0132M4-32.000F12.5DTNJL
    HCI(杭晶)
    SMD3225_4P
    无源晶振 32MHz ±10ppm 12.5pF 33Ω -40℃~+85℃
0132M4-32.000F12.5DTNJL 数据手册
QUARTZ CRYSTAL UNIT 0132M4 QUARTZ CRYSTAL UNIT SMD 3.2X2.5MM IN CERAMIC SEAM SEAL PACKAGE. PRODUCT FEATURES PRODUCT PHOTO (NOT IN SCALE)  Small dimensions 3.2x2.5x0.6 with 4 solder pads.  Highly reliable vacuum seam sealed ceramic package.  Tight tolerances and stabilities over temperature range.  Automotive compliance to AEC-Q200.  RoHS compliant, LEAD-FREE and HALOGEN-FREE. APPLICATIONS  Wireless LAN  Bluetooth  Mobil communication  Handheld equipment PRODUCT SPECIFICATIONS 0132M4 PARAMETER Nominal frequency range CONDITIONS / REMARKS 8.000 ~ 60.000MHz Crystal cut and mode AT-cut Frequency tolerance ±10ppm Frequency stability Operating temperature range / / —- Fundamental ±20ppm / —- ±30ppm Other options available. ±10ppm ±15ppm Other options available. –20 to +70°C –30 to +85°C Other options available. Equivalent series resistance Load capacitance
0132M4-32.000F12.5DTNJL 价格&库存
很抱歉,暂时无法提供与“0132M4-32.000F12.5DTNJL”相匹配的价格&库存,您可以联系我们找货
