7X02000602
7X02000602
    TXC(台晶)
    SMD3225_4P
    特性:输出频率:1 ~ 200MHz。 频率稳定性:± 25 ppm、± 50 ppm。 电源电压:1.8V、2.5V、3.3V。 工作温度:- 40℃ ~ 105℃。 输出类型:CMOS。 相位抖动...
7X02000602 数据手册
CMOS XO 7X Series Think of Frequency, Think of TXC Product Features 1. 2. 3. 4. 5. 6. 7. 8. 9.  Application: Output Frequency:1 ~ 200MHz  NB , PC , Tablet , Smartphone , PC peripherals , IPC , Frequency Stability : ± 25 , ± 50 ppm Server , Storage , Ethernet , USB , etc. Supply Voltage : 1.8 , 2.5 , 3.3V  Audio ADC , Video , AI Vision Processing Unit , CPLD , Operating Temperature:-40~105℃ FPGA , CPU , GPU , MCU , BMC , etc. Output Type : CMOS Phase Jitter:1ps (Max.) @100MHz , 3.3V RoHS and REACH Compliant , Pb-free , Halogen-free Fast Delivery Industry Standard Package: 3.2 x 2.5 x 1.0 mm Test condition Ambient temperature:25 ± 5℃ Relative humidity: 40% ~ 70% Table 1 . Electrical Specifications Parameters Symbol Min. Typ. Max. Units Notes Frequency Range and Stability Nominal Frequency F Frequency Tolerance FT 1 ~ 156.25 MHz 1 ~ 125 ± 25 ppm ± 50 @ 2.5 V 、3.3 V @ 1.8 V @ -40~85℃ , Note 1 @ -40~105℃ , Note 1 Operating Temperature Range Operating Temperature Topr -40 25 105 ℃ Supply Voltage and Current Consumption Supply Voltage Vdd Current Consumption Icc - - 25 mA Icc(ST) - - 10 uA Standby Current 1.8 , 2.5 , 3.3 (± 10%) V OE = Low CMOS Type Signal Characteristics Output Load : CMOS CL Output Voltage High VoH Output Voltage Low VoL Rise Time Tr Fall Time Tf Symmetry (Duty ratio) TH/T 15 pF 90%Vdd - - Vdd-0.4 - - - - 10%Vdd - - 0.4 - - 5 ns 10% → 90% Vdd Level - - 4 ns 20% → 80% Vdd Level - - 5 ns 90% → 10% Vdd Level - - 4 ns 80% → 20% Vdd Level 45 ~ 55 % V V Vdd @ 2.5 or 3.3 V Vdd @ 1.8 V Vdd @ 2.5 or 3.3 V Vdd @ 1.8 V Note 1: Inclusive of frequency tolerance at 25℃ , variation over temperature, supply voltage variation, aging and vibration. Rev. A (2023.11.27) Page 1 of 3 www.txc.com.tw CMOS XO 7X Series Think of Frequency, Think of TXC  Test condition Ambient temperature:25 ± 5℃ Relative humidity: 40% ~ 70% Table 1 . Electrical Specifications (continued) Parameters Symbol Min. Typ. Max. Units Notes Startup and Resume time Start-up Time Output Disable Delay Time Output Enable Delay Time Tosc - - 10 ms T off - - 250 us T on - - 300 us To 90% of Final Amplitude Enable Pin Control and Input Characteristics Enable Control - Yes - Enable Voltage High VIH 70%Vdd - - V Disable Voltage Low VIL - - 30%Vdd V Pad 1 Aging Performance Aging ±3 - ppm/yr. 1st. Year at 25℃ Jitter Performance RMS Phase Jitter Fout range:10MHz~40MHz @ Integrated from 12KHz ~ 5MHz Note1 PJ - - 1.0 ps PJ - - 1.0 ps RMS Phase Jitter Fout range:40MHz~200MHz @ Integrated from 12KHz ~ 20MHz Note1 Note 1 : Phase Jitter will be slightly different according to output frequency and supply voltage.  Test Diagram Pad 1(OE) Pad 3 (Output) Oscillator High (or open) OSC out Normal operation Low High impedance Stop oscillation Note : TXC sets CL to 15pF for simulation IC load. Customer does not need to layout it in reality circuit. Rev. A (2023.11.27) Page 2 of 3 www.txc.com.tw CMOS XO 7X Series Think of Frequency, Think of TXC  Waveform Conditions Waveform measurement system should have a min. bandwidth of 5 times the frequency being tested. Dimensions & Footprint (Recommended) Unit:mm 1.00±0.10 3.20±0.10 3 PAD FUNCTION: 2.50±0.10 4 2: GND 3: OUT 2 2 4 3 0.80 1.40 1.20 0.50 1 1.40 1.20 1.20±0.15 Suggested Layout 1.00±0.15 0.90±0.15 1: ENABLE CONTROL 4: VDD 1 0.65±0.15  Rev. A (2023.11.27) Page 3 of 3 www.txc.com.tw
