XC2EL89COO-114YLC-16M 数据手册
print
Crystal Unit
AEC-Q200
YSX321SC
Applications
Features
‧Industrial
‧Standard Frequency: 8 ~ 66MHz
‧Automotive
‧Low Impedance Performance
‧Dimensions: 3.20 x 2.50 x 0.70 mm
Specifications (规格参数)
Item
Nominal Frequency Range(额定频率范围)
‧AEC-Q200 Qualified
Symbol
Specifications
AT Fundamental
f_nom
Vibration Mode(震动模式)
Load Capacitance(负载电容)
CL
Frequency Tolerance(频率偏差) (at 25℃ )
Frequency Versus Temperature Characteristics(频率-温度特性)
Operating Temperature(工作温度)
Storage Temperature(储存温度)
8pF, 12pF, or specify
f_tol
±10ppm, ±30ppm, or specify
T_use
-40~+125℃, or specify
C0
3pF Max
f_tem
±50ppm, or specify
T_stg
Shunt Capacitance(静态电容)
Level of Drive(激励电平)
-55~+125℃
DL
Aging (老化)(at 25℃ )
1~200μW Max(100μW typical)
f_age
Equivalent Series Resistance (等效串联电阻(ESR))
8 ~ 9.9MHz
800Ω Max
11 ~ 11.9MHz
150Ω Max
10 ~ 10.9MHz
12 ~ 12.9MHz
8 ~ 66MHz
YSX321SC
250Ω Max
±2ppm/year Max
13 ~ 15.9MHz
80Ω Max
21 ~ 29.9MHz
60Ω Max
16 ~ 20.9MHz
100Ω Max
30 ~ 66.0MHz
Dimensions and Recommended Land Pattern (外观尺寸及推荐焊盘)
Dimensions (Unit: mm)
70Ω Max
50Ω Max
Recommended Land Pattern (Unit: mm)
www.yxc.hk
1
XC2EL89COO-114YLC-16M 价格&库存
很抱歉,暂时无法提供与“XC2EL89COO-114YLC-16M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.16390
- 50+0.93110
- 150+0.83138
- 500+0.70682
- 3000+0.65141
- 6000+0.61816
