TEMPERATURE COMPENSATED
CRYSTAL OSCILLATOR
8132H
TCXO UNIT
WITH
HCMOS
SMD 3.2X2.5MM
OUTPUT IN
CERAMIC SEAM SEAL PACKAGE.
PRODUCT FEATURES
PRODUCT PHOTO
(NOT IN SCALE)
Small dimensions 3.2x2.5x1.1 with 4 solder pads.
Tight stabilities over temperature range.
RoHS compliant, LEAD-FREE, HALOGEN-FREE and REACH compliant.
APPLICATIONS
WiMAX / WLAN / Ethernet
Telecommunication
Mobil applications
PRODUCT SPECIFICATIONS
PARAMETER
1.8V
SUPPLY VOLTAGE
2.5V
Frequency range
3.3V
9.5 ~ 60MHz
Frequency tolerance
±2.0ppm
Frequency stability
±2.5ppm
Operating temperature range
Initial tol. @+25°C
5.0ppm
±10ppm
–40 to +85°C / –40 to +90°C / –40 to +105°C
Aging per year
±1.0ppm
Output waveform and load
REMARKS
See note below table
In combination to
above stabilities.
@+25°C
LVCMOS 15pF
Output voltage level HIGH
90%Vcc
Minimum
Output voltage level LOW
10%Vcc
Maximum
Rise and Fall times
8ns
8ns
Symmetry (duty cycle)
8ns
45~55%
Phase noise (example 26MHz)
@ 50%VCC
-110dBc/Hz / -130dBc/Hz / -145dBc/Hz
Phase jitter RMS
8132H-33.333ML33DTL 价格&库存
很抱歉,暂时无法提供与“8132H-33.333ML33DTL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 型号:8132H-33.333ML33DTL
- 品牌:HCI(杭晶)
- 封装:SMD3225_4P
- 描述:高精度,高稳定性,TCXO,封装尺寸:3225,4P,频率:33.333MHz,输出方式:CMOS,工作电压:3.3V,初始精度:±1.5ppm,工作温度:-40℃~+85℃,频率稳定度:±2ppm
- 国内价格
- 1+25.49556
- 10+21.79224
- 30+19.59552
- 100+17.36964
- 品牌:HCI(杭晶)
- 封装:SMD3225_4P
- 国内价格
- 1+27.03800
- 100+24.57400
- 750+23.87000
- 1500+23.39700
- 3000+22.93500
