LO206A-27M-50-A
LO206A-27M-50-A
    LFC(龙营半导体)
    SMD2016-4P
    27MHz @3.3V
LO206A-27M-50-A 数据手册
LO206 Series Low Power Dual Mode EMI Reduction Oscillator Features ● ● ● ● ● FCC approved EMI attenuation Proprietary Low EMI Phase Modulated SaΦ ic™ Oscillator Dual Mode Clock Output : Low phase jitter clock or Low EMI clock RoHS compliant & Pb free AEC-Q100 G1 & G2 ● ● ● ● ● Frequency range 20MHz ~ 40MHz Supply voltage 1.62V ~ 3.63V CMOS output Operating temperature -40~125ºC SMD seam sealing ceramic package 2.0mm x 1.6mm Electrical Specifications Item Specification Frequency 20MHz ~ 40MHz Supply Voltage (VDD) 1.8V ~ 3.3V [1], ±10% Output Type CMOS Output Load 15 pF Oscillation Mode Fundamental Frequency Stability ±50 ppm [1] [2] [3] Operation Temperature Range -40ºC ~ 125ºC [1] Storage Temperature Range Output Voltage Low (VOL) -55ºC ~ 125ºC @ VDD = 3.3V, IOL = 12mA @ VDD = 1.8V, IOL = 4mA 0.2VDD Max. Output Voltage High (VOH) 0.8VDD Min. @ VDD = 3.3V, IOH = -12mA @ VDD = 1.8V, IOH = -4mA Rise(Tr) / Fall(Tf) Time [4] Dynamic Supply Current [5] 6 ns Max. 2.5mA EN=High / 4.0mA EN=Low Duty Cycle [6] 45% ~ 55% Start-Up Time 1 ms Max. Phase Jitter (12kHz~5MHz) 0.5 ps Max. [3][5] Aging (at 25ºC) ±3 ppm/year Max. Modulation Output Clock Mode Pin 1 selectable [1] Ordering options [2] Inclusive of frequency tolerance at 25°C, variations over operating temperature, supply voltage, load and 1st year aging at 25°C. [3] Modulation output clock mode is disabled. [4] Tr measure between 10% to 90%, Tf measure between 90% to 10% at 15pF load and VDD 1.8V~3.3V [5] Measure at 24MHz, VDD 1.8V [6] Measure at VDD /2 Page 1 REV: V1.4 Notice: The information in this document is subject to change without notice. www.lfc-semi.com LO206 Series Modulation Output Deviation [7], [8] Frequency (MHz) 20 24 25 27 VDD 1.8V ± 0.54 ± 0.62 ± 0.65 ± 0.70 Deviation range (%) @25ºC VDD 2.5V VDD 3.3V ± 0.36 ± 0.29 ± 0.42 ± 0.34 ± 0.45 ± 0.35 ± 0.54 ± 0.40 [7] The deviation range can vary by ±20% over voltage and temperature. [8] Modulation output mode is enabled, contact us for available frequencies and deviation range. Dimensions Pad Function 1 EN 2 GND 3 OUTPUT 4 VDD Suggested Layout (Unit: mm) Pin Definition Pin# Symbol 1 EN 2 3 4 GND OUTPUT VDD Functionality Modulation Output Clock Mode Enable Pin H (Logic "1") : Disable L (Logic "0") : Enable Internal pull-high resistor System ground reference Oscillator output System power supply Marking Duty Cycle Timing Output Rise/Fall Timing Temperature grade A Temperature range -40ºC ~ 125ºC Frequency stability (ppm) ±50 Page 2 REV: V1.4 Notice: The information in this document is subject to change without notice. www.lfc-semi.com LO206 Series Schematics , R2 = NC Ordering Information LO206 Product series A - 24.576M - 50 Frequency in Hz - C Supply voltage A : 3.3V B : 2.5V Operating temperature range A : -40~125°C C : 1.8V Frequency stability 50: +/-50ppm Page 3 REV: V1.4 Notice: The information in this document is subject to change without notice. www.lfc-semi.com
LO206A-27M-50-A 价格&库存
很抱歉,暂时无法提供与“LO206A-27M-50-A”相匹配的价格&库存,您可以联系我们找货
