中山惠源晶工电子科技有限公司
Zhongshan Huiyuan Crystal Electronic Technology Co., Ltd
GENERAL SPECIFICATIONS(电气特性)
1. Series model:
(系列号)
2.Normal Frequency:
(标称频率)
3.Oscillation Mode:
(振动模式)
4.Load Capacitance(CL):
(负载电容)
5.Frequency Tolerance 25±3℃:
(频率偏差 25±3℃)
6.Stability Over Temperature Range:
(工作温度频率偏差)
7.Effective Series Resistance:
(等效电阻)
SMD2520
12~48MHz
■Fundamental
□3rd
8PF,9PF,10PF,12PF,20PF
±10 PPM
±30 PPM
12MHZ≤ 150Ω
16~18.432MHZ≤ 80Ω
25~32MHZ≤ 50Ω
48MHZ≤ 40Ω
8.Shunt Capacitance(C0):
≤ 5 PF
(静态电容)
9. Typical drive level:
100 uW TYP.
(激励功率)
10.Operation Temperature Range:
-20℃ to +70℃
(工作温度范围)
11.Storage Temperature:
-20℃ to +70℃
(存储温度)
12.Insulation Resistance:
≥500 MΩ at DC 100V
(绝缘阻抗)
13.Aging:
±3 PPM/Year
(老化率)
14.Leak
1×10-7Torr.1/sec Max
(检漏)
15.Test circuit
S&A 250B Pi-Network Crystal Measurement System
(测试仪器)
Remark(备注):
晶振最佳储存条件:温度:25±5℃,湿度:
很抱歉,暂时无法提供与“HY26MSMD2520DA1R30”相匹配的价格&库存,您可以联系我们找货
