAGE.
PRODUCT FEATURES
PRODUCT PHOTO
(NOT IN SCALE)
Small dimensions 2.0x1.6x0.8 with 4 solder pads.
Tight stabilities over temperature range.
Voltage control function allows compensation of tolerance.
RoHS compliant, LEAD-FREE, HALOGEN-FREE and REACH compliant.
APPLICATIONS
WiMAX / WLAN / Ethernet
Telecommunication
Mobil applications
PRODUCT SPECIFICATIONS
PARAMETER
1.8V
SUPPLY VOLTAGE
2.5V
2.8/ 3.0/ 3.3V
Frequency range
10 ~ 52MHz
Frequency tolerance
REMARKS
±1.0ppm
Initial tol. @+25°C
Frequency stability
±0.5ppm; ±1.0ppm; 1.5ppm; ±2.0ppm; ±2.5ppm See note below table
Operating temperature range
–20 to +70°C / –30 to +85°C / –40 to +85°C stabilities.
In combination to above
Aging per year
±1.0ppm
Control voltage range Vc
0.3 ~ 1.5VDC
0.4 ~ 2.4VDC
Frequency pulling range
@+25°C
0.5 ~ 2.5VDC
±5.0ppm
Output waveform
Over control voltage
Clipped Sine Wave
10kΩ/10pF
Output load
Output voltage level
0.8Vp-p
Phase noise (example 19.2MHz)
Minimum
-115dBc/Hz / -135dBc/Hz / -148dBc/Hz
Phase jitter RMS
26MHz)
Note: Frequency stability is the frequency deviation over temperature range in reference to +25°C
PACKAGE OUTLINE / DIMENSIONS
PACKAGING INFORMATION
Tape & Reel compliant to EIA-481.
Embossed carrier width 8mm.
Component pitch in carrier 4mm.
Reel diameter 180mm.
QTY per reel: 3,000pcs
RECOMMENDED REFLOW PROFILE
Suzhou HangJing Elec&Tech Co., Ltd.
Http://www.hci.com.hk
Telephone:+86 (0)512 6591 6689
No.1,First Qunxing Rd,Suzhou Industrial Park,Jiangsu,China
Mobile phone:+86 (0)13819495058
e-mail: tony@hci.com.hk
9121S-19.200N33DT1JL 价格&库存
很抱歉,暂时无法提供与“9121S-19.200N33DT1JL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 型号:9121S-19.200N33DT1JL
- 品牌:HCI(杭晶)
- 封装:SMD2016_4P
- 描述:高精度,高稳定性,VCTCXO,封装尺寸:2016,4P,频率:19.2MHz,输出波形:Clipped Sine wave,电压:3.3V,初始精度:±1ppm,工作温度:-40℃~+85℃,频率稳定度:±1ppm
- 国内价格
- 1+10.63498
- 10+9.05732
- 30+8.06890
- 100+7.06148
- 500+6.60528
- 1000+6.40570
