TEMPERATURE COMPENSATED
CRYSTAL OSCILLATOR
8122S
TCXO UNIT WITH CLIPPED SINE WAVE OUTPUT IN SMD 2.5X2.0MM CERAMIC SEAM SEAL PACKAGE.
PRODUCT FEATURES
PRODUCT PHOTO
(NOT IN SCALE)
Small dimensions 2.5x2.0x0.9 with 4 solder pads.
Tight stabilities over temperature range.
RoHS compliant, LEAD-FREE, HALOGEN-FREE and REACH compliant.
APPLICATIONS
WiMAX / WLAN / Ethernet
Telecommunication
Mobil applications
PRODUCT SPECIFICATIONS
PARAMETER
1.8V
SUPPLY VOLTAGE
2.5V
2.8/ 3.0/ 3.3V
Frequency range
10 ~ 52MHz
REMARKS
Frequency tolerance
±2.0ppm
Initial tol. @+25°C
Frequency stability
±0.5ppm; ±1.0ppm; 1.5ppm; ±2.0ppm; ±2.5ppm
See note below table
Operating temperature range –20 to +70°C / –30 to +85°C / –40 to +85°C
In combination to
above stabilities.
Aging per year
@+25°C
±1.0ppm
Output waveform
Clipped Sine Wave
10kΩ/10pF
Output load
Output voltage level
0.8Vp-p
Phase noise (example
19.2MHz)
-115dBc/Hz / -135dBc/Hz / -148dBc/Hz
Phase jitter RMS
Minimum
26MHz)
Note: Frequency stability is the frequency deviation over temperature range in reference to +25°C
PACKAGE OUTLINE / DIMENSIONS
PACKAGING INFORMATION
Tape & Reel compliant to EIA-481.
Embossed carrier width 8mm.
Component pitch in carrier 4mm.
Reel diameter 180mm.
QTY per reel: 3,000pcs
RECOMMENDED REFLOW PROFILE
Suzhou HangJing Elec&Tech Co., Ltd.
Http://www.hci.com.hk
Telephone:+86 (0)512 6591 6689
No.1,First Qunxing Rd,Suzhou Industrial Park,Jiangsu,China
Mobile phone:+86 (0)13819495058
e-mail: tony@hci.com.hk
8122S-25.000NQ33FTL 价格&库存
很抱歉,暂时无法提供与“8122S-25.000NQ33FTL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 型号:8122S-25.000NQ33FTL
- 品牌:HCI(杭晶)
- 封装:SMD2520_4P
- 描述:高精度,高稳定性,TCXO,封装:2520,4P,频率:25MHz,输出模式:Clipped Sine wave,工作电压:3.3V,初始精度:±1ppm,工作温度:-30℃~+85℃,频率稳定度:±0.5ppm
- 国内价格
- 1+4.82220
- 10+3.96036
- 30+3.53970
- 100+3.10878
- 500+2.80098
- 1000+2.66760
- 品牌:HCI(杭晶)
- 封装:SMD2520_4P
- 国内价格
- 1+8.80000
- 100+7.65600
- 750+6.96300
- 1500+6.68800
- 3000+6.46800
