LO211A-125.000M-50-A
    LFC(龙营半导体)
    SMD2520_4P
    125MHz @3.3V
LO211A-125.000M-50-A 数据手册
LO2x1 Series Ultra Low Jitter Oscillator Features Applications  Frequency range  1MHz~200Mhz @3.3V  1MHz~125MHz @1.8V  Supply voltage 1.65V ~ 3.63V  Output Clock Tri-State Mode  CMOS output clock  Operating temperature -40~125ºC  RoHS compliant & Pb free  AEC-Q100 compliant (option)  SMD seam sealing ceramic package  2.0mm x1.6mm,2.5mm x2.0mm, 3.2mm x2.5mm  SATA, SAS, Ethernet, PCI Express, video, wireless.  Computing, storage, networking, telecom, Industrial control. Table1. Electrical Characteristics Parameter Output Frequency Range Frequency Stability Symbol F F_stab Operating Temperature Range T_use Supply Volage VDD Current Consumption IDD OE mode disable current I_od PDB mode standby Current I_std Duty Cycle DC Rise/Fall Time Tr, Tf Output Voltage High Output Voltage Low Min Typ. Max. 1 - 200 1 - 125 -20 - +20 -30 - +30 -100 - +100 -40 - +125 1.65 1.8 1.95 2.97 3.3 3.63 - - 3.4 mA 15pF Load, f=27MHz, VDD=3.3V - - 22 mA 15pF Load, f=40MHz, VDD=3.3V - - 10 uA When OE=GND, output is Pulled Down - 10 uA When OE=GND, output is Pulled Down 55 % 45 Unit MHz Condition VDD=3.3V VDD=1.8V -40~85 PPM -40~105 -40~125 ºC V 15pF load, 10%~90% VDD, high drive (VDD=3.3V) - 1.5 - nS VOH VDD -0.4 - - VDD VOL - - 0.4 VDD Input Voltage High VIH 70% - - VDD Pin1, OE Input Volage Low VIL - - 30% VDD Startup Time T_start - 5 7 mS OE Enable/Disable Time T_oe - - 10 nS Resume Time T_resume - - 7 mS Pin1, OE Measure from the time VDD reaches its rated minimum value. OE function; Ta=25 ºC, 15pFload. Add one clock period to this measurement for a usable clock output. In PDB mode, Ta=25 ºC, 15pFload - 200 300 pS F=27MHz, VDD= 3.3V 220 400 pS F=27MHz, VDD =1.8V F=27MHz, integration bandwidth=12kHz to 5MHz, VDD =1.8V PK-PK Period Jitter T_jitt RMS Phase Jitter T_phj First year Aging F_aging - - 0.7 pS -1.5 - +1.5 PPM IOH=-4mA, IOL=4mA, Standard Drive 25 ºC 10-year Aging -5 +5 PPM Notes: 1: All electrical specifications in the above table are specified with 15pF output load and for all VDD unless otherwise stated. REV: V1.6 Notice: The information in this document is subject to change without notice. 1/6 LO2x1 Series Table2. Pin Configuration Pin Symbol 1 OE 2 GND Power Functionality H or Open, Specified frequency output L: output is high impedance. Only output driver is disabled. H or Open, Specified frequency output L: output is low. Device goes to sleep mode. Supply current reduces to I_std. Electrical ground 3 OUT Output Oscillator output 4 VDD Power Power supply voltage Output Enable PDB mode Table3. Absolute Maximum Attempted operation outside the absolute maximum ratings of the part may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Min. Max. Unit Storage Temperature Parameter -60 150 ºC VDD -0.5 7 V - 2000 V Soldering Temperature 260 ºC Junction Temperature 150 ºC Electrostatic Discharge Phase Noise Plot Figure 1. Phase Noise, 27MHz, 1.8V, LVCOMS Output REV: V1.6 Notice: The information in this document is subject to change without notice. 2/6 LO2x1 Series Test Circuit and Waveform Figure 2. Test Circuit Notes: 2. Duty Cycle is computed as Duty Cycle = TH/Period. Figure 3. Waveform Timing Diagram Figure 4. Startup Timing (OE mode) Figure 6. OE Enable Timing Figure 5. Standby Resume Timing (PDB mode) Figure 7. OE Disable Timing Ordering Information REV: V1.6 Notice: The information in this document is subject to change without notice. 3/6 LO2x1 Series Dimensions 3225 2520 REV: V1.6 Notice: The information in this document is subject to change without notice. 4/6 LO2x1 Series 2016 Marking Temperature Grade Temperature Range Frequency Stability (PPM) A -40~125℃(AEC-Q100 Grade1) ±100 E -40~105℃ (AEC-Q100 Grade2) ±30 P -40~105℃ ±30 I -40~85℃ ±20 REV: V1.6 Notice: The information in this document is subject to change without notice. 5/6 LO2x1 Series Revision History Revision Number Date of Release Changes 1.0 03/29/2021 1) 1.1 04/29/2021 1) 2) Ordering information Marking 1.2 05/21/2021 1) Add dimensions 1.3 09/09/2021 1) Add temperature range -40~125℃ 1.4 10/26/2021 1) Add I temperature Grade 1.5 12/06/2021 1) Update the AEC-Q100 Grade 1 1.6 11/15/2022 1) 2) 3) Modify the PPM in the marking information Updated the electrical characteristics. Updated the phase noise plot. REV: V1.6 Notice: The information in this document is subject to change without notice. Preliminary datasheet 6/6
LO211A-125.000M-50-A 价格&库存
很抱歉,暂时无法提供与“LO211A-125.000M-50-A”相匹配的价格&库存,您可以联系我们找货
