川晶科技
Quartz Crystal Units
2520
3225
[ 2.5×2.0×0.55 mm ]
[ 3.2×2.5×0.70 mm ]
Frequency Range
Fundamental
8MHz~125MHz
Surface Mount Crystals
Features
Ÿ Small size SMD crystal units with 2.5×2.0 (2520), 3.2×2.5 (3225),
seam sealed package or glass sealed package.
Ÿ The entire package can be grounded via the top metal lid and the
bottom pads
Ÿ
Small footprint. Ideal for space constrained applications
Ÿ Exhibits extremely low aging with a high shock & vibration
resistance
Ÿ Applications: Mobile phone, Wl-LAN, Wireless communications,
Bluetooth, Clock for MPU, Radio communications, etc.
Standard Specifications
Item / Type
2520
Frequency Range
12~54 MHz (Fund.)
3225
Load Capacitance
8~125 MHz(Fund.)
8pF~32pF, or specify
10 0 µW typica l
Drive Level
Frequency Tolerance (at 25°C)
± 10ppm, ±20ppm or ±30ppm (max.)
Aging
±3ppm / Year (max.)
Storage Temperature Range
-55°C~+125°C
ESR (Equivalent Series Resistance)
3225
2520
Frequency Range
E.S.R
Frequency Range
E.S.R
12~15.999MHz
150 Ω max.
8~9.9999 MHz
250 Ω max.
16~29.999MHz
100 Ω max.
10~11.999 MHz
200 Ω max.
30~54MHz
70 Ω max.
12~29.999 MHz
80 Ω max.
30~125 MHz
40 Ω max.
Frequency stability Vs Operating temperature range
ppm
±5
±10
±15
±20
±25
±30
-10~+60
-20~+70
○: Available
×: Not available
Temp. (°C)
-40~+85
▲: Conditional
让世界爱上中国智造 www.chuanjingjscc.com
7
川晶科技
2520
3225
[ 2.5×2.0×0.55 mm ]
[ 3.2×2.5×0.70 mm ]
Frequency Range
Fundamental
8MHz~125MHz
Outline Dimensions (Unit: mm)
2520 (2.5×2.0×0.55 mm)
1.0
2.55±0.05
2
Top View
2
4
3
0.9 0.65 0.9
0.55±0.05
1
1
0.7
3
2.05±0.05
4
0.85 1.0
0.9
Top View Suggested Layout
Buttom View
Side View
3225 (3.2×2.5×0.70 mm)
3.2±0.1
0.9
3
1
1.4
0.8
1.4
2
1
2
Top View
4
Side View
1.2 0.5
0.7
0.7±0.1
2.5±0.1
1.2
4
3
Buttom View
8
很抱歉,暂时无法提供与“C3SB08.000F12M13”相匹配的价格&库存,您可以联系我们找货
