1532P-100.000K33DTL
1532P-100.000K33DTL
    HCI(杭晶)
    SMD3225_6P
    有源晶振 100MHz ±10ppm 3.3V -40℃~+85℃ LVPECL
1532P-100.000K33DTL 数据手册
O OSCILLATOR UNIT WITH LVPECL OUTPUT IN S C I L L A T O R U N I T 1532P SMD 3.2X2.5MM CERAMIC SEAM SEAL PACKAGE. PRODUCT FEATURES PRODUCT PHOTO (NOT IN SCALE)  Small dimensions 3.2x2.5x1.3 with 6 solder pads.  Highly reliable seam sealed ceramic package.  Wide frequency range.  Low jitter and phase noise.  RoHS compliant, LEAD-FREE and HALOGEN-FREE. APPLICATIONS  High speed communication  Telecom equipment  Handheld equipment PRODUCT SPECIFICATIONS 1532P PARAMETER Nominal frequency range CONDITIONS / REMARKS 10 ~ 800MHz Supply voltage / 2.5VDC Supply current Fund., Overtone or PLL 3.3VDC Other option possible 100mA Frequency stability ±25ppm Operating temperature range / ±50ppm Maximum, Fund mode lower ICC / ±100ppm –10 to +70°C or –40 to 85°C Output waveform and load LVPECL / 50Ω See note below. Other options available. Into VCC–2 Output voltage level HIGH VCC–1.025V / VCC–0.880V Minimum / Maximum Output voltage level LOW VCC–1.810V / VCC–1.620V Minimum / Maximum Rise and Fall times 1.5ns Symmetry (duty cycle) @ 20~80~20%VCC 45~55% Phase Jitter RMS @ outputs cross point
1532P-100.000K33DTL 价格&库存
很抱歉,暂时无法提供与“1532P-100.000K33DTL”相匹配的价格&库存,您可以联系我们找货
