CMOS XO
7X Series
Think of Frequency, Think of TXC
Product Features
1.
2.
3.
4.
5.
6.
7.
8.
9.
Application:
Output Frequency:1 ~ 200MHz
NB , PC , Tablet , Smartphone , PC peripherals , IPC ,
Frequency Stability : ± 25 , ± 50 ppm
Server , Storage , Ethernet , USB , etc.
Supply Voltage : 1.8 , 2.5 , 3.3V
Audio ADC , Video , AI Vision Processing Unit , CPLD ,
Operating Temperature:-40~105℃
FPGA , CPU , GPU , MCU , BMC , etc.
Output Type : CMOS
Phase Jitter:1ps (Max.) @100MHz , 3.3V
RoHS and REACH Compliant , Pb-free , Halogen-free
Fast Delivery
Industry Standard Package:
3.2 x 2.5 x 1.0 mm
Test condition
Ambient temperature:25 ± 5℃
Relative humidity: 40% ~ 70%
Table 1 . Electrical Specifications
Parameters
Symbol
Min.
Typ.
Max.
Units
Notes
Frequency Range and Stability
Nominal Frequency
F
Frequency Tolerance
FT
1 ~ 156.25
MHz
1 ~ 125
± 25
ppm
± 50
@ 2.5 V 、3.3 V
@ 1.8 V
@ -40~85℃ , Note 1
@ -40~105℃ , Note 1
Operating Temperature Range
Topr
-40
25
105
Supply Voltage and Current Consumption
Supply Voltage
Vdd
Current Consumption
Icc
25
mA
Icc(ST)
10
uA
Standby Current
1.8 , 2.5 , 3.3 (± 10%)
V
OE = Low
CMOS Type Signal Characteristics
Output Load : CMOS
CL
Output Voltage High
VoH
Output Voltage Low
VoL
Rise Time
Tr
Fall Time
Tf
Symmetry (Duty ratio)
TH/T
15
pF
90%Vdd
Vdd-0.4
10%Vdd
0.4
5
ns
10% → 90% Vdd Level
4
ns
20% → 80% Vdd Level
5
ns
90% → 10% Vdd Level
4
ns
80% → 20% Vdd Level
45
55
V
V
Vdd @ 2.5 or 3.3 V
Vdd @ 1.8 V
Vdd @ 2.5 or 3.3 V
Vdd @ 1.8 V
Note 1: Inclusive of frequency tolerance at 25℃ , variation over temperature, supply voltage variation, aging and vibration.
Rev. A (2023.11.27)
Page 1 of 3
www.txc.com.tw
CMOS XO
7X Series
Test condition
Table 1 . Electrical Specifications (continued)
Parameters
Symbol
Min.
Typ.
Max.
Units
Notes
Startup and Resume time
Start-up Time
Output Disable Delay Time
Output Enable Delay Time
Tosc
10
ms
T off
250
us
T on
300
us
To 90% of Final Amplitude
Enable Pin Control and Input Characteristics
Enable Control
Yes
Enable Voltage High
VIH
70%Vdd
V
Disable Voltage Low
VIL
30%Vdd
V
Pad 1
Aging Performance
Aging
±3
ppm/yr.
1st. Year at 25℃
Jitter Performance
RMS Phase Jitter
Fout range:10MHz~40MHz
@ Integrated from 12KHz ~ 5MHz
Note1
PJ
1.0
ps
PJ
1.0
ps
RMS Phase Jitter
Fout range:40MHz~200MHz
@ Integrated from 12KHz ~ 20MHz
Note1
Note 1 : Phase Jitter will be slightly different according to output frequency and supply voltage.
Test Diagram
Pad 1(OE)
Pad 3 (Output)
Oscillator
High (or open)
OSC out
Normal operation
Low
High impedance
Stop oscillation
Note : TXC sets CL to 15pF for simulation IC load. Customer does not need to layout it in reality circuit.
Rev. A (2023.11.27)
Page 2 of 3
www.txc.com.tw
CMOS XO
7X Series
Waveform Conditions
Waveform measurement system should have a min. bandwidth of 5 times the frequency being tested.
Dimensions & Footprint (Recommended)
Unit:mm
1.00±0.10
3.20±0.10
3
PAD FUNCTION:
2.50±0.10
4
2: GND
3: OUT
2
2
4
3
0.80 1.40
1.20
0.50
1
1.40
1.20
1.20±0.15
Suggested Layout
1.00±0.15
0.90±0.15
1: ENABLE CONTROL
4: VDD
1
0.65±0.15
Rev. A (2023.11.27)
Page 3 of 3
www.txc.com.tw
很抱歉,暂时无法提供与“7X25000600”相匹配的价格&库存,您可以联系我们找货
