KC-F-26.000M-9-1010-2070-60
    CECXTAL(中电熊猫)
    SMD2016_4P
    26MHZ 9PF ±10PPM -20 ℃ ~ +70℃
KC-F-26.000M-9-1010-2070-60 数据手册
RoHS Compliant RoHS APPROVAL SHEET 承 认 书 Product Name Quartz Crystal 石英晶体谐振器 P/N KC-F-26.000M-9-1010-2070-60 Customer’s Name Customer’s P/N Brand 中电熊猫(CEC) Specification Sheet # Date 2020-07-10 Generation Approval Customer Confirmation TEL:0086-769-81876691 FAX:0086-769-81876690 E-mail:yy@dgkbdz.com/wll@dgkbdz.com HTTP: http://www.dgkbdz.com/ 朱梦静 李坡 Compliant Specification of Quartz Crystal 石英晶体谐振器规格书 2.0×1.6 SMD DATE: 2020/07/10 ■ 更改记录(REVISION HISTORY) 日期(DATE) 1.2020-07-10 版本(EDITION) 第一版(First Edition) 拟制(DRAW) 朱梦静 Specification of Quartz Crystal 石英晶体谐振器规格书 2.0×1.6 SMD DATE: 2020/07/10 ■ 外形及印字(DIMENSION AND MARKING) Recommended land pattern C26.0 UNIT(单位)mm ■ 电气参数(ELECTRICAL SPECIFICATION) Type Nominal Frequency 型号 标称频率 2.0×1.6 Ceramic SMD 26.000000 MHz Mode of Oscillation 振荡模式 Operating Temperature Range 工作温度范围 Storage Temperature Range 保存温度范围 Test Set 测试系统 Fundamental Drive Level 100 uW Max. 激励电平 -20℃ ~ +70℃ -40℃ ~ +85℃ 250B PI-Network Loading Capacitance 负载电容 9 pF Frequency Tolerance 调整频差 ±10 ppm Max.(AT 25℃) Equivalent Resistance 等效阻抗 60 ohms Max. Temperature Drift 温度频差 ±10 ppm Max./-20℃ to +70℃ Shunt Capacitance 静态电容 7.0 pF Max. Motional Capacitance 动态电容 / Aging 老化率/年 ±3 ppm/ year Max. Insulation Resistance Other Note 绝缘阻抗 其它 500 MΩ Min / 100 V±15 V D.C. Tape & Reel Specification of Quartz Crystal 石英晶体谐振器规格书 2.0×1.6 SMD DATE: 2020/07/10 ■ 可靠性测试条件(RELIABILITY TEST) 条件 序号 项目 CONDITIONS NO ITEM 1 2 3 温度:85℃;时间:1000小时 AGING Temperature: 85℃;Times: 1000 hours △FL≤±10 ppm △RS≤5 Ω or ±20% (Whichever is Larger) 湿度抗性 ΔFR=±10 ppm MAX 高温:65℃(10小时,含升温),低温:25℃(2小时,含降 ΔRs=平均阻抗*20%或5 Ω MAX(两者取大值) 温), 湿度90%,循环10次,每循环24小时 MOISTURE RESISTANCE High-Temperature: 65℃±2℃(10 hours, including heating), Low-Temperature: 25℃±2℃(2 hours, including cooling), Humidity: 85%, for 10 cycles (24 hours/cycle) △FL≤±10 ppm △RS≤5 Ω or ±20% (Whichever is Larger) 温度:85℃±2℃;湿度85%;时间:1000小时 ΔFR=±10 ppm MAX ΔRs=平均阻抗*20%或5 Ω MAX(两者取大值) Temperature: 85℃±2℃; Humidity: 85%; Time: 1000 hours △FL≤±10 ppm △RS≤5 Ω or ±20% (Whichever is Larger) 温度:-40℃±2℃;时间:1000小时 ΔFR=±10 ppm MAX ΔRs=平均阻抗*20%或5 Ω MAX(两者取大值) 老化 湿热 低温 LOW-TEMPERATURE Temperature: -40℃±2℃; Time: 1000hours 5 热冲击 TEMPERATURE SHOCK 6 BASIS OF