中山惠源晶工电子科技有限公司
Zhongshan Huiyuan Crystal Electronic Technology Co., Ltd
GENERAL SPECIFICATIONS(电气特性)
1. Series model:
SMD2016
(系列号)
2.Normal Frequency:
16~38.4MHZMHz
(标称频率)
3.Oscillation Mode:
■Fundamental □3rd
(振动模式)
4.Load Capacitance(CL):
8PF,9PF,10PF,12PF
(负载电容)
5.Frequency Tolerance 25±3℃:
±10PPM
(频率偏差 25±3℃)
6.Stability Over Temperature Range:
±30 PPM
(工作温度频率偏差)
7.Effective Series Resistance:
16MHZ≤80Ω,24~32MHZ≤45Ω,38.4MHZ≤35Ω
(等效电阻)
8.Shunt Capacitance(C0):
≤ 5PF
(静态电容)
9. Typical drive level:
10 uW TYP.
(激励功率)
10.Operation Temperature Range:
-20℃ to +70℃
(工作温度范围)
11.Storage Temperature:
-20℃ to +70℃
(存储温度)
12.Insulation Resistance:
≥500 MΩ at DC 100V
(绝缘阻抗)
13.Aging:
±3 PPM/Year
(老化率)
14.Leak
1×10-7Torr.1/sec Max
(检漏)
15.Test circuit
S&A 250B Pi-Network Crystal Measurement System
(测试仪器)
Remark(备注):
晶振最佳储存条件:温度:25±5℃,湿度:
很抱歉,暂时无法提供与“HY16MSMD2016FA1R30”相匹配的价格&库存,您可以联系我们找货
