TXC CORPORATION
www.txccorp.com
SPECIFICATION FOR APPROVAL
CN:
CUSTOMER
PRODUCT TYPE
SMD SEAM SEALING X'TAL 3.2×2.5
NOMINAL FREQ.
16.000000MHz
TXC P/N
AM16000602
REVISION
A1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER
CONFIRMATION
(Singnature)
(Date)
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
MSL:Level 1
RoHS Compliant
FMT-DOC015 VER.C
TXC confidential and proprietary document
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
CN:
PRODUCT TYPE
NOMINAL FREQ.
16.000000MHz
TXC P/N
AM16000602
REVISION
A1
PE/RD
QA
Wen yuan Chang ZhongLin Wu
2-Jan-19
2-Jan-19
MFG
Zhi jun Wu
2-Jan-19
NOTE:
(1) TXC green product standard is based on the international standards. Relevant
information is posted on the TXC website and updated regularly. The documentation is
subject to the latest green product quality system.
(2) Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3) Revision "Ax" is production ready. PE, QA and MFG's approval required.
MSL:Level 1
RoHS Compliant
FMT-DOC015 VER.C
TXC CORPORATION
Rev
Revise page
S1
N/A
A1
N/A
FMT-DOC015 VER.C
TXC P/N:
Revise contents
AM16000602
REVISION: A1
PAGE: 1
Date
Ref.No.
Reviser
Initial released
9-Apr-18
N/A
Xiaohua Zhang
S Turn A
2-Jan-19
N/A
Xiaohua Zhang
TXC CORPORATION
TXC P/N:
AM16000602
REVISION: A1
PAGE: 2
Spec Sheet Contents
No.
Content
Page
1
ELECTRICAL SPECIFICATIONS & Attention
P.3
2
DIMENSIONS
P.4
3
MARKING
P.4
4
FACTORY LOCATION
P.4
5
SUGGESTED REFLOW PROFILE & MANUAL SOLDER CONDITION
P.4
6
STRUCTURE ILLUSTRATION
P.5
7
EMBOSS CARRIER TAPE & REEL
P.6
8
PACKING
P.7
9
RELIABILITY SPECIFICATIONS
P.8
FMT-DOC015 VER.C
TXC CORPORATION
TXC P/N:
AM16000602
REVISION: A1
PAGE: 3
■ ELECTRICAL SPECIFICATIONS
Parameters
SYM.
Electrical Spec.
MIN
TYPE
MAX
Notes
UNITS
FL
16.000000
MHz
Fundamental
CL
12
pF
4 Frequency Tolerance
±20
ppm
at 25 ℃ ± 3 ℃
5 Frequency Stability
±80
ppm
Over Operating Temp. Range (Reference 25℃)
6 Operating Temperature
7 Aging
1 Nominal Frequency
2 Oscillation Mode
3 Load Capacitance
-40
125
±3
ppm
1st Year at 25 ℃ ± 3 ℃
8 Drive Level
DL
50
100
μW
9 Effective Resistance Rr
Rr
120
Ω
10 Shunt Capacitance C0
C0
2
pF
11 Insulation Resistance
500
MΩ
12 Storage Temperature Range
-40
125
at DC 100V
Measure equipment
Electrical characteristics measured by S&A 250B or equivalent.
Unit Weight:
0.018±0.001 g/pcs
■ Attention (注意事項) :
1. If you intend to use product on controls relating to medical equipment, aeronautical equipment, aerospace, military science,
space equipment, etc.) please do not fail to advise us of your intention beforehand.
請勿將本產品使用在醫療,航空,宇航,軍事或與生命安全性相關的設備中,若需使用在上述應用請事前與TXC聯繫。
2. Crystal units will be damaged by ultrasonic welding process due to resonance of crystal wafer itself.
If ultrasonic welding used, TXC strongly recommend verifying damage by ultrasonic weld.
本產品在超音波封合的過程中晶片可能會因共振受損,若有超音波封合需求,TXC強烈建議應給予適當的驗證。
FMT-DOC015 VER.C
TXC CORPORATION
TXC P/N:
AM16000602
■ DIMENSIONS
REVISION: A1
PAGE: 4
Unit:mm
0.70 ± 0.10
3.20 ± 0.10
(Unit:mm)
GND
3
3
4
2.50 ± 0.10
4
1
GND
2
1
2
1.20±0.10
1.00±0.10
2
4
3
0.80 1.40
1.40
0.70±0.10
Bottom View
■ MARKING
1.20
0.50
1.20
1
0.90±0.10
Internal View Connection
Suggested Layout
T□□□
TXC Logo
Frequency Code
ex: 16.000000 MHz = 160
Lot Code
Date Code
Production Control Code
Month Code:
MONTH
YEAR
JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC
2005
2009
2013
2017
2021
A
B
C
D
E
F
G
H
J
K
L
M
2006
2010
2014
2018
2022
N
P
Q
R
S
T
U
V
W
X
Y
Z
2007
2011
2015
2019
2023
a
b
c
d
e
f
g
h
j
k
l
m
2008
2012
2016
2020
2024
n
p
q
r
s
t
u
v
w
x
y
z
*This month code will be cycled every four years
Production location: Taiwan & China (Ningbo)
10 sec
260
220
■ SUGGESTED REFLOW PROFILE
Peak Temperature : 260±5℃, 10 sec. Max.
Solder melting point : 220±10 ℃, 60 sec. Min.
