CXAF-025000-3-AL-39
CXAF-025000-3-AL-39
    AKER(安碁科技)
    SMD3225_4P
    25MHZ ±10PPM 12PF
CXAF-025000-3-AL-39 数据手册
Confidential Customer Name : Customer P/N : Frequency : Aker Approved P/N: Aker MPN : Rev. : ISSUE DATE 25.000000 MHz CXAF-025000-3-AL-39 CXAF-025000-3-AL-39 1 : Mar.7.2024 APPROVED CHECKED Xtal PREPARED Kiku APPROVED BY CUSTOMER AKER TECHNOLOGY CO., LTD. ADDRESS : NO 11-3, Jianguo Rd., Tanzi Dist., Taichung City 427, Taiwan. TEL:886-4-25335978 Web: www.aker.com.tw FAX : 886-4-25336011 MSL:Level 1 RoHS compliance IATF 16949 Certified AEC-Q200 Qualified Aker Approved P/N : APPROVED : PREPARED : CXAF-025000-3-AL-39 SHEET : 1 of 8 Xtal REV . : 1 Kiku Confidential Rev. Date Reviser Revise contents 1 2024/3/7 Kiku Initial Released Aker Approved P/N : APPROVED : PREPARED : CXAF-025000-3-AL-39 SHEET : 2 of 8 Xtal REV . : 1 Kiku Confidential SMD CRYSTAL SPECIFICATION 1 . ELECTRICAL CHARACTERISTICS Standard atmospheric conditions Unless otherwise specified , the standard range of atmospheric conditions for making measurement and tests are as follow : Ambient temperature : 25±5℃ Relative humidity : 40%~70% If there is any doubt about the results , measurement shall be made within the following limits : Ambient temperature : 25±3℃ Relative humidity : 40%~70% AKER Model : CXAF-321 Oscillation Mode : Fundamental Cutting Mode : AT CUT Measurement Equipment : 250B(Measured FL) Insulation Resistance : More than 500M ohms at DC 100V Electrical Spec Parameters Nominal Frequency Symbol Min. FL Typ. Max. 25.000000 Notes Units. MHz Frequency Tolerance ±10 ppm at 25℃ ± 3℃ Frequency Stability ±50 ppm Operating Temp (Refer 25℃) Load Capacitance CL 12 Aging pF ppm First Year at 25℃ ±3 Operating Temperature -40 ~ 125 ℃ Storage Temperature Range -55 ~ 150 ℃ Drive Level DL 100 uW Equivalent Series Resistance ESR 50 Ω C0 3 pF Shunt Capacitance @Series *Please kindly be noted that AKER DO NOT guarantee parts quality which involves human security application.* Aker Approved P/N : APPROVED : PREPARED : CXAF-025000-3-AL-39 SHEET : 3 of 8 Xtal REV . : 1 Kiku Confidential 2 . MARKING : 25.0 AK AQ AKER LOGO. ' FREQUENCY code & Internal identification code 1 Date Code:Please refer to the following table. Internal identification code 2 Date Code Table 3 . DIMENSION : ( Unit : mm ) Aker Approved P/N : APPROVED : PREPARED : CXAF-025000-3-AL-39 SHEET : 4 of 8 Xtal REV . : 1 Kiku Confidential 4 . STRUCTURE ILLUSTRATION A C B D G N I K R A M E Aker Approved P/N : APPROVED : PREPARED : CXAF-025000-3-AL-39 SHEET : 5 of 8 Xtal REV . : 1 Kiku Confidential 5 . PACKING : TAPE SPECIFICATION ( Unit : mm ) Feeding 180 ± 3 ( Unit : mm ) 60.5 ± 2 OUTLINE DIMENSION 13.2 9 ± 1.0 12 ± 1.5 2.5 Aker Approved P/N : APPROVED : PREPARED : 6. COVER TAPE ADHESION STRENGTH: 7 . SOLDERING REFLOW PROFILE CXAF-025000-3-AL-39 SHEET : 6 of 8 Xtal REV . : 1 Kiku Confidential Aker Approved P/N : APPROVED : PREPARED : CXAF-025000-3-AL-39 SHEET : 7 of 8 Xtal REV . : 1 Kiku Confidential 8. PACKING : 185mm 183mm 36mm BOX = 3000 PCS / REEL(MAX) Stuff 210mm 625mm 390mm SMD product packs 32 BOX=The outside box packs (3000 PCS *32 BOX = 96000 PCS)(MAX) Aker Approved P/N : APPROVED : PREPARED : CXAF-025000-3-AL-39 SHEET : 8 of 8 Xtal REV . : 1 Kiku Confidential 9 . MECHANICAL PERFORMANCE TEST ITEMS 9.1 Temperature Cycling TEST METHODS AND TEST CONDITION PERFORMANCE -55±3℃/30min maximum~+125±3℃/30min maximum, 1000cycles 9.2 Operational Life 125℃±3°C,1000hrs±12hrs 9.3 Biased Humidity 85°C±5°C&85%±5%R.H.,1000±12hrs 9.4 Resistance To Soldering Heat Test Reflow test 2 times. 9.5 High Temperature Exposure 150℃±3°C,1000hrs±12hrs 9.6 Vibration Test Freq.range: 10~2000Hz,Peak to peak amplitude:1.52mm Peak acceleration:5G (49m/s2),3 direction(X, Y,Z) ,20min 12cycles each of 3 orientations. 9.7 Mechanical Shock 100G,6mS,3 times for each direction(X, Y, Z ), 3 cycles 9.8 Physical Dimension Verify physical dimensions to the applicable device detail specification. 9.9 Solderability 260℃,Coated > 95% 9.10 Board Flex PCB=100*40(mm),Bending=2 mm (min), Duration=60+5/-0 sec 9.11 External Visual Inspect device construction and marking. 9.12 Terminal Strength A force of 17.7N for 60 seconds. To satisfy the electrical performance .
CXAF-025000-3-AL-39 价格&库存
很抱歉,暂时无法提供与“CXAF-025000-3-AL-39”相匹配的价格&库存,您可以联系我们找货
CXAF-025000-3-AL-39
    • 1+2.93760
    • 10+2.32200
    • 30+2.06280
    库存:39
