TAXM24M4ZFBCCT2T
TAXM24M4ZFBCCT2T
    YJX(雅晶鑫)
    SMD2016_4P
    无源晶振 24MHz ±20ppm 12pF 80Ω -40℃~+85℃
TAXM24M4ZFBCCT2T 数据手册
雅晶鑫電子 ● P/N:TAXM24M4ZFBCCT2T ELECTRICAL PARAMETERS Min 谐振器产品技术指标 1.Holder Type(型号规格) Max Units SEAM 2.0*1.6 2.Mode of Oscillation(振动模式) Fundamental 3.Frequency(标称频率) MHZ 24.000000 4.Load Capacitance (CL)(负载电容) pF 12 5.Shunt Capacitance (Co)(静态电容) 0 6.Equivalent Resistance(谐振电阻) 7.Frequency Tolerance at 25℃(调整频差) -20 8.Stability over operation temperance(温度频差) 5 pF 80 Ω 20 ppm ppm ± 10 9.Insulation Resistance (at D.C. 10V)(绝缘电阻) MΩ 500 10.Drive Level(激励功率) uw 100 11.Operating Temperature Range(工作温度范围) -40 85 ℃ 12.Storage Temperature Range(储存温度范围) -40 85 ℃ 13.Aging(老化率) 14.Other(其他) OUTLINE DIMENSIONS(UNIT:mm)外形尺寸(单位:mm) ±5 0 ppm/year
TAXM24M4ZFBCCT2T 价格&库存
很抱歉,暂时无法提供与“TAXM24M4ZFBCCT2T”相匹配的价格&库存,您可以联系我们找货
TAXM24M4ZFBCCT2T
  • 1+0.55110
  • 200+0.35530
  • 1500+0.30910
  • 3000+0.27390
库存:3000
TAXM24M4ZFBCCT2T
  • 10+0.28210
  • 100+0.26390
  • 500+0.24570
  • 2000+0.21840
  • 5000+0.20930
  • 10000+0.20384
库存:180
TAXM24M4ZFBCCT2T
  • 10+0.49864
  • 100+0.39906
  • 300+0.34938
  • 3000+0.28858
  • 6000+0.25877
  • 9000+0.24376
库存:6674