180
150
Reflow passage time : twice
Time (sec)
■ SUGGESTED MANUAL SOLDER CONDITION
120 sec
60 sec
Pressing a soliding iron of 350 ℃ on the terminal electrode for 4 seconds (twice).
NOTE: After manual welding, the product should be placed at least 2 hours
FMT-DOC015 VER.C
TXC CORPORATION
TXC P/N:
AM16000602
REVISION: A1
PAGE: 5
■ STRUCTURE ILLUSTRATION
NO
COMPONENTS
1 Lid
MATERIALS
FINISH/SPECIFICATIONS
Kovar (Fe/Co/Ni)
Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu
2 Package
3 PAD
Au
Tungsten metalize
+ Ni plating
+ Au plating
4 Crystal blank
SiO2
5 Conductive adhesive Resin+Ag
Silicon resin
6 Electrode
FMT-DOC015 VER.C
Noble Metal
TXC CORPORATION
TXC P/N:
AM16000602
REVISION: A1
PAGE: 6
■ PACKING
F
G
B
E
H
INDEX MARK
A
DIMENSIONS
REMARK :
C
Feeding
D
A
B
C
D
E
F
G
H
1.65
3.40
2.70
4.00
8.00
4.00
1.50
1.75
160mm min
160mm min
3000pcs Products
400mm min
T
T
T
T
Trailer
(UNIT : mm)
Empty Sealed
Leader
User Direction of Feeding
W
W1
2.0
L1
DIMENSIONS
FMT-DOC015 VER.C
L
178.0
L1
13.0
W
11.5
W1
8.0
L
pcs / Reel (UNIT : mm)
Standard Reel Quantity is 3,000 pcs per reel
TXC CORPORATION
TXC P/N:
AM16000602
REVISION: A1
PAGE: 7
■PACKING
Box Item:
1. Reel X 6
2. Reel X 12
3. Reel X 25
4. Reel X 50
5. Reel X 100
(L200 X W200 X H140mm)
(L200 X W200 X H250mm)
(L400 X W400 X H280mm)
(L399 X W346 X H360mm)
Note:
1. For the maximum reel of loads for each type box.
Label
Tape
Tape
shipping mark
Customer Information
Label :
[STORAGE]
1.Do not get wet by the rain.
2.The storage environment shall be 5℃ ~40℃ and 30% ~ 75%RH humidity and avoid exposure to sunlight.
3.If customers have special requirements, we can coordinate.
FMT-DOC015 VER.C
TXC CORPORATION
TXC P/N:
AM16000602
REVISION: A1
PAGE: 8
■ RELIABILITY SPECIFICATIONS (AEC-Q200 Compliant)
1.Mechanical Endurance
No.
Test Item
1.1 Drop Test
Test Methods
REF.DOC
JIS C 6701
120 cm height, 10 times on Stainless Plate .
1.2 Mechanical Shock
1.3 Vibration
Device are shocked to half sine wave ( 3000 G ) three mutually
perpendicular axes each 3 times. 0.3m sec. duration time
Frequency range
10 ~ 2000 Hz~10 Hz
Amplitude
1.52 mm/10G
Sweep time
20 minute
Perpendicular axes each test time
4 Hrs
MIL-STD-202
Method 213
MIL-STD-202
Method 204
(Total test time 12 Hrs)
Temperature
1.4 Solderability
245 ℃ ± 5℃
Immersing depth
1.25 mm
Immersion time
5 ± 1 seconds
Flux
J-STD-002
Rosin resin methyl alcohol
solvent ( 1 : 4 )
1.5 Terminal Strength
Mount on PCB board and shear strength 1.8kg for 60 sec.
AEC-Q200-006
1.6 Board Flex
Duration Time: 60 sec, Deviation: 3mm
AEC-Q200-005
2.Environmental Endurance
No.
Test Item
Test Methods
Pre-heat temperature
2.1 Resistance To Soldering Heat
REF. DOC
125 ℃
Pre-heat time
60 ~ 120 sec.
Test temperature
260 ± 5 ℃
Test time
10 ± 1 sec.
2.2 High Temp. Storage
+ 125 ℃ ± 3 ℃ for all 1000 Hrs.
2.3 Low Temp. Storage
- 55 ℃ ± 3 ℃ for all 1000 Hrs.
MIL-STD 202
Method 210
MIL-STD-202
Method 108
JIS C 6701
Total 1000 cycles of the following Thermal Shock :
1 cycle
2.4 Thermal Shock
125+/-3℃
25 ℃
-55+/-3 ℃
30min.
30 min.
MIL-STD-202
Method 107
20sec.Max.
2.5 Temperature Cycle
2.6 Biased Humidity
2.7 Moisture Resistance
2.8 Operational Life
FMT-DOC015 VER.C
Total 1000 cycles of the following temperature cycle :
- 55℃ ± 3 to 125℃ ± 3 , Dwell time:30min.
JESD 22
Method JA-104
+ 85℃ ± 3℃ , RH 85% , 1000 Hrs.
MIL-STD-202
Method 103
20 cycles ( +25℃~65℃ , 80%~100% RH) , 24hrs/cycle.
MIL-STD 202
Method 106
+ 125 ℃ ± 3 ℃ for 1000 Hrs.
MIL-STD-202
Method 108
很抱歉,暂时无法提供与“AM16000602”相匹配的价格&库存,您可以联系我们找货