VERDICT ΔFR=±10 ppm MAX ΔRs=平均阻抗*20%或5 Ω MAX(两者取大值) HUMIDITY 4 合格标准 跌落 DROP △FL≤±10 ppm △RS≤5 Ω or ±20% (Whichever is Larger) 5 min -55℃±2℃ (5 min)←→125℃±2℃ (5 min);循环1000次 ΔFR=±10 ppm MAX ΔRs=平均阻抗*20%或5 Ω MAX(两者取大值) 5 min -55℃±2℃ (5 min)←→125℃±2℃ (5 min); For 1000 cycles △FL≤±10 ppm △RS≤5 Ω or ±20% (Whichever is Larger) 1m高处自由跌落到硬木板上,循环3次 ΔFR=±5 ppm MAX ΔRs=平均阻抗*15%或2 Ω MAX(两者取大值) Height: 1m; 3 times △FL≤±5 ppm △RS≤2 Ω or ±15% (whichever is larger) Specification of Quartz Crystal 石英晶体谐振器规格书 2.0×1.6 SMD 条件 序号 项目 7 合格标准 CONDITIONS NO ITEM 机械冲击 峰值 Peak: 100g's MECHANICAL 持续时间 Duration: 6ms SHOCK 波形 Waveform: 半正弦波 Half-sine BASIS OF VERDICT ΔFR=±5 ppm MAX ΔRs=平均阻抗*15%或2 Ω MAX(两者取大值) 变化速度 Velocity Change: 12.3 ft / sec △FL≤±5 ppm △RS≤2 Ω or ±15% (Whichever is Larger) 振动方向 Direction: +X, -X, +Y, -Y, +Z, -Z 每个方向各3次 3 times/direction 8 振动 频率 Frequency: 10~2000Hz: 加速度幅度 Acceleration: 5g/s VIBRATION 振动方向 Direction: X, Y, Z 振动时间 Duration: 每个方向20分钟20 min/direction. 循环次数 Times: 12次 9 回流焊 REFLOW ΔFR=±5 ppm MAX. ΔRs=平均阻抗*15%或2Ω MAX(两者取大值) 外观完好 260℃±5℃ 120sec 10secmax CYCLE TIME周期: 200sec Max.(回流2次) 11 ΔFR=±5 ppm MAX ΔRs=平均阻抗*15%或2 Ω MAX(两者取大值) △FL≤±5 ppm △RS≤2 Ω or ±15% (Whichever is Larger) 150℃±5℃ 10 DATE: 2020/07/10 △FL≤±5 ppm △RS≤2 Ω or ±15% (Whichever is Larger)No Rusty 可焊性 SOLDER 温度:250℃,蒸汽老化8小时 浸锡率≥95% Temperature: 250℃, Time: 8hours Solder Coverage ≥95% 引出端强度 1.8kg的切向推力(60秒)以及1.8kg的垂直拉力(60秒) 电极不断裂 TERMINAL 1.8kg,of the tangential thrust (60 s) No Rupture Observed STRENGTH 1.8kg of the perpendicular tension (60 s) Specification of Quartz Crystal 石英晶体谐振器规格书 2.0×1.6 SMD ■编带(TAPE) ■轮(REEL) DATE: 2020/07/10 Specification of Quartz Crystal 石英晶体谐振器规格书 2.0×1.6 SMD DATE: 2020/07/10 ■编带方式(TAPING METHOD) 轮 Reel 压封带 Cover 载带 Tape MARKING MARKING MARKING MARKING Empty Pockets Pull Direction Pull Direction 拉伸方向 Empty Pockets Specification of Quartz Crystal 石英晶体谐振器规格书 2.0×1.6 SMD DATE: 2020/07/10 ■包装(PACKAGE) 1.自封袋(Bag) 1000 只=1 轮 1000 pcs=1 Reel Desiccant 2.内包装(Inside Package) 1 轮=1 盒 1 Reel=1 Box 3.外包装(Outside Package ) 10 盒=1 箱 10 Box=1 Carton 干燥剂 Specification of Quartz Crystal 石英晶体谐振器规格书 2.0×1.6 SMD ■保存条件(Storage Condotion) 1.保存温度:25℃±15℃ Storage Temperature:25℃±15℃ 2.湿度:10%-60% humidity:10%-60% DATE: 2020/07/10
KC-F-26.000M-9-1010-2070-60 价格&库存
很抱歉,暂时无法提供与“KC-F-26.000M-9-1010-2070-60”相匹配的价格&库存,您可以联系我们找货
