SWXCBACVF0-24.000000
    STARWAVE(思大)
    SMD3225_4P
    无源晶振 24MHz ±10ppm 12pF 60Ω -40℃~+85℃
SWXCBACVF0-24.000000 数据手册
B303-30 Tian an Cyber Park ,Huangge North Road ,Longgang District ,Shen Zhen , China TEL :+86(0)755-8327-9247 Fax :+86(0)755-8327-9247 http://www.starwavecorp.com E-mail :info@starwavecorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : SMD SEAM SEALING X'TAL 3.2*2.5 NOMINAL FREQ. : 24.000000MHz STARWAVE P/N : SWXCBACVF0-24.000000 REVISION : A1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) STAR requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by STAR after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. RoHS Compliant FMT-DOC024 Issue Date: 03.09'06 VER.D B303-30 Tian an Cyber Park ,Huangge North Road ,Longgang District ,Shen Zhen , China TEL :+86(0)755-8327-9247 Fax :+86(0)755-8327-9247 http://www.starwavecorp.com E-mail :info@starwavecorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : SMD SEAM SEALING X'TAL 3.2*2.5 NOMINAL FREQ. : 24.000000MHz STARWAVE P/N : SWXCBACVF0-24.000000 REVISION : A1 PE/RD QA MFG 09-Jan-24 09-Jan-24 09-Jan-24 NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required. RoHS Compliant FMT-DOC024 Issue Date: 03.09'06 VER.D P/N:SWXCBACVF0-24.000000 Rev Revise page A1 N/A FMT-DOC024 Revise contents Initial release REVISION: A1 PAGE: 1 Date Ref.No. Reviser 09-Jan-24 N/A Yachuan Miao Issue Date: 03.09'06 VER.D P/N:SWXCBACVF0-24.000000 REVISION: PAGE: A1 2 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by HP E5100A or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.018±0.001 g/pcs Parameters SYM. Electrical Spec. MIN TYPE MAX FL 24.000000 MHz 2 Oscillation Mode - Fundamental 3 Load Capacitance CL 4 Frequency Tolerance - 5 Frequency Tolerance - 6 Operating Temperature - 7 Aging - 1 Nominal Frequency - - pF - ±10 ppm shift to -5ppm at 25 ℃ ± 3 ℃ ppm Over Operating Temp. Range (Reference 25℃) ~ - 9 Effective Resistance Rr Rr - - 10 Shunt Capacitance C0 C0 - 5.0 11 Motional Capacitance C1 C1 - 12 Insulation Resistance - 500 13 Storage Temperature Range - 14 Pulling Sensitivity - FMT-DOC024 85 ±3 DL 8 Drive Level - 12 ±30 -40 Notes UNITS - ℃ ppm 1st Year uW - 60 Ω - - pF - 3.0 - fF - - - MΩ -40 ~ - ~ 125 19 ℃ 15 ppm/pF - 10 - at DC 100V Issue Date: 03.09'06 VER.D P/N:SWXCBACVF0-24.000000 REVISION: A1 PAGE: 3 ■ DIMENSIONS 0.7±0.1 3.20±0.1 GND 4 2.50±0.1 3 4 MARKING 1 2 3 2 GND 1 Internal View Connection 1.15 3 1 2 0.7 4 1.00 0.65 0.90 1.2 Top View Suggest Layout Units:mm ■ MARKING   Marking (℃) ■ SUGGESTED REFLOW PROFILE Total time : 200 sec. Max. Solder melting point :220 ℃ 10 sec 260 220 180 150 Time (sec) 120 sec FMT-DOC024 60 sec Issue Date: 03.09'06 VER.D P/N:SWXCBACVF0-24.000000 REVISION: A1 PAGE: 4 ■ STRUCTURE ILLUSTRATION NO COMPONENTS QTY MATERIALS FINISH/SPECIFICATIONS 1 Lid Kovar (Fe/Co/Ni) 1 - 2 Base(Package) Ceramic (AI 2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu 1 Color black 3 PAD Au 4 Tungsten metalize + Ni plating + Au plating 4 Crystal blank SiO2 1 - 5 Conductive adhesive Ag 4 Silicon resin 6 Electrode 2 - FMT-DOC024 Au + Cr Issue Date: 03.09'06 VER.D P/N:SWXCBACVF0-24.000000 A1 REVISION: PAGE: 5 ■ PACKING : (EIA-481-2) F G B E H INDEX MARK A DIMENSIONS C Feeding D A B C D E F G H 1.40 3.40 2.70 4.00 8.00 4.00 1.50 1.75 (UNIT : mm) REMARK : Trailer Parts 160mm(Min) Leader Empty Sealed 230mm(Min) 160mm(Min) User direction of feed W W1 2.0 L1 DIMENSIONS FMT-DOC024 L L1 W W1 178 13 11.5 8 L pcs / Reel (UNIT : mm) Standard Reel Quantity is 3,000 pcs per reel Issue Date: 03.09'06 VER.D P/N:SWXCBACVF0-24.000000 REVISION: A1 PAGE: 6 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance No. Test Item 1.1 Drop Test 1.2 Mechanical Shock 1.3 Vibration Test Methods REF.DOC 150 cm height, 3 times on concrete floor. JIS C6701 Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minute Perpendicular axes each test time 4 hours MIL-STD-202F MIL-STD-883E (Total test time 12 hours) 1.4 Gross Leak Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2Kg / cm2 1.5 Fine Leak Helium Bombing 4.5 Kg/ cm 2 for 2 hr 1.6 Solder ability MIL-STD-883E Temperature 260 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol MIL-STD-883E solvent ( 1 : 4 ) 2.Environmental Endurance No. Test Item 2.1 Resistance To Soldering Heat Test Methods Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. 2.2 High Temp. Storage + 125 ℃ ± 3 ℃ for 500 ± 12 hours 2.3 Low Temp. Storage - 40 ℃ ± 3 ℃ for 500 ± 12 hours REF. DOC MIL-STD-202F MIL-STD-883E Total 100 cycles of the following temperature cycle 1 cycle 125 ± 3 ¢J 2.4 Thermal Shock MIL-STD-883E 25 ¢J -55 ± 3 ¢J 30 min. 30 min. 10 min. max. 2.5 High Temp&Humidity 85℃ ± 3℃, RH 85% , 500Hrs JIS C5023 2.6 Pressure Cooker Storage 121 ± 3℃ , RH100% , 2 bar , 240Hrs JIS C6701 FMT-DOC024 Issue Date: 03.09'06 VER.D
SWXCBACVF0-24.000000 价格&库存
很抱歉,暂时无法提供与“SWXCBACVF0-24.000000”相匹配的价格&库存,您可以联系我们找货
  • 5+0.56916
  • 50+0.44993
  • 150+0.39032
  • 500+0.34560
库存:2085
