CO22H4-26.000-WPGDZSTL
    HCI(杭晶)
    SMD2520_4P
    有源晶振 26MHz ±10ppm 1.8V~3.3V-40℃~+125℃ HCMOS
CO22H4-26.000-WPGDZSTL 数据手册
O S C I L L A T O R U N I T CO22H4 OSCILLATOR UNIT WITH CMOS OUTPUT IN SMD 2.5X2.0MM CERAMIC SEAM SEAL PACKAGE. PRODUCT PHOTO (NOT IN SCALE) PRODUCT FEATURES  Small dimensions 2.5x2.0x0.55 with 4 solder pads.  Tight stabilities over temperature range.  Tri-state enable/ disable function (pad 1).  Automotive compliance to AEC-Q200 available.  RoHS compliant, LEAD-FREE, HALOGEN-FREE and REACH compliant. APPLICATIONS  WiFi / LAN / Bluetooth  Set-top Box / HDTV  Computer peripherals  DSC / PDA PRODUCT SPECIFICATIONS PARAMETER Frequency range 1.8V SUPPLY VOLTAGE 2.5V 1.25 ~ 125MHz 1.25 ~ 125MHz Frequency stability 3.3V 1.25 ~ 125MHz 32.768kHz available ±20ppm / ±25ppm / ±50ppm Operating temperature range REMARKS See note below –10 to +60°C / –20 to +70°C / –40 to +85°C Options up to +125°C ±3.0ppm Aging first year Supply current 7mA @+25°C 10mA Output waveform and load 15mA LVCMOS 15pF With load 15pF 30pF optional Output voltage level HIGH 1.62V 2.25V 2.97V Minimum Output voltage level LOW 0.18V 0.25V 0.33V Maximum 5ns 4ns 3ns
CO22H4-26.000-WPGDZSTL 价格&库存
很抱歉,暂时无法提供与“CO22H4-26.000-WPGDZSTL”相匹配的价格&库存,您可以联系我们找货
