0122M4-14.31818F20DTNJL
    HCI(杭晶)
    SMD2520_4P
    无源晶振 14.31818MHz ±10ppm 20pF 125Ω -40℃~+85℃
0122M4-14.31818F20DTNJL 数据手册
QUARTZ CRYSTAL UNIT 0122M4 QUARTZ CRYSTAL UNIT SMD 2.5X2.0MM IN CERAMIC SEAM SEAL PACKAGE. PRODUCT FEATURES PRODUCT PHOTO (NOT IN SCALE)  Small dimensions 2.5x2.0x0.55 with 4 solder pads.  Highly reliable vacuum seam sealed ceramic package.  Tight tolerances and stabilities over temperature range.  Automotive compliance to AEC-Q200 available.  RoHS compliant, LEAD-FREE and HALOGEN-FREE. APPLICATIONS  Wireless LAN  Bluetooth  Mobil communication  Handheld equipment PRODUCT SPECIFICATIONS 0122M4 PARAMETER Nominal frequency range CONDITIONS / REMARKS 12.000 ~ 60.000MHz Crystal cut and mode AT-cut Frequency tolerance ±10ppm Frequency stability Operating temperature range / / —- Fundamental ±20ppm / ±30ppm —Other options available. ±10ppm ±15ppm Other options available. –20 to +70°C –30 to +85°C Other options available. Equivalent series resistance Load capacitance
0122M4-14.31818F20DTNJL 价格&库存
很抱歉,暂时无法提供与“0122M4-14.31818F20DTNJL”相匹配的价格&库存,您可以联系我们找货
