OC3EL89CJO-113YLC-26M 数据手册
Crystal Oscillator
AEC-Q200
YSO140TC
Applications
Features
‧Automotive
‧Frequency range: 1MHz-54MHz
electronics
‧AEC-Q200.
‧Package Size: 1.6*1.2, 2.0*1.6
2.5*2.0 , 3.2*2.5, 5.0*3.2, 7.0*5.0mm
Specifications(规格参数)
Item
Symbol
Specifications
f₀
1MHz to 54MHz, or specify
Vcc
1.8V~3.3V
CMOS
Frequency Tolerance(频率偏差) (at 25℃ )
f_tol
±50ppm, ±100ppm, or specify
Operating Temperature(工作温度)
T_use
-40~+125℃, or specify
Storage Temperature(储存温度)
T_stg
-55~+150℃
Duty Cycle(占空比)
SYM
45~55%
Start-up Time(启动时间)
t_str
3ms Max.
Rise Time/Fall Time(上升沿/下降沿)
tr/tf
5ns Max
Phase Jitter [12 kHz ~ 20 MHz](相位抖动)
tpj
0.7ps max
f_age
±3ppm/year Max.
Frequency Range(额定频率范围)
Supply Voltage(电源电压)
Output Type(输出方式)
Frequency Aging(老化)(at 25℃ )
Current Consumption(消耗电流)
Supply Voltage (V)
Power Dissipation Vcc=1.8~3.3V 15pF only
1.000~40.000MHZ
41.000~54.000MHZ
7050/5032/3225/2520/2016/1612
1.8V
4mA max
9mA max
2.5V
4.5mA max
10mA max
3.3V
5mA max
12mA max
Pin Dimension
Pin
#1
#2
#3
#4
FUNCTION
Tri-state
GND
OUTPUT
VDD
*The picture on the right is only for PIN function description.
www.yxc.hk
1
Crystal Oscillator
AEC-Q200
YSO140TC
Dimensions and Recommended land pattern(外观尺寸及推荐焊盘)
Package Size – Dimensions (Unit: mm)
www.yxc.hk
Recommended Land Pattern (Unit: mm)
2
Crystal Oscillator
AEC-Q200
YSO140TC
Notes:
1.A capacitor of value 0.01uf~0.1uf or higher between Vdd and GND is required.
Test Circuit(测试电路)
CMOS
www.yxc.hk
3
OC3EL89CJO-113YLC-26M 价格&库存
很抱歉,暂时无法提供与“OC3EL89CJO-113YLC-26M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.03280
- 10+4.05000
- 30+3.56400
- 100+3.07800
- 500+2.78640
- 1000+2.63520
