DFA5600007
DFA5600007
    TXC(台晶)
    SMD3225_6P
    有源晶振
DFA5600007 数据手册
Differential XO DF Series Think of Frequency, Think of TXC Product Features 1. 2. 3. 4. 5. 6. 7. 8.  Application:  Fiber Channel , Gigabit Ethernet , Serial ATA , Serial Attached SCSI , PCI-Express , SDH / SONET , Ethernet Switch  Telecom , Networking , Server , Storage , Instrument 6 pads seam sealed ceramic package 3.3 and 2.5 V operation available Output Type : LVDS Output frequencies 50MHz ~ 320MHz Excellent low phase noise and jitter Tri-state function available RoHS and REACH Compliant , Pb-free , Halogen-free Industry Standard Package: 5.0 x 3.2 x 1.2 mm (CF Series) Test condition Ambient temperature:25 ± 5°C Relative humidity: 40% ~ 70% Table 1 . Electrical Specifications Parameters Symbol Min. Typ. Max. Units Conditions & Notes Common Electrical Characteristics Nominal Frequency F 50 ~ 320 MHz ± 25 Frequency Stability @ -40~85°C , Note 1 ± 30 ST ppm ± 50 Operating Temperature Topr Supply Voltage Vdd Start-up Time Tosc -40 - - @ -40~105°C , Note 1 @ -40~125°C , Note 1 125 2.5 , 3.3 (±10%) - 3rd Overtone °C V 10 ms To 90% of Final Amplitude LVDS Electrical Characteristics Current Consumption Icc - - 60 Ma RL=100Ω Icc(ST) - - 30 uA OE = Low Output Voltage High VoH - 1.43 1.6 V Output Voltage Low VoL 0.9 1.1 - V Offset Voltage - 1.125 1.250 1.375 V Output Swing (Single) - 247 330 454 mV Single Peak-to-Peak Output Swing (Differential) Vdiff 494 660 908 mV Differential Peak-to-Peak Rise / Fall Time Tr / Tf - - 0.5 ns 20% ~ 80% Output Swing Enable Voltage High - 0.7VDD - - V Note 2 Enable Voltage Low - - - 0.3VDD V Note 2 Output Enable Delay Time - - - 2 ms Output Disable Delay Time - - - 200 ns RMS Phase Jitter PJ - - 0.2 ps Standby Current Integrated from 12KHz ~ 20MHz @156.25MHz , 3.3V , Note3 Note 1 : Inclusive of frequency tolerance at 25°C , variation over temperature , supply voltage variation , 10 years aging and vibration. Note 2 : Output will be enable if OE is Logic 1 or open ; Output will be disable if OE is Logic 0. Note 3 : Phase Jitter will be slightly different according to output frequency and supply voltage. Rev. A (2023.11.30) Page 1 of 2 www.txc.com.tw Differential XO DF Series Think of Frequency, Think of TXC  Test Diagram Testing Circuit Note: 1. Above testing circuits cover all the specifications except temperature test & Jitter measurement. 2. All the testing equipment are 50 Ohm terminal. 3. OE terminal is open connection except OE function test.  Waveform Conditions  Dimensions & Footprint (Recommended) Rev. A (2023.11.30) Page 2 of 2 www.txc.com.tw
DFA5600007 价格&库存
很抱歉,暂时无法提供与“DFA5600007”相匹配的价格&库存,您可以联系我们找货
